O= option in Makefile
commit f82263c6989c31ae9b94cecddffb29dcbec38710 upstream.
Since commit ee0778a30153
("tools/power: turbostat: make Makefile a bit more capable")
turbostat's Makefile is using
BUILD_OUTPUT := $(PWD)
which obviously causes trouble when building "turbostat" with
make -C /usr/src/linux/tools/power/x86/turbostat ARCH=x86 turbostat
because GNU make does not update nor guarantee that $PWD is set.
This patch changes the Makefile to use $CURDIR instead, which GNU make
guarantees to set and update (i.e. when using "make -C ...") and also
adds support for the O= option (see "make help" in your root of your
kernel source tree for more details).
Link: https://bugs.gentoo.org/show_bug.cgi?id=533918
Fixes: ee0778a30153 ("tools/power: turbostat: make Makefile a bit more capable")
Signed-off-by: Thomas D. <whissi@whissi.de>
Cc: Mark Asselstine <mark.asselstine@windriver.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit c5e691928bf166ac03430e957038b60adba3cf6c upstream.
When a event PADDING is hit (a deleted event that is still in the ring
buffer), translate_data() sets the length of the padding and also updates
the data pointer which is passed back to the caller.
This is unneeded because the caller also updates the data pointer with
the passed back length. translate_data() should not update the pointer,
only set the length.
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/20150324135923.461431960@goodmis.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit e1e455f4f4d35850c30235747620d0d078fe9f64 upstream.
This patch fixes this build error with glibc < 2.6.
CC util/cloexec.o
cc1: warnings being treated as errors
util/cloexec.c: In function ‘perf_flag_probe’:
util/cloexec.c:24: error: implicit declaration of function
‘sched_getcpu’
util/cloexec.c:24: error: nested extern declaration of ‘sched_getcpu’
make: *** [util/cloexec.o] Error 1
Signed-off-by: Vinson Lee <vlee@twitter.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Yann Droneaud <ydroneaud@opteya.com>
Link: http://lkml.kernel.org/r/1427137761-16119-1-git-send-email-vlee@twopensource.com
commit 76aea7731e7050c066943a1d7456ec6510702601 upstream.
Commit:
c6e5e9fbc3ea ("perf tools: Fix building error in x86_64 when dwarf unwind is on")
removed the definition of IS_X86_64 but not all places using it, with
the consequence that perf-read-vdsox32 would not be built anymore, and
the default lib install directory was 'lib' instead of 'lib64'.
Also needs to go to v3.19.
Signed-off-by: H.J. Lu <hjl.tools@gmail.com>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/CAMe9rOqpGVq3D88w+D15ef7sv6G6k57ZeTvxBm46=WFgzo9p1w@mail.gmail.com
commit 4e31050f482c02c822b150d71cf1ea5be7c9d6e4 upstream.
The token STT_GNU_IFUNC is not available with glibc 2.9 and older.
Define this token if it is not already defined.
This patch fixes this build errors with older versions of glibc.
CC util/symbol-elf.o
util/symbol-elf.c: In function ‘elf_sym__is_function’:
util/symbol-elf.c:75: error: ‘STT_GNU_IFUNC’ undeclared (first use in this function)
util/symbol-elf.c:75: error: (Each undeclared identifier is reported only once
util/symbol-elf.c:75: error: for each function it appears in.)
make: *** [util/symbol-elf.o] Error 1
Cc: Avi Kivity <avi@cloudius-systems.com>
Cc: Stephane Eranian <eranian@google.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Link: http://lkml.kernel.org/r/1423528286-13630-1-git-send-email-vlee@twopensource.com
commit 48536c9195ae8c2a00fd8f400bac72ab613feaab upstream.
Commit f6edb53c4993ffe92ce521fb449d1c146cea6ec2 converted the probe to
a CPU wide event first (pid == -1). For kernels that do not support
the PERF_FLAG_FD_CLOEXEC flag the probe fails with EINVAL. Since this
errno is not handled pid is not reset to 0 and the subsequent use of
pid = -1 as an argument brings in an additional failure path if
perf_event_paranoid > 0:
$ perf record -- sleep 1
perf_event_open(..., 0) failed unexpectedly with error 13 (Permission denied)
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.007 MB /tmp/perf.data (11 samples) ]
Also, ensure the fd of the confirmation check is closed and comment why
pid = -1 is used.
