This renames CONFIG_KAISER to CONFIG_PAGE_TABLE_ISOLATION.
Added "nokaiser" boot option: an early param like "noinvpcid".
Most places now check int kaiser_enabled (#defined 0 when not
CONFIG_KAISER) instead of #ifdef CONFIG_KAISER; but entry_64.S
and entry_64_compat.S are using the ALTERNATIVE technique, which
patches in the preferred instructions at runtime. That technique
is tied to x86 cpu features, so X86_FEATURE_KAISER is fabricated.
Prior to "nokaiser", Kaiser #defined _PAGE_GLOBAL 0: revert that,
but be careful with both _PAGE_GLOBAL and CR4.PGE: setting them when
nokaiser like when !CONFIG_KAISER, but not setting either when kaiser -
neither matters on its own, but it's hard to be sure that _PAGE_GLOBAL
won't get set in some obscure corner, or something add PGE into CR4.
By omitting _PAGE_GLOBAL from __supported_pte_mask when kaiser_enabled,
all page table setup which uses pte_pfn() masks it out of the ptes.
It's slightly shameful that the same declaration versus definition of
kaiser_enabled appears in not one, not two, but in three header files
(asm/kaiser.h, asm/pgtable.h, asm/tlbflush.h). I felt safer that way,
than with #including any of those in any of the others; and did not
feel it worth an asm/kaiser_enabled.h - kernel/cpu/common.c includes
them all, so we shall hear about it if they get out of synch.
Cleanups while in the area: removed the silly #ifdef CONFIG_KAISER
from kaiser.c; removed the unused native_get_normal_pgd(); removed
the spurious reg clutter from SWITCH_*_CR3 macro stubs; corrected some
comments. But more interestingly, set CR4.PSE in secondary_startup_64:
the manual is clear that it does not matter whether it's 0 or 1 when
4-level-pts are enabled, but I was distracted to find cr4 different on
BSP and auxiliaries - BSP alone was adding PSE, in probe_page_size_mask().
Acked-by: Jiri Kosina <jkosina@suse.cz>
commit 544c4605acc5ae4afe7dd5914147947db182f2fb upstream.
usbip bind writes commands followed by random string when writing to
match_busid attribute in sysfs, caused by using full variable size
instead of string length.
Signed-off-by: Juan Zea <juan.zea@qindel.com>
Acked-by: Shuah Khan <shuahkh@osg.samsung.com>
When building objtool, we get the warning:
warning: objtool: x86 instruction decoder differs from kernel
That's due to commit 2816c0455cea088f07a210f8a00701a82a78aa9c which was
commit 12a78d43de767eaf8fb272facb7a7b6f2dc6a9df upstream that modified
arch/x86/lib/x86-opcode-map.txt without also updating the objtool copy.
The objtool copy was updated in a much larger patch upstream, but we
don't need all of that here, so just update the single file.
If this gets too annoying, I'll just end up doing what we did for 4.14
and backport the whole series to keep this from happening again, but as
this seems to be rare in the 4.9-stable series, this single patch should
be fine.
Cc: Masami Hiramatsu <mhiramat@kernel.org>
[ Upstream commit e7ede72a6d40cb3a30c087142d79381ca8a31dab ]
The current symbols__fixup_end() heuristic for the last entry in the rb
tree is suboptimal as it leads to not being able to recognize the symbol
in the call graph in a couple of corner cases, for example:
i) If the symbol has a start address (f.e. exposed via kallsyms)
that is at a page boundary, then the roundup(curr->start, 4096)
for the last entry will result in curr->start == curr->end with
a symbol length of zero.
ii) If the symbol has a start address that is shortly before a page
boundary, then also here, curr->end - curr->start will just be
very few bytes, where it's unrealistic that we could perform a
match against.
Instead, change the heuristic to roundup(curr->start, 4096) + 4096, so
that we can catch such corner cases and have a better chance to find
that specific symbol. It's still just best effort as the real end of the
symbol is unknown to us (and could even be at a larger offset than the
current range), but better than the current situation.
Alexei reported that he recently run into case i) with a JITed eBPF
program (these are all page aligned) as the last symbol which wasn't
properly shown in the call graph (while other eBPF program symbols in
the rb tree were displayed correctly). Since this is a generic issue,
lets try to improve the heuristic a bit.
