path: root/tools
2015-10-31selftests/x86: Add a fork() to entry_from_vm86 to catch fork bugsAndy Lutomirski
Mere possession of vm86 state is strange. Make sure that nothing gets corrupted if we fork after calling vm86(). Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Brian Gerst <brgerst@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Stas Sergeev <stsp@list.ru> Link: http://lkml.kernel.org/r/08f83295460a80e41dc5e3e81ec40d6844d316f5.1446270067.git.luto@kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-10-16Merge tag 'powerpc-4.3-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fixes from Michael Ellerman: - Re-enable CONFIG_SCSI_DH in our defconfigs - Remove unused os_area_db_id_video_mode - cxl: fix leak of IRQ names in cxl_free_afu_irqs() from Andrew - cxl: fix leak of ctx->irq_bitmap when releasing context via kernel API from Andrew - cxl: fix leak of ctx->mapping when releasing kernel API contexts from Andrew - cxl: Workaround malformed pcie packets on some cards from Philippe - cxl: Fix number of allocated pages in SPA from Christophe Lombard - Fix checkstop in native_hpte_clear() with lockdep from Cyril - Panic on unhandled Machine Check on powernv from Daniel - selftests/powerpc: Fix build failure of load_unaligned_zeropad test * tag 'powerpc-4.3-4' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: selftests/powerpc: Fix build failure of load_unaligned_zeropad test powerpc/powernv: Panic on unhandled Machine Check powerpc: Fix checkstop in native_hpte_clear() with lockdep cxl: Fix number of allocated pages in SPA cxl: Workaround malformed pcie packets on some cards cxl: fix leak of ctx->mapping when releasing kernel API contexts cxl: fix leak of ctx->irq_bitmap when releasing context via kernel API cxl: fix leak of IRQ names in cxl_free_afu_irqs() powerpc/ps3: Remove unused os_area_db_id_video_mode powerpc/configs: Re-enable CONFIG_SCSI_DH
2015-10-13selftests/powerpc: Fix build failure of load_unaligned_zeropad testMichael Ellerman
Commit 7a5692e6e533 ("arch/powerpc: provide zero_bytemask() for big-endian") added a call to __fls() in our word-at-a-time.h. That was fine for the kernel build but missed the fact that we also use word-at-a-time.h in a userspace test. Pulling in the kernel version of __fls() gets messy, so just define our own, it's unlikely to change often. Fixes: 7a5692e6e533 ("arch/powerpc: provide zero_bytemask() for big-endian") Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-10-07Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/urgent fix from Arnaldo Carvalho de Melo: - Fix build break on (at least) powerpc due to sample_reg_masks, not being available for linking. (Sukadev Bhattiprolu) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-10-07perf tools: Fix build break on powerpc due to sample_reg_masksSukadev Bhattiprolu
perf_regs.c does not get built on Powerpc as CONFIG_PERF_REGS is false. So the weak definition for 'sample_regs_masks' doesn't get picked up. Adding perf_regs.o to util/Build unconditionally, exposes a redefinition error for 'perf_reg_value()' function (due to the static inline version in util/perf_regs.h). So use #ifdef HAVE_PERF_REGS_SUPPORT' around that function. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Cc: Stephane Eranian <eranian@google.com> Cc: linuxppc-dev@ozlabs.org Link: http://lkml.kernel.org/r/20150930182836.GA27858@us.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-10-01Merge tag 'pm+acpi-4.3-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management and ACPI fixes from Rafael Wysocki: "These are fixes mostly, for a few changes made in this cycle (the intel_idle driver, the OPP library, the ACPI EC driver, turbostat) and for some issues that have just been discovered (ACPI PCI IRQ management, PCI power management documentation, turbostat), with a couple of cleanups on top of them. Specifics: - intel_idle driver fixup for the recently added Skylake chips support (Len Brown). - Operating Performance Points (OPP) library fix related to the recently added support for new DT bindings and a fix for a typo in a comment (Viresh Kumar, Stephen Boyd). - ACPI EC driver fix for a recently introduced memory leak in an error code path (Lv Zheng). - ACPI PCI IRQ management fix for the issue where an ISA IRQ is shared with a PCI device which requires it to be configured in a different way and may cause an interrupt storm to happen as a result with an extra ACPI SCI IRQ handling simplification on top of it (Jiang Liu). - Update of the PCI power