commit e9666d10a5677a494260d60d1fa0b73cc7646eb3 upstream.
Currently, CONFIG_JUMP_LABEL just means "I _want_ to use jump label".
The jump label is controlled by HAVE_JUMP_LABEL, which is defined
like this:
#if defined(CC_HAVE_ASM_GOTO) && defined(CONFIG_JUMP_LABEL)
# define HAVE_JUMP_LABEL
#endif
We can improve this by testing 'asm goto' support in Kconfig, then
make JUMP_LABEL depend on CC_HAS_ASM_GOTO.
Ugly #ifdef HAVE_JUMP_LABEL will go away, and CONFIG_JUMP_LABEL will
match to the real kernel capability.
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
[nc: Fix trivial conflicts in 4.19
arch/xtensa/kernel/jump_label.c doesn't exist yet
Ensured CC_HAVE_ASM_GOTO and HAVE_JUMP_LABEL were sufficiently
eliminated]
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit 0979ff7992fb6f4eb837995b12f4071dcafebd2d ]
Currently, ksym_search located at trace_helpers won't check symbols are
existing or not.
In ksym_search, when symbol is not found, it will return &syms[0](_stext).
But when the kernel symbols are not loaded, it will return NULL, which is
not a desired action.
This commit will add verification logic whether symbols are loaded prior
to the symbol search.
Signed-off-by: Daniel T. Lee <danieltimlee@gmail.com>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit e14d314c7a489f060d6d691866fef5f131281718 ]
Dan reported, that cleanup path in test_memcg_subtree_control()
triggers a static checker warning:
./tools/testing/selftests/cgroup/test_memcontrol.c:76 \
error: uninitialized symbol 'child2'.
Fix this by initializing child2 and parent2 variables and
split the cleanup path into few stages.
Signed-off-by: Roman Gushchin <guro@fb.com>
Fixes: 84092dbcf901 ("selftests: cgroup: add memory controller self-tests")
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Shuah Khan (Samsung OSG) <shuah@kernel.org>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Signed-off-by: Shuah Khan <shuah@kernel.org>
[ Upstream commit 32e621e55496a0009f44fe4914cd4a23cade4984 ]
Currently, building bpf samples will cause the following error.
./tools/lib/bpf/bpf.h:132:27: error: 'UINT32_MAX' undeclared here (not in a function) ..
#define BPF_LOG_BUF_SIZE (UINT32_MAX >> 8) /* verifier maximum in kernels <= 5.1 */
./samples/bpf/bpf_load.h:31:25: note: in expansion of macro 'BPF_LOG_BUF_SIZE'
extern char bpf_log_buf[BPF_LOG_BUF_SIZE];
Due to commit 4519efa6f8ea ("libbpf: fix BPF_LOG_BUF_SIZE off-by-one error")
hard-coded size of BPF_LOG_BUF_SIZE has been replaced with UINT32_MAX which is
defined in <stdint.h> header.
Even with this change, bpf selftests are running fine since these are built
with clang and it includes header(-idirafter) from clang/6.0.0/include.
(it has <stdint.h>)
clang -I. -I./include/uapi -I../../../include/uapi -idirafter /usr/local/include -idirafter /usr/include \
-idirafter /usr/lib/llvm-6.0/lib/clang/6.0.0/include -idirafter /usr/include/x86_64-linux-gnu \
-Wno-compare-distinct-pointer-types -O2 -target bpf -emit-llvm -c progs/test_sysctl_prog.c -o - | \
llc -march=bpf -mcpu=generic -filetype=obj -o /linux/tools/testing/selftests/bpf/test_sysctl_prog.o
But bpf samples are compiled with GCC, and it only searches and includes
headers declared at the target file. As '#include <stdint.h>' hasn't been
declared in tools/lib/bpf/bpf.h, it causes build failure of bpf samples.
gcc -Wp,-MD,./samples/bpf/.sockex3_user.o.d -Wall -Wmissing-prototypes -Wstrict-prototypes \
-O2 -fomit-frame-pointer -std=gnu89 -I./usr/include -I./tools/lib/ -I./tools/testing/selftests/bpf/ \
-I./tools/ lib/ -I./tools/include -I./tools/perf -c -o ./samples/bpf/sockex3_user.o ./samples/bpf/sockex3_user.c;
This commit add declaration of '#include <stdint.h>' to tools/lib/bpf/bpf.h
to fix this problem.
Acked-by: Yonghong Song <yhs@fb.com>
[ Upstream commit a7d006714724de4334c5e3548701b33f7b12ca96 ]
tools/bpf/bpftool/.gitignore has the "bpftool" pattern, which is
intended to ignore the following build artifact:
tools/bpf/bpftool/bpftool
However, the .gitignore entry is effective not only for the current
directory, but also for any sub-directories.
So, from the point of .gitignore grammar, the following check-in file
is also considered to be ignored:
tools/bpf/bpftool/bash-completion/bpftool
As the manual gitignore(5) says "Files already tracked by Git are not
affected", this is not a problem as far as Git is concerned.
However, Git is not the only program that parses .gitignore because
.gitignore is useful to distinguish build artifacts from source files.
For example, tar(1) supports the --exclude-vcs-ignore option. As of
writing, this option does not work perfectly, but it intends to create
a tarball excluding files specified by .gitignore.
So, I believe it is better to fix this issue.
You can fix it by prefixing the pattern with a slash; the leading slash
means the specified pattern is relative to the current directory.
Reviewed-by: Quentin Monnet <quentin.monnet@netronome.com>
Signed-off-by: Alexei Starovoitov <ast@kernel.org>
[ Upstream commit 6cea33701eb024bc6c920ab83940ee22afd29139 ]
Test test_libbpf.sh failed on my development server with failure
-bash-4.4$ sudo ./test_libbpf.sh
[0] libbpf: Error in bpf_object__probe_name():Operation not permitted(1).
Couldn't load basic 'r0 = 0' BPF program.
test_libbpf: failed at file test_l4lb.o
selftests: test_libbpf [FAILED]
-bash-4.4$
The reason is because my machine has 64KB locked memory by default which
is not enough for this program to get locked memory.
Similar to other bpf selftests, let us increase RLIMIT_MEMLOCK
to infinity, which fixed the issue.
Signed-off-by: Yonghong Song <yhs@fb.com>
[ Upstream commit ca31ca8247e2d3807ff5fa1d1760616a2292001c ]
When build perf for ARC recently, there was a build failure due to lack
of __NR_bpf.
| Auto-detecting system features:
| ... get_cpuid: [ OFF ]
| ... bpf: [ on ]
| # error __NR_bpf not defined. libbpf does not support your arch.
| bpf.c: In function 'sys_bpf':
| bpf.c:66:17: error: '__NR_bpf' undeclared (first use in this function)
| return syscall(__NR_bpf, cmd, attr, size);
| sys_bpf
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
This reverts commit 118d38a3577f7728278f6afda8436af05a6bec7f which is
commit 8184d44c9a577a2f1842ed6cc844bfd4a9981d8e upstream.
Tommi reports that this patch breaks the build, it's not really needed
so let's revert it.
Reported-by: Tommi Rantala <tommi.t.rantala@nokia.com>
Cc: Stanislav Fomichev <sdf@google.com>
Cc: Sasha Levin <sashal@kernel.org>
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
[ Upstream commit bf561d3c13423fc54daa19b5d49dc15fafdb7acc ]
While cross building perf to the ARC architecture on a fedora 30 host,
we were failing with:
CC /tmp/build/perf/bench/numa.o
bench/numa.c: In function ‘worker_thread’:
bench/numa.c:1261:12: error: ‘RUSAGE_THREAD’ undeclared (first use in this function); did you mean ‘SIGEV_THREAD’?
getrusage(RUSAGE_THREAD, &rusage);
SIGEV_THREAD
bench/numa.c:1261:12: note: each undeclared identifier is reported only once for each function it appears in
[perfbuilder@60d5802468f6 perf]$ /arc_gnu_2019.03-rc1_prebuilt_uclibc_le_archs_linux_install/bin/arc-linux-gcc --version | head -1
arc-linux-gcc (ARCv2 ISA Linux uClibc toolchain 2019.03-rc1) 8.3.1 20190225
Trying to reproduce a report by Vineet, I noticed that, with just
cross-built zlib and numactl libraries, I ended up with the above
failure.
