O= option in Makefile
commit f82263c6989c31ae9b94cecddffb29dcbec38710 upstream.
Since commit ee0778a30153
("tools/power: turbostat: make Makefile a bit more capable")
turbostat's Makefile is using
BUILD_OUTPUT := $(PWD)
which obviously causes trouble when building "turbostat" with
make -C /usr/src/linux/tools/power/x86/turbostat ARCH=x86 turbostat
because GNU make does not update nor guarantee that $PWD is set.
This patch changes the Makefile to use $CURDIR instead, which GNU make
guarantees to set and update (i.e. when using "make -C ...") and also
adds support for the O= option (see "make help" in your root of your
kernel source tree for more details).
Link: https://bugs.gentoo.org/show_bug.cgi?id=533918
Fixes: ee0778a30153 ("tools/power: turbostat: make Makefile a bit more capable")
Signed-off-by: Thomas D. <whissi@whissi.de>
Cc: Mark Asselstine <mark.asselstine@windriver.com>
Signed-off-by: Len Brown <len.brown@intel.com>
commit f61ff6c06dc8f32c7036013ad802c899ec590607 upstream.
Linus reported perf report command being interrupted due to processing
of 'out of order' event, with following error:
Timestamp below last timeslice flush
0x5733a8 [0x28]: failed to process type: 3
I could reproduce the issue and in my case it was caused by one CPU
(mmap) being behind during record and userspace mmap reader seeing the
data after other CPUs data were already stored.
This is expected under some circumstances because we need to limit the
number of events that we queue for reordering when we receive a
PERF_RECORD_FINISHED_ROUND or when we force flush due to memory
pressure.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Matt Fleming <matt.fleming@intel.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1417016371-30249-1-git-send-email-jolsa@kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[zhangzhiqiang: backport to 3.10:
- adjust context
- commit f61ff6c06d struct events_stats was defined in tools/perf/util/event.h
while 3.10 stable defined in tools/perf/util/hist.h.
- 3.10 stable there is no pr_oe_time() which used for debug.
- After the above adjustments, becomes same to the original patch:
https://github.com/torvalds/linux/commit/f61ff6c06dc8f32c7036013ad802c899ec590607
Signed-off-by: Zhiqiang Zhang <zhangzhiqiang.zhang@huawei.com>
commit db86da7cb76f797a1a8b445166a15cb922c6ff85 upstream.
A security fix in caused the way the unprivileged remount tests were
using user namespaces to break. Tweak the way user namespaces are
being used so the test works again.
commit 4a44a19b470a886997d6647a77bb3e38dcbfa8c5 upstream.
- MNT_NODEV should be irrelevant except when reading back mount flags,
no longer specify MNT_NODEV on remount.
- Test MNT_NODEV on devpts where it is meaningful even for unprivileged mounts.
- Add a test to verify that remount of a prexisting mount with the same flags
is allowed and does not change those flags.
- Cleanup up the definitions of MS_REC, MS_RELATIME, MS_STRICTATIME that are used
when the code is built in an environment without them.
- Correct the test error messages when tests fail. There were not 5 tests
that tested MS_RELATIME.
commit 4921e320244e099bdf237fd10428594ce5f5b87d upstream.
The commit '2814eb0 perf kmem: Remove die() calls' disabled 'perf kmem'
command for machines without numa support. It made the command fail if
'/sys/devices/system/node' dir wasn't found.
Skipping the numa based initialization in case the directory is not
found and continue execution.
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1379003976-5839-5-git-send-email-jolsa@redhat.com
Cc: zhangzhiqiang <zhangzhiqiang.zhang@huawei.com>
commit db181ce011e3c033328608299cd6fac06ea50130 upstream.
Kenton Varda <kenton@sandstorm.io> discovered that by remounting a
read-only bind mount read-only in a user namespace the
MNT_LOCK_READONLY bit would be cleared, allowing an unprivileged user
to the remount a read-only mount read-write.
Upon review of the code in remount it was discovered that the code allowed
nosuid, noexec, and nodev to be cleared. It was also discovered that
the code was allowing the per mount atime flags to be changed.
The first naive patch to fix these issues contained the flaw that using
default atime settings when remounting a filesystem could be disallowed.
To avoid this problems in the future add tests to ensure unprivileged
remounts are succeeding and failing at the appropriate times.