Reported-and-Tested-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Fixes: 2e538c4a1847 ("perf tools: Improve kernel/modules symbol lookup")
Link: http://lkml.kernel.org/r/bb5c80d27743be6f12afc68405f1956a330e1bc9.1489614365.git.daniel@iogearbox.net
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 46aa6a302b53f543f8e8b8e1714dc5e449ad36a6 ]
linux/tools/testing/selftests/vm $ make
gcc -Wall -I ../../../../usr/include compaction_test.c -lrt -o /compaction_test
/usr/lib/gcc/x86_64-pc-linux-gnu/4.9.4/../../../../x86_64-pc-linux-gnu/bin/ld: cannot open output file /compaction_test: Permission denied
collect2: error: ld returned 1 exit status
make: *** [../lib.mk:54: /compaction_test] Error 1
Since commit a8ba798bc8ec ("selftests: enable O and KBUILD_OUTPUT")
selftests/vm build fails if run from the "selftests/vm" directory, but
it works in the selftests/ directory. It's quicker to be able to do a
local vm-only build after a tree wipe and this patch allows for it
again.
Link: http://lkml.kernel.org/r/20170302173738.18994-4-aarcange@redhat.com
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
[ Upstream commit a6400120d042397675fcf694060779d21e9e762d ]
The MPX hardware data structurse are defined in a weird way: they define
their size in bytes and then union that with the type with which we want
to access them.
Yes, this is weird, but it does work. But, new GCC's complain that we
are accessing the array out of bounds. Just make it a zero-sized array
so gcc will stop complaining. There was not really a bug here.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/20171111001229.58A7933D@viggo.jf.intel.com
[ Upstream commit a6d8a21596df041f36f4c2ccc260c459e3e851f1 ]
Tests under alignment subdirectory are skipped when executed on previous
generation hardware, but harness still marks them as failed.
test: test_copy_unaligned
tags: git_version:unknown
[SKIP] Test skipped on line 26
skip: test_copy_unaligned
selftests: copy_unaligned [FAIL]
The MAGIC_SKIP_RETURN_VALUE value assigned to rc variable is retained till
the program exit which causes the test to be marked as failed.
This patch resets the value before returning to the main() routine.
With this patch the test o/p is as follows:
selftests: copy_unaligned [PASS]
Signed-off-by: Sachin Sant <sachinp@linux.vnet.ibm.com>
[ Upstream commit 2a4d0c627f5374f365a873dea4e10ae0bb437680 ]
Kernel erases R8..R11 registers prior returning to userspace
from int80:
https://lkml.org/lkml/2009/10/1/164
GCC can reuse these registers and doesn't expect them to change
during syscall invocation. I met this kind of bug in CRIU once
GCC 6.1 and CLANG stored local variables in those registers
and the kernel zerofied them during syscall:
https://github.com/xemul/criu/commit/990d33f1a1cdd17bca6c2eb059ab3be2564f7fa2
By that reason I suggest to add those registers to clobbers
in selftests. Also, as noted by Andy - removed unneeded clobber
for flags in INT $0x80 inline asm.
Signed-off-by: Dmitry Safonov <dsafonov@virtuozzo.com>
Acked-by: Andy Lutomirski <luto@kernel.org>
Cc: 0x7f454c46@gmail.com
Cc: Borislav Petkov <bp@suse.de>
Cc: Shuah Khan <shuah@kernel.org>
Cc: linux-kselftest@vger.kernel.org
Link: http://lkml.kernel.org/r/20170213101336.20486-1-dsafonov@virtuozzo.com
commit 297d6b6e56c2977fc504c61bbeeaa21296923f89 upstream.
While reading in more than one block (50) of KVP records, the allocation
goes per block, but the reads used the total number of allocated records
(without resetting the pointer/stream). This causes the records buffer to
overrun when the refresh reads more than one block over the previous
capacity (e.g. reading more than 100 KVP records whereas the in-memory
database was empty before).
Fix this by reading the correct number of KVP records from file each time.
Signed-off-by: Paul Meyer <Paul.Meyer@microsoft.com>
Signed-off-by: Long Li <longli@microsoft.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
[ Upstream commit 6ae8eefc6c8fe050f057781b70a83262eb0a61ee ]
LIST_POISON[12] are used to initialize list_head and hlist_node
pointers, and do void pointer arithmetic, which C++ doesn't like, so, to
avoid drifting from the kernel by introducing some HLIST_POISON to do
away with void pointer math, just make those poisoned pointers be NULL
when building it with a C++ compiler.
