[ Upstream commit fa1195ccc0af2d121abe0fe266a1caee8c265eea ]
We need to increase output offset in each iteration, not decrease it as
we currently do.
I guess we were lucky to finish in most cases in first iteration, so the
bug never showed. However it shows a lot when working with big (~4GB)
size data.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Fixes: 9c9f5a2f1944 ("perf tools: Introduce copyfile_offset() function")
Link: http://lkml.kernel.org/r/20180109133923.25406-1-jolsa@kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 94df1040b1e6aacd8dec0ba3c61d7e77cd695f26 ]
If a kernel modules is compressed, it should be decompressed before
running objdump to parse binary data correctly. This fixes a failure of
object code reading test for me.
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Cc: kernel-team@lge.com
Link: http://lkml.kernel.org/r/20170608073109.30699-8-namhyung@kernel.org
[ Upstream commit 2538b9e2450ae255337c04356e9e0f8cb9ec48d9 ]
In some situations the libdw unwinder stopped working properly. I.e.
with libunwind we see:
heaptrack_gui 2228 135073.400112: 641314 cycles:
e8ed _dl_fixup (/usr/lib/ld-2.25.so)
15f06 _dl_runtime_resolve_sse_vex (/usr/lib/ld-2.25.so)
ed94c KDynamicJobTracker::KDynamicJobTracker (/home/milian/projects/compiled/kf5/lib64/libKF5KIOWidgets.so.5.35.0)
608f3 _GLOBAL__sub_I_kdynamicjobtracker.cpp (/home/milian/projects/compiled/kf5/lib64/libKF5KIOWidgets.so.5.35.0)
f199 call_init.part.0 (/usr/lib/ld-2.25.so)
f2a5 _dl_init (/usr/lib/ld-2.25.so)
db9 _dl_start_user (/usr/lib/ld-2.25.so)
But with libdw and without this patch this sample is not properly
unwound:
Debug output showed me that libdw found a module for the last frame
address, but it thinks it belongs to /usr/lib/ld-2.25.so. This patch
double-checks what libdw sees and what perf knows. If the mappings
mismatch, we now report the elf known to perf. This fixes the situation
above, and the libdw unwinder produces the same stack as libunwind.
Signed-off-by: Milian Wolff <milian.wolff@kdab.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20170602143753.16907-1-milian.wolff@kdab.com
[ Upstream commit 1deec1bd96ccd8beb04d2112a6d12fe20505c3a6 ]
When perf processes build-id event, it creates DSOs with the build-id.
But it didn't set the module short name (like '[module-name]') so when
processing a kernel mmap event of the module, it cannot found the DSO as
it only checks the short names.
That leads for perf to create a same DSO without the build-id info and
it'll lookup the system path even if the DSO is already in the build-id
cache. After kernel was updated, perf cannot find the DSO and cannot
show symbols in it anymore.
You can see this if you have an old data file (w/ old kernel version):
$ perf report -i perf.data.old -v |& grep scsi_mod
build id event received for /lib/modules/3.19.2-1-ARCH/kernel/drivers/scsi/scsi_mod.ko.gz : cafe1ce6ca13a98a5d9ed3425cde249e57a27fc1
Failed to open /lib/modules/3.19.2-1-ARCH/kernel/drivers/scsi/scsi_mod.ko.gz, continuing without symbols
The second message didn't show the build-id. With this patch:
build id event received for /lib/modules/3.19.2-1-ARCH/kernel/drivers/scsi/scsi_mod.ko.gz: cafe1ce6ca13a98a5d9ed3425cde249e57a27fc1
/lib/modules/3.19.2-1-ARCH/kernel/drivers/scsi/scsi_mod.ko.gz with build id cafe1ce6ca13a98a5d9ed3425cde249e57a27fc1 not found, continuing without symbols
Now it shows the build-id but still cannot load the symbol table. This
is a different problem which will be fixed in the next patch.
Link: http://lkml.kernel.org/r/20170531120105.21731-1-namhyung@kernel.org
[ Fix the build on older compilers (debian <= 8, fedora <= 21, etc) wrt kmod_path var init ]
[ Upstream commit 54265664c15a68905d8d67d19205e9a767636434 ]
The s390 architecture maps sys_mmap (nr 90) into sys_old_mmap. For this
reason perf trace can't find the proper syscall event to get args format
from and displays it wrongly as 'continued'.
To fix that fill the "alias" field with "old_mmap" for trace's mmap record
to get the correct translation.
Before:
0.042 ( 0.011 ms): vest/43052 fstat(statbuf: 0x3ffff89fd90 ) = 0
0.042 ( 0.028 ms): vest/43052 ... [continued]: mmap()) = 0x3fffd6e2000
0.072 ( 0.025 ms): vest/43052 read(buf: 0x3fffd6e2000, count: 4096 ) = 6
After:
0.045 ( 0.011 ms): fstat(statbuf: 0x3ffff8a0930 ) = 0
0.057 ( 0.018 ms): mmap(arg: 0x3ffff8a0858 ) = 0x3fffd14a000
0.076 ( 0.025 ms): read(buf: 0x3fffd14a000, count: 4096 ) = 6
Link: http://lkml.kernel.org/r/20170531113557.19175-1-jolsa@kernel.org
[ Upstream commit 9f5c6d8777a2d962b0eeacb2a16f37da6bea545b ]
This improve the error message so that user can know event-name error
before writing new events to kprobe-events interface.