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
commit f35f71244da6e51db4e1f2c7e318581f498ececf upstream.
It appears that no one ever run ffs-test on a big-endian machine,
since it used cpu-endianess for fs_count and hs_count fields which
should be in little-endian format. Fix by wrapping the numbers in
cpu_to_le32.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit b69e63a45f2d96a0dfe930ed20385058d4574d2f upstream.
message is currently shown as:
Error:
You may not have permission to collect %sstats.
Consider tweaking /proc/sys/kernel/perf_event_paranoid:
Note the %sstats. With patch this becomes:
Error:
You may not have permission to collect stats.
Signed-off-by: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1369526040-1368-1-git-send-email-dsahern@gmail.com
Cc: xiakaixu <xiakaixu@huawei.com>
commit 2b92865e648ce04a39fda4f903784a5d01ecb0dc upstream.
turbostat uses inline assembly to call cpuid. On 32-bit x86, on systems
that have certain security features enabled by default that make -fPIC
the default, this causes a build error:
turbostat.c: In function ‘check_cpuid’:
turbostat.c:1906:2: error: PIC register clobbered by ‘ebx’ in ‘asm’
asm("cpuid" : "=a" (fms), "=c" (ecx), "=d" (edx) : "a" (1) : "ebx");
GCC provides a header cpuid.h, containing a __get_cpuid function that
works with both PIC and non-PIC. (On PIC, it saves and restores ebx
around the cpuid instruction.) Use that instead.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
commit b731f3119de57144e16c19fd593b8daeb637843e upstream.
turbostat's Makefile puts arch/x86/include/uapi/ in the include path, so
that it can include <asm/msr.h> from it. It isn't in general safe to
include even uapi headers directly from the kernel tree without
processing them through scripts/headers_install.sh, but asm/msr.h
happens to work.
However, that include path can break with some versions of system
headers, by overriding some system headers with the unprocessed versions
directly from the kernel source. For instance:
In file included from /build/x86-generic/usr/include/bits/sigcontext.h:28:0,
from /build/x86-generic/usr/include/signal.h:339,
from /build/x86-generic/usr/include/sys/wait.h:31,
from turbostat.c:27:
../../../../arch/x86/include/uapi/asm/sigcontext.h:4:28: fatal error: linux/compiler.h: No such file or directory
This occurs because the system bits/sigcontext.h on that build system
includes <asm/sigcontext.h>, and asm/sigcontext.h in the kernel source
includes <linux/compiler.h>, which scripts/headers_install.sh would have
filtered out.
Since turbostat really only wants a single header, just include that one
header rather than putting an entire directory of kernel headers on the
include path.
In the process, switch from msr.h to msr-index.h, since turbostat just
wants the MSR numbers.
commit ad85ace07a05062ef6b59c35a5e80b6eaee1eee6 upstream.
Currently, if we use perf kvm --guestkallsyms --guestmodules report, we
can not get the perf information from perf data file. All sample are
shown as unknown.
Reproducing steps:
# perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules record -a sleep 1
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.624 MB perf.data.guest (~27260 samples) ]
# perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules report |grep %
100.00% [guest/6471] [unknown] [g] 0xffffffff8164f330
This bug was introduced by 207b57926 (perf kvm: Fix regression with guest machine creation).
In original code, it uses perf_session__find_machine(), it means we deliver symbol to machine
which has the same pid, if no machine found, deliver it to *default* guest. But if we use
perf_session__findnew_machine() here, if no machine was found, new machine with pid will be built
and added. Then the default guest which with pid == 0 will never get a symbol.
And because the new machine initialized here has no kernel map created, the symbol delivered to
it will be marked as "unknown".
This patch here is to revert commit 207b57926 and fix the SEGFAULT bug in another way.
Verification steps:
# ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules record -a sleep 1
[ perf record: Captured and wrote 0.651 MB perf.data.guest (~28437 samples) ]
# ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules report |grep %
22.64% :6471 [guest.kernel.kallsyms] [g] update_rq_clock.part.70
19.99% :6471 [guest.kernel.kallsyms] [g] d_free
18.46% :6471 [guest.kernel.kallsyms] [g] bio_phys_segments
16.25% :6471 [guest.kernel.kallsyms] [g] dequeue_task
12.78% :6471 [guest.kernel.kallsyms] [g] __switch_to
7.91% :6471 [guest.kernel.kallsyms] [g] scheduler_tick
1.75% :6471 [guest.kernel.kallsyms] [g] native_apic_mem_write
0.21% :6471 [guest.kernel.kallsyms] [g] apic_timer_interrupt
Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com>
Acked-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/1387564907-3045-1-git-send-email-yangds.fnst@cn.fujitsu.com
commit 3b16ff89676d9902dc39976aee3cb0314ee37d93 upstream.