So, since RUSAGE_THREAD is available as a define, check for that and
numactl libraries, I ended up with the above failure.
So, since RUSAGE_THREAD is available as a define in the system headers,
check if it is defined in the 'perf bench numa' sources and define it if
not.
Now it builds and I have to figure out if the problem reported by Vineet
only takes place if we have libelf or some other library available.
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: linux-snps-arc@lists.infradead.org
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Link: https://lkml.kernel.org/n/tip-2wb4r1gir9xrevbpq7qp0amk@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit 8ea58f1e8b11cca3087b294779bf5959bf89cc10 upstream.
Currently, this Makefile hardcodes GNU ar, meaning that if it is not
available, there is no way to supply a different one and the build will
fail.
$ make AR=llvm-ar CC=clang LD=ld.lld HOSTAR=llvm-ar HOSTCC=clang \
HOSTLD=ld.lld HOSTLDFLAGS=-fuse-ld=lld defconfig modules_prepare
AR /out/tools/objtool/libsubcmd.a
/bin/sh: 1: ar: not found
Follow the logic of HOST{CC,LD} and allow the user to specify a
different ar tool via HOSTAR (which is used elsewhere in other
tools/ Makefiles).
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
Reviewed-by: Mukesh Ojha <mojha@codeaurora.org>
Cc: <stable@vger.kernel.org>
Link: http://lkml.kernel.org/r/80822a9353926c38fd7a152991c6292491a9d0e8.1558028966.git.jpoimboe@redhat.com
Link: https://github.com/ClangBuiltLinux/linux/issues/481
commit 1b6599a9d8e6c9f7e9b0476012383b1777f7fc93 upstream.
The sample timestamp is updated to ensure that the timestamp represents
the time of the sample and not a branch that the decoder is still
walking towards. The sample timestamp is updated when the decoder
returns, but the decoder does not return for non-taken branches. Update
the sample timestamp then also.
Note that commit 3f04d98e972b5 ("perf intel-pt: Improve sample
timestamp") was also a stable fix and appears, for example, in v4.4
stable tree as commit a4ebb58fd124 ("perf intel-pt: Improve sample
timestamp").
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: stable@vger.kernel.org # v4.4+
Fixes: 3f04d98e972b ("perf intel-pt: Improve sample timestamp")
Link: http://lkml.kernel.org/r/20190510124143.27054-4-adrian.hunter@intel.com
commit 61b6e08dc8e3ea80b7485c9b3f875ddd45c8466b upstream.
The decoder uses its current timestamp in samples. Usually that is a
timestamp that has already passed, but in some cases it is a timestamp
for a branch that the decoder is walking towards, and consequently
hasn't reached.
The intel_pt_sample_time() function decides which is which, but was not
handling TNT packets exactly correctly.
In the case of TNT, the timestamp applies to the first branch, so the
decoder must first walk to that branch.
That means intel_pt_sample_time() should return true for TNT, and this
patch makes that change. However, if the first branch is a non-taken
branch (i.e. a 'N'), then intel_pt_sample_time() needs to return false
for subsequent taken branches in the same TNT packet.
To handle that, introduce a new state INTEL_PT_STATE_TNT_CONT to
distinguish the cases.
timestamp").
Fixes: 3f04d98e972b5 ("perf intel-pt: Improve sample timestamp")
Link: http://lkml.kernel.org/r/20190510124143.27054-3-adrian.hunter@intel.com
commit 7ba8fa20e26eb3c0c04d747f7fd2223694eac4d5 upstream.
The timestamp used to determine if an instruction sample is made, is an
estimate based on the number of instructions since the last known
timestamp. A consequence is that it might go backwards, which results in
extra samples. Change it so that a sample is only made when the
timestamp goes forwards.
Note this does not affect a sampling period of 0 or sampling periods
specified as a count of instructions.
Example:
Before:
$ perf script --itrace=i10us
ls 13812 [003] 2167315.222583: 3270 instructions:u: 7fac71e2e494 __GI___tunables_init+0xf4 (/lib/x86_64-linux-gnu/ld-2.28.so)
ls 13812 [003] 2167315.222667: 30902 instructions:u: 7fac71e2da0f _dl_cache_libcmp+0x2f (/lib/x86_64-linux-gnu/ld-2.28.so)
ls 13812 [003] 2167315.222667: 10 instructions:u: 7fac71e2d9ff _dl_cache_libcmp+0x1f (/lib/x86_64-linux-gnu/ld-2.28.so)
ls 13812 [003] 2167315.222667: 8 instructions:u: 7fac71e2d9ea _dl_cache_libcmp+0xa (/lib/x86_64-linux-gnu/ld-2.28.so)
ls 13812 [003] 2167315.222667: 14 instructions:u: 7fac71e2d9ea _dl_cache_libcmp+0xa (/lib/x86_64-linux-gnu/ld-2.28.so)
ls 13812 [003] 2167315.222667: 6 instructions:u: 7fac71e2d9ff _dl_cache_libcmp+0x1f (/lib/x86_64-linux-gnu/ld-2.28.so)
ls 13812 [003] 2167315.222667: 14 instructions:u: 7fac71e2d9ff _dl_cache_libcmp+0x1f (/lib/x86_64-linux-gnu/ld-2.28.so)
ls 13812 [003] 2167315.222667: 4 instructions:u: 7fac71e2dab2 _dl_cache_libcmp+0xd2 (/lib/x86_64-linux-gnu/ld-2.28.so)
ls 13812 [003] 2167315.222728: 16423 instructions:u: 7fac71e2477a _dl_map_object_deps+0x1ba (/lib/x86_64-linux-gnu/ld-2.28.so)
ls 13812 [003] 2167315.222734: 12731 instructions:u: 7fac71e27938 _dl_name_match_p+0x68 (/lib/x86_64-linux-gnu/ld-2.28.so)
After:
ls 13812 [003] 2167315.222728: 16479 instructions:u: 7fac71e2477a _dl_map_object_deps+0x1ba (/lib/x86_64-linux-gnu/ld-2.28.so)
Fixes: f4aa081949e7b ("perf tools: Add Intel PT decoder")
Link: http://lkml.kernel.org/r/20190510124143.27054-2-adrian.hunter@intel.com
commit e6f393bc939d566ce3def71232d8013de9aaadde upstream.
When a function falls through to the next function due to a compiler
bug, objtool prints some obscure warnings. For example:
drivers/regulator/core.o: warning: objtool: regulator_count_voltages()+0x95: return with modified stack frame
drivers/regulator/core.o: warning: objtool: regulator_count_voltages()+0x0: stack state mismatch: cfa1=7+32 cfa2=7+8
Instead it should be printing:
drivers/regulator/core.o: warning: objtool: regulator_supply_is_couple() falls through to next function regulator_count_voltages()
This used to work, but was broken by the following commit:
13810435b9a7 ("objtool: Support GCC 8's cold subfunctions")
The padding nops at the end of a function aren't actually part of the
function, as defined by the symbol table. So the 'func' variable in
validate_branch() is getting cleared to NULL when a padding nop is
encountered, breaking the fallthrough detection.
If the current instruction doesn't have a function associated with it,
just consider it to be part of the previously detected function by not
overwriting the previous value of 'func'.