Needs to go to 3.18 stable tree as well.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Based-on-patch-by: David Ahern <david.ahern@oracle.com>
Acked-by: David Ahern <david.ahern@oracle.com>
Cc: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/54EC610C.8000403@intel.com
Pull core kernel fixes from Ingo Molnar:
"Two liblockdep fixes and a CPU hotplug race fix"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tools/liblockdep: don't include host headers
tools/liblockdep: ignore generated .so file
smpboot: Add missing get_online_cpus() in smpboot_register_percpu_thread()
Adding host headers to include path may cause unexpected surprises when cross
compiling. Remove /usr/local/include from the default include path.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
The commit dfef99cd0b2c ("perf probe: Use ref_reloc_sym based address
instead of the symbol name") converts kprobes to use ref_reloc_sym (i.e.
_stext) and offset instead of using symbol's name directly. So on my
system, adding do_fork ends up with like below:
$ sudo perf probe -v --add do_fork%return
probe-definition(0): do_fork%return
symbol:do_fork file:(null) line:0 offset:0 return:1 lazy:(null)
0 arguments
Looking at the vmlinux_path (7 entries long)
Using /lib/modules/3.17.6-1-ARCH/build/vmlinux for symbols
Could not open debuginfo. Try to use symbols.
Opening /sys/kernel/debug/tracing/kprobe_events write=1
Added new event:
Writing event: r:probe/do_fork _stext+456136
Failed to write event: Invalid argument
Error: Failed to add events. Reason: Operation not permitted (Code: -1)
As you can see, the do_fork was translated to _stext+456136. This was
because to support (local) symbols that have same name. But the problem
is that kretprobe requires to be inserted at function start point so it
simply checks whether it's called with offset 0. And if not, it'll
return with -EINVAL. You can see it with dmesg.
$ dmesg | tail -1
[125621.764103] Return probe must be used without offset.
So we need to use the symbol name instead of ref_reloc_sym in case of
return probes.
Reported-by: Jiri Olsa <jolsa@redhat.com>
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Tested-by: Jiri Olsa <jolsa@redhat.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/1421234288-22758-4-git-send-email-namhyung@kernel.org
given name
Removing boilerplate from two places, where one would have to find the
first entry, then iterate using symbol__next_by_name + strcmp to see if
the next member had the same name.
Link: http://lkml.kernel.org/n/tip-eh73z8gthv20yowirmx2yk38@git.kernel.org
The find_probe_trace_events_from_map() searches matching symbol from a
map (so from a backing dso). For uprobes, it'll create a new map (and
dso) and loads it using a filter. It's a little bit inefficient in that
it'll read out the symbol table everytime but works well anyway.
For kprobes however, it'll reuse existing kernel map which might be
loaded before. In this case map__load() just returns with no result.
It makes kprobes always failed to find symbol even if it exists in the
map (dso).
To fix it, use map__find_symbol_by_name() instead. It'll load a map
with full symbols and sorts them by name. It needs to search sibing
nodes since there can be multiple (local) symbols with same name.
Link: http://lkml.kernel.org/r/1421234288-22758-3-git-send-email-namhyung@kernel.org
[ Use symbol__next_by_name ]
Given a symbol, go to the next entry in a rbtree sorted by symbol name.
Link: http://lkml.kernel.org/n/tip-aq210drxprnu2so4dye5xa3j@git.kernel.org
When a dso contains multiple symbols which have same name, current
dso__find_symbol_by_name() only finds an one of them and there's no way
to get the all symbols without going through the rbtree.
So make symbols__find_by_name() return the first entry with the given
name and the next patch in this series will provide a way to iterate
from there, by the name ordered rb_tree, till a suitable symbol is
found.
Link: http://lkml.kernel.org/r/1421234288-22758-2-git-send-email-namhyung@kernel.org
[ Yanked this independent hunk, without changes, from a larger patch ]
The lock prefix handling fails to free the strdup()'d name as well as
the fields allocated by the instruction parsing.
Signed-off-by: Rabin Vincent <rabin@rab.in>
Link: http://lkml.kernel.org/r/1421607621-15005-2-git-send-email-rabin@rab.in
Don't use the ins's ->sncprintf() if the parsing failed.
