path: root/tools
2018-02-25tools build: Add tools tree support for 'make -s'Josh Poimboeuf
commit e572d0887137acfc53f18175522964ec19d88175 upstream. When doing a kernel build with 'make -s', everything is silenced except the objtool build. That's because the tools tree support for silent builds is some combination of missing and broken. Three changes are needed to fix it: - Makefile: propagate '-s' to the sub-make's MAKEFLAGS variable so the tools Makefiles can see it. - tools/scripts/Makefile.include: fix the tools Makefiles' ability to recognize '-s'. The MAKE_VERSION and MAKEFLAGS checks are copied from the top-level Makefile. This silences the "DESCEND objtool" message. - tools/build/Makefile.build: add support to the tools Build files for recognizing '-s'. Again the MAKE_VERSION and MAKEFLAGS checks are copied from the top-level Makefile. This silences all the object compile/link messages. Reported-and-Tested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Michal Marek <mmarek@suse.com> Link: http://lkml.kernel.org/r/e8967562ef640c3ae9a76da4ae0f4e47df737c34.1484799200.git.jpoimboe@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25perf bench numa: Fixup discontiguous/sparse numa nodesSatheesh Rajendran
[ Upstream commit 321a7c35c90cc834851ceda18a8ee18f1d032b92 ] Certain systems are designed to have sparse/discontiguous nodes. On such systems, 'perf bench numa' hangs, shows wrong number of nodes and shows values for non-existent nodes. Handle this by only taking nodes that are exposed by kernel to userspace. Signed-off-by: Satheesh Rajendran <sathnaga@linux.vnet.ibm.com> Reviewed-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1edbcd353c009e109e93d78f2f46381930c340fe.1511368645.git.sathnaga@linux.vnet.ibm.com Signed-off-by: Balamuruhan S <bala24@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-25perf top: Fix window dimensions change handlingJiri Olsa
[ Upstream commit 89d0aeab4252adc2a7ea693637dd21c588bfa2d1 ] The stdio perf top crashes when we change the terminal window size. The reason is that we assumed we get the perf_top pointer as a signal handler argument which is not the case. Changing the SIGWINCH handler logic to change global resize variable, which is checked in the main thread loop. Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Tested-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-ysuzwz77oev1ftgvdscn9bpu@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22selftests/x86/mpx: Fix incorrect bounds with old _sigfaultRui Wang
commit 961888b1d76d84efc66a8f5604b06ac12ac2f978 upstream. For distributions with old userspace header files, the _sigfault structure is different. mpx-mini-test fails with the following error: [root@Purley]# mpx-mini-test_64 tabletest XSAVE is supported by HW & OS XSAVE processor supported state mask: 0x2ff XSAVE OS supported state mask: 0x2ff BNDREGS: size: 64 user: 1 supervisor: 0 aligned: 0 BNDCSR: size: 64 user: 1 supervisor: 0 aligned: 0 starting mpx bounds table test ERROR: siginfo bounds do not match shadow bounds for register 0 Fix it by using the correct offset of _lower/_upper in _sigfault. RHEL needs this patch to work. Signed-off-by: Rui Wang <rui.y.wang@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: dave.hansen@linux.intel.com Fixes: e754aedc26ef ("x86/mpx, selftests: Add MPX self test") Link: http://lkml.kernel.org/r/1513586050-1641-1-git-send-email-rui.y.wang@intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22selftests/x86: Do not rely on "int $0x80" in single_step_syscall.cDominik Brodowski
commit 4105c69703cdeba76f384b901712c9397b04e9c2 upstream. On 64-bit builds, we should not rely on "int $0x80" working (it only does if CONFIG_IA32_EMULATION=y is enabled). To keep the "Set TF and check int80" test running on 64-bit installs with CONFIG_IA32_EMULATION=y enabled, build this test only if we can also build 32-bit binaries (which should be a good approximation for that). Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Dmitry Safonov <dsafonov@virtuozzo.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kselftest@vger.kernel.org Cc: shuah@kernel.org Link: http://lkml.kernel.org/r/20180211111013.16888-5-linux@dominikbrodowski.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22selftests/x86: Do not rely on "int $0x80" in test_mremap_vdso.cDominik Brodowski
commit 2cbc0d66de0480449c75636f55697c7ff3af61fc upstream. On 64-bit builds, we should not rely on "int $0x80" working (it only does if CONFIG_IA32_EMULATION=y is enabled). Without this patch, the move test may succeed, but the "int $0x80" causes a segfault, resulting in a false negative output of this self-test. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Andy Lutomirski <luto@kernel.org> Cc: Dmitry Safonov <dsafonov@virtuozzo.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kselftest@vger.kernel.org Cc: shuah@kernel.org Link: http://lkml.kernel.org/r/20180211111013.16888-4-linux@dominikbrodowski.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22selftests/x86/pkeys: Remove unused functionsIngo Molnar
