commit 32677207dcc5e594254b7fb4fb2352b1755b1d5b upstream.
The child_exit errno needs to be shifted by 8 bits to compare against the
return values for the bisect variables.
Fixes: c5dacb88f0a64 ("ktest: Allow overriding bisect test results")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit df21d2fa733035e4d414379960f94b2516b41296 upstream.
Test uses PMC2 to count the event. But PMC1 is being initialized.
Patch to fix it.
Fixes: 3752e453f6ba ('selftests/powerpc: Add tests of PMU EBBs')
Signed-off-by: Madhavan Srinivasan <maddy@linux.vnet.ibm.com>
commit cf346d5bd4b9d61656df2f72565c9b354ef3ca0d upstream.
Both register_perl_scripting() and register_python_scripting() allocate
this variable, fix it by checking if it already was.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: Wang Nan <wangnan0@huawei.com>
Fixes: 7e4b21b84c43 ("perf/scripts: Add Python scripting engine")
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit a2b1e8a20c992b01eeb76de00d4f534cbe9f3822 upstream.
Nothing in this minimal script seems to require bash. We often run these
tests on embedded devices where the only shell available is the busybox
ash. Use sh instead.
Signed-off-by: Rolf Eike Beer <eb@emlix.com>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
commit 3659f98b5375d195f1870c3e508fe51e52206839 upstream.
commit 67befc652845c8ffbefc8d173a6e6ced14d472f1 upstream.
Ingo reported following build failure:
$ make clean install
CC plugin_kmem.o
fixdep: error opening depfile: ./.plugin_hrtimer.o.d: No such file or directory
/home/mingo/tip/tools/build/Makefile.build:77: recipe for target
'plugin_hrtimer.o' failed
make[3]: *** [plugin_hrtimer.o] Error 2
Makefile:189: recipe for target 'plugin_hrtimer-in.o' failed
make[2]: *** [plugin_hrtimer-in.o] Error 2
Makefile.perf:414: recipe for target 'libtraceevent_plugins' failed
make[1]: *** [libtraceevent_plugins] Error 2
make[1]: *** Waiting for unfinished jobs....
Currently we have the install-traceevent-plugins target being dependent
on $(LIBTRACEEVENT), which will actualy not build any plugin. So the
install-traceevent-plugins target itself will try to build plugins,
but..
Plugins built is also triggered by perf build itself via
libtraceevent_plugins target.
This might cause a race having one make thread removing temp files from
another and result in above error. Fixing this by having proper plugins
build dependency before installing plugins.
Reported-and-Tested-by:: Ingo Molnar <mingo@kernel.org>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/1448546044-28973-3-git-send-email-jolsa@kernel.org
Cc: Thomas Backlund <tmb@mageia.org>
commit 432746f8e0b6a82ba832b771afe31abd51af6752 upstream.
When we call symbol__fixup_duplicate() we use algorithms to pick the
"best" symbols for cases where there are various functions/aliases to an
address, and those check zero size symbols, which, before calling
symbol__fixup_end() are _all_ symbols in a just parsed kallsyms file.
So first fixup the end, then fixup the duplicates.
Found while trying to figure out why 'perf test vmlinux' failed, see the
output of 'perf test -v vmlinux' to see cases where the symbols picked
as best for vmlinux don't match the ones picked for kallsyms.
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Fixes: 694bf407b061 ("perf symbols: Add some heuristics for choosing the best duplicate symbol")
Link: http://lkml.kernel.org/n/tip-rxqvdgr0mqjdxee0kf8i2ufn@git.kernel.org
commit c97b40e4d15f13a36cd037d598e45cbe9e1e5757 upstream.
We can allow aliases to be kept, but we were checking this just when
loading vmlinux files, be consistent, do it for any symbol table loading
code that calls symbol__fixup_duplicate() by making this function check
.allow_aliases instead.
Fixes: 680d926a8cb0 ("perf symbols: Allow symbol alias when loading map for symbol name")
Link: http://lkml.kernel.org/n/tip-z0avp0s6cfjckc4xj3pdfjdz@git.kernel.org
commit d9ea48bc4e7cc297ca1073fa3f90ed80d964b7b4 upstream.
Milian reported that the event group on TUI shows duplicated overhead.
This was due to a bug on calculating hpp->buf position. The
hpp_advance() was called from __hpp__slsmg_color_printf() on TUI but
it's already called from the hpp__call_print_fn macro in __hpp__fmt().
The end result is that the print function returns number of bytes it
printed but the buffer advanced twice of the length.
This is generally not a problem since it doesn't need to access the
buffer again. But with event group, overhead needs to be printed
multiple times and hist_entry__snprintf_alignment() tries to fill the
space with buffer after it printed. So it (brokenly) showed the last
overhead again.
The bug was there from the beginning, but I think it's only revealed
when the alignment function was added.
Reported-by: Milian Wolff <milian.wolff@kdab.com>
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Fixes: 89fee7094323 ("perf hists: Do column alignment on the format iterator")
Link: http://lkml.kernel.org/r/20160912061958.16656-2-namhyung@kernel.org
commit 51fd2df1e882a3c2a3f4b6c9ff243a93c9046dba upstream.
We broke interval data displays with commit:
3f416f22d1e2 ("perf stat: Do not clean event's private stats")
This commit removed stats cleaning, which is important for '-r' option
to carry counters data over the whole run. But it's necessary to clean
it for interval mode, otherwise the displayed value is avg of all
previous values.
