commit b0a9ab62ab96e258a0ddd81d7fe2719c3db36006 upstream.
Before this patch this message would very briefly appear on the
screen and then the screen would get updates only on the top,
for number of interrupts received, etc, but no annotation would
be performed:
[root@doppio linux-2.6-tip]# perf top -s n_tty_write > /tmp/bla
objdump: '[kernel.kallsyms]': No such file
Now this is what the user gets:
Can't annotate n_tty_write: No vmlinux file was found in the
path: [0] vmlinux
[1] /boot/vmlinux
[2] /boot/vmlinux-2.6.33-rc5
[3] /lib/modules/2.6.33-rc5/build/vmlinux
[4] /usr/lib/debug/lib/modules/2.6.33-rc5/vmlinux
This bug was introduced when we added automatic search for
vmlinux, before that time the user had to specify a vmlinux
file.
Reported-by: David S. Miller <davem@davemloft.net>
Reported-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1268664418-28328-2-git-send-email-acme@infradead.org>
OPT_INCR()
commit c05556421742eb47f80301767653a4bcb19de9de upstream.
Parsing an option from the command line with OPT_BOOLEAN on a
bool data type would not work on a big-endian machine due to the
manner in which the boolean was being cast into an int and
incremented. For example, running 'perf probe --list' on a
PowerPC machine would fail to properly set the list_events bool
and would therefore print out the usage information and
terminate.
This patch makes OPT_BOOLEAN work as expected with a bool
datatype. For cases where the original OPT_BOOLEAN was
intentionally being used to increment an int each time it was
passed in on the command line, this patch introduces OPT_INCR
with the old behaviour of OPT_BOOLEAN (the verbose variable is
currently the only such example of this).
I have reviewed every use of OPT_BOOLEAN to verify that a true
C99 bool was passed. Where integers were used, I verified that
they were only being used for boolean logic and changed them to
bools to ensure that they would not be mistakenly used as ints.
The major exception was the verbose variable which now uses
OPT_INCR instead of OPT_BOOLEAN.
Signed-off-by: Ian Munsie <imunsie@au.ibm.com>
Cc: <stable@kernel.org>
Cc: Git development list <git@vger.kernel.org>
Cc: Ian Munsie <imunsie@au1.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
Cc: Eric B Munson <ebmunson@us.ibm.com>
Cc: Valdis.Kletnieks@vt.edu
Cc: WANG Cong <amwang@redhat.com>
Cc: Thiago Farina <tfransosi@gmail.com>
Cc: Masami Hiramatsu <mhiramat@redhat.com>
Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Cc: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: John Kacur <jkacur@redhat.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <1271147857-11604-1-git-send-email-imunsie@au.ibm.com>
Usually "_text" is enough, but I received reports that its not always
available, so fallback to "_stext" for the symbol we use to check if we
need to apply any relocation to all the symbols in the kernel symtab,
for when, for instance, kexec is being used.
Reported-by: Darren Hart <dvhltc@us.ibm.com>
Reported-by: Steven Rostedt <rostedt@goodmis.org>
The raw_field_ptr() helper, used to retrieve the address of a field
inside a trace event, treats every strings as if they were dynamic
ie: having a secondary level of indirection to retrieve their
contents.
FIELD_IS_STRING doesn't mean FIELD_IS_DYNAMIC, we only need to
compute the secondary dereference for the latter case.
This fixes perf sched segfaults, bad cmdline report and may be
some other bugs.
Reported-by: Jason Baron <jbaron@redhat.com>
Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Commit 5a0e3ad ("include cleanup: Update gfp.h and slab.h
includes to prepare for breaking implicit slab.h inclusion
from percpu.h") added a '#include <linux/slab.h>' to
tools/perf/builtin-kmem.h because: that tool has lines like
this:
if (!strcmp(event->name, "kmalloc") ||
!strcmp(event->name, "kmem_cache_alloc")) {
process_alloc_event(data, event, cpu, timestamp, thread, 0);
return;
So, using the script regex:
>>> import re
>>> s = re.compile(r'^(|.*[^a-zA-Z0-9_])_*(slab_is_available|kmem_cache_|k[mzc]alloc|krealloc|kz?free|ksize|__getname|putname)')
>>> l = ' !strcmp(event->name, "kmem_cache_alloc")) {'
>>> s.search(l)
<_sre.SRE_Match object at 0xb77b1ad0>
Remove that file that is not available in the tools/perf include
path and thus builtin-kmem.c couldn't be compiled.
