path: root/tools
2016-05-17tools lib traceevent: Do not reassign parg after collapse_tree()Steven Rostedt
[ Upstream commit 106b816cb46ebd87408b4ed99a2e16203114daa6 ] At the end of process_filter(), collapse_tree() was changed to update the parg parameter, but the reassignment after the call wasn't removed. What happens is that the "current_op" gets modified and freed and parg is assigned to the new allocated argument. But after the call to collapse_tree(), parg is assigned again to the just freed "current_op", and this causes the tool to crash. The current_op variable must also be assigned to NULL in case of error, otherwise it will cause it to be free()ed twice. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: stable@vger.kernel.org # 3.14+ Fixes: 42d6194d133c ("tools lib traceevent: Refactor process_filter()") Link: http://lkml.kernel.org/r/20160511150936.678c18a1@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-18perf tools: Dont stop PMU parsing on alias parse errorAndi Kleen
[ Upstream commit 940db6dcd3f4659303fdf6befe7416adc4d24118 ] When an error happens during alias parsing currently the complete parsing of all attributes of the PMU is stopped. This is breaks old perf on a newer kernel that may have not-yet-know alias attributes (such as .scale or .per-pkg). Continue when some attribute is unparseable. This is IMHO a stable candidate and should be backported to older versions to avoid problems with newer kernels. v2: Print warnings when something goes wrong. v3: Change warning to debug output Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: stable@vger.kernel.org # v3.6+ Link: http://lkml.kernel.org/r/1455749095-18358-1-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-18tools/hv: Use include/uapi with __EXPORTED_HEADERS__Kamal Mostafa
[ Upstream commit 50fe6dd10069e7c062e27f29606f6e91ea979399 ] Use the local uapi headers to keep in sync with "recently" added #define's (e.g. VSS_OP_REGISTER1). Fixes: 3eb2094c59e8 ("Adding makefile for tools/hv") Cc: <stable@vger.kernel.org> Signed-off-by: Kamal Mostafa <kamal@canonical.com> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-11efi: Make efivarfs entries immutable by defaultPeter Jones
[ Upstream commit ed8b0de5a33d2a2557dce7f9429dca8cb5bc5879 ] "rm -rf" is bricking some peoples' laptops because of variables being used to store non-reinitializable firmware driver data that's required to POST the hardware. These are 100% bugs, and they need to be fixed, but in the mean time it shouldn't be easy to *accidentally* brick machines. We have to have delete working, and picking which variables do and don't work for deletion is quite intractable, so instead make everything immutable by default (except for a whitelist), and make tools that aren't quite so broad-spectrum unset the immutable flag. Signed-off-by: Peter Jones <pjones@redhat.com> Tested-by: Lee, Chun-Yi <jlee@suse.com> Acked-by: Matthew Garrett <mjg59@coreos.com> Signed-off-by: Matt Fleming <matt@codeblueprint.co.uk> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-03-07perf tools: Update MANIFEST per files removed from kernelDavid Ahern
[ Upstream commit c8ad7063626406181a7ebab10cb31b4f741b13d4 ] Building perf out of kernel tree is currently broken because the MANIFEST file refers to kernel files that have been removed. With this patch make perf-targz-src-pkg succeeds as does building perf using the generated tarfile. Signed-off-by: David Ahern <david.ahern@oracle.com> Link: http://lkml.kernel.org/r/1433526173-172332-1-git-send-email-david.ahern@oracle.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-03perf kvm record/report: 'unprocessable sample' error while ↵Ravi Bangoria
recording/reporting guest data [ Upstream commit 3caeaa562733c4836e61086ec07666635006a787 ] While recording guest samples in host using perf kvm record, it will populate unprocessable sample error, though samples will be recorded properly. While generating report using perf kvm report, no samples will be processed and same error will populate. We have seen this behaviour with upstream perf(4.4-rc3) on x86 and ppc64 hardware. Reason behind this failure is, when it tries to fetch machine from rb_tree of machines, it fails. As a part of tracing a bug, we figured out that this code was incorrectly refactored in commit 54245fdc3576 ("perf session: Remove wrappers to machines__find"). This patch will change the functionality such that if it can't fetch machine in first trial, it will create one node of machine and add that to rb_tree. So next time when it tries to fetch same machine from rb_tree, it won't fail. Actually