commit 26a4d4c00f85cb844dd11dd35e848b079c2f5e8f upstream.
We should close the fd before the return of read_attr_usbip_status.
Fixes: 3391ba0e2792 ("usbip: tools: Extract generic code to be shared with vudc backend")
Signed-off-by: Hewenliang <hewenliang4@huawei.com>
Cc: stable <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/20191025043515.20053-1-hewenliang4@huawei.com
commit 700c1018b86d0d4b3f1f2d459708c0cdf42b521d upstream.
gawk 5.0.1 generates the following regexp warnings:
GEN /home/sasha/torvalds/tools/objtool/arch/x86/lib/inat-tables.c
awk: ../arch/x86/tools/gen-insn-attr-x86.awk:260: warning: regexp escape sequence `\:' is not a known regexp operator
awk: ../arch/x86/tools/gen-insn-attr-x86.awk:350: (FILENAME=../arch/x86/lib/x86-opcode-map.txt FNR=41) warning: regexp escape sequence `\&' is not a known regexp operator
Ealier versions of gawk are not known to generate these warnings. The
gawk manual referenced below does not list characters ':' and '&' as
needing escaping, so 'unescape' them. See
https://www.gnu.org/software/gawk/manual/html_node/Escape-Sequences.html
for more info.
Running diff on the output generated by the script before and after
applying the patch reported no differences.
[ bp: Massage commit message. ]
[ Caught the respective tools header discrepancy. ]
Reported-by: kbuild test robot <lkp@intel.com>
Signed-off-by: Alexander Kapshuk <alexander.kapshuk@gmail.com>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: "Peter Zijlstra (Intel)" <peterz@infradead.org>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: x86-ml <x86@kernel.org>
Link: https://lkml.kernel.org/r/20190924044659.3785-1-alexander.kapshuk@gmail.com
[ Upstream commit f8ddf49b420112e28bdd23d7ad52d7991a0ccbe3 ]
Fix warnings found using static analysis with cppcheck, use %d printf
format specifier for signed ints rather than %u
Signed-off-by: Erik Schmauss <erik.schmauss@intel.com>
[ Upstream commit 69f8117f17b332a68cd8f4bf8c2d0d3d5b84efc5 ]
Use TEST_GEN_PROGS and don't redefine all, this makes the out-of-tree
build work. We need to move the extra dependencies below the include
of lib.mk, because it adds the $(OUTPUT) prefix if it's defined.
We can also drop the clean rule, lib.mk does it for us.
[ Upstream commit 266bac361d5677e61a6815bd29abeb3bdced2b07 ]
For the out-of-tree build to work we need to tell switch_endian_test
to look for check-reversed.S in $(OUTPUT).
[ Upstream commit 27825349d7b238533a47e3d98b8bb0efd886b752 ]
We should use TEST_GEN_PROGS, not TEST_PROGS. That tells the selftests
makefile (lib.mk) that those tests are generated (built), and so it
adds the $(OUTPUT) prefix for us, making the out-of-tree build work
correctly.
It also means we don't need our own clean rule, lib.mk does it.
We also have to update the signal_tm rule to use $(OUTPUT).
Signed-off-by: Joel Stanley <joel@jms.id.au>
[ Upstream commit 04d5e4bd37516ad60854eb74592c7dbddd75d277 ]
Printf's say errno but print the string version of error.
Make consistent.
Signed-off-by: Jerry Hoemann <jerry.hoemann@hpe.com>
Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org>
[ Upstream commit 9a244229a4b850b11952a0df79607c69b18fd8df ]
When /dev/watchdog open fails, watchdog exits with "watchdog not enabled"
message. This is incorrect when open fails due to insufficient privilege.
Fix message to clearly state the reason when open fails with EACCESS when
a non-root user runs it.
[ Upstream commit 2452c96e617a0ff6fb2692e55217a3fa57a7322c ]
Test $comm in kprobe-event argument syntax testcase
only if it is supported on the kernel because
$comm has been introduced 4.8 kernel.
So on older stable kernel, it should be skipped.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
[ Upstream commit e325808c0051b16729ffd472ff887c6cae5c6317 ]
Currently the call to atoi is being passed a single char string
that is not null terminated, so there is a potential read overrun
along the stack when parsing for an integer value. Fix this by
instead using a 2 char string that is initialized to all zeros
to ensure that a 1 char read into the string is always terminated
with a \0.
Detected by cppcheck:
"Invalid atoi() argument nr 1. A nul-terminated string is required."
commit 0161a94e2d1c713bd34d72bc0239d87c31747bf7 upstream.
gpio tools fail to build correctly with make parallelization:
$ make -s -j24
ld: gpio-utils.o: file not recognized: file truncated
make[1]: *** [/home/labbott/linux_upstream/tools/build/Makefile.build:145: lsgpio-in.o] Error 1
make: *** [Makefile:43: lsgpio-in.o] Error 2
make: *** Waiting for unfinished jobs....
This is because gpio-utils.o is used across multiple targets.
Fix this by making gpio-utios.o a proper dependency.
