path: root/tools
2012-01-30perf top: Fix number of samples displayedStephane Eranian
In recent versions of perf top, pressing the 'e' key to change the number of displayed samples had no effect. The number of samples was still dictated by the size of the terminal (stdio mode). That was quite annoying because typically only the first dozen samples really matter. This patch fixes this. Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20120130105037.GA5160@quad Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-30perf tools: Fix strlen() bug in perf_event__synthesize_event_type()Stephane Eranian
The event_type record has a max length for the event name. It's called MAX_EVENT_NAME. The name may be truncated to fit the max length. But the header.size still reflects the original name length. If that length is > MAX_EVENT_NAME, then the header.size field is bogus. Fix this by using the length of the name after the potential truncation. Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20120120094912.GA4882@quad Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-30perf tools: Fix broken build by defining _GNU_SOURCE in MakefileDavid Daney
When building on my Debian/mips system, util/util.c fails to build because commit 1aed2671738785e8f5aea663a6fda91aa7ef59b5 (perf kvm: Do guest-only counting by default) indirectly includes stdio.h before the feature selection in util.h is done. This prevents _GNU_SOURCE in util.h from enabling the declaration of getline(), from now second inclusion of stdio.h, and the build is broken. There is another breakage in util/evsel.c caused by include ordering, but I didn't fully track down the commit that caused it. The root cause of all this is an inconsistent definition of _GNU_SOURCE, so I move the definition into the Makefile so that it is passed to all invocations of the compiler and used uniformly for all system header files. All other #define and #undef of _GNU_SOURCE are removed as they cause conflicts with the definition passed to the compiler. All the features.h definitions (_LARGEFILE64_SOURCE _FILE_OFFSET_BITS=64 and _GNU_SOURCE) are needed by the python glue code too, so they are moved to BASIC_CFLAGS, and the misleading comments about BASIC_CFLAGS are removed. This gives me a clean build on x86_64 (fc12) and mips (Debian). Cc: David Daney <david.daney@cavium.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1326836461-11952-1-git-send-email-ddaney.cavm@gmail.com Signed-off-by: David Daney <david.daney@cavium.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-18Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux This includes initial support for the recently published ACPI 5.0 spec. In particular, support for the "hardware-reduced" bit that eliminates the dependency on legacy hardware. APEI has patches resulting from testing on real hardware. Plus other random fixes. * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (52 commits) acpi/apei/einj: Add extensions to EINJ from rev 5.0 of acpi spec intel_idle: Split up and provide per CPU initialization func ACPI processor: Remove unneeded variable passed by acpi_processor_hotadd_init V2 ACPI processor: Remove unneeded cpuidle_unregister_driver call intel idle: Make idle driver more robust intel_idle: Fix a cast to pointer from integer of different size warning in intel_idle ACPI: kernel-parameters.txt : Add intel_idle.max_cstate intel_idle: remove redundant local_irq_disable() call ACPI processor: Fix error path, also remove sysdev link ACPI: processor: fix acpi_get_cpuid for UP processor intel_idle: fix API misuse ACPI APEI: Convert atomicio routines ACPI: Export interfaces for ioremapping/iounmapping ACPI registers ACPI: Fix possible alignment issues with GAS 'address' references ACPI, ia64: Use SRAT table rev to use 8bit or 16/32bit PXM fields (ia64) ACPI, x86: Use SRAT table rev to use 8bit or 32bit PXM fields (x86/x86-64) ACPI: Store SRAT table revision ACPI, APEI, Resolve false conflict between ACPI NVS and APEI ACPI, Record ACPI NVS regions ACPI, APEI, EINJ, Refine the fix of resource conflict ...