Reported-by: kbuild test robot <lkp@intel.com>
Fixes: 13810435b9a7 ("objtool: Support GCC 8's cold subfunctions")
Link: http://lkml.kernel.org/r/546d143820cd08a46624ae8440d093dd6c902cae.1557766718.git.jpoimboe@redhat.com
[ Upstream commit 30c04d796b693e22405c38e9b78e9a364e4c77e6 ]
The run_netsocktests will be marked as passed regardless the actual test
result from the ./socket:
selftests: net: run_netsocktests
running socket test
[FAIL]
ok 1..6 selftests: net: run_netsocktests [PASS]
This is because the test script itself has been successfully executed.
Fix this by exit 1 when the test failed.
Signed-off-by: Po-Hsu Lin <po-hsu.lin@canonical.com>
[ Upstream commit becf2319f320cae43e20cf179cc51a355a0deb5f ]
When an icmp error such as pkttoobig is received, conntrack checks
if the "inner" header (header of packet that did not fit link mtu)
is matches an existing connection, and, if so, sets that packet as
being related to the conntrack entry it found.
It was recently reported that this "related" setting also works
if the inner header is from another, different connection (i.e.,
artificial/forged icmp error).
Add a test, followup patch will add additional "inner dst matches
outer dst in reverse direction" check before setting related state.
Link: https://www.synacktiv.com/posts/systems/icmp-reachable.html
[ Upstream commit f32c2877bcb068a718bb70094cd59ccc29d4d082 ]
There was a missing comparison with 0 when checking if type is "s64" or
"u64". Therefore, the body of the if-statement was entered if "type" was
"u64" or not "s64", which made the first strcmp() redundant since if
type is "u64", it's not "s64".
If type is "s64", the body of the if-statement is not entered but since
the remainder of the function consists of if-statements which will not
be entered if type is "s64", we will just return "val", which is
correct, albeit at the cost of a few more calls to strcmp(), i.e., it
will behave just as if the if-statement was entered.
If type is neither "s64" or "u64", the body of the if-statement will be
entered incorrectly and "val" returned. This means that any type that is
checked after "s64" and "u64" is handled the same way as "s64" and
"u64", i.e., the limiting of "val" to fit in for example "s8" is never
reached.
This was introduced in the kernel tree when the sources were copied from
trace-cmd in commit f7d82350e597 ("tools/events: Add files to create
libtraceevent.a"), and in the trace-cmd repo in 1cdbae6035cei
("Implement typecasting in parser") when the function was introduced,
i.e., it has always behaved the wrong way.
Detected by cppcheck.
Signed-off-by: Rikard Falkeborn <rikard.falkeborn@gmail.com>
Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: Tzvetomir Stoyanov <tstoyanov@vmware.com>
Fixes: f7d82350e597 ("tools/events: Add files to create libtraceevent.a")
Link: http://lkml.kernel.org/r/20190409091529.2686-1-rikard.falkeborn@gmail.com
[ Upstream commit a5f622984a623df9a84cf43f6b098d8dd76fbe05 ]
A couple of tests are verifying a route has been removed. The helper
expects the prefix as the first part of the expected output. When
checking that a route has been deleted the prefix is empty leading
to an invalid ip command:
$ ip ro ls match
Command line is not complete. Try option "help"
Fix by moving the comparison of expected output and output to a new
function that is used by both check_route and check_route6. Use the
new helper for the 2 checks on route removal.
Also, remove the reset of 'set -x' in route_setup which overrides the
user managed setting.
Fixes: d69faad76584c ("selftests: fib_tests: Add prefix route tests with metric")
Signed-off-by: David Ahern <dsahern@gmail.com>
commit d8eabc37310a92df40d07c5a8afc53cebf996716 upstream
Greg pointed out that speculation related bit defines are using (1 << N)
format instead of BIT(N). Aside of that (1 << N) is wrong as it should use
1UL at least.
Clean it up.
[ Josh Poimboeuf: Fix tools build ]
Reported-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Borislav Petkov <bp@suse.de>
Reviewed-by: Frederic Weisbecker <frederic@kernel.org>
Reviewed-by: Jon Masters <jcm@redhat.com>
Tested-by: Jon Masters <jcm@redhat.com>
commit f2c4db1bd80720cd8cb2a5aa220d9bc9f374f04e upstream
Going primarily by:
https://en.wikipedia.org/wiki/List_of_Intel_Atom_microprocessors
with additional information gleaned from other related pages; notably:
- Bonnell shrink was called Saltwell
- Moorefield is the Merriefield refresh which makes it Airmont
The general naming scheme is: FAM6_ATOM_UARCH_SOCTYPE
for i in `git grep -l FAM6_ATOM` ; do
sed -i -e 's/ATOM_PINEVIEW/ATOM_BONNELL/g' \
-e 's/ATOM_LINCROFT/ATOM_BONNELL_MID/' \
-e 's/ATOM_PENWELL/ATOM_SALTWELL_MID/g' \
-e 's/ATOM_CLOVERVIEW/ATOM_SALTWELL_TABLET/g' \
-e 's/ATOM_CEDARVIEW/ATOM_SALTWELL/g' \
-e 's/ATOM_SILVERMONT1/ATOM_SILVERMONT/g' \
-e 's/ATOM_SILVERMONT2/ATOM_SILVERMONT_X/g' \
-e 's/ATOM_MERRIFIELD/ATOM_SILVERMONT_MID/g' \
-e 's/ATOM_MOOREFIELD/ATOM_AIRMONT_MID/g' \
-e 's/ATOM_DENVERTON/ATOM_GOLDMONT_X/g' \
-e 's/ATOM_GEMINI_LAKE/ATOM_GOLDMONT_PLUS/g' ${i}
done
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Vince Weaver <vincent.weaver@maine.edu>
Cc: dave.hansen@linux.intel.com
Cc: len.brown@intel.com
[ Upstream commit 4fa5ecda2bf96be7464eb406df8aba9d89260227 ]
This fixes the following warning seen on GCC 7.3:
arch/x86/kernel/dumpstack.o: warning: objtool: oops_end() falls through to next function show_regs()
Link: https://lkml.kernel.org/r/3418ebf5a5a9f6ed7e80954c741c0b904b67b5dc.1554398240.git.jpoimboe@redhat.com
[ Upstream commit f68d7c44e76532e46f292ad941aa3706cb9e6e40 ]
Fixes: 65b2b4939a64 ("selftests: net: initial fib rule tests")
Signed-off-by: Hangbin Liu <liuhangbin@gmail.com>
Reviewed-by: David Ahern <dsahern@gmail.com>
[ Upstream commit 977c7a6d1e263ff1d755f28595b99e4bc0c48a9f ]
Since commit 1fb87b8e9599 ("perf machine: Don't search for active kernel
start in __machine__create_kernel_maps"), the __machine__create_kernel_maps()
just create a map what start and end are both zero. Though the address will be
updated later, the order of map in the rbtree may be incorrect.
The commit ee05d21791db ("perf machine: Set main kernel end address properly")
fixed the logic in machine__create_kernel_maps(), but it's still wrong in
function machine__process_kernel_mmap_event().