Noticed with:
$ make LLVM_CONFIG=/usr/bin/llvm-config-3.9 LIBCLANGLLVM=1
CXX util/c++/clang.o
CXX util/c++/clang-test.o
In file included from /home/lizj/linux/tools/include/linux/list.h:5:0,
from /home/lizj/linux/tools/perf/util/namespaces.h:13,
from /home/lizj/linux/tools/perf/util/util.h:15,
from /home/lizj/linux/tools/perf/util/util-cxx.h:20,
from util/c++/clang-c.h:5,
from util/c++/clang-test.cpp:2:
/home/lizj/linux/tools/include/linux/list.h: In function ‘void list_del(list_head*)’:
/home/lizj/linux/tools/include/linux/poison.h:14:31: error: pointer of type ‘void *’ used in arithmetic [-Werror=pointer-arith]
# define POISON_POINTER_DELTA 0
/home/lizj/linux/tools/include/linux/poison.h:22:41: note: in expansion of macro ‘POISON_POINTER_DELTA’
#define LIST_POISON1 ((void *) 0x100 + POISON_POINTER_DELTA)
/home/lizj/linux/tools/include/linux/list.h:107:16: note: in expansion of macro ‘LIST_POISON1’
entry->next = LIST_POISON1;
In file included from /home/lizj/linux/tools/perf/util/namespaces.h:13:0,
/home/lizj/linux/tools/include/linux/list.h:107:14: error: invalid conversion from ‘void*’ to ‘list_head*’ [-fpermissive]
Reported-by: Li Zhijian <lizhijian@cn.fujitsu.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Philip Li <philip.li@intel.com>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-m5ei2o0mjshucbr28baf5lqz@git.kernel.org
[ Upstream commit 22905582f6dd4bbd0c370fe5732c607452010c04 ]
Command perf test -v 16 (Setup struct perf_event_attr test) always
reports success even if the test case fails. It works correctly if you
also specify -F (for don't fork).
root@s35lp76 perf]# ./perf test -v 16
15: Setup struct perf_event_attr :
--- start ---
running './tests/attr/test-record-no-delay'
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.002 MB /tmp/tmp4E1h7R/perf.data
(1 samples) ]
expected task=0, got 1
expected precise_ip=0, got 3
expected wakeup_events=1, got 0
FAILED './tests/attr/test-record-no-delay' - match failure
test child finished with 0
---- end ----
Setup struct perf_event_attr: Ok
The reason for the wrong error reporting is the return value of the
system() library call. It is called in run_dir() file tests/attr.c and
returns the exit status, in above case 0xff00.
This value is given as parameter to the exit() function which can only
handle values 0-0xff.
The child process terminates with exit value of 0 and the parent does
not detect any error.
This patch corrects the error reporting and prints the correct test
result.
Signed-off-by: Thomas-Mich Richter <tmricht@linux.vnet.ibm.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Cc: Thomas-Mich Richter <tmricht@linux.vnet.ibm.com>
LPU-Reference: 20170913081209.39570-2-tmricht@linux.vnet.ibm.com
Link: http://lkml.kernel.org/n/tip-rdube6rfcjsr1nzue72c7lqn@git.kernel.org
[ Upstream commit c15562c0dcb2c7f26e891923b784cf1926b8c833 ]
usbip_host_driver.h now depends on several additional headers, which
need to be installed along with it.
Fixes: 021aed845303 ("staging: usbip: userspace: migrate usbip_host_driver ...")
Fixes: 3391ba0e2792 ("usbip: tools: Extract generic code to be shared with ...")
[ Upstream commit fec8f5ae1715a01c72ad52cb2ecd8aacaf142302 ]
We weren't testing the .limit and .limit_in_pages fields very well.
Add more tests.
This addition seems to trigger the "bits 16:19 are undefined" issue
that was fixed in an earlier patch. I think that, at least on my
CPU, the high nibble of the limit ends in LAR bits 16:19.
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Borislav Petkov <bpetkov@suse.de>
Link: http://lkml.kernel.org/r/5601c15ea9b3113d288953fd2838b18bedf6bc67.1509794321.git.luto@kernel.org
commit afb999cdef69148f366839e74470d8f5375ba5f1 upstream.
Some distributions (Debian, OpenSUSE) have a udev rule in place to cancel
all fallback mechanism uevents immediately. This would obviously
make it hard to test against the fallback mechanism test interface,
so we need to check for this.
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 880444e214cfd293a2e8cc4bd3505f7ffa6ce33a upstream.
Error that we expect should not be spilled to stdout.
Without this we get:
./fw_filesystem.sh: line 58: printf: write error: Invalid argument
./fw_filesystem.sh: line 63: printf: write error: No such device
./fw_filesystem.sh: line 69: echo: write error: No such file or directory
./fw_filesystem.sh: filesystem loading works
./fw_filesystem.sh: async filesystem loading works
With it:
[ Upstream commit 75fc5ae5cc53fff71041ecadeb3354a2b4c9fe42 ]
Signed-off-by: Taeung Song <treeze.taeung@gmail.com>
Link: http://lkml.kernel.org/r/1485952447-7013-2-git-send-email-treeze.taeung@gmail.com
[ Upstream commit 22048c5485503749754b3b5daf9d99ef89fcacdc ]
turbostat displays a GFXMHz column, which comes from reading
/sys/class/graphics/fb0/device/drm/card0/gt_cur_freq_mhz
But GFXMHz was not changing, even when a manual
cat /sys/class/graphics/fb0/device/drm/card0/gt_cur_freq_mhz
showed a new value.