management documentation that became outdated and started to actively confuse the readers to make it actually reflect the code (Rafael J Wysocki). - turbostat fixes including an IVB Xeon regression fix (related to the --debug command line option), Skylake adjustment for the TSC running at a frequency that doesn't match the base one exactly, and a Knights Landing quirk to account for the fact that it only updates APERF and MPERF every 1024 clock cycles plus bumping up the turbostat version number (Len Brown, Hubert Chrzaniuk)" * tag 'pm+acpi-4.3-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: tools/power turbosat: update version number tools/power turbostat: SKL: Adjust for TSC difference from base frequency tools/power turbostat: KNL workaround for %Busy and Avg_MHz tools/power turbostat: IVB Xeon: fix --debug regression ACPI / PCI: Remove duplicated penalty on SCI IRQ ACPI, PCI, irq: Do not share PCI IRQ with ISA IRQ ACPI / EC: Fix a memory leak issue in acpi_ec_query() PM / OPP: Fix typo modifcation -> modification PCI / PM: Update runtime PM documentation for PCI devices PM / OPP: of_property_count_u32_elems() can return errors intel_idle: Skylake Client Support - updated
2015-09-27Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Thomas Gleixner: "Another pile of fixes for perf: - Plug overflows and races in the core code - Sanitize the flow of the perf syscall so we error out before handling the more complex and hard to undo setups - Improve and fix Broadwell and Skylake hardware support - Revert a fix which broke what it tried to fix in perf tools - A couple of smaller fixes in various places of perf tools" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Fix copying of /proc/kcore perf intel-pt: Remove no_force_psb from documentation perf probe: Use existing routine to look for a kernel module by dso->short_name perf/x86: Change test_aperfmperf() and test_intel() to static tools lib traceevent: Fix string handling in heterogeneous arch environments perf record: Avoid infinite loop at buildid processing with no samples perf: Fix races in computing the header sizes perf: Fix u16 overflows perf: Restructure perf syscall point of no return perf/x86/intel: Fix Skylake FRONTEND MSR extrareg mask perf/x86/intel/pebs: Add PEBS frontend profiling for Skylake perf/x86/intel: Make the CYCLE_ACTIVITY.* constraint on Broadwell more specific perf tools: Bool functions shouldn't return -1 tools build: Add test for presence of __get_cpuid() gcc builtin tools build: Add test for presence of numa_num_possible_cpus() in libnuma Revert "perf symbols: Fix mismatched declarations for elf_getphdrnum" perf stat: Fix per-pkg event reporting bug
2015-09-27Merge branch 'turbostat' of ↵Rafael J. Wysocki
https://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux into pm-tools Pull turbostat updates for v4.3 from Len Brown. * 'turbostat' of https://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: tools/power turbosat: update version number tools/power turbostat: SKL: Adjust for TSC difference from base frequency tools/power turbostat: KNL workaround for %Busy and Avg_MHz tools/power turbostat: IVB Xeon: fix --debug regression
2015-09-26tools/power turbosat: update version numberLen Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2015-09-26tools/power turbostat: SKL: Adjust for TSC difference from base frequencyLen Brown
On a Skylake with 1500MHz base frequency, the TSC runs at 1512MHz. This is because the TSC is no longer in the n*100 MHz BCLK domain, but is now in the m*24MHz crystal clock domain. (24 MHz * 63 = 1512 MHz) This adds error to several calculations in turbostat, unless the TSC sample sizes are adjusted for this difference. Note that calculations in the time domain are immune from this issue, as the timing sub-system has already calibrated the TSC against a known wall clock. AVG_MHz = APERF_delta/measurement_interval need no adjustment. APERF_delta is in the BCLK domain, and measurement_interval is in the time domain. TSC_MHz = TSC_delta/measurement_interval needs no adjustment -- as we really do want to report the actual measured TSC delta here, and measurement_interval is in the accurate time domain. %Busy = MPERF_delta/TSC_delta needs adjustment to use TSC_BCLK_DOMAIN_delta. TSC_BCLK_DOMAIN_delta = TSC_delta * base_hz / tsc_hz Bzy_MHz = TSC_delta/APERF_delta/MPERF_delta/measurement_interval need adjustment as above. No other metrics in turbostat need to be adjusted. Before: CPU Avg_MHz %Busy Bzy_MHz TSC_MHz - 550 24.84 2216 1512 0 2191 98.73 2219 1514 2 0 0.01 2130 1512 1 9 0.43 2016 1512 3 2 0.08 2016 1512 After: CPU Avg_MHz %Busy Bzy_MHz TSC_MHz - 550 25.05 2198 1512 0 2190 99.62 2199 1512 2 0 0.01 2152 1512 1 9 0.46 2000 1512 3 2 0.10 2000 1512 Note that in this example, the "Before" Bzy_MHz was reported as exceeding the 2200 max turbo rate. Also, even a pinned spin loop would not be reported as over 99% busy. Signed-off-by: Len Brown <len.brown@intel.com>