Before:
$ perf stat -e cycles -a -I 1000 record
# time counts unit events
1.000240796 75,216,287 cycles
2.000512791 107,823,524 cycles
$ perf stat report
2.000512791 91,519,906 cycles
Now:
$ perf stat report
Notice the second value being bigger (91,.. < 107,..).
This could be easily verified by using perf script which displays raw
stat data:
$ perf script
CPU THREAD VAL ENA RUN TIME EVENT
0 -1 23855779 1000209530 1000209530 1000240796 cycles
1 -1 33340397 1000224964 1000224964 1000240796 cycles
2 -1 15835415 1000226695 1000226695 1000240796 cycles
3 -1 2184696 1000228245 1000228245 1000240796 cycles
0 -1 97014312 2000514533 2000514533 2000512791 cycles
1 -1 46121497 2000543795 2000543795 2000512791 cycles
2 -1 32269530 2000543566 2000543566 2000512791 cycles
3 -1 7634472 2000544108 2000544108 2000512791 cycles
The sum of the first 4 values is the first interval aggregated value:
23855779 + 33340397 + 15835415 + 2184696 = 75,216,287
The sum of the second 4 values minus first value is the second interval
aggregated value:
97014312 + 46121497 + 32269530 + 7634472 - 75216287 = 107,823,524
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1454485436-20639-1-git-send-email-jolsa@kernel.org
Cc: Jeremy Linton <jeremy.linton@arm.com>
commit 3bccbe20f6d188ce7b00326e776b745cfd35b10a upstream.
The MTC packet provides a 8-bit slice of CTC which is related to TSC by
the TMA packet, however the TMA packet only provides the lower 16 bits
of CTC. If mtc_shift > 8 then some of the MTC bits are not in the CTC
provided by the TMA packet. Fix-up the last_mtc calculated from the TMA
packet by copying the missing bits from the current MTC assuming the
least difference between the two, and that the current MTC comes after
last_mtc.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1475062896-22274-2-git-send-email-adrian.hunter@intel.com
commit 51ee6481fa8e879cc942bcc1b0af713e158b7a98 upstream.
In cycle-accurate mode, timestamps can be calculated from CYC packets.
The decoder also estimates timestamps based on the number of
instructions since the last timestamp. For that to work in
cycle-accurate mode, the instruction count needs to be reset to zero
when a timestamp is calculated from a CYC packet, but that wasn't
happening, so fix it.
Link: http://lkml.kernel.org/r/1475062896-22274-1-git-send-email-adrian.hunter@intel.com
commit 810c398bc09b2f2dfde52a7d2483a710612c5fb8 upstream.
Fix occasional decoder errors decoding trace data collected in snapshot
mode.
Snapshot mode can take successive snapshots of trace which might overlap.
The decoder checks whether there is an overlap but only looks at the
current and previous buffer. However buffers that do not contain
synchronization (i.e. PSB) packets cannot be decoded or used for overlap
checking. That means the decoder actually needs to check overlaps between
the current buffer and the previous buffer that contained usable data.
Make that change.
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Link: http://lkml.kernel.org/r/1474641528-18776-10-git-send-email-adrian.hunter@intel.com
commit 2d6a4d64812bb12dda53704943b61a7496d02098 upstream.
The curly braces are missing here so we print stuff unintentionally.
Fixes: 9da4714a2d44 ('slub: slabinfo update for cmpxchg handling')
Link: http://lkml.kernel.org/r/20160715211243.GE19522@mwanda
Acked-by: Christoph Lameter <cl@linux.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Colin Ian King <colin.king@canonical.com>
Cc: Laura Abbott <labbott@fedoraproject.org>
[ Upstream commit b4ed5d1682c6613988c2eb1de55df5ac9988afcc ]
Currently some "Unspecified error 0x80004005" is reported on the Windows
side if something fails. Handle the ENOSPC case and return
ERROR_DISK_FULL, which allows at least Copy-VMFile to report a meaning
full error.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
commit 3d918fb13abdbeca7947578f5d7e426eafad7f5e upstream.
In order to successfully decode Intel PT traces, context switch events
are needed from the moment the trace starts. Currently that is ensured
by using the 'immediate' flag which enables the switch event when it is
opened.
However, since commit 86c2786994bd ("perf intel-pt: Add support for
PERF_RECORD_SWITCH") that might not always happen. When tracing
system-wide the context switch event is added to the tracking event
which was not set as 'immediate'. Change that so it is.
Fixes: 86c2786994bd ("perf intel-pt: Add support for PERF_RECORD_SWITCH")
Link: http://lkml.kernel.org/r/1471245784-22580-1-git-send-email-adrian.hunter@intel.com
commit d8d378fa1a0c98ecb50ca52c9bf3bc14e25aa2d2 upstream.
The unit tests crash when hotplug races the previous probe. This race
requires that the loading of the nfit_test module be terminated with
SIGTERM, and the module to be unloaded while the ars scan is still
running.