E.g.
#./perf probe -x /lib64/libc-2.25.so malloc_get_state*
Internal error: "malloc_get_state@GLIBC_2" is an invalid event name.
Error: Failed to add events.
Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Reviewed-by: Thomas Richter <tmricht@linux.vnet.ibm.com>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Paul Clarke <pc@us.ibm.com>
Cc: bhargavb <bhargavaramudu@gmail.com>
Cc: linux-rt-users@vger.kernel.org
Link: http://lkml.kernel.org/r/151275040665.24652.5188568529237584489.stgit@devbox
[ Upstream commit fe06fe860250a4f01d0eaf70a2563b1997174a74 ]
The tm-resched-dscr test has started failing sometimes, depending on
what compiler it's built with, eg:
test: tm_resched_dscr
Check DSCR TM context switch: tm-resched-dscr: tm-resched-dscr.c:76: test_body: Assertion `rv' failed.
!! child died by signal 6
When it fails we see that the compiler doesn't initialise rv to 1 before
entering the inline asm block. Although that's counter intuitive, it
is allowed because we tell the compiler that the inline asm will write
to rv (using "=r"), meaning the original value is irrelevant.
Marking it as a read/write parameter would presumably work, but it seems
simpler to fix it by setting the initial value of rv in the inline asm.
Fixes: 96d016108640 ("powerpc: Correct DSCR during TM context switch")
Acked-by: Michael Neuling <mikey@neuling.org>
[ Upstream commit 805b151a1afd24414706a7f6ae275fbb9649be74 ]
__kmod_path__parse() uses is_supported_compression() to determine and
parse out compressed module file extensions. On systems without zlib,
this test fails and __kmod_path__parse() continues to strcmp "ko" with
"gz". Don't do this on those systems.
Signed-off-by: Kim Phillips <kim.phillips@arm.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Fixes: 3c8a67f50a1e ("perf tools: Add kmod_path__parse function")
Link: http://lkml.kernel.org/r/20170503131402.c66e314460026c80cd787b34@arm.com
commit 78393fdde2a456cafa414b171c90f26a3df98b20 upstream.
POPF is currently broken -- add tests to catch the error. This
results in:
[RUN] POPF with VIP set and IF clear from vm86 mode
[INFO] Exited vm86 mode due to STI
[FAIL] Incorrect return reason (started at eip = 0xd, ended at eip = 0xf)
because POPF currently fails to check IF before reporting a pending
interrupt.
This patch also makes the FAIL message a bit more informative.
Reported-by: Bart Oldeman <bartoldeman@gmail.com>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Stas Sergeev <stsp@list.ru>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/a16270b5cfe7832d6d00c479d0f871066cbdb52b.1521003603.git.luto@kernel.org
commit a9e017d5619eb371460c8e516f4684def62bef3a upstream.
The STR and SLDT instructions are not valid when running on virtual-8086
mode and generate an invalid operand exception. These two instructions are
protected by the Intel User-Mode Instruction Prevention (UMIP) security
feature. In protected mode, if UMIP is enabled, these instructions generate
a general protection fault if called from CPL > 0. Linux traps the general
protection fault and emulates the instructions sgdt, sidt and smsw; but not
str and sldt.
These tests are added to verify that the emulation code does not emulate
these two instructions but the expected invalid operand exception is
seen.
Tests fallback to exit with INT3 in case emulation does happen.
Signed-off-by: Ricardo Neri <ricardo.neri-calderon@linux.intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Chen Yucong <slaoub@gmail.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Huang Rui <ray.huang@amd.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Ravi V. Shankar <ravi.v.shankar@intel.com>
Cc: Shuah Khan <shuah@kernel.org>
Cc: ricardo.neri@intel.com
Link: http://lkml.kernel.org/r/1509935277-22138-13-git-send-email-ricardo.neri-calderon@linux.intel.com
commit 9390afebe1d3f5a0be18b1afdd0ce09d67cebf9e upstream.
Certain user space programs that run on virtual-8086 mode may utilize
instructions protected by the User-Mode Instruction Prevention (UMIP)
security feature present in new Intel processors: SGDT, SIDT and SMSW. In
such a case, a general protection fault is issued if UMIP is enabled. When
such a fault happens, the kernel traps it and emulates the results of
these instructions with dummy values. The purpose of this new
test is to verify whether the impacted instructions can be executed
without causing such #GP. If no #GP exceptions occur, we expect to exit
virtual-8086 mode from INT3.