2015-09-26tools/power turbostat: KNL workaround for %Busy and Avg_MHzHubert Chrzaniuk
KNL increments APERF and MPERF every 1024 clocks. This is compliant with the architecture specification, which requires that only the ratio of APERF/MPERF need be valid. However, turbostat takes advantage of the fact that these two MSRs increment every un-halted clock at the actual and base frequency: AVG_MHz = APERF_delta/measurement_interval %Busy = MPERF_delta/TSC_delta This quirk is needed for these calculations to also work on KNL, which would otherwise show a value 1024x smaller than expected. Signed-off-by: Hubert Chrzaniuk <hubert.chrzaniuk@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2015-09-26tools/power turbostat: IVB Xeon: fix --debug regressionLen Brown
Staring in Linux-4.3-rc1, commit 6fb3143b561c ("tools/power turbostat: dump CONFIG_TDP") touches MSR 0x648, which is not supported on IVB-Xeon. This results in "turbostat --debug" exiting on those systems: turbostat: /dev/cpu/2/msr offset 0x648 read failed: Input/output error Remove IVB-Xeon from the list of machines supporting with that MSR. Signed-off-by: Len Brown <len.brown@intel.com>
2015-09-25perf tools: Fix copying of /proc/kcoreAdrian Hunter
A copy of /proc/kcore containing the kernel text can be made to the buildid cache. e.g. perf buildid-cache -v -k /proc/kcore To workaround objdump limitations, a copy is also made when annotating against /proc/kcore. The copying process stops working from libelf about v1.62 onwards (the problem was found with v1.63). The cause is that a call to gelf_getphdr() in kcore__add_phdr() fails because additional validation has been added to gelf_getphdr(). The use of gelf_getphdr() is a misguided attempt to get default initialization of the Gelf_Phdr structure. That should not be necessary because every member of the Gelf_Phdr structure is subsequently assigned. So just remove the call to gelf_getphdr(). Similarly, a call to gelf_getehdr() in gelf_kcore__init() can be removed also. Committer notes: Note to stable@kernel.org, from Adrian in the cover letter for this patchkit: The "Fix copying of /proc/kcore" problem goes back to v3.13 if you think it is important enough for stable. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: stable@kernel.org Link: http://lkml.kernel.org/r/1443089122-19082-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-25perf intel-pt: Remove no_force_psb from documentationAdrian Hunter
no_force_psb was dropped as a late change to the kernel driver. Consequently, remove it from the documentation. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1443089122-19082-2-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-25perf probe: Use existing routine to look for a kernel module by dso->short_nameArnaldo Carvalho de Melo
We have map_groups__find_by_name() to look at the list of modules that are in place for a given machine, so use it instead of traversing the machine dso list, which also includes DSOs for userspace. When merging the user and kernel DSO lists a bug was introduced where 'perf probe' stopped being able to add probes to modules using its short name: # perf probe -m usbnet --add usbnet_start_xmit usbnet_start_xmit is out of .text, skip it. Error: Failed to add events. # With this fix it works again: # perf probe -m usbnet --add usbnet_start_xmit Added new event: probe:usbnet_start_xmit (on usbnet_start_xmit in usbnet) You can now use it in all perf tools, such as: perf record -e probe:usbnet_start_xmit -aR sleep 1 # Reported-by: Wang Nan <wangnan0@huawei.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Fixes: 3d39ac538629 ("perf machine: No need to have two DSOs lists") Link: http://lkml.kernel.org/r/20150924015008.GE1897@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-22membarrier: clean up selftestMathieu Desnoyers