In contrast to the normal nfit driver, the unit test calls
acpi_nfit_init() twice to simulate hotplug, whereas the nominal case
goes through the acpi_nfit_notify() event handler. The
acpi_nfit_notify() path is careful to flush the previous region
registration before servicing the hotplug event. The unit test was
missing this guarantee.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff810cdce7>] pwq_activate_delayed_work+0x47/0x170
Call Trace:
[<ffffffff810ce186>] pwq_dec_nr_in_flight+0x66/0xa0
[<ffffffff810ce490>] process_one_work+0x2d0/0x680
[<ffffffff810ce331>] ? process_one_work+0x171/0x680
[<ffffffff810ce88e>] worker_thread+0x4e/0x480
[<ffffffff810ce840>] ? process_one_work+0x680/0x680
[<ffffffff810d5343>] kthread+0xf3/0x110
[<ffffffff8199846f>] ret_from_fork+0x1f/0x40
[<ffffffff810d5250>] ? kthread_create_on_node+0x230/0x230
commit 916d4092a1d2d7bb50630497be71ee4c4c2807fa upstream.
$ rpm -q glibc
glibc-2.12-1.166.el6_7.1.x86_64
<SNIP>
CC /tmp/build/perf/tests/llvm.o
cc1: warnings being treated as errors
tests/llvm.c: In function ‘test_llvm__fetch_bpf_obj’:
tests/llvm.c:53: error: declaration of ‘index’ shadows a global declaration
/usr/include/string.h:489: error: shadowed declaration is here
<SNIP>
CC /tmp/build/perf/tests/bpf.o
tests/bpf.c: In function ‘__test__bpf’:
tests/bpf.c:149: error: declaration of ‘index’ shadows a global declaration
<SNIP>
Cc: He Kuang <hekuang@huawei.com>
Cc: pi3orama@163.com
Cc: Zefan Li <lizefan@huawei.com>
Fixes: b31de018a628 ("perf test: Enhance the LLVM test: update basic BPF test program")
Fixes: ba1fae431e74 ("perf test: Add 'perf test BPF'")
Link: http://lkml.kernel.org/n/tip-akpo4r750oya2phxoh9e3447@git.kernel.org
Cc: Nikolay Borisov <kernel@kyup.com>
commit 106b816cb46ebd87408b4ed99a2e16203114daa6 upstream.
At the end of process_filter(), collapse_tree() was changed to update
the parg parameter, but the reassignment after the call wasn't removed.
What happens is that the "current_op" gets modified and freed and parg
is assigned to the new allocated argument. But after the call to
collapse_tree(), parg is assigned again to the just freed "current_op",
and this causes the tool to crash.
The current_op variable must also be assigned to NULL in case of error,
otherwise it will cause it to be free()ed twice.
Acked-by: Namhyung Kim <namhyung@kernel.org>
Fixes: 42d6194d133c ("tools lib traceevent: Refactor process_filter()")
Link: http://lkml.kernel.org/r/20160511150936.678c18a1@gandalf.local.home
commit f594bae08183fb6b57db55387794ece3e1edf6f6 upstream.
I'm surprised this remained undocumented since at least 2011. And it is
actually a very useful switch, as Steve and I came to realize recently.
Add the text from
2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events")
which added the incrementing aspect to -d.
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Davidlohr Bueso <dbueso@suse.com>
Cc: Mel Gorman <mgorman@suse.com>
Fixes: 2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events")
Link: http://lkml.kernel.org/r/1457347294-32546-1-git-send-email-bp@alien8.de
commit 89fee59b504f86925894fcc9ba79d5c933842f93 upstream.
Steam frequently puts game binaries in folders with spaces.
Note: "(deleted)" markers are now treated as part of the file name.
Signed-off-by: Marcin Ślusarz <marcin.slusarz@gmail.com>
Fixes: 6064803313ba ("perf tools: Use sscanf for parsing /proc/pid/maps")
Link: http://lkml.kernel.org/r/20160119190303.GA17579@marcin-Inspiron-7720
cursor
commit c221acb0f970d3b80d72c812cda19c121acf5d52 upstream.
When this feature was introduced a check was made if there was a
resolved symbol under the cursor, it got lost in commit ea7cd5923309
("perf hists browser: Split popup menu actions - part 2"), reinstate it.
Cc: Jiri Olsa <jolsa@kernel.org>,
Fixes: ea7cd5923309 ("perf hists browser: Split popup menu actions - part 2")
Link: http://lkml.kernel.org/r/1452960197-5323-9-git-send-email-namhyung@kernel.org
[ Carved out from a larger patch ]
commit a55e5663761366fb883f6f25375dd68bc958b9db upstream.
We were dropping the reference we possibly held but not obtaining one
for the new maps, which we will drop at perf_evlist__delete(), fix it.
This was caught by Steven Noonan in some of the machines which would
produce this output when caught by glibc debug mechanisms:
$ sudo perf test 21
21: Test object code reading :***
Error in `perf': corrupted double-linked list: 0x00000000023ffcd0 ***
======= Backtrace: =========
/usr/lib/libc.so.6(+0x72055)[0x7f25be0f3055]
/usr/lib/libc.so.6(+0x779b6)[0x7f25be0f89b6]
/usr/lib/libc.so.6(+0x7a0ed)[0x7f25be0fb0ed]
/usr/lib/libc.so.6(__libc_calloc+0xba)[0x7f25be0fceda]
perf(parse_events_lex_init_extra+0x38)[0x4cfff8]
perf(parse_events+0x55)[0x4a0615]
perf(perf_evlist__config+0xcf)[0x4eeb2f]
perf[0x479f82]
perf(test__code_reading+0x1e)[0x47ad4e]
perf(cmd_test+0x5dd)[0x46452d]
perf[0x47f4e3]
perf(main+0x603)[0x42c723]
/usr/lib/libc.so.6(__libc_start_main+0xf0)[0x7f25be0a1610]
perf(_start+0x29)[0x42c859]
Further investigation using valgrind led to the reference count imbalance fixed
in this patch.