Reported-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: Tejun Heo <tj@kernel.org>
LKML-Reference: <1270561053-14308-1-git-send-email-acme@infradead.org>
Building chokes with:
In file included from /usr/include/gelf.h:53,
from /usr/include/elfutils/libdw.h:53,
from util/probe-finder.h:61,
from util/probe-finder.c:39:
/usr/include/libelf.h:98: error: expected specifier-qualifier-list before 'off64_t'
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
LKML-Reference: <20100329164755.GA16034@aftab>
This is a fix to the signed/unsigned field handling in the
Python scripting engine, based on a patch from Roel Kluin.
Basically, Python wants to use a PyInt (which is internally a
long) if it can i.e. if the value will fit into that type. If
not, it stores it into a PyLong, which isn't actually a long,
but an arbitrary-precision integer variable.
The code below is similar to to what Python does internally, and
it seems to work as expected on the x86 and x86_64 sytems I
tested it on.
Signed-off-by: Tom Zanussi <tzanussi@gmail.com>
Cc: Roel Kluin <roel.kluin@gmail.com>
Cc: rostedt@goodmis.org
LKML-Reference: <1270184305.6422.10.camel@tropicana>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
powerpc/perf_events: Fix call-graph recording, add perf_arch_fetch_caller_regs
perf top: Add missing initialization to zero
perf probe: Use original address instead of CU-based address
perf probe: Fix offset to allow signed value
perf top: Improve the autosizing of column lenghts
perf probe: Fix need_dwarf flag if lazy matching is used
perf probe: Fix probe_point buffer overrun
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (35 commits)
perf: Fix unexported generic perf_arch_fetch_caller_regs
perf record: Don't try to find buildids in a zero sized file
perf: export perf_trace_regs and perf_arch_fetch_caller_regs
perf, x86: Fix hw_perf_enable() event assignment
perf, ppc: Fix compile error due to new cpu notifiers
perf: Make the install relative to DESTDIR if specified
kprobes: Calculate the index correctly when freeing the out-of-line execution slot
perf tools: Fix sparse CPU numbering related bugs
perf_event: Fix oops triggered by cpu offline/online
perf: Drop the obsolete profile naming for trace events
perf: Take a hot regs snapshot for trace events
perf: Introduce new perf_fetch_caller_regs() for hot regs snapshot
perf/x86-64: Use frame pointer to walk on irq and process stacks
lockdep: Move lock events under lockdep recursion protection
perf report: Print the map table just after samples for which no map was found
perf report: Add multiple event support
perf session: Change perf_session post processing functions to take histogram tree
perf session: Add storage for seperating event types in report
perf session: Change add_hist_entry to take the tree root instead of session
perf record: Add ID and to recorded event data when recording multiple events
The dso_short_width has to start as zero, as we're calculating
the maximum short DSO name length, somehow I missed this one.
Reported-by: Frédéric Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1268774926-27488-1-git-send-email-acme@infradead.org>
Use original address for looking up the location of variables
for dwarf_getlocation_addr() instead of CU-based address.
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Cc: systemtap <systemtap@sources.redhat.com>
Cc: DLE <dle-develop@lists.sourceforge.net>
LKML-Reference: <20100315170235.31852.91195.stgit@localhost6.localdomain6>
Fix dereference offset to intmax_t from uintmax_t, because
it can have negative values (for example local variable's offset
from frame pointer).
LKML-Reference: <20100315170228.31852.71946.stgit@localhost6.localdomain6>
When profiling C++ workloads the symbol name length can be
really big, so cap it before it garbles the result.