commit ce676638fe7b284132a7d7d5e7e7ad81bab9947e upstream. This also gets rid of two build warnings: protection_keys.c: In function ‘dumpit’: protection_keys.c:419:3: warning: ignoring return value of ‘write’, declared with attribute warn_unused_result [-Wunused-result] write(1, buf, nr_read); ^~~~~~~~~~~~~~~~~~~~~~ Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-22kselftest: fix OOM in memory compaction testArnd Bergmann
commit 4c1baad223906943b595a887305f2e8124821dad upstream. Running the compaction_test sometimes results in out-of-memory failures. When I debugged this, it turned out that the code to reset the number of hugepages to the initial value is simply broken since we write into an open sysctl file descriptor multiple times without seeking back to the start. Adding the lseek here fixes the problem. Cc: stable@vger.kernel.org Reported-by: Naresh Kamboju <naresh.kamboju@linaro.org> Link: https://bugs.linaro.org/show_bug.cgi?id=3145 Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03usbip: list: don't list devices attached to vhci_hcdShuah Khan
commit ef824501f50846589f02173d73ce3fe6021a9d2a upstream. usbip host lists devices attached to vhci_hcd on the same server when user does attach over localhost or specifies the server as the remote. usbip attach -r localhost -b busid or usbip attach -r servername (or server IP) Fix it to check and not list devices that are attached to vhci_hcd. Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03usbip: prevent bind loops on devices attached to vhci_hcdShuah Khan
commit ef54cf0c600fb8f5737fb001a9e357edda1a1de8 upstream. usbip host binds to devices attached to vhci_hcd on the same server when user does attach over localhost or specifies the server as the remote. usbip attach -r localhost -b busid or usbip attach -r servername (or server IP) Unbind followed by bind works, however device is left in a bad state with accesses via the attached busid result in errors and system hangs during shutdown. Fix it to check and bail out if the device is already attached to vhci_hcd. Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03cpupower : Fix cpupower working when cpu0 is offlineAbhishek Goel
[ Upstream commit dbdc468f35ee827cab2753caa1c660bdb832243a ] cpuidle_monitor used to assume that cpu0 is always online which is not a valid assumption on POWER machines. This patch fixes this by getting the cpu on which the current thread is running, instead of always using cpu0 for monitoring which may not be online. Signed-off-by: Abhishek Goel <huntbag@linux.vnet.ibm.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03cpupowerutils: bench - Fix cpu online checkAbhishek Goel
[ Upstream commit 53d1cd6b125fb9d69303516a1179ebc3b72f797a ] cpupower_is_cpu_online was incorrectly checking for 0. This patch fixes this by checking for 1 when the cpu is online. Signed-off-by: Abhishek Goel <huntbag@linux.vnet.ibm.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-03tools/gpio: Fix build error with musl libcJoel Stanley
commit 1696784eb7b52b13b62d160c028ef2c2c981d4f2 upstream. The GPIO tools build fails when using a buildroot toolchain that uses musl as it's C library: arm-broomstick-linux-musleabi-gcc -Wp,-MD,./.gpio-event-mon.o.d \ -Wp,-MT,gpio-event-mon.o -O2 -Wall -g -D_GNU_SOURCE \ -Iinclude -D"BUILD_STR(s)=#s" -c -o gpio-event-mon.o gpio-event-mon.c gpio-event-mon.c:30:6: error: unknown type name ‘u_int32_t’; did you mean ‘uint32_t’? u_int32_t handleflags, ^~~~~~~~~ uint32_t The glibc headers installed on my laptop include sys/types.h in unistd.h, but it appears that musl does not. Fixes: 97f69747d8b1 ("tools/gpio: add the gpio-event-mon tool") Signed-off-by: Joel Stanley <joel@jms.id.au> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31usbip: Fix potential format overflow in userspace toolsJonathan Dieter
commit e5dfa3f902b9a642ae8c6997d57d7c41e384a90b upstream. The usbip userspace tools call sprintf()/snprintf() and don't check for the return value which can lead the paths to overflow, truncating the final file in the path. More urgently, GCC 7 now warns that these aren't checked with -Wformat-overflow, and with -Werror enabled in configure.ac, that makes these tools unbuildable. This patch fixes these problems by replacing sprintf() with snprintf() in one place and adding checks for the return value of snprintf(). Reviewed-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Jonathan Dieter <jdieter@lesbg.com> Acked-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31usbip: Fix implicit fallthrough warningJonathan Dieter
commit cfd6ed4537a9e938fa76facecd4b9cd65b6d1563 upstream. GCC 7 now warns when switch statements fall through implicitly, and with -Werror enabled in configure.ac, that makes these tools unbuildable. We fix this by notifying the compiler that this particular case statement is meant to fall through. Reviewed-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Jonathan Dieter <jdieter@lesbg.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-31usbip: prevent vhci_hcd driver from leaking a socket pointer addressShuah Khan
commit 2f2d0088eb93db5c649d2a5e34a3800a8a935fc5 upstream. When a client has a USB device attached over IP, the vhci_hcd driver is locally leaking a socket pointer address via the /sys/devices/platform/vhci_hcd/status file (world-readable) and in debug output when "usbip --debug port" is run. Fix it to not leak. The socket pointer address is not used at the moment and it was made visible as a convenient way to find IP address from socket pointer address by looking up /proc/net/{tcp,tcp6}. As this opens a security hole, the fix replaces socket pointer address with sockfd. Reported-by: Secunia Research <vuln@secunia.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23perf tools: Fix build with ARCH=x86_64Jiada Wang