Reported-and-Tested-by: Steven Noonan <steven@uplinklabs.net>
Report-Link: http://lkml.kernel.org/r/CAKbGBLjC2Dx5vshxyGmQkcD+VwiAQLbHoXA9i7kvRB2-2opHZQ@mail.gmail.com
Fixes: f30a79b012e5 ("perf tools: Add reference counting for cpu_map object")
Link: http://lkml.kernel.org/n/tip-j0u1bdhr47sa511sgg76kb8h@git.kernel.org
commit 1342e0b7a6c1a060c593037fbac9f4b717f1cb3b upstream.
Tracing a workload that uses transactions gave a seg fault as follows:
perf record -e intel_pt// workload
perf report
Program received signal SIGSEGV, Segmentation fault.
0x000000000054b58c in intel_pt_reset_last_branch_rb (ptq=0x1a36110)
at util/intel-pt.c:929
929 ptq->last_branch_rb->nr = 0;
(gdb) p ptq->last_branch_rb
$1 = (struct branch_stack *) 0x0
(gdb) up
1148 intel_pt_reset_last_branch_rb(ptq);
(gdb) l
1143 if (ret)
1144 pr_err("Intel Processor Trace: failed to deliver transaction event
1145 ret);
1146
1147 if (pt->synth_opts.callchain)
1149
1150 return ret;
1151 }
1152
(gdb) p pt->synth_opts.callchain
$2 = true
(gdb)
(gdb) bt
#0 0x000000000054b58c in intel_pt_reset_last_branch_rb (ptq=0x1a36110)
#1 0x000000000054c1e0 in intel_pt_synth_transaction_sample (ptq=0x1a36110)
#2 0x000000000054c5b2 in intel_pt_sample (ptq=0x1a36110)
Caused by checking the 'callchain' flag when it should have been the
'last_branch' flag. Fix that.
Reported-by: Andi Kleen <ak@linux.intel.com>
Fixes: f14445ee72c5 ("perf intel-pt: Support generating branch stack")
Link: http://lkml.kernel.org/r/1460977068-11566-1-git-send-email-adrian.hunter@intel.com
commit 50fe6dd10069e7c062e27f29606f6e91ea979399 upstream.
Use the local uapi headers to keep in sync with "recently" added #define's
(e.g. VSS_OP_REGISTER1).
Fixes: 3eb2094c59e8 ("Adding makefile for tools/hv")
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
commit 67d5268908283c187e0a460048a423256c2fb288 upstream.
The util/python-ext-sources file contains source files required to build
the python extension relative to $(srctree)/tools/perf,
Such a file path $(FILE).c is handed over to the python extension build
system, which builds the final object in the
$(PYTHON_EXTBUILD)/tmp/$(FILE).o path.
After the build is done all files from $(PYTHON_EXTBUILD)lib/ are
carried as the result binaries.
Above system fails when we add source file relative to ../lib, which we
do for:
../lib/bitmap.c
../lib/find_bit.c
../lib/hweight.c
../lib/rbtree.c
All above objects will be built like:
$(PYTHON_EXTBUILD)/tmp/../lib/bitmap.c
$(PYTHON_EXTBUILD)/tmp/../lib/find_bit.c
$(PYTHON_EXTBUILD)/tmp/../lib/hweight.c
$(PYTHON_EXTBUILD)/tmp/../lib/rbtree.c
which accidentally happens to be final library path:
$(PYTHON_EXTBUILD)/lib/
Changing setup.py to pass full paths of source files to Extension build
class and thus keep all built objects under $(PYTHON_EXTBUILD)tmp
directory.
Reported-by: Jeff Bastian <jbastian@redhat.com>
Tested-by: Josh Boyer <jwboyer@fedoraproject.org>
Link: http://lkml.kernel.org/r/20160227201350.GB28494@krava.redhat.com
commit 26dee028d365fbc0e3326606a8520260b4462381 upstream.
According to man pages, asprintf returns -1 when failure. This patch
fixes two incorrect return value checker.
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Brendan Gregg <brendan.d.gregg@gmail.com>
Cc: Cody P Schafer <dev@codyps.com>
Cc: Jeremie Galarneau <jeremie.galarneau@efficios.com>
Cc: Kirill Smelkov <kirr@nexedi.com>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Fixes: ffeb883e5662 ("perf tools: Show proper error message for wrong terms of hw/sw events")
Link: http://lkml.kernel.org/r/1455882283-79592-5-git-send-email-wangnan0@huawei.com
commit 940db6dcd3f4659303fdf6befe7416adc4d24118 upstream.
When an error happens during alias parsing currently the complete
parsing of all attributes of the PMU is stopped. This is breaks old perf
on a newer kernel that may have not-yet-know alias attributes (such as
.scale or .per-pkg).
Continue when some attribute is unparseable.
This is IMHO a stable candidate and should be backported to older
versions to avoid problems with newer kernels.
v2: Print warnings when something goes wrong.
v3: Change warning to debug output
Link: http://lkml.kernel.org/r/1455749095-18358-1-git-send-email-andi@firstfloor.org
commit 3f416f22d1e21709a631189ba169f76fd267b374 upstream.
Mel reported stddev reporting was broken due to following commit:
106a94a0f8c2 ("perf stat: Introduce read_counters function")
This commit merged interval and overall counters reading into single
read_counters function.