We don't need to specify an explicit rule in the Makefile, the implicit one will do the same. The "__EXPORTED_HEADERS__" define is not needed, because we build the test against the installed kernel headers, not the in-tree kernel headers. Re-use "$(TEST_PROGS)" in the clean target rather than spelling the executable name twice. Include <unistd.h> rather than the rather specific <asm-generic/unistd.h>. Include <syscall.h> rather than <sys/syscall.h>. In both cases, the former header is located in a standard location and includes the latter. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Cc: Pranith Kumar <bobby.prani@gmail.com> Cc: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22userfaultfd: selftest: don't error out if pthread_mutex_t isn't identicalAndrea Arcangeli
On ppc big endian this check fails, the mutex doesn't necessarily need to be identical for all pages after pthread_mutex_lock/unlock cycles. The count verification (outside of the pthread_mutex_t structure) suffices and that is retained. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Dr. David Alan Gilbert <dgilbert@redhat.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Thierry Reding <treding@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22userfaultfd: selftest: return an error if BOUNCE_VERIFY failsAndrea Arcangeli
This will report the error in the exit code, in addition of the fprintf. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Dr. David Alan Gilbert <dgilbert@redhat.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Thierry Reding <treding@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22userfaultfd: selftest: avoid my_bcmp false positives with powerpcAndrea Arcangeli
Keep a non-zero placeholder after the count, for the my_bcmp comparison of the page against the zeropage. The lockless increment between 255 to 256 against a lockless my_bcmp could otherwise return false positives on ppc32le. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Tested-by: Michael Ellerman <mpe@ellerman.id.au> Cc: Dr. David Alan Gilbert <dgilbert@redhat.com> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Thierry Reding <treding@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22userfaultfd: selftest: only warn if __NR_userfaultfd is undefinedMichael Ellerman
If __NR_userfaultfd is not yet defined by the arch, warn but still build and run the userfaultfd selftest successfully. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Dr. David Alan Gilbert <dgilbert@redhat.com> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Thierry Reding <treding@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22userfaultfd: selftest: headers fixupAndrea Arcangeli
Depend on "make headers_install" to create proper headers to include and provide syscall numbers. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Dr. David Alan Gilbert <dgilbert@redhat.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Thierry Reding <treding@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22userfaultfd: selftests: vm: pick up sanitized kernel headersThierry Reding
Add the usr/include subdirectory of the top-level tree to the include path, and make sure to include headers without relative paths to make sure the sanitized headers get picked up. Otherwise the compiler will not be able to find the linux/compiler.h header included by the non- sanitized include/uapi/linux/userfaultfd.h. While at it, make sure to only hardcode the syscall numbers on x86 and PowerPC if they haven't been properly picked up from the headers. Signed-off-by: Thierry Reding <treding@nvidia.com> Acked-by: Michael Ellerman <mpe@ellerman.id.au> Cc: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Dr. David Alan Gilbert <dgilbert@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-09-22tools lib traceevent: Fix string handling in heterogeneous arch environmentsKapileshwar Singh
When a trace recorded on a 32-bit device is processed with a 64-bit binary, the higher 32-bits of the address need to ignored. The lack of this results in the output of the 64-bit pointer value to the trace as the 32-bit address lookup fails in find_printk(). Before: burn-1778 [003] 548.600305: bputs: 0xc0046db2s: 2cec5c058d98c After: burn-1778 [003] 548.600305: bputs: 0xc0046db2s: RT throttling activated The problem occurs in PRINT_FIELD when the field is recognized as a pointer to a string (of the type const char *) Heterogeneous architectures cases below can arise and should be handled: * Traces recorded using 32-bit addresses processed on a 64-bit machine * Traces recorded using 64-bit addresses processed on a 32-bit machine Reported-by: Juri Lelli <juri.lelli@arm.com> Signed-off-by: Kapileshwar Singh <kapileshwar.singh@arm.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Javi Merino <javi.merino@arm.