path: root/tools
2016-11-10perf build: Fix traceevent plugins build raceJiri Olsa
commit 67befc652845c8ffbefc8d173a6e6ced14d472f1 upstream. Ingo reported following build failure: $ make clean install ... CC plugin_kmem.o fixdep: error opening depfile: ./.plugin_hrtimer.o.d: No such file or directory /home/mingo/tip/tools/build/Makefile.build:77: recipe for target 'plugin_hrtimer.o' failed make[3]: *** [plugin_hrtimer.o] Error 2 Makefile:189: recipe for target 'plugin_hrtimer-in.o' failed make[2]: *** [plugin_hrtimer-in.o] Error 2 Makefile.perf:414: recipe for target 'libtraceevent_plugins' failed make[1]: *** [libtraceevent_plugins] Error 2 make[1]: *** Waiting for unfinished jobs.... Currently we have the install-traceevent-plugins target being dependent on $(LIBTRACEEVENT), which will actualy not build any plugin. So the install-traceevent-plugins target itself will try to build plugins, but.. Plugins built is also triggered by perf build itself via libtraceevent_plugins target. This might cause a race having one make thread removing temp files from another and result in above error. Fixing this by having proper plugins build dependency before installing plugins. Reported-and-Tested-by:: Ingo Molnar <mingo@kernel.org> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1448546044-28973-3-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Thomas Backlund <tmb@mageia.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31perf symbols: Fixup symbol sizes before picking best onesArnaldo Carvalho de Melo
commit 432746f8e0b6a82ba832b771afe31abd51af6752 upstream. When we call symbol__fixup_duplicate() we use algorithms to pick the "best" symbols for cases where there are various functions/aliases to an address, and those check zero size symbols, which, before calling symbol__fixup_end() are _all_ symbols in a just parsed kallsyms file. So first fixup the end, then fixup the duplicates. Found while trying to figure out why 'perf test vmlinux' failed, see the output of 'perf test -v vmlinux' to see cases where the symbols picked as best for vmlinux don't match the ones picked for kallsyms. Cc: Anton Blanchard <anton@samba.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Fixes: 694bf407b061 ("perf symbols: Add some heuristics for choosing the best duplicate symbol") Link: http://lkml.kernel.org/n/tip-rxqvdgr0mqjdxee0kf8i2ufn@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31perf symbols: Check symbol_conf.allow_aliases for kallsyms loading tooArnaldo Carvalho de Melo
commit c97b40e4d15f13a36cd037d598e45cbe9e1e5757 upstream. We can allow aliases to be kept, but we were checking this just when loading vmlinux files, be consistent, do it for any symbol table loading code that calls symbol__fixup_duplicate() by making this function check .allow_aliases instead. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Fixes: 680d926a8cb0 ("perf symbols: Allow symbol alias when loading map for symbol name") Link: http://lkml.kernel.org/n/tip-z0avp0s6cfjckc4xj3pdfjdz@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31perf hists browser: Fix event group displayNamhyung Kim
commit d9ea48bc4e7cc297ca1073fa3f90ed80d964b7b4 upstream. Milian reported that the event group on TUI shows duplicated overhead. This was due to a bug on calculating hpp->buf position. The hpp_advance() was called from __hpp__slsmg_color_printf() on TUI but it's already called from the hpp__call_print_fn macro in __hpp__fmt(). The end result is that the print function returns number of bytes it printed but the buffer advanced twice of the length. This is generally not a problem since it doesn't need to access the buffer again. But with event group, overhead needs to be printed multiple times and hist_entry__snprintf_alignment() tries to fill the space with buffer after it printed. So it (brokenly) showed the last overhead again. The bug was there from the beginning, but I think it's only revealed when the alignment function was added. Reported-by: Milian Wolff <milian.wolff@kdab.com> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Fixes: 89fee7094323 ("perf hists: Do column alignment on the format iterator") Link: http://lkml.kernel.org/r/20160912061958.16656-2-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-31perf stat: Fix interval output valuesJiri Olsa
commit 51fd2df1e882a3c2a3f4b6c9ff243a93c9046dba upstream. We broke interval data displays with commit: 3f416f22d1e2 ("perf stat: Do not clean event's private stats") This commit removed stats cleaning, which is important for '-r' option to carry counters data over the whole run. But it's necessary to clean it for interval mode, otherwise the displayed value is avg of all previous values. Before: $ perf stat -e cycles -a -I 1000 record # time counts unit events 1.000240796 75,216,287 cycles 2.000512791 107,823,524 cycles $ perf stat report # time counts unit events 1.000240796 75,216,287 cycles 2.000512791 91,519,906 cycles Now: $ perf stat report # time counts unit events 1.000240796 75,216,287 cycles 2.000512791 107,823,524 cycles Notice the second value being bigger (91,.. < 107,..). This could be easily verified by using perf script which displays raw stat data: $ perf script CPU THREAD VAL ENA RUN TIME EVENT 0 -1 23855779 1000209530 1000209530 1000240796 cycles 1 -1 33340397 1000224964 1000224964 1000240796 cycles 2 -1 15835415 1000226695 1000226695 1000240796 cycles 3 -1 2184696 1000228245 1000228245 1000240796 cycles 0 -1 97014312 2000514533 2000514533 2000512791 cycles 1 -1 46121497 2000543795 2000543795 2000512791 cycles 2 -1 32269530 2000543566 2000543566 2000512791 cycles 3 -1 7634472 2000544108 2000544108 2000512791 cycles The sum of the first 4 values is the first interval aggregated value: 23855779 + 33340397 + 15835415 + 2184696 = 75,216,287 The sum of the second 4 values minus first value is the second interval aggregated value: 97014312 + 46121497 + 32269530 + 7634472 - 75216287 = 107,823,524 Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1454485436-20639-1-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jeremy Linton <jeremy.linton@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28perf intel-pt: Fix MTC timestamp calculation for large MTC periodsAdrian Hunter