For example, this fixes the display of "imul %edx". Without this patch:
| imul (null),(null)
After this patch:
| imul %edx
Link: http://lkml.kernel.org/r/1421607621-15005-1-git-send-email-rabin@rab.in
When building perf for arm64 I hit a warning (and be treated as an
error) like below:
aarch64-oe-linux-gcc -o .../scripts/perl/Perf-Trace-Util/Context.o -c -Wbad-function-cast \
... scripts/perl/Perf-Trace-Util/Context.c
In file included from .../usr/lib64/perl/5.14.3/CORE/perl.h:2464:0,
from Context.xs:23:
/.../usr/lib64/perl/5.14.3/CORE/handy.h:108:0: error: "bool" redefined [-Werror]
# define bool char
In file included from /.../usr/src/kernel/tools/include/linux/types.h:4:0,
from /.../usr/src/kernel/arch/arm64/include/uapi/asm/sigcontext.h:19,
from /.../usr/include/bits/sigcontext.h:27,
from /.../usr/include/signal.h:340,
from /.../usr/include/sys/param.h:28,
from /.../usr/lib64/perl/5.14.3/CORE/perl.h:678,
from Context.xs:23:
/.../usr/lib/aarch64-oe-linux/gcc/aarch64-oe-linux/4.9.2/include/stdbool.h:33:0: note: this is the location of the previous definition
#define bool _Bool
Looks like the failure is caused by arm64 uapi/asm/sigcontext.h, which
includes linux/types.h while other archs not.
Current perl consider this problem:
http://perl5.git.perl.org/perl.git/commit/bd31be4baa3ee68abdb92c0db3200efe0fad903b
However there are users which use old version of perl.
This patch includes stdbool.h before Context.xs and define HAS_BOOL to
prevent perl'e headers define its own 'bool'. Code is learn from perl's
git tree.
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Acked-by: Jiri Olsa <jolsa@redhat.com>
Cc: Li Zefan <lizefan@huawei.com>
Link: http://lkml.kernel.org/r/1421671397-4659-1-git-send-email-wangnan0@huawei.com
[acme@mica ~]$ trace -p 3330
Error: Unable to find debugfs
Hint: Was your kernel was compiled with debugfs support?
Hint: Is the debugfs filesystem mounted?
Hint: Try 'sudo mount -t debugfs nodev /sys/kernel/debug'
Fix it.
Cc: Borislav Petkov <bp@suse.de>
Cc: Don Zickus <dzickus@redhat.com>
Link: http://lkml.kernel.org/n/tip-kb9s0xy5z8i51abdu4bgm3rv@git.kernel.org
dwfl_report_offline() works only when libraries are prelinked.
Replace dwfl_report_offline() with dwfl_report_elf() so we correctly
extract debug info even from libraries that are not prelinked.
Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Link: http://lkml.kernel.org/r/20150114221045.GA17703@us.ibm.com
Currently the symbol structure is allocated with symbol_conf.priv_size
to carry sideband information like annotation, map browser on TUI and
sort-by-name tree node. So retrieving these information from symbol
needs to care about the details of such placement.
However the annotation code just assumes that the symbol is placed after
the struct annotation. But actually there's other info between them.
So accessing those struct will lead to an undefined behavior (usually a
crash) after they write their info to the same location.
To reproduce the problem, please follow the steps below:
1. run perf report (TUI of course) with -v option
2. open map browser (by pressing right arrow key for any entry)
3. search any function (by pressing '/' key and input whatever..)
4. return to the hist browser (by pressing 'q' or left arrow key)
5. open annotation window for the same entry (by pressing 'a' key)
Link: http://lkml.kernel.org/r/1421234288-22758-1-git-send-email-namhyung@kernel.org
Perf tool fails to unwind user stack if the event raises in a shared
object. This patch improves tests/dwarf-unwind.c to demonstrate the
problem by utilizing commonly used glibc function "bsearch". If perf is
not statically linked, the testcase will try to unwind a mixed call
trace.