Cast __u64 to u64 to silence this warning on older distros, such as
Fedora 12:
CC /tmp/build/perf/util/scripting-engines/trace-event-perl.o
cc1: warnings being treated as errors
util/scripting-engines/trace-event-perl.c: In function ‘perl_process_tracepoint’:
util/scripting-engines/trace-event-perl.c:285: error: format ‘%lu’ expects type ‘long unsigned int’, but argument 2 has type ‘__u64’
make[1]: *** [/tmp/build/perf/util/scripting-engines/trace-event-perl.o] Error 1
make: *** [install] Error 2
make: Leaving directory `/home/acme/git/linux/tools/perf'
[acme@fedora12 linux]$
Reported-by: Waiman Long <Waiman.Long@hp.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Link: http://lkml.kernel.org/n/tip-nlxofdqcdjfm0w9o6bgq4kqv@git.kernel.org
Link: http://lkml.kernel.org/r/1381265120-58532-1-git-send-email-Waiman.Long@hp.com
Cc: Xie XiuQi <xiexiuqi@huawei.com>
commit f447ef4a56dee4b68a91460bcdfe06b5011085f2 upstream.
If a user calls 'cpupower set --perf-bias 15', the process will end with
a SIGSEGV in libc because cpupower-set passes a NULL optarg to the atoi
call. This is because the getopt_long structure currently has all of
the options as having an optional_argument when they really have a
required argument. We change the structure to use required_argument to
match the short options and it resolves the issue.
This fixes https://bugzilla.redhat.com/show_bug.cgi?id=1000439
Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Thomas Renninger <trenn@suse.de>
commit 53805eca3d89b095062c11a6798689bb0af09216 upstream.
The 4fb71074a570 (perf ui/hist: Consolidate hpp helpers) cset introduced
a cast of percent_color_snprintf to a function pointer type with
varargs. Change percent_color_snprintf to be variadic and remove the
cast.
The symptom of this was all percentages being reported as 0.00% in perf
report --stdio output on the armhf arch.
Signed-off-by: Michael Hudson-Doyle <michael.hudson@linaro.org>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Jean Pihet <jean.pihet@linaro.org>
Link: http://lkml.kernel.org/r/87zjppvw7y.fsf@canonical.com
commit ce7eebe5c3deef8e19c177c24ee75843256e69ca upstream.
The compilation only looks for linux/magic.h from the default include
paths, which does not include the source tree. This results in a build
error if linux/magic.h is not available or not installed.
For example, this build error occurs on CentOS 5.
$ make -C tools/lib/lk V=1
gcc -o debugfs.o -c -ggdb3 -Wall -Wextra -std=gnu99 -Werror -O6
-D_FORTIFY_SOURCE=2 -Wbad-function-cast -Wdeclaration-after-statement
-Wformat-security -Wformat-y2k -Winit-self -Wmissing-declarations
-Wmissing-prototypes -Wnested-externs -Wno-system-headers
-Wold-style-definition -Wpacked -Wredundant-decls -Wshadow
-Wstrict-aliasing=3 -Wstrict-prototypes -Wswitch-default -Wswitch-enum
-Wundef -Wwrite-strings -Wformat -fPIC -D_LARGEFILE64_SOURCE
-D_FILE_OFFSET_BITS=64 debugfs.c
debugfs.c:8:25: error: linux/magic.h: No such file or directory
The only symbol from linux/magic.h needed by debugfs.c is DEBUGFS_MAGIC,
and that is already defined in debugfs.h. linux/magic.h isn't providing
any extra symbols and can unincluded. This is similar to the approach by
perf, which has its own magic.h wrapper at
tools/perf/util/include/linux/magic.h
Signed-off-by: Vinson Lee <vlee@twitter.com>
Acked-by: Borislav Petkov <bp@suse.de>
Cc: Borislav Petkov <bp@suse.de>
Cc: Vinson Lee <vlee@freedesktop.org>
Link: http://lkml.kernel.org/r/1379546200-17028-1-git-send-email-vlee@freedesktop.org
commit 89365e6c9ad4c0e090e4c6a4b67a3ce319381d89 upstream.
