path: root/tools
2015-10-22tools lib traceevent: Fix string handling in heterogeneous arch environmentsKapileshwar Singh
commit c2e4b24ff848bb180f9b9cd873a38327cd219ad2 upstream. When a trace recorded on a 32-bit device is processed with a 64-bit binary, the higher 32-bits of the address need to ignored. The lack of this results in the output of the 64-bit pointer value to the trace as the 32-bit address lookup fails in find_printk(). Before: burn-1778 [003] 548.600305: bputs: 0xc0046db2s: 2cec5c058d98c After: burn-1778 [003] 548.600305: bputs: 0xc0046db2s: RT throttling activated The problem occurs in PRINT_FIELD when the field is recognized as a pointer to a string (of the type const char *) Heterogeneous architectures cases below can arise and should be handled: * Traces recorded using 32-bit addresses processed on a 64-bit machine * Traces recorded using 64-bit addresses processed on a 32-bit machine Reported-by: Juri Lelli <juri.lelli@arm.com> Signed-off-by: Kapileshwar Singh <kapileshwar.singh@arm.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Javi Merino <javi.merino@arm.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1442928123-13824-1-git-send-email-kapileshwar.singh@arm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22tools/lguest: Fix redefinition of struct virtio_pci_cfg_capRusty Russell
commit e523caa601f4a7c2fa1ecd040db921baf7453798 upstream. Ours uses a u32 for the data, since we ensure it's always aligned and it's x86 so it doesn't matter anyway. lguest.c:128:8: error: redefinition of ‘struct virtio_pci_cfg_cap’ Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael S. Tsirkin <mst@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Fixes: 3121bb023e2db ("virtio: define virtio_pci_cfg_cap in header.") Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf probe: Use existing routine to look for a kernel module by dso->short_nameArnaldo Carvalho de Melo
commit 266fa2b22294909ddf6e7d2f8acfe07adf9fd978 upstream. We have map_groups__find_by_name() to look at the list of modules that are in place for a given machine, so use it instead of traversing the machine dso list, which also includes DSOs for userspace. When merging the user and kernel DSO lists a bug was introduced where 'perf probe' stopped being able to add probes to modules using its short name: # perf probe -m usbnet --add usbnet_start_xmit usbnet_start_xmit is out of .text, skip it. Error: Failed to add events. # With this fix it works again: # perf probe -m usbnet --add usbnet_start_xmit Added new event: probe:usbnet_start_xmit (on usbnet_start_xmit in usbnet) You can now use it in all perf tools, such as: perf record -e probe:usbnet_start_xmit -aR sleep 1 # Reported-by: Wang Nan <wangnan0@huawei.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Fixes: 3d39ac538629 ("perf machine: No need to have two DSOs lists") Link: http://lkml.kernel.org/r/20150924015008.GE1897@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf header: Fixup reading of HEADER_NRCPUS featureArnaldo Carvalho de Melo
commit caa470475d9b59eeff093ae650800d34612c4379 upstream. The original patch introducing this header wrote the number of CPUs available and online in one order and then swapped those values when reading, fix it. Before: # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 4 # echo 0 > /sys/devices/system/cpu/cpu2/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 3 # echo 0 > /sys/devices/system/cpu/cpu1/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 2 After the fix, bringing back the CPUs online: # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 2 # nrcpus avail : 4 # echo 1 > /sys/devices/system/cpu/cpu2/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 3 # nrcpus avail : 4 # echo 1 > /sys/devices/system/cpu/cpu1/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 4 Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Cc: Stephane Eranian <eranian@google.com> Cc: Wang Nan <wangnan0@huawei.com> Fixes: fbe96f29ce4b ("perf tools: Make perf.data more self-descriptive (v8)") Link: http://lkml.kernel.org/r/20150911153323.GP23511@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf tools: Fix parse_events_add_pmu callerJiri Olsa
commit 5ad4da4302712fba10624d28cb6c269fee592b69 upstream. Following commit changed parse_events_add_pmu interface: 36adec85a86f perf tools: Change parse_events_add_pmu interface but forgot to change one caller. Because of lessen compilation rules for the bison parser, the compiler did not warn on that. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Raphael Beamonte <raphael.beamonte@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Matt Fleming <matt@codeblueprint.co.uk> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Fixes: 36adec85a86f ("perf tools: Change parse_events_add_pmu interface") Link: http://lkml.kernel.org/r/1441180605-24737-2-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf tools: Add empty Build files for architectures lacking themBen Hutchings
