path: root/tools
2010-04-01perf: Make the install relative to DESTDIR if specifiedJohn Kacur
commit 7ae5f21361fea11f58c398701da635f778635d13 upstream. Without this change, the install path is relative to prefix/DESTDIR where prefix is automatically set to $HOME. This can produce unexpected results. For example: make -C tools/perf DESTDIR=/home/jkacur/tmp install-man creates the directory: /home/jkacur/home/jkacur/tmp/share/... instead of the expected: /home/jkacur/tmp/share/... Signed-off-by: John Kacur <jkacur@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Kyle McMartin <kyle@redhat.com> LKML-Reference: <1268312220-12880-1-git-send-email-jkacur@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-25perf timechart: Use tid not pid for COMM changeArjan van de Ven
commit 8f06d7e6e1bbfb32698d6d455583ab7460c090e2 upstream. A process that changes its comm field, does this on a per kernel task struct basis. The timechart tool used, incorrectly, the pid to track this, and should have used the tid instead... Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20100116125319.34ac3edd@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-08perf tools: Fix permission checksPekka Enberg
The perf_event_open() system call returns EACCES if the user is not root which results in a very confusing error message: $ perf record -A -a -f Error: perfcounter syscall returned with -1 (Permission denied) Fatal: No CONFIG_PERF_EVENTS=y kernel support configured? It turns out that's because perf tools are checking only for EPERM. Fix that up to get a much better error message: $ perf record -A -a -f Fatal: Permission error - are you root? Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1257696066-4046-1-git-send-email-penberg@cs.helsinki.fi> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26perf tools: Remove -Wcast-alignPaul Mundt
The present use of -Wcast-align causes the build to blow up on SH due to generating a "cast increases required alignment of target type" error on each invocation of list_for_each_entry(). It seems that this was previously reported and killed off in the ia64 support patch, but nothing seems to have happened with that. Presumably the same problem still remains there, too. Signed-off-by: Paul Mundt <lethal@linux-sh.org> LKML-Reference: <20091026054000.GA13517@linux-sh.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-25perf tools: Fix compatibility with libelf 0.8 and autodetectMarti Raudsepp
The Makefile now automatically defines LIBELF_NO_MMAP when libelf 0.8.x is detected. libelf 0.8 is still maintained and some distributions such as Arch Linux use it instead of elfutils. Signed-off-by: Marti Raudsepp <marti@juffo.org> Cc: Lucas De Marchi <lucas.de.marchi@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> LKML-Reference: <1256400636.3007.16.camel@newn> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-20perf timechart: Improve the visual appearance of scheduler delaysArjan van de Ven
[from KS feedback] Currently, scheduler delays are shown in a mostly transparent, light yellow color. This color is rather hard to see on several screens, especially projectors. This patch changes the color of the scheduler delays to be a much more "hard" yellow that survived the kernel summit projector. Reported-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091020064731.20ae126a@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-20perf timechart: Fix the wakeup-arrows that point to non-visible processesArjan van de Ven
The timechart wakeup arrows currently show no process information when the waker/wakee are processes that are not actually chosen to be shown on the timechart. This patch fixes this oversight, by looking through all processes (after giving preference to visible processes) as well as falling back to just showing the PID if no name for the process can be resolved. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091020064649.0e4959b2@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-19perf top: Fix --delay_secs 0 division by zeroTim Blechmann
Add delay_secs sanity check to handle_keypress, this fixes a division by zero crash. Signed-off-by: Tim Blechmann <tim@klingt.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4AD9EBFD.106@klingt.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-16perf tools: Bump version to 0.0.2Ingo Molnar
We released the first version of perf with 0.0.1 in v2.6.31, time to double our version number to 0.0.2 ;-) Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-12perf tools: Remove static debugfs path from parse-eventsAshwin Chaugule
Timechart doesn't work if debugfs is not in /sys/kernel/debug/. Fixed by using global debugfs_path which is filled in by perf. Signed-off-by: Ashwin Chaugule <ashwinc@quicinc.com> Cc: "Arjan van de Ven" <arjan@linux.intel.com> LKML-Reference: <a751bdc6978478de6d10440e587a2cc7.squirrel@www.codeaurora.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-12perf tools: Fix the NO_64BIT build on pure 64-bit systemsIngo Molnar