This builds upon the autosizing already present where we choose
to use the short, basename of DSOs instead of its long, full
pathname.
Reported-by: Pavel Krauz <krauz@cngroup.cz>
LKML-Reference: <1268676230-9261-1-git-send-email-acme@infradead.org>
perf: Provide generic perf_sample_data initialization
MAINTAINERS: Add Arnaldo as tools/perf/ co-maintainer
perf trace: Don't use pager if scripting
perf trace/scripting: Remove extraneous header read
perf, ARM: Modify kuser rmb() call to compile for Thumb-2
x86/stacktrace: Don't dereference bad frame pointers
perf archive: Don't try to collect files without a build-id
perf_events, x86: Fixup fixed counter constraints
perf, x86: Restrict the ANY flag
perf, x86: rename macro in ARCH_PERFMON_EVENTSEL_ENABLE
perf, x86: add some IBS macros to perf_event.h
perf, x86: make IBS macros available in perf_event.h
hw-breakpoints: Remove stub unthrottle callback
x86/hw-breakpoints: Remove the name field
perf: Remove pointless breakpoint union
perf lock: Drop the buffers multiplexing dependency
perf lock: Fix and add misc documentally things
percpu: Add __percpu sparse annotations to hw_breakpoint
Set need_dwarf if lazy matching pattern is specified, because
lazy matching requires real source path for which we must use
debuginfo.
LKML-Reference: <20100312232224.2017.54550.stgit@localhost6.localdomain6>
Fix probe_point array-size overrun problem. In some cases (e.g.
inline function), one user-specified probe-point can be
translated to many probe address, and it overruns pre-defined
array-size. This also removes redundant MAX_PROBES macro
definition.
LKML-Reference: <20100312232217.2017.45017.stgit@localhost6.localdomain6>
[ Note that only root can create new probes. Eventually we should remove
the MAX_PROBES limit, but that is a larger patch not eligible to
perf/urgent treatment. ]
Fixing this symptom:
[acme@mica linux-2.6-tip]$ perf record -a -f
Fatal: Permission error - are you root?
Bus error
I.e. if for some reason no data is collected, in this case a non
root user trying to do systemwide profiling, no data will be
collected, and then we end up trying to mmap a zero sized file
and access the file header, b00m.
LKML-Reference: <1268333592-30872-1-git-send-email-acme@infradead.org>
Without this change, the install path is relative to
prefix/DESTDIR where prefix is automatically set to $HOME.
This can produce unexpected results. For example:
make -C tools/perf DESTDIR=/home/jkacur/tmp install-man
creates the directory: /home/jkacur/home/jkacur/tmp/share/...
instead of the expected: /home/jkacur/tmp/share/...
Signed-off-by: John Kacur <jkacur@redhat.com>
Cc: Kyle McMartin <kyle@redhat.com>
LKML-Reference: <1268312220-12880-1-git-send-email-jkacur@redhat.com>
At present, the perf subcommands that do system-wide monitoring
(perf stat, perf record and perf top) don't work properly unless
the online cpus are numbered 0, 1, ..., N-1. These tools ask
for the number of online cpus with sysconf(_SC_NPROCESSORS_ONLN)
and then try to create events for cpus 0, 1, ..., N-1.
This creates problems for systems where the online cpus are
numbered sparsely. For example, a POWER6 system in
single-threaded mode (i.e. only running 1 hardware thread per
core) will have only even-numbered cpus online.
This fixes the problem by reading the /sys/devices/system/cpu/online
file to find out which cpus are online. The code that does that is in
tools/perf/util/cpumap.[ch], and consists of a read_cpu_map()
function that sets up a cpumap[] array and returns the number of
online cpus. If /sys/devices/system/cpu/online can't be read or
can't be parsed successfully, it falls back to using sysconf to
ask how many cpus are online and sets up an identity map in cpumap[].
The perf record, perf stat and perf top code then calls
read_cpu_map() in the system-wide monitoring case (instead of
sysconf) and uses cpumap[] to get the cpu numbers to pass to
perf_event_open.
