commit ad343a98e74e85aa91d844310e797f96fee6983b upstream.
Use a separate fd set for select()-s exception fds param to fix the
following gcc warning:
pager.c:36:12: error: passing argument 2 to restrict-qualified parameter aliases with argument 4 [-Werror=restrict]
select(1, &in, NULL, &in, NULL);
Link: http://lkml.kernel.org/r/20180101105626.7168-1-sergey.senozhatsky@gmail.com
Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Fredrik Schön <fredrikschon@gmail.com>
commit 854e55ad289ef8888e7991f0ada85d5846f5afb9 upstream.
Starting with recent GCC 8 builds, objtool and perf fail to build with
the following error:
../str_error_r.c: In function ‘str_error_r’:
../str_error_r.c:25:3: error: passing argument 1 to restrict-qualified parameter aliases with argument 5 [-Werror=restrict]
snprintf(buf, buflen, "INTERNAL ERROR: strerror_r(%d, %p, %zd)=%d", errnum, buf, buflen, err);
The code seems harmless, but there's probably no benefit in printing the
'buf' pointer in this situation anyway, so just remove it to make GCC
happy.
Reported-by: Laura Abbott <labbott@redhat.com>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Tested-by: Laura Abbott <labbott@redhat.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/r/20180316031154.juk2uncs7baffctp@treble
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
This reverts commit e2d054998b151e85b6305aa72264f67097bd78e9 which is
commit 1d6b3c9ba756a5134fd7ad1959acac776d17404b upstream.
It breaks the build, so obviously none of us actually tested it :(
Reported-by: Maxime Hadjinlian <maxime.hadjinlian@gmail.com>
Reported-by: Akemi Yagi <toracat@elrepo.org>
Cc: David Ahern <dsahern@gmail.com>
Cc: kernel-team@lge.com
Cc: Sasha Levin <alexander.levin@microsoft.com>
This reverts commit 7525a238be8f46617cdda29d1be5b85ffe3b042d which is
commit 94df1040b1e6aacd8dec0ba3c61d7e77cd695f26 upstream.
It breaks the build of perf on 4.9.y, so I'm dropping it.
Reported-by: Pavlos Parissis <pavlos.parissis@gmail.com>
Reported-by: Lei Chen <chenl.lei@gmail.com>
commit 91d29b288aed3406caf7c454bf2b898c96cfd177 upstream.
timestamp_insn_cnt is used to estimate the timestamp based on the number of
instructions since the last known timestamp.
If the estimate is not accurate enough decoding might not be correctly
synchronized with side-band events causing more trace errors.
However there are always timestamps following an overflow, so the
estimate is not needed and can indeed result in more errors.
Suppress the estimate by setting timestamp_insn_cnt to zero.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/1520431349-30689-5-git-send-email-adrian.hunter@intel.com
commit 1c196a6c771c47a2faa63d38d913e03284f73a16 upstream.
When a TIP packet is expected but there is a different packet, it is an
error. However the unexpected packet might be something important like a
TSC packet, so after the error, it is necessary to continue from there,
rather than the next packet. That is achieved by setting pkt_step to
zero.
Link: http://lkml.kernel.org/r/1520431349-30689-4-git-send-email-adrian.hunter@intel.com
commit 63d8e38f6ae6c36dd5b5ba0e8c112e8861532ea2 upstream.
sync_switch is a facility to synchronize decoding more closely with the
point in the kernel when the context actually switched.
The flag when sync_switch is enabled was global to the decoding, whereas
it is really specific to the CPU.
The trace data for different CPUs is put on different queues, so add
sync_switch to the intel_pt_queue structure and use that in preference
to the global setting in the intel_pt structure.
That fixes problems decoding one CPU's trace because sync_switch was
disabled on a different CPU's queue.
Link: http://lkml.kernel.org/r/1520431349-30689-3-git-send-email-adrian.hunter@intel.com
commit 117db4b27bf08dba412faf3924ba55fe970c57b8 upstream.
Overlap detection was not not updating the buffer's 'consecutive' flag.
Marking buffers consecutive has the advantage that decoding begins from
the start of the buffer instead of the first PSB. Fix overlap detection
to identify consecutive buffers correctly.
Link: http://lkml.kernel.org/r/1520431349-30689-2-git-send-email-adrian.hunter@intel.com
[ Upstream commit fa1195ccc0af2d121abe0fe266a1caee8c265eea ]
We need to increase output offset in each iteration, not decrease it as
we currently do.
I guess we were lucky to finish in most cases in first iteration, so the
bug never showed. However it shows a lot when working with big (~4GB)
size data.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Fixes: 9c9f5a2f1944 ("perf tools: Introduce copyfile_offset() function")
Link: http://lkml.kernel.org/r/20180109133923.25406-1-jolsa@kernel.org
[ Upstream commit 34a048cc06802556e5f96f325dc32cc2f6a11225 ]
Do not confuse the compiler with a semicolon preceding a block. Replace
the semicolon with an empty block to avoid a warning:
gcc -Wl,-no-as-needed -Wall -lpthread seccomp_bpf.c -o /.../linux/tools/testing/selftests/seccomp/seccomp_bpf
In file included from seccomp_bpf.c:40:0:
seccomp_bpf.c: In function ‘change_syscall’:
../kselftest_harness.h:558:2: warning: this ‘for’ clause does not guard... [-Wmisleading-indentation]
for (; _metadata->trigger; _metadata->trigger = __bail(_assert))
../kselftest_harness.h:574:14: note: in expansion of macro ‘OPTIONAL_HANDLER’
} while (0); OPTIONAL_HANDLER(_assert)
../kselftest_harness.h:440:2: note: in expansion of macro ‘__EXPECT’
__EXPECT(expected, seen, ==, 0)
seccomp_bpf.c:1313:2: note: in expansion of macro ‘EXPECT_EQ’
EXPECT_EQ(0, ret);
seccomp_bpf.c:1317:2: note: ...this statement, but the latter is misleadingly indented as if it is guarded by the ‘for’
Signed-off-by: Mickaël Salaün <mic@digikod.net>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
Cc: Will Drewry <wad@chromium.org>
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
[ Upstream commit 94df1040b1e6aacd8dec0ba3c61d7e77cd695f26 ]
If a kernel modules is compressed, it should be decompressed before
running objdump to parse binary data correctly. This fixes a failure of
object code reading test for me.