To reproduce this issue, we need an environment which the module address
is before the kernel text segment. I tested it on an aarch64 machine with
kernel 4.19.25:
[root@localhost hulk]# grep _stext /proc/kallsyms
ffff000008081000 T _stext
[root@localhost hulk]# grep _etext /proc/kallsyms
ffff000009780000 R _etext
[root@localhost hulk]# tail /proc/modules
hisi_sas_v2_hw 77824 0 - Live 0xffff00000191d000
nvme_core 126976 7 nvme, Live 0xffff0000018b6000
mdio 20480 1 ixgbe, Live 0xffff0000018ab000
hisi_sas_main 106496 1 hisi_sas_v2_hw, Live 0xffff000001861000
hns_mdio 20480 2 - Live 0xffff000001822000
hnae 28672 3 hns_dsaf,hns_enet_drv, Live 0xffff000001815000
dm_mirror 40960 0 - Live 0xffff000001804000
dm_region_hash 32768 1 dm_mirror, Live 0xffff0000017f5000
dm_log 32768 2 dm_mirror,dm_region_hash, Live 0xffff0000017e7000
dm_mod 315392 17 dm_mirror,dm_log, Live 0xffff000001780000
Before fix:
[root@localhost bin]# perf record sleep 3
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.011 MB perf.data (9 samples) ]
[root@localhost bin]# perf buildid-list -i perf.data
4c4e46c971ca935f781e603a09b52a92e8bdfee8 [vdso]
[root@localhost bin]# perf buildid-list -i perf.data -H
0000000000000000000000000000000000000000 /proc/kcore
After fix:
[root@localhost tools]# ./perf/perf record sleep 3
[root@localhost tools]# ./perf/perf buildid-list -i perf.data
28a6c690262896dbd1b5e1011ed81623e6db0610 [kernel.kallsyms]
106c14ce6e4acea3453e484dc604d66666f08a2f [vdso]
[root@localhost tools]# ./perf/perf buildid-list -i perf.data -H
28a6c690262896dbd1b5e1011ed81623e6db0610 /proc/kcore
Signed-off-by: Wei Li <liwei391@huawei.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Cc: David Ahern <dsahern@gmail.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Cc: Kim Phillips <kim.phillips@arm.com>
Cc: Li Bin <huawei.libin@huawei.com>
Link: http://lkml.kernel.org/r/20190228092003.34071-1-liwei391@huawei.com
Signed-off-by: Sasha Levin (Microsoft) <sashal@kernel.org>
commit ba4aa02b417f08a0bee5e7b8ed70cac788a7c854 upstream.
So that we reduce the difference of tools/include/linux/bitops.h to the
original kernel file, include/linux/bitops.h, trying to remove the need
to define BITS_PER_LONG, to avoid clashes with asm/bitsperlong.h.
And the things removed from tools/include/linux/bitops.h are really in
linux/bits.h, so that we can have a copy and then
tools/perf/check_headers.sh will tell us when new stuff gets added to
linux/bits.h so that we can check if it is useful and if any adjustment
needs to be done to the tools/{include,arch}/ copies.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Alexander Sverdlin <alexander.sverdlin@nokia.com>
Cc: Wang Nan <wangnan0@huawei.com>
Link: https://lkml.kernel.org/n/tip-y1sqyydvfzo0bjjoj4zsl562@git.kernel.org
[ Upstream commit e0a2e73e501c77037c8756137e87b12c7c3c9793 ]
Without this usbip fails on a machine with devices
that lexicographically come after vhci_hcd.
ie.
$ ls -l /sys/devices/platform
drwxr-xr-x. 4 root root 0 Sep 19 16:21 serial8250
-rw-r--r--. 1 root root 4096 Sep 19 23:50 uevent
drwxr-xr-x. 6 root root 0 Sep 20 13:15 vhci_hcd.0
drwxr-xr-x. 4 root root 0 Sep 19 16:22 w83627hf.656
Because it detects 'w83627hf.656' as another vhci_hcd controller,
and then fails to be able to talk to it.
Note: this doesn't actually fix usbip's support for multiple
controllers... that's still broken for other reasons
("vhci_hcd.0" is hardcoded in a string macro), but is enough to
actually make it work on the above machine.
See also:
https://bugzilla.redhat.com/show_bug.cgi?id=1631148
Cc: Jonathan Dieter <jdieter@gmail.com>
Cc: Valentina Manea <valentina.manea.m@gmail.com>
Cc: Shuah Khan <shuah@kernel.org>
Cc: linux-usb@vger.kernel.org
Signed-off-by: Maciej Żenczykowski <zenczykowski@gmail.com>
Acked-by: Shuah Khan (Samsung OSG) <shuah@kernel.org>
Tested-by: Jonathan Dieter <jdieter@gmail.com>
[ Upstream commit d982b33133284fa7efa0e52ae06b88f9be3ea764 ]
==20875==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 1160 byte(s) in 1 object(s) allocated from:
#0 0x7f1b6fc84138 in calloc (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xee138)
#1 0x55bd50005599 in zalloc util/util.h:23
#2 0x55bd500068f5 in perf_evsel__newtp_idx util/evsel.c:327
#3 0x55bd4ff810fc in perf_evsel__newtp /home/work/linux/tools/perf/util/evsel.h:216
#4 0x55bd4ff81608 in test__perf_evsel__tp_sched_test tests/evsel-tp-sched.c:69
#5 0x55bd4ff528e6 in run_test tests/builtin-test.c:358
#6 0x55bd4ff52baf in test_and_print tests/builtin-test.c:388
#7 0x55bd4ff543fe in __cmd_test tests/builtin-test.c:583
#8 0x55bd4ff5572f in cmd_test tests/builtin-test.c:722
#9 0x55bd4ffc4087 in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#10 0x55bd4ffc45c6 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#11 0x55bd4ffc49ca in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#12 0x55bd4ffc5138 in main /home/changbin/work/linux/tools/perf/perf.c:520
#13 0x7f1b6e34809a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Indirect leak of 19 byte(s) in 1 object(s) allocated from:
#0 0x7f1b6fc83f30 in __interceptor_malloc (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xedf30)
#1 0x7f1b6e3ac30f in vasprintf (/lib/x86_64-linux-gnu/libc.so.6+0x8830f)
Signed-off-by: Changbin Du <changbin.du@gmail.com>
Reviewed-by: Jiri Olsa <jolsa@kernel.org>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Daniel Borkmann <daniel@iogearbox.net>
Cc: Steven Rostedt (VMware) <rostedt@goodmis.org>
Fixes: 6a6cd11d4e57 ("perf test: Add test for the sched tracepoint format fields")
Link: http://lkml.kernel.org/r/20190316080556.3075-17-changbin.du@gmail.com
[ Upstream commit f97a8991d3b998e518f56794d879f645964de649 ]
==7506==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 13 byte(s) in 3 object(s) allocated from:
#0 0x7f03339d6070 in __interceptor_strdup (/usr/lib/x86_64-linux-gnu/libasan.so.5+0x3b070)
#1 0x5625e53aaef0 in expr__find_other util/expr.y:221
#2 0x5625e51bcd3f in test__expr tests/expr.c:52
#3 0x5625e51528e6 in run_test tests/builtin-test.c:358
#4 0x5625e5152baf in test_and_print tests/builtin-test.c:388
#5 0x5625e51543fe in __cmd_test tests/builtin-test.c:583
#6 0x5625e515572f in cmd_test tests/builtin-test.c:722
#7 0x5625e51c3fb8 in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#8 0x5625e51c44f7 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#9 0x5625e51c48fb in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#10 0x5625e51c5069 in main /home/changbin/work/linux/tools/perf/perf.c:520
#11 0x7f033214d09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Fixes: 075167363f8b ("perf tools: Add a simple expression parser for JSON")
Link: http://lkml.kernel.org/r/20190316080556.3075-16-changbin.du@gmail.com