it was the case before refactoring of code in aforementioned commit. This patch is generated from acme perf/core branch. Below I've mention an example that demonstrate the behaviour before and after applying patch. Before applying patch: [Note: One needs to run guest before recording data in host] ravi@ravi-bangoria:~$ ./perf kvm record -a Warning: 5903 unprocessable samples recorded. Do you have a KVM guest running and not using 'perf kvm'? [ perf record: Captured and wrote 1.409 MB perf.data.guest (285 samples) ] ravi@ravi-bangoria:~$ ./perf kvm report --stdio Warning: 5903 unprocessable samples recorded. Do you have a KVM guest running and not using 'perf kvm'? # To display the perf.data header info, please use --header/--header-only options. # # Total Lost Samples: 0 # # Samples: 285 of event 'cycles' # Event count (approx.): 88715406 # # Overhead Command Shared Object Symbol # ........ ....... ............. ...... # # (For a higher level overview, try: perf report --sort comm,dso) # After applying patch: ravi@ravi-bangoria:~$ ./perf kvm record -a [ perf record: Captured and wrote 1.188 MB perf.data.guest (17 samples) ] ravi@ravi-bangoria:~$ ./perf kvm report --stdio # To display the perf.data header info, please use --header/--header-only options. # # Total Lost Samples: 0 # # Samples: 17 of event 'cycles' # Event count (approx.): 700746 # # Overhead Command Shared Object Symbol # ........ ....... ................ ...................... # 34.19% :5758 [unknown] [g] 0xffffffff818682ab 22.79% :5758 [unknown] [g] 0xffffffff812dc7f8 22.79% :5758 [unknown] [g] 0xffffffff818650d0 14.83% :5758 [unknown] [g] 0xffffffff8161a1b6 2.49% :5758 [unknown] [g] 0xffffffff818692bf 0.48% :5758 [unknown] [g] 0xffffffff81869253 0.05% :5758 [unknown] [g] 0xffffffff81869250 Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com> Cc: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Cc: stable@vger.kernel.org # v3.19+ Fixes: 54245fdc3576 ("perf session: Remove wrappers to machines__find") Link: http://lkml.kernel.org/r/1449471302-11283-1-git-send-email-ravi.bangoria@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-02-01tools lib traceevent: Fix output of %llu for 64 bit values read on 32 bit ↵Steven Rostedt
machines [ Upstream commit 32abc2ede536aae52978d6c0a8944eb1df14f460 ] When a long value is read on 32 bit machines for 64 bit output, the parsing needs to change "%lu" into "%llu", as the value is read natively. Unfortunately, if "%llu" is already there, the code will add another "l" to it and fail to parse it properly. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: stable@vger.kernel.org Link: http://lkml.kernel.org/r/20151116172516.4b79b109@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-12-14tools/net: Use include/uapi with __EXPORTED_HEADERS__Kamal Mostafa
[ Upstream commit d7475de58575c904818efa369c82e88c6648ce2e ] Use the local uapi headers to keep in sync with "recently" added #define's (e.g. SKF_AD_VLAN_TPID). Refactored CFLAGS, and bpf_asm doesn't need -I. Fixes: 3f356385e8a4 ("filter: bpf_asm: add minimal bpf asm tool") Signed-off-by: Kamal Mostafa <kamal@canonical.com> Acked-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22tools lib traceevent: Fix string handling in heterogeneous arch environmentsKapileshwar Singh
commit c2e4b24ff848bb180f9b9cd873a38327cd219ad2 upstream. When a trace recorded on a 32-bit device is processed with a 64-bit binary, the higher 32-bits of the address need to ignored. The lack of this results in the output of the 64-bit pointer value to the trace as the 32-bit address lookup fails in find_printk(). Before: burn-1778 [003] 548.600305: bputs: 0xc0046db2s: 2cec5c058d98c After: burn-1778 [003] 548.600305: bputs: 0xc0046db2s: RT throttling activated The problem occurs in PRINT_FIELD when the field is recognized as a pointer to a string (of the type const char *) Heterogeneous architectures cases below can arise and should be handled: * Traces recorded using 32-bit addresses processed on a 64-bit machine * Traces recorded using 64-bit addresses processed on a 32-bit machine Reported-by: Juri Lelli <juri.lelli@arm.com> Signed-off-by: Kapileshwar Singh <kapileshwar.singh@arm.com> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Javi Merino <javi.merino@arm.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/1442928123-13824-1-git-send-email-kapileshwar.singh@arm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf header: Fixup reading of HEADER_NRCPUS featureArnaldo Carvalho de Melo