Randy Dunlap reported that 'make NO_64BIT=1' fails to build a pure 32-b it binary on 64-bit/64-bit x86 systems. The reason is that we dont pass in the -m32 and GCC defaults to -m64. So pass it in - and also extend the warning message about libelf dependencies - glibc-dev[el] is needed as well beyond the libelf library. Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: Message-Id: <20091005131729.78444bfb.randy.dunlap@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-12perf tools: Fix const char type propagationRandy Dunlap
The following perf build warnings/errors in function argument types: builtin-sched.c:1894: warning: passing argument 1 of 'sort_dimension__add' discards qualifiers from pointer target type util/trace-event-parse.c:685: warning: passing argument 2 of 'read_expected' discards qualifiers from pointer target type util/trace-event-parse.c:741: warning: passing argument 4 of 'test_type_token' discards qualifiers from pointer target type util/trace-event-parse.c:706: warning: passing argument 2 of 'read_expected_item' discards qualifiers from pointer target type ... trigger because older GCC is not able to prove that sort_dimension__add() does not change the string. Some goes for test_type_token(). Fix this by improving type consistency. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20091005131729.78444bfb.randy.dunlap@oracle.com> [ Also remove ugly type cast now unnecessary. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06perf_event: Provide vmalloc() based mmap() backingPeter Zijlstra
Some architectures such as Sparc, ARM and MIPS (basically everything with flush_dcache_page()) need to deal with dcache aliases by carefully placing pages in both kernel and user maps. These architectures typically have to use vmalloc_user() for this. However, on other architectures, vmalloc() is not needed and has the downsides of being more restricted and slower than regular allocations. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: David Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1254830228.21044.272.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06perf tools: elf_sym__is_function() should accept "zero" sized functionsArnaldo Carvalho de Melo
Asm routines that end up having size equal to zero are not really zero sized, and as now we do kernel_maps__fixup_sym_end, at least for kernel routines this gets fixed. A similar fixup needs to be done for the userspace bits as well, but as this fixup started only because in /proc/kallsyms we don't have the end address nor the function size, it appeared here first. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> LKML-Reference: <1254796503-27203-1-git-send-email-acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06perf trace: Update eval_flag() flags array to match interrupt.hTom Zanussi
Add missing BLOCK_IOPOLL_SOFTIRQ entry. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: lizf@cn.fujitsu.com Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1254808849-7829-3-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06perf trace: Remove unused code in builtin-trace.cTom Zanussi
And some minor whitespace cleanup. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: lizf@cn.fujitsu.com Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1254808849-7829-2-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-04perf: Propagate term signal to childChris Wilson
If we launch the child on behalf of the user, ensure that it dies along with ourselves when we are interrupted. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Chris Wilson <chris@chris-wilson.co.uk> LKML-Reference: <1254616502-4728-1-git-send-email-chris@chris-wilson.co.uk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-01perf tools: Run generate-cmdlist.sh properlyMulyadi Santosa
Right now generate-cmdlist.sh is not executable, so we should call it as an argument ".". This fixes cases where due to different umask defaults the generate-cmdlist.sh script is not executable in a kernel tree checkout. Signed-off-by: Mulyadi Santosa <mulyadi.santosa@gmail.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <f284c33d0909251201w422e9687x8cd3a784e85adf7d@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-01perf timechart: Add a power-only modeArjan van de Ven
For doing work on the Linux power management components, I need to make long (30+ seconds) traces. Currently, this then results in a HUGE svg file, with mostly process data that isn't interesting. This patch adds a --power-only mode to perf timechart that only outputs the CPU power section of the SVG; this significantly reduces the size of the SVG file, making even 30+ second traces viewable with inkscape. As a minor tweak for the same effect, the minimum text size is decreased; current inkscape cannot zoom in deep enough to show text this small, but it reduces inkscape compute time. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: peterz@infradead.org LKML-Reference: <20090924154013.0675ab71@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-30perf top: Add poll_idle to the skip listArnaldo Carvalho de Melo
