path: root/tools
2010-04-01perf probe: Fix probe_point buffer overrunMasami Hiramatsu
commit 594087a04eea544356f9c52e83c1a9bc380ce80f upstream. Fix probe_point array-size overrun problem. In some cases (e.g. inline function), one user-specified probe-point can be translated to many probe address, and it overruns pre-defined array-size. This also removes redundant MAX_PROBES macro definition. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20100312232217.2017.45017.stgit@localhost6.localdomain6> [ Note that only root can create new probes. Eventually we should remove the MAX_PROBES limit, but that is a larger patch not eligible to perf/urgent treatment. ] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01perf: Make the install relative to DESTDIR if specifiedJohn Kacur
commit 7ae5f21361fea11f58c398701da635f778635d13 upstream. Without this change, the install path is relative to prefix/DESTDIR where prefix is automatically set to $HOME. This can produce unexpected results. For example: make -C tools/perf DESTDIR=/home/jkacur/tmp install-man creates the directory: /home/jkacur/home/jkacur/tmp/share/... instead of the expected: /home/jkacur/tmp/share/... Signed-off-by: John Kacur <jkacur@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Kyle McMartin <kyle@redhat.com> LKML-Reference: <1268312220-12880-1-git-send-email-jkacur@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-04-01perf annotate: Defer allocating sym_priv->hist arrayArnaldo Carvalho de Melo
commit 628ada0cb03666dd463f7c25947eaccdf440c309 upstream Because symbol->end is not fixed up at symbol_filter time, only after all symbols for a DSO are loaded, and that, for asm symbols, may be bogus, causing segfaults when hits happen in these symbols. Backported-from: 628ada0 Reported-by: David Miller <davem@davemloft.net> Reported-by: Anton Blanchard <anton@samba.org> Acked-by: David Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20100225155740.GB8553@ghostprotocols.net> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-15perf symbols: Check the right return variableZhang, Yanmin
commit 37fe5fcb7a5b5235c8b71bf5469ce4c7246e3fab upstream. In function dso__split_kallsyms(), curr_map saves the return value of map__new2. So check it instead of var map after the call returns. Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1267066851.1726.9.camel@localhost> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-22perf probe: Init struct probe_point and set counter correctlyMasami Hiramatsu
Clear struct probe_point before using it in show_perf_probe_events(), and set pp->found counter correctly in synthesize_perf_probe_point(). Without this initialization, clear_probe_point() will free random addresses. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20100218181652.26547.57790.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-14perf top: Fix help text alignmentKirill Smelkov
Print this: Mapped keys: [d] display refresh delay. (2) [e] display entries (lines). (46) [f] profile display filter (count). (5) [F] annotate display filter (percent). (5%) [s] annotate symbol. (NULL) [S] stop annotation. [K] hide kernel_symbols symbols. (no) [U] hide user symbols. (no) [z] toggle sample zeroing. (0) [qQ] quit. instead of: Mapped keys: [d] display refresh delay. (2) [e] display entries (lines). (46) [f] profile display filter (count). (5) [F] annotate display filter (percent). (5%) [s] annotate symbol. (NULL) [S] stop annotation. [K] hide kernel_symbols symbols. (no) [U] hide user symbols. (no) [z] toggle sample zeroing. (0) [qQ] quit. Signed-off-by: Kirill Smelkov <kirr@landau.phys.spbu.ru> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20100212162059.GA30041@landau.phys.spbu.ru> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-09perf: Fix hypervisor sample reportingAnton Blanchard
cpumode bits are defined as such: #define PERF_RECORD_MISC_KERNEL (1 << 0) #define PERF_RECORD_MISC_USER (2 << 0) #define PERF_RECORD_MISC_HYPERVISOR (3 << 0) We need to compare against the complete value of cpumode, otherwise hypervisor samples get incorrectly attributed as userspace. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: fweisbec@gmail.com LKML-Reference: <20100209034304.GA3702@kryten> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-27perf: Ignore perf.data.oldAmerigo Wang
Tell git to ignore this file. Signed-off-by: WANG Cong <amwang@redhat.com> LKML-Reference: <20100125051052.3999.28082.sendpatchset@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-27perf report: Fix segmentation fault when running with '-g none'Yong Wang
Segmentation fault occurs when running perf report with '-g none'. Reported-by: Austin Zhang <austin.zhang@intel.com> Signed-off-by: Yong Wang <yong.y.wang@intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20100122014750.GA4111@ywang-moblin2.bj.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-20perf kmem: Print usage help for unknown commandsPekka Enberg
This patch fixes "perf kmem" to print usage help instead of doing nothing. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> LKML-Reference: <1263921971-10782-1-git-send-email-penberg@cs.helsinki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-20perf kmem: Increase "Hit" column lengthPekka Enberg