commit caa470475d9b59eeff093ae650800d34612c4379 upstream. The original patch introducing this header wrote the number of CPUs available and online in one order and then swapped those values when reading, fix it. Before: # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 4 # echo 0 > /sys/devices/system/cpu/cpu2/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 3 # echo 0 > /sys/devices/system/cpu/cpu1/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 2 After the fix, bringing back the CPUs online: # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 2 # nrcpus avail : 4 # echo 1 > /sys/devices/system/cpu/cpu2/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 3 # nrcpus avail : 4 # echo 1 > /sys/devices/system/cpu/cpu1/online # perf record usleep 1 # perf report --header-only | grep 'nrcpus \(online\|avail\)' # nrcpus online : 4 # nrcpus avail : 4 Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Kan Liang <kan.liang@intel.com> Cc: Stephane Eranian <eranian@google.com> Cc: Wang Nan <wangnan0@huawei.com> Fixes: fbe96f29ce4b ("perf tools: Make perf.data more self-descriptive (v8)") Link: http://lkml.kernel.org/r/20150911153323.GP23511@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf tools: Add empty Build files for architectures lacking themBen Hutchings
commit 93df8a1ed6231727c5db94a80b1a6bd5ee67cec3 upstream. perf currently fails to build on MIPS as there is no tools/perf/arch/mips/Build file. Adding an empty file fixes this as there are no MIPS-specific sources to build. It looks like the same is needed for Alpha and PA-RISC, though I haven't been able to test those. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Fixes: 5e8c0fb6a957 ("perf build: Add arch x86 objects building") Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1438704627.7315.2.camel@decadent.org.uk Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf stat: Get correct cpu id for print_aggrKan Liang
commit 601083cffb7cabdcc55b8195d732f0f7028570fa upstream. print_aggr() fails to print per-core/per-socket statistics after commit 582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events") if events have differnt cpus. Because in print_aggr(), aggr_get_id needs index (not cpu id) to find core/pkg id. Also, evsel cpu maps should be used to get aggregated id. Here is an example: Counting events cycles,uncore_imc_0/cas_count_read/. (Uncore event has cpumask 0,18) $ perf stat -e cycles,uncore_imc_0/cas_count_read/ -C0,18 --per-core sleep 2 Without this patch, it failes to get CPU 18 result. Performance counter stats for 'CPU(s) 0,18': S0-C0 1 7526851 cycles S0-C0 1 1.05 MiB uncore_imc_0/cas_count_read/ S1-C0 0 <not counted> cycles S1-C0 0 <not counted> MiB uncore_imc_0/cas_count_read/ With this patch, it can get both CPU0 and CPU18 result. Performance counter stats for 'CPU(s) 0,18': S0-C0 1 6327768 cycles S0-C0 1 0.47 MiB uncore_imc_0/cas_count_read/ S1-C0 1 330228 cycles S1-C0 1 0.29 MiB uncore_imc_0/cas_count_read/ Signed-off-by: Kan Liang <kan.liang@intel.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Stephane Eranian <eranian@google.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Fixes: 582ec0829b3d ("perf stat: Fix per-socket output bug for uncore events") Link: http://lkml.kernel.org/r/1435820925-51091-1-git-send-email-kan.liang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf hists: Update the column width for the "srcline" sort keyArnaldo Carvalho de Melo
commit e8e6d37e73e6b950c891c780745460b87f4755b6 upstream. When we introduce a new sort key, we need to update the hists__calc_col_len() function accordingly, otherwise the width will be limited to strlen(header). We can't update it when obtaining a line value for a column (for instance, in sort__srcline_cmp()), because we reset it all when doing a resort (see hists__output_recalc_col_len()), so we need to, from what is in the hist_entry fields, set each of the column widths. Cc: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: Jiri Olsa <jolsa@kernel.org> Fixes: 409a8be61560 ("perf tools: Add sort by src line/number") Link: http://lkml.kernel.org/n/tip-jgbe0yx8v1gs89cslr93pvz2@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf tools: Fix copying of /proc/kcoreAdrian Hunter