commit 7a759cd8e8272ee18922838ee711219c7c796a31 upstream. With commit: 0a943cb10ce78 (tools build: Add HOSTARCH Makefile variable) when building for ARCH=x86_64, ARCH=x86_64 is passed to perf instead of ARCH=x86, so the perf build process searchs header files from tools/arch/x86_64/include, which doesn't exist. The following build failure is seen: In file included from util/event.c:2:0: tools/include/uapi/linux/mman.h:4:27: fatal error: uapi/asm/mman.h: No such file or directory compilation terminated. Fix this issue by using SRCARCH instead of ARCH in perf, just like the main kernel Makefile and tools/objtool's. Signed-off-by: Jiada Wang <jiada_wang@mentor.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Eugeniu Rosca <erosca@de.adit-jv.com> Cc: Jan Stancek <jstancek@redhat.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com> Cc: Rui Teng <rui.teng@linux.vnet.ibm.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Wang Nan <wangnan0@huawei.com> Fixes: 0a943cb10ce7 ("tools build: Add HOSTARCH Makefile variable") Link: http://lkml.kernel.org/r/1491793357-14977-2-git-send-email-jiada_wang@mentor.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Tuomas Tynkkynen <tuomas@tuxera.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-23objtool: Improve error message for bad file argumentJosh Poimboeuf
commit 385d11b152c4eb638eeb769edcb3249533bb9a00 upstream. If a nonexistent file is supplied to objtool, it complains with a non-helpful error: open: No such file or directory Improve it to: objtool: Can't open 'foo': No such file or directory Reported-by: Markus <M4rkusXXL@web.de> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/406a3d00a21225eee2819844048e17f68523ccf6.1516025651.git.jpoimboe@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17objtool: Fix retpoline support for pre-ORC objtoolJosh Poimboeuf
Objtool 1.0 (pre-ORC) produces the following warning when it encounters a retpoline: arch/x86/crypto/camellia-aesni-avx2-asm_64.o: warning: objtool: .altinstr_replacement+0xf: return instruction outside of a callable function That warning is meant to catch GCC bugs and missing ENTRY/ENDPROC annotations, neither of which are applicable to alternatives. Silence the warning for alternative instructions, just like objtool 2.0 already does. Reported-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17selftests/x86: Add test_vsyscallAndy Lutomirski
commit 352909b49ba0d74929b96af6dfbefc854ab6ebb5 upstream. This tests that the vsyscall entries do what they're expected to do. It also confirms that attempts to read the vsyscall page behave as expected. If changes are made to the vsyscall code or its memory map handling, running this test in all three of vsyscall=none, vsyscall=emulate, and vsyscall=native are helpful. (Because it's easy, this also compares the vsyscall results to their vDSO equivalents.) Note to KAISER backporters: please test this under all three vsyscall modes. Also, in the emulate and native modes, make sure that test_vsyscall_64 agrees with the command line or config option as to which mode you're in. It's quite easy to mess up the kernel such that native mode accidentally emulates or vice versa. Greg, etc: please backport this to all your Meltdown-patched kernels. It'll help make sure the patches didn't regress vsyscalls. CSigned-off-by: Andy Lutomirski <luto@kernel.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Hugh Dickins <hughd@google.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Juergen Gross <jgross@suse.com> Cc: Kees Cook <keescook@chromium.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/2b9c5a174c1d60fd7774461d518aa75598b1d8fd.1515719552.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17objtool: Allow alternatives to be ignoredJosh Poimboeuf
commit 258c76059cece01bebae098e81bacb1af2edad17 upstream. Getting objtool to understand retpolines is going to be a bit of a challenge. For now, take advantage of the fact that retpolines are patched in with alternatives. Just read the original (sane) non-alternative instruction, and ignore the patched-in retpoline. This allows objtool to understand the control flow *around* the retpoline, even if it can't yet follow what's inside. This means the ORC unwinder will fail to unwind from inside a retpoline, but will work fine otherwise. Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-3-git-send-email-dwmw@amazon.co.uk [dwmw2: Applies to tools/objtool/builtin-check.c not check.[ch]] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17objtool: Detect jumps to retpoline thunksJosh Poimboeuf