openat_syscall_event_on_all_cpus test
[ Upstream commit 93faa52e8371f0291ee1ff4994edae2b336b6233 ]
==7497==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 40 byte(s) in 1 object(s) allocated from:
#0 0x7f0333a88f30 in __interceptor_malloc (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xedf30)
#1 0x5625e5326213 in cpu_map__trim_new util/cpumap.c:45
#2 0x5625e5326703 in cpu_map__read util/cpumap.c:103
#3 0x5625e53267ef in cpu_map__read_all_cpu_map util/cpumap.c:120
#4 0x5625e5326915 in cpu_map__new util/cpumap.c:135
#5 0x5625e517b355 in test__openat_syscall_event_on_all_cpus tests/openat-syscall-all-cpus.c:36
#6 0x5625e51528e6 in run_test tests/builtin-test.c:358
#7 0x5625e5152baf in test_and_print tests/builtin-test.c:388
#8 0x5625e51543fe in __cmd_test tests/builtin-test.c:583
#9 0x5625e515572f in cmd_test tests/builtin-test.c:722
#10 0x5625e51c3fb8 in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#11 0x5625e51c44f7 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#12 0x5625e51c48fb in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#13 0x5625e51c5069 in main /home/changbin/work/linux/tools/perf/perf.c:520
#14 0x7f033214d09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Fixes: f30a79b012e5 ("perf tools: Add reference counting for cpu_map object")
Link: http://lkml.kernel.org/r/20190316080556.3075-15-changbin.du@gmail.com
[ Upstream commit 42dfa451d825a2ad15793c476f73e7bbc0f9d312 ]
Using gcc's ASan, Changbin reports:
==7494==ERROR: LeakSanitizer: detected memory leaks
Direct leak of 48 byte(s) in 1 object(s) allocated from:
#0 0x7f0333a89138 in calloc (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xee138)
#1 0x5625e5330a5e in zalloc util/util.h:23
#2 0x5625e5330a9b in perf_counts__new util/counts.c:10
#3 0x5625e5330ca0 in perf_evsel__alloc_counts util/counts.c:47
#4 0x5625e520d8e5 in __perf_evsel__read_on_cpu util/evsel.c:1505
#5 0x5625e517a985 in perf_evsel__read_on_cpu /home/work/linux/tools/perf/util/evsel.h:347
#6 0x5625e517ad1a in test__openat_syscall_event tests/openat-syscall.c:47
#7 0x5625e51528e6 in run_test tests/builtin-test.c:358
#8 0x5625e5152baf in test_and_print tests/builtin-test.c:388
#9 0x5625e51543fe in __cmd_test tests/builtin-test.c:583
#10 0x5625e515572f in cmd_test tests/builtin-test.c:722
#11 0x5625e51c3fb8 in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#12 0x5625e51c44f7 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#13 0x5625e51c48fb in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#14 0x5625e51c5069 in main /home/changbin/work/linux/tools/perf/perf.c:520
#15 0x7f033214d09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Indirect leak of 72 byte(s) in 1 object(s) allocated from:
#1 0x5625e532560d in zalloc util/util.h:23
#2 0x5625e532566b in xyarray__new util/xyarray.c:10
#3 0x5625e5330aba in perf_counts__new util/counts.c:15
#4 0x5625e5330ca0 in perf_evsel__alloc_counts util/counts.c:47
#5 0x5625e520d8e5 in __perf_evsel__read_on_cpu util/evsel.c:1505
#6 0x5625e517a985 in perf_evsel__read_on_cpu /home/work/linux/tools/perf/util/evsel.h:347
#7 0x5625e517ad1a in test__openat_syscall_event tests/openat-syscall.c:47
#8 0x5625e51528e6 in run_test tests/builtin-test.c:358
#9 0x5625e5152baf in test_and_print tests/builtin-test.c:388
#10 0x5625e51543fe in __cmd_test tests/builtin-test.c:583
#11 0x5625e515572f in cmd_test tests/builtin-test.c:722
#12 0x5625e51c3fb8 in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#13 0x5625e51c44f7 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#14 0x5625e51c48fb in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#15 0x5625e51c5069 in main /home/changbin/work/linux/tools/perf/perf.c:520
#16 0x7f033214d09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
His patch took care of evsel->prev_raw_counts, but the above backtraces
are about evsel->counts, so fix that instead.
Reported-by: Changbin Du <changbin.du@gmail.com>
Link: https://lkml.kernel.org/n/tip-hd1x13g59f0nuhe4anxhsmfp@git.kernel.org
[ Upstream commit cb6186aeffda4d27e56066c79e9579e7831541d3 ]
We need to map__put() before returning from failure of
sample__resolve_callchain().
Detected with gcc's ASan.
Cc: Krister Johansen <kjlx@templeofstupid.com>
Fixes: 9c68ae98c6f7 ("perf callchain: Reference count maps")
Link: http://lkml.kernel.org/r/20190316080556.3075-10-changbin.du@gmail.com
[ Upstream commit 70c819e4bf1c5f492768b399d898d458ccdad2b6 ]
We should go to the cleanup path, to avoid leaks, detected using gcc's
ASan.
Link: http://lkml.kernel.org/r/20190316080556.3075-9-changbin.du@gmail.com
[ Upstream commit 8bde8516893da5a5fdf06121f74d11b52ab92df5 ]
Detected with gcc's ASan:
Direct leak of 4356 byte(s) in 120 object(s) allocated from:
#0 0x7ff1a2b5a070 in __interceptor_strdup (/usr/lib/x86_64-linux-gnu/libasan.so.5+0x3b070)
#1 0x55719aef4814 in build_id_cache__origname util/build-id.c:215
#2 0x55719af649b6 in print_sdt_events util/parse-events.c:2339
#3 0x55719af66272 in print_events util/parse-events.c:2542
#4 0x55719ad1ecaa in cmd_list /home/changbin/work/linux/tools/perf/builtin-list.c:58
#5 0x55719aec745d in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
#6 0x55719aec7d1a in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
#7 0x55719aec8184 in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
#8 0x55719aeca41a in main /home/changbin/work/linux/tools/perf/perf.c:520
#9 0x7ff1a07ae09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Fixes: 40218daea1db ("perf list: Show SDT and pre-cached events")
Link: http://lkml.kernel.org/r/20190316080556.3075-7-changbin.du@gmail.com
[ Upstream commit 54569ba4b06d5baedae4614bde33a25a191473ba ]
Direct leak of 66 byte(s) in 5 object(s) allocated from:
#0 0x7ff3b1f32070 in __interceptor_strdup (/usr/lib/x86_64-linux-gnu/libasan.so.5+0x3b070)
#1 0x560c8761034d in collect_config util/config.c:597
#2 0x560c8760d9cb in get_value util/config.c:169
#3 0x560c8760dfd7 in perf_parse_file util/config.c:285
#4 0x560c8760e0d2 in perf_config_from_file util/config.c:476
#5 0x560c876108fd in perf_config_set__init util/config.c:661
#6 0x560c87610c72 in perf_config_set__new util/config.c:709
#7 0x560c87610d2f in perf_config__init util/config.c:718
#8 0x560c87610e5d in perf_config util/config.c:730
#9 0x560c875ddea0 in main /home/changbin/work/linux/tools/perf/perf.c:442
#10 0x7ff3afb8609a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Cc: Taeung Song <treeze.taeung@gmail.com>
Fixes: 20105ca1240c ("perf config: Introduce perf_config_set class")
Link: http://lkml.kernel.org/r/20190316080556.3075-6-changbin.du@gmail.com
[ Upstream commit 9b40dff7ba3caaf0d1919f98e136fa3400bd34aa ]
The option 'sort-order' should be 'sort_order'.