commit b5cabbcbd157a4bf5a92dfc85134999a3b55342d upstream. A copy of /proc/kcore containing the kernel text can be made to the buildid cache. e.g. perf buildid-cache -v -k /proc/kcore To workaround objdump limitations, a copy is also made when annotating against /proc/kcore. The copying process stops working from libelf about v1.62 onwards (the problem was found with v1.63). The cause is that a call to gelf_getphdr() in kcore__add_phdr() fails because additional validation has been added to gelf_getphdr(). The use of gelf_getphdr() is a misguided attempt to get default initialization of the Gelf_Phdr structure. That should not be necessary because every member of the Gelf_Phdr structure is subsequently assigned. So just remove the call to gelf_getphdr(). Similarly, a call to gelf_getehdr() in gelf_kcore__init() can be removed also. Committer notes: Note to stable@kernel.org, from Adrian in the cover letter for this patchkit: The "Fix copying of /proc/kcore" problem goes back to v3.13 if you think it is important enough for stable. Signed-off-by: Adrian Hunter <adrian.hunter@intel.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1443089122-19082-3-git-send-email-adrian.hunter@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-10perf symbols: Store if there is a filter in placeArnaldo Carvalho de Melo
commit 0bc2f2f7d080561cc484d2d0a162a9396bed3383 upstream. When setting yup the symbols library we setup several filter lists, for dsos, comms, symbols, etc, and there is code that, if there are filters, do certain operations, like recalculate the number of non filtered histogram entries in the top/report TUI. But they were considering just the "Zoom" filters, when they need to take into account as well the above mentioned filters (perf top --comms, --dsos, etc). So store in symbol_conf.has_filter true if any of those filters is in place. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-f5edfmhq69vfvs1kmikq1wep@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Andre Tomt <lkml@tomt.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-10perf hists browser: Take the --comm, --dsos, etc filters into accountArnaldo Carvalho de Melo
commit 9c0fa8dd3d58de8b688fda758eea1719949c7f0a upstream. At some point: commit 2c86c7ca7606 Author: Namhyung Kim <namhyung@kernel.org> Date: Mon Mar 17 18:18:54 2014 -0300 perf report: Merge al->filtered with hist_entry->filtered We stopped dropping samples for things filtered via the --comms, --dsos, --symbols, etc, i.e. things marked as filtered in the symbol resolution routines (thread__find_addr_map(), perf_event__preprocess_sample(), etc). But then, in: commit 268397cb2a47 Author: Namhyung Kim <namhyung@kernel.org> Date: Tue Apr 22 14:49:31 2014 +0900 perf top/tui: Update nr_entries properly after a filter is applied We don't take into account entries that were filtered in perf_event__preprocess_sample() and friends, which leads to inconsistency in the browser seek routines, that expects the number of hist_entry->filtered entries to match what it thinks is the number of unfiltered, browsable entries. So, for instance, when we do: perf top --symbols ___non_existent_symbol___ the hist_browser__nr_entries() routine thinks there are no filters in place, uses the hists->nr_entries but all entries are filtered, leading to a segfault. Tested with: perf top --symbols malloc,free --percentage=relative Freezing, by pressing 'f', at any time and doing the math on the percentages ends up with 100%, ditto for: perf top --dsos libpthread-2.20.so,libxul.so --percentage=relative Both were segfaulting, all fixed now. More work needed to do away with checking if filters are in place, we should just use the nr_non_filtered_samples counter, no need to conditionally use it or hists.nr_filter, as what the browser does is just show unfiltered stuff. An audit of how it is being accounted is needed, this is the minimal fix. Reported-by: Michael Petlan <mpetlan@redhat.com> Fixes: 268397cb2a47 ("perf top/tui: Update nr_entries properly after a filter is applied") Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-6w01d5q97qk0d64kuojme5in@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03perf bench numa: Fix to show proper convergence statsSrikar Dronamraju
commit 2b42b09b88c831ba4da2d669581dde371c38c2af upstream. With commit: e1e455f4f4d3 (perf tools: Work around lack of sched_getcpu in glibc < 2.6), perf_bench numa mem with -c or -m option is not able to correctly calculate convergence. With the above commit, sched_getcpu always seems to return -1. The intention of commit e1e455f was to add a sched_getcpu in glibc < 2.6. Hence keep the sched_getcpu definition under an ifdef. This regression happened occurred between v4.0 and v4.1 Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Vinson Lee <vlee@twitter.com> Fixes: e1e455f4f4d3 ("perf tools: Work around lack of sched_getcpu in glibc < 2.6") Link: http://lkml.kernel.org/r/20150624111004.GA5220@linux.vnet.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-21tools selftests: Fix 'clean' target with make 3.81Arnaldo Carvalho de Melo