By debugging libunwind I found that there is a bug in unwind-libunwind:
it always passes 0 as segbase to libunwind, cause libunwind unable to
locate debug_frame entry fir first level ip address (I add some more
debugging output into libunwind to make things clear):
>_Uarm_dwarf_find_debug_frame: start_ip = 10be98, end_ip = 10c2a4
>_Uarm_dwarf_find_debug_frame: found debug_frame table `/lib/libc-2.18.so': segbase=0x0, len=7, gp=0x0, table_data=0x449388
>_Uarm_dwarf_search_unwind_table: call lookup:ip = b6cd3bcc, segbase = 0, rel_ip = b6cd3bcc
>lookup: e->start_ip_offset = bcf18 (rel_ip = b6cd3bcc)
>lookup: e->start_ip_offset = 6d314 (rel_ip = b6cd3bcc)
>lookup: e->start_ip_offset = 33d0c (rel_ip = b6cd3bcc)
>lookup: e->start_ip_offset = 15d0c (rel_ip = b6cd3bcc)
>lookup: e->start_ip_offset = 15c40 (rel_ip = b6cd3bcc)
>_Uarm_dwarf_search_unwind_table: IP b6cd3bcc inside range b6c12000-b6d4c000, but no explicit unwind info found
>put_rs_cache: unmasking signals/interrupts and releasing lock
>_Uarm_dwarf_step: returning -10
>_Uarm_step: dwarf_step()=-10
This patch passes map->start as segbase to dwarf_find_debug_frame(), so
di will be initialized correctly.
In addition, dso and executable are different when setting segbase. This
patch first check whether the elf is executable, and pass segbase only
for shared object.
Cc: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/1421203007-75799-1-git-send-email-wangnan0@huawei.com
This is due to duplicated unistd inclusion (via uClibc headers + kernel headers)
Also seen on ARM uClibc based tools
------- ARC build ---------->8-------------
CC util/evlist.o
~/arc/k.org/arch/arc/include/uapi/asm/unistd.h:25:0,
from util/../perf-sys.h:10,
from util/../perf.h:15,
from util/event.h:7,
from util/event.c:3:
~/arc/k.org/include/uapi/asm-generic/unistd.h:906:0:
warning: "__NR_fcntl64" redefined [enabled by default]
#define __NR_fcntl64 __NR3264_fcntl
~/arc/gnu/INSTALL_1412-arc-2014.12-rc1/arc-snps-linux-uclibc/sysroot/usr/include/sys/syscall.h:24:0,
from util/../perf-sys.h:6,
----------------->8-------------------
------- ARM build ---------->8-------------
CC FPIC plugin_scsi.o
In file included from util/../perf-sys.h:9:0,
from util/cache.h:7,
from perf.c:12:
~/arc/k.org/arch/arm/include/uapi/asm/unistd.h:28:0:
warning: "__NR_restart_syscall" redefined [enabled by default]
~/buildroot/host/usr/arm-buildroot-linux-uclibcgnueabi/sysroot/usr/include/sys/syscall.h:25:0,
from perf.c:12:
~/buildroot/host/usr/arm-buildroot-linux-uclibcgnueabi/sysroot/usr/include/bits/sysnum.h:17:0:
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com>
Link: http://lkml.kernel.org/r/1421156604-30603-4-git-send-email-vgupta@synopsys.com
CC bench/sched-pipe.o
In file included from builtin-annotate.c:13:0:
util/cache.h:76:15: warning: redundant redeclaration of 'strlcpy'
[-Wredundant-decls]
extern size_t strlcpy(char *dest, const char *src, size_t size);
In file included from util/util.h:55:0,
from builtin.h:4,
from builtin-annotate.c:8:
~/vineetg/arc/gnu/INSTALL_1412-arc-2014.12-rc1/arc-snps-linux-uclibc/sysroot/usr/include/string.h:396:15:
note: previous declaration of 'strlcpy' was here
extern size_t strlcpy(char *__restrict dst, const char *__restrict src,
Link: http://lkml.kernel.org/r/1421156604-30603-3-git-send-email-vgupta@synopsys.com
ARC Linux uses the no legacy syscalls abi and corresponding uClibc headers
statfs defines f_type to be U32 which causes perf build breakage
http://git.uclibc.org/uClibc/tree/libc/sysdeps/linux/common-generic/bits/statfs.h
CC fs/fs.o
fs/fs.c: In function 'fs__valid_mount':
fs/fs.c:82:24: error: comparison between signed and unsigned integer
expressions [-Werror=sign-compare]
else if (st_fs.f_type != magic)
cc1: all warnings being treated as errors
Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com>
Cc: Cody P Schafer <dev@codyps.com>
Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com>
Link: http://lkml.kernel.org/r/1420888254-17504-2-git-send-email-vgupta@synopsys.com
We need to use lib/hweight.c for that, just like we do for lib/rbtree.c,
so tools need to link hweight.o. For now do it directly, but we need to
have a tools/lib/lk.a or .so that collects these goodies...