commit 3bccbe20f6d188ce7b00326e776b745cfd35b10a upstream. The MTC packet provides a 8-bit slice of CTC which is related to TSC by the TMA packet, however the TMA packet only provides the lower 16 bits of CTC. If mtc_shift > 8 then some of the MTC bits are not in the CTC provided by the TMA packet. Fix-up the last_mtc calculated from the TMA packet by copying the missing bits from the current MTC assuming the least difference between the two, and that the current MTC comes after last_mtc. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1475062896-22274-2-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28perf intel-pt: Fix estimated timestamps for cycle-accurate modeAdrian Hunter
commit 51ee6481fa8e879cc942bcc1b0af713e158b7a98 upstream. In cycle-accurate mode, timestamps can be calculated from CYC packets. The decoder also estimates timestamps based on the number of instructions since the last timestamp. For that to work in cycle-accurate mode, the instruction count needs to be reset to zero when a timestamp is calculated from a CYC packet, but that wasn't happening, so fix it. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1475062896-22274-1-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-28perf intel-pt: Fix snapshot overlap detection decoder errorsAdrian Hunter
commit 810c398bc09b2f2dfde52a7d2483a710612c5fb8 upstream. Fix occasional decoder errors decoding trace data collected in snapshot mode. Snapshot mode can take successive snapshots of trace which might overlap. The decoder checks whether there is an overlap but only looks at the current and previous buffer. However buffers that do not contain synchronization (i.e. PSB) packets cannot be decoded or used for overlap checking. That means the decoder actually needs to check overlaps between the current buffer and the previous buffer that contained usable data. Make that change. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Masami Hiramatsu <mhiramat@kernel.org> Cc: Mathieu Poirier <mathieu.poirier@linaro.org> Link: http://lkml.kernel.org/r/1474641528-18776-10-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-07tools/vm/slabinfo: fix an unintentional printfDan Carpenter
commit 2d6a4d64812bb12dda53704943b61a7496d02098 upstream. The curly braces are missing here so we print stuff unintentionally. Fixes: 9da4714a2d44 ('slub: slabinfo update for cmpxchg handling') Link: http://lkml.kernel.org/r/20160715211243.GE19522@mwanda Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: Laura Abbott <labbott@fedoraproject.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-15tools: hv: report ENOSPC errors in hv_fcopy_daemonOlaf Hering
[ Upstream commit b4ed5d1682c6613988c2eb1de55df5ac9988afcc ] Currently some "Unspecified error 0x80004005" is reported on the Windows side if something fails. Handle the ENOSPC case and return ERROR_DISK_FULL, which allows at least Copy-VMFile to report a meaning full error. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07perf intel-pt: Fix occasional decoding errors when tracing system-wideAdrian Hunter
commit 3d918fb13abdbeca7947578f5d7e426eafad7f5e upstream. In order to successfully decode Intel PT traces, context switch events are needed from the moment the trace starts. Currently that is ensured by using the 'immediate' flag which enables the switch event when it is opened. However, since commit 86c2786994bd ("perf intel-pt: Add support for PERF_RECORD_SWITCH") that might not always happen. When tracing system-wide the context switch event is added to the tracking event which was not set as 'immediate'. Change that so it is. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Fixes: 86c2786994bd ("perf intel-pt: Add support for PERF_RECORD_SWITCH") Link: http://lkml.kernel.org/r/1471245784-22580-1-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-07tools/testing/nvdimm: fix SIGTERM vs hotplug crashDan Williams
commit d8d378fa1a0c98ecb50ca52c9bf3bc14e25aa2d2 upstream. The unit tests crash when hotplug races the previous probe. This race requires that the loading of the nfit_test module be terminated with SIGTERM, and the module to be unloaded while the ars scan is still running. In contrast to the normal nfit driver, the unit test calls acpi_nfit_init() twice to simulate hotplug, whereas the nominal case goes through the acpi_nfit_notify() event handler. The acpi_nfit_notify() path is careful to flush the previous region registration before servicing the hotplug event. The unit test was missing this guarantee. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff810cdce7>] pwq_activate_delayed_work+0x47/0x170 [..] Call Trace: [<ffffffff810ce186>] pwq_dec_nr_in_flight+0x66/0xa0 [<ffffffff810ce490>] process_one_work+0x2d0/0x680 [<ffffffff810ce331>] ? process_one_work+0x171/0x680 [<ffffffff810ce88e>] worker_thread+0x4e/0x480 [<ffffffff810ce840>] ? process_one_work+0x680/0x680 [<ffffffff810ce840>] ? process_one_work+0x680/0x680 [<ffffffff810d5343>] kthread+0xf3/0x110 [<ffffffff8199846f>] ret_from_fork+0x1f/0x40 [<ffffffff810d5250>] ? kthread_create_on_node+0x230/0x230 Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-06-01perf test: Fix build of BPF and LLVM on older glibc librariesArnaldo Carvalho de Melo
commit 916d4092a1d2d7bb50630497be71ee4c4c2807fa upstream. $ rpm -q glibc glibc-2.12-1.166.el6_7.1.x86_64 <SNIP> CC /tmp/build/perf/tests/llvm.o cc1: warnings being treated as errors tests/llvm.c: In function ‘test_llvm__fetch_bpf_obj’: tests/llvm.c:53: error: declaration of ‘index’ shadows a global declaration /usr/include/string.h:489: error: shadowed declaration is here <SNIP> CC /tmp/build/perf/tests/bpf.o cc1: warnings being treated as errors tests/bpf.c: In function ‘__test__bpf’: tests/bpf.c:149: error: declaration of ‘index’ shadows a global declaration /usr/include/string.h:489: error: shadowed declaration is here <SNIP> Cc: He Kuang <hekuang@huawei.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: pi3orama@163.com Cc: Wang Nan <wangnan0@huawei.com> Cc: Zefan Li <lizefan@huawei.com> Fixes: b31de018a628 ("perf test: Enhance the LLVM test: update basic BPF test program") Fixes: ba1fae431e74 ("perf test: Add 'perf test BPF'") Link: http://lkml.kernel.org/n/tip-akpo4r750oya2phxoh9e3447@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Nikolay Borisov <kernel@kyup.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-18tools lib traceevent: Do not reassign parg after collapse_tree()Steven Rostedt