It turns out that a rewind() on the open file is not sufficient,
fflush() (or a close/open) is needed to read fresh values.
Reported-by: Yaroslav Isakov <yaroslav.isakov@gmail.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit 10859f3855db4c6f10dc7974ff4b3a292f3de8e0 upstream.
The 2.26 release of glibc changed how siginfo_t is defined, and the earlier
work-around to using the kernel definition are no longer needed. The old
way needs to stay around for a while, though.
Reported-by: Seth Forshee <seth.forshee@canonical.com>
Cc: Will Drewry <wad@chromium.org>
Tested-by: Seth Forshee <seth.forshee@canonical.com>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
commit 23d98c204386a98d9ef9f9e744f41443ece4929f upstream.
Those are funny cases. Make sure they work.
(Something is screwy with signal handling if a selector is 1, 2, or 3.
Anyone who wants to dive into that rabbit hole is welcome to do so.)
Cc: Chang Seok <chang.seok.bae@intel.com>
commit 0eb46345364d7318b11068c46e8a68d5dc10f65e upstream.
After the link tests, there is a race on one side of the test for
the link coming up. It's possible, in some cases, for the test script
to write to the 'peer_trans' files before the link has come up.
To fix this, we simply use the link event file to ensure both sides
see the link as up before continuning.
Signed-off-by: Logan Gunthorpe <logang@deltatee.com>
Acked-by: Allen Hubbe <Allen.Hubbe@dell.com>
Signed-off-by: Jon Mason <jdmason@kudzu.us>
Fixes: a9c59ef77458 ("ntb_test: Add a selftest script for the NTB subsystem")
commit 07b0b22b3e58824f70b9188d085d400069ca3240 upstream.
The code mistakenly prints the local perf results for the remote test
so the script reports identical results for both directions. Fix this
by ensuring we print the remote result.
commit eebc509b20881b92d62e317b2c073e57c5f200f0 upstream.
Fix --funcs (-F) option to show correct symbols for offline module.
Since previous perf-probe uses machine__findnew_module_map() for offline
module, even if user passes a module file (with full path) which is for
other architecture, perf-probe always tries to load symbol map for
current kernel module.
This fix uses dso__new_map() to load the map from given binary as same
as a map for user applications.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/148350053478.19001.15435255244512631545.stgit@devbox
Cc: Krister Johansen <kjlx@templeofstupid.com>
[ Upstream commit 7934c98a6e04028eb34c1293bfb5a6b0ab630b66 ]
Markus reported that perf segfaults when reading /sys/kernel/notes from
a kernel linked with GNU gold, due to what looks like a gold bug, so do
some bounds checking to avoid crashing in that case.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Report-Link: http://lkml.kernel.org/r/20161219161821.GA294@x4
Link: http://lkml.kernel.org/n/tip-ryhgs6a6jxvz207j2636w31c@git.kernel.org
[ Upstream commit 30a9c6444810429aa2b7cbfbd453ce339baaadbf ]
Those are binaries as well, so should be installed by:
make -C tools/perf install-bin'
too.
Cc: Daniel Bristot de Oliveira <bristot@redhat.com>
Link: http://lkml.kernel.org/n/tip-3841b37u05evxrs1igkyu6ks@git.kernel.org
[ Upstream commit 074859184d770824f4437dca716bdeb625ae8b1c ]
Currently, the sched:sched_switch tracepoint reports deadline tasks with
priority -1. But when reading the trace via perf script I've got the
following output:
# ./d & # (d is a deadline task, see [1])
# perf record -e sched:sched_switch -a sleep 1
# perf script
swapper 0 [000] 2146.962441: sched:sched_switch: swapper/0:0 [120] R ==> d:2593 [4294967295]
d 2593 [000] 2146.972472: sched:sched_switch: d:2593 [4294967295] R ==> g:2590 [4294967295]
The task d reports the wrong priority [4294967295]. This happens because
the "int prio" is stored in an unsigned long long val. Although it is
set as a %lld, as int is shorter than unsigned long long,
trace_seq_printf prints it as a positive number.
The fix is just to cast the val as an int, and print it as a %d,
as in the sched:sched_switch tracepoint's "format".