Reported-by: Jan Beulich <JBeulich@suse.com>
Link: http://lkml.kernel.org/n/tip-a1e91dx3apzqw5kbdt7ut21s@git.kernel.org
When thread__init_map_groups() fails, a new thread should be removed
from the rbtree since it's gonna be freed. Also update last match cache
only if the function succeeded.
Reported-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/1420763892-15535-1-git-send-email-namhyung@kernel.org
When build with 'make ARCH=x86' and dwarf unwind is on, there is a
compiling error:
CC /home/wn/perf/arch/x86/util/unwind-libdw.o
CC /home/wn/perf/arch/x86/tests/regs_load.o
arch/x86/tests/regs_load.S: Assembler messages:
arch/x86/tests/regs_load.S:65: Error: operand type mismatch for `push'
arch/x86/tests/regs_load.S:72: Error: operand type mismatch for `pop'
make[1]: *** [/home/wn/perf/arch/x86/tests/regs_load.o] Error 1
make[1]: INTERNAL: Exiting with 25 jobserver tokens available; should be 24!
make: *** [all] Error 2
Which is caused by incorrectly undefine macro HAVE_ARCH_X86_64_SUPPORT.
'config/Makefile.arch' tests __x86_64__ only when 'ARCH=x86_64'.
However, when building x86_64 kernel, ARCH=x86 is valid and commonly
used. Build systems, such as yocto, uses x86_64 compiler with 'ARCH=x86'
to build x86_64 perf, which causes mismatching.
As __LP64__ is defined for x86_64 as well, we can consolidate the
__x86_64__ check to the __LP64__ check and get rid of the IS_X86_64
IMHO.
(This patch is made by Namhyung Kim when replying my v1 patch:
https://lkml.org/lkml/2015/1/7/17
I modified the code to remove dependency on RAW_ARCH:
https://lkml.org/lkml/2015/1/7/865
Namhyung Kim didn't provide his SOB in his original email. I add
mine only for my modification.)
Link: http://lkml.kernel.org/r/1421029255-23039-1-git-send-email-wangnan0@huawei.com
[ Namhyung provided his S-o-B on a followup to this patch thread on lkml ]
When it failed to write probe commands to the probe_event file in
debugfs, it needs to propagate the error code properly. Current code
blindly uses the return value of the write(2) so it always uses
-1 (-EPERM) and it might confuse users.
Link: http://lkml.kernel.org/r/1420886028-15135-4-git-send-email-namhyung@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest
Pull kselftest fixes from Shuah Khan:
"This update contains three patches to fix one compile error, and two
run-time bugs. One of them fixes infinite loop on ARM"
* tag 'linux-kselftest-3.19-rc-5' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest:
selftests/vm: fix link error for transhuge-stress test
tools: testing: selftests: mq_perf_tests: Fix infinite loop on ARM
selftests/exec: allow shell return code of 126
Pull perf fixes from Ingo Molnar:
"Mostly tooling fixes, but also some kernel side fixes: uncore PMU
driver fix, user regs sampling fix and an instruction decoder fix that
unbreaks PEBS precise sampling"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86/uncore/hsw-ep: Handle systems with only two SBOXes
perf/x86_64: Improve user regs sampling
perf: Move task_pt_regs sampling into arch code
x86: Fix off-by-one in instruction decoder
perf hists browser: Fix segfault when showing callchain
perf callchain: Free callchains when hist entries are deleted
perf hists: Fix children sort key behavior
perf diff: Fix to sort by baseline field by default
perf list: Fix --raw-dump option
perf probe: Fix crash in dwarf_getcfi_elf
perf probe: Fix to fall back to find probe point in symbols
perf callchain: Append callchains only when requested
perf ui/tui: Print backtrace symbols when segfault occurs
perf report: Show progress bar for output resorting
locking fixes
add -lrt to fix undefined reference to `clock_gettime'
error seen when the test is compiled using gcc 4.6.4.
Signed-off-by: Andrey Skvortsov <andrej.skvortzov@gmail.com>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
When perf report on TUI shows callchain it checks first node has
siblings to determine whether it needs to print percentage value.