commit 106b816cb46ebd87408b4ed99a2e16203114daa6 upstream. At the end of process_filter(), collapse_tree() was changed to update the parg parameter, but the reassignment after the call wasn't removed. What happens is that the "current_op" gets modified and freed and parg is assigned to the new allocated argument. But after the call to collapse_tree(), parg is assigned again to the just freed "current_op", and this causes the tool to crash. The current_op variable must also be assigned to NULL in case of error, otherwise it will cause it to be free()ed twice. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Fixes: 42d6194d133c ("tools lib traceevent: Refactor process_filter()") Link: http://lkml.kernel.org/r/20160511150936.678c18a1@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04perf stat: Document --detailed optionBorislav Petkov
commit f594bae08183fb6b57db55387794ece3e1edf6f6 upstream. I'm surprised this remained undocumented since at least 2011. And it is actually a very useful switch, as Steve and I came to realize recently. Add the text from 2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events") which added the incrementing aspect to -d. Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Borislav Petkov <bp@suse.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Davidlohr Bueso <dbueso@suse.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mel Gorman <mgorman@suse.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 2cba3ffb9a9d ("perf stat: Add -d -d and -d -d -d options to show more CPU events") Link: http://lkml.kernel.org/r/1457347294-32546-1-git-send-email-bp@alien8.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04perf tools: handle spaces in file names obtained from /proc/pid/mapsMarcin Ślusarz
commit 89fee59b504f86925894fcc9ba79d5c933842f93 upstream. Steam frequently puts game binaries in folders with spaces. Note: "(deleted)" markers are now treated as part of the file name. Signed-off-by: Marcin Ślusarz <marcin.slusarz@gmail.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Fixes: 6064803313ba ("perf tools: Use sscanf for parsing /proc/pid/maps") Link: http://lkml.kernel.org/r/20160119190303.GA17579@marcin-Inspiron-7720 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04perf hists browser: Only offer symbol scripting when a symbol is under the ↵Namhyung Kim
cursor commit c221acb0f970d3b80d72c812cda19c121acf5d52 upstream. When this feature was introduced a check was made if there was a resolved symbol under the cursor, it got lost in commit ea7cd5923309 ("perf hists browser: Split popup menu actions - part 2"), reinstate it. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org>, Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Wang Nan <wangnan0@huawei.com> Fixes: ea7cd5923309 ("perf hists browser: Split popup menu actions - part 2") Link: http://lkml.kernel.org/r/1452960197-5323-9-git-send-email-namhyung@kernel.org [ Carved out from a larger patch ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04perf evlist: Reference count the cpu and thread maps at set_maps()Arnaldo Carvalho de Melo
commit a55e5663761366fb883f6f25375dd68bc958b9db upstream. We were dropping the reference we possibly held but not obtaining one for the new maps, which we will drop at perf_evlist__delete(), fix it. This was caught by Steven Noonan in some of the machines which would produce this output when caught by glibc debug mechanisms: $ sudo perf test 21 21: Test object code reading :*** Error in `perf': corrupted double-linked list: 0x00000000023ffcd0 *** ======= Backtrace: ========= /usr/lib/libc.so.6(+0x72055)[0x7f25be0f3055] /usr/lib/libc.so.6(+0x779b6)[0x7f25be0f89b6] /usr/lib/libc.so.6(+0x7a0ed)[0x7f25be0fb0ed] /usr/lib/libc.so.6(__libc_calloc+0xba)[0x7f25be0fceda] perf(parse_events_lex_init_extra+0x38)[0x4cfff8] perf(parse_events+0x55)[0x4a0615] perf(perf_evlist__config+0xcf)[0x4eeb2f] perf[0x479f82] perf(test__code_reading+0x1e)[0x47ad4e] perf(cmd_test+0x5dd)[0x46452d] perf[0x47f4e3] perf(main+0x603)[0x42c723] /usr/lib/libc.so.6(__libc_start_main+0xf0)[0x7f25be0a1610] perf(_start+0x29)[0x42c859] Further investigation using valgrind led to the reference count imbalance fixed in this patch. Reported-and-Tested-by: Steven Noonan <steven@uplinklabs.net> Report-Link: http://lkml.kernel.org/r/CAKbGBLjC2Dx5vshxyGmQkcD+VwiAQLbHoXA9i7kvRB2-2opHZQ@mail.gmail.com Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Fixes: f30a79b012e5 ("perf tools: Add reference counting for cpu_map object") Link: http://lkml.kernel.org/n/tip-j0u1bdhr47sa511sgg76kb8h@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04perf intel-pt: Fix segfault tracing transactionsAdrian Hunter
commit 1342e0b7a6c1a060c593037fbac9f4b717f1cb3b upstream. Tracing a workload that uses transactions gave a seg fault as follows: perf record -e intel_pt// workload perf report Program received signal SIGSEGV, Segmentation fault. 0x000000000054b58c in intel_pt_reset_last_branch_rb (ptq=0x1a36110) at util/intel-pt.c:929 929 ptq->last_branch_rb->nr = 0; (gdb) p ptq->last_branch_rb $1 = (struct branch_stack *) 0x0 (gdb) up 1148 intel_pt_reset_last_branch_rb(ptq); (gdb) l 1143 if (ret) 1144 pr_err("Intel Processor Trace: failed to deliver transaction event 1145 ret); 1146 1147 if (pt->synth_opts.callchain) 1148 intel_pt_reset_last_branch_rb(ptq); 1149 1150 return ret; 1151 } 1152 (gdb) p pt->synth_opts.callchain $2 = true (gdb) (gdb) bt #0 0x000000000054b58c in intel_pt_reset_last_branch_rb (ptq=0x1a36110) #1 0x000000000054c1e0 in intel_pt_synth_transaction_sample (ptq=0x1a36110) #2 0x000000000054c5b2 in intel_pt_sample (ptq=0x1a36110) Caused by checking the 'callchain' flag when it should have been the 'last_branch' flag. Fix that. Reported-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Fixes: f14445ee72c5 ("perf intel-pt: Support generating branch stack") Link: http://lkml.kernel.org/r/1460977068-11566-1-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12tools/hv: Use include/uapi with __EXPORTED_HEADERS__Kamal Mostafa
commit 50fe6dd10069e7c062e27f29606f6e91ea979399 upstream. Use the local uapi headers to keep in sync with "recently" added #define's (e.g. VSS_OP_REGISTER1). Fixes: 3eb2094c59e8 ("Adding makefile for tools/hv") Signed-off-by: Kamal Mostafa <kamal@canonical.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12perf tools: Fix python extension buildJiri Olsa