2012-01-18Merge branches 'einj', 'intel_idle', 'misc', 'srat' and 'turbostat-ivb' into ↵Len Brown
release
2012-01-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Add INGORE_ERRORS to ignore warnings in boot up ktest: Still do reboot even for REBOOT_TYPE = script ktest: Fix compare script to test if options are not documented ktest: Detect typos in option names ktest: Have all values be set by defaults ktest: Change initialization of defaults hash to perl format ktest: Add options SWITCH_TO_GOOD and SWITCH_TO_TEST ktest: Allow overriding bisect test results ktest: Evaluate options before processing them ktest: Evaluate $KERNEL_VERSION in both install and post install ktest: Only ask options needed for install ktest: When creating a new config, ask for BUILD_OPTIONS ktest: Do not ask for some options if the only test is build ktest: Ask for type of test when creating a new config ktest: Allow bisect test to restart where it left off ktest: When creating new config, allow the use of ${THIS_DIR} ktest: Add default for ssh-user, build-target and target-image ktest: Allow success logs to be stored ktest: Save test output
2012-01-15Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (39 commits) perf tools: Fix compile error on x86_64 Ubuntu perf report: Fix --stdio output alignment when --showcpuutilization used perf annotate: Get rid of field_sep check perf annotate: Fix usage string perf kmem: Fix a memory leak perf kmem: Add missing closedir() calls perf top: Add error message for EMFILE perf test: Change type of '-v' option to INCR perf script: Add missing closedir() calls tracing: Fix compile error when static ftrace is enabled recordmcount: Fix handling of elf64 big-endian objects. perf tools: Add const.h to MANIFEST to make perf-tar-src-pkg work again perf tools: Add support for guest/host-only profiling perf kvm: Do guest-only counting by default perf top: Don't update total_period on process_sample perf hists: Stop using 'self' for struct hist_entry perf hists: Rename total_session to total_period x86: Add counter when debug stack is used with interrupts enabled x86: Allow NMIs to hit breakpoints in i386 x86: Keep current stack in NMI breakpoints ...
2012-01-14Merge branch 'for-3.3' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.3' of git://linux-nfs.org/~bfields/linux: (31 commits) nfsd4: nfsd4_create_clid_dir return value is unused NFSD: Change name of extended attribute containing junction svcrpc: don't revert to SVC_POOL_DEFAULT on nfsd shutdown svcrpc: fix double-free on shutdown of nfsd after changing pool mode nfsd4: be forgiving in the absence of the recovery directory nfsd4: fix spurious 4.1 post-reboot failures NFSD: forget_delegations should use list_for_each_entry_safe NFSD: Only reinitilize the recall_lru list under the recall lock nfsd4: initialize special stateid's at compile time NFSd: use network-namespace-aware cache registering routines SUNRPC: create svc_xprt in proper network namespace svcrpc: update outdated BKL comment nfsd41: allow non-reclaim open-by-fh's in 4.1 svcrpc: avoid memory-corruption on pool shutdown svcrpc: destroy server sockets all at once svcrpc: make svc_delete_xprt static nfsd: Fix oops when parsing a 0 length export nfsd4: Use kmemdup rather than duplicating its implementation nfsd4: add a separate (lockowner, inode) lookup nfsd4: fix CONFIG_NFSD_FAULT_INJECTION compile error ...
2012-01-12Merge branch 'akpm' (aka "Andrew's patch-bomb, take two")Linus Torvalds
Andrew explains: - various misc stuff - Most of the rest of MM: memcg, threaded hugepages, others. - cpumask - kexec - kdump - some direct-io performance tweaking - radix-tree optimisations - new selftests code A note on this: often people will develop a new userspace-visible feature and will develop userspace code to exercise/test that feature. Then they merge the patch and the selftest code dies. Sometimes we paste it into the changelog. Sometimes the code gets thrown into Documentation/(!). This saddens me. So this patch creates a bare-bones framework which will henceforth allow me to ask people to include their test apps in the kernel tree so we can keep them alive. Then when people enhance or fix the feature, I can ask them to update the test app too. The infrastruture is terribly trivial at present - let's see how it evolves. - checkpoint/restart feature work. A note on this: this is a project by various mad Russians to perform c/r mainly from userspace, with various oddball helper code added into the kernel where the need is demonstrated. So rather than some large central lump of code, what we have is little bits and pieces popping up in