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/20170608073109.30699-8-namhyung@kernel.org
[ Upstream commit 1d6b3c9ba756a5134fd7ad1959acac776d17404b ]
Currently perf decompresses kernel modules when loading the symbol table
but it missed to do it when reading raw data.
Link: http://lkml.kernel.org/r/20170608073109.30699-6-namhyung@kernel.org
[ Upstream commit 2538b9e2450ae255337c04356e9e0f8cb9ec48d9 ]
In some situations the libdw unwinder stopped working properly. I.e.
with libunwind we see:
heaptrack_gui 2228 135073.400112: 641314 cycles:
e8ed _dl_fixup (/usr/lib/ld-2.25.so)
15f06 _dl_runtime_resolve_sse_vex (/usr/lib/ld-2.25.so)
ed94c KDynamicJobTracker::KDynamicJobTracker (/home/milian/projects/compiled/kf5/lib64/libKF5KIOWidgets.so.5.35.0)
608f3 _GLOBAL__sub_I_kdynamicjobtracker.cpp (/home/milian/projects/compiled/kf5/lib64/libKF5KIOWidgets.so.5.35.0)
f199 call_init.part.0 (/usr/lib/ld-2.25.so)
f2a5 _dl_init (/usr/lib/ld-2.25.so)
db9 _dl_start_user (/usr/lib/ld-2.25.so)
But with libdw and without this patch this sample is not properly
unwound:
Debug output showed me that libdw found a module for the last frame
address, but it thinks it belongs to /usr/lib/ld-2.25.so. This patch
double-checks what libdw sees and what perf knows. If the mappings
mismatch, we now report the elf known to perf. This fixes the situation
above, and the libdw unwinder produces the same stack as libunwind.
Signed-off-by: Milian Wolff <milian.wolff@kdab.com>
Link: http://lkml.kernel.org/r/20170602143753.16907-1-milian.wolff@kdab.com
[ Upstream commit 1deec1bd96ccd8beb04d2112a6d12fe20505c3a6 ]
When perf processes build-id event, it creates DSOs with the build-id.
But it didn't set the module short name (like '[module-name]') so when
processing a kernel mmap event of the module, it cannot found the DSO as
it only checks the short names.
That leads for perf to create a same DSO without the build-id info and
it'll lookup the system path even if the DSO is already in the build-id
cache. After kernel was updated, perf cannot find the DSO and cannot
show symbols in it anymore.
You can see this if you have an old data file (w/ old kernel version):
$ perf report -i perf.data.old -v |& grep scsi_mod
build id event received for /lib/modules/3.19.2-1-ARCH/kernel/drivers/scsi/scsi_mod.ko.gz : cafe1ce6ca13a98a5d9ed3425cde249e57a27fc1
Failed to open /lib/modules/3.19.2-1-ARCH/kernel/drivers/scsi/scsi_mod.ko.gz, continuing without symbols
The second message didn't show the build-id. With this patch:
build id event received for /lib/modules/3.19.2-1-ARCH/kernel/drivers/scsi/scsi_mod.ko.gz: cafe1ce6ca13a98a5d9ed3425cde249e57a27fc1
/lib/modules/3.19.2-1-ARCH/kernel/drivers/scsi/scsi_mod.ko.gz with build id cafe1ce6ca13a98a5d9ed3425cde249e57a27fc1 not found, continuing without symbols
Now it shows the build-id but still cannot load the symbol table. This
is a different problem which will be fixed in the next patch.
Link: http://lkml.kernel.org/r/20170531120105.21731-1-namhyung@kernel.org
[ Fix the build on older compilers (debian <= 8, fedora <= 21, etc) wrt kmod_path var init ]
[ Upstream commit 54265664c15a68905d8d67d19205e9a767636434 ]
The s390 architecture maps sys_mmap (nr 90) into sys_old_mmap. For this
reason perf trace can't find the proper syscall event to get args format
from and displays it wrongly as 'continued'.
To fix that fill the "alias" field with "old_mmap" for trace's mmap record
to get the correct translation.
Before:
0.042 ( 0.011 ms): vest/43052 fstat(statbuf: 0x3ffff89fd90 ) = 0
0.042 ( 0.028 ms): vest/43052 ... [continued]: mmap()) = 0x3fffd6e2000
0.072 ( 0.025 ms): vest/43052 read(buf: 0x3fffd6e2000, count: 4096 ) = 6
After:
0.045 ( 0.011 ms): fstat(statbuf: 0x3ffff8a0930 ) = 0
0.057 ( 0.018 ms): mmap(arg: 0x3ffff8a0858 ) = 0x3fffd14a000
0.076 ( 0.025 ms): read(buf: 0x3fffd14a000, count: 4096 ) = 6
Link: http://lkml.kernel.org/r/20170531113557.19175-1-jolsa@kernel.org
[ Upstream commit 9f5c6d8777a2d962b0eeacb2a16f37da6bea545b ]
This improve the error message so that user can know event-name error
before writing new events to kprobe-events interface.
E.g.
#./perf probe -x /lib64/libc-2.25.so malloc_get_state*
Internal error: "malloc_get_state@GLIBC_2" is an invalid event name.
Error: Failed to add events.
Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Reviewed-by: Thomas Richter <tmricht@linux.vnet.ibm.com>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Paul Clarke <pc@us.ibm.com>
Cc: bhargavb <bhargavaramudu@gmail.com>
Cc: linux-rt-users@vger.kernel.org
Link: http://lkml.kernel.org/r/151275040665.24652.5188568529237584489.stgit@devbox
[ Upstream commit 1982ad48fc82c284a5cc55697a012d3357e84d01 ]
As the documentation for dwfl_frame_pc says, frames that
are no activation frames need to have their program counter
decremented by one to properly find the function of the caller.