The instructions protected by UMIP are executed in representative use
cases:
a) displacement-only memory addressing
b) register-indirect memory addressing
c) results stored directly in operands
Unfortunately, it is not possible to check the results against a set of
expected values because no emulation will occur in systems that do not
have the UMIP feature. Instead, results are printed for verification. A
simple verification is done to ensure that results of all tests are
identical.
Link: http://lkml.kernel.org/r/1509935277-22138-12-git-send-email-ricardo.neri-calderon@linux.intel.com
commit 327d53d005ca47b10eae940616ed11c569f75a9b upstream.
Fix a logic error that caused the test to exit with 0 even if test
cases failed.
Cc: bartoldeman@gmail.com
Link: http://lkml.kernel.org/r/b1cc37144038958a469c8f70a5f47a6a5638636a.1521003603.git.luto@kernel.org
[ Upstream commit 2adfa4210f8f35cdfb4e08318cc06b99752964c2 ]
The 'configinit.sh' script checks the format of optional argument for the
build directory, printing an error message if the format is not valid.
However, the error message uses the wrong variable, indicating an empty
string even though the user entered a non-empty (but erroneous) string.
This commit fixes the script to use the correct variable.
Fixes: c87b9c601ac8 ("rcutorture: Add KVM-based test framework")
Signed-off-by: SeongJae Park <sj38.park@gmail.com>
[ Upstream commit 77be4c878c72e411ad22af96b6f81dd45c26450a ]
Indeed musl doesn't define old SIGCLD signal name but only new one SIGCHLD.
SIGCHLD is the new POSIX name for that signal so it doesn't change
anything on other libcs.
This fixes this kind of build error:
usbipd.c: In function ‘set_signal’:
usbipd.c:459:12: error: 'SIGCLD' undeclared (first use in this function)
sigaction(SIGCLD, &act, NULL);
usbipd.c:459:12: note: each undeclared identifier is reported only once
for each function it appears in
Makefile:407: recipe for target 'usbipd.o' failed
make[3]: *** [usbipd.o] Error 1
Signed-off-by: Julien BOIBESSOT <julien.boibessot@armadeus.com>
Acked-by: Shuah Khan <shuahkh@osg.samsung.com>
[ Upstream commit 65c79230576873b312c3599479c1e42355c9f349 ]
The file /sys/module/firmware_class/parameters/path can be used
to set a custom firmware path. The fw_filesystem.sh script creates
a temporary directory to add a test firmware file to be used during
testing, in order for this to work it uses the custom path syfs file
and it was supposed to reset back the file on execution exit. The
script failed to do this due to a typo, it was using OLD_PATH instead
of OLD_FWPATH, since its inception since v3.17.
Its not as easy to just keep the old setting, it turns out that
resetting an empty setting won't actually do what we want, we need
to check if it was empty and set an empty space.
Without this we end up having the temporary path always set after
we run these tests.
Fixes: 0a8adf58475 ("test: add firmware_class loader test")
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
[ Upstream commit 0973ad97c187e06aece61f685b9c3b2d93290a73 ]
Session sets a number parameters that rely on evlist. These parameters
are not used in pipe-mode and should not be set, since evlist is
unavailable. Fix that.
Signed-off-by: David Carrillo-Cisneros <davidcc@google.com>
Cc: He Kuang <hekuang@huawei.com>
Cc: Paul Turner <pjt@google.com>
Cc: Simon Que <sque@chromium.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20170410201432.24807-6-davidcc@google.com
[ Check if file != NULL in perf_session__new(), like when used by builtin-top.c ]
[ Upstream commit 1e0d4f0200e4dbdfc38d818f329d8a0955f7c6f5 ]
__perf_session__process_pipe_events reuses the same memory buffer to
process all events in the pipe.
When reordering is needed (e.g. -b option), events are not immediately
flushed, but kept around until reordering is possible, causing
memory corruption.
The problem is usually observed by a "Unknown sample error" output. It
can easily be reproduced by:
perf record -o - noploop | perf inject -b > output
Committer testing:
Before:
$ perf record -o - stress -t 2 -c 2 | perf inject -b > /dev/null
stress: info: [8297] dispatching hogs: 2 cpu, 0 io, 0 vm, 0 hdd
stress: info: [8297] successful run completed in 2s
[ perf record: Woken up 3 times to write data ]
[ perf record: Captured and wrote 0.000 MB - ]
Warning:
Found 1 unknown events!
Is this an older tool processing a perf.data file generated by a more recent tool?
If that is not the case, consider reporting to linux-kernel@vger.kernel.org.
After:
stress: info: [9027] dispatching hogs: 2 cpu, 0 io, 0 vm, 0 hdd
stress: info: [9027] successful run completed in 2s
no symbols found in /usr/bin/stress, maybe install a debug package?
Link: http://lkml.kernel.org/r/20170410201432.24807-3-davidcc@google.com
[ Upstream commit 70946723eeb859466f026274b29c6196e39149c4 ]
On old perf, when using 'perf probe -d' to delete an inexistent event,
it returns errno, eg,
-bash-4.3# perf probe -d xxx || echo $?