Cc: Milian Wolff <milian.wolff@kdab.com>
Fixes: 893c5c798be9 ("perf config: Show default report configuration in example and docs")
Link: http://lkml.kernel.org/r/20190316080556.3075-5-changbin.du@gmail.com
[ Upstream commit 39df730b09774bd860e39ea208a48d15078236cb ]
Detected via gcc's ASan:
Direct leak of 2048 byte(s) in 64 object(s) allocated from:
6 #0 0x7f606512e370 in __interceptor_realloc (/usr/lib/x86_64-linux-gnu/libasan.so.5+0xee370)
7 #1 0x556b0f1d7ddd in thread_map__realloc util/thread_map.c:43
8 #2 0x556b0f1d84c7 in thread_map__new_by_tid util/thread_map.c:85
9 #3 0x556b0f0e045e in is_event_supported util/parse-events.c:2250
10 #4 0x556b0f0e1aa1 in print_hwcache_events util/parse-events.c:2382
11 #5 0x556b0f0e3231 in print_events util/parse-events.c:2514
12 #6 0x556b0ee0a66e in cmd_list /home/changbin/work/linux/tools/perf/builtin-list.c:58
13 #7 0x556b0f01e0ae in run_builtin /home/changbin/work/linux/tools/perf/perf.c:302
14 #8 0x556b0f01e859 in handle_internal_command /home/changbin/work/linux/tools/perf/perf.c:354
15 #9 0x556b0f01edc8 in run_argv /home/changbin/work/linux/tools/perf/perf.c:398
16 #10 0x556b0f01f71f in main /home/changbin/work/linux/tools/perf/perf.c:520
17 #11 0x7f6062ccf09a in __libc_start_main (/lib/x86_64-linux-gnu/libc.so.6+0x2409a)
Fixes: 89896051f8da ("perf tools: Do not put a variable sized type not at the end of a struct")
Link: http://lkml.kernel.org/r/20190316080556.3075-3-changbin.du@gmail.com
[ Upstream commit 2a95496634a017c19641f26f00907af75b962f01 ]
turbostat failed to return a non-zero exit status even though the
supplied command (turbostat <command>) failed. Currently when turbostat
forks a command it returns zero instead of the actual exit status of the
command. Modify the code to return the exit status.
Signed-off-by: David Arcari <darcari@redhat.com>
Acked-by: Len Brown <len.brown@intel.com>
[ Upstream commit fae2708174ae95d98d19f194e03d6e8f688ae195 ]
the control path of 'sample' action does not validate the value of 'rate'
provided by the user, but then it uses it as divisor in the traffic path.
Validate it in tcf_sample_init(), and return -EINVAL with a proper extack
message in case that value is zero, to fix a splat with the script below:
# tc f a dev test0 egress matchall action sample rate 0 group 1 index 2
# tc -s a s action sample
total acts 1
action order 0: sample rate 1/0 group 1 pipe
index 2 ref 1 bind 1 installed 19 sec used 19 sec
Action statistics:
Sent 0 bytes 0 pkt (dropped 0, overlimits 0 requeues 0)
backlog 0b 0p requeues 0
# ping 192.0.2.1 -I test0 -c1 -q
divide error: 0000 [#1] SMP PTI
CPU: 1 PID: 6192 Comm: ping Not tainted 5.1.0-rc2.diag2+ #591
Hardware name: Red Hat KVM, BIOS 0.5.1 01/01/2011
RIP: 0010:tcf_sample_act+0x9e/0x1e0 [act_sample]
Code: 6a f1 85 c0 74 0d 80 3d 83 1a 00 00 00 0f 84 9c 00 00 00 4d 85 e4 0f 84 85 00 00 00 e8 9b d7 9c f1 44 8b 8b e0 00 00 00 31 d2 <41> f7 f1 85 d2 75 70 f6 85 83 00 00 00 10 48 8b 45 10 8b 88 08 01
RSP: 0018:ffffae320190ba30 EFLAGS: 00010246
RAX: 00000000b0677d21 RBX: ffff8af1ed9ec000 RCX: 0000000059a9fe49
RDX: 0000000000000000 RSI: 000000000c7e33b7 RDI: ffff8af23daa0af0
RBP: ffff8af1ee11b200 R08: 0000000074fcaf7e R09: 0000000000000000
R10: 0000000000000050 R11: ffffffffb3088680 R12: ffff8af232307f80
R13: 0000000000000003 R14: ffff8af1ed9ec000 R15: 0000000000000000
FS: 00007fe9c6d2f740(0000) GS:ffff8af23da80000(0000) knlGS:0000000000000000
CR2: 00007fff6772f000 CR3: 00000000746a2004 CR4: 00000000001606e0
Call Trace:
tcf_action_exec+0x7c/0x1c0
tcf_classify+0x57/0x160
__dev_queue_xmit+0x3dc/0xd10
ip_finish_output2+0x257/0x6d0
ip_output+0x75/0x280
ip_send_skb+0x15/0x40
raw_sendmsg+0xae3/0x1410
sock_sendmsg+0x36/0x40
__sys_sendto+0x10e/0x140
__x64_sys_sendto+0x24/0x30
do_syscall_64+0x60/0x210
entry_SYSCALL_64_after_hwframe+0x49/0xbe
Kernel panic - not syncing: Fatal exception in interrupt
Add a TDC selftest to document that 'rate' is now being validated.
Reported-by: Matteo Croce <mcroce@redhat.com>
Fixes: 5c5670fae430 ("net/sched: Introduce sample tc action")
Signed-off-by: Davide Caratti <dcaratti@redhat.com>
Acked-by: Yotam Gigi <yotam.gi@gmail.com>
[ Upstream commit cc437642255224e4140fed1f3e3156fc8ad91903 ]
In Python3, the result of PyModule_Create (called from
scripts/python/Perf-Trace-Util/Context.c) is not automatically added to
sys.modules. See: https://bugs.python.org/issue4592
Below is the observed behavior without the fix:
# ldd /usr/bin/perf | grep -i python
libpython3.6m.so.1.0 => /usr/lib64/libpython3.6m.so.1.0 (0x00007f8e1dfb2000)
# perf record /bin/false
[ perf record: Captured and wrote 0.015 MB perf.data (17 samples) ]
# perf script -g python | cat
generated Python script: perf-script.py
# perf script -s ./perf-script.py
Traceback (most recent call last):
File "./perf-script.py", line 18, in <module>
from perf_trace_context import *
ModuleNotFoundError: No module named 'perf_trace_context'
Error running python script ./perf-script.py
Committer notes:
To build with python3 use:
$ make -C tools/perf PYTHON=python3
Use a non-const variable to pass the 'name' arg to
PyImport_AppendInittab(), as python2.6 has that as 'char *', which ends
up trowing this in some environments:
CC /tmp/build/perf/util/parse-branch-options.o
util/scripting-engines/trace-event-python.c: In function 'python_start_script':
util/scripting-engines/trace-event-python.c:1520:2: error: passing argument 1 of 'PyImport_AppendInittab' discards 'const' qualifier from pointer target type [-Werror]
PyImport_AppendInittab("perf_trace_context", initfunc);
In file included from /usr/include/python2.6/Python.h:130:0,
from util/scripting-engines/trace-event-python.c:22:
/usr/include/python2.6/import.h:54:17: note: expected 'char *' but argument is of type 'const char *'
PyAPI_FUNC(int) PyImport_AppendInittab(char *name, void (*initfunc)(void));
cc1: all warnings being treated as errors
Signed-off-by: Tony Jones <tonyj@suse.de>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Jaroslav Škarvada <jskarvad@redhat.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Ravi Bangoria <ravi.bangoria@linux.ibm.com>
Cc: Seeteena Thoufeek <s1seetee@linux.vnet.ibm.com>
Fixes: 66dfdff03d19 ("perf tools: Add Python 3 support")
Link: http://lkml.kernel.org/r/20190124005229.16146-2-tonyj@suse.de
[ Upstream commit 72e0b15cb24a497d7d0d4707cf51ff40c185ae8c ]
With Python3. PyUnicode_FromStringAndSize is unsafe to call on attr and will
return NULL. Use _PyBytes_FromStringAndSize (as with raw_buf).