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
LKML-Reference: <20100310093609.GA3959@brick.ozlabs.ibm.com>
If -vv is used just the map table will be printed, -vvv will
print the symbol table too, with it we can see that we have a
bug where some samples are not being resolved to a map when we
get them in the perf.data stream, but after we have it all
processed, we can find the right map, some reordering probably
is happening.
Upcoming patches will provide ways to ask for most PERF_SAMPLE_
conditional samples to be taken for !PERF_RECORD_SAMPLE events
too, then we'll be able to ask for PERF_SAMPLE_TIME and
PERF_SAMPLE_CPU to help diagnose this.
LKML-Reference: <1268161097-17761-1-git-send-email-acme@infradead.org>
Perf report does not handle multiple events being reported, even
though perf record stores them properly on disk. This patch
addresses that issue by adding the logic to perf report to use
the event stream id that is saved by record and the new data
structures to seperate the event streams and report them
individually.
Signed-off-by: Eric B Munson <ebmunson@us.ibm.com>
LKML-Reference: <1267804269-22660-6-git-send-email-acme@infradead.org>
histogram tree
Now that report can store historgrams for multiple events we
need to be able to do the post processing work for each
histogram. This patch changes the post processing functions so
that they can be called individually for each event's histogram.
[ Guarantee bisectabilty by fixing up builtin-report.c ]
LKML-Reference: <1267804269-22660-5-git-send-email-acme@infradead.org>
This patch adds the structures necessary to count each event
type independently in perf report.
LKML-Reference: <1267804269-22660-4-git-send-email-acme@infradead.org>
In order to minimize the impact of storing multiple events in a
report this function will now take the root of the histogram
tree so that the logic for selecting the proper tree can be
inserted before the call.
LKML-Reference: <1267804269-22660-3-git-send-email-acme@infradead.org>
Currently perf record does not write the ID or the to disk for
events. This doesn't allow report to tell if an event stream
contains one or more types of events. This patch adds this
entry to the list of data that record will write to disk if more
than one event was requested.
LKML-Reference: <1267804269-22660-2-git-send-email-acme@infradead.org>
cc1: warnings being treated as errors
util/probe-finder.c: In function 'find_line_range':
util/probe-finder.c:172: warning: 'src' may be used
uninitialized in this function make: *** [util/probe-finder.o]
Error 1
LKML-Reference: <1267804269-22660-1-git-send-email-acme@infradead.org>
LKML-Reference: <1267800842-22324-1-git-send-email-acme@infradead.org>
tools/perf/util/probe-event.c
Merge reason: Pick up -rc1 and resolve the conflict as well.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
* 'perf-probes-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
x86: Issue at least one memory barrier in stop_machine_text_poke()
perf probe: Correct probe syntax on command line help
perf probe: Add lazy line matching support
perf probe: Show more lines after last line
perf probe: Check function address range strictly in line finder
perf probe: Use libdw callback routines
perf probe: Use elfutils-libdw for analyzing debuginfo
perf probe: Rename probe finder functions
perf probe: Fix bugs in line range finder
perf probe: Update perf probe document
perf probe: Do not show --line option without dwarf support
kprobes: Add documents of jump optimization
kprobes/x86: Support kprobes jump optimization on x86
x86: Add text_poke_smp for SMP cross modifying code
kprobes/x86: Cleanup save/restore registers
kprobes/x86: Boost probes when reentering
kprobes: Jump optimization sysctl interface
kprobes: Introduce kprobes jump optimization
kprobes: Introduce generic insn_slot framework
kprobes/x86: Cleanup RELATIVEJUMP_INSTRUCTION to RELATIVEJUMP_OPCODE
It's useful for paging through raw traces, but just gets in the
way when scripting.
Cc: fweisbec@gmail.com
LKML-Reference: <1267599873-8193-3-git-send-email-tzanussi@gmail.com>
perf_header__read() is already done in perf_session__open(), so
remove it from the script gen case.
LKML-Reference: <1267599873-8193-2-git-send-email-tzanussi@gmail.com>
The Thumb-2 instruction set does not provide an encoding
for sub pc, r0, #95 as present in the rmb() definition used
by perf. This results in compilation failure when using a
compiler targetting an instruction set other than ARM.