This fixes many cases where perf report currently attributes
the cost to the next line. I.e. I have code like this:
#include <thread>
#include <chrono>
using namespace std;
int main()
this_thread::sleep_for(chrono::milliseconds(1000));
this_thread::sleep_for(chrono::milliseconds(100));
this_thread::sleep_for(chrono::milliseconds(10));
return 0;
Now compile and record it:
g++ -std=c++11 -g -O2 test.cpp
echo 1 | sudo tee /proc/sys/kernel/sched_schedstats
perf record \
--event sched:sched_stat_sleep \
--event sched:sched_process_exit \
--event sched:sched_switch --call-graph=dwarf \
--output perf.data.raw \
./a.out
echo 0 | sudo tee /proc/sys/kernel/sched_schedstats
perf inject --sched-stat --input perf.data.raw --output perf.data
Before this patch, the report clearly shows the off-by-one issue.
Most notably, the last sleep invocation is incorrectly attributed
to the "return 0;" line:
Overhead Source:Line
100.00% core.c:0
---__schedule core.c:0
schedule
do_nanosleep hrtimer.c:0
hrtimer_nanosleep
sys_nanosleep
entry_SYSCALL_64_fastpath .tmp_entry_64.o:0
__nanosleep_nocancel .:0
std::this_thread::sleep_for<long, std::ratio<1l, 1000l> > thread:323
|--90.08%--main test.cpp:9
| __libc_start_main
| _start
|--9.01%--main test.cpp:10
| __libc_start_main
| _start
--0.91%--main test.cpp:13
__libc_start_main
_start
With this patch here applied, the issue is fixed. The report becomes
much more usable:
100.00% core.c:0
schedule
hrtimer_nanosleep
sys_nanosleep
|--90.08%--main test.cpp:8
| __libc_start_main
| _start
|--9.01%--main test.cpp:9
| __libc_start_main
| _start
--0.91%--main test.cpp:10
__libc_start_main
_start
Similarly it works for signal frames:
__noinline void bar(void)
volatile long cnt = 0;
for (cnt = 0; cnt < 100000000; cnt++);
__noinline void foo(void)
bar();
void sig_handler(int sig)
foo();
int main(void)
signal(SIGUSR1, sig_handler);
raise(SIGUSR1);
foo();
return 0;
Before, the report wrongly points to `signal.c:29` after raise():
$ perf report --stdio --no-children -g srcline -s srcline
100.00% signal.c:11
---bar signal.c:11
|--50.49%--main signal.c:29
| __libc_start_main
| _start
--49.51%--0x33a8f
raise .:0
main signal.c:29
__libc_start_main
_start
With this patch in, the issue is fixed and we instead get:
100.00% signal signal [.] bar
---bar signal.c:11
| __libc_start_main
| _start
--49.51%--0x33a8f
raise .:0
main signal.c:27
__libc_start_main
_start
Note how this patch fixes this issue for both unwinding methods, i.e.
both dwfl and libunwind. The former case is straight-forward thanks
to dwfl_frame_pc(). For libunwind, we replace the functionality via
unw_is_signal_frame() for any but the very first frame.
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Yao Jin <yao.jin@linux.intel.com>
Link: http://lkml.kernel.org/r/20170524062129.32529-4-namhyung@kernel.org
[ Upstream commit fe06fe860250a4f01d0eaf70a2563b1997174a74 ]
The tm-resched-dscr test has started failing sometimes, depending on
what compiler it's built with, eg:
test: tm_resched_dscr
Check DSCR TM context switch: tm-resched-dscr: tm-resched-dscr.c:76: test_body: Assertion `rv' failed.
!! child died by signal 6
When it fails we see that the compiler doesn't initialise rv to 1 before
entering the inline asm block. Although that's counter intuitive, it
is allowed because we tell the compiler that the inline asm will write
to rv (using "=r"), meaning the original value is irrelevant.
Marking it as a read/write parameter would presumably work, but it seems
simpler to fix it by setting the initial value of rv in the inline asm.
Fixes: 96d016108640 ("powerpc: Correct DSCR during TM context switch")
Acked-by: Michael Neuling <mikey@neuling.org>
commit 3346a6a4e5ba8c040360f753b26938cec31a4bdc upstream.
sysret_ss_attrs fails to compile leading x86 test run to fail on systems
configured to build using PIE by default. Add -no-pie fix it.
Relocation might still fail if relocated above 4G. For now this change
fixes the build and runs x86 tests.
tools/testing/selftests/x86$ make
gcc -m64 -o .../tools/testing/selftests/x86/single_step_syscall_64 -O2
-g -std=gnu99 -pthread -Wall single_step_syscall.c -lrt -ldl
gcc -m64 -o .../tools/testing/selftests/x86/sysret_ss_attrs_64 -O2 -g
-std=gnu99 -pthread -Wall sysret_ss_attrs.c thunks.S -lrt -ldl
/usr/bin/ld: /tmp/ccS6pvIh.o: relocation R_X86_64_32S against `.text'
can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: Nonrepresentable section on output
collect2: error: ld returned 1 exit status
Makefile:49: recipe for target
'.../tools/testing/selftests/x86/sysret_ss_attrs_64' failed
make: *** [.../tools/testing/selftests/x86/sysret_ss_attrs_64] Error 1
Suggested-by: Andy Lutomirski <luto@kernel.org>
commit 91c49c2deb96ffc3c461eaae70219d89224076b7 upstream.
'si_pkey' is now #defined to be the name of the new siginfo field that
protection keys uses. Rename it not to conflict.
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Link: http://lkml.kernel.org/r/20171111001231.DFFC8285@viggo.jf.intel.com
commit d12fe87e62d773e81e0cb3a123c5a480a10d7d91 upstream.
Fix the debug print statements in these tests where they reference
si_codes and in particular __SI_FAULT. __SI_FAULT is a kernel
internal value and should never be seen by userspace.
While I am in there also fix si_code_str. si_codes are an enumeration
there are not a bitmap so == and not & is the apropriate operation to
test for an si_code.