Cc: <stable@vger.kernel.org>
Signed-off-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
[ Upstream commit 8a5e0af240e07dd3d4897eb8ff52aab757da7fab ]
pcitest is currently broken due to the following compiler error
and related warning. Fix by changing the run_test() function
signature to return an integer result.
pcitest.c: In function run_test:
pcitest.c:143:9: warning: return with a value, in function
returning void
return (ret < 0) ? ret : 1 - ret; /* return 0 if test succeeded */
pcitest.c: In function main:
pcitest.c:232:9: error: void value not ignored as it ought to be
return run_test(test);
Fixes: fef31ecaaf2c ("tools: PCI: Fix compilation warnings")
Signed-off-by: Alan Mikhak <alan.mikhak@sifive.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Reviewed-by: Paul Walmsley <paul.walmsley@sifive.com>
[ Upstream commit fef31ecaaf2c5c54db85b35e893bf8abec96b93f ]
Current compilation produces the following warnings:
tools/pci/pcitest.c: In function 'run_test':
tools/pci/pcitest.c:56:9: warning: unused variable 'time'
[-Wunused-variable]
double time;
tools/pci/pcitest.c:55:25: warning: unused variable 'end'
[-Wunused-variable]
struct timespec start, end;
tools/pci/pcitest.c:55:18: warning: unused variable 'start'
[-Wunused-variable]
tools/pci/pcitest.c:146:1: warning: control reaches end of non-void
function [-Wreturn-type]
Fix them:
- remove unused variables
- change function return from int to void, since it's not used
Signed-off-by: Gustavo Pimentel <gustavo.pimentel@synopsys.com>
[lorenzo.pieralisi@arm.com: rewrote the commit log]
Reviewed-by: Kishon Vijay Abraham I <kishon@ti.com>
commit 5c089fd0c73411f2170ab795c9ffc16718c7d007 upstream.
If the entry is deleted from the IDR between the call to
radix_tree_iter_find() and rcu_dereference_raw(), idr_get_next()
will return NULL, which will end the iteration prematurely. We should
instead continue to the next entry in the IDR. This only happens if the
iteration is protected by the RCU lock. Most IDR users use a spinlock
or semaphore to exclude simultaneous modifications. It was noticed once
the PID allocator was converted to use the IDR, as it uses the RCU lock,
but there may be other users elsewhere in the kernel.
We can't use the normal pattern of calling radix_tree_deref_retry()
(which catches both a retry entry in a leaf node and a node entry in
the root) as the IDR supports storing entries which are unaligned,
which will trigger an infinite loop if they are encountered. Instead,
we have to explicitly check whether the entry is a retry entry.
Fixes: 0a835c4f090a ("Reimplement IDR and IDA using the radix tree")
Reported-by: Brendan Gregg <bgregg@netflix.com>
Tested-by: Brendan Gregg <bgregg@netflix.com>
Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org>
commit 722ddfde366fd46205456a9c5ff9b3359dc9a75e upstream.
The final sort might get confused when the comparison is done over
bigger numbers than int like for -s time.
Check the following report for longer workloads:
$ perf report -s time -F time,overhead --stdio
Fix hist_entry__sort() to properly return int64_t and not possible cut
int.
Fixes: 043ca389a318 ("perf tools: Use hpp formats to sort final output")
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Michael Petlan <mpetlan@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: stable@vger.kernel.org # v3.16+
Link: http://lore.kernel.org/lkml/20191104232711.16055-1-jolsa@kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit 4a6a6f5c4aeedb72db871d60bfcca89835f317aa upstream.
make TARGETS=gpio kselftest fails with:
Makefile:23: tools/build/Makefile.include: No such file or directory
When the gpio tool make is invoked from tools Makefile, srctree is
cleared and the current logic check for srctree equals to empty
string to determine srctree location from CURDIR.
When the build in invoked from selftests/gpio Makefile, the srctree
is set to "." and the same logic used for srctree equals to empty is
needed to determine srctree.
Check building_out_of_srctree undefined as the condition for both
cases to fix "make TARGETS=gpio kselftest" build failure.
Signed-off-by: Shuah Khan <skhan@linuxfoundation.org>
commit 5b216ea1c40cf06eead15054c70e238c9bd4729e upstream.
Newer versions of GCC (>= 9) demand that the size of the string to be
copied must be explicitly smaller than the size of the destination.
Thus, the NULL char has to be taken into account on strncpy.
This will avoid the following compiling error:
tlbie_test.c: In function 'main':
tlbie_test.c:639:4: error: 'strncpy' specified bound 100 equals destination size
strncpy(logdir, optarg, LOGDIR_NAME_SIZE);
cc1: all warnings being treated as errors
Cc: stable@vger.kernel.org # v4.14
Signed-off-by: Desnes A. Nunes do Rosario <desnesn@linux.ibm.com>
Link: https://lore.kernel.org/r/20191003211010.9711-1-desnesn@linux.ibm.com
[sandipan: Backported to v4.14]
Signed-off-by: Sandipan Das <sandipan@linux.ibm.com>
commit 93cad5f789951eaa27c3392b15294b4e51253944 upstream.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com>
[mpe: Some minor fixes to make it build]
Link: https://lore.kernel.org/r/20190924035254.24612-4-aneesh.kumar@linux.ibm.com
[ Upstream commit d64479a3e3f9924074ca7b50bd72fa5211dca9c1 ]
This test reports EINVAL for getsockopt(SOL_SOCKET, SO_DOMAIN)
occasionally due to the uninitialized length parameter.
Initialize it to fix this, and also use int for "test_family" to comply
with the API standard.
Fixes: d6a61f80b871 ("soreuseport: test mixed v4/v6 sockets")
Reported-by: Maciej Żenczykowski <maze@google.com>
Signed-off-by: Wei Wang <weiwan@google.com>
Cc: Craig Gallek <cgallek@google.com>
[ Upstream commit 1abecfcaa7bba21c9985e0136fa49836164dd8fd ]
The memory @orig_flags is allocated by strdup(), it is freed on the
normal path, but leak to free on the error path.