various places which either expose something new or which permit something which is normally kernel-private to be modified. The overall project is an ongoing thing. I've judged that the size and scope of the thing means that we're more likely to be successful with it if we integrate the support into mainline piecemeal rather than allowing it all to develop out-of-tree. However I'm less confident than the developers that it will all eventually work! So what I'm asking them to do is to wrap each piece of new code inside CONFIG_CHECKPOINT_RESTORE. So if it all eventually comes to tears and the project as a whole fails, it should be a simple matter to go through and delete all trace of it. This lot pretty much wraps up the -rc1 merge for me. * akpm: (96 commits) unlzo: fix input buffer free ramoops: update parameters only after successful init ramoops: fix use of rounddown_pow_of_two() c/r: prctl: add PR_SET_MM codes to set up mm_struct entries c/r: procfs: add start_data, end_data, start_brk members to /proc/$pid/stat v4 c/r: introduce CHECKPOINT_RESTORE symbol selftests: new x86 breakpoints selftest selftests: new very basic kernel selftests directory radix_tree: take radix_tree_path off stack radix_tree: remove radix_tree_indirect_to_ptr() dio: optimize cache misses in the submission path vfs: cache request_queue in struct block_device fs/direct-io.c: calculate fs_count correctly in get_more_blocks() drivers/parport/parport_pc.c: fix warnings panic: don't print redundant backtraces on oops sysctl: add the kernel.ns_last_pid control kdump: add udev events for memory online/offline include/linux/crash_dump.h needs elf.h kdump: fix crash_kexec()/smp_send_stop() race in panic() kdump: crashk_res init check for /sys/kernel/kexec_crash_size ...
2012-01-12selftests: new x86 breakpoints selftestFrederic Weisbecker
Bring a first selftest in the relevant directory. This tests several combinations of breakpoints and watchpoints in x86, as well as icebp traps and int3 traps. Given the amount of breakpoint regressions we raised after we merged the generic breakpoint infrastructure, such selftest became necessary and can still serve today as a basis for new patches that touch the do_debug() path. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Michal Marek <mmarek@suse.cz> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12selftests: new very basic kernel selftests directoryFrederic Weisbecker
Bring a new kernel selftests directory in tools/testing/selftests. To add a new selftest, create a subdirectory with the sources and a makefile that creates a target named "run_test" then add the subdirectory name to the TARGET var in tools/testing/selftests/Makefile and tools/testing/selftests/run_tests script. This can help centralizing and maintaining any useful selftest that developers usually tend to let rust in peace on some random server. Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Michal Marek <mmarek@suse.cz> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-12lguest: move the lguest tool to the tools directoryDavidlohr Bueso
This is a better location instead of having it in Documentation. Signed-off-by: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (fixed compile)
2012-01-12virtio: rename virtqueue_add_buf_gfp to virtqueue_add_bufRusty Russell
Remove wrapper functions. This makes the allocation type explicit in all callers; I used GPF_KERNEL where it seemed obvious, left it at GFP_ATOMIC otherwise. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Christoph Hellwig <hch@lst.de>
2012-01-12virtio: harsher barriers for rpmsg.Rusty Russell
We were cheating with our barriers; using the smp ones rather than the real device ones. That was fine, until rpmsg came along, which is used to talk to a real device (a non-SMP CPU). Unfortunately, just putting back the real barriers (reverting d57ed95d) causes a performance regression on virtio-pci. In particular, Amos reports netbench's TCP_RR over virtio_net CPU utilization increased up to 35% while throughput went down by up to 14%. By comparison, this branch is in the noise. Reference: https://lkml.org/lkml/2011/12/11/22 Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-10mm-tracepoint: fix documentation and examplesKonstantin Khlebnikov
We renamed the page-free mm tracepoints. Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2012-01-08perf tools: Fix compile error on x86_64 UbuntuNamhyung Kim