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/1442928123-13824-1-git-send-email-kapileshwar.singh@arm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Martin Schwidefsky: "A couple of system call updates. The two new system calls userfaultfd and membarrier have been added, as well as the 17 direct calls for the multiplexed socket system calls. In addition the system call compat wrappers have been flagged as notrace functions and a few wrappers could be removed. And bug fixes for the vector register handling, cpu_mf, suspend/resume, compat signals, SMT cputime accounting and the zfcp dumper" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390: wire up separate socketcalls system calls s390/compat: remove superfluous compat wrappers s390/compat: do not trace compat wrapper functions s390/s390x: allocate sys_membarrier system call number s390/configs//zfcpdump_defconfig: Remove CONFIG_MEMSTICK s390: wire up userfaultfd system call s390/vtime: correct scaled cputime for SMT s390/cpum_cf: Corrected return code for unauthorized counter sets s390/compat: correct uc_sigmask of the compat signal frame s390: fix floating point register corruption s390/hibernate: fix save and restore of vector registers
2015-09-19Merge tag 'linux-kselftest-4.3-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest fixes from Shuah Khan: "This update contains 7 fixes for problems ranging from build failurs to incorrect error reporting" * tag 'linux-kselftest-4.3-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: selftests: exec: revert to default emit rule selftests: change install command to rsync selftests: mqueue: simplify the Makefile selftests: mqueue: allow extra cflags selftests: rename jump label to static_keys selftests/seccomp: add support for s390 seltests/zram: fix syntax error
2015-09-18Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio fixes and cleanups from Michael Tsirkin: "This fixes the virtio-test tool, and improves the error handling for virtio-ccw" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: virtio/s390: handle failures of READ_VQ_CONF ccw tools/virtio: propagate V=X to kernel build vhost: move features to core tools/virtio: fix build after 4.2 changes
2015-09-18perf record: Avoid infinite loop at buildid processing with no samplesMark Rutland
If a session contains no events, we can get stuck in an infinite loop in __perf_session__process_events, with a non-zero file_size and data_offset, but a zero data_size. In this case, we can mmap the entirety of the file (consisting of the file and attribute headers), and fetch_mmaped_event will correctly refuse to read any (unmapped and non-existent) event headers. This causes __perf_session__process_events to unmap the file and retry with the exact same parameters, getting stuck in an infinite loop. This has been observed to result in an exit-time hang when counting rare/unschedulable events with perf record, and can be triggered artificially with the script below: ---- #!/bin/sh printf "REPRO: launching perf\n"; ./perf record -e software/config=9/ sleep 1 & PERF_PID=$!; sleep 0.002; kill -2 $PERF_PID; printf "REPRO: waiting for perf (%d) to exit...\n" "$PERF_PID"; wait $PERF_PID; printf "REPRO: perf exited\n"; ---- To avoid this, have __perf_session__process_events bail out early when the file has no data (i.e. it has no events). Commiter note: I only managed to reproduce this when setting /proc/sys/kernel/kptr_restrict to '1' and changing the code to purposefully not process any samples and no synthesized samples, i.e. kptr_restrict prevents 'record' from synthesizing the kernel mmaps for vmlinux + modules and since it is a workload started from perf, we don't synthesize mmap/comm records for existing threads. Adrian Hunter managed to reproduce it in his environment tho. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Tested-by: Arnaldo Carvalho de Melo <acme@kernel.org> Tested-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1442423929-12253-1-git-send-email-mark.rutland@arm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-18Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/urgent fixes from Arnaldo Carvalho de Melo: User visible changes: - When handling perf_event_open() returning EBUSY and not being able to opendir the procfs mount point we would tell the user that the oprofile daemon was found by returning -1 on as the return for a bool function, oops, fix it, found with Coccinelle. (Peter Senna Tschudin). - Fix per-pkg event reporting bug in 'perf stat'. (Stephane Eranian) Developer visible changes: - Fix missing prototype for function provided when it isn't present in the libelf present, fixing the build on RHEL/CentOS 5.1 systems, for instance. (Arnaldo Carvalho de Melo) - Detect if the gcc and libnuma have the features needed to avoid requiring the use of NO_LIBNUMA and/or NO_AUXTRACE to build on older systems. (Arnaldo Carvalho de Melo) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-09-17perf tools: Bool functions shouldn't return -1Peter Senna Tschudin