Need to check for /dev/zero.
Most likely more strings are missing too.
Link: http://lkml.kernel.org/r/1366848182-30449-1-git-send-email-andi@firstfloor.org
commit a363a9da65d253fa7354ce5fd630f4f94df934cc upstream.
Among other things, the following:
commit 31160d7feab786c991780d7f0ce2755a469e0e5e
Date: Tue Jan 8 16:22:36 2013 -0500
perf tools: Fix GNU make v3.80 compatibility issue
attempts to aid the user by tapping into an existing error message,
as described in the commit message:
... Also fix an issue where _get_attempt was called with only
one argument. This prevented the error message from printing
the name of the variable that can be used to fix the problem.
or more precisely:
-$(if $($(1)),$(call _ge_attempt,$($(1)),$(1)),$(call _ge_attempt,$(2)))
+$(if $($(1)),$(call _ge_attempt,$($(1)),$(1)),$(call _ge_attempt,$(2),$(1)))
However, The "missing" argument was in fact missing on purpose; it's
absence is a signal that the error message should be skipped, because
the failure would be due to the default value, not any user-supplied
value. This can be seen in how `_ge_attempt' uses `gea_err' (in the
config/utilities.mak file):
_ge_attempt = $(if $(get-executable),$(get-executable),$(_gea_warn)$(call _gea_err,$(2)))
_gea_warn = $(warning The path '$(1)' is not executable.)
_gea_err = $(if $(1),$(error Please set '$(1)' appropriately))
That is, because the argument is no longer missing, the value `$(1)'
(associated with `_gea_err') always evaluates to true, thus always
triggering the error condition that is meant to be reserved for
only the case when a user explicitly supplies an invalid value.
Concretely, the result is a regression in the Makefile's configuration
of python support; rather than gracefully disable support when the
relevant executables cannot be found according to default values, the
build process halts in error as though the user explicitly supplied
the values.
This new commit simply reverts the offending one-line change.
Reported-by: Pekka Enberg <penberg@kernel.org>
Link: http://lkml.kernel.org/r/CAOJsxLHv17Ys3M7P5q25imkUxQW6LE_vABxh1N3Tt7Mv6Ho4iw@mail.gmail.com
Signed-off-by: Michael Witten <mfwitten@gmail.com>
Cc: Mark Brown <broonie@sirena.org.uk>
commit ed4bb9744b41d39ba35080c2390e201575121dc7 upstream.
Each subnet string needs to be separated with a semicolon. Fix this bug.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
On platforms with C8-C10 support, the additional C-states cause
turbostat to overrun its output buffer of 128 bytes per CPU. Increase
this to 256 bytes per CPU.
[ As a bugfix, this should go into 3.10; however, since the C8-C10
support didn't go in until after 3.9, this need not go into any stable
kernel. ]
Cc: Len Brown <len.brown@intel.com>
Revert commit 58c7be84fec8 ("selftest: add simple test for soft-dirty
bit"). This is the self test for Pavel's pagemap2 patches which didn't
actually get merged.
Reported-by: Pavel Emelyanov <xemul@parallels.com>
We can read /proc/kallsyms in a fraction of a second, so why waste
a further fraction of a second showing progress?
The sort order of dictionaries in Python is undocumented. Use
tuples instead, which are documented to be lexically ordered.
The comparison between traced and symbol addresses is backwards: if
the traced address doesn't exactly match a symbol (which we don't
expect it to), we'll show the next symbol and the offset to it,
whereas we should show the previous symbol and the offset from it.
Cc: stable@vger.kernel.org
This works much better if we don't treat protocol numbers as addresses.
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux
Pull idle update from Len Brown:
"Add support for new Haswell-ULT CPU idle power states"
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux:
intel_idle: initial C8, C9, C10 support
tools/power turbostat: display C8, C9, C10 residency
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio & lguest updates from Rusty Russell:
"Lots of virtio work which wasn't quite ready for last merge window.
Plus I dived into lguest again, reworking the pagetable code so we can
move the switcher page: our fixmaps sometimes take more than 2MB now..."
Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename.
Hopefully correctly resolved.
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits)
caif_virtio: Remove bouncing email addresses
lguest: improve code readability in lg_cpu_start.
virtio-net: fill only rx queues which are being used
lguest: map Switcher below fixmap.
lguest: cache last cpu we ran on.
lguest: map Switcher text whenever we allocate a new pagetable.
lguest: don't share Switcher PTE pages between guests.
lguest: expost switcher_pages array (as lg_switcher_pages).
lguest: extract shadow PTE walking / allocating.
lguest: make check_gpte et. al return bool.
lguest: assume Switcher text is a single page.
lguest: rename switcher_page to switcher_pages.
lguest: remove RESERVE_MEM constant.
lguest: check vaddr not pgd for Switcher protection.
lguest: prepare to make SWITCHER_ADDR a variable.
virtio: console: replace EMFILE with EBUSY for already-open port
virtio-scsi: reset virtqueue affinity when doing cpu hotplug
virtio-scsi: introduce multiqueue support
virtio-scsi: push vq lock/unlock into virtscsi_vq_done
virtio-scsi: pass struct virtio_scsi to virtqueue completion function
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
* Dump signals from process-wide and per-thread queues with
different sizes of buffers.
* Check error paths for buffers with restricted permissions. A part of
buffer or a whole buffer is for read-only.
* Try to get nonexistent signal.
Signed-off-by: Andrew Vagin <avagin@openvz.org>
Cc: Roland McGrath <roland@redhat.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Pedro Alves <palves@redhat.com>
It creates a mapping of 3 pages and checks that reads, writes and
clear-refs result in present and soft-dirt bits reported from pagemap2
set as expected.
[akpm@linux-foundation.org: alphasort the Makefile TARGETS to reduce rejects]
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
Pull trivial tree updates from Jiri Kosina:
"Usual stuff, mostly comment fixes, typo fixes, printk fixes and small
code cleanups"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits)
mm: Convert print_symbol to %pSR
gfs2: Convert print_symbol to %pSR
m32r: Convert print_symbol to %pSR
iostats.txt: add easy-to-find description for field 6
x86 cmpxchg.h: fix wrong comment
treewide: Fix typo in printk and comments
doc: devicetree: Fix various typos
docbook: fix 8250 naming in device-drivers
pata_pdc2027x: Fix compiler warning
treewide: Fix typo in printks
mei: Fix comments in drivers/misc/mei
treewide: Fix typos in kernel messages
pm44xx: Fix comment for "CONFIG_CPU_IDLE"
doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP"
mmzone: correct "pags" to "pages" in comment.
kernel-parameters: remove outdated 'noresidual' parameter
Remove spurious _H suffixes from ifdef comments
sound: Remove stray pluses from Kconfig file
radio-shark: Fix printk "CONFIG_LED_CLASS"
doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE
Pull perf updates from Ingo Molnar:
"Features:
- Add "uretprobes" - an optimization to uprobes, like kretprobes are
an optimization to kprobes. "perf probe -x file sym%return" now
works like kretprobes. By Oleg Nesterov.
- Introduce per core aggregation in 'perf stat', from Stephane
Eranian.
- Add memory profiling via PEBS, from Stephane Eranian.
- Event group view for 'annotate' in --stdio, --tui and --gtk, from
Namhyung Kim.
- Add support for AMD NB and L2I "uncore" counters, by Jacob Shin.
- Add Ivy Bridge-EP uncore support, by Zheng Yan
- IBM zEnterprise EC12 oprofile support patchlet from Robert Richter.
- Add perf test entries for checking breakpoint overflow signal
handler issues, from Jiri Olsa.
- Add perf test entry for for checking number of EXIT events, from
Namhyung Kim.
- Add perf test entries for checking --cpu in record and stat, from
Jiri Olsa.
- Introduce perf stat --repeat forever, from Frederik Deweerdt.
- Add --no-demangle to report/top, from Namhyung Kim.
- PowerPC fixes plus a couple of cleanups/optimizations in uprobes
and trace_uprobes, by Oleg Nesterov.
Various fixes and refactorings:
- Fix dependency of the python binding wrt libtraceevent, from
Naohiro Aota.
- Simplify some perf_evlist methods and to allow 'stat' to share code
with 'record' and 'trace', by Arnaldo Carvalho de Melo.