Fix this by adding free(orig_flags) on the error path.
Fixes: 0e11115644b3 ("perf kmem: Print gfp flags in human readable string")
Signed-off-by: Yunfeng Ye <yeyunfeng@huawei.com>
Cc: Feilong Lin <linfeilong@huawei.com>
Cc: Hu Shiyuan <hushiyuan@huawei.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Link: http://lore.kernel.org/lkml/f9e9f458-96f3-4a97-a1d5-9feec2420e07@huawei.com
[ Upstream commit ae199c580da1754a2b051321eeb76d6dacd8707b ]
There is a memory leak problem in the failure paths of
build_cl_output(), so fix it.
Acked-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lore.kernel.org/lkml/4d3c0178-5482-c313-98e1-f82090d2d456@huawei.com
[ Upstream commit 6bdfd9f118bd59cf0f85d3bf4b72b586adea17c1 ]
The Intel fixed counters use a special table to override the JSON
information.
During this override the period information from the JSON file got
dropped, which results in inst_retired.any and similar running with
frequency mode instead of a period.
Just specify the expected period in the table.
Cc: Jiri Olsa <jolsa@kernel.org>
Link: http://lore.kernel.org/lkml/20190927233546.11533-2-andi@firstfloor.org
[ Upstream commit ee212d6ea20887c0ef352be8563ca13dbf965906 ]
Whenever an mmap/mmap2 event occurs, the map tree must be updated to add a new
entry. If a new map overlaps a previous map, the overlapped section of the
previous map is effectively unmapped, but the non-overlapping sections are
still valid.
maps__fixup_overlappings() is responsible for creating any new map entries from
the previously overlapped map. It optionally creates a before and an after map.
When creating the after map the existing code failed to adjust the map.pgoff.
This meant the new after map would incorrectly calculate the file offset
for the ip. This results in incorrect symbol name resolution for any ip in the
after region.
Make maps__fixup_overlappings() correctly populate map.pgoff.
Add an assert that new mapping matches old mapping at the beginning of
the after map.
Committer-testing:
Validated correct parsing of libcoreclr.so symbols from .NET Core 3.0 preview9
(which didn't strip symbols).
Preparation:
~/dotnet3.0-preview9/dotnet new webapi -o perfSymbol
cd perfSymbol
~/dotnet3.0-preview9/dotnet publish
perf record ~/dotnet3.0-preview9/dotnet \
bin/Debug/netcoreapp3.0/publish/perfSymbol.dll
^C
Before:
perf script --show-mmap-events 2>&1 | grep -e MMAP -e unknown |\
grep libcoreclr.so | head -n 4
dotnet 1907 373352.698780: PERF_RECORD_MMAP2 1907/1907: \
[0x7fe615726000(0x768000) @ 0 08:02 5510620 765057155]: \
r-xp .../3.0.0-preview9-19423-09/libcoreclr.so
dotnet 1907 373352.701091: PERF_RECORD_MMAP2 1907/1907: \
[0x7fe615974000(0x1000) @ 0x24e000 08:02 5510620 765057155]: \
rwxp .../3.0.0-preview9-19423-09/libcoreclr.so
dotnet 1907 373352.701241: PERF_RECORD_MMAP2 1907/1907: \
[0x7fe615c42000(0x1000) @ 0x51c000 08:02 5510620 765057155]: \
dotnet 1907 373352.705249: 250000 cpu-clock: \
7fe6159a1f99 [unknown] \
(.../3.0.0-preview9-19423-09/libcoreclr.so)
After:
All the [unknown] symbols were resolved.
Signed-off-by: Steve MacLean <Steve.MacLean@Microsoft.com>
Tested-by: Brian Robbins <brianrob@microsoft.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Eric Saint-Etienne <eric.saint.etienne@oracle.com>
Cc: John Keeping <john@metanate.com>
Cc: John Salem <josalem@microsoft.com>
Cc: Leo Yan <leo.yan@linaro.org>
Cc: Song Liu <songliubraving@fb.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Tom McDonald <thomas.mcdonald@microsoft.com>
Link: http://lore.kernel.org/lkml/BN8PR21MB136270949F22A6A02335C238F7800@BN8PR21MB1362.namprd21.prod.outlook.com
[ Upstream commit e3e2cf3d5b1fe800b032e14c0fdcd9a6fb20cf3b ]
An optimized build such as:
make -C tools/perf CLANG=1 CC=clang EXTRA_CFLAGS="-O3
will turn the dereference operation into a ud2 instruction, raising a
SIGILL rather than a SIGSEGV. Use raise(..) for correctness and clarity.
Similar issues were addressed in Numfor Mbiziwo-Tiapo's patch:
https://lkml.org/lkml/2019/7/8/1234
Committer testing:
Before:
[root@quaco ~]# perf test hooks
55: perf hooks : Ok
[root@quaco ~]# perf test -v hooks
55: perf hooks :
--- start ---
test child forked, pid 17092
SIGSEGV is observed as expected, try to recover.