commit 67d5268908283c187e0a460048a423256c2fb288 upstream. The util/python-ext-sources file contains source files required to build the python extension relative to $(srctree)/tools/perf, Such a file path $(FILE).c is handed over to the python extension build system, which builds the final object in the $(PYTHON_EXTBUILD)/tmp/$(FILE).o path. After the build is done all files from $(PYTHON_EXTBUILD)lib/ are carried as the result binaries. Above system fails when we add source file relative to ../lib, which we do for: ../lib/bitmap.c ../lib/find_bit.c ../lib/hweight.c ../lib/rbtree.c All above objects will be built like: $(PYTHON_EXTBUILD)/tmp/../lib/bitmap.c $(PYTHON_EXTBUILD)/tmp/../lib/find_bit.c $(PYTHON_EXTBUILD)/tmp/../lib/hweight.c $(PYTHON_EXTBUILD)/tmp/../lib/rbtree.c which accidentally happens to be final library path: $(PYTHON_EXTBUILD)/lib/ Changing setup.py to pass full paths of source files to Extension build class and thus keep all built objects under $(PYTHON_EXTBUILD)tmp directory. Reported-by: Jeff Bastian <jbastian@redhat.com> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Josh Boyer <jwboyer@fedoraproject.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20160227201350.GB28494@krava.redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12perf tools: Fix checking asprintf return valueWang Nan
commit 26dee028d365fbc0e3326606a8520260b4462381 upstream. According to man pages, asprintf returns -1 when failure. This patch fixes two incorrect return value checker. Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexei Starovoitov <ast@kernel.org> Cc: Brendan Gregg <brendan.d.gregg@gmail.com> Cc: Cody P Schafer <dev@codyps.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jeremie Galarneau <jeremie.galarneau@efficios.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kirill Smelkov <kirr@nexedi.com> Cc: Li Zefan <lizefan@huawei.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Fixes: ffeb883e5662 ("perf tools: Show proper error message for wrong terms of hw/sw events") Link: http://lkml.kernel.org/r/1455882283-79592-5-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-04-12perf tools: Dont stop PMU parsing on alias parse errorAndi Kleen
commit 940db6dcd3f4659303fdf6befe7416adc4d24118 upstream. When an error happens during alias parsing currently the complete parsing of all attributes of the PMU is stopped. This is breaks old perf on a newer kernel that may have not-yet-know alias attributes (such as .scale or .per-pkg). Continue when some attribute is unparseable. This is IMHO a stable candidate and should be backported to older versions to avoid problems with newer kernels. v2: Print warnings when something goes wrong. v3: Change warning to debug output Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Link: http://lkml.kernel.org/r/1455749095-18358-1-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03perf stat: Do not clean event's private statsJiri Olsa
commit 3f416f22d1e21709a631189ba169f76fd267b374 upstream. Mel reported stddev reporting was broken due to following commit: 106a94a0f8c2 ("perf stat: Introduce read_counters function") This commit merged interval and overall counters reading into single read_counters function. The old interval code cleaned the stddev data for some reason (it's never displayed in interval mode) and the mentioned commit kept on cleaning the stddev data in merged function, which resulted in the stddev not being displayed. Removing the wrong stddev data cleanup init_stats call. Reported-and-Tested-by: Mel Gorman <mgorman@techsingularity.net> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Fixes: 106a94a0f8c2 ("perf stat: Introduce read_counters function") Link: http://lkml.kernel.org/r/1453290995-18485-4-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03tools: hv: vss: fix the write()'s argument: error -> vss_msgDexuan Cui
commit a689d2510f188e75391dbebacbddfd74d42f2a7e upstream. Fix the write()'s argument in the daemon code. Cc: Vitaly Kuznetsov <vkuznets@redhat.com> Cc: "K. Y. Srinivasan" <kys@microsoft.com> Signed-off-by: Dexuan Cui <decui@microsoft.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-03-03efi: Make efivarfs entries immutable by defaultPeter Jones
commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 upstream. "rm -rf" is bricking some peoples' laptops because of variables being used to store non-reinitializable firmware driver data that's required to POST the hardware. These are 100% bugs, and they need to be fixed, but in the mean time it shouldn't be easy to *accidentally* brick machines. We have to have delete working, and picking which variables do and don't work for deletion is quite intractable, so instead make everything immutable by default (except for a whitelist), and make tools that aren't quite so broad-spectrum unset the immutable flag. Signed-off-by: Peter Jones <pjones@redhat.com> Tested-by: Lee, Chun-Yi <jlee@suse.com> Acked-by: Matthew Garrett <mjg59@coreos.com> Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-25perf kvm record/report: 'unprocessable sample' error while ↵Ravi Bangoria
recording/reporting guest data commit 3caeaa562733c4836e61086ec07666635006a787 upstream. While recording guest samples in host using perf kvm record, it will populate unprocessable sample error, though samples will be recorded properly. While generating report using perf kvm report, no samples will be processed and same error will populate. We have seen this behaviour with upstream perf(4.4-rc3) on x86 and ppc64 hardware. Reason behind this failure is, when it tries to fetch machine from rb_tree of machines, it fails. As a part of tracing a bug, we figured out that this code was incorrectly refactored in commit 54245fdc3576 ("perf session: Remove wrappers to machines__find"). This patch will change the functionality such that if it can't fetch machine in first trial, it will create one node of machine and add that to rb_tree. So next time when it tries to fetch same machine from rb_tree, it won't fail. Actually it was the case before refactoring of code in aforementioned commit. This patch is generated from acme perf/core branch. Below I've mention an example that demonstrate the behaviour before and after applying patch. Before applying patch: [Note: One needs to run guest before recording data in host] ravi@ravi-bangoria:~$ ./perf kvm record -a Warning: 5903 unprocessable samples recorded. Do you have a KVM guest running and not using 'perf kvm'? [ perf record: Captured and wrote 1.409 MB perf.data.guest (285 samples) ] ravi@ravi-bangoria:~$ ./perf kvm report --stdio Warning: 5903 unprocessable samples recorded. Do you have a KVM guest running and not using 'perf kvm'? # To display the perf.data header info, please use --header/--header-only options. # # Total Lost Samples: 0 # # Samples: 285 of event 'cycles' # Event count (approx.): 88715406 # # Overhead Command Shared Object Symbol # ........ ....... ............. ...... # # (For a higher level overview, try: perf report --sort comm,dso) # After applying patch: ravi@ravi-bangoria:~$ ./perf kvm record -a [ perf record: Captured and wrote 1.188 MB perf.data.guest (17 samples) ] ravi@ravi-bangoria:~$ ./perf kvm report --stdio # To display the perf.data header info, please use --header/--header-only options. # # Total Lost Samples: 0 # # Samples: 17 of event 'cycles' # Event count (approx.): 700746 # # Overhead Command Shared Object Symbol # ........ ....... ................ ...................... # 34.19% :5758 [unknown] [g] 0xffffffff818682ab 22.79% :5758 [unknown] [g] 0xffffffff812dc7f8 22.79% :5758 [unknown] [g] 0xffffffff818650d0 14.83% :5758 [unknown] [g] 0xffffffff8161a1b6 2.49% :5758 [unknown] [g] 0xffffffff818692bf 0.48% :5758 [unknown] [g] 0xffffffff81869253 0.05% :5758 [unknown] [g] 0xffffffff81869250 Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com> Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Fixes: 54245fdc3576 ("perf session: Remove wrappers to machines__find") Link: http://lkml.kernel.org/r/1449471302-11283-1-git-send-email-ravi.bangoria@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-25perf tools: tracepoint_error() can receive e=NULL, robustify itAdrian Hunter
commit ec183d22cc284a7a1e17f0341219d8ec8ca070cc upstream. Fixes segmentation fault using, for instance: (gdb) run record -I -e intel_pt/tsc=1,noretcomp=1/u /bin/ls Starting program: /home/acme/bin/perf record -I -e intel_pt/tsc=1,noretcomp=1/u /bin/ls Missing separate debuginfos, use: dnf debuginfo-install glibc-2.22-7.fc23.x86_64 [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib64/libthread_db.so.1". Program received signal SIGSEGV, Segmentation fault. 0 x00000000004b9ea5 in tracepoint_error (e=0x0, err=13, sys=0x19b1370 "sched", name=0x19a5d00 "sched_switch") at util/parse-events.c:410 (gdb) bt #0 0x00000000004b9ea5 in tracepoint_error (e=0x0, err=13, sys=0x19b1370 "sched", name=0x19a5d00 "sched_switch") at util/parse-events.c:410 #1 0x00000000004b9fc5 in add_tracepoint (list=0x19a5d20, idx=0x7fffffffb8c0, sys_name=0x19b1370 "sched", evt_name=0x19a5d00 "sched_switch", err=0x0, head_config=0x0) at util/parse-events.c:433 #2 0x00000000004ba334 in add_tracepoint_event (list=0x19a5d20, idx=0x7fffffffb8c0, sys_name=0x19b1370 "sched", evt_name=0x19a5d00 "sched_switch", err=0x0, head_config=0x0) at util/parse-events.c:498 #3 0x00000000004bb699 in parse_events_add_tracepoint (list=0x19a5d20, idx=0x7fffffffb8c0, sys=0x19b1370 "sched", event=0x19a5d00 "sched_switch", err=0x0, head_config=0x0) at util/parse-events.c:936 #4 0x00000000004f6eda in parse_events_parse (_data=0x7fffffffb8b0, scanner=0x19a49d0) at util/parse-events.y:391 #5 0x00000000004bc8e5 in parse_events__scanner (str=0x663ff2 "sched:sched_switch", data=0x7fffffffb8b0, start_token=258) at util/parse-events.c:1361 #6 0x00000000004bca57 in parse_events (evlist=0x19a5220, str=0x663ff2 "sched:sched_switch", err=0x0) at util/parse-events.c:1401 #7 0x0000000000518d5f in perf_evlist__can_select_event (evlist=0x19a3b90, str=0x663ff2 "sched:sched_switch") at util/record.c:253 #8 0x0000000000553c42 in intel_pt_track_switches (evlist=0x19a3b90) at arch/x86/util/intel-pt.c:364 #9 0x00000000005549d1 in intel_pt_recording_options (itr=0x19a2c40, evlist=0x19a3b90, opts=0x8edf68 <record+232>) at arch/x86/util/intel-pt.c:664 #10 0x000000000051e076 in auxtrace_record__options (itr=0x19a2c40, evlist=0x19a3b90, opts=0x8edf68 <record+232>) at util/auxtrace.c:539 #11 0x0000000000433368 in cmd_record (argc=1, argv=0x7fffffffde60, prefix=0x0) at builtin-record.c:1264 #12 0x000000000049bec2 in run_builtin (p=0x8fa2a8 <commands+168>, argc=5, argv=0x7fffffffde60) at perf.c:390 #13 0x000000000049c12a in handle_internal_command (argc=5, argv=0x7fffffffde60) at perf.c:451 #14 0x000000000049c278 in run_argv (argcp=0x7fffffffdcbc, argv=0x7fffffffdcb0) at perf.c:495 #15 0x000000000049c60a in main (argc=5, argv=0x7fffffffde60) at perf.c:618 (gdb) Intel PT attempts to find the sched:sched_switch tracepoint but that seg faults if tracefs is not readable, because the error reporting structure is null, as errors are not reported when automatically adding tracepoints. Fix by checking before using. Committer note: This doesn't take place in a kernel that supports perf_event_attr.context_switch, that is the default way that will be used for tracking context switches, only in older kernels, like 4.2, in a machine with Intel PT (e.g. Broadwell) for non-priviledged users. Further info from a similar patch by Wang: The error is in tracepoint_error: it assumes the 'e' parameter is valid. However, there are many situation a parse_event() can be called without parse_events_error. See result of $ grep 'parse_events(.*NULL)' ./tools/perf/ -r' Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Tong Zhang <ztong@vt.edu> Cc: Wang Nan <wangnan0@huawei.com> Fixes: 196581717d85 ("perf tools: Enhance parsing events tracepoint error output") Link: http://lkml.kernel.org/r/1453809921-24596-2-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-25tools lib traceevent: Fix output of %llu for 64 bit values read on 32 bit ↵Steven Rostedt
machines commit 32abc2ede536aae52978d6c0a8944eb1df14f460 upstream. When a long value is read on 32 bit machines for 64 bit output, the parsing needs to change "%lu" into "%llu", as the value is read natively. Unfortunately, if "%llu" is already there, the code will add another "l" to it and fail to parse it properly. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20151116172516.4b79b109@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-08Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Two core subsystem fixes, plus a handful of tooling fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Fix race in swevent hash perf: Fix race in perf_event_exec() perf list: Robustify event printing routine perf list: Add support for PERF_COUNT_SW_BPF_OUT perf hists browser: Fix segfault if use symbol filter in cmdline perf hists browser: Reset selection when refresh perf hists browser: Add NULL pointer check to prevent crash perf buildid-list: Fix return value of perf buildid-list -k perf buildid-list: Show running kernel build id fix
2015-12-16perf list: Robustify event printing routineArnaldo Carvalho de Melo