The old interval code cleaned the stddev data for some reason (it's
never displayed in interval mode) and the mentioned commit kept on
cleaning the stddev data in merged function, which resulted in the
stddev not being displayed.
Removing the wrong stddev data cleanup init_stats call.
Reported-and-Tested-by: Mel Gorman <mgorman@techsingularity.net>
Fixes: 106a94a0f8c2 ("perf stat: Introduce read_counters function")
Link: http://lkml.kernel.org/r/1453290995-18485-4-git-send-email-jolsa@kernel.org
commit a689d2510f188e75391dbebacbddfd74d42f2a7e upstream.
Fix the write()'s argument in the daemon code.
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: "K. Y. Srinivasan" <kys@microsoft.com>
Signed-off-by: Dexuan Cui <decui@microsoft.com>
commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 upstream.
"rm -rf" is bricking some peoples' laptops because of variables being
used to store non-reinitializable firmware driver data that's required
to POST the hardware.
These are 100% bugs, and they need to be fixed, but in the mean time it
shouldn't be easy to *accidentally* brick machines.
We have to have delete working, and picking which variables do and don't
work for deletion is quite intractable, so instead make everything
immutable by default (except for a whitelist), and make tools that
aren't quite so broad-spectrum unset the immutable flag.
Signed-off-by: Peter Jones <pjones@redhat.com>
Tested-by: Lee, Chun-Yi <jlee@suse.com>
Acked-by: Matthew Garrett <mjg59@coreos.com>
Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk>
recording/reporting guest data
commit 3caeaa562733c4836e61086ec07666635006a787 upstream.
While recording guest samples in host using perf kvm record, it will
populate unprocessable sample error, though samples will be recorded
properly. While generating report using perf kvm report, no samples will
be processed and same error will populate. We have seen this behaviour
with upstream perf(4.4-rc3) on x86 and ppc64 hardware.
Reason behind this failure is, when it tries to fetch machine from
rb_tree of machines, it fails. As a part of tracing a bug, we figured
out that this code was incorrectly refactored in commit 54245fdc3576
("perf session: Remove wrappers to machines__find").
This patch will change the functionality such that if it can't fetch
machine in first trial, it will create one node of machine and add that to
rb_tree. So next time when it tries to fetch same machine from rb_tree,
it won't fail. Actually it was the case before refactoring of code in
aforementioned commit.
This patch is generated from acme perf/core branch.
Below I've mention an example that demonstrate the behaviour before and
after applying patch.
Before applying patch:
[Note: One needs to run guest before recording data in host]
ravi@ravi-bangoria:~$ ./perf kvm record -a
Warning:
5903 unprocessable samples recorded.
Do you have a KVM guest running and not using 'perf kvm'?
[ perf record: Captured and wrote 1.409 MB perf.data.guest (285 samples) ]
ravi@ravi-bangoria:~$ ./perf kvm report --stdio
Warning:
# To display the perf.data header info, please use --header/--header-only options.
# Total Lost Samples: 0
# Samples: 285 of event 'cycles'
# Event count (approx.): 88715406
# Overhead Command Shared Object Symbol
# (For a higher level overview, try: perf report --sort comm,dso)
After applying patch:
[ perf record: Captured and wrote 1.188 MB perf.data.guest (17 samples) ]
# Samples: 17 of event 'cycles'
# Event count (approx.): 700746
34.19% :5758 [unknown] [g] 0xffffffff818682ab
22.79% :5758 [unknown] [g] 0xffffffff812dc7f8
22.79% :5758 [unknown] [g] 0xffffffff818650d0
14.83% :5758 [unknown] [g] 0xffffffff8161a1b6
2.49% :5758 [unknown] [g] 0xffffffff818692bf
0.48% :5758 [unknown] [g] 0xffffffff81869253
0.05% :5758 [unknown] [g] 0xffffffff81869250
Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Fixes: 54245fdc3576 ("perf session: Remove wrappers to machines__find")
Link: http://lkml.kernel.org/r/1449471302-11283-1-git-send-email-ravi.bangoria@linux.vnet.ibm.com
commit ec183d22cc284a7a1e17f0341219d8ec8ca070cc upstream.