It's fairly easy to overflow the "Hit" column with just few seconds of tracing so increase the column length to avoid broken formatting. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> LKML-Reference: <1263921803-10214-1-git-send-email-penberg@cs.helsinki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-17perf timechart: Use tid not pid for COMM changeArjan van de Ven
A process that changes its comm field, does this on a per kernel task struct basis. The timechart tool used, incorrectly, the pid to track this, and should have used the tid instead... Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> CC: <stable@kernel.org> LKML-Reference: <20100116125319.34ac3edd@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-13perf tools: Check if /dev/null can be used as the -o gcc argumentArnaldo Carvalho de Melo
At least on Debian PARISC64, using: acme@parisc:~/git/linux-2.6-tip$ gcc -v Using built-in specs. Target: hppa-linux-gnu Configured with: ../src/configure -v --with-pkgversion='Debian 4.3.4-6' --with-bugurl=file:///usr/share/doc/gcc-4.3/README.Bugs --enable-languages=c,c++,fortran,objc,obj-c++ --prefix=/usr --enable-shared --enable-multiarch --enable-linker-build-id --with-system-zlib --libexecdir=/usr/lib --without-included-gettext --enable-threads=posix --enable-nls --with-gxx-include-dir=/usr/include/c++/4.3 --program-suffix=-4.3 --enable-clocale=gnu --enable-libstdcxx-debug --enable-objc-gc --enable-mpfr --disable-libssp --enable-checking=release --build=hppa-linux-gnu --host=hppa-linux-gnu --target=hppa-linux-gnu Thread model: posix gcc version 4.3.4 (Debian 4.3.4-6) there are issues about using 'gcc -o /dev/null': /usr/bin/ld: final link failed: File truncated collect2: ld returned 1 exit status So we test that and use /dev/null in environments where it works, while using an .INTERMEDIATE file on those where it can't be used, so that the .perf.dev.null file can be used instead and then deleted when make exits. Researched-with: Kyle McMartin <kyle@mcmartin.ca> Researched-with: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1263293910-8484-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-13perf tools: Move QUIET_STDERR def to before first useArnaldo Carvalho de Melo
QUIET_STDERR is used when detecting if -fstack-protector-all can be used. Noticed while building the perf tools on a Debian PARISC64 machine. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1263293910-8484-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-28perf kmem: Fix statistics typoWenji Huang
Replace bytes_req with bytes_alloc. Signed-off-by: Wenji Huang <wenji.huang@oracle.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Cc: acme@redhat.com LKML-Reference: <1261389175-2227-1-git-send-email-wenji.huang@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-28perf: Rename perf_event_hw_event in design documentTim Blechmann
perf_event_hw_event has been renamed to perf_event_attr. The design document was still using the old name, though. Signed-off-by: Tim Blechmann <tim@klingt.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4B37646A.90108@klingt.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-28perf tools: Add missing header files to LIB_H Makefile variableArnaldo Carvalho de Melo
So that changes in them trigger rebuilds, like when we're doing bisects. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1261957026-15580-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-28perf record: We should fork only if a program was specified to runArnaldo Carvalho de Melo
IOW: Now 'perf record -a' works, this was a bug introduced in: 856e96608a72412d319e498a3a7c557571f811bd "perf record: Properly synchronize child creation" Also fix the -C usage, i.e. allow for profiling all the tasks in one CPU. Reported-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1261957026-15580-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-18perf diff: Fix usage array, it must end with a NULL entryArnaldo Carvalho de Melo
Fixing this: [acme@doppio linux-2.6-tip]$ perf diff --hell Error: unknown option `hell' usage: perf diff [<options>] [old_file] [new_file] Segmentation fault [acme@doppio linux-2.6-tip]$ Also go over the other such arrays to check if they all were OK, they are, but there were some minor changes to do like making one static and renaming another to match the command it refers to. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1261161358-23959-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-18perf session: Make events_stats u64 to avoid overflow on 32-bit archesArnaldo Carvalho de Melo