But it missed a case that first node is NULL. So sometimes it segfaults
like below:
$ perf top -g
perf: Segmentation fault
-------- backtrace --------
perf[0x4fcefb]
/usr/lib/libc.so.6(+0x33b20)[0x7f2a35839b20]
perf(rb_next+0x8)[0x47d3d8]
perf[0x4f6058]
perf[0x4f833b]
perf[0x4f8610]
perf[0x4f209e]
perf(ui_browser__run+0x3a)[0x4f2e6a]
perf[0x4f94ee]
perf(perf_evlist__tui_browse_hists+0x94)[0x4fbbf4]
perf[0x444d10]
/usr/lib/libpthread.so.0(+0x7314)[0x7f2a37070314]
/usr/lib/libc.so.6(clone+0x6d)[0x7f2a358ee5bd]
$ addr2line -e `which perf` 0x4f6058
/home/namhyung/project/linux/tools/perf/ui/browsers/hists.c:553
I don't know why the backtrace didn't print some symbols..
Fixes: 4087d11cd945 ("perf hists browser: Print overhead percent value for first-level callchain")
Link: http://lkml.kernel.org/r/1419401076-21700-1-git-send-email-namhyung@kernel.org
Markus reported that "perf top -g" can leak ~300MB per second on his
machine. This is partly because it missed to free callchains when hist
entries are deleted. Fix it.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Cc: Markus Trippelsdorf <markus@trippelsdorf.de>
Link: http://lkml.kernel.org/r/20141230053813.GD6081@sejong
When perf report --children resorts output fields, it tries to put
caller above the callee. But this was only meaningful for a same thread
and doing this requires callchain enabled. So fix its check before
comparing the callchain depth.
This also changes the hist accumulation tests: In test 3, xmalloc in
bash thread should be above than other perf threads due to alphabetical
order of comm string. Also it's under page_fault in bash thread since
alphabetical order of dso name. The sys_perf_event_open in perf thread
is put on the last line since it's self overhead is 0.
In test 4, the sys_perf_event_open is put above other perf entries that
have same children overhead since its callchain depth is smaller.
Link: http://lkml.kernel.org/r/1419309381-2593-1-git-send-email-namhyung@kernel.org
We can't use a char type to check for a negative return value since char
isn't guaranteed to be signed. Indeed, the char type tends to be unsigned on
ARM.
Signed-off-by: dann frazier <dann.frazier@canonical.com>
When the shell fails to invoke a script because its path name
is too long (ENAMETOOLONG), most shells return 127 to indicate
command not found. However, some systems report 126 (which POSIX
suggests should indicate a non-executable file) for this case,
so allow that too.
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org>
Signed-off-by: David Drysdale <drysdale@google.com>
Tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
The currently perf diff didn't add the baseline and delta (or other
compute) fields to the sort list so output will be sorted by other
fields like alphabetical order of DSO or symbol as below example.
Fix it by adding hpp formats for the fields and provides default compare
functions.
Before:
$ perf diff
# Event 'cycles'
# Baseline Delta Shared Object Symbol
[bridge] [k] ip_sabotage_in
[btrfs] [k] __etree_search.constprop.47
0.01% [btrfs] [k] btrfs_file_mmap
0.01% -0.01% [btrfs] [k] btrfs_getattr
[e1000e] [k] e1000_watchdog
0.00% [kernel.vmlinux] [k] PageHuge
0.00% [kernel.vmlinux] [k] __acct_update_integrals
0.00% [kernel.vmlinux] [k] __activate_page
[kernel.vmlinux] [k] __alloc_fd
0.02% +0.02% [kernel.vmlinux] [k] __alloc_pages_nodemask
After:
24.73% -4.62% perf [.] append_chain_children
7.96% -1.29% perf [.] dso__find_symbol
6.97% -2.07% libc-2.20.so [.] vfprintf
4.61% +0.88% libc-2.20.so [.] __fprintf_chk
4.41% +2.43% perf [.] sort__comm_cmp
4.10% -0.16% perf [.] comm__str
4.03% -0.93% perf [.] machine__findnew_thread_time
3.82% +3.09% perf [.] __hists__add_entry
2.95% -0.18% perf [.] sort__dso_cmp
Link: http://lkml.kernel.org/r/1419656793-32756-1-git-send-email-namhyung@kernel.org
Currently, 'perf list --raw-dump' requires extra arguments
(e.g., hw) to invoke, which breaks bash/zsh completion
(perf-completion.sh).