Fatal error (SEGFAULT) in perf hook 'test'
test child finished with 0
---- end ----
perf hooks: Ok
[root@quaco ~]#
After:
55: perf hooks : Ok
55: perf hooks :
--- start ---
test child forked, pid 17909
---- end ----
perf hooks: Ok
[root@quaco ~]#
Fixes: a074865e60ed ("perf tools: Introduce perf hooks")
Signed-off-by: Ian Rogers <irogers@google.com>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lore.kernel.org/lkml/20190925195924.152834-2-irogers@google.com
[ Upstream commit 4b0b2b096da9d296e0e5668cdfba8613bd6f5bc8 ]
Unconditionally defining _FORTIFY_SOURCE can break tools that don't work
with it, such as memory sanitizers:
https://github.com/google/sanitizers/wiki/AddressSanitizer#faq
Fixes: 4b6ab94eabe4 ("perf subcmd: Create subcmd library")
Link: http://lore.kernel.org/lkml/20190925195924.152834-1-irogers@google.com
commit b59711e9b0d22fd47abfa00602fd8c365cdd3ab7 upstream.
During perf inject --jit, JIT_CODE_MOVE records were injecting MMAP records
with an incorrect filename. Specifically it was missing the ".so" suffix.
Further the JIT_CODE_LOAD record were silently truncating the
jr->load.code_index field to 32 bits before generating the filename.
Make both records emit the same filename based on the full 64 bit
code_index field.
Fixes: 9b07e27f88b9 ("perf inject: Add jitdump mmap injection support")
Cc: stable@vger.kernel.org # v4.6+
Cc: Brian Robbins <brianrob@microsoft.com>
Link: http://lore.kernel.org/lkml/BN8PR21MB1362FF8F127B31DBF4121528F7800@BN8PR21MB1362.namprd21.prod.outlook.com
commit 7d4c85b7035eb2f9ab217ce649dcd1bfaf0cacd3 upstream.
The 'test_dir' variable is assigned to the 'release' array which is
out-of-scope 3 lines later.
Extend the scope of the 'release' array so that an out-of-scope array
isn't accessed.
Bug detected by clang's address sanitizer.
Fixes: 07bc5c699a3d ("perf tools: Make fetch_kernel_version() publicly available")
Cc: stable@vger.kernel.org # v4.4+
Link: http://lore.kernel.org/lkml/20190926220018.25402-1-irogers@google.com
[ Upstream commit b63fd11cced17fcb8e133def29001b0f6aaa5e06 ]
When using 'perf stat' with repeat and interval option, it shows wrong
values for events.
The wrong values will be shown for the first interval on the second and
subsequent repetitions.
Without the fix:
# perf stat -r 3 -I 2000 -e faults -e sched:sched_switch -a sleep 5
2.000282489 53 faults
2.000282489 513 sched:sched_switch
4.005478208 3,721 faults
4.005478208 2,666 sched:sched_switch
5.025470933 395 faults
5.025470933 1,307 sched:sched_switch
2.009602825 1,84,46,74,40,73,70,95,47,520 faults <------
2.009602825 1,84,46,74,40,73,70,95,49,568 sched:sched_switch <------
4.019612206 4,730 faults
4.019612206 2,746 sched:sched_switch
5.039615484 3,953 faults
5.039615484 1,496 sched:sched_switch
2.000274620 1,84,46,74,40,73,70,95,47,520 faults <------
2.000274620 1,84,46,74,40,73,70,95,47,520 sched:sched_switch <------
4.000480342 4,282 faults
4.000480342 2,303 sched:sched_switch
5.000916811 1,322 faults
5.000916811 1,064 sched:sched_switch
prev_raw_counts is allocated when using intervals. This is used when
calculating the difference in the counts of events when using interval.
The current counts are stored in prev_raw_counts to calculate the
differences in the next iteration.
On the first interval of the second and subsequent repetitions,
prev_raw_counts would be the values stored in the last interval of the
previous repetitions, while the current counts will only be for the
first interval of the current repetition.
Hence there is a possibility of events showing up as big number.
Fix this by resetting prev_raw_counts whenever perf stat repeats the
command.
With the fix:
2.019349347 2,597 faults
2.019349347 2,753 sched:sched_switch
4.019577372 3,098 faults
4.019577372 2,532 sched:sched_switch
5.019415481 1,879 faults
5.019415481 1,356 sched:sched_switch
2.000178813 8,468 faults
2.000178813 2,254 sched:sched_switch
4.000404621 7,440 faults
4.000404621 1,266 sched:sched_switch
5.040196079 2,458 faults
5.040196079 556 sched:sched_switch
2.000191939 6,870 faults
2.000191939 1,170 sched:sched_switch
4.000414103 541 faults
4.000414103 902 sched:sched_switch
5.000809863 450 faults
5.000809863 364 sched:sched_switch
Committer notes:
This was broken since the cset introducing the --interval feature, i.e.
--repeat + --interval wasn't tested at that point, add the Fixes tag so
that automatic scripts can pick this up.
Fixes: 13370a9b5bb8 ("perf stat: Add interval printing")
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Tested-by: Ravi Bangoria <ravi.bangoria@linux.ibm.com>
Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Cc: stable@vger.kernel.org # v3.9+
Link: http://lore.kernel.org/lkml/20190904094738.9558-2-srikar@linux.vnet.ibm.com
[ Fixed up conflicts with libperf, i.e. some perf_{evsel,evlist} lost the 'perf' prefix ]
[ Upstream commit 443f2d5ba13d65ccfd879460f77941875159d154 ]
Observe a segmentation fault when 'perf stat' is asked to repeat forever
with the interval option.