commit 93df8a1ed6231727c5db94a80b1a6bd5ee67cec3 upstream. perf currently fails to build on MIPS as there is no tools/perf/arch/mips/Build file. Adding an empty file fixes this as there are no MIPS-specific sources to build. It looks like the same is needed for Alpha and PA-RISC, though I haven't been able to test those. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Fixes: 5e8c0fb6a957 ("perf build: Add arch x86 objects building") Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1438704627.7315.2.camel@decadent.org.uk Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf tools: Add missing forward declaration of struct map to probe-event.hWang Nan
commit 5a023b57a8e96327925a39312bccc443a7c540b6 upstream. Commit 7b6ff0bdbf4f7f429c2116cca92a6d171217449e ("perf probe ppc64le: Fixup function entry if using kallsyms lookup") adds 'struct map' into probe-event.h but not forward declares it. This patch fixes it. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Daniel Borkmann <daniel@iogearbox.net> Cc: David Ahern <dsahern@gmail.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kaixu Xia <xiakaixu@huawei.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Fixes: 7b6ff0bdbf4f ("perf probe ppc64le: Fixup function entry if using kallsyms lookup") Link: http://lkml.kernel.org/n/1436445342-1402-30-git-send-email-wangnan0@huawei.com [ No need to include map.h, just forward declare 'struct map' ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf stat: Get correct cpu id for print_aggrKan Liang
commit 601083cffb7cabdcc55b8195d732f0f7028570fa upstream. print_aggr() fails to print per-core/per-socket statistics after commit 582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events") if events have differnt cpus. Because in print_aggr(), aggr_get_id needs index (not cpu id) to find core/pkg id. Also, evsel cpu maps should be used to get aggregated id. Here is an example: Counting events cycles,uncore_imc_0/cas_count_read/. (Uncore event has cpumask 0,18) $ perf stat -e cycles,uncore_imc_0/cas_count_read/ -C0,18 --per-core sleep 2 Without this patch, it failes to get CPU 18 result. Performance counter stats for 'CPU(s) 0,18': S0-C0 1 7526851 cycles S0-C0 1 1.05 MiB uncore_imc_0/cas_count_read/ S1-C0 0 <not counted> cycles S1-C0 0 <not counted> MiB uncore_imc_0/cas_count_read/ With this patch, it can get both CPU0 and CPU18 result. Performance counter stats for 'CPU(s) 0,18': S0-C0 1 6327768 cycles S0-C0 1 0.47 MiB uncore_imc_0/cas_count_read/ S1-C0 1 330228 cycles S1-C0 1 0.29 MiB uncore_imc_0/cas_count_read/ Signed-off-by: Kan Liang <kan.liang@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Stephane Eranian <eranian@google.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Fixes: 582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events") Link: http://lkml.kernel.org/r/1435820925-51091-1-git-send-email-kan.liang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf hists: Update the column width for the "srcline" sort keyArnaldo Carvalho de Melo
commit e8e6d37e73e6b950c891c780745460b87f4755b6 upstream. When we introduce a new sort key, we need to update the hists__calc_col_len() function accordingly, otherwise the width will be limited to strlen(header). We can't update it when obtaining a line value for a column (for instance, in sort__srcline_cmp()), because we reset it all when doing a resort (see hists__output_recalc_col_len()), so we need to, from what is in the hist_entry fields, set each of the column widths. Cc: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Jiri Olsa <jolsa@kernel.org> Fixes: 409a8be61560 ("perf tools: Add sort by src line/number") Link: http://lkml.kernel.org/n/tip-jgbe0yx8v1gs89cslr93pvz2@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf tools: Fix copying of /proc/kcoreAdrian Hunter
commit b5cabbcbd157a4bf5a92dfc85134999a3b55342d upstream. A copy of /proc/kcore containing the kernel text can be made to the buildid cache. e.g. perf buildid-cache -v -k /proc/kcore To workaround objdump limitations, a copy is also made when annotating against /proc/kcore. The copying process stops working from libelf about v1.62 onwards (the problem was found with v1.63). The cause is that a call to gelf_getphdr() in kcore__add_phdr() fails because additional validation has been added to gelf_getphdr(). The use of gelf_getphdr() is a misguided attempt to get default initialization of the Gelf_Phdr structure. That should not be necessary because every member of the Gelf_Phdr structure is subsequently assigned. So just remove the call to gelf_getphdr(). Similarly, a call to gelf_getehdr() in gelf_kcore__init() can be removed also. Committer notes: Note to stable@kernel.org, from Adrian in the cover letter for this patchkit: The "Fix copying of /proc/kcore" problem goes back to v3.13 if you think it is important enough for stable. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1443089122-19082-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-20Merge tag 'perf-urgent-for-mingo' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull perf/urgent fixes from Arnaldo Carvalho de Melo: - Fix buildid processing done at the end of a 'perf record' session, a problem that happened in workloads involving lots of small short-lived processes. That code was not asking the perf_session layer to order the events. Make the code more robust to handle some of the problems with such out-of-order events and fix 'perf record' to ask for ordered events on systems where we have perf_event_attr.sample_id_all. (Adrian Hunter) - Show backtrace when handling a SIGSEGV in 'perf top --stdio' (Arnaldo Carvalho de Melo) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-08-19perf top: Show backtrace when handling a SIGSEGV on --stdio modeArnaldo Carvalho de Melo