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> LKML-Reference: <20090925220239.GA5488@ghostprotocols.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24perf tools: Dont use openat()Eric Dumazet
openat() is still a young glibc facility, better to not use it in a non performance critical program (perf list) Many machines have older glibc (RHEL 4 Update 5 -> glibc-2.3.4-2.36 on my dev machine for example). Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ulrich Drepper <drepper@redhat.com> LKML-Reference: <4ABB767D.6080004@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24perf tools: Fix buffer allocationEric Dumazet
"perf top" cores dump on my dev machine, if run from a directory where vmlinux is present: *** glibc detected *** malloc(): memory corruption: 0x085670d0 *** Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: <stable@kernel.org> LKML-Reference: <4ABB6EB7.7000002@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24perf tools: .gitignore += perf*.htmlKirill Smelkov
I've tried building the docs in tools/perf/Documentation/ , and after that `git status` showed dozen of untracked htmls. Let's ignore them. Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru> LKML-Reference: <1253790022-10300-1-git-send-email-kirr@mns.spb.ru> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-24perf tools: Handle relative paths while loading module symbolsMike Galbraith
Inform util/module.c::mod_dso__load_module_paths() that relative paths do exist in some modules.dep, and make it fail noisily should it encounter a path that it doesn't understand, or a module it cannot open. Reported-by: Avi Kivity <avi@redhat.com> Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: rostedt@goodmis.org Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <1253779628.10513.8.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23perf tools: Fix module symbol loading bugMike Galbraith
Avi Kivity reported 'perf annotate' failures with modules, the requested function was not annotated. If there are no modules currently loaded, or the last module scanned is not loaded, dso__load_modules() steps on the value from dso__load_vmlinux(), so we happily load the kallsyms symbols on top of what we've already loaded. Fix that such that the total count of symbols loaded is returned. Should module symbol load fail after parsing of vmlinux, is's a hard failure, so do not silently fall-back to kallsyms. Reported-by: Avi Kivity <avi@redhat.com> Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: rostedt@goodmis.org Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <1253697658.11461.36.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-22perf stat: Fix zero total printoutsIngo Molnar
Before: 0 sched:sched_switch # nan M/sec After: 0 sched:sched_switch # 0.000 M/sec Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-20perf util: SVG performance improvementsArjan van de Ven
Tweak the output SVG to increase performance in SVG viewers by limiting the different types of font sizes and by smarter transformations on the text. At least with Inkscape this gives a notable performance improvement during zoom and scrolling. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090920181438.3a49cb93@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-20perf util: Make the timechart SVG width dynamicArjan van de Ven
This patch adds a command line option for timechart that allows the user to specify the width of the SVG file. This patch also makes sure that each second of recording has at least 200 units (pixels at 96 DPI) of width. This impacts recordings longer than 5 seconds; recordings shorter than 5 second will scale up to have a width of 1000 units for the whole recording (as before). Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090920181416.69570c5d@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-20perf timechart: Show the duration of scheduler delays in the SVGArjan van de Ven
Given that scheduler latencies are the hot thing nowadays, show the duration of said latencies in the SVG in text form. In addition, if the latency is more than 10 msec, pick a brighter yellow color as a way to point these long delays out. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090920181353.796f4509@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-20perf timechart: Show the name of the waker/wakee in timechartArjan van de Ven
Timechart currently shows thin green lines for sending or receiving wakeups. This patch also prints (in a very small font) the name of the process that is being woken/wakes up this process. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090920181328.68baa978@linux.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf utils: Use a define for the maximum length of a trace eventArjan van de Ven