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Fixes: 5f23f6d082a9 ("x86/pkeys: Add self-tests")
Fixes: e754aedc26ef ("x86/mpx, selftests: Add MPX self test")
commit 693cb5580fdb026922363aa103add64b3ecd572e upstream.
On new enough glibc, the pkey syscalls numbers are available. Check
first before defining them to avoid warnings like:
protection_keys.c:198:0: warning: "SYS_pkey_alloc" redefined
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Cc: Borislav Petkov <bpetkov@suse.de>
Link: http://lkml.kernel.org/r/1fbef53a9e6befb7165ff855fc1a7d4788a191d6.1509794321.git.luto@kernel.org
commit 2195bff041486eb7fcceaf058acaedcd057efbdc upstream.
The siginfo contains a bunch of information about the fault.
For protection keys, it tells us which protection key's
permissions were violated.
The wrong offset in here leads to reading garbage and thus
failures in the tests.
We should probably eventually move this over to using the
kernel's headers defining the siginfo instead of a hard-coded
offset. But, for now, just do the simplest fix.
commit 40c21898ba5372c14ef71717040529794a91ccc2 upstream.
When printing stats in CSV mode, 'perf stat' appends extra separators
when a counter is not supported:
<not supported>,,L1-dcache-store-misses,mesos/bd442f34-2b4a-47df-b966-9b281f9f56fc,0,100.00,,,,
Which causes a failure when parsing fields. The numbers of separators
should be the same for each line, no matter if the counter is or not
supported.
Signed-off-by: Ilya Pronin <ipronin@twitter.com>
Acked-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20180306064353.31930-1-xiyou.wangcong@gmail.com
Fixes: 92a61f6412d3 ("perf stat: Implement CSV metrics output")
commit 4b0b37d4cc54b21a6ecad7271cbc850555869c62 upstream.
glibc keeps getting cleverer, and my version now turns raise() into
more than one syscall. Since the test relies on ptrace seeing an
exact set of syscalls, this breaks the test. Replace raise(SIGSTOP)
with syscall(SYS_tgkill, ...) to force glibc to get out of our way.
Cc: linux-kselftest@vger.kernel.org
Link: http://lkml.kernel.org/r/bc80338b453afa187bc5f895bd8e2c8d6e264da2.1521300271.git.luto@kernel.org
[ Upstream commit 805b151a1afd24414706a7f6ae275fbb9649be74 ]
__kmod_path__parse() uses is_supported_compression() to determine and
parse out compressed module file extensions. On systems without zlib,
this test fails and __kmod_path__parse() continues to strcmp "ko" with
"gz". Don't do this on those systems.
Signed-off-by: Kim Phillips <kim.phillips@arm.com>
Fixes: 3c8a67f50a1e ("perf tools: Add kmod_path__parse function")
Link: http://lkml.kernel.org/r/20170503131402.c66e314460026c80cd787b34@arm.com
[ Upstream commit 8b06b884cd98f7ec8b5028680b99fabfb7b3e192 ]
Keep the nfit_test instances alive until after nfit_test_teardown(), as
we may be doing resource lookups until the final un-registrations have
completed. This fixes crashes of the form.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000038
IP: __release_resource+0x12/0x90
Call Trace:
remove_resource+0x23/0x40
__wrap_remove_resource+0x29/0x30 [nfit_test_iomap]
acpi_nfit_remove_resource+0xe/0x10 [nfit]
devm_action_release+0xf/0x20
release_nodes+0x16d/0x2b0
devres_release_all+0x3c/0x60
device_release+0x21/0x90
kobject_release+0x6a/0x170
kobject_put+0x2f/0x60
put_device+0x17/0x20
platform_device_unregister+0x20/0x30
nfit_test_exit+0x36/0x960 [nfit_test]
Reported-by: Linda Knippers <linda.knippers@hpe.com>
commit 78393fdde2a456cafa414b171c90f26a3df98b20 upstream.
POPF is currently broken -- add tests to catch the error. This
results in:
[RUN] POPF with VIP set and IF clear from vm86 mode
[INFO] Exited vm86 mode due to STI
[FAIL] Incorrect return reason (started at eip = 0xd, ended at eip = 0xf)
because POPF currently fails to check IF before reporting a pending
interrupt.
This patch also makes the FAIL message a bit more informative.
Reported-by: Bart Oldeman <bartoldeman@gmail.com>
Cc: Stas Sergeev <stsp@list.ru>
Link: http://lkml.kernel.org/r/a16270b5cfe7832d6d00c479d0f871066cbdb52b.1521003603.git.luto@kernel.org
commit a9e017d5619eb371460c8e516f4684def62bef3a upstream.
The STR and SLDT instructions are not valid when running on virtual-8086
mode and generate an invalid operand exception. These two instructions are
protected by the Intel User-Mode Instruction Prevention (UMIP) security
feature. In protected mode, if UMIP is enabled, these instructions generate
a general protection fault if called from CPL > 0. Linux traps the general
protection fault and emulates the instructions sgdt, sidt and smsw; but not
str and sldt.
These tests are added to verify that the emulation code does not emulate
these two instructions but the expected invalid operand exception is
seen.
Tests fallback to exit with INT3 in case emulation does happen.
Signed-off-by: Ricardo Neri <ricardo.neri-calderon@linux.intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Chen Yucong <slaoub@gmail.com>
Cc: Chris Metcalf <cmetcalf@mellanox.com>
Cc: Huang Rui <ray.huang@amd.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Michael S. Tsirkin <mst@redhat.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Ravi V. Shankar <ravi.v.shankar@intel.com>
Cc: Shuah Khan <shuah@kernel.org>
Cc: ricardo.neri@intel.com
Link: http://lkml.kernel.org/r/1509935277-22138-13-git-send-email-ricardo.neri-calderon@linux.intel.com
commit 9390afebe1d3f5a0be18b1afdd0ce09d67cebf9e upstream.