$ perf list --raw-dump
Error: unknown option `raw-dump'
usage: perf list [hw|sw|cache|tracepoint|pmu|event_glob]
After,
cpu-cycles instructions cache-references cache-misses ...
Signed-off-by: Taesoo Kim <tsgatesv@gmail.com>
Cc: Taesoo kim <taesoo@gatech.edu>
Link: http://lkml.kernel.org/r/1419997015-11071-1-git-send-email-tsgatesv@gmail.com
David reported that perf can segfault when adding an uprobe event like
this:
$ perf probe -x /lib64/libc-2.14.90.so -a 'malloc size=%di'
(gdb) bt
#0 parse_eh_frame_hdr (hdr=0x0, hdr_size=2596, hdr_vaddr=71788,
ehdr=0x7fffffffd390, eh_frame_vaddr=
0x7fffffffd378, table_entries=0x8808d8, table_encoding=0x8808e0 "") at
dwarf_getcfi_elf.c:79
#1 0x000000385f81615a in getcfi_scn_eh_frame (hdr_vaddr=71788,
hdr_scn=0x8839b0, shdr=0x7fffffffd2f0, scn=<optimized out>,
ehdr=0x7fffffffd390, elf=0x882b30) at dwarf_getcfi_elf.c:231
#2 getcfi_shdr (ehdr=0x7fffffffd390, elf=0x882b30) at dwarf_getcfi_elf.c:283
#3 dwarf_getcfi_elf (elf=0x882b30) at dwarf_getcfi_elf.c:309
#4 0x00000000004d5bac in debuginfo__find_probes (pf=0x7fffffffd4f0,
dbg=Unhandled dwarf expression opcode 0xfa) at util/probe-finder.c:993
#5 0x00000000004d634a in debuginfo__find_trace_events (dbg=0x880840,
pev=<optimized out>, tevs=0x880f88, max_tevs=<optimized out>) at
util/probe-finder.c:1200
#6 0x00000000004aed6b in try_to_find_probe_trace_events (target=0x881b20
"/lib64/libpthread-2.14.90.so",
max_tevs=128, tevs=0x880f88, pev=0x859b30) at util/probe-event.c:482
#7 convert_to_probe_trace_events (target=0x881b20
"/lib64/libpthread-2.14.90.so", max_tevs=128, tevs=0x880f88,
pev=0x859b30) at util/probe-event.c:2356
#8 add_perf_probe_events (pevs=<optimized out>, npevs=1, max_tevs=128,
target=0x881b20 "/lib64/libpthread-2.14.90.so", force_add=false) at
util/probe-event.c:2391
#9 0x000000000044014f in __cmd_probe (argc=<optimized out>,
argv=0x7fffffffe2f0, prefix=Unhandled dwarf expression opcode 0xfa) at
at builtin-probe.c:488
#10 0x0000000000440313 in cmd_probe (argc=5, argv=0x7fffffffe2f0,
prefix=<optimized out>) at builtin-probe.c:506
#11 0x000000000041d133 in run_builtin (p=0x805680, argc=5,
argv=0x7fffffffe2f0) at perf.c:341
#12 0x000000000041c8b2 in handle_internal_command (argv=<optimized out>,
argc=<optimized out>) at perf.c:400
#13 run_argv (argv=<optimized out>, argcp=<optimized out>) at perf.c:444
#14 main (argc=5, argv=0x7fffffffe2f0) at perf.c:559
And I found a related commit (5704c8c4fa71 "getcfi_scn_eh_frame: Don't
crash and burn when .eh_frame bits aren't there.") in elfutils that can
lead to a unexpected crash like this. To safely use the function, it
needs to check the .eh_frame section is a PROGBITS type.
Tested-by: David Ahern <dsahern@gmail.com>
Cc: Mark Wielaard <mjw@redhat.com>
Link: http://lkml.kernel.org/r/20141230090533.GH6081@sejong
Fix to fall back to find a probe point in symbols if perf fails to find
it in debuginfo.
This can happen when the target function is an alias of another
function. Such alias doesn't have an entry in debuginfo but in symbols.