Info: Event "*:xxx" does not exist.
Error: Failed to delete events.
255
But now perf_del_probe_events() will always set ret = 0, different from
previous del_perf_probe_events(). After this, it returns errno again,
eg,
-bash-4.3# ./perf probe -d xxx || echo $?
"xxx" does not hit any event.
254
And it is more appropriate to return -ENOENT instead of -EPERM.
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Hanjun Guo <guohanjun@huawei.com>
Fixes: dddc7ee32fa1 ("perf probe: Fix an error when deleting probes successfully")
Link: http://lkml.kernel.org/r/1489738592-61011-1-git-send-email-wangkefeng.wang@huawei.com
[ Upstream commit 88b897a30c525c2eee6e7f16e1e8d0f18830845e ]
This patch significantly improves the execution time of
perf_event__synthesize_mmap_events() when running perf record on systems
where processes have lots of threads.
It just happens that cat /proc/pid/maps support uses a O(N^2) algorithm to
generate each map line in the maps file. If you have 1000 threads, then you
have necessarily 1000 stacks. For each vma, you need to check if it
corresponds to a thread's stack. With a large number of threads, this can take
a very long time. I have seen latencies >> 10mn.
As of today, perf does not use the fact that a mapping is a stack, therefore we
can work around the issue by using /proc/pid/tasks/pid/maps. This entry does
not try to map a vma to stack and is thus much faster with no loss of
functonality.
The proc-map-timeout logic is kept in case users still want some upper limit.
In V2, we fix the file path from /proc/pid/tasks/pid/maps to actual
/proc/pid/task/pid/maps, tasks -> task. Thanks Arnaldo for catching this.
Committer note:
This problem seems to have been elliminated in the kernel since commit :
b18cb64ead40 ("fs/proc: Stop trying to report thread stacks").
Signed-off-by: Stephane Eranian <eranian@google.com>
Acked-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20170315135059.GC2177@redhat.com
Link: http://lkml.kernel.org/r/1489598233-25586-1-git-send-email-eranian@google.com
[ Upstream commit 4b0b3aa6a2756e6115fdf275c521e4552a7082f3 ]
Skip the sample which doesn't have branch_info to avoid segmentation
fault:
The fault can be reproduced by:
perf record -a
perf report -F cycles
Signed-off-by: Changbin Du <changbin.du@intel.com>
Fixes: 0e332f033a82 ("perf tools: Add support for cycles, weight branch_info field")
Link: http://lkml.kernel.org/r/20170313083148.23568-1-changbin.du@intel.com
commit e572d0887137acfc53f18175522964ec19d88175 upstream.
When doing a kernel build with 'make -s', everything is silenced except
the objtool build. That's because the tools tree support for silent
builds is some combination of missing and broken.
Three changes are needed to fix it:
- Makefile: propagate '-s' to the sub-make's MAKEFLAGS variable so the
tools Makefiles can see it.
- tools/scripts/Makefile.include: fix the tools Makefiles' ability to
recognize '-s'. The MAKE_VERSION and MAKEFLAGS checks are copied from
the top-level Makefile. This silences the "DESCEND objtool" message.
- tools/build/Makefile.build: add support to the tools Build files for
recognizing '-s'. Again the MAKE_VERSION and MAKEFLAGS checks are
copied from the top-level Makefile. This silences all the object
compile/link messages.
Reported-and-Tested-by: Peter Zijlstra <peterz@infradead.org>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Michal Marek <mmarek@suse.com>
Link: http://lkml.kernel.org/r/e8967562ef640c3ae9a76da4ae0f4e47df737c34.1484799200.git.jpoimboe@redhat.com
[ Upstream commit 321a7c35c90cc834851ceda18a8ee18f1d032b92 ]
Certain systems are designed to have sparse/discontiguous nodes. On
such systems, 'perf bench numa' hangs, shows wrong number of nodes and
shows values for non-existent nodes. Handle this by only taking nodes
that are exposed by kernel to userspace.
Signed-off-by: Satheesh Rajendran <sathnaga@linux.vnet.ibm.com>
Reviewed-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1edbcd353c009e109e93d78f2f46381930c340fe.1511368645.git.sathnaga@linux.vnet.ibm.com
Signed-off-by: Balamuruhan S <bala24@linux.vnet.ibm.com>
[ Upstream commit 89d0aeab4252adc2a7ea693637dd21c588bfa2d1 ]
The stdio perf top crashes when we change the terminal
window size. The reason is that we assumed we get the
perf_top pointer as a signal handler argument which is
not the case.
Changing the SIGWINCH handler logic to change global
resize variable, which is checked in the main thread
loop.