- Remove dead code in related to libtraceevent integration, from
Namhyung Kim.
- Revert "perf sched: Handle PERF_RECORD_EXIT events" to get 'perf
sched lat' back working, by Arnaldo Carvalho de Melo
- We don't use Newt anymore, just plain libslang, by Arnaldo Carvalho
de Melo.
- Kill a bunch of die() calls, from Namhyung Kim.
- Fix build on non-glibc systems due to libio.h absence, from Cody P
Schafer.
- Remove some perf_session and tracing dead code, from David Ahern.
- Honor parallel jobs, fix from Borislav Petkov
- Introduce tools/lib/lk library, initially just removing duplication
among tools/perf and tools/vm. from Borislav Petkov
... and many more I missed to list, see the shortlog and git log for
more details."
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (136 commits)
perf/x86/intel/P4: Robistify P4 PMU types
perf/x86/amd: Fix AMD NB and L2I "uncore" support
perf/x86/amd: Remove old-style NB counter support from perf_event_amd.c
perf/x86: Check all MSRs before passing hw check
perf/x86/amd: Add support for AMD NB and L2I "uncore" counters
perf/x86/intel: Add Ivy Bridge-EP uncore support
perf/x86/intel: Fix SNB-EP CBO and PCU uncore PMU filter management
perf/x86: Avoid kfree() in CPU_{STARTING,DYING}
uprobes/perf: Avoid perf_trace_buf_prepare/submit if ->perf_events is empty
uprobes/tracing: Don't pass addr=ip to perf_trace_buf_submit()
uprobes/tracing: Change create_trace_uprobe() to support uretprobes
uprobes/tracing: Make seq_printf() code uretprobe-friendly
uprobes/tracing: Make register_uprobe_event() paths uretprobe-friendly
uprobes/tracing: Make uprobe_{trace,perf}_print() uretprobe-friendly
uprobes/tracing: Introduce is_ret_probe() and uretprobe_dispatcher()
uprobes/tracing: Introduce uprobe_{trace,perf}_print() helpers
uprobes/tracing: Generalize struct uprobe_trace_entry_head
uprobes/tracing: Kill the pointless local_save_flags/preempt_count calls
uprobes/tracing: Kill the pointless seq_print_ip_sym() call
uprobes/tracing: Kill the pointless task_pt_regs() calls
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest
Pull ktest update from Steven Rostedt:
"A couple of fixes to handle a config file that tests multiple machines
and has conflicts it the grub menus. That is, if the machines use the
same grub menu name, but they are at different locations in the
menu.lst file"
* tag 'ktest-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest:
ktest: Reset grub menu cache with different machines
ktest: Allow tests to use different GRUB_MENUs
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver update from Greg Kroah-Hartman:
"Here's the big char / misc driver update for 3.10-rc1
A number of various driver updates, the majority being new
functionality in the MEI driver subsystem (it's now a subsystem, it
started out just a single driver), extcon updates, memory updates,
hyper-v updates, and a bunch of other small stuff that doesn't fit in
any other tree.
All of these have been in linux-next for a while"
* tag 'char-misc-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (148 commits)
Tools: hv: Fix a checkpatch warning
tools: hv: skip iso9660 mounts in hv_vss_daemon
tools: hv: use FIFREEZE/FITHAW in hv_vss_daemon
tools: hv: use getmntent in hv_vss_daemon
tools: hv: fix checks for origin of netlink message in hv_vss_daemon
Tools: hv: fix warnings in hv_vss_daemon
misc: mark spear13xx-pcie-gadget as broken
mei: fix krealloc() misuse in in mei_cl_irq_read_msg()
mei: reduce flow control only for completed messages
mei: reseting -> resetting
mei: fix reading large reposnes
mei: revamp mei_irq_read_client_message function
mei: revamp mei_amthif_irq_read_message
mei: revamp hbm state machine
Revert "drivers/scsi: use module_pcmcia_driver() in pcmcia drivers"
Revert "scsi: pcmcia: nsp_cs: remove module init/exit function prototypes"
mei: wd: fix line over 80 characters
misc: tsl2550: Use dev_pm_ops
Testing like this for TP_STATUS_AVAILABLE clearly is a stupid bug
since it always returns true. Fix this by only checking for flags
where the kernel owns the packet and negate this result, since we
also could run into the non-zero status TP_STATUS_WRONG_FORMAT
and need to reclaim frames.