The output with the fix is:
# ./d &
# perf script
swapper 0 [000] 4306.374037: sched:sched_switch: swapper/0:0 [120] R ==> d:10941 [-1]
d 10941 [000] 4306.383823: sched:sched_switch: d:10941 [-1] R ==> swapper/0:0 [120]
[1] d.c
#include <stdio.h>
#include <unistd.h>
#include <sys/syscall.h>
#include <linux/types.h>
#include <linux/sched.h>
struct sched_attr {
__u32 size, sched_policy;
__u64 sched_flags;
__s32 sched_nice;
__u32 sched_priority;
__u64 sched_runtime, sched_deadline, sched_period;
int sched_setattr(pid_t pid, const struct sched_attr *attr, unsigned int flags)
return syscall(__NR_sched_setattr, pid, attr, flags);
int main(void)
struct sched_attr attr = {
.size = sizeof(attr),
.sched_policy = SCHED_DEADLINE, /* This creates a 10ms/30ms reservation */
.sched_runtime = 10 * 1000 * 1000,
.sched_period = attr.sched_deadline = 30 * 1000 * 1000,
if (sched_setattr(0, &attr, 0) < 0) {
perror("sched_setattr");
return -1;
for(;;);
Committer notes:
Got the program from the provided URL, http://bristot.me/lkml/d.c,
trimmed it and included in the cset log above, so that we have
everything needed to test it in one place.
Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/866ef75bcebf670ae91c6a96daa63597ba981f0d.1483443552.git.bristot@redhat.com
[ Upstream commit 1f2ed153b916c95a49a1ca9d7107738664224b7f ]
Since 'perf probe' supports cross-arch probes, it is possible to analyze
different arch kernel image which has different bits-per-long.
In that case, it fails to get the module name because it uses the
MOD_NAME_OFFSET macro based on the host machine bits-per-long, instead
of the target arch bits-per-long.
This fixes above issue by changing modname-offset based on the target
archs bit width. This is ok because linux kernel uses LP64 model on
64bit arch.
E.g. without this (on x86_64, and target module is arm32):
$ perf probe -m build-arm/fs/configfs/configfs.ko -D configfs_lookup
p:probe/configfs_lookup :configfs_lookup+0
^-Here is an empty module name.
With this fix, you can see correct module name:
p:probe/configfs_lookup configfs:configfs_lookup+0
Link: http://lkml.kernel.org/r/148337043836.6752.383495516397005695.stgit@devbox
target
commit 80f62589fa52f530cffc50e78c0b5a2ae572d61e upstream.
When the jump instruction is displayed at the row 0 in annotate view,
the arrow is broken. An example:
16.86 │ ┌──je 82
0.01 │ movsd (%rsp),%xmm0
│ movsd 0x8(%rsp),%xmm4
│ movsd 0x8(%rsp),%xmm1
│ movsd (%rsp),%xmm3
│ divsd %xmm4,%xmm0
│ divsd %xmm3,%xmm1
│ movsd (%rsp),%xmm2
│ addsd %xmm1,%xmm0
│ addsd %xmm2,%xmm0
│ movsd %xmm0,(%rsp)
│82: sub $0x1,%ebx
83.03 │ ↑ jne 38
│ add $0x10,%rsp
│ xor %eax,%eax
│ pop %rbx
│ ← retq
The patch increments the row number before checking with 0.
Signed-off-by: Yao Jin <yao.jin@linux.intel.com>
Cc: Kan Liang <kan.liang@intel.com>
Fixes: 944e1abed9e1 ("perf ui browser: Add method to draw up/down arrow line")
Link: http://lkml.kernel.org/r/1496901704-30275-1-git-send-email-yao.jin@linux.intel.com
commit 6a558f12dbe85437acbdec5e149ea07b5554eced upstream.
Sometimes a FUP packet is associated with a TSX transaction and a flag is
set to indicate that. Ensure that flag is cleared on any error condition
because at that point the decoder can no longer assume it is correct.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/1495786658-18063-9-git-send-email-adrian.hunter@intel.com
commit 622b7a47b843c78626f40c1d1aeef8483383fba2 upstream.
The decoder will try to use branch packets to find an IP to start decoding
or to recover from errors. Currently the FUP packet is used only in the
case of an overflow, however there is no reason for that to be a special
case. So just use FUP always when scanning for an IP.
Link: http://lkml.kernel.org/r/1495786658-18063-8-git-send-email-adrian.hunter@intel.com
commit f952eaceb089b691eba7c4e13686e742a8f26bf5 upstream.
Intel PT uses IP compression based on the last IP. For decoding purposes,
'last IP' is not updated when a branch target has been suppressed, which is
indicated by IPBytes == 0. IPBytes is stored in the packet 'count', so
ensure never to set 'last_ip' when packet 'count' is zero.