Tested-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/n/tip-ysuzwz77oev1ftgvdscn9bpu@git.kernel.org
commit ef824501f50846589f02173d73ce3fe6021a9d2a upstream.
usbip host lists devices attached to vhci_hcd on the same server
when user does attach over localhost or specifies the server as the
remote.
usbip attach -r localhost -b busid
or
usbip attach -r servername (or server IP)
Fix it to check and not list devices that are attached to vhci_hcd.
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
commit ef54cf0c600fb8f5737fb001a9e357edda1a1de8 upstream.
usbip host binds to devices attached to vhci_hcd on the same server
remote.
or
Unbind followed by bind works, however device is left in a bad state with
accesses via the attached busid result in errors and system hangs during
shutdown.
Fix it to check and bail out if the device is already attached to vhci_hcd.
commit e5dfa3f902b9a642ae8c6997d57d7c41e384a90b upstream.
The usbip userspace tools call sprintf()/snprintf() and don't check for
the return value which can lead the paths to overflow, truncating the
final file in the path.
More urgently, GCC 7 now warns that these aren't checked with
-Wformat-overflow, and with -Werror enabled in configure.ac, that makes
these tools unbuildable.
This patch fixes these problems by replacing sprintf() with snprintf() in
one place and adding checks for the return value of snprintf().
Reviewed-by: Peter Senna Tschudin <peter.senna@gmail.com>
Signed-off-by: Jonathan Dieter <jdieter@lesbg.com>
commit cfd6ed4537a9e938fa76facecd4b9cd65b6d1563 upstream.
GCC 7 now warns when switch statements fall through implicitly, and with
-Werror enabled in configure.ac, that makes these tools unbuildable.
We fix this by notifying the compiler that this particular case statement
is meant to fall through.
commit 2f2d0088eb93db5c649d2a5e34a3800a8a935fc5 upstream.
When a client has a USB device attached over IP, the vhci_hcd driver is
locally leaking a socket pointer address via the
/sys/devices/platform/vhci_hcd/status file (world-readable) and in debug
output when "usbip --debug port" is run.
Fix it to not leak. The socket pointer address is not used at the moment
and it was made visible as a convenient way to find IP address from socket
pointer address by looking up /proc/net/{tcp,tcp6}.
As this opens a security hole, the fix replaces socket pointer address with
sockfd.
Reported-by: Secunia Research <vuln@secunia.com>
commit 352909b49ba0d74929b96af6dfbefc854ab6ebb5 upstream.
This tests that the vsyscall entries do what they're expected to do.
It also confirms that attempts to read the vsyscall page behave as
expected.
If changes are made to the vsyscall code or its memory map handling,
running this test in all three of vsyscall=none, vsyscall=emulate,
and vsyscall=native are helpful.
(Because it's easy, this also compares the vsyscall results to their
vDSO equivalents.)
Note to KAISER backporters: please test this under all three
vsyscall modes. Also, in the emulate and native modes, make sure
that test_vsyscall_64 agrees with the command line or config
option as to which mode you're in. It's quite easy to mess up
the kernel such that native mode accidentally emulates
or vice versa.
Greg, etc: please backport this to all your Meltdown-patched
kernels. It'll help make sure the patches didn't regress
vsyscalls.
CSigned-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Juergen Gross <jgross@suse.com>
Link: http://lkml.kernel.org/r/2b9c5a174c1d60fd7774461d518aa75598b1d8fd.1515719552.git.luto@kernel.org
This reverts commit b5213e1e9f25ccde958aa6364815ee87fef91100 which was
commit 46aa6a302b53f543f8e8b8e1714dc5e449ad36a6 upstream.
This is being reverted because the affected commit this was trying to
fix, a8ba798bc8ec ("selftests: enable O and KBUILD_OUTPUT"), was never
backported to the 4.4-stable tree.
Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
Cc: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: "Dr. David Alan Gilbert" <dgilbert@redhat.com>
Cc: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Hillf Danton <hillf.zj@alibaba-inc.com>
Cc: Sasha Levin <alexander.levin@verizon.com>
commit 544c4605acc5ae4afe7dd5914147947db182f2fb upstream.
usbip bind writes commands followed by random string when writing to
match_busid attribute in sysfs, caused by using full variable size
instead of string length.
Signed-off-by: Juan Zea <juan.zea@qindel.com>
[ Upstream commit e7ede72a6d40cb3a30c087142d79381ca8a31dab ]
The current symbols__fixup_end() heuristic for the last entry in the rb
tree is suboptimal as it leads to not being able to recognize the symbol
in the call graph in a couple of corner cases, for example:
i) If the symbol has a start address (f.e. exposed via kallsyms)
that is at a page boundary, then the roundup(curr->start, 4096)
for the last entry will result in curr->start == curr->end with
a symbol length of zero.
ii) If the symbol has a start address that is shortly before a page
boundary, then also here, curr->end - curr->start will just be
very few bytes, where it's unrealistic that we could perform a
match against.
Instead, change the heuristic to roundup(curr->start, 4096) + 4096, so
that we can catch such corner cases and have a better chance to find
that specific symbol. It's still just best effort as the real end of the
symbol is unknown to us (and could even be at a larger offset than the
current range), but better than the current situation.