Without fix:
# perf stat -r 0 -I 5000 -e cycles -a sleep 10
# time counts unit events
5.000211692 3,13,89,82,34,157 cycles
10.000380119 1,53,98,52,22,294 cycles
10.040467280 17,16,79,265 cycles
Segmentation fault
This problem was only observed when we use forever option aka -r 0 and
works with limited repeats. Calling print_counter with ts being set to
NULL, is not a correct option when interval is set. Hence avoid
print_counter(NULL,..) if interval is set.
With fix:
5.019866622 3,15,14,43,08,697 cycles
10.039865756 3,15,16,31,95,261 cycles
10.059950628 1,26,05,47,158 cycles
5.009902655 3,14,52,62,33,932 cycles
10.019880228 3,14,52,22,89,154 cycles
10.030543876 66,90,18,333 cycles
5.009848281 3,14,51,98,25,437 cycles
10.029854402 3,15,14,93,04,918 cycles
5.009834177 3,14,51,95,92,316 cycles
Committer notes:
Did the 'git bisect' to find the cset introducing the problem to add the
Fixes tag below, and at that time the problem reproduced as:
(gdb) run stat -r0 -I500 sleep 1
<SNIP>
Program received signal SIGSEGV, Segmentation fault.
print_interval (prefix=prefix@entry=0x7fffffffc8d0 "", ts=ts@entry=0x0) at builtin-stat.c:866
866 sprintf(prefix, "%6lu.%09lu%s", ts->tv_sec, ts->tv_nsec, csv_sep);
(gdb) bt
#0 print_interval (prefix=prefix@entry=0x7fffffffc8d0 "", ts=ts@entry=0x0) at builtin-stat.c:866
#1 0x000000000041860a in print_counters (ts=ts@entry=0x0, argc=argc@entry=2, argv=argv@entry=0x7fffffffd640) at builtin-stat.c:938
#2 0x0000000000419a7f in cmd_stat (argc=2, argv=0x7fffffffd640, prefix=<optimized out>) at builtin-stat.c:1411
#3 0x000000000045c65a in run_builtin (p=p@entry=0x6291b8 <commands+216>, argc=argc@entry=5, argv=argv@entry=0x7fffffffd640) at perf.c:370
#4 0x000000000045c893 in handle_internal_command (argc=5, argv=0x7fffffffd640) at perf.c:429
#5 0x000000000045c8f1 in run_argv (argcp=argcp@entry=0x7fffffffd4ac, argv=argv@entry=0x7fffffffd4a0) at perf.c:473
#6 0x000000000045cac9 in main (argc=<optimized out>, argv=<optimized out>) at perf.c:588
(gdb)
Mostly the same as just before this patch:
0x00000000005874a7 in print_interval (config=0xa1f2a0 <stat_config>, evlist=0xbc9b90, prefix=0x7fffffffd1c0 "`", ts=0x0) at util/stat-display.c:964
964 sprintf(prefix, "%6lu.%09lu%s", ts->tv_sec, ts->tv_nsec, config->csv_sep);
(gdb) bt
#0 0x00000000005874a7 in print_interval (config=0xa1f2a0 <stat_config>, evlist=0xbc9b90, prefix=0x7fffffffd1c0 "`", ts=0x0) at util/stat-display.c:964
#1 0x0000000000588047 in perf_evlist__print_counters (evlist=0xbc9b90, config=0xa1f2a0 <stat_config>, _target=0xa1f0c0 <target>, ts=0x0, argc=2, argv=0x7fffffffd670)
at util/stat-display.c:1172
#2 0x000000000045390f in print_counters (ts=0x0, argc=2, argv=0x7fffffffd670) at builtin-stat.c:656
#3 0x0000000000456bb5 in cmd_stat (argc=2, argv=0x7fffffffd670) at builtin-stat.c:1960
#4 0x00000000004dd2e0 in run_builtin (p=0xa30e00 <commands+288>, argc=5, argv=0x7fffffffd670) at perf.c:310
#5 0x00000000004dd54d in handle_internal_command (argc=5, argv=0x7fffffffd670) at perf.c:362
#6 0x00000000004dd694 in run_argv (argcp=0x7fffffffd4cc, argv=0x7fffffffd4c0) at perf.c:406
#7 0x00000000004dda11 in main (argc=5, argv=0x7fffffffd670) at perf.c:531
(gdb)
Fixes: d4f63a4741a8 ("perf stat: Introduce print_counters function")
Cc: stable@vger.kernel.org # v4.2+
Link: http://lore.kernel.org/lkml/20190904094738.9558-3-srikar@linux.vnet.ibm.com
[ Upstream commit 0216234c2eed1367a318daeb9f4a97d8217412a0 ]
We release wrong pointer on error path in cpu_cache_level__read
function, leading to segfault:
(gdb) r record ls
Starting program: /root/perf/tools/perf/perf record ls
[ perf record: Woken up 1 times to write data ]
double free or corruption (out)
Thread 1 "perf" received signal SIGABRT, Aborted.
0x00007ffff7463798 in raise () from /lib64/power9/libc.so.6
(gdb) bt
#0 0x00007ffff7463798 in raise () from /lib64/power9/libc.so.6
#1 0x00007ffff7443bac in abort () from /lib64/power9/libc.so.6
#2 0x00007ffff74af8bc in __libc_message () from /lib64/power9/libc.so.6
#3 0x00007ffff74b92b8 in malloc_printerr () from /lib64/power9/libc.so.6
#4 0x00007ffff74bb874 in _int_free () from /lib64/power9/libc.so.6
#5 0x0000000010271260 in __zfree (ptr=0x7fffffffa0b0) at ../../lib/zalloc..