Fixes segmentation fault using, for instance:
(gdb) run record -I -e intel_pt/tsc=1,noretcomp=1/u /bin/ls
Starting program: /home/acme/bin/perf record -I -e intel_pt/tsc=1,noretcomp=1/u /bin/ls
Missing separate debuginfos, use: dnf debuginfo-install glibc-2.22-7.fc23.x86_64
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
0 x00000000004b9ea5 in tracepoint_error (e=0x0, err=13, sys=0x19b1370 "sched", name=0x19a5d00 "sched_switch") at util/parse-events.c:410
(gdb) bt
#0 0x00000000004b9ea5 in tracepoint_error (e=0x0, err=13, sys=0x19b1370 "sched", name=0x19a5d00 "sched_switch") at util/parse-events.c:410
#1 0x00000000004b9fc5 in add_tracepoint (list=0x19a5d20, idx=0x7fffffffb8c0, sys_name=0x19b1370 "sched", evt_name=0x19a5d00 "sched_switch", err=0x0, head_config=0x0)
at util/parse-events.c:433
#2 0x00000000004ba334 in add_tracepoint_event (list=0x19a5d20, idx=0x7fffffffb8c0, sys_name=0x19b1370 "sched", evt_name=0x19a5d00 "sched_switch", err=0x0, head_config=0x0)
at util/parse-events.c:498
#3 0x00000000004bb699 in parse_events_add_tracepoint (list=0x19a5d20, idx=0x7fffffffb8c0, sys=0x19b1370 "sched", event=0x19a5d00 "sched_switch", err=0x0, head_config=0x0)
at util/parse-events.c:936
#4 0x00000000004f6eda in parse_events_parse (_data=0x7fffffffb8b0, scanner=0x19a49d0) at util/parse-events.y:391
#5 0x00000000004bc8e5 in parse_events__scanner (str=0x663ff2 "sched:sched_switch", data=0x7fffffffb8b0, start_token=258) at util/parse-events.c:1361
#6 0x00000000004bca57 in parse_events (evlist=0x19a5220, str=0x663ff2 "sched:sched_switch", err=0x0) at util/parse-events.c:1401
#7 0x0000000000518d5f in perf_evlist__can_select_event (evlist=0x19a3b90, str=0x663ff2 "sched:sched_switch") at util/record.c:253
#8 0x0000000000553c42 in intel_pt_track_switches (evlist=0x19a3b90) at arch/x86/util/intel-pt.c:364
#9 0x00000000005549d1 in intel_pt_recording_options (itr=0x19a2c40, evlist=0x19a3b90, opts=0x8edf68 <record+232>) at arch/x86/util/intel-pt.c:664
#10 0x000000000051e076 in auxtrace_record__options (itr=0x19a2c40, evlist=0x19a3b90, opts=0x8edf68 <record+232>) at util/auxtrace.c:539
#11 0x0000000000433368 in cmd_record (argc=1, argv=0x7fffffffde60, prefix=0x0) at builtin-record.c:1264
#12 0x000000000049bec2 in run_builtin (p=0x8fa2a8 <commands+168>, argc=5, argv=0x7fffffffde60) at perf.c:390
#13 0x000000000049c12a in handle_internal_command (argc=5, argv=0x7fffffffde60) at perf.c:451
#14 0x000000000049c278 in run_argv (argcp=0x7fffffffdcbc, argv=0x7fffffffdcb0) at perf.c:495
#15 0x000000000049c60a in main (argc=5, argv=0x7fffffffde60) at perf.c:618
(gdb)
Intel PT attempts to find the sched:sched_switch tracepoint but that seg
faults if tracefs is not readable, because the error reporting structure
is null, as errors are not reported when automatically adding
tracepoints. Fix by checking before using.
Committer note:
This doesn't take place in a kernel that supports
perf_event_attr.context_switch, that is the default way that will be
used for tracking context switches, only in older kernels, like 4.2, in
a machine with Intel PT (e.g. Broadwell) for non-priviledged users.
Further info from a similar patch by Wang:
The error is in tracepoint_error: it assumes the 'e' parameter is valid.
However, there are many situation a parse_event() can be called without
parse_events_error. See result of
$ grep 'parse_events(.*NULL)' ./tools/perf/ -r'
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Tong Zhang <ztong@vt.edu>
Fixes: 196581717d85 ("perf tools: Enhance parsing events tracepoint error output")
Link: http://lkml.kernel.org/r/1453809921-24596-2-git-send-email-adrian.hunter@intel.com
machines
commit 32abc2ede536aae52978d6c0a8944eb1df14f460 upstream.
When a long value is read on 32 bit machines for 64 bit output, the
parsing needs to change "%lu" into "%llu", as the value is read
natively.
Unfortunately, if "%llu" is already there, the code will add another "l"
to it and fail to parse it properly.
Link: http://lkml.kernel.org/r/20151116172516.4b79b109@gandalf.local.home
Pull perf fixes from Ingo Molnar:
"Two core subsystem fixes, plus a handful of tooling fixes"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf: Fix race in swevent hash
perf: Fix race in perf_event_exec()
perf list: Robustify event printing routine
perf list: Add support for PERF_COUNT_SW_BPF_OUT
perf hists browser: Fix segfault if use symbol filter in cmdline
perf hists browser: Reset selection when refresh
perf hists browser: Add NULL pointer check to prevent crash
perf buildid-list: Fix return value of perf buildid-list -k
perf buildid-list: Show running kernel build id fix
When a43eec304259 ("bpf: introduce bpf_perf_event_output() helper") added
PERF_COUNT_SW_BPF_OUTPUT we ended up with a new entry in the event_symbols_sw
array that wasn't initialized, thus set to NULL, fix print_symbol_events()
to check for that case so that we don't crash if this happens again.
(gdb) bt
#0 __match_glob (ignore_space=false, pat=<optimized out>, str=<optimized out>) at util/string.c:198
#1 strglobmatch (str=<optimized out>, pat=pat@entry=0x7fffffffe61d "stall") at util/string.c:252
#2 0x00000000004993a5 in print_symbol_events (type=1, syms=0x872880 <event_symbols_sw+160>, max=11, name_only=false, event_glob=0x7fffffffe61d "stall")
at util/parse-events.c:1615
#3 print_events (event_glob=event_glob@entry=0x7fffffffe61d "stall", name_only=false) at util/parse-events.c:1675
#4 0x000000000042c79e in cmd_list (argc=1, argv=0x7fffffffe390, prefix=<optimized out>) at builtin-list.c:68
#5 0x00000000004788a5 in run_builtin (p=p@entry=0x871758 <commands+120>, argc=argc@entry=2, argv=argv@entry=0x7fffffffe390) at perf.c:370
#6 0x0000000000420ab0 in handle_internal_command (argv=0x7fffffffe390, argc=2) at perf.c:429
#7 run_argv (argv=0x7fffffffe110, argcp=0x7fffffffe11c) at perf.c:473
#8 main (argc=2, argv=0x7fffffffe390) at perf.c:588
(gdb) p event_symbols_sw[PERF_COUNT_SW_BPF_OUTPUT]
$4 = {symbol = 0x0, alias = 0x0}
(gdb)
A patch to robustify perf to not segfault when the next counter gets added in
the kernel will follow this one.