The ctype.h include is not needed here and it breaks build on some systems (at least 64bit Ubuntu 10.04) like below. Just get rid of it. CC util/trace-event-info.o cc1: warnings being treated as errors util/trace-event-info.c: In function ‘record_file’: util/trace-event-info.c:192: error: implicit declaration of function ‘pwrite’ util/trace-event-info.c:192: error: nested extern declaration of ‘pwrite’ make: *** [util/trace-event-info.o] Error 1 Cc: Ingo Molnar <mingo@elte.hu> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1326035430-7621-1-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-08perf report: Fix --stdio output alignment when --showcpuutilization usedNamhyung Kim
Current perf report output is broken if --showcpuutilization is used. Combination with -n and/or --show-total-period make things worse. This patch fixes it as follows: before: 48.25% 48.25% 0.00% sleep [kernel.kallsyms] [k] trace_hardirqs_off 34.99% 34.99% 0.00% sleep [kernel.kallsyms] [k] __find_get_block_slow 15.99% 15.99% 0.00% sleep [kernel.kallsyms] [k] lock_release_holdtime 0.77% 0.77% 0.00% sleep [kernel.kallsyms] [k] native_write_msr_safe after: 48.25% 48.25% 0.00% sleep [kernel.kallsyms] [k] trace_hardirqs_off 34.99% 34.99% 0.00% sleep [kernel.kallsyms] [k] __find_get_block_slow 15.99% 15.99% 0.00% sleep [kernel.kallsyms] [k] lock_release_holdtime 0.77% 0.77% 0.00% sleep [kernel.kallsyms] [k] native_write_msr_safe Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325957132-10600-8-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-08perf annotate: Get rid of field_sep checkNamhyung Kim
The 'field_sep' variable is not set anywhere. Just remove the conditional. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325957132-10600-7-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-08perf annotate: Fix usage stringNamhyung Kim
The annotate command doesn't take non-option arguments. In fact, it can take last argument as a symbol filter though, but that's a special case and, IMHO, it should be discouraged in favor of the -s option. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325957132-10600-6-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-08perf kmem: Fix a memory leakNamhyung Kim
The 'str' should be freed when sort_dimension__add() failed too. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325957132-10600-5-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-08perf kmem: Add missing closedir() callsNamhyung Kim
The setup_cpunode_map() calls opendir() but misses corresponding closedir(). Add them. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325957132-10600-4-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-08perf top: Add error message for EMFILENamhyung Kim
When a user tries to open so many events, perf_event_open syscall may fail with EMFILE. Provide advise for that case. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325957132-10600-3-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-08perf test: Change type of '-v' option to INCRNamhyung Kim
The '-v' option is usually defined via OPT_INCR not _INTEGER. Follow the trend :). Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325957132-10600-2-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-08perf script: Add missing closedir() callsNamhyung Kim
The get_script_path() calls opendir() but misses corresponding closedir()'s. Add them. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325957132-10600-1-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-06Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (185 commits) powerpc: fix compile error with 85xx/p1010rdb.c powerpc: fix compile error with 85xx/p1023_rds.c powerpc/fsl: add MSI support for the Freescale hypervisor arch/powerpc/sysdev/fsl_rmu.c: introduce missing kfree powerpc/fsl: Add support for Integrated Flash Controller powerpc/fsl: update compatiable on fsl 16550 uart nodes powerpc/85xx: fix PCI and localbus properties in p1022ds.dts powerpc/85xx: re-enable ePAPR byte channel driver in corenet32_smp_defconfig powerpc/fsl: Update defconfigs to enable some standard FSL HW features powerpc: Add TBI PHY node to first MDIO bus sbc834x: put full compat string in board match check powerpc/fsl-pci: Allow 64-bit PCIe devices to DMA to any memory address powerpc: Fix unpaired probe_hcall_entry and probe_hcall_exit offb: Fix setting of the pseudo-palette for >8bpp offb: Add palette hack for qemu "standard vga" framebuffer offb: Fix bug in calculating requested vram size powerpc/boot: Change the WARN to INFO for boot wrapper overlap message powerpc/44x: Fix build error on currituck platform powerpc/boot: Change the load address for the wrapper to fit the kernel powerpc/44x: Enable CRASH_DUMP for 440x ... Fix up a trivial conflict in arch/powerpc/include/asm/cputime.h due to the additional sparse-checking code for cputime_t.