As per Ingo's review: use a #define rather than an open coded constant for the maximum length of a trace event for storing in the perf.data file. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: fweisbec@gmail.com Cc: peterz@infradead.org Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20090919133630.10533d3e@infradead.org> [ add a few comments to nearby functions ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf: Add timechart help text and add timechart to "perf help"Arjan van de Ven
As suggested by Ingo, add a timechart man page help text, as well as add it to the "perf help" overview. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: fweisbec@gmail.com Cc: peterz@infradead.org Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20090919133604.3767fa35@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf utils: Be consistent about minimum text size in the svghelperArjan van de Ven
Be more consistent in the svghelper about the minimum text size by having a global #define for this. There needs to be a minimum text size in order to keep the size of the SVG file within the reach of what current SVG viewers can cope with. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: fweisbec@gmail.com Cc: peterz@infradead.org Cc: Paul Mackerras <paulus@samba.org> Cc: Arjan van de Ven <arjan@infradead.org> LKML-Reference: <20090919133507.7374ef8b@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf timechart: Add "perf timechart record"Arjan van de Ven
Add a command line option to record a trace, similar to "perf sched record". Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: fweisbec@gmail.com Cc: peterz@infradead.org Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20090919133442.0dc2c7f5@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf: Add the timechart toolArjan van de Ven
timechart is a tool to visualize what is going on in the system. The user makes a trace of what is going on with > perf record --timechart /usr/bin/some_command and then can turn the output of this into an svg file > perf timechart which then can be viewed with any SVG view; inkscape works well enough for me. The idea behind timechart is to create a "infinitely zoomable" picture; something that has high level information on a 1:1 zoom level, but which exposes more details every time you zoom into a specific area. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090912130713.6a77bbc0@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf: Add a SVG helper library fileArjan van de Ven
The timechart tool writes out SVG format output; this patch adds a set of helper functions to abstract dealing with SVG from the core timechart code. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090912130613.677f0516@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf: Add a sample_event type to the event_unionArjan van de Ven
Add a sample_event type to the event_union so that raw samples can be processed easily. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090912130511.411434b5@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf: Allow perf utilities to have "callback" options without argumentsArjan van de Ven
timechart needs to add a "callback" type command line argument that does not take arguments. This patch adds the parse-options.h infrastructure to make this possible. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090912130440.548666c1@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf: Store trace event name/id pairs in perf.dataArjan van de Ven
The trace event name<->id mapping is dynamic for each kernel compile. In order for perf.data to be useable outside the actual system, we thus need to store a table of this mapping for later use. This patch adds this table to perf.data, and provides helper functions for lookup up fields from this table. To avoid mistakes, lookup-from-table is kept completely seprate from lookup-from-local-debugfs. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090912130405.6960d099@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19perf: Add a timestamp to fork eventsArjan van de Ven
perf timechart needs to know when a process forked, in order to be able to visualize properly when tasks start. This patch adds a time field to the event structure, and fills it in appropriately. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090912130341.51ad2de2@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19Merge branch 'linus' into perfcounters/coreIngo Molnar
Merge reason: Bring in tracing changes we depend on. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18perf sched: Add --input=file option to builtin-sched.cMike Galbraith