Reported-by: Ingo Molnar <mingo@kernel.org>
Link: http://lkml.kernel.org/n/tip-57wysblcjfrseb0zg5u7ek10@git.kernel.org
When PERF_COUNT_SW_BPF_OUTPUT was added to the kernel we should've
added it to tools/perf, where it is used just to list events.
This ended up causing a segfault in commands like "perf list stall".
Fix it by adding that new software counter.
added in the kernel will follow this one.
Link: http://lkml.kernel.org/n/tip-uya354upi3eprsey6mi5962d@git.kernel.org
commit cf561f0d2eb74574ad9985a2feab134267a9d298 ("virtio: introduce
virtio_is_little_endian() helper") changed byteswap logic to
skip feature bit checks for LE platforms, but didn't
update tools/virtio, so vring_bench started failing.
Update the copy under tools/virtio/ (TODO: find a way to avoid this code
duplication).
Cc: Greg Kurz <gkurz@linux.vnet.ibm.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Makes them more generally available.
If feed perf a symbol filter in cmdline and the result is empty,
pressing 'Enter' in the hist browser causes crash:
# ./perf report perf.data <-- Common mistake for beginners
Then press 'Enter':
perf: Segmentation fault
-------- backtrace --------
/home/wangnan/perf[0x53e578]
/lib64/libc.so.6(+0x3545f)[0x7f76bafe045f]
/home/wangnan/perf[0x539dd4]
/home/wangnan/perf(perf_evlist__tui_browse_hists+0x96)[0x53d216]
/home/wangnan/perf(cmd_report+0x1b9f)[0x442c7f]
/home/wangnan/perf[0x47efa2]
/home/wangnan/perf(main+0x5f5)[0x432fa5]
/lib64/libc.so.6(__libc_start_main+0xf4)[0x7f76bafccbd4]
/home/wangnan/perf[0x4330d4]
This is because 'perf.data' is interpreted as a symbol filter, and the
result is empty, so selection is empty. However,
hist_browser__toggle_fold() forgets to check it.
This patch simply return false when selection is NULL.
Link: http://lkml.kernel.org/r/1449455746-41952-2-git-send-email-wangnan0@huawei.com
With the following steps:
Step 1: perf report
Step 2: Use UP/DOWN to select an entry, don't press 'ENTER'
Step 3: Use '/' to filter symbols, use a filter which returns
empty result
Step 4: Press 'ENTER'
We see that, even if we have filtered all the symbols (and the main
interface is empty), pressing 'ENTER' still selects one symbol. This
behavior surprises the user.
This patch resets browser->{he_,}selection in hist_browser__refresh()
and lets it choose default selection. In this case
browser->{he_,}selection keeps NULL so user won't see annotation item in
menu.
Link: http://lkml.kernel.org/r/1449455746-41952-4-git-send-email-wangnan0@huawei.com
Before this patch we can trigger a segfault by following steps:
Step 0: Use 'perf record' to generate a perf.data without callchain
Step 1: perf report
empty result
Step 4: Press 'ENTER' (notice here that the old selection is still
there. This is another problem)
Step 5: Press 'ENTER' to annotate that symbol
Step 6: Press 'LEFT' to go out.
Result: segfault:
/home/wangnan/perf[0x53e568]
/lib64/libc.so.6(+0x3545f)[0x7fba75d3245f]
/home/wangnan/perf[0x537516]
/home/wangnan/perf[0x533fef]
/home/wangnan/perf[0x53b347]
/home/wangnan/perf(perf_evlist__tui_browse_hists+0x96)[0x53d206]
/lib64/libc.so.6(__libc_start_main+0xf4)[0x7fba75d1ebd4]
This is because in this case 'nd' could be NULL in
ui_browser__hists_seek(), but that function never checks it.
This patch adds checker for potential NULL pointer in that function.
After this patch the above steps won't segfault.
Link: http://lkml.kernel.org/r/1449455746-41952-3-git-send-email-wangnan0@huawei.com
The buildid string length is returned by perf buildid-list -k command.
Since a non-zero return value means an error, perf buildid-list -k cmd
should return 0 when successful instead.
Before:
# perf buildid-list -k
39356d74e96e02346fe0ec1f3f162b6c522bac62
# echo $?
41
After:
# echo $?
0
Signed-off-by: Michael Petlan <mpetlan@redhat.com>
Fixes: 0b5a7935f3b5 ("perf buildid: Introduce sysfs/filename__sprintf_build_id")
LPU-Reference: 1449080871.24573.145.camel@redhat.com
The --kernel option of perf buildid-list tool should show the running
kernel buildid. The functionality has been lost during other changes of
the related code.
The build_id__sprintf() function should return length of the build-id
string, but it was the length of the build-id raw data instead. Due to
that, some return value checking caused that the final string was not
printed out.
With this patch the build_id__sprintf() returns the correct value, so
the --kernel option works again.