#6 0x0000000010139340 in cpu_cache_level__read (cache=0x7fffffffa090, cac..
#7 0x0000000010143c90 in build_caches (cntp=0x7fffffffa118, size=<optimiz..
Releasing the proper pointer.
Fixes: 720e98b5faf1 ("perf tools: Add perf data cache feature")
Cc: stable@vger.kernel.org: # v4.6+
Link: http://lore.kernel.org/lkml/20190912105235.10689-1-jolsa@kernel.org
[ Upstream commit e0d2615856b2046c2e8d5bfd6933f37f69703b0b ]
If the re-allocation of tep->cmdlines succeeds, then the previous
allocation of tep->cmdlines will be freed. If we later fail in
add_new_comm(), we must not free cmdlines, and also should assign
tep->cmdlines to the new allocation. Otherwise when freeing tep, the
tep->cmdlines will be pointing to garbage.
Fixes: a6d2a61ac653a ("tools lib traceevent: Remove some die() calls")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: linux-trace-devel@vger.kernel.org
Link: http://lkml.kernel.org/r/20190828191819.970121417@goodmis.org
[ Upstream commit 26acf400d2dcc72c7e713e1f55db47ad92010cc2 ]
Naresh Kamboju reported, that on the i386 build pr_err()
doesn't get defined properly due to header ordering:
perf-in.o: In function `libunwind__x86_reg_id':
tools/perf/util/libunwind/../../arch/x86/util/unwind-libunwind.c:109:
undefined reference to `pr_err'
Reported-by: Naresh Kamboju <naresh.kamboju@linaro.org>
Cc: David Ahern <dsahern@gmail.com>
[ Upstream commit 815c1560bf8fd522b8d93a1d727868b910c1cc24 ]
With Java 11 there is no seperate JRE anymore.
Details:
https://coderanch.com/t/701603/java/JRE-JDK
Therefore the detection of the JRE needs to be adapted.
This change works for s390 and x86. I have not tested other platforms.
Committer testing:
Continues to work with the OpenJDK 8:
$ rm -f ~acme/lib64/libperf-jvmti.so
$ rpm -qa | grep jdk-devel
java-1.8.0-openjdk-devel-1.8.0.222.b10-0.fc30.x86_64
$ git log --oneline -1
a51937170f33 (HEAD -> perf/core) perf build: Add detection of java-11-openjdk-devel package
$ rm -rf /tmp/build/perf ; mkdir -p /tmp/build/perf ; make -C tools/perf O=/tmp/build/perf install > /dev/null 2>1
$ ls -la ~acme/lib64/libperf-jvmti.so
-rwxr-xr-x. 1 acme acme 230744 Sep 24 16:46 /home/acme/lib64/libperf-jvmti.so
Suggested-by: Andreas Krebbel <krebbel@linux.ibm.com>
Signed-off-by: Thomas Richter <tmricht@linux.ibm.com>
Cc: Hendrik Brueckner <brueckner@linux.ibm.com>
Cc: Vasily Gorbik <gor@linux.ibm.com>
Link: http://lore.kernel.org/lkml/20190909114116.50469-4-tmricht@linux.ibm.com
commit 82a2f88458d70704be843961e10b5cef9a6e95d3 upstream.
The tools/lib/traceevent/Makefile had a test added to it to detect a failure
of the "nm" when making the dynamic list file (whatever that is). The
problem is that the test sorts the values "U W w" and some versions of sort
will place "w" ahead of "W" (even though it has a higher ASCII value, and
break the test.
Add 'tr "w" "W"' to merge the two and not worry about the ordering.
Reported-by: Tzvetomir Stoyanov <tstoyanov@vmware.com>
Cc: David Carrillo-Cisneros <davidcc@google.com>
Cc: He Kuang <hekuang@huawei.com>
Cc: Michal rarek <mmarek@suse.com>
Cc: Paul Turner <pjt@google.com>
Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Fixes: 6467753d61399 ("tools lib traceevent: Robustify do_generate_dynamic_list_file")
Link: http://lkml.kernel.org/r/20190805130150.25acfeb1@gandalf.local.home
[ Upstream commit e97fd1383cd77c467d2aed7fa4e596789df83977 ]
To be compliant with XDG user directory layout, the user's plugin
directory is changed from ~/.traceevent/plugins to
~/.local/lib/traceevent/plugins/
Suggested-by: Patrick McLean <chutzpah@gentoo.org>
Signed-off-by: Tzvetomir Stoyanov <tstoyanov@vmware.com>
Cc: Patrick McLean <chutzpah@gentoo.org>
Link: https://lore.kernel.org/linux-trace-devel/20190313144206.41e75cf8@patrickm/
Link: http://lore.kernel.org/linux-trace-devel/20190801074959.22023-4-tz.stoyanov@gmail.com
Link: http://lore.kernel.org/lkml/20190805204355.344622683@goodmis.org
[ Upstream commit b92675f4a9c02dd78052645597dac9e270679ddf ]
While tracing a program that calls isatty(3), I noticed that strace
reported TCGETS for the request argument of the underlying ioctl(2)
syscall while perf trace reported TCSETS. strace is corrrect. The bug in
perf was due to the tty ioctl beauty table starting at 0x5400 rather
than 0x5401.