Link: http://lkml.kernel.org/r/1495786658-18063-7-git-send-email-adrian.hunter@intel.com
commit ee14ac0ef6827cd6f9a572cc83dd0191ea17812c upstream.
purposes, 'last IP' is considered to be reset to zero whenever there is
a synchronization packet (PSB). The decoder wasn't doing that, and was
treating the zero value to mean that there was no last IP, whereas
compression can be done against the zero value. Fix by setting last_ip
to zero when a PSB is received and keep track of have_last_ip.
Link: http://lkml.kernel.org/r/1495786658-18063-6-git-send-email-adrian.hunter@intel.com
commit ad7167a8cd174ba7d8c0d0ed8d8410521206d104 upstream.
A value of zero is used to indicate that there is no IP. Ensure the
value is zero when the state is INTEL_PT_STATE_NO_IP.
Link: http://lkml.kernel.org/r/1495786658-18063-5-git-send-email-adrian.hunter@intel.com
commit 12b7080609097753fd8198cc1daf589be3ec1cca upstream.
The return compression stack must be cleared whenever there is a PSB. Fix
one case where that was not happening.
Link: http://lkml.kernel.org/r/1495786658-18063-4-git-send-email-adrian.hunter@intel.com
commit 3f04d98e972b59706bd43d6cc75efac91f8fba50 upstream.
The decoder uses its current timestamp in samples. Usually that is a
timestamp that has already passed, but in some cases it is a timestamp
for a branch that the decoder is walking towards, and consequently
hasn't reached. Improve that situation by using the pkt_state to
determine when to use the current or previous timestamp.
Link: http://lkml.kernel.org/r/1495786658-18063-3-git-send-email-adrian.hunter@intel.com
commit 22c06892332d8916115525145b78e606e9cc6492 upstream.
Move decoder error setting into one condition.
Cc'ed to stable because later fixes depend on it.
Link: http://lkml.kernel.org/r/1495786658-18063-2-git-send-email-adrian.hunter@intel.com
commit 796a3bae2fba6810427efdb314a1c126c9490fb3 upstream.
test_execve does rather odd mount manipulations to safely create
temporary setuid and setgid executables that aren't visible to the
rest of the system. Those executables end up in the test's cwd, but
that cwd is MNT_DETACHed.
The core namespace code considers MNT_DETACHed trees to belong to no
mount namespace at all and, in general, MNT_DETACHed trees are only
barely function. This interacted with commit 380cf5ba6b0a ("fs:
Treat foreign mounts as nosuid") to cause all MNT_DETACHed trees to
act as though they're nosuid, breaking the test.
Fix it by just not detaching the tree. It's still in a private
mount namespace and is therefore still invisible to the rest of the
system (except via /proc, and the same nosuid logic will protect all
other programs on the system from believing in test_execve's setuid
bits).
While we're at it, fix some blatant whitespace problems.
Reported-by: Naresh Kamboju <naresh.kamboju@linaro.org>
Fixes: 380cf5ba6b0a ("fs: Treat foreign mounts as nosuid")
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
Cc: Greg KH <greg@kroah.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 98dcea0cfd04e083ac74137ceb9a632604740e2d upstream.
liblockdep has been broken since commit 75dd602a5198 ("lockdep: Fix
lock_chain::base size"), as that adds a check that MAX_LOCK_DEPTH is
within the range of lock_chain::depth and in liblockdep it is much
too large.
That should have resulted in a compiler error, but didn't because:
- the check uses ARRAY_SIZE(), which isn't yet defined in liblockdep
so is assumed to be an (undeclared) function
- putting a function call inside a BUILD_BUG_ON() expression quietly
turns it into some nonsense involving a variable-length array
It did produce a compiler warning, but I didn't notice because
liblockdep already produces too many warnings if -Wall is enabled
(which I'll fix shortly).
Even before that commit, which reduced lock_chain::depth from 8 bits
to 6, MAX_LOCK_DEPTH was too large.
Cc: a.p.zijlstra@chello.nl
Link: http://lkml.kernel.org/r/20170525130005.5947-3-alexander.levin@verizon.com
commit 3e96dac7c956089d3f23aca98c4dfca57b6aaf8a upstream.
Add error check codes on post processing and improve it for offline
probe events as:
- post processing fails if no matched symbol found in map(-ENOENT)
or strdup() failed(-ENOMEM).
- Even if the symbol name is the same, it updates symbol address
and offset.
Link: http://lkml.kernel.org/r/148411443738.9978.4617979132625405545.stgit@devbox
commit 8a937a25a7e3c19d5fb3f9d92f605cf5fda219d8 upstream.