commit 39b735332cb8b33a27c28592d969e4016c86c3ea upstream. A direct jump to a retpoline thunk is really an indirect jump in disguise. Change the objtool instruction type accordingly. Objtool needs to know where indirect branches are so it can detect switch statement jump tables. This fixes a bunch of warnings with CONFIG_RETPOLINE like: arch/x86/events/intel/uncore_nhmex.o: warning: objtool: nhmex_rbox_msr_enable_event()+0x44: sibling call from callable instruction with modified stack frame kernel/signal.o: warning: objtool: copy_siginfo_to_user()+0x91: sibling call from callable instruction with modified stack frame ... Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: gnomes@lxorguk.ukuu.org.uk Cc: Rik van Riel <riel@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: thomas.lendacky@amd.com Cc: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jiri Kosina <jikos@kernel.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Kees Cook <keescook@google.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linux-foundation.org> Cc: Paul Turner <pjt@google.com> Link: https://lkml.kernel.org/r/1515707194-20531-2-git-send-email-dwmw@amazon.co.uk [dwmw2: Applies to tools/objtool/builtin-check.c not check.c] Signed-off-by: David Woodhouse <dwmw@amazon.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-17objtool, modules: Discard objtool annotation sections for modulesJosh Poimboeuf
commit e390f9a9689a42f477a6073e2e7df530a4c1b740 upstream. The '__unreachable' and '__func_stack_frame_non_standard' sections are only used at compile time. They're discarded for vmlinux but they should also be discarded for modules. Since this is a recurring pattern, prefix the section names with ".discard.". It's a nice convention and vmlinux.lds.h already discards such sections. Also remove the 'a' (allocatable) flag from the __unreachable section since it doesn't make sense for a discarded section. Suggested-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Jessica Yu <jeyu@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: d1091c7fa3d5 ("objtool: Improve detection of BUG() and other dead ends") Link: http://lkml.kernel.org/r/20170301180444.lhd53c5tibc4ns77@treble Signed-off-by: Ingo Molnar <mingo@kernel.org> [dwmw2: Remove the unreachable part in backporting since it's not here yet] Signed-off-by: David Woodhouse <dwmw@amazon.co.ku> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05KPTI: Rename to PAGE_TABLE_ISOLATIONKees Cook
This renames CONFIG_KAISER to CONFIG_PAGE_TABLE_ISOLATION. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-05kaiser: add "nokaiser" boot option, using ALTERNATIVEHugh Dickins
Added "nokaiser" boot option: an early param like "noinvpcid". Most places now check int kaiser_enabled (#defined 0 when not CONFIG_KAISER) instead of #ifdef CONFIG_KAISER; but entry_64.S and entry_64_compat.S are using the ALTERNATIVE technique, which patches in the preferred instructions at runtime. That technique is tied to x86 cpu features, so X86_FEATURE_KAISER is fabricated. Prior to "nokaiser", Kaiser #defined _PAGE_GLOBAL 0: revert that, but be careful with both _PAGE_GLOBAL and CR4.PGE: setting them when nokaiser like when !CONFIG_KAISER, but not setting either when kaiser - neither matters on its own, but it's hard to be sure that _PAGE_GLOBAL won't get set in some obscure corner, or something add PGE into CR4. By omitting _PAGE_GLOBAL from __supported_pte_mask when kaiser_enabled, all page table setup which uses pte_pfn() masks it out of the ptes. It's slightly shameful that the same declaration versus definition of kaiser_enabled appears in not one, not two, but in three header files (asm/kaiser.h, asm/pgtable.h, asm/tlbflush.h). I felt safer that way, than with #including any of those in any of the others; and did not feel it worth an asm/kaiser_enabled.h - kernel/cpu/common.c includes them all, so we shall hear about it if they get out of synch. Cleanups while in the area: removed the silly #ifdef CONFIG_KAISER from kaiser.c; removed the unused native_get_normal_pgd(); removed the spurious reg clutter from SWITCH_*_CR3 macro stubs; corrected some comments. But more interestingly, set CR4.PSE in secondary_startup_64: the manual is clear that it does not matter whether it's 0 or 1 when 4-level-pts are enabled, but I was distracted to find cr4 different on BSP and auxiliaries - BSP alone was adding PSE, in probe_page_size_mask(). Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02usbip: fix usbip bind writing random string after command in match_busidJuan Zea
commit 544c4605acc5ae4afe7dd5914147947db182f2fb upstream. usbip bind writes commands followed by random string when writing to match_busid attribute in sysfs, caused by using full variable size instead of string length. Signed-off-by: Juan Zea <juan.zea@qindel.com> Acked-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-01-02sync objtool's copy of x86-opcode-map.txtGreg Kroah-Hartman
When building objtool, we get the warning: warning: objtool: x86 instruction decoder differs from kernel That's due to commit 2816c0455cea088f07a210f8a00701a82a78aa9c which was commit 12a78d43de767eaf8fb272facb7a7b6f2dc6a9df upstream that modified arch/x86/lib/x86-opcode-map.txt without also updating the objtool copy. The objtool copy was updated in a much larger patch upstream, but we don't need all of that here, so just update the single file. If this gets too annoying, I'll just end up doing what we did for 4.14 and backport the whole series to keep this from happening again, but as this seems to be rare in the 4.9-stable series, this single patch should be fine. Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20perf symbols: Fix symbols__fixup_end heuristic for corner casesDaniel Borkmann