This patch redefines rmb() for ARM by casting the address
of the kuser helper to a function pointer, therefore getting
the compiler to take care of making the call.
Patch taken against tip/master.
Cc: Russell King - ARM Linux <linux@arm.linux.org.uk>
Cc: Jamie Iles <jamie.iles@picochip.com>
LKML-Reference: <1267616878-2154-1-git-send-email-will.deacon@arm.com>
Move @SRC right after FUNC in syntax according to syntax change
on command line help.
Cc: K.Prasad <prasad@linux.vnet.ibm.com>
LKML-Reference: <20100304033843.3819.10087.stgit@localhost6.localdomain6>
To avoid these error:
[root@doppio ~]# perf archive
tar: .build-id/00/00000000000000000000000000000000000000: Cannot stat:
No such file or directory
tar: Exiting with failure status due to previous errors
[root@doppio ~]#
More work is needed to support archiving symtabs for binaries
without a build-id, perhaps creating a perf.data UUID + adding
build-ids for the binaries copied into the cache and then have
this perf.data session UUID be a directory with symlinks to the
by now calculated build-id of the files inside it.
Or just do an extra pass and insert the calculated build-ids in
the perf.data header.
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (172 commits)
perf_event, amd: Fix spinlock initialization
perf_event: Fix preempt warning in perf_clock()
perf tools: Flush maps on COMM events
perf_events, x86: Split PMU definitions into separate files
perf annotate: Handle samples not at objdump output addr boundaries
perf_events, x86: Remove superflous MSR writes
perf_events: Simplify code by removing cpu argument to hw_perf_group_sched_in()
perf_events, x86: AMD event scheduling
perf_events: Add new start/stop PMU callbacks
perf_events: Report the MMAP pgoff value in bytes
perf annotate: Defer allocating sym_priv->hist array
perf symbols: Improve debugging information about symtab origins
perf top: Use a macro instead of a constant variable
perf symbols: Check the right return variable
perf/scripts: Tag syscall_name helper as not yet available
perf/scripts: Add perf-trace-python Documentation
perf/scripts: Remove unnecessary PyTuple resizes
perf/scripts: Add syscall tracing scripts
perf/scripts: Add Python scripting engine
perf/scripts: Remove check-perf-trace from listed scripts
Fix trivial conflict in tools/perf/util/probe-event.c
We need to deal with time ordered events to build a correct
state machine of lock events. This is why we multiplex the lock
events buffers. But the ordering is done from the kernel, on
the tracing fast path, leading to high contention between cpus.
Without multiplexing, the events appears in a weak order.
If we have four events, each split per cpu, perf record will
read the events buffers in the following order:
[ CPU0 ev0, CPU0 ev1, CPU0 ev3, CPU0 ev4, CPU1 ev0, CPU1 ev0....]
To handle a post processing reordering, we could just read and sort
the whole in memory, but it just doesn't scale with high amounts
of events: lock events can fill huge amounts in few times.
Basically we need to sort in memory and find a "grace period"
point when we know that a given slice of previously sorted events
can be committed for post-processing, so that we can unload the
memory usage step by step and keep a scalable sorting list.
There is no strong rules about how to define such "grace period".
What does this patch is:
We define a FLUSH_PERIOD value that defines a grace period in
seconds.
We want to have a slice of events covering 2 * FLUSH_PERIOD in our
sorted list.
If FLUSH_PERIOD is big enough, it ensures every events that occured
in the first half of the timeslice have all been buffered and there
are none remaining and there won't be further to put inside this
first timeslice. Then once we reach the 2 * FLUSH_PERIOD
timeslice, we flush the first half to be gentle with the memory
(the second half can still get new events in the middle, so wait
another period to flush it)
FLUSH_PERIOD is defined to 5 seconds. Say the first event started on
time t0. We can safely assume that at the time we are processing
events of t0 + 10 seconds, ther won't be anymore events to read
from perf.data that occured between t0 and t0 + 5 seconds. Hence
we can safely flush the first half.