It was just freezing instead of informing about the SEGV, fix it and also print a backtrace, just like in the TUI mode and in 'perf trace'. Tested by provoking a NULL deref when pressing 'z': 0.31% libc-2.20.so [.] malloc_consolidate 0.31% ld-2.20.so [.] _dl_relocate_object 0.28% cc1 [.] ht_lookup 0.28% cc1 [.] ira_init_register_move_cost perf: Segmentation fault Obtained 7 stack frames. perf(dump_stack+0x32) [0x4d69f2] perf(sighandler_dump_stack+0x29) [0x4d6a89] /lib64/libc.so.6(+0x34960) [0x7f5064333960] perf() [0x438790] /lib64/libpthread.so.0(+0x752a) [0x7f50663dd52a] /lib64/libc.so.6(clone+0x6d) [0x7f50643ff22d] # Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-pewrpzqd29rgmhu2wkk7fhww@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-19perf tools: Fix buildid processingAdrian Hunter
After recording, 'perf record' post-processes the data to determine which buildids are needed. That processing must process the data in time order, if possible, because otherwise dependent events, like forks and mmaps, will not make sense. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1439994561-27436-4-git-send-email-adrian.hunter@intel.com [ Moved the sample_id_add to after trying to open the events, use pr_warning ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-19perf tools: Make fork event processing more resilientAdrian Hunter
When processing a fork event, the tools lookup the parent thread by its tid. In a couple of cases, it is possible for that thread to have the wrong pid. That can happen if the data is being processed out of order, or if the (fork) event that would have removed the erroneous thread was lost. Assume the latter case, print a dump message, remove the erroneous thread, create a new one with the correct pid, and keep going. Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1439994561-27436-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-19perf tools: Avoid deadlock when map_groups are brokenAdrian Hunter
Attempting to clone map groups onto themselves will deadlock. It only happens because of other bugs, but the code should protect itself anyway. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Jiri Olsa <jolsa@kernel.org> Link: http://lkml.kernel.org/r/1439994561-27436-2-git-send-email-adrian.hunter@intel.com [ Use pr_debug() instead of dump_fprintf() ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-08-14Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Misc fixes: PMU driver corner cases, tooling fixes, and an 'AUX' (Intel PT) race related core fix" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/intel/cqm: Do not access cpu_data() from CPU_UP_PREPARE handler perf/x86/intel: Fix memory leak on hot-plug allocation fail perf: Fix PERF_EVENT_IOC_PERIOD migration race perf: Fix double-free of the AUX buffer perf: Fix fasync handling on inherited events perf tools: Fix test build error when bindir contains double slash perf stat: Fix transaction lenght metrics perf: Fix running time accounting
2015-07-28Merge tag 'linux-kselftest-4.2-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest fix from Shuah Khan. * tag 'linux-kselftest-4.2-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: selftests/futex: Fix futex_cmp_requeue_pi() error handling
2015-07-28perf tools: Fix test build error when bindir contains double slashPawel Moll
When building with a prefix ending with a slash, for example: $ make prefix=/usr/local/ one of the perf tests fail to compile due to BUILD_STR macro mishandling bindir_SQ string containing with two slashes: -DBINDIR="BUILD_STR(/usr/local//bin)" with the following error: CC tests/attr.o tests/attr.c: In function ‘test__attr’: tests/attr.c:168:50: error: expected ‘)’ before ‘;’ token snprintf(path_perf, PATH_MAX, "%s/perf", BINDIR); ^ tests/attr.c:176:1: error: expected ‘;’ before ‘}’ token } ^ tests/attr.c:176:1: error: control reaches end of non-void function [-Werror=return-type] } ^ cc1: all warnings being treated as errors This patch works around the problem by "cleaning" the bindir string using make's abspath function. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1438092613-21014-1-git-send-email-pawel.moll@arm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-28perf stat: Fix transaction lenght metricsAndi Kleen
The transaction length metrics in perf stat -T broke recently. It would not match the metric correctly and always print K/sec. This was caused by a incorrect update of the cycles_in_tx statistics. Update the correct variable. Also the check for zero division was reversed, which resulted in K/sec being printed for no transactions. Fix this also up. Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Link: http://lkml.kernel.org/r/1438039491-22091-1-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-20selftests/futex: Fix futex_cmp_requeue_pi() error handlingDarren Hart