Committer testing:
Using augmented_raw_syscalls.o and settings to make 'perf trace'
use strace formatting, i.e. with this in ~/.perfconfig
# cat ~/.perfconfig
[trace]
add_events = /home/acme/git/linux/tools/perf/examples/bpf/augmented_raw_syscalls.c
show_zeros = yes
show_duration = no
no_inherit = yes
show_timestamp = no
show_arg_names = no
args_alignment = 40
show_prefix = yes
# strace -e ioctl stty > /dev/null
ioctl(0, TCGETS, {B38400 opost isig icanon echo ...}) = 0
ioctl(1, TIOCGWINSZ, 0x7fff8a9b0860) = -1 ENOTTY (Inappropriate ioctl for device)
ioctl(1, TCGETS, 0x7fff8a9b0540) = -1 ENOTTY (Inappropriate ioctl for device)
+++ exited with 0 +++
Before:
# perf trace -e ioctl stty > /dev/null
ioctl(0, TCSETS, 0x7fff2cf79f20) = 0
ioctl(1, TIOCSWINSZ, 0x7fff2cf79f40) = -1 ENOTTY (Inappropriate ioctl for device)
ioctl(1, TCSETS, 0x7fff2cf79c20) = -1 ENOTTY (Inappropriate ioctl for device)
After:
ioctl(0, TCGETS, 0x7ffed0763920) = 0
ioctl(1, TIOCGWINSZ, 0x7ffed0763940) = -1 ENOTTY (Inappropriate ioctl for device)
ioctl(1, TCGETS, 0x7ffed0763620) = -1 ENOTTY (Inappropriate ioctl for device)
Signed-off-by: Benjamin Peterson <benjamin@python.org>
Fixes: 1cc47f2d46206d67285aea0ca7e8450af571da13 ("perf trace beauty ioctl: Improve 'cmd' beautifier")
Link: http://lkml.kernel.org/r/20190823033625.18814-1-benjamin@python.org
[ Upstream commit d9c5c083416500e95da098c01be092b937def7fa ]
Following the patch 'perf stat: Fix --no-scale', an alignment trap
happens in process_counter_values() on ARMv7 platforms due to the
attempt to copy non 64 bits aligned double words (pointed by 'count')
via a NEON vectored instruction ('vld1' with 64 bits alignment
constraint).
This patch sets a 64 bits alignment constraint on 'contents[]' field in
'struct xyarray' since the 'count' pointer used above points to such a
structure.
Signed-off-by: Gerald Baeza <gerald.baeza@st.com>
Cc: Alexandre Torgue <alexandre.torgue@st.com>
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Link: http://lkml.kernel.org/r/1566464769-16374-1-git-send-email-gerald.baeza@st.com
[ Upstream commit 0a4d8fb229dd78f9e0752817339e19e903b37a60 ]
Same as in the commit 01766229533f ("perf record: Support s390 random
socket_id assignment"), aarch64 also have this problem.
Without this fix:
[root@localhost perf]# ./perf report --header -I -v
socket_id number is too big.You may need to upgrade the perf tool.
# captured on : Thu Aug 1 22:58:38 2019
# header version : 1
# Core ID and Socket ID information is not available
With this fix:
cpumask list: 0-31
cpumask list: 32-63
cpumask list: 64-95
cpumask list: 96-127
# CPU 0: Core ID 0, Socket ID 36
# CPU 1: Core ID 1, Socket ID 36
# CPU 126: Core ID 126, Socket ID 8442
# CPU 127: Core ID 127, Socket ID 8442
Signed-off-by: Tan Xiaojun <tanxiaojun@huawei.com>
Cc: Alexey Budankov <alexey.budankov@linux.intel.com>
Cc: Kan Liang <kan.liang@linux.intel.com>
Cc: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: Tzvetomir Stoyanov (VMware) <tz.stoyanov@gmail.com>
Link: http://lkml.kernel.org/r/1564717737-21602-1-git-send-email-tanxiaojun@huawei.com
[ Upstream commit 4fe94ce1c6ba678b5f12b94bb9996eea4fc99e85 ]
To get the expected output we have to ignore whatever changes the user
has in its ~/.perfconfig file, so set PERF_CONFIG to /dev/null to
achieve that.
Before:
# egrep 'trace|show_' ~/.perfconfig
[trace]
show_zeros = yes
show_duration = no
show_timestamp = no
show_arg_names = no
show_prefix = yes
# echo $PERF_CONFIG
# perf test "trace + vfs_getname"
70: Check open filename arg using perf trace + vfs_getname: FAILED!
# export PERF_CONFIG=/dev/null
70: Check open filename arg using perf trace + vfs_getname: Ok
After:
[trace]
show_zeros = yes
show_duration = no
show_timestamp = no
show_arg_names = no
show_prefix = yes
# echo $PERF_CONFIG
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Luis Cláudio Gonçalves <lclaudio@redhat.com>
Cc: Taeung Song <treeze.taeung@gmail.com>
Link: https://lkml.kernel.org/n/tip-3up27pexg5i3exuzqrvt4m8u@git.kernel.org
commit f73b3cc39c84220e6dccd463b5c8279b03514646 upstream.
If the build user has the CFLAGS variable set in their environment,
objtool blindly appends to it, which can cause unexpected behavior.
Clobber CFLAGS to ensure consistent objtool compilation behavior.