Below is the observed behavior without the fix. Note it is first necessary
to apply the prior fix (Add trace_context extension module to sys,modules):
# perf record -e raw_syscalls:sys_enter /bin/false
[ perf record: Captured and wrote 0.018 MB perf.data (21 samples) ]
in trace_begin
Segmentation fault (core dumped)
Link: http://lkml.kernel.org/r/20190124005229.16146-3-tonyj@suse.de
[ Upstream commit 8184d44c9a577a2f1842ed6cc844bfd4a9981d8e ]
Use recently introduced bpf_probe_prog_type() to skip tests in the
test_verifier() if bpf_verify_program() fails. The skipped test is
indicated in the output.
Example:
679/p bpf_get_stack return R0 within range SKIP (unsupported program
type 5)
680/p ld_abs: invalid op 1 OK
Summary: 863 PASSED, 165 SKIPPED, 3 FAILED
Signed-off-by: Stanislav Fomichev <sdf@google.com>
[ Upstream commit 3aa415dd2128e478ea3225b59308766de0e94d6b ]
The get_metadata() test requires real root, so let's skip it if we're not
real root.
Note that I used XFAIL here because that's what the test does later if
CONFIG_CHEKCKPOINT_RESTORE happens to not be enabled. After looking at the
code, there doesn't seem to be a nice way to skip tests defined as TEST(),
since there's no return code (I tried exit(KSFT_SKIP), but that didn't work
either...). So let's do it this way to be consistent, and easier to fix
when someone comes along and fixes it.
Signed-off-by: Tycho Andersen <tycho@tycho.ws>
[ Upstream commit 2187d87eacd46f6214ce3dc9cfd7a558375a4153 ]
On IBM z13 machine types 2964 and 2965 the descriptor
sizes for sampling and diagnostic sampling entries
might be missing in the trailer entry and are set to zero.
This leads to a perf report failure when processing diagnostic
sampling entries.
This patch adds missing descriptor sizes when the trailer entry
contains zero for these fields.
Output before:
[root@s38lp82 perf]# ./perf report --stdio | fgrep Samples
0xabbf0 [0x8]: failed to process type: 68
Error:
failed to process sample
Output after:
# Total Lost Samples: 0
# Samples: 3K of event 'SF_CYCLES_BASIC_DIAG'
# Samples: 162 of event 'CF_DIAG'
Fixes: 2b1444f2e28b ("perf report: Add raw report support for s390 auxiliary trace")
Signed-off-by: Thomas Richter <tmricht@linux.ibm.com>
Reviewed-by: Hendrik Brueckner <brueckner@linux.ibm.com>
Link: http://lkml.kernel.org/r/20190211100627.85714-1-tmricht@linux.ibm.com
[ Upstream commit 7346195e8643482968f547483e0d823ec1982fab ]
We can't assume inlined symbols with the same name are equal, because
their address range may be different. This will cause the symbols with
different addresses be shadowed when adding to the hist entry, and lead
to ERANGE error when checking the symbol address during sample parse,
the addr should be within the range of [sym.start, sym.end].
The error message is like: "0x36aea60 [0x8]: failed to process type: 68".
The second parameter of symbol__new() is the length of the fake symbol
for the inline frame, which is the subtraction of the end and start
address of base_sym.
Signed-off-by: He Kuang <hekuang@huawei.com>
Fixes: aa441895f7b4 ("perf report: Compare symbol name for inlined frames when sorting")
Link: http://lkml.kernel.org/r/20190219130531.15692-1-hekuang@huawei.com
[ Upstream commit 03d309711d687460d1345de8a0363f45b1c8cd11 ]
Commit 489338a717a0 ("perf tests evsel-tp-sched: Fix bitwise operator")
causes test case 14 "Parse sched tracepoints fields" to fail on s390.
This test succeeds on x86.
In fact this test now fails on all architectures with type char treated
as type unsigned char.
The root cause is the signed-ness of character arrays in the tracepoints
sched_switch for structure members prev_comm and next_comm.
On s390 the output of:
[root@m35lp76 perf]# cat /sys/kernel/debug/tracing/events/sched/sched_switch/format
format:
field:unsigned short common_type; offset:0; size:2; signed:0;
field:char prev_comm[16]; offset:8; size:16; signed:0;
field:char next_comm[16]; offset:40; size:16; signed:0;
reveals the character arrays prev_comm and next_comm are per
default unsigned char and have values in the range of 0..255.
On x86 both fields are signed as this output shows:
[root@f29]# cat /sys/kernel/debug/tracing/events/sched/sched_switch/format
format:
field:char prev_comm[16]; offset:8; size:16; signed:1;
field:char next_comm[16]; offset:40; size:16; signed:1;
and the character arrays prev_comm and next_comm are per default signed
char and have values in the range of -1..127. The implementation of
type char is architecture specific.
Since the character arrays in both tracepoints sched_switch and
sched_wakeup should contain ascii characters, simply omit the check for
signedness in the test case.
Output before:
[root@m35lp76 perf]# ./perf test -F 14
14: Parse sched tracepoints fields :
--- start ---
sched:sched_switch: "prev_comm" signedness(0) is wrong, should be 1
sched:sched_switch: "next_comm" signedness(0) is wrong, should be 1
sched:sched_wakeup: "comm" signedness(0) is wrong, should be 1
---- end ----
14: Parse sched tracepoints fields : FAILED!
Output after:
[root@m35lp76 perf]# ./perf test -Fv 14
--- start ---
---- end ----
Parse sched tracepoints fields: Ok
Fixes: 489338a717a0 ("perf tests evsel-tp-sched: Fix bitwise operator")
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20190219153639.31267-1-tmricht@linux.ibm.com
[ Upstream commit 11db1ad4513d6205d2519e1a30ff4cef746e3243 ]
The output of "perf annotate -l --stdio xxx" changed since commit 425859ff0de33
("perf annotate: No need to calculate notes->start twice") removed notes->start
assignment in symbol__calc_lines(). It will get failed in
find_address_in_section() from symbol__tty_annotate() subroutine as the
a2l->addr is wrong. So the annotate summary doesn't report the line number of
source code correctly.