Before:
# perf buildid-list --kernel
After:
972c1edab5bdc06cc224af45d510af662a3c6972
LPU-Reference: 1448632089.24573.114.camel@redhat.com
When support for _FIT was added, the code presumed that the data
returned by the _FIT method is identical to the NFIT table, which
starts with an acpi_table_header. However, the _FIT is defined
to return a data in the format of a series of NFIT type structure
entries and as a method, has an acpi_object header rather tahn
To address the differences, explicitly save the acpi_table_header
from the NFIT, since it is accessible through /sys, and change
the nfit pointer in the acpi_desc structure to point to the
table entries rather than the headers.
Reported-by: Jeff Moyer (jmoyer@redhat.com>
Signed-off-by: Linda Knippers <linda.knippers@hpe.com>
Acked-by: Vishal Verma <vishal.l.verma@intel.com>
[vishal: fix up unit test for new header assumptions]
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest
Pull kselftest fixes from Shuah Khan:
"This update consists of one minor documentation fix and a fix to an
existing test"
* tag 'linux-kselftest-4.4-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest:
selftests/seccomp: Get page size from sysconf
tools:testing/selftests: fix typo in futex/README
Pull perf tool fixes from Thomas Gleixner:
"A couple of fixes for perf tools:
- Build system updates
- Plug a memory leak in an error path of perf probe
- Tear down probes correctly when adding fails
- Fixes to the perf symbol handling
- Fix ordering of event processing in buildid-list
- Fix per DSO filtering in the histogram browser"
perf probe: Clear probe_trace_event when add_probe_trace_event() fails
perf probe: Fix memory leaking on failure by clearing all probe_trace_events
perf inject: Also re-pipe lost_samples event
perf buildid-list: Requires ordered events
perf symbols: Fix dso lookup by long name and missing buildids
perf symbols: Allow forcing reading of non-root owned files by root
perf hists browser: The dso can be obtained from popup_action->ms.map->dso
perf hists browser: Fix 'd' hotkey action to filter by DSO
perf symbols: Rebuild rbtree when adjusting symbols for kcore
tools: Add a "make all" rule
tools: Actually install tmon in the install rule
PageIdle is exported in include/uapi/linux/kernel-page-flags.h, so let's
make page-types.c tool handle it.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com>
Pull more power management and ACPI updates from Rafael Wysocki:
"These are mostly fixes and cleanups (ACPI core, PM core, cpufreq, ACPI
EC driver, device properties) including three reverts of recent
intel_pstate driver commits due to a regression introduced by one of
them plus support for Atom Airmont cores in intel_pstate (which really
boils down to adding new frequency tables for Airmont) and additional
turbostat updates.
Specifics:
- Revert three recent intel_pstate driver commits one of which
introduced a regression and the remaining two depend on the
problematic one (Rafael Wysocki).
- Fix breakage related to the recently introduced ACPI _CCA object
support in the PCI DMA setup code (Suravee Suthikulpanit).
- Fix up the recently introduced ACPI CPPC support to only use the
hardware-reduced version of the PCCT structure as the only
architecture to support it (ARM64) will only use hardware-reduced
ACPI anyway (Ashwin Chaugule).
- Fix a cpufreq mediatek driver build problem (Arnd Bergmann).
- Fix the SMBus transaction handling implementation in the ACPI core
to avoid re-entrant calls to wait_event_timeout() which makes
intermittent boot stalls related to the Smart Battery Subsystem
initialization go away and revert a workaround of another problem
with the same underlying root cause (Chris Bainbridge).
- Fix the generic wakeup interrupts framework to avoid using invalid
IRQ numbers (Dmitry Torokhov).
- Remove a redundant check from the ACPI EC driver (Markus Elfring).
- Modify the intel_pstate driver so it can support more Atom flavors
than just one (Baytrail) and add support for Atom Airmont cores
(which require new freqnency tables) to it (Philippe Longepe).
- Clean up MSR-related symbols in turbostat (Len Brown)"
* tag 'pm+acpi-4.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm:
PCI: Fix OF logic in pci_dma_configure()
Revert "Documentation: kernel_parameters for Intel P state driver"
cpufreq: mediatek: fix build error
cpufreq: intel_pstate: Add separate support for Airmont cores
cpufreq: intel_pstate: Replace BYT with ATOM
Revert "cpufreq: intel_pstate: Use ACPI perf configuration"
Revert "cpufreq: intel_pstate: Avoid calculation for max/min"
ACPI-EC: Drop unnecessary check made before calling acpi_ec_delete_query()
Revert "ACPI / SBS: Add 5 us delay to fix SBS hangs on MacBook"
ACPI / SMBus: Fix boot stalls / high CPU caused by reentrant code
PM / wakeirq: check that wake IRQ is valid before accepting it
ACPI / CPPC: Use h/w reduced version of the PCCT structure
x86: remove unused definition of MSR_NHM_PLATFORM_INFO
tools/power turbostat: use new name for MSR_PLATFORM_INFO
The commit fd88d16c58c2 ("selftests/seccomp: Be more precise with
syscall arguments.") use PAGE_SIZE directly which lead to build
failure on arm64.
Replace it with generic interface(sysconf(_SC_PAGESIZE)) to fix this
failure.
Build and test successful on x86_64 and arm64.
Signed-off-by: Bamvor Jian Zhang <bamvor.zhangjian@linaro.org>
Tested-by: Michael Ellerman <mpe@ellerman.id.au>