To point out funky bugs, we have a guardian that checks a new event
timestamp is not below the last event's timestamp flushed and that
displays a warning in this case.
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
I've forgot to add 'perf lock' line to command-list.txt,
so users of perf could not find perf lock when they type 'perf'.
Fixing command-list.txt requires document
(tools/perf/Documentation/perf-lock.txt).
But perf lock is too much "under construction" to write a
stable document, so this is something like pseudo document for now.
And I wrote description of perf lock at help section of
CONFIG_LOCK_STAT, this will navigate users of lock trace events.
Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
LKML-Reference: <1265267295-8388-1-git-send-email-mitake@dcl.info.waseda.ac.jp>
Merge reason:
__percpu annotations need the corresponding sparse address
space definition upstream.
tools/perf/util/probe-event.c (trivial)
Even though we don't register the counters until the child is right about
to exec(), we're still going to get at least a few events while the
fork()'d child is still executing 'perf' and in particular we're going to
get the MMAP events.
We can't distinguish the ones in the newly executed process because the
PID will be the same.
One way to solve this would be to have a PERF_RECORD_EXEC event, and when
this is seen 'perf' can flush it's map cache. We can't use
PERF_RECORD_COMM since that's generated by other things, not just exec().
Actually, thinking about it some more, using PERF_RECORD_COMM might be a
good enough approximation.
LKML-Reference: <1267196914-16238-1-git-send-email-acme@infradead.org>
Without this patch we get this for need_resched:
[root@mica ~]# perf annotate need_resched
Percent | Source code & Disassembly of vmlinux
: Disassembly of section .text:
: ffffffff810095ed <need_resched>:
: return (state & TASK_INTERRUPTIBLE) || __fatal_signal_pending(p);
: static inline int need_resched(void)
0.00 : ffffffff810095ed: 55 push %rbp
: return unlikely(test_thread_flag(TIF_NEED_RESCHED));
0.00 : ffffffff810095ee: be 03 00 00 00 mov $0x3,%esi
: static inline struct thread_info *current_thread_info(void)
: struct thread_info *ti;
: ti = (void *)(percpu_read_stable(kernel_stack) +
0.00 : ffffffff810095f3: 65 48 8b 3c 25 48 b5 mov %gs:0xb548,%rdi
0.00 : ffffffff810095fa: 00 00
0.00 : ffffffff810095fc: 48 89 e5 mov %rsp,%rbp
0.00 : ffffffff810095ff: 48 81 ef d8 1f 00 00 sub $0x1fd8,%rdi
0.00 : ffffffff81009606: e8 9d ff ff ff callq ffffffff810095a8 <test_ti_thread_flag>
0.00 : ffffffff8100960b: c9 leaveq
0.00 : ffffffff8100960c: 85 c0 test %eax,%eax
0.00 : ffffffff8100960e: 0f 95 c0 setne %al
0.00 : ffffffff81009611: 0f b6 c0 movzbl %al,%eax
: Disassembly of section .vsyscall_0:
: Disassembly of section .vsyscall_fn:
: Disassembly of section .vsyscall_1:
: Disassembly of section .vsyscall_2:
: Disassembly of section .init.text:
: Disassembly of section .altinstr_replacement:
: Disassembly of section .exit.text:
[root@mica ~]#
But from the 'perf report' result we know that there are hits
for need_resched on a 4 way machine mostly doing nothing, so
after adding code to show what is in each hist offset and
collapsing IP hits for what happens between objdump lines we
get, for the same perf.data file:
[root@mica ~]# perf annotate -v need_resched
52.78 : ffffffff810095ee: be 03 00 00 00 mov $0x3,%esi
9.72 : ffffffff810095ff: 48 81 ef d8 1f 00 00 sub $0x1fd8,%rdi
37.50 : ffffffff8100960e: 0f 95 c0 setne %al
[root@mica ~]#
And now 'perf annotate -v', verbose mode, will show the hits per
precise IP, so that one can make sense of the attribution to
each objdumop line:
Looking at the vmlinux_path (5 entries long)
Using /lib/modules/2.6.33-rc8-tip-00784-g3471df5-dirty/build/vmlinux
for symbols annotate_sym: filename=/lib/modules/2.6.33-rc8-tip-00784-g3471df5-dirty/build/vmlinux, sym=need_resched, start=0xffffffff810095ed, end=0xffffffff81009614
ffffffff810095f1: 152
ffffffff81009603: 28
ffffffff8100960f: 55
ffffffff81009610: 53
h->sum: 288
<SNIP same annotation>
LKML-Reference: <1267194194-15670-1-git-send-email-acme@infradead.org>
Add lazy line matching support for specifying new probes.