perf sched record passes unparsed args on to perf record, so specifying an output file via perf sched record -o FILE (cmd) just works. Ergo, provide an option to specify input file as well. Also add the missing 'map' command to help. Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1253254944.20589.11.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18perf trace: Sample timestamp and cpu when using record flagLi Zefan
Sample timestamp and cpu just like the -R option. Before: init-0 [-01] 1266874889.17179869184709551615: irq_handler_entry: irq=18 handler=eth0 init-0 [-01] 1266874889.17179869184709551615: irq_handler_entry: irq=18 handler=eth0 init-0 [-01] 1266874889.17179869184709551615: irq_handler_entry: irq=1 handler=i8042 init-0 [-01] 1266874889.17179869184709551615: irq_handler_entry: irq=18 handler=eth0 init-0 [-01] 1266874889.17179869184709551615: irq_handler_entry: irq=1 handler=i8042 After: init-0 [001] 7364.568965353: irq_handler_entry: irq=18 handler=eth0 init-0 [001] 7365.530226877: irq_handler_entry: irq=1 handler=i8042 init-0 [001] 7365.542831563: irq_handler_entry: irq=18 handler=eth0 init-0 [001] 7365.644156299: irq_handler_entry: irq=18 handler=eth0 init-0 [001] 7365.694556201: irq_handler_entry: irq=18 handler=eth0 Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4AB1F827.8040905@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18perf tools: Increase MAX_EVENT_LENGTHLi Zefan
The name length of some trace events is longer than 30, like sys_enter_sched_get_priority_max and ext4_mb_discard_preallocations. Passing those events to perf-record will fail, try: # ./perf record -f -e syscalls:sys_enter_sched_get_priority_max -F 1 -a Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4AB1F4AB.7050205@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18perf tools: Fix memory leak in read_ftrace_printk()Li Zefan
get_tracing_file() should be paired with put_tracing_file(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <4AB1F48F.4070807@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-17perf sched: Determine the number of CPUs automaticallyIngo Molnar
For 'perf sched map' output, determine max_cpu automatically, instead of the static default of 15. [ v2: use sysconf() pointed out by Arjan van de Ven <arjan@infradead.org> ] Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-17perf record: Disable profiling before draining the bufferPeter Zijlstra
I noticed that perf-record continues profiling itself after the child terminated and we're draining the buffer. This can cause a _lot_ of overhead with --all recording - we keep and keep recording, which produces new and new events. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-16perf sched: Add 'perf sched map' scheduling event map printoutIngo Molnar
This prints a textual context-switching outline of workload captured via perf sched record. For example, on a 16 CPU box it outputs: N1 O1 . . . S1 . . . B0 . *I0 C1 . M1 . 23002.773423 secs N1 O1 . *Q0 . S1 . . . B0 . I0 C1 . M1 . 23002.773423 secs N1 O1 . Q0 . S1 . . . B0 . *R1 C1 . M1 . 23002.773485 secs N1 O1 . Q0 . S1 . *S0 . B0 . R1 C1 . M1 . 23002.773478 secs *L0 O1 . Q0 . S1 . S0 . B0 . R1 C1 . M1 . 23002.773523 secs L0 O1 . *. . S1 . S0 . B0 . R1 C1 . M1 . 23002.773531 secs L0 O1 . . . S1 . S0 . B0 . R1 C1 *T1 M1 . 23002.773547 secs T1 => irqbalance:2089 L0 O1 . . . S1 . S0 . *P0 . R1 C1 T1 M1 . 23002.773549 secs *N1 O1 . . . S1 . S0 . P0 . R1 C1 T1 M1 . 23002.773566 secs N1 O1 . . . *J0 . S0 . P0 . R1 C1 T1 M1 . 23002.773571 secs N1 O1 . . . J0 . S0 *B0 P0 . R1 C1 T1 M1 . 23002.773592 secs N1 O1 . . . J0 . *U0 B0 P0 . R1 C1 T1 M1 . 23002.773582 secs N1 O1 . . . *S1 . U0 B0 P0 . R1 C1 T1 M1 . 23002.773604 secs N1 O1 . . . S1 . U0 B0 *. . R1 C1 T1 M1 . 23002.773615 secs N1 O1 . . . S1 . U0 B0 . . *K0 C1 T1 M1 . 23002.773631 secs N1 O1 . *M0 . S1 . U0 B0 . . K0 C1 T1 M1 . 23002.773624 secs N1 O1 . M0 . S1 . U0 *. . . K0 C1 T1 M1 . 23002.773644 secs N1 O1 . M0 . S1 . U0 . . . *R1 C1 T1 M1 . 23002.773662 secs N1 O1 . M0 . S1 . *. . . . R1 C1 T1 M1 . 23002.773648 secs N1 O1 . *. . S1 . . . . . R1 C1 T1 M1 . 23002.773680 secs N1 O1 . . . *L0 . . . . . R1 C1 T1 M1 . 23002.773717 secs *N0 O1 . . . L0 . . . . . R1 C1 T1 M1 . 23002.773709 secs *N1 O1 . . . L0 . . . . . R1 C1 T1 M1 . 23002.773747 secs Columns stand for individual CPUs, from CPU0 to CPU15, and the two-letter shortcuts stand for tasks that are running on a CPU. '*' denotes the CPU that had the event. A dot signals an idle CPU. New tasks are assigned new two-letter shortcuts - when they occur first they are printed. In the above example 'T1' stood for irqbalance: T1 => irqbalance:2089 Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-16perf sched: Make idle thread and comm/pid names more consistentIngo Molnar
Peter noticed that we have 3 ways of referring to the idle thread: [idle]:0 swapper:0 swapper-0 Standardize on 'swapper:0'. Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