When a43eec304259 ("bpf: introduce bpf_perf_event_output() helper") added PERF_COUNT_SW_BPF_OUTPUT we ended up with a new entry in the event_symbols_sw array that wasn't initialized, thus set to NULL, fix print_symbol_events() to check for that case so that we don't crash if this happens again. (gdb) bt #0 __match_glob (ignore_space=false, pat=<optimized out>, str=<optimized out>) at util/string.c:198 #1 strglobmatch (str=<optimized out>, pat=pat@entry=0x7fffffffe61d "stall") at util/string.c:252 #2 0x00000000004993a5 in print_symbol_events (type=1, syms=0x872880 <event_symbols_sw+160>, max=11, name_only=false, event_glob=0x7fffffffe61d "stall") at util/parse-events.c:1615 #3 print_events (event_glob=event_glob@entry=0x7fffffffe61d "stall", name_only=false) at util/parse-events.c:1675 #4 0x000000000042c79e in cmd_list (argc=1, argv=0x7fffffffe390, prefix=<optimized out>) at builtin-list.c:68 #5 0x00000000004788a5 in run_builtin (p=p@entry=0x871758 <commands+120>, argc=argc@entry=2, argv=argv@entry=0x7fffffffe390) at perf.c:370 #6 0x0000000000420ab0 in handle_internal_command (argv=0x7fffffffe390, argc=2) at perf.c:429 #7 run_argv (argv=0x7fffffffe110, argcp=0x7fffffffe11c) at perf.c:473 #8 main (argc=2, argv=0x7fffffffe390) at perf.c:588 (gdb) p event_symbols_sw[PERF_COUNT_SW_BPF_OUTPUT] $4 = {symbol = 0x0, alias = 0x0} (gdb) A patch to robustify perf to not segfault when the next counter gets added in the kernel will follow this one. Reported-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexei Starovoitov <ast@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-57wysblcjfrseb0zg5u7ek10@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-12-16perf list: Add support for PERF_COUNT_SW_BPF_OUTArnaldo Carvalho de Melo
When PERF_COUNT_SW_BPF_OUTPUT was added to the kernel we should've added it to tools/perf, where it is used just to list events. This ended up causing a segfault in commands like "perf list stall". Fix it by adding that new software counter. A patch to robustify perf to not segfault when the next counter gets added in the kernel will follow this one. Reported-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Alexei Starovoitov <ast@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-uya354upi3eprsey6mi5962d@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-12-07tools/virtio: fix byteswap logicMichael S. Tsirkin
commit cf561f0d2eb74574ad9985a2feab134267a9d298 ("virtio: introduce virtio_is_little_endian() helper") changed byteswap logic to skip feature bit checks for LE platforms, but didn't update tools/virtio, so vring_bench started failing. Update the copy under tools/virtio/ (TODO: find a way to avoid this code duplication). Cc: Greg Kurz <gkurz@linux.vnet.ibm.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2015-12-07tools/virtio: move list macro stubsMichael S. Tsirkin
Makes them more generally available. Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2015-12-07perf hists browser: Fix segfault if use symbol filter in cmdlineWang Nan
If feed perf a symbol filter in cmdline and the result is empty, pressing 'Enter' in the hist browser causes crash: # ./perf report perf.data <-- Common mistake for beginners Then press 'Enter': perf: Segmentation fault -------- backtrace -------- /home/wangnan/perf[0x53e578] /lib64/libc.so.6(+0x3545f)[0x7f76bafe045f] /home/wangnan/perf[0x539dd4] /home/wangnan/perf(perf_evlist__tui_browse_hists+0x96)[0x53d216] /home/wangnan/perf(cmd_report+0x1b9f)[0x442c7f] /home/wangnan/perf[0x47efa2] /home/wangnan/perf(main+0x5f5)[0x432fa5] /lib64/libc.so.6(__libc_start_main+0xf4)[0x7f76bafccbd4] /home/wangnan/perf[0x4330d4] This is because 'perf.data' is interpreted as a symbol filter, and the result is empty, so selection is empty. However, hist_browser__toggle_fold() forgets to check it. This patch simply return false when selection is NULL. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1449455746-41952-2-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-12-07perf hists browser: Reset selection when refreshWang Nan
With the following steps: Step 1: perf report Step 2: Use UP/DOWN to select an entry, don't press 'ENTER' Step 3: Use '/' to filter symbols, use a filter which returns empty result Step 4: Press 'ENTER' We see that, even if we have filtered all the symbols (and the main interface is empty), pressing 'ENTER' still selects one symbol. This behavior surprises the user. This patch resets browser->{he_,}selection in hist_browser__refresh() and lets it choose default selection. In this case browser->{he_,}selection keeps NULL so user won't see annotation item in menu. Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1449455746-41952-4-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-12-07perf hists browser: Add NULL pointer check to prevent crashWang Nan
Before this patch we can trigger a segfault by following steps: Step 0: Use 'perf record' to generate a perf.data without callchain Step 1: perf report Step 2: Use UP/DOWN to select an entry, don't press 'ENTER' Step 3: Use '/' to filter symbols, use a filter which returns empty result Step 4: Press 'ENTER' (notice here that the old selection is still there. This is another problem) Step 5: Press 'ENTER' to annotate that symbol Step 6: Press 'LEFT' to go out. Result: segfault: perf: Segmentation fault -------- backtrace -------- /home/wangnan/perf[0x53e568] /lib64/libc.so.6(+0x3545f)[0x7fba75d3245f] /home/wangnan/perf[0x537516] /home/wangnan/perf[0x533fef] /home/wangnan/perf[0x53b347] /home/wangnan/perf(perf_evlist__tui_browse_hists+0x96)[0x53d206] /home/wangnan/perf(cmd_report+0x1b9f)[0x442c7f] /home/wangnan/perf[0x47efa2] /home/wangnan/perf(main+0x5f5)[0x432fa5] /lib64/libc.so.6(__libc_start_main+0xf4)[0x7fba75d1ebd4] /home/wangnan/perf[0x4330d4] This is because in this case 'nd' could be NULL in ui_browser__hists_seek(), but that function never checks it. This patch adds checker for potential NULL pointer in that function. After this patch the above steps won't segfault. Signed-off-by: Wang Nan <wangnan0@huawei.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1449455746-41952-3-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-12-07perf buildid-list: Fix return value of perf buildid-list -kMichael Petlan
The buildid string length is returned by perf buildid-list -k command. Since a non-zero return value means an error, perf buildid-list -k cmd should return 0 when successful instead. Before: # perf buildid-list -k 39356d74e96e02346fe0ec1f3f162b6c522bac62 # echo $? 41 After: # perf buildid-list -k 39356d74e96e02346fe0ec1f3f162b6c522bac62 # echo $? 0 Signed-off-by: Michael Petlan <mpetlan@redhat.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Fixes: 0b5a7935f3b5 ("perf buildid: Introduce sysfs/filename__sprintf_build_id") LPU-Reference: 1449080871.24573.145.camel@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-12-07perf buildid-list: Show running kernel build id fixMichael Petlan