David Ahern reported this problem in https://lkml.org/lkml/2014/12/29/355
I ensured the problem and deeper investigation discovers it.
eu-readelf --debug-dump=info /usr/lib/debug/lib/x86_64-linux-gnu/libc-2.19.so | grep \"malloc\" -A6
name (strp) "malloc"
decl_file (data1) 25
decl_line (data2) 466
prototyped (flag_present)
type (ref4) [ 81b5]
declaration (flag_present)
[ 8f58] formal_parameter
decl_file (data1) 23
type (ref4) [ 9f4a]
sibling (ref4) [ bb29]
All these entires have no instances (all of them are declarations)
This is why the perf probe failed to find it in debuginfo.
However, there are some malloc instances in symbols.
eu-readelf --symbols /usr/lib/debug/lib/x86_64-linux-gnu/libc-2.19.so | grep malloc$
1181: 0000000000080700 5332 FUNC LOCAL DEFAULT 12 _int_malloc
4537: 00000000000831d0 339 FUNC LOCAL DEFAULT 12 __GI___libc_malloc
5545: 00000000000831d0 339 FUNC LOCAL DEFAULT 12 __malloc
6063: 00000000000831d0 339 FUNC GLOBAL DEFAULT 12 malloc
7302: 00000000000831d0 339 FUNC GLOBAL DEFAULT 12 __libc_malloc
As you an see, malloc and __libc_malloc have same address, and actually
__libc_malloc has an entry in debuginfo. So you can set up a probe on
__libc_malloc.
To fix this problem shortly, perf probe simply falls back to find probe
point(malloc) in symbols if it is not found in debuginfo.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: yrl.pp-manager.tt@hitachi.com
Link: http://lkml.kernel.org/r/20141231062747.2087.80961.stgit@localhost.localdomain
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
Pull perf/urgent fixes from Arnaldo Carvalho de Melo:
User visible fixes:
- Show progress bar in more places while doing histogram processing
in the hists browser (Namhyung Kim)
- Print backtrace symbols when segfault occurs in 'report' (Namhyung Kim)
Infrastructure fixes:
- Append callchains only when requested (Namhyung Kim)
Pull kselftest fix from Shuah Khan:
"Fix exec test compile warnings"
* tag 'linux-kselftest-3.19-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest:
selftests/exec: Use %zu to format size_t
* pm-domains:
PM / Domains: Export of_genpd_get_from_provider function
* powercap:
powercap / RAPL: add IDs for future Xeon CPUs
* pm-tools:
tools / cpupower: Fix no idle state information return value
tools / cpupower: Correctly detect if running as root
The perf report --children can be called with callchain disabled so no
need to append callchains. Actually the root of callchain tree is not
initialized properly in this case.
Link: http://lkml.kernel.org/r/1419223455-4362-7-git-send-email-namhyung@kernel.org
The output will look like below. (I added an error into ui__init() for
the test).
$ perf report
perf[0x503781]
/usr/lib/libc.so.6(+0x33b20)[0x7f1a14f04b20]
perf(ui__init+0xd5)[0x503645]
perf(setup_browser+0x97)[0x4ce4e7]
perf(cmd_report+0xcea)[0x4392ba]
perf[0x428493]
perf(main+0x60a)[0x427c0a]
/usr/lib/libc.so.6(__libc_start_main+0xf0)[0x7f1a14ef1040]
perf[0x427d29]
[0x0]
Link: http://lkml.kernel.org/r/1419223455-4362-4-git-send-email-namhyung@kernel.org
Sometimes it takes a long time to resort hist entries for output in case
of a large data file. Show a progress bar window and inform user.
Link: http://lkml.kernel.org/r/1419223455-4362-3-git-send-email-namhyung@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/sashal/linux into core/urgent
Pull a liblockdep fix from Sasha Levin:
"A small (but important) fix to the way we detect freeing live locks. We would
pass a wrong memory region when testing for locks inside freed memory spaces,
which would trigger false positives."
On 32-bit:
execveat.c: In function 'check_execveat_pathmax':
execveat.c:183: warning: format '%lu' expects type 'long unsigned int', but argument 3 has type 'size_t'
execveat.c:187: warning: format '%lu' expects type 'long unsigned int', but argument 2 has type 'size_t'
sysfs_get_idlestate_count() returns an unsigned int. Returning -ENODEV
is not the right thing to do here, and in any case is handled the same
way as if there are no states found.
Signed-off-by: Prarit Bhargava <prarit@redhat.com>
Acked-by: Thomas Renninger <trenn@suse.de>