An earlier (pre-kernel-integration) refactoring of this code mistakenly replaced the error condition, <, with a >. Use < to detect an error as opposed to a successful requeue or signal race. Reported-by: David Binderman <dcb314@hotmail.com> Cc: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2015-07-18Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Mostly tooling fixes, plus a static key fix fixing /sys/devices/cpu/rdpmc" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Really allow to specify custom CC, AR or LD perf auxtrace: Fix misplaced check for HAVE_SYNC_COMPARE_AND_SWAP_SUPPORT perf hists browser: Take the --comm, --dsos, etc filters into account perf symbols: Store if there is a filter in place x86, perf: Fix static_key bug in load_mm_cr4() tools: Copy lib/hweight.c from the kernel sources perf tools: Fix the detached tarball wrt rbtree copy perf thread_map: Fix the sizeof() calculation for map entries tools lib: Improve clean target perf stat: Fix shadow declaration of close perf tools: Fix lockup using 32-bit compat vdso
2015-07-15perf tools: Really allow to specify custom CC, AR or LDAlexey Brodkin
Commit 5ef7bbb09f7b ("perf tools: Allow to specify custom linker command") was meant to enable usage non $(CROSS_COMPILE)ld linker during perf building. But implementation didn't take into account the fact that LD is a pre-defined variable in GNU Make. I.e. it is always defined. Which means there's no point to check "LD ?= ..." because it will never succeed. And so LD will be either that explicitly passed to make like this: ------->8------- make LD=path_to_my_ld ... ------->8------- or default value, which is host's "ld". Latter leads to failure of cross-linkage because instead of cross linker "$(CROSS_COMPILE)ld" host's "ld" is used. Fortunately there's a way to do correct substitution of $(CROSS_COMPILE)ld with user defined LD on command-line. As a reference was used implementation in "tools/lib/traceevent/Makefile". Build tested for x86_64 and ARC. Thanks Jiri for this hint. Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Fixes: 5ef7bbb09f7b ("perf tools: Allow to specify custom linker command") Cc: Aaro Koskinen <aaro.koskinen@nokia.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: linux-arch@vger.kernel.org Link: http://lkml.kernel.org/r/1436864720-26316-1-git-send-email-abrodkin@synopsys.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-15perf auxtrace: Fix misplaced check for HAVE_SYNC_COMPARE_AND_SWAP_SUPPORTAdrian Hunter
Move the checking for HAVE_SYNC_COMPARE_AND_SWAP_SUPPORT for AUX area mmaps until after checking if such mmaps are used anyway. Reported-by: Alexey Brodkin <Alexey.Brodkin@synopsys.com> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Alexey Brodkin <Alexey.Brodkin@synopsys.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Vineet Gupta <Vineet.Gupta1@synopsys.com> Cc: linux-arch@vger.kernel.org Link: http://lkml.kernel.org/r/55A5023C.7020907@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-13perf hists browser: Take the --comm, --dsos, etc filters into accountArnaldo Carvalho de Melo
At some point: commit 2c86c7ca7606 Author: Namhyung Kim <namhyung@kernel.org> Date: Mon Mar 17 18:18:54 2014 -0300 perf report: Merge al->filtered with hist_entry->filtered We stopped dropping samples for things filtered via the --comms, --dsos, --symbols, etc, i.e. things marked as filtered in the symbol resolution routines (thread__find_addr_map(), perf_event__preprocess_sample(), etc). But then, in: commit 268397cb2a47 Author: Namhyung Kim <namhyung@kernel.org> Date: Tue Apr 22 14:49:31 2014 +0900 perf top/tui: Update nr_entries properly after a filter is applied We don't take into account entries that were filtered in perf_event__preprocess_sample() and friends, which leads to inconsistency in the browser seek routines, that expects the number of hist_entry->filtered entries to match what it thinks is the number of unfiltered, browsable entries. So, for instance, when we do: perf top --symbols ___non_existent_symbol___ the hist_browser__nr_entries() routine thinks there are no filters in place, uses the hists->nr_entries but all entries are filtered, leading to a segfault. Tested with: perf top --symbols malloc,free --percentage=relative Freezing, by pressing 'f', at any time and doing the math on the percentages ends up with 100%, ditto for: perf top --dsos libpthread-2.20.so,libxul.so --percentage=relative Both were segfaulting, all fixed now. More work needed to do away with checking if filters are in place, we should just use the nr_non_filtered_samples counter, no need to conditionally use it or hists.nr_filter, as what the browser does is just show unfiltered stuff. An audit of how it is being accounted is needed, this is the minimal fix. Reported-by: Michael Petlan <mpetlan@redhat.com> Fixes: 268397cb2a47 ("perf top/tui: Update nr_entries properly after a filter is applied") Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-6w01d5q97qk0d64kuojme5in@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-13perf symbols: Store if there is a filter in placeArnaldo Carvalho de Melo