[ Upstream commit e7ede72a6d40cb3a30c087142d79381ca8a31dab ] The current symbols__fixup_end() heuristic for the last entry in the rb tree is suboptimal as it leads to not being able to recognize the symbol in the call graph in a couple of corner cases, for example: i) If the symbol has a start address (f.e. exposed via kallsyms) that is at a page boundary, then the roundup(curr->start, 4096) for the last entry will result in curr->start == curr->end with a symbol length of zero. ii) If the symbol has a start address that is shortly before a page boundary, then also here, curr->end - curr->start will just be very few bytes, where it's unrealistic that we could perform a match against. Instead, change the heuristic to roundup(curr->start, 4096) + 4096, so that we can catch such corner cases and have a better chance to find that specific symbol. It's still just best effort as the real end of the symbol is unknown to us (and could even be at a larger offset than the current range), but better than the current situation. Alexei reported that he recently run into case i) with a JITed eBPF program (these are all page aligned) as the last symbol which wasn't properly shown in the call graph (while other eBPF program symbols in the rb tree were displayed correctly). Since this is a generic issue, lets try to improve the heuristic a bit. Reported-and-Tested-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Fixes: 2e538c4a1847 ("perf tools: Improve kernel/modules symbol lookup") Link: http://lkml.kernel.org/r/bb5c80d27743be6f12afc68405f1956a330e1bc9.1489614365.git.daniel@iogearbox.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-20userfaultfd: selftest: vm: allow to build in vm/ directoryAndrea Arcangeli
[ Upstream commit 46aa6a302b53f543f8e8b8e1714dc5e449ad36a6 ] linux/tools/testing/selftests/vm $ make gcc -Wall -I ../../../../usr/include compaction_test.c -lrt -o /compaction_test /usr/lib/gcc/x86_64-pc-linux-gnu/4.9.4/../../../../x86_64-pc-linux-gnu/bin/ld: cannot open output file /compaction_test: Permission denied collect2: error: ld returned 1 exit status make: *** [../lib.mk:54: /compaction_test] Error 1 Since commit a8ba798bc8ec ("selftests: enable O and KBUILD_OUTPUT") selftests/vm build fails if run from the "selftests/vm" directory, but it works in the selftests/ directory. It's quicker to be able to do a local vm-only build after a tree wipe and this patch allows for it again. Link: http://lkml.kernel.org/r/20170302173738.18994-4-aarcange@redhat.com Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Mike Rapoport <rppt@linux.vnet.ibm.com> Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com> Cc: Mike Kravetz <mike.kravetz@oracle.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Hillf Danton <hillf.zj@alibaba-inc.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14x86/mpx/selftests: Fix up weird arraysDave Hansen
[ Upstream commit a6400120d042397675fcf694060779d21e9e762d ] The MPX hardware data structurse are defined in a weird way: they define their size in bytes and then union that with the type with which we want to access them. Yes, this is weird, but it does work. But, new GCC's complain that we are accessing the array out of bounds. Just make it a zero-sized array so gcc will stop complaining. There was not really a bug here. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20171111001229.58A7933D@viggo.jf.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14selftest/powerpc: Fix false failures for skipped testsSachin Sant
[ Upstream commit a6d8a21596df041f36f4c2ccc260c459e3e851f1 ] Tests under alignment subdirectory are skipped when executed on previous generation hardware, but harness still marks them as failed. test: test_copy_unaligned tags: git_version:unknown [SKIP] Test skipped on line 26 skip: test_copy_unaligned selftests: copy_unaligned [FAIL] The MAGIC_SKIP_RETURN_VALUE value assigned to rc variable is retained till the program exit which causes the test to be marked as failed. This patch resets the value before returning to the main() routine. With this patch the test o/p is as follows: test: test_copy_unaligned tags: git_version:unknown [SKIP] Test skipped on line 26 skip: test_copy_unaligned selftests: copy_unaligned [PASS] Signed-off-by: Sachin Sant <sachinp@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14x86/selftests: Add clobbers for int80 on x86_64Dmitry Safonov
[ Upstream commit 2a4d0c627f5374f365a873dea4e10ae0bb437680 ] Kernel erases R8..R11 registers prior returning to userspace from int80: https://lkml.org/lkml/2009/10/1/164 GCC can reuse these registers and doesn't expect them to change during syscall invocation. I met this kind of bug in CRIU once GCC 6.1 and CLANG stored local variables in those registers and the kernel zerofied them during syscall: https://github.com/xemul/criu/commit/990d33f1a1cdd17bca6c2eb059ab3be2564f7fa2 By that reason I suggest to add those registers to clobbers in selftests. Also, as noted by Andy - removed unneeded clobber for flags in INT $0x80 inline asm. Signed-off-by: Dmitry Safonov <dsafonov@virtuozzo.com> Acked-by: Andy Lutomirski <luto@kernel.org> Cc: 0x7f454c46@gmail.com Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bp@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Shuah Khan <shuah@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kselftest@vger.kernel.org Link: http://lkml.kernel.org/r/20170213101336.20486-1-dsafonov@virtuozzo.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-14hv: kvp: Avoid reading past allocated blocks from KVP filePaul Meyer