Reported-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Tested-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Link: https://lkml.kernel.org/r/83a276df209962e6058fcb6c615eef9d401c21bc.1567121311.git.jpoimboe@redhat.com
CC: Nathan Chancellor <natechancellor@gmail.com>
commit 056d28d135bca0b1d0908990338e00e9dadaf057 upstream.
If it is not in the default location, compilation fails at several points.
Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Link: https://lkml.kernel.org/r/91a25e992566a7968fedc89ec80e7f4c83ad0548.1553622500.git.jpoimboe@redhat.com
[ Upstream commit eeb71c950bc6eee460f2070643ce137e067b234c ]
turbostat could be terminated by general protection fault on some latest
hardwares which (for example) support 9 levels of C-states and show 18
"tADDED" lines. That bloats the total output and finally causes buffer
overrun. So let's extend the buffer to avoid this.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Len Brown <len.brown@intel.com>
[ Upstream commit 03531482402a2bc4ab93cf6dde46833775e035e9 ]
The -w argument in x86_energy_perf_policy currently triggers an
unconditional segfault.
This is because the argument string reads: "+a:c:dD:E:e:f:m:M:rt:u:vw" and
yet the argument handler expects an argument.
When parse_optarg_string is called with a null argument, we then proceed to
crash in strncmp, not horribly friendly.
The man page describes -w as taking an argument, the long form
(--hwp-window) is correctly marked as taking a required argument, and the
code expects it.
As such, this patch simply marks the short form (-w) as requiring an
argument.
Signed-off-by: Zephaniah E. Loss-Cutler-Hull <zephaniah@gmail.com>
[ Upstream commit adb8049097a9ec4acd09fbd3aa8636199a78df8a ]
x86_energy_perf_policy first uses __get_cpuid() to check the maximum
CPUID level and exits if it is too low. It then assumes that later
calls will succeed (which I think is architecturally guaranteed). It
also assumes that CPUID works at all (which is not guaranteed on
x86_32).
If optimisations are enabled, gcc warns about potentially
uninitialized variables. Fix this by adding an exit-on-error after
every call to __get_cpuid() instead of just checking the maximum
level.
[ Upstream commit 89eb4d8d25722a0a0194cf7fa47ba602e32a6da7 ]
When building hv_kvp_daemon GCC-8.3 complains:
hv_kvp_daemon.c: In function ‘kvp_get_ip_info.constprop’:
hv_kvp_daemon.c:812:30: warning: ‘ip_buffer’ may be used uninitialized in this function [-Wmaybe-uninitialized]
struct hv_kvp_ipaddr_value *ip_buffer;
this seems to be a false positive: we only use ip_buffer when
op == KVP_OP_GET_IP_INFO and it is only unset when op == KVP_OP_ENUMERATE.
Silence the warning by initializing ip_buffer to NULL.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
[ Upstream commit b0995156071b0ff29a5902964a9dc8cfad6f81c0 ]
HyperV KVP and VSS daemons should exit with 0 when the '--help'
or '-h' flags are used.
Signed-off-by: Adrian Vladu <avladu@cloudbasesolutions.com>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Cc: Stephen Hemminger <sthemmin@microsoft.com>
Cc: Sasha Levin <sashal@kernel.org>
Cc: Alessandro Pilotti <apilotti@cloudbasesolutions.com>
This reverts commit 0e8529143a212a2f93fd5dfa63f83275f7c44655.
Which was upstream commit 53fe307dfd309e425b171f6272d64296a54f4dff.
Ben Hutchings reports that this commit depends on new code added in
v4.18, and so is irrelevant on older kernels, and breaks the build.
[ Upstream commit c096397c78f766db972f923433031f2dec01cae0 ]
selftests kvm test cases need pre-required kernel configs for the test
to get pass.
Signed-off-by: Naresh Kamboju <naresh.kamboju@linaro.org>
[ Upstream commit 8e6e5bea2e34c61291d00cb3f47560341aa84bc3 ]
The events defined in pmu-events JSON are parsed and added into perf
tool. For fixed counters, we handle the encodings between JSON and perf
by using a static array fixed[].
But the fixed[] has missed an important event "cpu_clk_unhalted.core".
For example, on the Tremont platform,
[root@localhost ~]# perf stat -e cpu_clk_unhalted.core -a
event syntax error: 'cpu_clk_unhalted.core'
\___ parser error
With this patch, the event cpu_clk_unhalted.core can be parsed.
[root@localhost perf]# ./perf stat -e cpu_clk_unhalted.core -a -vvv
perf_event_attr:
type 4
size 112
config 0x3c
sample_type IDENTIFIER
read_format TOTAL_TIME_ENABLED|TOTAL_TIME_RUNNING
disabled 1
inherit 1
exclude_guest 1
Signed-off-by: Jin Yao <yao.jin@linux.intel.com>
Cc: Jin Yao <yao.jin@intel.com>
Link: http://lkml.kernel.org/r/20190729072755.2166-1-yao.jin@linux.intel.com
[ Upstream commit 5f5e25f1c7933a6e1673515c0b1d5acd82fea1ed ]
cpu_map__snprint_mask() would write to illegal memory pointed by
zalloc(0) when there is only one cpu.
This patch fixes the calculation and adds sanity check against the input
parameters.
Signed-off-by: He Zhe <zhe.he@windriver.com>
Fixes: 4400ac8a9a90 ("perf cpumap: Introduce cpu_map__snprint_mask()")
Link: http://lkml.kernel.org/r/1564734592-15624-2-git-send-email-zhe.he@windriver.com