2012-01-06perf tools: Add const.h to MANIFEST to make perf-tar-src-pkg work againSebastian Andrzej Siewior
Fixes: |make: *** No rule to make target `../../include/linux/const.h', needed by `builtin-annotate.o'. Stop. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1324128938-17553-1-git-send-email-sebastian@breakpoint.cc Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-06perf tools: Add support for guest/host-only profilingJoerg Roedel
To restrict a counter to either host or guest mode this patch introduces two new event modifiers: G and H. With G the counter is configured in guest-only mode and with H in host-only mode. Cc: Gleb Natapov <gleb@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joerg Roedel <joro@8bytes.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Link: http://lkml.kernel.org/n/tip-or5aj3rghy9ngyg882z6kln9@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-06perf kvm: Do guest-only counting by defaultJoerg Roedel
Make use of exclude_guest and exlude_host in perf-kvm to do only guest-only counting by default. Cc: Gleb Natapov <gleb@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joerg Roedel <joro@8bytes.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> [ committer note: Moved perf_{guest,host} & event_attr_init to util.c ] [ so as not to drag more stuff to the python binding] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-06perf top: Don't update total_period on process_sampleArnaldo Carvalho de Melo
It will be recalculated at __hists__output_resort, to take into account filters possibly applied by the TUI, etc. Since we do the percent math only for those entries that will appear on the TUI instead of for _all_ the entries at decay time, updating it for each sample makes the entries seem to decay faster when using the navigation keys (since the screen will be refreshed), as we're not coalescing the entries that are being batched to be merged at next resort/decay time, but considering their periods. Bug introduced in 743eb86. Reported-by: Ingo Molnar <mingo@elte.hu> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-k0d0rq9a8nqtkqohov8cir72@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-06perf hists: Stop using 'self' for struct hist_entryArnaldo Carvalho de Melo
Stop using this python/OOP convention, doesn't really helps. Will do more from time to time till we get it cleaned up in all of /perf. Suggested-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-me4dyj6s5snh7jr8wb9gzt82@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-06perf hists: Rename total_session to total_periodArnaldo Carvalho de Melo
Nowadays we do it per evsel, not per session (that may have multiple evsels), so rename it to avoid confusion. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-azsgomr5h4dmaudoogw48w49@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-04ktest: Add INGORE_ERRORS to ignore warnings in boot upSteven Rostedt
When testing a kernel that has warnings, ktest.pl will fail the test when it sees the warning. If you need to test the the kernel and want to ignore the errors that are produced, the option IGNORE_ERRORS has been added. When IGNORE_ERRORS is set to something other than 0, it will ignore call traces due to WARN_ON(). Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-01-04ktest: Still do reboot even for REBOOT_TYPE = scriptSteven Rostedt
The REBOOT_TYPE may be either grub or script, if it is script it is expected that a REBOOT_SCRIPT is defined. With the SWITCH_TO_TEST which is the complement of SWITCH_TO_GOOD, which does basically the same thing as REBOOT_SCRIPT and but for both grub and script, the REBOOT_SCRIPT does not need to be mandatory anymore. Do not require the REBOOT_SCRIPT and always run the reboot code for both grub and script. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-01-03perf kvm: Fix copy & paste error in descriptionJoerg Roedel
The --host option certainly enables host-data collection. Cc: Avi Kivity <avi@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: kvm@vger.kernel.org Link: http://lkml.kernel.org/r/1317816084-18026-5-git-send-email-gleb@redhat.com Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-03perf script: Kill script_spec__deleteNamhyung Kim
As script_spec__delete() frees given struct script_spec it should not be called if we failed to allocate the struct. Also it's the only caller of the function, we can get rid of the function itself. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325000151-4463-4-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-03perf top: Fix a memory leakNamhyung Kim
The 'buf' should be freed when symbol wasn't found too. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325000151-4463-3-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-03perf stat: Introduce get_ratio_color() helperNamhyung Kim
The get_ratio_color() returns appropriate color string based on @ratio. It helps reducing code duplication. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325000151-4463-2-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-03perf session: Remove impossible condition checkNamhyung Kim
The 'size' cannot be 0 because it was set to 8 on the above line in case it was 0 and never changed. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1325000151-4463-1-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-02misc latin1 to utf8 conversionsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-12-29perf tools: Fix feature-bits rework fallout, remove unused variableIngo Molnar
Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Robert Richter <robert.richter@amd.com> Link: http://lkml.kernel.org/n/tip-lfckuwbl8m1ykb7t9ydsxe4r@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-12-23perf script: Add generic perl handler to process eventsRobert Richter