Returning a negative value for a boolean function seem to have the undesired effect of returning true. Replace -1 by false in a bool-returning function. The diff of the .s file before and after the change (for x86_64): 3907c3907 < movl $1, %ebx --- > xorl %ebx, %ebx while if -1 is replaced by true, the diff is empty. This issue was found by the following Coccinelle semantic patch: <smpl> @@ identifier f; constant C; typedef bool; @@ bool f (...){ <+... * return -C; ...+> } </smpl> Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Cc: Matt Fleming <matt.fleming@intel.com> Cc: Milos Vyletel <milos@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1442484533-19742-1-git-send-email-peter.senna@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-17Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: - misc fixes all around the map - block non-root vm86(old) if mmap_min_addr != 0 - two small debuggability improvements - removal of obsolete paravirt op * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/platform: Fix Geode LX timekeeping in the generic x86 build x86/apic: Serialize LVTT and TSC_DEADLINE writes x86/ioapic: Force affinity setting in setup_ioapic_dest() x86/paravirt: Remove the unused pv_time_ops::get_tsc_khz method x86/ldt: Fix small LDT allocation for Xen x86/vm86: Fix the misleading CONFIG_VM86 Kconfig help text x86/cpu: Print family/model/stepping in hex x86/vm86: Block non-root vm86(old) if mmap_min_addr != 0 x86/alternatives: Make optimize_nops() interrupt safe and synced x86/mm/srat: Print non-volatile flag in SRAT x86/cpufeatures: Enable cpuid for Intel SHA extensions
2015-09-17Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo MOlnar: "Mostly tooling fixes, but also two x86 PMU driver fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tests: Fix software clock events test setting maps perf tests: Fix task exit test setting maps perf evlist: Fix create_syswide_maps() not propagating maps perf evlist: Fix add() not propagating maps perf evlist: Factor out a function to propagate maps for a single evsel perf evlist: Make create_maps() use set_maps() perf evlist: Make set_maps() more resilient perf evsel: Add own_cpus member perf evlist: Fix missing thread_map__put in propagate_maps() perf evlist: Fix splice_list_tail() not setting evlist perf evlist: Add has_user_cpus member perf evlist: Remove redundant validation from propagate_maps() perf evlist: Simplify set_maps() logic perf evlist: Simplify propagate_maps() logic perf top: Fix segfault pressing -> with no hist entries perf header: Fixup reading of HEADER_NRCPUS feature perf/x86/intel: Fix constraint access perf/x86/intel/bts: Set event->hw.itrace_started in pmu::start to match the new logic perf tools: Fix use of wrong event when processing exit events perf tools: Fix parse_events_add_pmu caller
2015-09-17tools build: Add test for presence of __get_cpuid() gcc builtinArnaldo Carvalho de Melo
The auxtrace code needed by Intel PT uses the __get_cpuid() gcc builtin, that is not present in old systems, breaking the build. Add a test to check for that builtin and disable AUXTRACE in those systems. [acme@rhel5 linux]$ make NO_LIBPERL=1 -C tools/perf O=/tmp/build/perf install-bin make: Entering directory `/home/acme/git/linux/tools/perf' BUILD: Doing 'make -j2' parallel build Auto-detecting system features: <SNIP> ... lzma: [ on ] ... get_cpuid: [ OFF ] <SNIP> config/Makefile:630: Your gcc lacks the __get_cpuid() builtin, disables support for auxtrace/Intel PT, please install a newer gcc MKDIR /tmp/build/perf/util/ <SNIP> This fixes the build on old systems such as RHEL/CentOS 5.11. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: "Naveen N. Rao" <naveen.n.rao@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Stephane Eranian <eranian@google.com> Cc: Victor Kamensky <victor.kamensky@linaro.org> Cc: Vinson Lee <vlee@twopensource.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-d4puslul0jltoodzpx9r4sje@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-17tools build: Add test for presence of numa_num_possible_cpus() in libnumaArnaldo Carvalho de Melo