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Different tests may use a different machine. In such cases, we need to
try to get the current grub menu index. If the same grub menu is used
for two different machines, it may not be at the same index on the
second machine. A search for the index must be performed again.
Fix a checkpatch warning.
fsreeze does not work for iso9660 filesystems. A ENOSUPP may be caught
in the freeze case, but the subsequent thaw call would fail and leads to
a false error.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
As suggested by Paolo Bonzini, use ioctl instead of calling fsfreeze.
As suggested by Paolo Bonzini, use getmntent instead of parsing output
of mount(1).
Similar to what commit 95a69adab9acfc3981c504737a2b6578e4d846ef ("tools:
hv: Netlink source address validation allows DoS") does in
hv_kvp_daemon, improve checks for origin of netlink connector message.
This change fixes a few compile errors:
hv_vss_daemon.c:64:15: warning: unknown escape sequence '\/'
hv_vss_daemon.c: In function 'vss_operate':
hv_vss_daemon.c:66: warning: 'return' with no value, in function returning non-void
hv_vss_daemon.c: In function 'main':
hv_vss_daemon.c:130: warning: ignoring return value of 'daemon', declared with attribute warn_unused_result
hv_vss_daemon.c:47: warning: 'fs_op' may be used uninitialized in this function
drivers/net/ethernet/emulex/benet/be_main.c
drivers/net/ethernet/intel/igb/igb_main.c
drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c
include/net/scm.h
net/batman-adv/routing.c
net/ipv4/tcp_input.c
The e{uid,gid} --> {uid,gid} credentials fix conflicted with the
cleanup in net-next to now pass cred structs around.
The be2net driver had a bug fix in 'net' that overlapped with the VLAN
interface changes by Patrick McHardy in net-next.
An IGB conflict existed because in 'net' the build_skb() support was
reverted, and in 'net-next' there was a comment style fix within that
code.
Several batman-adv conflicts were resolved by making sure that all
calls to batadv_is_my_mac() are changed to have a new bat_priv first
argument.
Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO
rewrite in 'net-next', mostly overlapping changes.
Thanks to Stephen Rothwell and Antonio Quartulli for help with several
of these merge resolutions.
Display residency in the new C-states, C8, C9, C10.
C8, C9, C10 are present on some:
"Fourth Generation Intel(R) Core(TM) Processors",
which are based on Intel(R) microarchitecture code name Haswell.
Signed-off-by: Kristen Carlson Accardi <kristen@linux.intel.com>
Pull idle patches from Len Brown:
"A pair of small patches for 3.9-rc7.
This CPU-id should have been included in the ones that we updated
earlier in 3.9. This pair of patches will allow this flavor of
Haswell to behave like the other flavors."
tools/power turbostat: additional Haswell CPU-id
intel_idle: additional Haswell CPU-id
Correct spelling typos in printk and comments.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
This patch adds a simple test case that probes the packet socket's
TPACKET_V1, TPACKET_V2 and TPACKET_V3 behavior regarding mmap(2)'ed
I/O for a small burst of 100 packets. The test currently runs for ...
TPACKET_V1: RX_RING, TX_RING
TPACKET_V2: RX_RING, TX_RING
TPACKET_V3: RX_RING
... and will output on success:
test: TPACKET_V1 with PACKET_RX_RING .................... 100 pkts (9600 bytes)
test: TPACKET_V1 with PACKET_TX_RING .................... 100 pkts (9600 bytes)
test: TPACKET_V2 with PACKET_RX_RING .................... 100 pkts (9600 bytes)
test: TPACKET_V2 with PACKET_TX_RING .................... 100 pkts (9600 bytes)
test: TPACKET_V3 with PACKET_RX_RING .................... 100 pkts (9600 bytes)
OK. All tests passed
Reusable parts of psock_fanout.c have been put into a psock_lib.h
file for common usage. Test case successfully tested on x86_64.
Initial motivation was to avoid the confusing exit when when '/' is
pressed in non verbose mode, as specified in the help line searches
are only available in verbose mode.
Cc: Namhyung Kim <namhyung@gmail.com>
Link: http://lkml.kernel.org/n/tip-20xezxim2y4agmkx7f3sucll@git.kernel.org