commit 60df4642a83546fa6ea8286f5094ce8c0906c3ec upstream. Make 3.81 doesn't have the 'undefine' command. Using undefine to clear LDFLAGS fails when make version 3.81 is used. Fix it to use override to clear LDFLAGS. Tested-by: Shuah Khan <shuahkh@osg.samsung.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Link: http://lkml.kernel.org/r/20150514151225.GH23588@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com> Cc: Sudip Mukherjee <sudipm.mukherjee@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-29perf tools: Fix build breakage if prefix= is specifiedLukas Wunner
commit 75e84ab906ef8935cff3df3d8929f1bafea81599 upstream. Invoking Makefile.perf with prefix= breaks the build since Makefile.perf hands that variable down to Makefile.build where it overrides prefix := $(subst ./,,$(OUTPUT)$(dir)/) leading to errors like this: No rule to make target '/usrabspath.o', needed by '/usrlibperf-in.o' Signed-off-by: Lukas Wunner <lukas@wunner.de> Acked-by: Jiri Olsa <jolsa@kernel.org> Cc: David Ahern <dsahern@gmail.com> Fixes: c819e2cf2eb6f65d3208d195d7a0edef6108d5 Link: http://lkml.kernel.org/r/5582c48a.84a22b0a.a918.5285SMTPIN_ADDED_MISSING@mx.google.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-05Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Misc fixes: - early_idt_handlers[] fix that fixes the build with bleeding edge tooling - build warning fix on GCC 5.1 - vm86 fix plus self-test to make it harder to break it again" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/asm/irq: Stop relying on magic JMP behavior for early_idt_handlers x86/asm/entry/32, selftests: Add a selftest for kernel entries from VM86 mode x86/boot: Add CONFIG_PARAVIRT_SPINLOCKS quirk to arch/x86/boot/compressed/misc.h x86/asm/entry/32: Really make user_mode() work correctly for VM86 mode
2015-05-31Merge branch 'turbostat' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull turbostat tool fixes from Len Brown: "Just one minor kernel dependency in this batch -- added a #define to msr-index.h" * 'turbostat' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: tools/power turbostat: update version number to 4.7 tools/power turbostat: allow running without cpu0 tools/power turbostat: correctly decode of ENERGY_PERFORMANCE_BIAS tools/power turbostat: enable turbostat to support Knights Landing (KNL) tools/power turbostat: correctly display more than 2 threads/core
2015-05-30x86/asm/entry/32, selftests: Add a selftest for kernel entries from VM86 modeAndy Lutomirski
Test a couple of special cases in 32-bit kernels for entries from vm86 mode. This will OOPS both old kernels due to a bug and and 4.1-rc5 due to a regression I introduced, and it should make sure that the SYSENTER-from-vm86-mode hack in the kernel keeps working. Signed-off-by: Andy Lutomirski <luto@kernel.org> Cc: Jan Beulich <JBeulich@suse.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Shuah Khan <shuahkh@osg.samsung.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/09a9916761e0a9e42d4922f147af45a0079cc1e8.1432936374.git.luto@kernel.org Tests: 394838c96013 x86/asm/entry/32: Fix user_mode() misuses Tests: 7ba554b5ac69 x86/asm/entry/32: Really make user_mode() work correctly for VM86 mode Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-27tools/power turbostat: update version number to 4.7Len Brown
Signed-off-by: Len Brown <len.brown@intel.com>
2015-05-27tools/power turbostat: allow running without cpu0Prarit Bhargava
Linux-3.7 added CONFIG_BOOTPARAM_HOTPLUG_CPU0, allowing systems to offline cpu0. But when cpu0 is offline, turbostat will not run: # turbostat ls turbostat: no /dev/cpu/0/msr This patch replaces the hard-coded use of cpu0 in turbostat with the current cpu, allowing it to run without a cpu0. Fewer cross-calls may also be needed due to use of current cpu, though this hard-coding was used only for the --debug preamble. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2015-05-27tools/power turbostat: correctly decode of ENERGY_PERFORMANCE_BIASLen Brown
When EPB is 0xF, turbosat was incorrectly describing it as "custom" instead of calling it "powersave": < cpu0: MSR_IA32_ENERGY_PERF_BIAS: 0x0000000f (custom) > cpu0: MSR_IA32_ENERGY_PERF_BIAS: 0x0000000f (powersave) Signed-off-by: Len Brown <len.brown@intel.com>
2015-05-27tools/power turbostat: enable turbostat to support Knights Landing (KNL)Dasaratharaman Chandramouli