Certain user space programs that run on virtual-8086 mode may utilize
instructions protected by the User-Mode Instruction Prevention (UMIP)
security feature present in new Intel processors: SGDT, SIDT and SMSW. In
such a case, a general protection fault is issued if UMIP is enabled. When
such a fault happens, the kernel traps it and emulates the results of
these instructions with dummy values. The purpose of this new
test is to verify whether the impacted instructions can be executed
without causing such #GP. If no #GP exceptions occur, we expect to exit
virtual-8086 mode from INT3.
The instructions protected by UMIP are executed in representative use
cases:
a) displacement-only memory addressing
b) register-indirect memory addressing
c) results stored directly in operands
Unfortunately, it is not possible to check the results against a set of
expected values because no emulation will occur in systems that do not
have the UMIP feature. Instead, results are printed for verification. A
simple verification is done to ensure that results of all tests are
identical.
Link: http://lkml.kernel.org/r/1509935277-22138-12-git-send-email-ricardo.neri-calderon@linux.intel.com
commit 327d53d005ca47b10eae940616ed11c569f75a9b upstream.
Fix a logic error that caused the test to exit with 0 even if test
cases failed.
Cc: bartoldeman@gmail.com
Link: http://lkml.kernel.org/r/b1cc37144038958a469c8f70a5f47a6a5638636a.1521003603.git.luto@kernel.org
[ Upstream commit 2adfa4210f8f35cdfb4e08318cc06b99752964c2 ]
The 'configinit.sh' script checks the format of optional argument for the
build directory, printing an error message if the format is not valid.
However, the error message uses the wrong variable, indicating an empty
string even though the user entered a non-empty (but erroneous) string.
This commit fixes the script to use the correct variable.
Fixes: c87b9c601ac8 ("rcutorture: Add KVM-based test framework")
Signed-off-by: SeongJae Park <sj38.park@gmail.com>
[ Upstream commit 77be4c878c72e411ad22af96b6f81dd45c26450a ]
Indeed musl doesn't define old SIGCLD signal name but only new one SIGCHLD.
SIGCHLD is the new POSIX name for that signal so it doesn't change
anything on other libcs.
This fixes this kind of build error:
usbipd.c: In function ‘set_signal’:
usbipd.c:459:12: error: 'SIGCLD' undeclared (first use in this function)
sigaction(SIGCLD, &act, NULL);
usbipd.c:459:12: note: each undeclared identifier is reported only once
for each function it appears in
Makefile:407: recipe for target 'usbipd.o' failed
make[3]: *** [usbipd.o] Error 1
Signed-off-by: Julien BOIBESSOT <julien.boibessot@armadeus.com>
Acked-by: Shuah Khan <shuahkh@osg.samsung.com>
[ Upstream commit 65c79230576873b312c3599479c1e42355c9f349 ]
The file /sys/module/firmware_class/parameters/path can be used
to set a custom firmware path. The fw_filesystem.sh script creates
a temporary directory to add a test firmware file to be used during
testing, in order for this to work it uses the custom path syfs file
and it was supposed to reset back the file on execution exit. The
script failed to do this due to a typo, it was using OLD_PATH instead
of OLD_FWPATH, since its inception since v3.17.
Its not as easy to just keep the old setting, it turns out that
resetting an empty setting won't actually do what we want, we need
to check if it was empty and set an empty space.
Without this we end up having the temporary path always set after
we run these tests.
Fixes: 0a8adf58475 ("test: add firmware_class loader test")
Signed-off-by: Luis R. Rodriguez <mcgrof@kernel.org>
[ Upstream commit db49a71798a38f3ddf3f3462703328dca39b1ac7 ]
(This is a patch has been sitting in the Intel CQM/CMT driver series for
a while, despite not depend on it. Sending it now independently since
the series is being discarded.)
When an event is in error state, read() returns 0 instead of sizeof()
buffer. In certain modes, such as interval printing, ignoring the 0
return value may cause bogus count deltas to be computed and thus
invalid results printed.
This patch fixes this problem by modifying read_counters() to mark the
event as not scaled (scaled = -1) to force the printout routine to show
<NOT COUNTED>.
Signed-off-by: Stephane Eranian <eranian@google.com>
Reviewed-by: David Carrillo-Cisneros <davidcc@google.com>
Cc: Mathieu Poirier <mathieu.poirier@linaro.org>
Cc: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/20170412182301.44406-1-davidcc@google.com
[ Upstream commit 0973ad97c187e06aece61f685b9c3b2d93290a73 ]
Session sets a number parameters that rely on evlist. These parameters
are not used in pipe-mode and should not be set, since evlist is
unavailable. Fix that.
Signed-off-by: David Carrillo-Cisneros <davidcc@google.com>
Cc: He Kuang <hekuang@huawei.com>
Cc: Simon Que <sque@chromium.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20170410201432.24807-6-davidcc@google.com
[ Check if file != NULL in perf_session__new(), like when used by builtin-top.c ]
[ Upstream commit 1e0d4f0200e4dbdfc38d818f329d8a0955f7c6f5 ]
__perf_session__process_pipe_events reuses the same memory buffer to
process all events in the pipe.
When reordering is needed (e.g. -b option), events are not immediately
flushed, but kept around until reordering is possible, causing
memory corruption.
The problem is usually observed by a "Unknown sample error" output. It
can easily be reproduced by:
perf record -o - noploop | perf inject -b > output
Committer testing:
Before:
$ perf record -o - stress -t 2 -c 2 | perf inject -b > /dev/null
stress: info: [8297] dispatching hogs: 2 cpu, 0 io, 0 vm, 0 hdd
stress: info: [8297] successful run completed in 2s
[ perf record: Woken up 3 times to write data ]
[ perf record: Captured and wrote 0.000 MB - ]
Warning:
Found 1 unknown events!
Is this an older tool processing a perf.data file generated by a more recent tool?
If that is not the case, consider reporting to linux-kernel@vger.kernel.org.
After:
stress: info: [9027] dispatching hogs: 2 cpu, 0 io, 0 vm, 0 hdd
stress: info: [9027] successful run completed in 2s
no symbols found in /usr/bin/stress, maybe install a debug package?