The current perf scripting facility only supports tracepoints. This patch implements a generic perl handler to support other events than tracepoints too. This patch introduces a function process_event() that is called by perf for each sample. The function is called with byte streams as arguments containing information about the event, its attributes, the sample and raw data. Perl's unpack() function can easily be used for byte decoding. The following is the default implementation for process_event() that can also be generated with perf script: # Packed byte string args of process_event(): # # $event: union perf_event util/event.h # $attr: struct perf_event_attr linux/perf_event.h # $sample: struct perf_sample util/event.h # $raw_data: perf_sample->raw_data util/event.h sub process_event { my ($event, $attr, $sample, $raw_data) = @_; my @event = unpack("LSS", $event); my @attr = unpack("LLQQQQQLLQQ", $attr); my @sample = unpack("QLLQQQQQLL", $sample); my @raw_data = unpack("C*", $raw_data); use Data::Dumper; print Dumper \@event, \@attr, \@sample, \@raw_data; } Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1323969824-9711-4-git-send-email-robert.richter@amd.com Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-23perf tools: Use for_each_set_bit() to iterate over feature flagsRobert Richter
This patch introduces the for_each_set_bit() macro and modifies feature implementation to use it. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1323248577-11268-8-git-send-email-robert.richter@amd.com Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-23perf tools: Unify handling of features when writing feature sectionRobert Richter
The features HEADER_TRACE_INFO and HEADER_BUILD_ID are handled different when writing the feature section. All other features are simply disabled on failure and writing the section goes on without returning an error. There is no reason for these special cases. This patch unifies handling of the features. This should be ok since all features can be parsed independently. Offset and size of a feature's block is stored in struct perf_file_ section right after the data block of perf.data (see perf_session__ write_header()). Thus, if a feature does not exist then other features can be processed anyway. Also moving special code for HEADER_BUILD_ID out to write_build_id(). v2: * perf record throws an error now if buildids may not be generated, which can be disabled with the --no-buildid option. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1323248577-11268-6-git-send-email-robert.richter@amd.com Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-23perf report: Accept fifos as input fileRobert Richter
The default input file for perf report is not handled the same way as perf record does it for its output file. This leads to unexpected behavior of perf report, etc. E.g.: # perf record -a -e cpu-cycles sleep 2 | perf report | cat failed to open perf.data: No such file or directory (try 'perf record' first) While perf record writes to a fifo, perf report expects perf.data to be read. This patch changes this to accept fifos as input file. Applies to the following commands: perf annotate perf buildid-list perf evlist perf kmem perf lock perf report perf sched perf script perf timechart Also fixes char const* -> const char* type declaration for filename strings. v2: * Prevent potential null pointer access to input_name in builtin-report.c. Needed due to removal of patch "perf report: Setup browser if stdout is a pipe" Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1323248577-11268-5-git-send-email-robert.richter@amd.com Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-23perf tools: Moving code in some filesRobert Richter
Needed for later changes. No modified functionality. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1323248577-11268-4-git-send-email-robert.richter@amd.com Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-23perf tools: Fix out-of-bound access to struct perf_sessionRobert Richter
If filename is NULL there is an out-of-bound access to struct perf_session if it would be used with perf_session__open(). Shouldn't actually happen in current implementation as filename is always !NULL. Fixing this by always null-terminating filename. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1323248577-11268-3-git-send-email-robert.richter@amd.com Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-23perf tools: Continue processing header on unknown featuresRobert Richter
A feature may be unknown if perf.data is created and parsed on different perf tool versions. This should not stop the header to be processed, instead continue processing it. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1323248577-11268-2-git-send-email-robert.richter@amd.com Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-23perf tools: Improve macros for struct feature_opsRobert Richter
Reducing duplication and line size by extending function names for print and write from a single name. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1323248577-11268-7-git-send-email-robert.richter@amd.com Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-23perf: builtin-record: Document and check that mmap_pages must be a power of two.Nelson Elhage
Now that we automatically point users at it, let's provide them some guidance so that they hopefully don't just get mysterious EINVAL's from the kernel. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1324301972-22740-4-git-send-email-nelhage@nelhage.com Signed-off-by: Nelson Elhage <nelhage@nelhage.com> [ committer note: Made it work after 50a682c ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