The --kernel option of perf buildid-list tool should show the running kernel buildid. The functionality has been lost during other changes of the related code. The build_id__sprintf() function should return length of the build-id string, but it was the length of the build-id raw data instead. Due to that, some return value checking caused that the final string was not printed out. With this patch the build_id__sprintf() returns the correct value, so the --kernel option works again. Before: # perf buildid-list --kernel # After: # perf buildid-list --kernel 972c1edab5bdc06cc224af45d510af662a3c6972 # Signed-off-by: Michael Petlan <mpetlan@redhat.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> LPU-Reference: 1448632089.24573.114.camel@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-11-30nfit: Adjust for different _FIT and NFIT headersLinda Knippers
When support for _FIT was added, the code presumed that the data returned by the _FIT method is identical to the NFIT table, which starts with an acpi_table_header. However, the _FIT is defined to return a data in the format of a series of NFIT type structure entries and as a method, has an acpi_object header rather tahn an acpi_table_header. To address the differences, explicitly save the acpi_table_header from the NFIT, since it is accessible through /sys, and change the nfit pointer in the acpi_desc structure to point to the table entries rather than the headers. Reported-by: Jeff Moyer (jmoyer@redhat.com> Signed-off-by: Linda Knippers <linda.knippers@hpe.com> Acked-by: Vishal Verma <vishal.l.verma@intel.com> [vishal: fix up unit test for new header assumptions] Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-11-23Merge tag 'linux-kselftest-4.4-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest fixes from Shuah Khan: "This update consists of one minor documentation fix and a fix to an existing test" * tag 'linux-kselftest-4.4-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: selftests/seccomp: Get page size from sysconf tools:testing/selftests: fix typo in futex/README
2015-11-22Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf tool fixes from Thomas Gleixner: "A couple of fixes for perf tools: - Build system updates - Plug a memory leak in an error path of perf probe - Tear down probes correctly when adding fails - Fixes to the perf symbol handling - Fix ordering of event processing in buildid-list - Fix per DSO filtering in the histogram browser" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf probe: Clear probe_trace_event when add_probe_trace_event() fails perf probe: Fix memory leaking on failure by clearing all probe_trace_events perf inject: Also re-pipe lost_samples event perf buildid-list: Requires ordered events perf symbols: Fix dso lookup by long name and missing buildids perf symbols: Allow forcing reading of non-root owned files by root perf hists browser: The dso can be obtained from popup_action->ms.map->dso perf hists browser: Fix 'd' hotkey action to filter by DSO perf symbols: Rebuild rbtree when adjusting symbols for kcore tools: Add a "make all" rule tools: Actually install tmon in the install rule
2015-11-20tools/vm/page-types.c: support KPF_IDLENaoya Horiguchi
PageIdle is exported in include/uapi/linux/kernel-page-flags.h, so let's make page-types.c tool handle it. Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com> Reviewed-by: Vladimir Davydov <vdavydov@virtuozzo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-11-20Merge tag 'pm+acpi-4.4-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull more power management and ACPI updates from Rafael Wysocki: "These are mostly fixes and cleanups (ACPI core, PM core, cpufreq, ACPI EC driver, device properties) including three reverts of recent intel_pstate driver commits due to a regression introduced by one of them plus support for Atom Airmont cores in intel_pstate (which really boils down to adding new frequency tables for Airmont) and additional turbostat updates. Specifics: - Revert three recent intel_pstate driver commits one of which introduced a regression and the remaining two depend on the problematic one (Rafael Wysocki). - Fix breakage related to the recently introduced ACPI _CCA object support in the PCI DMA setup code (Suravee Suthikulpanit). - Fix up the recently introduced ACPI CPPC support to only use the hardware-reduced version of the PCCT structure as the only architecture to support it (ARM64) will only use hardware-reduced ACPI anyway (Ashwin Chaugule). - Fix a cpufreq mediatek driver build problem (Arnd Bergmann). - Fix the SMBus transaction handling implementation in the ACPI core to avoid re-entrant calls to wait_event_timeout() which makes intermittent boot stalls related to the Smart Battery Subsystem initialization go away and revert a workaround of another problem with the same underlying root cause (Chris Bainbridge). - Fix the generic wakeup interrupts framework to avoid using invalid IRQ numbers (Dmitry Torokhov). - Remove a redundant check from the ACPI EC driver (Markus Elfring). - Modify the intel_pstate driver so it can support more Atom flavors than just one (Baytrail) and add support for Atom Airmont cores (which require new freqnency tables) to it (Philippe Longepe). - Clean up MSR-related symbols in turbostat (Len Brown)" * tag 'pm+acpi-4.4-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: PCI: Fix OF logic in pci_dma_configure() Revert "Documentation: kernel_parameters for Intel P state driver" cpufreq: mediatek: fix build error cpufreq: intel_pstate: Add separate support for Airmont cores cpufreq: intel_pstate: Replace BYT with ATOM Revert "cpufreq: intel_pstate: Use ACPI perf configuration" Revert "cpufreq: intel_pstate: Avoid calculation for max/min" ACPI-EC: Drop unnecessary check made before calling acpi_ec_delete_query() Revert "ACPI / SBS: Add 5 us delay to fix SBS hangs on MacBook" ACPI / SMBus: Fix boot stalls / high CPU caused by reentrant code PM / wakeirq: check that wake IRQ is valid before accepting it ACPI / CPPC: Use h/w reduced version of the PCCT structure x86: remove unused definition of MSR_NHM_PLATFORM_INFO tools/power turbostat: use new name for MSR_PLATFORM_INFO
2015-11-18selftests/seccomp: Get page size from sysconfBamvor Jian Zhang