Link: http://lkml.kernel.org/r/20170410201432.24807-3-davidcc@google.com
[ Upstream commit 32ccb130f5325abc81b32b1a538390f46e4860f6 ]
The kernel has a special check for a specific irq_vectors trace event.
TRACE_EVENT_PERF_PERM(irq_work_exit,
is_sampling_event(p_event) ? -EPERM : 0);
The perf-record fails for this irq_vectors event when it is present,
like when using a wildcard:
root@skl:/tmp# perf record -a -e irq_vectors:* sleep 2
Error:
You may not have permission to collect system-wide stats.
Consider tweaking /proc/sys/kernel/perf_event_paranoid,
which controls use of the performance events system by
unprivileged users (without CAP_SYS_ADMIN).
The current value is 2:
-1: Allow use of (almost) all events by all users
>= 0: Disallow raw tracepoint access by users without CAP_IOC_LOCK
>= 1: Disallow CPU event access by users without CAP_SYS_ADMIN
>= 2: Disallow kernel profiling by users without CAP_SYS_ADMIN
To make this setting permanent, edit /etc/sysctl.conf too, e.g.:
kernel.perf_event_paranoid = -1
This patch prints out the exact sub event that failed with EPERM for
wildcards to help in understanding what went wrong when this event is
present:
After the patch:
Error:
No permission to enable irq_vectors:irq_work_exit event.
Committer notes:
So we have a lot of irq_vectors events:
[root@jouet ~]# perf list irq_vectors:*
List of pre-defined events (to be used in -e):
irq_vectors:call_function_entry [Tracepoint event]
irq_vectors:call_function_exit [Tracepoint event]
irq_vectors:call_function_single_entry [Tracepoint event]
irq_vectors:call_function_single_exit [Tracepoint event]
irq_vectors:deferred_error_apic_entry [Tracepoint event]
irq_vectors:deferred_error_apic_exit [Tracepoint event]
irq_vectors:error_apic_entry [Tracepoint event]
irq_vectors:error_apic_exit [Tracepoint event]
irq_vectors:irq_work_entry [Tracepoint event]
irq_vectors:irq_work_exit [Tracepoint event]
irq_vectors:local_timer_entry [Tracepoint event]
irq_vectors:local_timer_exit [Tracepoint event]
irq_vectors:reschedule_entry [Tracepoint event]
irq_vectors:reschedule_exit [Tracepoint event]
irq_vectors:spurious_apic_entry [Tracepoint event]
irq_vectors:spurious_apic_exit [Tracepoint event]
irq_vectors:thermal_apic_entry [Tracepoint event]
irq_vectors:thermal_apic_exit [Tracepoint event]
irq_vectors:threshold_apic_entry [Tracepoint event]
irq_vectors:threshold_apic_exit [Tracepoint event]
irq_vectors:x86_platform_ipi_entry [Tracepoint event]
irq_vectors:x86_platform_ipi_exit [Tracepoint event]
And some may be sampled:
[root@jouet ~]# perf record -e irq_vectors:local* sleep 20s
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.020 MB perf.data (2 samples) ]
[root@jouet ~]# perf report -D | egrep 'stats:|events:'
Aggregated stats:
TOTAL events: 155
MMAP events: 144
COMM events: 2
EXIT events: 1
SAMPLE events: 2
MMAP2 events: 4
FINISHED_ROUND events: 1
TIME_CONV events: 1
irq_vectors:local_timer_entry stats:
TOTAL events: 1
SAMPLE events: 1
irq_vectors:local_timer_exit stats:
TOTAL events: 1
SAMPLE events: 1
[root@jouet ~]#
But, as shown in the tracepoint definition at the start of this message,
some, like "irq_vectors:irq_work_exit", may not be sampled, just counted,
i.e. if we try to sample, as when using 'perf record', we get an error:
[root@jouet ~]# perf record -e irq_vectors:irq_work_exit
Error:
<SNIP>
The error message is misleading, this patch will help in pointing out
what is the event causing such an error, but the error message needs
improvement, i.e. we need to figure out a way to check if a tracepoint
is counting only, like this one, when all we can do is to count it with
'perf stat', at most printing the delta using interval printing, as in:
[root@jouet ~]# perf stat -I 5000 -e irq_vectors:irq_work_*
# time counts unit events
5.000168871 0 irq_vectors:irq_work_entry
5.000168871 0 irq_vectors:irq_work_exit
10.000676730 0 irq_vectors:irq_work_entry
10.000676730 0 irq_vectors:irq_work_exit
15.001122415 0 irq_vectors:irq_work_entry
15.001122415 0 irq_vectors:irq_work_exit
20.001298051 0 irq_vectors:irq_work_entry
20.001298051 0 irq_vectors:irq_work_exit
25.001485020 1 irq_vectors:irq_work_entry
25.001485020 1 irq_vectors:irq_work_exit
30.001658706 0 irq_vectors:irq_work_entry
30.001658706 0 irq_vectors:irq_work_exit
^C 32.045711878 0 irq_vectors:irq_work_entry
32.045711878 0 irq_vectors:irq_work_exit
[root@jouet ~]#
But at least, when we use a wildcard, this patch helps a bit.
Signed-off-by: Yao Jin <yao.jin@linux.intel.com>
Cc: Kan Liang <kan.liang@intel.com>
Link: http://lkml.kernel.org/r/1491566932-503-1-git-send-email-yao.jin@linux.intel.com
[ Upstream commit fd2b2975149f5f7099693027cece81b16842964a ]
Which may happen when we start a tracing session and a thread is waiting
for something like "poll" to return, in which case we better print "?"
both for the syscall entry timestamp and for the duration.
E.g.:
Tracing existing mutt session:
# perf trace -p `pidof mutt`
? ( ? ): mutt/17135 ... [continued]: poll()) = 1
0.027 ( 0.013 ms): mutt/17135 read(buf: 0x7ffcb3c42cef, count: 1) = 1
0.047 ( 0.008 ms): mutt/17135 poll(ufds: 0x7ffcb3c42c50, nfds: 1, timeout_msecs: 1000) = 1
0.059 ( 0.008 ms): mutt/17135 read(buf: 0x7ffcb3c42cef, count: 1) = 1
<SNIP>
Before it would print a large number because we'd do:
ttrace->entry_time - trace->base_time
And entry_time would be 0, while base_time would be the timestamp for
the first event 'perf trace' reads, oops.