Before fix:
liwei@euler:~/main_code/hulk_work/hulk/tools/perf$ cat common_while_1.c
void hotspot_1(void)
volatile int i;
for (i = 0; i < 0x10000000; i++);
int main(void)
hotspot_1();
return 0;
liwei@euler:~/main_code/hulk_work/hulk/tools/perf$ gcc common_while_1.c -g -o common_while_1
liwei@euler:~/main_code/hulk_work/hulk/tools/perf$ sudo ./perf record ./common_while_1
[ perf record: Woken up 2 times to write data ]
[ perf record: Captured and wrote 0.488 MB perf.data (12498 samples) ]
liwei@euler:~/main_code/hulk_work/hulk/tools/perf$ sudo ./perf annotate -l -s hotspot_1 --stdio
Sorted summary for file /home/liwei/main_code/hulk_work/hulk/tools/perf/common_while_1
19.30 common_while_1[32]
19.03 common_while_1[4e]
19.01 common_while_1[16]
5.04 common_while_1[13]
4.99 common_while_1[4b]
4.78 common_while_1[2c]
4.77 common_while_1[10]
4.66 common_while_1[2f]
4.59 common_while_1[51]
4.59 common_while_1[35]
4.52 common_while_1[19]
4.20 common_while_1[56]
0.51 common_while_1[48]
Percent | Source code & Disassembly of common_while_1 for cycles:ppp (12480 samples, percent: local period)
: Disassembly of section .text:
: 00000000000005fa <hotspot_1>:
: hotspot_1():
: void hotspot_1(void)
0.00 : 5fa: push %rbp
0.00 : 5fb: mov %rsp,%rbp
: volatile int i;
: for (i = 0; i < 0x10000000; i++);
0.00 : 5fe: movl $0x0,-0x4(%rbp)
0.00 : 605: jmp 610 <hotspot_1+0x16>
0.00 : 607: mov -0x4(%rbp),%eax
common_while_1[10] 4.77 : 60a: add $0x1,%eax
common_while_1[13] 5.04 : 60d: mov %eax,-0x4(%rbp)
common_while_1[16] 19.01 : 610: mov -0x4(%rbp),%eax
common_while_1[19] 4.52 : 613: cmp $0xfffffff,%eax
0.00 : 618: jle 607 <hotspot_1+0xd>
After fix:
[ perf record: Captured and wrote 0.488 MB perf.data (12500 samples) ]
33.34 common_while_1.c:5
33.34 common_while_1.c:6
33.32 common_while_1.c:7
Percent | Source code & Disassembly of common_while_1 for cycles:ppp (12482 samples, percent: local period)
: hotspot_1():
: volatile int i;
common_while_1.c:5 4.70 : 60a: add $0x1,%eax
4.89 : 60d: mov %eax,-0x4(%rbp)
common_while_1.c:5 19.03 : 610: mov -0x4(%rbp),%eax
common_while_1.c:5 4.72 : 613: cmp $0xfffffff,%eax
0.00 : 61a: movl $0x0,-0x4(%rbp)
0.00 : 621: jmp 62c <hotspot_1+0x32>
0.00 : 623: mov -0x4(%rbp),%eax
common_while_1.c:6 4.54 : 626: add $0x1,%eax
4.73 : 629: mov %eax,-0x4(%rbp)
common_while_1.c:6 19.54 : 62c: mov -0x4(%rbp),%eax
common_while_1.c:6 4.54 : 62f: cmp $0xfffffff,%eax
Cc: Jin Yao <yao.jin@linux.intel.com>
Fixes: 425859ff0de33 ("perf annotate: No need to calculate notes->start twice")
Link: http://lkml.kernel.org/r/20190221095716.39529-1-liwei391@huawei.com
[ Upstream commit 7c5b019e3a638a5a290b0ec020f6ca83d2ec2aaa ]
Fix buffer overflow observed when running perf test.
The overflow is when trying to evaluate "1ULL << (64 - 1)" which is
resulting in -9223372036854775808 which overflows the 20 character
buffer.
If is possible this bug has been reported before but I still don't see
any fix checked in:
See: https://www.spinics.net/lists/linux-perf-users/msg07714.html
Reported-by: Michael Sartain <mikesart@fastmail.com>
Reported-by: Mathias Krause <minipli@googlemail.com>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/20190228015532.8941-1-tonyj@suse.de
[ Upstream commit e34c940245437f36d2c492edd1f8237eff391064 ]
Ravi Bangoria reported that we fail with an empty NUMA node with the
following message:
$ lscpu
NUMA node0 CPU(s):
NUMA node1 CPU(s): 0-4
$ sudo ./perf c2c report
node/cpu topology bugFailed setup nodes
Fix this by detecting the empty node and keeping its CPU set empty.
Reported-by: Nageswara R Sastry <nasastry@in.ibm.com>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Tested-by: Ravi Bangoria <ravi.bangoria@linux.ibm.com>
Cc: Jonas Rabenstein <jonas.rabenstein@studium.uni-erlangen.de>
Link: http://lkml.kernel.org/r/20190305152536.21035-2-jolsa@kernel.org
[ Upstream commit 8e2688876c7f7073d925e1f150e86b8ed3338f52 ]
libbpf targets don't explicitly depend on fixdep target, so when
we do 'make -j$(nproc)', there is a high probability, that some
objects will be built before fixdep binary is available.
Fix this by running sub-make; this makes sure that fixdep dependency
is properly accounted for.
For the same issue in perf, see commit abb26210a395 ("perf tools: Force
fixdep compilation at the start of the build").
Before:
$ rm -rf /tmp/bld; mkdir /tmp/bld; make -j$(nproc) O=/tmp/bld -C tools/lib/bpf/
... libelf: [ on ]
... bpf: [ on ]
HOSTCC /tmp/bld/fixdep.o
CC /tmp/bld/libbpf.o
CC /tmp/bld/bpf.o
CC /tmp/bld/btf.o
CC /tmp/bld/nlattr.o
CC /tmp/bld/libbpf_errno.o
CC /tmp/bld/str_error.o
CC /tmp/bld/netlink.o
CC /tmp/bld/bpf_prog_linfo.o
CC /tmp/bld/libbpf_probes.o
CC /tmp/bld/xsk.o
HOSTLD /tmp/bld/fixdep-in.o
LINK /tmp/bld/fixdep
LD /tmp/bld/libbpf-in.o
LINK /tmp/bld/libbpf.a
LINK /tmp/bld/libbpf.so
LINK /tmp/bld/test_libbpf
$ head /tmp/bld/.libbpf.o.cmd
# cannot find fixdep (/usr/local/google/home/sdf/src/linux/xxx//fixdep)
# using basic dep data
/tmp/bld/libbpf.o: libbpf.c /usr/include/stdc-predef.h \
/usr/include/stdlib.h /usr/include/features.h \
/usr/include/x86_64-linux-gnu/sys/cdefs.h \
/usr/include/x86_64-linux-gnu/bits/wordsize.h \
/usr/include/x86_64-linux-gnu/gnu/stubs.h \
/usr/include/x86_64-linux-gnu/gnu/stubs-64.h \
/usr/lib/gcc/x86_64-linux-gnu/7/include/stddef.h \
After:
... libelf: [ on ]
... bpf: [ on ]
CC /tmp/bld/bpf.o
CC /tmp/bld/btf.o
CC /tmp/bld/xsk.o
cmd_/tmp/bld/libbpf.o := gcc -Wp,-MD,/tmp/bld/.libbpf.o.d -Wp,-MT,/tmp/bld/libbpf.o -g -Wall -DHAVE_LIBELF_MMAP_SUPPORT -DCOMPAT_NEED_REALLOCARRAY -Wbad-function-cast -Wdeclaration-after-statement -Wformat-security -Wformat-y2k -Winit-self -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wno-system-headers -Wold-style-definition -Wpacked -Wredundant-decls -Wshadow -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wundef -Wwrite-strings -Wformat -Wstrict-aliasing=3 -Werror -Wall -fPIC -I. -I/usr/local/google/home/sdf/src/linux/tools/include -I/usr/local/google/home/sdf/src/linux/tools/arch/x86/include/uapi -I/usr/local/google/home/sdf/src/linux/tools/include/uapi -fvisibility=hidden -D"BUILD_STR(s)=$(pound)s" -c -o /tmp/bld/libbpf.o libbpf.c
source_/tmp/bld/libbpf.o := libbpf.c
deps_/tmp/bld/libbpf.o := \
/usr/include/stdlib.h \
Fixes: 7c422f557266 ("tools build: Build fixdep helper from perf and basic libs")
Reported-by: Eric Dumazet <edumazet@google.com>
commit 056d28d135bca0b1d0908990338e00e9dadaf057 upstream.
If it is not in the default location, compilation fails at several points.
Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Link: https://lkml.kernel.org/r/91a25e992566a7968fedc89ec80e7f4c83ad0548.1553622500.git.jpoimboe@redhat.com
commit f3b4e06b3bda759afd042d3d5fa86bea8f1fe278 upstream.
A TSC packet can slip past MTC packets so that the timestamp appears to
go backwards. One estimate is that can be up to about 40 CPU cycles,
which is certainly less than 0x1000 TSC ticks, but accept slippage an
order of magnitude more to be on the safe side.
Fixes: 79b58424b821c ("perf tools: Add Intel PT support for decoding MTC packets")
Link: http://lkml.kernel.org/r/20190325135135.18348-1-adrian.hunter@intel.com