The existing numa test checks only if numa.h and numa_available() are present, but that can be satisfied with an old libnuma that is not enough for the 'perf bench numa' entry, so add a test to check for that: [acme@rhel5 linux]$ make NO_AUXTRACE=1 NO_LIBPERL=1 -C tools/perf O=/tmp/build/perf install-bin make: Entering directory `/home/acme/git/linux/tools/perf' BUILD: Doing 'make -j2' parallel build Auto-detecting system features: ... libelf: [ on ] ... libnuma: [ on ] ... numa_num_possible_cpus: [ OFF ] ... libperl: [ on ] <SNIP> config/Makefile:577: Old numa library found, disables 'perf bench numa mem' benchmark, please install numactl-devel/libnuma-devel/libnuma-dev >= 2.0.8 INSTALL binaries <SNIP> This fixes the build on old systems such as RHEL/CentOS 5.11. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: "Naveen N. Rao" <naveen.n.rao@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Stephane Eranian <eranian@google.com> Cc: Victor Kamensky <victor.kamensky@linaro.org> Cc: Vinson Lee <vlee@twopensource.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-zqriqkezppi2de2iyjin1tnc@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-17Revert "perf symbols: Fix mismatched declarations for elf_getphdrnum"Arnaldo Carvalho de Melo
This reverts commit f785f2357673d520a0b7b468973cdd197f336494. We have a test to check if elf_getphdrnum() is present, so, if it fails, we'll get: [acme@rhel5 linux]$ cat /tmp/build/perf/feature/test-libelf-getphdrnum.make.output cc1: warnings being treated as errors test-libelf-getphdrnum.c: In function ‘main’: test-libelf-getphdrnum.c:7: warning: implicit declaration of function ‘elf_getphdrnum’ [acme@rhel5 linux]$ And this block will not be compiled: #ifndef HAVE_ELF_GETPHDRNUM_SUPPORT static int elf_getphdrnum(Elf *elf, size_t *dst) ... #endif So, if elf_getphdrnum() is being defined somewhere, there is a problem with the test that is not detecting that function, go fix it. Reported-by: Vinson Lee <vlee@twopensource.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: "Naveen N. Rao" <naveen.n.rao@linux.vnet.ibm.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Stephane Eranian <eranian@google.com> Cc: Victor Kamensky <victor.kamensky@linaro.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-qn459fal6acvcvm50i8zxx9k@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-17s390: wire up userfaultfd system callHeiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2015-09-16perf stat: Fix per-pkg event reporting bugStephane Eranian
Per-pkg events need to be captured once per processor socket. The code in check_per_pkg() ensures only one value per processor package is used. However there is a problem with this function in case the first CPU of the package does not measure anything for the per-pkg event, but other CPUs do. Consider the following: $ create cgroup FOO; echo $$ >FOO/tasks; taskset -c 1 noploop & $ perf stat -a -I 1000 -e intel_cqm/llc_occupancy/ -G FOO sleep 100 1.00000 <not counted> Bytes intel_cqm/llc_occupancy/ FOO The reason for this is that CPU0 in the cgroup has nothing running on it. Yet check_per_plg() will mark socket0 as processed and no other event value will be considered for the socket. This patch fixes the problem by having check_per_pkg() only consider events which actually ran. Signed-off-by: Stephane Eranian <eranian@google.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Kan Liang <kan.liang@intel.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1441286620-10117-1-git-send-email-eranian@google.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-16tools/virtio: propagate V=X to kernel buildMichael S. Tsirkin
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2015-09-15perf tests: Fix software clock events test setting mapsAdrian Hunter
The test titled "Test software clock events have valid period values" was setting cpu/thread maps directly. Make it use the proper function perf_evlist__set_maps() especially now that it also propagates the maps. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-15-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf tests: Fix task exit test setting mapsAdrian Hunter
The test titled "Test number of exit event of a simple workload" was setting cpu/thread maps directly. Make it use the proper function perf_evlist__set_maps() especially now that it also propagates the maps. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-14-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf evlist: Fix create_syswide_maps() not propagating mapsAdrian Hunter