commit 297d6b6e56c2977fc504c61bbeeaa21296923f89 upstream. While reading in more than one block (50) of KVP records, the allocation goes per block, but the reads used the total number of allocated records (without resetting the pointer/stream). This causes the records buffer to overrun when the refresh reads more than one block over the previous capacity (e.g. reading more than 100 KVP records whereas the in-memory database was empty before). Fix this by reading the correct number of KVP records from file each time. Signed-off-by: Paul Meyer <Paul.Meyer@microsoft.com> Signed-off-by: Long Li <longli@microsoft.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09tools include: Do not use poison with C++Arnaldo Carvalho de Melo
[ Upstream commit 6ae8eefc6c8fe050f057781b70a83262eb0a61ee ] LIST_POISON[12] are used to initialize list_head and hlist_node pointers, and do void pointer arithmetic, which C++ doesn't like, so, to avoid drifting from the kernel by introducing some HLIST_POISON to do away with void pointer math, just make those poisoned pointers be NULL when building it with a C++ compiler. Noticed with: $ make LLVM_CONFIG=/usr/bin/llvm-config-3.9 LIBCLANGLLVM=1 CXX util/c++/clang.o CXX util/c++/clang-test.o In file included from /home/lizj/linux/tools/include/linux/list.h:5:0, from /home/lizj/linux/tools/perf/util/namespaces.h:13, from /home/lizj/linux/tools/perf/util/util.h:15, from /home/lizj/linux/tools/perf/util/util-cxx.h:20, from util/c++/clang-c.h:5, from util/c++/clang-test.cpp:2: /home/lizj/linux/tools/include/linux/list.h: In function ‘void list_del(list_head*)’: /home/lizj/linux/tools/include/linux/poison.h:14:31: error: pointer of type ‘void *’ used in arithmetic [-Werror=pointer-arith] # define POISON_POINTER_DELTA 0 ^ /home/lizj/linux/tools/include/linux/poison.h:22:41: note: in expansion of macro ‘POISON_POINTER_DELTA’ #define LIST_POISON1 ((void *) 0x100 + POISON_POINTER_DELTA) ^ /home/lizj/linux/tools/include/linux/list.h:107:16: note: in expansion of macro ‘LIST_POISON1’ entry->next = LIST_POISON1; ^ In file included from /home/lizj/linux/tools/perf/util/namespaces.h:13:0, from /home/lizj/linux/tools/perf/util/util.h:15, from /home/lizj/linux/tools/perf/util/util-cxx.h:20, from util/c++/clang-c.h:5, from util/c++/clang-test.cpp:2: /home/lizj/linux/tools/include/linux/list.h:107:14: error: invalid conversion from ‘void*’ to ‘list_head*’ [-fpermissive] Reported-by: Li Zhijian <lizhijian@cn.fujitsu.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Philip Li <philip.li@intel.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-m5ei2o0mjshucbr28baf5lqz@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09perf test attr: Fix ignored test case resultThomas Richter
[ Upstream commit 22905582f6dd4bbd0c370fe5732c607452010c04 ] Command perf test -v 16 (Setup struct perf_event_attr test) always reports success even if the test case fails. It works correctly if you also specify -F (for don't fork). root@s35lp76 perf]# ./perf test -v 16 15: Setup struct perf_event_attr : --- start --- running './tests/attr/test-record-no-delay' [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.002 MB /tmp/tmp4E1h7R/perf.data (1 samples) ] expected task=0, got 1 expected precise_ip=0, got 3 expected wakeup_events=1, got 0 FAILED './tests/attr/test-record-no-delay' - match failure test child finished with 0 ---- end ---- Setup struct perf_event_attr: Ok The reason for the wrong error reporting is the return value of the system() library call. It is called in run_dir() file tests/attr.c and returns the exit status, in above case 0xff00. This value is given as parameter to the exit() function which can only handle values 0-0xff. The child process terminates with exit value of 0 and the parent does not detect any error. This patch corrects the error reporting and prints the correct test result. Signed-off-by: Thomas-Mich Richter <tmricht@linux.vnet.ibm.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Thomas-Mich Richter <tmricht@linux.vnet.ibm.com> LPU-Reference: 20170913081209.39570-2-tmricht@linux.vnet.ibm.com Link: http://lkml.kernel.org/n/tip-rdube6rfcjsr1nzue72c7lqn@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09usbip: tools: Install all headers needed for libusbip developmentBen Hutchings
[ Upstream commit c15562c0dcb2c7f26e891923b784cf1926b8c833 ] usbip_host_driver.h now depends on several additional headers, which need to be installed along with it. Fixes: 021aed845303 ("staging: usbip: userspace: migrate usbip_host_driver ...") Fixes: 3391ba0e2792 ("usbip: tools: Extract generic code to be shared with ...") Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Acked-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-12-09selftests/x86/ldt_get: Add a few additional tests for limitsAndy Lutomirski