Fix perf-probe to show probe definition on gcc generated symbols for
offline kernel (including cross-arch kernel image).
gcc sometimes optimizes functions and generate new symbols with suffixes
such as ".constprop.N" or ".isra.N" etc. Since those symbol names are
not recorded in DWARF, we have to find correct generated symbols from
offline ELF binary to probe on it (kallsyms doesn't correct it). For
online kernel or uprobes we don't need it because those are rebased on
_text, or a section relative address.
E.g. Without this:
$ perf probe -k build-arm/vmlinux -F __slab_alloc*
__slab_alloc.constprop.9
$ perf probe -k build-arm/vmlinux -D __slab_alloc
p:probe/__slab_alloc __slab_alloc+0
If you put above definition on target machine, it should fail
because there is no __slab_alloc in kallsyms.
With this fix, perf probe shows correct probe definition on
__slab_alloc.constprop.9:
p:probe/__slab_alloc __slab_alloc.constprop.9+0
Link: http://lkml.kernel.org/r/148350060434.19001.11864836288580083501.stgit@devbox
commit d7dd112ea5cacf91ae72c0714c3b911eb6016fea upstream.
Fix below compile error:
CC util/scripting-engines/trace-event-perl.o
In file included from /usr/lib/perl5/5.22.2/i686-linux/CORE/perl.h:5673:0,
from util/scripting-engines/trace-event-perl.c:31:
/usr/lib/perl5/5.22.2/i686-linux/CORE/inline.h: In function 'S__is_utf8_char_slow':
/usr/lib/perl5/5.22.2/i686-linux/CORE/inline.h:270:5: error: nested extern declaration of 'Perl___notused' [-Werror=nested-externs]
dTHX; /* The function called below requires thread context */
cc1: all warnings being treated as errors
After digging perl5 repository, I find out that we will meet this
compile error with perl from v5.21.1 to v5.25.4
Signed-off-by: Wang YanQing <udknight@gmail.com>
Link: http://lkml.kernel.org/r/20170212024655.GA15997@udknight
commit 8434a2ec13d5c8cb25716950bfbf7c9d7b64628a upstream.
In commit daeecbc0c431 ("perf tools: Add event_update event scale type"), the
handling of PERF_EVENT_UPDATE__SCALE cast struct event_update_event->data to a
pointer to event_update_event_scale, uses some field from this casted struct
and then ends up falling through to the handling of another event type,
PERF_EVENT_UPDATE__CPUS were it casts that ev->data to yet another type, oops,
fix it by inserting the missing break.
Noticed when building perf using gcc 7 on Fedora Rawhide:
util/header.c: In function 'perf_event__process_event_update':
util/header.c:3207:16: error: this statement may fall through [-Werror=implicit-fallthrough=]
evsel->scale = ev_scale->scale;
util/header.c:3208:2: note: here
case PERF_EVENT_UPDATE__CPUS:
This wasn't noticed because probably PERF_EVENT_UPDATE__CPUS comes after
PERF_EVENT_UPDATE__SCALE, so we would just create a bogus evsel->own_cpus when
processing a PERF_EVENT_UPDATE__SCALE to then leak it and create a new cpu map
with the correct data.
Fixes: daeecbc0c431 ("perf tools: Add event_update event scale type")
Link: http://lkml.kernel.org/n/tip-lukcf9hdj092ax2914ss95at@git.kernel.org
commit 3aff8ba0a4c9c9191bb788171a1c54778e1246a2 upstream.
Addressing this warning from gcc 7:
CC /tmp/build/perf/bench/numa.o
bench/numa.c: In function '__bench_numa':
bench/numa.c:1582:42: error: '%d' directive output may be truncated writing between 1 and 10 bytes into a region of size between 8 and 17 [-Werror=format-truncation=]
snprintf(tname, 32, "process%d:thread%d", p, t);
bench/numa.c:1582:25: note: directive argument in the range [0, 2147483647]
In file included from /usr/include/stdio.h:939:0,
from bench/../util/util.h:47,
from bench/../builtin.h:4,
from bench/numa.c:11:
/usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 17 and 35 bytes into a destination of size 32
return __builtin___snprintf_chk (__s, __n, __USE_FORTIFY_LEVEL - 1,
__bos (__s), __fmt, __va_arg_pack ());
Cc: Petr Holasek <pholasek@redhat.com>
Link: http://lkml.kernel.org/n/tip-twa37vsfqcie5gwpqwnjuuz9@git.kernel.org
commit 2e2bbc039fad9eabad6c4c1a473c8b2554cdd2d4 upstream.