When setting yup the symbols library we setup several filter lists, for dsos, comms, symbols, etc, and there is code that, if there are filters, do certain operations, like recalculate the number of non filtered histogram entries in the top/report TUI. But they were considering just the "Zoom" filters, when they need to take into account as well the above mentioned filters (perf top --comms, --dsos, etc). So store in symbol_conf.has_filter true if any of those filters is in place. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-f5edfmhq69vfvs1kmikq1wep@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-11Merge branch 'libnvdimm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm Pull libnvdimm fixes from Dan Williams: "1) Fixes for a handful of smatch reports (Thanks Dan C.!) and minor bug fixes (patches 1-6) 2) Correctness fixes to the BLK-mode nvdimm driver (patches 7-10). Granted these are slightly large for a -rc update. They have been out for review in one form or another since the end of May and were deferred from the merge window while we settled on the "PMEM API" for the PMEM-mode nvdimm driver (ie memremap_pmem, memcpy_to_pmem, and wmb_pmem). Now that those apis are merged we implement them in the BLK driver to guarantee that mmio aperture moves stay ordered with respect to incoming read/write requests, and that writes are flushed through those mmio-windows and platform-buffers to be persistent on media. These pass the sub-system unit tests with the updates to tools/testing/nvdimm, and have received a successful build-report from the kbuild robot (468 configs). With acks from Rafael for the touches to drivers/acpi/" * 'libnvdimm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/nvdimm: nfit: add support for NVDIMM "latch" flag nfit: update block I/O path to use PMEM API tools/testing/nvdimm: add mock acpi_nfit_flush_address entries to nfit_test tools/testing/nvdimm: fix return code for unimplemented commands tools/testing/nvdimm: mock ioremap_wt pmem: add maintainer for include/linux/pmem.h nfit: fix smatch "use after null check" report nvdimm: Fix return value of nvdimm_bus_init() if class_create() fails libnvdimm: smatch cleanups in __nd_ioctl sparse: fix misplaced __pmem definition
2015-07-10tools/testing/nvdimm: add mock acpi_nfit_flush_address entries to nfit_testDan Williams
In preparation for fixing the BLK path to properly use "directed pcommit" enable the unit test infrastructure to emit mock "flush" tables. Writes to these flush addresses trigger a memory controller to flush its internal buffers to persistent media, similar to the x86 "pcommit" instruction. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-07-10tools/testing/nvdimm: fix return code for unimplemented commandsDan Williams
The implementation for the new "DIMM Flags" DSM relies on the -ENOTTY return code to indicate that the flags are unimplimented and to fall back to a safe default. As is the -ENXIO error code erroneoously indicates to fail enabling a BLK region. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-07-10tools/testing/nvdimm: mock ioremap_wtDan Williams
In the 4.2-rc1 merge the default_memremap_pmem() implementation switched from ioremap_nocache() to ioremap_wt(). Add it to the list of mocked routines to restore the ability to run the unit tests. Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-07-09tools: Copy lib/hweight.c from the kernel sourcesArnaldo Carvalho de Melo
Instead of accessing it directly, as it uses EXPORT_SYMBOL, that has no meaning in tools/perf and because we removed the stubs for it, i.e. we removed the tools/include/linux/export.h file. This fixes the build for the detached tarball sources cases and removes one more source of entanglement with the kernel sources. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-oyqx541o7apa2cskjhcxi6nx@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-09perf tools: Fix the detached tarball wrt rbtree copyArnaldo Carvalho de Melo
The python binding build process was still looking at the kernel rbtree.c file, so, when doing a in-tree build it would work, but when creating a tarball using tools/perf/MANIFEST as the contents list and then trying to build the resulting detached sources, it failed. Fix it by removing one level of indirection from rbtree.c in the tools/perf/util/python-ext-sources file. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-8u83c2k5guyhxdlkaaqis8k4@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-09perf thread_map: Fix the sizeof() calculation for map entriesArnaldo Carvalho de Melo
When we started adding extra stuff per array entry, growing the size of those entries to more than sizeof(pid_t), we had to convert those sizeof operations to the more robust sizeof(map->map[0]) idiom, that is future proof, i.e. if/when we add more stuff to those entries, that expression will produce the new per-entry size. And besides that, we need to zero out those extra fields, that sometimes may not get filled, like when we couldn't care less about the comms, since we don't need those, but since we will try freeing it at thread_map__delete(), we better fix it. That is why a thread_map__realloc() was provided. But that method wasn't used in thread_map__new_by_uid(), fix it. Reported-by: Ingo Molnar <mingo@kernel.org> Fixes: 792402fd5c0a ("perf thrad_map: Add comm string into array") Fixes: 9d7e8c3a96e5 ("perf tools: Add thread_map__(alloc|realloc) helpers") Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-6a0swlm6m8lnu3wpjv284hkb@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-08tools lib: Improve clean targetRiku Voipio