[ Upstream commit fec8f5ae1715a01c72ad52cb2ecd8aacaf142302 ] We weren't testing the .limit and .limit_in_pages fields very well. Add more tests. This addition seems to trigger the "bits 16:19 are undefined" issue that was fixed in an earlier patch. I think that, at least on my CPU, the high nibble of the limit ends in LAR bits 16:19. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/5601c15ea9b3113d288953fd2838b18bedf6bc67.1509794321.git.luto@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15tools: firmware: check for distro fallback udev cancel ruleLuis R. Rodriguez
commit afb999cdef69148f366839e74470d8f5375ba5f1 upstream. Some distributions (Debian, OpenSUSE) have a udev rule in place to cancel all fallback mechanism uevents immediately. This would obviously make it hard to test against the fallback mechanism test interface, so we need to check for this. Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-15selftests: firmware: send expected errors to /dev/nullLuis R. Rodriguez
commit 880444e214cfd293a2e8cc4bd3505f7ffa6ce33a upstream. Error that we expect should not be spilled to stdout. Without this we get: ./fw_filesystem.sh: line 58: printf: write error: Invalid argument ./fw_filesystem.sh: line 63: printf: write error: No such device ./fw_filesystem.sh: line 69: echo: write error: No such file or directory ./fw_filesystem.sh: filesystem loading works ./fw_filesystem.sh: async filesystem loading works With it: ./fw_filesystem.sh: filesystem loading works ./fw_filesystem.sh: async filesystem loading works Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org> Signed-off-by: Amit Pundir <amit.pundir@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08perf tools: Only increase index if perf_evsel__new_idx() succeedsTaeung Song
[ Upstream commit 75fc5ae5cc53fff71041ecadeb3354a2b4c9fe42 ] Signed-off-by: Taeung Song <treeze.taeung@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1485952447-7013-2-git-send-email-treeze.taeung@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-08tools/power turbostat: bugfix: GFXMHz column not changingLen Brown
[ Upstream commit 22048c5485503749754b3b5daf9d99ef89fcacdc ] turbostat displays a GFXMHz column, which comes from reading /sys/class/graphics/fb0/device/drm/card0/gt_cur_freq_mhz But GFXMHz was not changing, even when a manual cat /sys/class/graphics/fb0/device/drm/card0/gt_cur_freq_mhz showed a new value. It turns out that a rewind() on the open file is not sufficient, fflush() (or a close/open) is needed to read fresh values. Reported-by: Yaroslav Isakov <yaroslav.isakov@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05selftests/seccomp: Support glibc 2.26 siginfo_t.hKees Cook
commit 10859f3855db4c6f10dc7974ff4b3a292f3de8e0 upstream. The 2.26 release of glibc changed how siginfo_t is defined, and the earlier work-around to using the kernel definition are no longer needed. The old way needs to stay around for a while, though. Reported-by: Seth Forshee <seth.forshee@canonical.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Will Drewry <wad@chromium.org> Cc: Shuah Khan <shuah@kernel.org> Cc: linux-kselftest@vger.kernel.org Signed-off-by: Kees Cook <keescook@chromium.org> Tested-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-13selftests/x86/fsgsbase: Test selectors 1, 2, and 3Andy Lutomirski
commit 23d98c204386a98d9ef9f9e744f41443ece4929f upstream. Those are funny cases. Make sure they work. (Something is screwy with signal handling if a selector is 1, 2, or 3. Anyone who wants to dive into that rabbit hole is welcome to do so.) Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Borislav Petkov <bpetkov@suse.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Chang Seok <chang.seok.bae@intel.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30ntb: ntb_test: ensure the link is up before trying to configure the mwsLogan Gunthorpe
commit 0eb46345364d7318b11068c46e8a68d5dc10f65e upstream. After the link tests, there is a race on one side of the test for the link coming up. It's possible, in some cases, for the test script to write to the 'peer_trans' files before the link has come up. To fix this, we simply use the link event file to ensure both sides see the link as up before continuning. Signed-off-by: Logan Gunthorpe <logang@deltatee.com> Acked-by: Allen Hubbe <Allen.Hubbe@dell.com> Signed-off-by: Jon Mason <jdmason@kudzu.us> Fixes: a9c59ef77458 ("ntb_test: Add a selftest script for the NTB subsystem") Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30NTB: ntb_test: fix bug printing ntb_perf resultsLogan Gunthorpe
commit 07b0b22b3e58824f70b9188d085d400069ca3240 upstream. The code mistakenly prints the local perf results for the remote test so the script reports identical results for both directions. Fix this by ensuring we print the remote result. Signed-off-by: Logan Gunthorpe <logang@deltatee.com> Fixes: a9c59ef77458 ("ntb_test: Add a selftest script for the NTB subsystem") Acked-by: Allen Hubbe <Allen.Hubbe@dell.com> Signed-off-by: Jon Mason <jdmason@kudzu.us> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30perf probe: Fix --funcs to show correct symbols for offline moduleMasami Hiramatsu