Cc: Luis Claudio Gonçalves <lclaudio@redhat.com>
Link: http://lkml.kernel.org/n/tip-wbcb93ofva2qdjd5ltn5eeqq@git.kernel.org
[ Upstream commit 5a2342111c68e623e27ee7ea3d0492d8dad6bda0 ]
Valgrind was complaining:
$ valgrind ./perf list >/dev/null
==11643== Memcheck, a memory error detector
==11643== Copyright (C) 2002-2015, and GNU GPL'd, by Julian Seward et al.
==11643== Using Valgrind-3.12.0 and LibVEX; rerun with -h for copyright info
==11643== Command: ./perf list
==11643==
==11643== Conditional jump or move depends on uninitialised value(s)
==11643== at 0x4C30620: rindex (vg_replace_strmem.c:199)
==11643== by 0x49DAA9: build_id_cache__origname (build-id.c:198)
==11643== by 0x49E1C7: build_id_cache__valid_id (build-id.c:222)
==11643== by 0x49E1C7: build_id_cache__list_all (build-id.c:507)
==11643== by 0x4B9C8F: print_sdt_events (parse-events.c:2067)
==11643== by 0x4BB0B3: print_events (parse-events.c:2313)
==11643== by 0x439501: cmd_list (builtin-list.c:53)
==11643== by 0x497150: run_builtin (perf.c:359)
==11643== by 0x428CE0: handle_internal_command (perf.c:421)
==11643== by 0x428CE0: run_argv (perf.c:467)
==11643== by 0x428CE0: main (perf.c:614)
Additionally, a zero length result from readlink() is not very interesting.
Signed-off-by: Tommi Rantala <tommi.t.rantala@nokia.com>
Link: http://lkml.kernel.org/r/20170322130624.21881-3-tommi.t.rantala@nokia.com
[ Upstream commit 6ebd2547dd24daf95a21b2bc59931de8502afcc3 ]
It is wrong way to read link name from a build-id file. Because a
build-id file is not anymore a symbolic link but build-id directory of
it is symbolic link, so fix it.
For example, if build-id file name gotten from
dso__build_id_filename() is as below,
/root/.debug/.build-id/4f/75c7d197c951659d1c1b8b5fd49bcdf8f3f8b1/elf
To correctly read link name of build-id, use the build-id dir path that
is a symbolic link, instead of the above build-id file name like below.
Signed-off-by: Taeung Song <treeze.taeung@gmail.com>
Link: http://lkml.kernel.org/r/1490598638-13947-2-git-send-email-treeze.taeung@gmail.com
Fixes: 01412261d994 ("perf buildid-cache: Use path/to/bin/buildid/elf instead of path/to/bin/buildid")
[ Upstream commit 70946723eeb859466f026274b29c6196e39149c4 ]
On old perf, when using 'perf probe -d' to delete an inexistent event,
it returns errno, eg,
-bash-4.3# perf probe -d xxx || echo $?
Info: Event "*:xxx" does not exist.
Error: Failed to delete events.
255
But now perf_del_probe_events() will always set ret = 0, different from
previous del_perf_probe_events(). After this, it returns errno again,
eg,
-bash-4.3# ./perf probe -d xxx || echo $?
"xxx" does not hit any event.
254
And it is more appropriate to return -ENOENT instead of -EPERM.
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Acked-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Hanjun Guo <guohanjun@huawei.com>
Fixes: dddc7ee32fa1 ("perf probe: Fix an error when deleting probes successfully")
Link: http://lkml.kernel.org/r/1489738592-61011-1-git-send-email-wangkefeng.wang@huawei.com
[ Upstream commit f0a30dca5f84fe8048271799b56677ac2279de66 ]
'*ntevs' contains number of elements present in 'tevs' array. If there
are no elements in array, 'tevs2' can be directly assigned to 'tevs'
without allocating more space. So the condition should be '*ntevs == 0'
not 'ntevs == 0'.
Signed-off-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Fixes: 42bba263eb58 ("perf probe: Allow wildcard for cached events")
Link: http://lkml.kernel.org/r/20170308065908.4128-1-ravi.bangoria@linux.vnet.ibm.com
[ Upstream commit 88b897a30c525c2eee6e7f16e1e8d0f18830845e ]
This patch significantly improves the execution time of
perf_event__synthesize_mmap_events() when running perf record on systems
where processes have lots of threads.
It just happens that cat /proc/pid/maps support uses a O(N^2) algorithm to
generate each map line in the maps file. If you have 1000 threads, then you
have necessarily 1000 stacks. For each vma, you need to check if it
corresponds to a thread's stack. With a large number of threads, this can take
a very long time. I have seen latencies >> 10mn.
As of today, perf does not use the fact that a mapping is a stack, therefore we
can work around the issue by using /proc/pid/tasks/pid/maps. This entry does
not try to map a vma to stack and is thus much faster with no loss of
functonality.
The proc-map-timeout logic is kept in case users still want some upper limit.
In V2, we fix the file path from /proc/pid/tasks/pid/maps to actual
/proc/pid/task/pid/maps, tasks -> task. Thanks Arnaldo for catching this.
Committer note:
This problem seems to have been elliminated in the kernel since commit :
b18cb64ead40 ("fs/proc: Stop trying to report thread stacks").