Addressing a few cases spotted by a new warning in gcc 7:
tests/parse-events.c: In function 'test_pmu_events':
tests/parse-events.c:1790:39: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 90 [-Werror=format-truncation=]
snprintf(name, MAX_NAME, "cpu/event=%s/u", ent->d_name);
from /git/linux/tools/perf/util/map.h:9,
from /git/linux/tools/perf/util/symbol.h:7,
from /git/linux/tools/perf/util/evsel.h:10,
from tests/parse-events.c:3:
/usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 13 and 268 bytes into a destination of size 100
tests/parse-events.c:1798:29: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 100 [-Werror=format-truncation=]
snprintf(name, MAX_NAME, "%s:u,cpu/event=%s/u", ent->d_name, ent->d_name);
Fixes: 945aea220bb8 ("perf tests: Move test objects into 'tests' directory")
Link: http://lkml.kernel.org/n/tip-ty4q2p8zp1dp3mskvubxskm5@git.kernel.org
commit 7ea6856d6f5629d742edc23b8b76e6263371ef45 upstream.
To address new warnings emmited by gcc 7, e.g.::
CC /tmp/build/perf/util/intel-pt-decoder/intel-pt-pkt-decoder.o
CC /tmp/build/perf/tests/parse-events.o
util/intel-pt-decoder/intel-pt-pkt-decoder.c: In function 'intel_pt_pkt_desc':
util/intel-pt-decoder/intel-pt-pkt-decoder.c:499:6: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (!(packet->count))
util/intel-pt-decoder/intel-pt-pkt-decoder.c:501:2: note: here
case INTEL_PT_CYC:
CC /tmp/build/perf/util/intel-pt-decoder/intel-pt-decoder.o
Acked-by: Andi Kleen <ak@linux.intel.com>
Link: http://lkml.kernel.org/n/tip-mf0hw789pu9x855us5l32c83@git.kernel.org
commit bdf23a9a190d7ecea092fd5c4aabb7d4bd0a9980 upstream.
The size of dirent->dt_name is NAME_MAX + 1, but the size for the 'path'
buffer is hard coded at 256, which may truncate it because we also
prepend "/proc/", so that all that into account and thank gcc 7 for this
warning:
/git/linux/tools/perf/util/thread_map.c: In function 'thread_map__new_by_uid':
/git/linux/tools/perf/util/thread_map.c:119:39: error: '%s' directive output may be truncated writing up to 255 bytes into a region of size 250 [-Werror=format-truncation=]
snprintf(path, sizeof(path), "/proc/%s", dirent->d_name);
from /git/linux/tools/perf/util/thread_map.c:5:
/usr/include/bits/stdio2.h:64:10: note: '__builtin___snprintf_chk' output between 7 and 262 bytes into a destination of size 256
Link: http://lkml.kernel.org/n/tip-csy0r8zrvz5efccgd4k12c82@git.kernel.org
commit 7b0214b702ad8e124e039a317beeebb3f020d125 upstream.
The implicit fall through case label here is intended, so let us inform
that to gcc >= 7:
CC /tmp/build/perf/builtin-top.o
builtin-top.c: In function 'display_thread':
builtin-top.c:644:7: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (errno == EINTR)
builtin-top.c:647:3: note: here
default:
Link: http://lkml.kernel.org/n/tip-lmcfnnyx9ic0m6j0aud98p4e@git.kernel.org
commit d64b721d27aef3fbeb16ecda9dd22ee34818ff70 upstream.
that to gcc >= 7:
util/strfilter.c: In function 'strfilter_node__sprint':
util/strfilter.c:270:6: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (len < 0)
util/strfilter.c:272:2: note: here
case '!':
Link: http://lkml.kernel.org/n/tip-z2dpywg7u8fim000hjfbpyfm@git.kernel.org
commit 94bdd5edb34e472980d1e18b4600d6fb92bd6b0a upstream.
that to gcc >= 7:
CC /tmp/build/perf/util/string.o
util/string.c: In function 'perf_atoll':
util/string.c:22:7: error: this statement may fall through [-Werror=implicit-fallthrough=]
if (*p)
util/string.c:24:3: note: here
case '\0':
Link: http://lkml.kernel.org/n/tip-0ophb30v9apkk6o95el0rqlq@git.kernel.org
commit b5bf1733d6a391c4e90ea8f8468d83023be74a2a upstream.
For cases where implicit fall through case labels are intended,
to let us inform that to gcc >= 7:
if (*p)
case '\0':
So we introduce:
#define __fallthrough __attribute__ ((fallthrough))
And use it in such cases.
Cc: William Cohen <wcohen@redhat.com>
Link: http://lkml.kernel.org/n/tip-qnpig0xfop4hwv6k4mv1wts5@git.kernel.org