The clean targets miss some .cmd and .d files. Signed-off-by: Riku Voipio <riku.voipio@linaro.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-kbuild@vger.kernel.org Link: http://lkml.kernel.org/r/1434631938-12681-1-git-send-email-riku.voipio@linaro.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-08perf stat: Fix shadow declaration of closeJiri Olsa
Vinson reported shadow declaration of close introduced by the following commit: 106a94a0f8c2 perf stat: Introduce read_counters function Using close_counters name instead. Reported-by: Vinson Lee <vlee@twopensource.com> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Fixes: 106a94a0f8c2 ("perf stat: Introduce read_counters function") Link: http://lkml.kernel.org/r/20150708111731.GA3512@krava.redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-07perf tools: Fix lockup using 32-bit compat vdsoAdrian Hunter
The __machine__findnew_compat() function is called only from __machine__findnew_vdso_compat() which is called only from machine__findnew_vdso() which already holds machine->dsos.lock, so remove locking from __machine__findnew_compat(). This manifests itself tracing 32-bit programs with a 64-bit perf. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1436267618-20521-1-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-06Merge branch 'perf/rbtree_copy' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent Pull rbtree build fix from Arnaldo Carvalho de Melo. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-05tools: Copy rbtree_augmented.h from the kernelArnaldo Carvalho de Melo
To complete the transitioning to not to share the same files with the kernel, also moving it from tools/perf/include/linux/ to tools/include/linux to make the whoke rbtree kit to other tools/ living codebases. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-5bxyehixafckqm6ez25alnfo@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-05tools: Move rbtree.h from tools/perf/Arnaldo Carvalho de Melo
The previous step, copying the contents minus the rcupdate.h parts, was done as a minimal fix, now do the move from tools/perf/. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-52fllxtsgmtke66pmv98mcma@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-05tools: Copy lib/rbtree.c to tools/lib/Arnaldo Carvalho de Melo
So that we can remove kernel specific stuff we've been stubbing out via a tools/include/linux/export.h that gets removed in this patch and to avoid breakages in the future like the one fixed recently where rcupdate.h started being used in rbtree.h. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-rxuzfsozpb8hv1emwpx06rm6@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-05perf tools: Copy rbtree.h from the kernelArnaldo Carvalho de Melo
We were using the include/linux/rbtree.h directly from the kernel, which broke the build as soon as it started using rcupdate.h, to avoid dragging the rcu header files into tools/, for which there is no use so far, grab a copy of rbtree.h. This is the minimal fix, later patches will copy as well lib/rbtree.c and move rbtree.h into tools/include/, etc. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-dfmuj0j63w4by7vhlh4hhn74@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-05tools: Adopt {READ,WRITE_ONCE} from the kernelArnaldo Carvalho de Melo
We need it to build rbtree.c after this cset: commit d72da4a4d973 Author: Peter Zijlstra <peterz@infradead.org> Date: Wed May 27 11:09:36 2015 +0930 rbtree: Make lockless searches non-fatal Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-qlnzhezv5ddwst0w9fydju0y@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-04Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "This tree includes an x86 PMU scheduling fix, but most changes are late breaking tooling fixes and updates: User visible fixes: - Create config.detected into OUTPUT directory, fixing parallel builds sharing the same source directory (Aaro Kiskinen) - Allow to specify custom linker command, fixing some MIPS64 builds. (Aaro Kiskinen) - Fix to show proper convergence stats in 'perf bench numa' (Srikar Dronamraju) User visible changes: - Validate syscall list passed via -e argument to 'perf trace'. (Arnaldo Carvalho de Melo) - Introduce 'perf stat --per-thread' (Jiri Olsa) - Check access permission for --kallsyms and --vmlinux (Li Zhang) - Move toggling event logic from 'perf top' and into hists browser, allowing freeze/unfreeze with event lists with more than one entry (Namhyung Kim) - Add missing newlines when dumping PERF_RECORD_FINISHED_ROUND and showing the Aggregated stats in 'perf report -D' (Adrian Hunter) Infrastructure fixes: - Add missing break for PERF_RECORD_ITRACE_START, which caused those events samples to be parsed as well as PERF_RECORD_LOST_SAMPLES. ITRACE_START only appears when Intel PT or BTS are present, so.. (Jiri