Changes mainly to account for minor differences in Knights Landing(KNL): 1. KNL supports C1 and C6 core states. 2. KNL supports PC2, PC3 and PC6 package states. 3. KNL has a different encoding of the TURBO_RATIO_LIMIT MSR Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2015-05-27tools/power turbostat: correctly display more than 2 threads/coreDasaratharaman Chandramouli
Without this update, turbostat displays only 2 threads per core. Some processors, such as Xeon Phi, have more. Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2015-05-27tools: bpf_jit_disasm: fix segfault on disabled debugging log outputDaniel Borkmann
With recent debugging, I noticed that bpf_jit_disasm segfaults when there's no debugging output from the JIT compiler to the kernel log. Reason is that when regexec(3) doesn't match on anything, start/end offsets are not being filled out and contain some uninitialized garbage from stack. Thus, we need zero out offsets first. Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-05-16Merge branch 'for-rc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux Pull thermal fixes from Zhang Rui: "Specifics: - fix an issue in intel_powerclamp driver that idle injection target is not accurately maintained on newer Intel CPUs. Package C8 to C10 states are introduced on these CPUs but they were not included in the package c-state residency calculation. From Jacob Pan. - fix a problem that package c-state idle injection was missing on Broadwell server, by adding its id to intel_powerclamp driver. From Jacob Pan. - a couple of small fixes and cleanups from Joe Perches, Mathias Krause, Dan Carpenter and Anand Moon" * 'for-rc' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: tools/thermal: tmon: fixed the 'make install' command thermal: rockchip: fix an error code thermal/powerclamp: fix missing newer package c-states thermal/intel_powerclamp: add id for broadwell server thermal/intel_powerclamp: add __init / __exit annotations thermal: Use bool function return values of true/false not 1/0
2015-05-16Merge tag 'linux-kselftest-4.1-rc4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest Pull kselftest fixes from Shuah Khan: "Urgent fix for Kselftest regression introduced in 4.1-rc1 by the new x86 test due to its hard dependency on 32-bit build environment. A set of 5 patches fix the make kselftest run and kselftest install" * tag 'linux-kselftest-4.1-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/shuah/linux-kselftest: selftests, x86: Rework x86 target architecture detection selftests, x86: Remove useless run_tests rule selftests/x86: install tests selftest/x86: have no dependency on all when cross building selftest/x86: build both bitnesses
2015-05-15Merge branch 'liblockdep-fixes' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/sashal/linux into perf/urgent Pull liblockdep fixes from Sasha Levin: "two fixes that deal with compilation errors in liblockdep." Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-13tools/liblockdep: Fix compilation errorEunbong Song
Recent changes to kernel/locking/lockdep.c broke the liblockdep build. Fix that. Signed-off-by: Eunbong Song <eunb.song@samsung.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-13tools/liblockdep: Fix linker error in case of cross compileEunbong Song
If we try to cross compile liblockdep, even if we set the CROSS_COMPILE variable the linker error can occur because LD is not set with CROSS_COMPILE. This patch adds "LD" can be set automatically with CROSS_COMPILE variable so fixes linker error problem. Signed-off-by: Eunbong Song <eunb.song@samsung.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-05-12selftests, x86: Rework x86 target architecture detectionAndy Lutomirski
We currently fail to build on a non-multilib x86_64 target. We print a helpful error, but it's nicer to allow the build to succeed. Fix it and improve cross-compilation support by detecting architecture support directly and building only the relevant tests. Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2015-05-12selftests, x86: Remove useless run_tests ruleAndy Lutomirski
Now that selftests/x86 uses the kselftest infrastructure, the run_x86_tests.sh mechanism is just in the way. Signed-off-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2015-05-12selftests/x86: install testsTyler Baker
Include lib.mk and set TEST_PROGS where appropriate. Cc: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Tyler Baker <tyler.baker@linaro.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2015-05-12selftest/x86: have no dependency on all when cross buildingTyler Baker
If the CROSS_COMPILE is set remove all's dependency on all_32 and all_64. Cc: Andy Lutomirski <luto@amacapital.net> Acked-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Tyler Baker <tyler.baker@linaro.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2015-05-12selftest/x86: build both bitnessesTyler Baker