Pekka Enberg reported weird percentages in perf report. It turns out we are overflowing a 32-bit variables in struct events_stats on 32-bit architectures. Before: [acme@ana linux-2.6-tip]$ perf report -i pekka.perf.data 2> /dev/null | head -10 281.96% Xorg b710a561 [.] 0x000000b710a561 140.15% Xorg [kernel] [k] __initramfs_end 51.56% metacity libgobject-2.0.so.0.2000.1 [.] 0x00000000026e46 35.12% evolution libcairo.so.2.10800.6 [.] 0x000000000203bd 33.84% metacity libpthread-2.9.so [.] 0x00000000007a3d After: [acme@ana linux-2.6-tip]$ perf report -i pekka.perf.data 2> /dev/null | head -10 30.04% Xorg b710a561 [.] 0x000000b710a561 14.93% Xorg [kernel] [k] __initramfs_end 5.49% metacity libgobject-2.0.so.0.2000.1 [.] 0x00000000026e46 3.74% evolution libcairo.so.2.10800.6 [.] 0x000000000203bd 3.61% metacity libpthread-2.9.so [.] 0x00000000007a3d Reported-by: Pekka Enberg <penberg@cs.helsinki.fi> Tested-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1261148583-20395-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-17perf probe: Check new event nameMasami Hiramatsu
Check new event name is same syntax as a C symbol in perf command. In other words, checking the name is as like as other tracepoint events. This can prevent user to create an event with useless name (e.g. foo|bar, foo*bar). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091216222415.14459.71383.stgit@dhcp-100-2-132.bos.redhat.com> [ v2: minor cleanups ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-17perf probe: Check whether debugfs path is correctMasami Hiramatsu
Check whether the debugfs path is correct before executing a command, because perf-probe depends on debugfs. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091216222400.14459.48162.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-17perf probe: Fix libdwarf include path for DebianMasami Hiramatsu
Fix libdwarf include path to fit debian-like systems too. Borislav Petkov reported: > even after installing libdwarf-dev on my debian box here, > make in tools/perf/ still complains that it cannot find libdwarf: > > Makefile:491: No libdwarf.h found or old libdwarf.h found, disables dwarf > support. Please install libdwarf-dev/libdwarf-devel >= 20081231 > > The problem is that the include path on debian is not > /usr/include/libdwarf/ but simply /usr/include because the debian > package libdwarf-dev puts the headers straight into > /usr/include. This patch adds -I/usr/include/libdwarf to BASIC_CFLAGS and fix probe-finder.h to include just libdwarf.h/dwarf.h. This patch also adds a workaround for the undefined _MIPS_SZLONG bug in libdwarf.h. Reported-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Gabor Gombas <gombasg@sztaki.hu> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> LKML-Reference: <20091216221618.13816.83296.stgit@dhcp-100-2-132.bos.redhat.com> [ v2: small stylistic fixlets to probe-finder.h ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf record: Use per-task-per-cpu events for inherited eventsPeter Zijlstra
Create events with a pid and cpu contraint for inherited events so that we get a stream per cpu, instead of all cpus contending on a single stream. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: fweisbec@gmail.com Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20091216165904.987643843@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf record: Properly synchronize child creationPeter Zijlstra
Remove that ugly usleep and provide proper serialization between parent and child just like perf-stat does. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: fweisbec@gmail.com Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20091216165904.908184135@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf diff: Percent calcs should use double valuesArnaldo Carvalho de Melo
Otherwise we do integer math and the delta values round up to multiples of 1.0%. Also, calculate absolute values. Things look precise now: $ perf report -i perf.data.old --sort dso,symbol | head -13 9.02% libc-2.10.1.so [.] _IO_vfprintf_internal 4.88% find [.] 0x00000000014af0 2.91% [kernel] [k] __kmalloc 2.85% [kernel] [k] ext4_htree_store_dirent 2.50% libc-2.10.1.so [.] __GI_memmove 2.44% [kernel] [k] half_md4_transform 2.43% [kernel] [k] _spin_lock 2.33% [kernel] [k] system_call $ perf report -i perf.data --sort dso,symbol | head -13 8.55% libc-2.10.1.so [.] _IO_vfprintf_internal 3.11% [kernel] [k] __kmalloc 3.07% [kernel] [k] ext4_htree_store_dirent 2.66% find [.] 0x00000000016bcf 2.61% [kernel] [k] _atomic_dec_and_lock 2.46% [kernel] [k] half_md4_transform 2.41% libc-2.10.1.so [.] __GI_memmove 2.30% find [.] 0x00000000009219 $ perf diff | head -13 9.02% -0.47% libc-2.10.1.so [.] _IO_vfprintf_internal 2.91% +0.20% [kernel] [k] __kmalloc 2.85% +0.23% [kernel] [k] ext4_htree_store_dirent 1.99% +0.62% [kernel] [k] _atomic_dec_and_lock 2.44% +0.02% [kernel] [k] half_md4_transform 2.50% -0.09% libc-2.10.1.so [.] __GI_memmove 1.88% +0.01% [kernel] [k] __d_lookup 2.43% -0.75% [kernel] [k] _spin_lock 0.97% +0.62% [kernel] [k] path_get 1.99% -0.42% libc-2.10.1.so [.] _int_malloc $ Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260981109-2621-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf diff: Change the default sort order to "dso,symbol"Arnaldo Carvalho de Melo