Olsa) - Call the perf_session destructor when bailing out in the inject, kmem, report, kvm and mem tools (Taeung Song) Infrastructure changes: - Move stuff out of 'perf stat' and into the lib for further use (Jiri Olsa) - Reference count the cpu_map and thread_map classes (Jiri Olsa) - Set evsel->{cpus,threads} from the evlist, if not set, allowing the generalization of some 'perf stat' functions that previously were accessing private static evlist variable (Jiri Olsa) - Delete an unnecessary check before the calling free_event_desc() (Markus Elfring) - Allow auxtrace data alignment (Adrian Hunter) - Allow events with dot (Andi Kleen) - Fix failure to 'perf probe' events on arm (He Kuang) - Add testing for Makefile.perf (Jiri Olsa) - Add test for make install with prefix (Jiri Olsa) - Fix single target build dependency check (Jiri Olsa) - Access thread_map entries via accessors, prep patch to hold more info per entry, for ongoing 'perf stat --per-thread' work (Jiri Olsa) - Use __weak definition from compiler.h (Sukadev Bhattiprolu) - Split perf_pmu__new_alias() (Sukadev Bhattiprolu)" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (54 commits) perf tools: Allow to specify custom linker command perf tools: Create config.detected into OUTPUT directory perf mem: Fill in the missing session freeing after an error occurs perf kvm: Fill in the missing session freeing after an error occurs perf report: Fill in the missing session freeing after an error occurs perf kmem: Fill in the missing session freeing after an error occurs perf inject: Fill in the missing session freeing after an error occurs perf tools: Add missing break for PERF_RECORD_ITRACE_START perf/x86: Fix 'active_events' imbalance perf symbols: Check access permission when reading symbol files perf stat: Introduce --per-thread option perf stat: Introduce print_counters function perf stat: Using init_stats instead of memset perf stat: Rename print_interval to process_interval perf stat: Remove perf_evsel__read_cb function perf stat: Move perf_stat initialization counter process code perf stat: Move zero_per_pkg into counter process code perf stat: Separate counters reading and processing perf stat: Introduce read_counters function perf stat: Introduce perf_evsel__read function ...
2015-07-02Merge tag 'acpica-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPICA updates from Rafael Wysocki: "Additional ACPICA material for v4.2-rc1 This will update the ACPICA code in the kernel to upstream revision 20150619 (a bug-fix release mostly including stable-candidate fixes) and restore an earlier ACPICA commit that had to be reverted due to a regression introduced by it (the regression is addressed by blacklisting the only known system affected by it to date). The only new feature added by this update is the support for overriding objects in the ACPI namespace and a new ACPI table that can be used for that called the Override System Definition Table (OSDT). That should allow us to "patch" the ACPI namespace built from incomplete or incorrect ACPI System Definition tables (DSDT, SSDT) during system startup without the need to provide replacements for all of those tables in the future. Specifics: - Fix system resume problems related to 32-bit and 64-bit versions of the Firmware ACPI Control Structure (FACS) in the firmare (Lv Zheng) - Fix double initialization of the FACS (Lv Zheng) - Add _CLS object processing code to ACPICA (Suravee Suthikulpanit) - Add support for the (currently missing) new GIC version field in the Multiple APIC Description Table (MADT) (Hanjun Guo) - Add support for overriding objects in the ACPI namespace to ACPICA and OSDT support (Lv Zheng, Bob Moore, Zhang Rui) - Updates related to the TCPA and TPM2 ACPI tables (Bob Moore) - Restore the commit modifying _REV to always return "2" (as required by ACPI 6) and add a blacklisting mechanism for systems that may be affected by that change (Rafael J Wysocki) - Assorted fixes and cleanups (Bob Moore, Lv Zheng, Sascha Wildner)" * tag 'acpica-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (28 commits) Revert 'Revert "ACPICA: Permanently set _REV to the value '2'."' ACPI / init: Make it possible to override _REV ACPICA: Update version to 20150619 ACPICA: Comment update, no functional change ACPICA: Update TPM2 ACPI table ACPICA: Update definitions for the TCPA and TPM2 ACPI tables ACPICA: Split C library prototypes to new header ACPICA: De-macroize calls to standard C library functions ACPI / acpidump: Update acpidump manual ACPICA: acpidump: Convert the default behavior to dump from /sys/firmware/acpi/tables ACPICA: acpidump: Allow customized tables to be dumped without accessing /dev/mem ACPICA: Cleanup output for the ASL Debug object ACPICA: Update for acpi_install_table memory types ACPICA: Namespace: Change namespace override to avoid node deletion ACPICA: Namespace: Add support of OSDT table ACPICA: Namespace: Add support to allow overriding objects ACPICA: ACPI 6.0: Add values for MADT GIC version field ACPICA: Utilities: Add _CLS processing ACPICA: Add dragon_fly support to unix file mapping file ACPICA: EFI: Add EFI interface definitions to eliminate dependency of GNU EFI ...