This also changes the syntax of perf probe a bit. Now
perf probe accepts one of below probe event definitions.
1) Define event based on function name
[EVENT=]FUNC[@SRC][:RLN|+OFF|%return|;PTN] [ARG ...]
2) Define event based on source file with line number
[EVENT=]SRC:ALN [ARG ...]
3) Define event based on source file with lazy pattern
[EVENT=]SRC;PTN [ARG ...]
- New lazy matching pattern(PTN) follows ';' (semicolon). And it
must be put the end of the definition.
- So, @SRC is no longer the part which must be put at the end
of the definition.
Note that ';' (semicolon) can be interpreted as the end of
a command by the shell. This means that you need to quote it.
(anyway you will need to quote the lazy pattern itself too,
because it may contains other sensitive characters, like
'[',']' etc.).
Lazy matching
The lazy line matching is similar to glob matching except
ignoring spaces in both of pattern and target.
e.g.
'a=*' can matches 'a=b', 'a = b', 'a == b' and so on.
This provides some sort of flexibility and robustness to
probe point definitions against minor code changes.
(for example, actual 10th line of schedule() can be changed
easily by modifying schedule(), but the same line matching
'rq=cpu_rq*' may still exist.)
Changes in v3:
- Cast Dwarf_Addr to uintmax_t for printf-formats.
Changes in v2:
- Cast Dwarf_Addr to unsigned long long for printf-formats.
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
LKML-Reference: <20100225133611.6725.45078.stgit@localhost6.localdomain6>
Show 2 more lines after the last probe-able line.
This will clearly show the last closed-brace of
inline functions.
LKML-Reference: <20100225133604.6725.76820.stgit@localhost6.localdomain6>
Check (inlined) function address range strictly for
improving output of probe-able lines of inline functions.
Without this change, perf probe --line <function> sometimes
showed other inline function bodies too, because it didn't
filter out inlined functions.
Cc: Ulrich Drepper <drepper@redhat.com>
Cc: Roland McGrath <roland@redhat.com>
LKML-Reference: <20100225133557.6725.20697.stgit@localhost6.localdomain6>
Use libdw callback functions aggressively, and remove
local tree-search API. This change simplifies the code.
Changes in v3:
Changes in v2:
LKML-Reference: <20100225133549.6725.81499.stgit@localhost6.localdomain6>
Newer gcc introduces newer & richer debuginfo, and only libdw
in elfutils project can support it. So perf probe moves onto
elfutils-libdw from libdwarf.
Changes in v3:
- Cast Dwarf_Addr/Dwarf_Word to uintmax_t for printf-formats.
- Recover a sign-prefix which was removed in v2 by mistake.
Changes in v2:
- Fix a type-casting bug in Makefile.
- Cast Dwarf_Addr/Dwarf_Word to unsigned long long for printf-formats.
LKML-Reference: <20100225133542.6725.34724.stgit@localhost6.localdomain6>
Rename *_probepoint to *_probe_point, for nothing
but a cosmetic reason.
LKML-Reference: <20100225133534.6725.52615.stgit@localhost6.localdomain6>
Fix find_line_range_by_line() to init line_list and remove
misconseptional found marking which should be done when
real lines are found (if there is no lines probe-able,
find_line_range() should return 0).
LKML-Reference: <20100225133527.6725.52418.stgit@localhost6.localdomain6>