This is a more intuitive / more meaningful default: $ perf diff | head -8 9.02% +1.00% libc-2.10.1.so [.] _IO_vfprintf_internal 2.91% -1.00% [kernel] [k] __kmalloc 2.85% -1.00% [kernel] [k] ext4_htree_store_dirent 1.99% -1.00% [kernel] [k] _atomic_dec_and_lock 2.44% [kernel] $ Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260979793-1981-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf diff: Use perf_session__fprintf_hists just like 'perf record'Arnaldo Carvalho de Melo
That means that almost everything you can do with 'perf report' can be done with 'perf diff', for instance: $ perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2699 samples) ] $ perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2687 samples) ] perf diff | head -8 9.02% +1.00% find libc-2.10.1.so [.] _IO_vfprintf_internal 2.91% -1.00% find [kernel] [k] __kmalloc 2.85% -1.00% find [kernel] [k] ext4_htree_store_dirent 1.99% -1.00% find [kernel] [k] _atomic_dec_and_lock 2.44% find [kernel] [k] half_md4_transform $ So if you want to zoom into libc: $ perf diff --dsos libc-2.10.1.so | head -8 37.34% find [.] _IO_vfprintf_internal 10.34% find [.] __GI_memmove 8.25% +2.00% find [.] _int_malloc 5.07% -1.00% find [.] __GI_mempcpy 7.62% +2.00% find [.] _int_free $ And if there were multiple commands using libc, it is also possible to aggregate them all by using --sort symbol: $ perf diff --dsos libc-2.10.1.so --sort symbol | head -8 37.34% [.] _IO_vfprintf_internal 10.34% [.] __GI_memmove 8.25% +2.00% [.] _int_malloc 5.07% -1.00% [.] __GI_mempcpy 7.62% +2.00% [.] _int_free $ The displacement column now is off by default, to use it: perf diff -m --dsos libc-2.10.1.so --sort symbol | head -8 37.34% [.] _IO_vfprintf_internal 10.34% [.] __GI_memmove 8.25% +2.00% [.] _int_malloc 5.07% -1.00% +2 [.] __GI_mempcpy 7.62% +2.00% -1 [.] _int_free $ Using -t/--field-separator can be used for scripting: $ perf diff -t, -m --dsos libc-2.10.1.so --sort symbol | head -8 37.34, , ,[.] _IO_vfprintf_internal 10.34, , ,[.] __GI_memmove 8.25,+2.00%, ,[.] _int_malloc 5.07,-1.00%, +2,[.] __GI_mempcpy 7.62,+2.00%, -1,[.] _int_free 6.99,+1.00%, -1,[.] _IO_new_file_xsputn 1.89,-2.00%, +4,[.] __readdir64 $ Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260978567-550-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf report: Fix cut'n'paste error recently introducedArnaldo Carvalho de Melo
Introduced in: d599db3fc5dd4f1e8432fdbc6d899584b25f4dff "perf report: Generalize perf_session__fprintf_hists()" Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260973631-28035-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf session: Move perf report specific hits out of perf_session__fprintf_histsArnaldo Carvalho de Melo
Those don't make sense for tools such as 'perf diff'. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260973631-28035-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf tools: Move hist entries printing routines from perf reportArnaldo Carvalho de Melo
Will be used in other tools such as 'perf diff'. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260973631-28035-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf report: Generalize perf_session__fprintf_hists()Arnaldo Carvalho de Melo
Pull it out of builtin-report - further changes will be made and it will then be reusable in 'perf diff' as well. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260914682-29652-4-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf symbols: Move symbol filtering to event__preprocess_sample()Arnaldo Carvalho de Melo
So that --dsos, --comm, --symbols can bem used in more tools, like in perf diff: $ perf record -f find / > /dev/null $ perf record -f find / > /dev/null $ perf diff --dsos /lib64/libc-2.10.1.so | head -5 1 +22392124 /lib64/libc-2.10.1.so _IO_vfprintf_internal 2 +6410655 /lib64/libc-2.10.1.so __GI_memmove 3 +1 +9192692 /lib64/libc-2.10.1.so _int_malloc 4 -1 -15158605 /lib64/libc-2.10.1.so _int_free 5 +45669 /lib64/libc-2.10.1.so _IO_new_file_xsputn $ Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260914682-29652-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf symbols: Adopt the strlists for dso, commArnaldo Carvalho de Melo
Will be used in perf diff too. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260914682-29652-2-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf symbols: Make symbol_conf globalArnaldo Carvalho de Melo
This simplifies a lot of functions, less stuff to be done by tool writers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260914682-29652-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Fix to show which probe point is not foundMasami Hiramatsu
Fix perf probe to show which probe point is not found. With out this patch, it shows just "No probe point found." This doesn't help users if they specify several probes. e.g. # perf probe -f --add schedule --add test Fatal: No probe point found. This patch makes error message more helpful as below. # perf probe --add schedule --add test Fatal: Probe point 'test' not found. - probe not added. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153247.17436.49068.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Check symbols in symtab/kallsymsMasami Hiramatsu