Alexei reported that he recently run into case i) with a JITed eBPF
program (these are all page aligned) as the last symbol which wasn't
properly shown in the call graph (while other eBPF program symbols in
the rb tree were displayed correctly). Since this is a generic issue,
lets try to improve the heuristic a bit.
Reported-and-Tested-by: Alexei Starovoitov <ast@kernel.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Fixes: 2e538c4a1847 ("perf tools: Improve kernel/modules symbol lookup")
Link: http://lkml.kernel.org/r/bb5c80d27743be6f12afc68405f1956a330e1bc9.1489614365.git.daniel@iogearbox.net
[ Upstream commit 46aa6a302b53f543f8e8b8e1714dc5e449ad36a6 ]
linux/tools/testing/selftests/vm $ make
gcc -Wall -I ../../../../usr/include compaction_test.c -lrt -o /compaction_test
/usr/lib/gcc/x86_64-pc-linux-gnu/4.9.4/../../../../x86_64-pc-linux-gnu/bin/ld: cannot open output file /compaction_test: Permission denied
collect2: error: ld returned 1 exit status
make: *** [../lib.mk:54: /compaction_test] Error 1
Since commit a8ba798bc8ec ("selftests: enable O and KBUILD_OUTPUT")
selftests/vm build fails if run from the "selftests/vm" directory, but
it works in the selftests/ directory. It's quicker to be able to do a
local vm-only build after a tree wipe and this patch allows for it
again.
Link: http://lkml.kernel.org/r/20170302173738.18994-4-aarcange@redhat.com
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
[ Upstream commit a6d8a21596df041f36f4c2ccc260c459e3e851f1 ]
Tests under alignment subdirectory are skipped when executed on previous
generation hardware, but harness still marks them as failed.
test: test_copy_unaligned
tags: git_version:unknown
[SKIP] Test skipped on line 26
skip: test_copy_unaligned
selftests: copy_unaligned [FAIL]
The MAGIC_SKIP_RETURN_VALUE value assigned to rc variable is retained till
the program exit which causes the test to be marked as failed.
This patch resets the value before returning to the main() routine.
With this patch the test o/p is as follows:
selftests: copy_unaligned [PASS]
Signed-off-by: Sachin Sant <sachinp@linux.vnet.ibm.com>
commit 297d6b6e56c2977fc504c61bbeeaa21296923f89 upstream.
While reading in more than one block (50) of KVP records, the allocation
goes per block, but the reads used the total number of allocated records
(without resetting the pointer/stream). This causes the records buffer to
overrun when the refresh reads more than one block over the previous
capacity (e.g. reading more than 100 KVP records whereas the in-memory
database was empty before).
Fix this by reading the correct number of KVP records from file each time.
Signed-off-by: Paul Meyer <Paul.Meyer@microsoft.com>
Signed-off-by: Long Li <longli@microsoft.com>
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
[ Upstream commit 22905582f6dd4bbd0c370fe5732c607452010c04 ]
Command perf test -v 16 (Setup struct perf_event_attr test) always
reports success even if the test case fails. It works correctly if you
also specify -F (for don't fork).
root@s35lp76 perf]# ./perf test -v 16
15: Setup struct perf_event_attr :
--- start ---
running './tests/attr/test-record-no-delay'
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.002 MB /tmp/tmp4E1h7R/perf.data
(1 samples) ]
expected task=0, got 1
expected precise_ip=0, got 3
expected wakeup_events=1, got 0
FAILED './tests/attr/test-record-no-delay' - match failure
test child finished with 0
---- end ----
Setup struct perf_event_attr: Ok
The reason for the wrong error reporting is the return value of the
system() library call. It is called in run_dir() file tests/attr.c and
returns the exit status, in above case 0xff00.
This value is given as parameter to the exit() function which can only
handle values 0-0xff.
The child process terminates with exit value of 0 and the parent does
not detect any error.
This patch corrects the error reporting and prints the correct test
result.
Signed-off-by: Thomas-Mich Richter <tmricht@linux.vnet.ibm.com>
Cc: Hendrik Brueckner <brueckner@linux.vnet.ibm.com>
Cc: Thomas-Mich Richter <tmricht@linux.vnet.ibm.com>
LPU-Reference: 20170913081209.39570-2-tmricht@linux.vnet.ibm.com
Link: http://lkml.kernel.org/n/tip-rdube6rfcjsr1nzue72c7lqn@git.kernel.org
[ Upstream commit fec8f5ae1715a01c72ad52cb2ecd8aacaf142302 ]
We weren't testing the .limit and .limit_in_pages fields very well.
Add more tests.
This addition seems to trigger the "bits 16:19 are undefined" issue
that was fixed in an earlier patch. I think that, at least on my
CPU, the high nibble of the limit ends in LAR bits 16:19.