Fix it by making it call perf_evlist__set_maps() instead of setting the maps itself. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-13-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf evlist: Fix add() not propagating mapsAdrian Hunter
If evsels are added after maps are created, then they won't have any maps propagated to them. Fix that. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-12-git-send-email-adrian.hunter@intel.com [ Moved the moving of propagate_maps() to the patch before, so that this one does _just_ the one lile fix calling in add()] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf evlist: Factor out a function to propagate maps for a single evselAdrian Hunter
Subsequent fixes will need a function that just propagates maps for a single evsel so factor it out. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-11-git-send-email-adrian.hunter@intel.com [ Moved them to before perf_evlist__add() to avoid having to move it in the next patch ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf evlist: Make create_maps() use set_maps()Adrian Hunter
Since there is a function to set maps, perf_evlist__create_maps() should use it. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-10-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf evlist: Make set_maps() more resilientAdrian Hunter
Make perf_evlist__set_maps() more resilient by allowing for the possibility that one or another of the maps isn't being changed and therefore should not be "put". Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-9-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf evsel: Add own_cpus memberAdrian Hunter
perf_evlist__propagate_maps() cannot easily tell if an evsel has its own cpu map. To make that simpler, keep a copy of the PMU cpu map and adjust the propagation logic accordingly. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-8-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf evlist: Fix missing thread_map__put in propagate_maps()Adrian Hunter
perf_evlist__propagate_maps() incorrectly assumes evsel->threads is NULL before reassigning it, but it won't be NULL when perf_evlist__set_maps() is used to set different (or NULL) maps. Thus thread_map__put must be used, which works even if evsel->threads is NULL. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-7-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf evlist: Fix splice_list_tail() not setting evlistAdrian Hunter
Commit d49e46950772 ("perf evsel: Add a backpointer to the evlist a evsel is in") updated perf_evlist__add() but not perf_evlist__splice_list_tail(). This illustrates that it is better if perf_evlist__splice_list_tail() calls perf_evlist__add() instead of duplicating the logic, so do that. This will also simplify a subsequent fix for propagating maps. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-6-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf evlist: Add has_user_cpus memberAdrian Hunter
Subsequent patches will need to call perf_evlist__propagate_maps without reference to a "target". Add evlist->has_user_cpus to record whether the user has specified which cpus to target (and therefore whether that list of cpus should override the default settings for a selected event i.e. the cpu maps should be propagated) Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-5-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf evlist: Remove redundant validation from propagate_maps()Adrian Hunter
The validation checks that the values that were just assigned, got assigned i.e. the error can't ever happen. Subsequent patches will call this code in places where errors are not being returned. Changing those code paths to return this non-existent error is counter-productive, so just remove it. That in turn results in perf_evlist__set_maps not needing to return an error, but callers aren't checking it either, so remove that too. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-4-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-15perf evlist: Simplify set_maps() logicAdrian Hunter
Don't need to check for NULL when "putting" evlist->maps and evlist->threads because the "put" functions already do that. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Link: http://lkml.kernel.org/r/1441699142-18905-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