2015-07-01ACPICA: De-macroize calls to standard C library functionsBob Moore
ACPICA commit 3b1026e0bdd3c32eb6d5d313f3ba0b1fee7597b4 ACPICA commit 00f0dc83f5cfca53b27a3213ae0d7719b88c2d6b ACPICA commit 47d22a738d0e19fd241ffe4e3e9d4e198e4afc69 Across all of ACPICA. Replace C library macros such as ACPI_STRLEN with the standard names such as strlen. The original purpose for these macros is long since obsolete. Also cast various invocations as necessary. Bob Moore, Jung-uk Kim, Lv Zheng. Link: https://github.com/acpica/acpica/commit/3b1026e0 Link: https://github.com/acpica/acpica/commit/00f0dc83 Link: https://github.com/acpica/acpica/commit/47d22a73 Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Jung-uk Kim <jkim@FreeBSD.org> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPI / acpidump: Update acpidump manualLv Zheng
This patch updates acpidump manual according to the recent changes. Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: acpidump: Convert the default behavior to dump from ↵Lv Zheng
/sys/firmware/acpi/tables ACPICA commit 04c3bd7e9d6aeb2b3edebe99c90dc271ae4e6353 In order to work without any additional option to dump tables when /dev/mem doesn't exist, this patch switches the default behavior of acpidump to dump from /sys/firmware/acpi/tables. Reported by Al Stone, Fixed by Lv Zheng. Link: https://github.com/acpica/acpica/commit/04c3bd7e Reported-by: Al Stone <ahs3@redhat.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: acpidump: Allow customized tables to be dumped without accessing ↵Lv Zheng
/dev/mem ACPICA commit ab29013cfa2424140446aff196a70b211ab343a9 The /dev/mem can be configured out, in which case, acpidump should still work with "-c" option as tables can be found in /sys/firmware/acpi/tables. This patch allows acpidump to work without /dev/mem. This patch has been tested with "acpidump -c" and "acpidump -c -n FADT". And it worked as expected. Lv Zheng. Link: https://github.com/acpica/acpica/commit/ab29013c Reported-by: Al Stone <ahs3@redhat.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01ACPICA: Add dragon_fly support to unix file mapping fileSascha Wildner
ACPICA commit 795b215d6fd062386f0a1c23dff9ffa244683c4f ACPICA BZ 1130 This patch doesn't affect Linux kernel. Link: https://bugs.acpica.org/show_bug.cgi?id=1130 Link: https://github.com/acpica/acpica/commit/795b215d Signed-off-by: Sascha Wildner <swildner@gmail.com> Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lv Zheng <lv.zheng@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-07-01perf tools: Allow to specify custom linker commandAaro Koskinen
Allow to specify custom linker command. This fixes MIPS64 builds for 64-bit userspace as it will allow to pass a linker using the correct linker flags for 64-bit ABI (by default GNU binutils ld will assume N32). Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1435751683-18500-2-git-send-email-aaro.koskinen@nokia.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-01perf tools: Create config.detected into OUTPUT directoryAaro Koskinen
Create config.detected into OUTPUT directory instead of source directory. This fixes parallel builds that share the same source directory. Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1435751683-18500-1-git-send-email-aaro.koskinen@nokia.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