Cc: Borislav Petkov <bpetkov@suse.de>
Link: http://lkml.kernel.org/r/5601c15ea9b3113d288953fd2838b18bedf6bc67.1509794321.git.luto@kernel.org
commit afb999cdef69148f366839e74470d8f5375ba5f1 upstream.
Some distributions (Debian, OpenSUSE) have a udev rule in place to cancel
all fallback mechanism uevents immediately. This would obviously
make it hard to test against the fallback mechanism test interface,
so we need to check for this.
Signed-off-by: Amit Pundir <amit.pundir@linaro.org>
commit 880444e214cfd293a2e8cc4bd3505f7ffa6ce33a upstream.
Error that we expect should not be spilled to stdout.
Without this we get:
./fw_filesystem.sh: line 58: printf: write error: Invalid argument
./fw_filesystem.sh: line 63: printf: write error: No such device
./fw_filesystem.sh: line 69: echo: write error: No such file or directory
./fw_filesystem.sh: filesystem loading works
./fw_filesystem.sh: async filesystem loading works
With it:
[AmitP: Dropped the async trigger testing parts from original commit]
commit 1b1fe542b6f010cf6bc7e1c92805e1c0e133e007 upstream.
Now that we've added a 'trigger_async_request' knob to test the
request_firmware_nowait() API, let's use it. Also add tests for the
empty ("") string, since there have been a couple errors in that
handling already.
Since we now have real ways that the sysfs write might fail, let's add
the appropriate check on the 'echo' lines too.
Signed-off-by: Brian Norris <computersforpeace@gmail.com>
[ Upstream commit 75fc5ae5cc53fff71041ecadeb3354a2b4c9fe42 ]
Signed-off-by: Taeung Song <treeze.taeung@gmail.com>
Link: http://lkml.kernel.org/r/1485952447-7013-2-git-send-email-treeze.taeung@gmail.com
commit b581c01fff646b5075d65359c8667de9c667da9e upstream.
On my Archlinux machine, perf faild to build like below:
CC scripts/perl/Perf-Trace-Util/Context.o
In file included from /usr/lib/perl5/core/perl/CORE/perl.h:3905:0,
from Context.xs:23:
/usr/lib/perl5/core/perl/CORE/inline.h: In function :
/usr/lib/perl5/core/perl/CORE/cop.h:612:13: warning: declaration of 'av'
shadows a previous local [-Werror-shadow]
AV *av =3D GvAV(PL_defgv);
/usr/lib/perl5/core/perl/CORE/inline.h:526:5: note: in expansion of
macro 'CX_POP_SAVEARRAY'
CX_POP_SAVEARRAY(cx);
In file included from /usr/lib/perl5/core/perl/CORE/perl.h:5853:0,
from Context.xs:23:
/usr/lib/perl5/core/perl/CORE/inline.h:518:9: note:
shadowed declaration is here
AV *av;
What I did to fix is adding '-Wno-shadow' as the error message said it's
the cause of the failure. Since it's from the perl (not perf) code
base, we don't have the control so I just wanted to ignore the warning
when compiling perl scripting code.
Committer note:
This also fixes the build on Fedora Rawhide.
Link: http://lkml.kernel.org/r/20160802024317.31725-1-namhyung@kernel.org
Cc: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
[ Upstream commit 7934c98a6e04028eb34c1293bfb5a6b0ab630b66 ]
Markus reported that perf segfaults when reading /sys/kernel/notes from
a kernel linked with GNU gold, due to what looks like a gold bug, so do
some bounds checking to avoid crashing in that case.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Report-Link: http://lkml.kernel.org/r/20161219161821.GA294@x4
Link: http://lkml.kernel.org/n/tip-ryhgs6a6jxvz207j2636w31c@git.kernel.org
[ Upstream commit 30a9c6444810429aa2b7cbfbd453ce339baaadbf ]
Those are binaries as well, so should be installed by:
make -C tools/perf install-bin'
too.
Cc: Daniel Bristot de Oliveira <bristot@redhat.com>
Link: http://lkml.kernel.org/n/tip-3841b37u05evxrs1igkyu6ks@git.kernel.org
[ Upstream commit 074859184d770824f4437dca716bdeb625ae8b1c ]
Currently, the sched:sched_switch tracepoint reports deadline tasks with
priority -1. But when reading the trace via perf script I've got the
following output:
# ./d & # (d is a deadline task, see [1])
# perf record -e sched:sched_switch -a sleep 1
# perf script
swapper 0 [000] 2146.962441: sched:sched_switch: swapper/0:0 [120] R ==> d:2593 [4294967295]
d 2593 [000] 2146.972472: sched:sched_switch: d:2593 [4294967295] R ==> g:2590 [4294967295]
The task d reports the wrong priority [4294967295]. This happens because
the "int prio" is stored in an unsigned long long val. Although it is
set as a %lld, as int is shorter than unsigned long long,
trace_seq_printf prints it as a positive number.