The commit fd88d16c58c2 ("selftests/seccomp: Be more precise with syscall arguments.") use PAGE_SIZE directly which lead to build failure on arm64. Replace it with generic interface(sysconf(_SC_PAGESIZE)) to fix this failure. Build and test successful on x86_64 and arm64. Signed-off-by: Bamvor Jian Zhang <bamvor.zhangjian@linaro.org> Acked-by: Kees Cook <keescook@chromium.org> Tested-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2015-11-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking fixes from David Miller: 1) Fix list tests in netfilter ingress support, from Florian Westphal. 2) Fix reversal of input and output interfaces in ingress hook invocation, from Pablo Neira Ayuso. 3) We have a use after free in r8169, caught by Dave Jones, fixed by Francois Romieu. 4) Splice use-after-free fix in AF_UNIX frmo Hannes Frederic Sowa. 5) Three ipv6 route handling bug fixes from Martin KaFai Lau: a) Don't create clone routes not managed by the fib6 tree b) Don't forget to check expiration of DST_NOCACHE routes. c) Handle rt->dst.from == NULL properly. 6) Several AF_PACKET fixes wrt transport header setting and SKB protocol setting, from Daniel Borkmann. 7) Fix thunder driver crash on shutdown, from Pavel Fedin. 8) Several Mellanox driver fixes (max MTU calculations, use of correct DMA unmap in TX path, etc.) from Saeed Mahameed, Tariq Toukan, Doron Tsur, Achiad Shochat, Eran Ben Elisha, and Noa Osherovich. 9) Several mv88e6060 DSA driver fixes (wrong bit definitions for certain registers, etc.) from Neil Armstrong. 10) Make sure to disable preemption while updating per-cpu stats of ip tunnels, from Jason A. Donenfeld. 11) Various ARM64 bpf JIT fixes, from Yang Shi. 12) Flush icache properly in ARM JITs, from Daniel Borkmann. 13) Fix masking of RX and TX interrupts in ravb driver, from Masaru Nagai. 14) Fix netdev feature propagation for devices not implementing ->ndo_set_features(). From Nikolay Aleksandrov. 15) Big endian fix in vmxnet3 driver, from Shrikrishna Khare. 16) RAW socket code increments incorrect SNMP counters, fix from Ben Cartwright-Cox. 17) IPv6 multicast SNMP counters are bumped twice, fix from Neil Horman. 18) Fix handling of VLAN headers on stacked devices when REORDER is disabled. From Vlad Yasevich. 19) Fix SKB leaks and use-after-free in ipvlan and macvlan drivers, from Sabrina Dubroca. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (83 commits) MAINTAINERS: Update Mellanox's Eth NIC driver entries net/core: revert "net: fix __netdev_update_features return.." and add comment af_unix: take receive queue lock while appending new skb rtnetlink: fix frame size warning in rtnl_fill_ifinfo net: use skb_clone to avoid alloc_pages failure. packet: Use PAGE_ALIGNED macro packet: Don't check frames_per_block against negative values net: phy: Use interrupts when available in NOLINK state phy: marvell: Add support for 88E1540 PHY arm64: bpf: make BPF prologue and epilogue align with ARM64 AAPCS macvlan: fix leak in macvlan_handle_frame ipvlan: fix use after free of skb ipvlan: fix leak in ipvlan_rcv_frame vlan: Do not put vlan headers back on bridge and macvlan ports vlan: Fix untag operations of stacked vlans with REORDER_HEADER off via-velocity: unconditionally drop frames with bad l2 length ipg: Remove ipg driver dl2k: Add support for IP1000A-based cards snmp: Remove duplicate OUTMCAST stat increment net: thunder: Check for driver data in nicvf_remove() ...
2015-11-16tools:testing/selftests: fix typo in futex/READMEWei Jiangang
Correct typo in tools/testing/selftests/futex/README. Signed-off-by: Wei Jiangang <weijg.fnst@cn.fujitsu.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2015-11-16Merge branch 'pm-tools'Rafael J. Wysocki
* pm-tools: x86: remove unused definition of MSR_NHM_PLATFORM_INFO tools/power turbostat: use new name for MSR_PLATFORM_INFO
2015-11-15tools/net: Use include/uapi with __EXPORTED_HEADERS__Kamal Mostafa
Use the local uapi headers to keep in sync with "recently" added #define's (e.g. SKF_AD_VLAN_TPID). Refactored CFLAGS, and bpf_asm doesn't need -I. Fixes: 3f356385e8a4 ("filter: bpf_asm: add minimal bpf asm tool") Signed-off-by: Kamal Mostafa <kamal@canonical.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-11-15Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Thomas Gleixner: "Mostly updates to the perf tool plus two fixes to the kernel core code: - Handle tracepoint filters correctly for inherited events (Peter Zijlstra) - Prevent a deadlock in perf_lock_task_context (Paul McKenney) - Add missing newlines to some pr_err() calls (Arnaldo Carvalho de Melo) - Print full source file paths when using 'perf annotate --print-line --full-paths' (Michael Petlan) - Fix 'perf probe -d' when just one out of uprobes and kprobes is enabled (Wang Nan) - Add compiler.h to list.h to fix 'make perf-tar-src-pkg' generated tarballs, i.e. out of tree building (Arnaldo Carvalho de Melo) - Add the llvm-src-base.c and llvm-src-kbuild.c files, generated by the 'perf test' LLVM entries, when running it in-tree, to .gitignore (Yunlong Song) - libbpf error reporting improvements, using a strerror interface to more precisely tell the user about problems with the provided scriptlet, be it in C or as a ready made object file (Wang Nan) - Do not be case sensitive when searching for matching 'perf test' entries (Arnaldo Carvalho de Melo) - Inform the user about objdump failures in 'perf annotate' (Andi Kleen) - Improve the LLVM 'perf test' entry, introduce a new ones for BPF and kbuild tests to check the environment used by clang to compile .c scriptlets (Wang Nan)" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (32 commits) perf/x86/intel/rapl: Remove the unused RAPL_EVENT_DESC() macro tools include: Add compiler.h to list.h perf probe: Verify parameters in two functions perf session: Add missing newlines to some pr_err() calls perf annotate: Support full source file paths for srcline fix perf test: Add llvm-src-base.c and llvm-src-kbuild.c to .gitignore perf: Fix inherited events vs. tracepoint filters perf: Disable IRQs across RCU RS CS that acquires scheduler lock perf test: Do not be case sensitive when searching for matching tests perf test: Add 'perf test BPF' perf test: Enhance the LLVM tests: add kbuild test perf test: Enhance the LLVM test: update basic BPF test program perf bpf: Improve BPF related error messages perf tools: Make fetch_kernel_version() publicly available bpf tools: Add new API bpf_object__get_kversion() bpf tools: Improve libbpf error reporting perf probe: Cleanup find_perf_probe_point_from_map to reduce redundancy perf annotate: Inform the user about objdump failures in --stdio perf stat: Make stat options global perf sched latency: Fix thread pid reuse issue ...