commit eebc509b20881b92d62e317b2c073e57c5f200f0 upstream. Fix --funcs (-F) option to show correct symbols for offline module. Since previous perf-probe uses machine__findnew_module_map() for offline module, even if user passes a module file (with full path) which is for other architecture, perf-probe always tries to load symbol map for current kernel module. This fix uses dso__new_map() to load the map from given binary as same as a map for user applications. Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/148350053478.19001.15435255244512631545.stgit@devbox Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Krister Johansen <kjlx@templeofstupid.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06perf symbols: Robustify reading of build-id from sysfsArnaldo Carvalho de Melo
[ Upstream commit 7934c98a6e04028eb34c1293bfb5a6b0ab630b66 ] Markus reported that perf segfaults when reading /sys/kernel/notes from a kernel linked with GNU gold, due to what looks like a gold bug, so do some bounds checking to avoid crashing in that case. Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Report-Link: http://lkml.kernel.org/r/20161219161821.GA294@x4 Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-ryhgs6a6jxvz207j2636w31c@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06perf tools: Install tools/lib/traceevent plugins with install-binArnaldo Carvalho de Melo
[ Upstream commit 30a9c6444810429aa2b7cbfbd453ce339baaadbf ] Those are binaries as well, so should be installed by: make -C tools/perf install-bin' too. Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Daniel Bristot de Oliveira <bristot@redhat.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/n/tip-3841b37u05evxrs1igkyu6ks@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06tools lib traceevent: Fix prev/next_prio for deadline tasksDaniel Bristot de Oliveira
[ Upstream commit 074859184d770824f4437dca716bdeb625ae8b1c ] Currently, the sched:sched_switch tracepoint reports deadline tasks with priority -1. But when reading the trace via perf script I've got the following output: # ./d & # (d is a deadline task, see [1]) # perf record -e sched:sched_switch -a sleep 1 # perf script ... swapper 0 [000] 2146.962441: sched:sched_switch: swapper/0:0 [120] R ==> d:2593 [4294967295] d 2593 [000] 2146.972472: sched:sched_switch: d:2593 [4294967295] R ==> g:2590 [4294967295] The task d reports the wrong priority [4294967295]. This happens because the "int prio" is stored in an unsigned long long val. Although it is set as a %lld, as int is shorter than unsigned long long, trace_seq_printf prints it as a positive number. The fix is just to cast the val as an int, and print it as a %d, as in the sched:sched_switch tracepoint's "format". The output with the fix is: # ./d & # perf record -e sched:sched_switch -a sleep 1 # perf script ... swapper 0 [000] 4306.374037: sched:sched_switch: swapper/0:0 [120] R ==> d:10941 [-1] d 10941 [000] 4306.383823: sched:sched_switch: d:10941 [-1] R ==> swapper/0:0 [120] [1] d.c --- #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #include <linux/types.h> #include <linux/sched.h> struct sched_attr { __u32 size, sched_policy; __u64 sched_flags; __s32 sched_nice; __u32 sched_priority; __u64 sched_runtime, sched_deadline, sched_period; }; int sched_setattr(pid_t pid, const struct sched_attr *attr, unsigned int flags) { return syscall(__NR_sched_setattr, pid, attr, flags); } int main(void) { struct sched_attr attr = { .size = sizeof(attr), .sched_policy = SCHED_DEADLINE, /* This creates a 10ms/30ms reservation */ .sched_runtime = 10 * 1000 * 1000, .sched_period = attr.sched_deadline = 30 * 1000 * 1000, }; if (sched_setattr(0, &attr, 0) < 0) { perror("sched_setattr"); return -1; } for(;;); } --- Committer notes: Got the program from the provided URL, http://bristot.me/lkml/d.c, trimmed it and included in the cset log above, so that we have everything needed to test it in one place. Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Daniel Bristot de Oliveira <bristot@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/866ef75bcebf670ae91c6a96daa63597ba981f0d.1483443552.git.bristot@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-06perf probe: Fix to get correct modname from elf headerMasami Hiramatsu
[ Upstream commit 1f2ed153b916c95a49a1ca9d7107738664224b7f ] Since 'perf probe' supports cross-arch probes, it is possible to analyze different arch kernel image which has different bits-per-long. In that case, it fails to get the module name because it uses the MOD_NAME_OFFSET macro based on the host machine bits-per-long, instead of the target arch bits-per-long. This fixes above issue by changing modname-offset based on the target archs bit width. This is ok because linux kernel uses LP64 model on 64bit arch. E.g. without this (on x86_64, and target module is arm32): $ perf probe -m build-arm/fs/configfs/configfs.ko -D configfs_lookup p:probe/configfs_lookup :configfs_lookup+0 ^-Here is an empty module name. With this fix, you can see correct module name: $ perf probe -m build-arm/fs/configfs/configfs.ko -D configfs_lookup p:probe/configfs_lookup configfs:configfs_lookup+0 Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/148337043836.6752.383495516397005695.stgit@devbox Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