The fix is just to cast the val as an int, and print it as a %d,
as in the sched:sched_switch tracepoint's "format".
The output with the fix is:
# ./d &
# perf script
swapper 0 [000] 4306.374037: sched:sched_switch: swapper/0:0 [120] R ==> d:10941 [-1]
d 10941 [000] 4306.383823: sched:sched_switch: d:10941 [-1] R ==> swapper/0:0 [120]
[1] d.c
#include <stdio.h>
#include <unistd.h>
#include <sys/syscall.h>
#include <linux/types.h>
#include <linux/sched.h>
struct sched_attr {
__u32 size, sched_policy;
__u64 sched_flags;
__s32 sched_nice;
__u32 sched_priority;
__u64 sched_runtime, sched_deadline, sched_period;
int sched_setattr(pid_t pid, const struct sched_attr *attr, unsigned int flags)
return syscall(__NR_sched_setattr, pid, attr, flags);
int main(void)
struct sched_attr attr = {
.size = sizeof(attr),
.sched_policy = SCHED_DEADLINE, /* This creates a 10ms/30ms reservation */
.sched_runtime = 10 * 1000 * 1000,
.sched_period = attr.sched_deadline = 30 * 1000 * 1000,
if (sched_setattr(0, &attr, 0) < 0) {
perror("sched_setattr");
return -1;
for(;;);
Committer notes:
Got the program from the provided URL, http://bristot.me/lkml/d.c,
trimmed it and included in the cset log above, so that we have
everything needed to test it in one place.
Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/866ef75bcebf670ae91c6a96daa63597ba981f0d.1483443552.git.bristot@redhat.com
commit f952eaceb089b691eba7c4e13686e742a8f26bf5 upstream.
Intel PT uses IP compression based on the last IP. For decoding purposes,
'last IP' is not updated when a branch target has been suppressed, which is
indicated by IPBytes == 0. IPBytes is stored in the packet 'count', so
ensure never to set 'last_ip' when packet 'count' is zero.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/1495786658-18063-7-git-send-email-adrian.hunter@intel.com
commit 622b7a47b843c78626f40c1d1aeef8483383fba2 upstream.
The decoder will try to use branch packets to find an IP to start decoding
or to recover from errors. Currently the FUP packet is used only in the
case of an overflow, however there is no reason for that to be a special
case. So just use FUP always when scanning for an IP.
Link: http://lkml.kernel.org/r/1495786658-18063-8-git-send-email-adrian.hunter@intel.com
commit ee14ac0ef6827cd6f9a572cc83dd0191ea17812c upstream.
purposes, 'last IP' is considered to be reset to zero whenever there is
a synchronization packet (PSB). The decoder wasn't doing that, and was
treating the zero value to mean that there was no last IP, whereas
compression can be done against the zero value. Fix by setting last_ip
to zero when a PSB is received and keep track of have_last_ip.
Link: http://lkml.kernel.org/r/1495786658-18063-6-git-send-email-adrian.hunter@intel.com
commit e1717e0485af4f47fc4da1e979ac817f9ad61b0f upstream.
The June 2015 Intel SDM introduced IP Compression types 4 and 6. Refer
to section 36.4.2.2 Target IP (TIP) Packet - IP Compression.
Existing Intel PT packet decoder did not support type 4, and got type 6
wrong. Because type 3 and type 4 have the same number of bytes, the
packet 'count' has been changed from being the number of ip bytes to
being the type code. That allows the Intel PT decoder to correctly
decide whether to sign-extend or use the last ip. However that also
meant the code had to be adjusted in a number of places.
Currently hardware is not using the new compression types, so this fix
has no effect on existing hardware.
Link: http://lkml.kernel.org/r/1469005206-3049-1-git-send-email-adrian.hunter@intel.com
target
commit 80f62589fa52f530cffc50e78c0b5a2ae572d61e upstream.
When the jump instruction is displayed at the row 0 in annotate view,
the arrow is broken. An example:
16.86 │ ┌──je 82
0.01 │ movsd (%rsp),%xmm0
│ movsd 0x8(%rsp),%xmm4
│ movsd 0x8(%rsp),%xmm1
│ movsd (%rsp),%xmm3
│ divsd %xmm4,%xmm0
│ divsd %xmm3,%xmm1
│ movsd (%rsp),%xmm2
│ addsd %xmm1,%xmm0
│ addsd %xmm2,%xmm0
│ movsd %xmm0,(%rsp)
│82: sub $0x1,%ebx
83.03 │ ↑ jne 38
│ add $0x10,%rsp
│ xor %eax,%eax
│ pop %rbx
│ ← retq
The patch increments the row number before checking with 0.
Signed-off-by: Yao Jin <yao.jin@linux.intel.com>
Cc: Kan Liang <kan.liang@intel.com>
Fixes: 944e1abed9e1 ("perf ui browser: Add method to draw up/down arrow line")
Link: http://lkml.kernel.org/r/1496901704-30275-1-git-send-email-yao.jin@linux.intel.com