Using uname with the processor flag option in some cases can yield 'unknown' so lets use the machine flag option as it is deterministic. Add a dependency for all_32 when building on a x86 64 bit host so that both bitnesses are built in this case. Cc: Andy Lutomirski <luto@amacapital.net> Acked-by: Andy Lutomirski <luto@kernel.org> Signed-off-by: Tyler Baker <tyler.baker@linaro.org> Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
2015-05-12perf tools: Use getconf to determine number of online CPUsWill Deacon
Parsing /proc/cpuinfo is a fiddly, arch-dependent business and a recent change to get it working for Sparc broke arm and arm64 platforms. Use sysconf to determine the number of online CPUs only parsing /proc/cpuinfo when sysconf is not available. Signed-off-by: Will Deacon <will.deacon@arm.com> Acked-by: Jiri Olsa <jolsa@kernel.org> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David Ahern <david.ahern@oracle.com> Cc: Mark Rutland <Mark.Rutland@arm.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150423140454.GJ1652@arm.com [ Made it fall back to parsing /proc when getconf not found ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-05-12tools: Fix tools/vm buildAndi Kleen
libabikfs.a doesn't exist anymore, so we now need to link with libapi.a. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/1426199953-15324-1-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-05-09tools/thermal: tmon: fixed the 'make install' commandAnand Moon
To install tmon we issue "make install" which produces bellow error. root@odroidxu3:/usr/src/odroidxu3-4.y-testing/tools/thermal/tmon# make install mkdir -p /usr/bin install -m 755 -p "tmon" "/usr/bin/tmon" mkdir -p / install -m 644 -p "" "/" install: cannot stat ‘’: No such file or directory make: [install] Error 1 (ignored) Signed-off-by: Anand Moon <linux.amoon@gmail.com> Acked-by: Jacob Pan <jacob.jun.pan@linux.intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com>
2015-05-06Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Mostly tooling fixes, but also an uncore PMU driver fix and an uncore PMU driver hardware-enablement addition" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf probe: Fix segfault if passed with ''. perf report: Fix -T/--threads option to work again perf bench numa: Fix immediate meeting of convergence condition perf bench numa: Fixes of --quiet argument perf bench futex: Fix hung wakeup tasks after requeueing perf probe: Fix bug with global variables handling perf top: Fix a segfault when kernel map is restricted. tools lib traceevent: Fix build failure on 32-bit arch perf kmem: Fix compiles on RHEL6/OL6 tools lib api: Undefine _FORTIFY_SOURCE before setting it perf kmem: Consistently use PRIu64 for printing u64 values perf trace: Disable events and drain events when forked workload ends perf trace: Enable events when doing system wide tracing and starting a workload perf/x86/intel/uncore: Move PCI IDs for IMC to uncore driver perf/x86/intel/uncore: Add support for Intel Haswell ULT (lower power Mobile Processor) IMC uncore PMUs perf/x86/intel: Add cpu_(prepare|starting|dying) for core_pmu
2015-05-05perf probe: Fix segfault if passed with ''.Wang Nan
Since parse_perf_probe_point() deals with a user passed argument, we should not assume it to be a valid string. Without this patch, if pass '' to perf probe, a segfault raises: $ perf probe -a '' Segmentation fault This patch checks argument of parse_perf_probe_point() before string processing. After this patch: $ perf probe -a '' usage: perf probe [<options>] 'PROBEDEF' ['PROBEDEF' ...] or: perf probe [<options>] --add 'PROBEDEF' [--add 'PROBEDEF' ...] ... Signed-off-by: Wang Nan <wangnan0@huawei.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Zefan Li <lizefan@huawei.com> Link: http://lkml.kernel.org/r/1430210769-94177-1-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-05-01perf report: Fix -T/--threads option to work againNamhyung Kim
The commit 512ae1bd6acb ("perf tools: Consolidate management of default sort orders") changed default value of the 'sort_order' variable to NULL indicating that users don't set any sort keys on the command line. However it missed to update a check in perf_evlist__tty_browse_hists() so that 'perf report -T' cannot show the per-thread values after the normal output. This patch fixes it to work again. Note that the -T option only works on --stdio and neither --sort nor --parent option was given. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1430309328-28317-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-05-01selftests/powerpc: Fix the pmu install ruleMichael Ellerman