Check symbols in symtab/kallsyms when no debuginfo is available. e.g. # perf probe test Fatal: Kernel symbol 'test' not found - probe not added. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153239.17436.55034.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Check build-id of vmlinuxMasami Hiramatsu
Check build-id of vmlinux by using functions in symbol.c. This also exposes map__load() for getting vmlinux path, and removes vmlinux path list in builtin-probe.c, because symbol.c already has that. Checking build-id prevents users to open old or different debuginfo from current running kernel. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153232.17436.45539.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Reject second attempt of adding same-name eventMasami Hiramatsu
Reject second attempt of adding same-name event. This patch also provides --force option which allows user to add additional probe events on the same-name event. e.g. (the first attempt : success) ./perf probe schedule Added new event: probe:schedule (on schedule+0) (the second attempt : failure) ./perf probe schedule:11 Error: event "schedule" already exists. (Use -f to force duplicates.) Fatal: Can't add new event. (the second attempt with -f : successfully added) ./perf probe -f schedule:11 Added new event: probe:schedule_1 (on schedule+45) Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153225.17436.15166.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Support event name for --add optionMasami Hiramatsu
Support event name syntax for --add option. This allows users to specify event name for each new event. The --add syntax is: perf probe --add '[EVENT=]SRC:LINE ARGS' or perf probe --add '[EVENT=]FUNC[+OFFS|%return|:RLN][@SRC] ARGS' e.g. ./perf probe --add myprobe1=schedule Note: currently group name is not supported yet, because it can cause name-space confliction with other tracepoint/ hw-breakpoint events. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153218.17436.84675.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Add glob matching support on --delMasami Hiramatsu
Add glob-expression matching support on --del option. You can use wildcards for specifying deleting events. e.g. Clear all probe events: # perf probe --del '*' Clear probes on schedule(): # perf probe --del 'schedule*' Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153210.17436.12327.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Use strlist__for_each macros in probe-event.cMasami Hiramatsu
Use strlist__for_each macros instead of using strlist__entry() and index variable. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153203.17436.52039.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf tools: Add for_each macros for strlistMasami Hiramatsu
Add for_each iteration macros for strlist. This patch introduces strlist__for_each() and strlist__for_each_safe(), both are similar to list_for_each() and list_for_each_safe(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153156.17436.49157.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Fix --del to update current event listMasami Hiramatsu
Fix --del option to update current existing event list after perf probe deleted an event. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153149.17436.61265.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Fix --del to show info instead of warningMasami Hiramatsu
Fix --del option to show info message instead of warning if failing to find specified event. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153142.17436.7793.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Show need-dwarf message only if it is really neededMasami Hiramatsu
Show need-dwarf message only if the probe is really requires debuginfo analysis. This also use pr_debug for debugging message instead of pr_warning. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153135.17436.99052.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Check hyphen only argumentMasami Hiramatsu
Check hyphen only command argument, because perf-probe doesn't support event recording feature yet. e.g. # perf probe - Error: '-' is not supported. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153128.17436.9266.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Check the result of e_snprintf()Masami Hiramatsu
Fix show_perf_probe_event() to check the result of e_snprintf(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153121.17436.34674.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf probe: Cleanup struct session in builtin-probe.cMasami Hiramatsu
Clean up struct session in builtin-probe.c, including change need_dwarf to bool and move listing flag into struct session as list_events flag. This also changes parse_perf_probe_event() interface due to code readability. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091215153114.17436.77000.stgit@dhcp-100-2-132.bos.redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-15perf diff: Fix documentationArnaldo Carvalho de Melo
Add a newline do fix this problem: ERROR: perf-diff.txt: line 31: closing [blockdef-listing] delimiter expected Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260882082-10007-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