My patch to add install support for the powerpc selftests had a typo, leading to the three tests in the pmu directory itself not being installed. Fixes: 6faeeea44b84 ("selftests: Add install support for the powerpc tests") Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-04-30Revert "powerpc/tm: Abort syscalls in active transactions"Michael Ellerman
This reverts commit feba40362b11341bee6d8ed58d54b896abbd9f84. Although the principle of this change is good, the implementation has a few issues. Firstly we can sometimes fail to abort a syscall because r12 may have been clobbered by C code if we went down the virtual CPU accounting path, or if syscall tracing was enabled. Secondly we have decided that it is safer to abort the syscall even earlier in the syscall entry path, so that we avoid the syscall tracing path when we are transactional. So that we have time to thoroughly test those changes we have decided to revert this for this merge window and will merge the fixed version in the next window. NB. Rather than reverting the selftest we just drop tm-syscall from TEST_PROGS so that it's not run by default. Fixes: feba40362b11 ("powerpc/tm: Abort syscalls in active transactions") Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-04-27perf bench numa: Fix immediate meeting of convergence conditionPetr Holasek
This patch fixes the race in the beginning of benchmark run when some threads hasn't got assigned curr_cpu yet so they don't occur in nodes-of-process stats and benchmark concludes that all remaining threads are converged already. The race can be reproduced with small amount of threads and some bigger amount of shared process memory, e.g. one process, two threads and 5GB of process memory. Signed-off-by: Petr Holasek <pholasek@redhat.com> Reviewed-by: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1429198699-25039-4-git-send-email-pholasek@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-04-27perf bench numa: Fixes of --quiet argumentPetr Holasek
Corrected description and fixed function of --quiet argument. Signed-off-by: Petr Holasek <pholasek@redhat.com> Reviewed-by: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1429198699-25039-2-git-send-email-pholasek@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-04-27perf bench futex: Fix hung wakeup tasks after requeueingDavidlohr Bueso
The futex-requeue benchmark can hang because of missing wakeups once the benchmark is done, ie: [Run 1]: Requeued 1024 of 1024 threads in 0.3290 ms perf: couldn't wakeup all tasks (135/1024) This bug, while perhaps suggesting missing wakeups in kernel futex code, is merely a consequence of the crappy FUTEX_CMP_REQUEUE man page, incorrectly mentioning that the number of requeued tasks is in fact returned, not the wakeups. This patch acknowledges this and updates the corresponding futex_wake code around it. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Cc: Mel Gorman <mgorman@suse.de> Link: http://lkml.kernel.org/r/1429894848.10273.44.camel@stgolabs.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-04-27perf probe: Fix bug with global variables handlingHe Kuang
There are missing curly braces which causes find_variable() return wrong value when probing with global variables. This problem can be reproduced as following: $ perf probe -v --add='generic_perform_write global_variable_for_test' ... Try to find probe point from debuginfo. Probe point found: generic_perform_write+0 Searching 'global_variable_for_test' variable in context. An error occurred in debuginfo analysis (-2). Error: Failed to add events. Reason: No such file or directory (Code: -2) After this patch: $ perf probe -v --add='generic_perform_write global_variable_for_test' ... Converting variable global_variable_for_test into trace event. global_variable_for_test type is int. Found 1 probe_trace_events. Opening /sys/kernel/debug/tracing/kprobe_events write=1 Added new event: Writing event: p:probe/generic_perform_write _stext+1237464 global_variable_for_test=@global_variable_for_test+0:s32 probe:generic_perform_write (on generic_perform_write with global_variable_for_test) You can now use it in all perf tools, such as: perf record -e probe:generic_perform_write -aR sleep 1 Signed-off-by: He Kuang <hekuang@huawei.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1429949338-18678-1-git-send-email-hekuang@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