Link: http://lkml.kernel.org/r/20170315135059.GC2177@redhat.com
Link: http://lkml.kernel.org/r/1489598233-25586-1-git-send-email-eranian@google.com
[ Upstream commit 4b0b3aa6a2756e6115fdf275c521e4552a7082f3 ]
Skip the sample which doesn't have branch_info to avoid segmentation
fault:
The fault can be reproduced by:
perf record -a
perf report -F cycles
Signed-off-by: Changbin Du <changbin.du@intel.com>
Fixes: 0e332f033a82 ("perf tools: Add support for cycles, weight branch_info field")
Link: http://lkml.kernel.org/r/20170313083148.23568-1-changbin.du@intel.com
[ Upstream commit 02d492e5dcb72c004d213756eb87c9d62a6d76a7 ]
When using perf stat on an AMD F15h system with the default hw events
attributes, some of the events don't get counted:
Performance counter stats for 'sleep 1':
0.749208 task-clock (msec) # 0.001 CPUs utilized
1 context-switches # 0.001 M/sec
0 cpu-migrations # 0.000 K/sec
54 page-faults # 0.072 M/sec
1,122,815 cycles # 1.499 GHz
286,740 stalled-cycles-frontend # 25.54% frontend cycles idle
<not counted> stalled-cycles-backend (0.00%)
<not counted> instructions (0.00%)
<not counted> branches (0.00%)
<not counted> branch-misses (0.00%)
1.001550070 seconds time elapsed
The reason is that we have the HW watchdog consuming one PMU counter and
when perf tries to schedule 6 events on 6 counters and some of those
counters are constrained to only a specific subset of PMCs by the
hardware, the event scheduling fails.
So issue a hint to disable the HW watchdog around a perf stat session.
Committer note:
Testing it...
# perf stat -d usleep 1
Performance counter stats for 'usleep 1':
1.180203 task-clock (msec) # 0.490 CPUs utilized
1 context-switches # 0.847 K/sec
54 page-faults # 0.046 M/sec
184,754 cycles # 0.157 GHz
714,553 instructions # 3.87 insn per cycle
154,661 branches # 131.046 M/sec
7,247 branch-misses # 4.69% of all branches
219,984 L1-dcache-loads # 186.395 M/sec
17,600 L1-dcache-load-misses # 8.00% of all L1-dcache hits (90.16%)
<not counted> LLC-loads (0.00%)
<not counted> LLC-load-misses (0.00%)
0.002406823 seconds time elapsed
Some events weren't counted. Try disabling the NMI watchdog:
echo 0 > /proc/sys/kernel/nmi_watchdog
perf stat ...
echo 1 > /proc/sys/kernel/nmi_watchdog
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Robert Richter <rric@kernel.org>
Cc: Vince Weaver <vince@deater.net>
Link: http://lkml.kernel.org/r/20170211183218.ijnvb5f7ciyuunx4@pd.tnic
commit de19e5c3c51fdb1ff20d0f61d099db902ff7494b upstream.
trigger_on() means that the trigger is available but not ready, however
trigger_on() was making it ready. That can segfault if the signal comes
before trigger_ready(). e.g. (USR2 signal delivery not shown)
$ perf record -e intel_pt//u -S sleep 1
perf: Segmentation fault
Obtained 16 stack frames.
/home/ahunter/bin/perf(sighandler_dump_stack+0x40) [0x4ec550]
/lib/x86_64-linux-gnu/libc.so.6(+0x36caf) [0x7fa76411acaf]
/home/ahunter/bin/perf(perf_evsel__disable+0x26) [0x4b9dd6]
/home/ahunter/bin/perf() [0x43a45b]
/lib/x86_64-linux-gnu/libc.so.6(__xstat64+0x15) [0x7fa7641d2cc5]
/home/ahunter/bin/perf() [0x4ec6c9]
/home/ahunter/bin/perf() [0x4ec73b]
/home/ahunter/bin/perf() [0x4eca15]
/home/ahunter/bin/perf(machine__create_kernel_maps+0x257) [0x4f0b77]
/home/ahunter/bin/perf(perf_session__new+0xc0) [0x4f86f0]
/home/ahunter/bin/perf(cmd_record+0x722) [0x43c132]
/home/ahunter/bin/perf() [0x4a11ae]
/home/ahunter/bin/perf(main+0x5d4) [0x427fb4]
Note, for testing purposes, this is hard to hit unless you add some sleep()
in builtin-record.c before record__open().
Fixes: 3dcc4436fa6f ("perf tools: Introduce trigger class")
Link: http://lkml.kernel.org/r/1519807144-30694-1-git-send-email-adrian.hunter@intel.com
commit e572d0887137acfc53f18175522964ec19d88175 upstream.
When doing a kernel build with 'make -s', everything is silenced except
the objtool build. That's because the tools tree support for silent
builds is some combination of missing and broken.
Three changes are needed to fix it:
- Makefile: propagate '-s' to the sub-make's MAKEFLAGS variable so the
tools Makefiles can see it.
- tools/scripts/Makefile.include: fix the tools Makefiles' ability to
recognize '-s'. The MAKE_VERSION and MAKEFLAGS checks are copied from
the top-level Makefile. This silences the "DESCEND objtool" message.
- tools/build/Makefile.build: add support to the tools Build files for
recognizing '-s'. Again the MAKE_VERSION and MAKEFLAGS checks are
copied from the top-level Makefile. This silences all the object
compile/link messages.
Reported-and-Tested-by: Peter Zijlstra <peterz@infradead.org>
Cc: Michal Marek <mmarek@suse.com>
Link: http://lkml.kernel.org/r/e8967562ef640c3ae9a76da4ae0f4e47df737c34.1484799200.git.jpoimboe@redhat.com
[ Upstream commit 321a7c35c90cc834851ceda18a8ee18f1d032b92 ]
Certain systems are designed to have sparse/discontiguous nodes. On
such systems, 'perf bench numa' hangs, shows wrong number of nodes and
shows values for non-existent nodes. Handle this by only taking nodes
that are exposed by kernel to userspace.
Signed-off-by: Satheesh Rajendran <sathnaga@linux.vnet.ibm.com>
Reviewed-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Acked-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1edbcd353c009e109e93d78f2f46381930c340fe.1511368645.git.sathnaga@linux.vnet.ibm.com
Signed-off-by: Balamuruhan S <bala24@linux.vnet.ibm.com>
[ Upstream commit 89d0aeab4252adc2a7ea693637dd21c588bfa2d1 ]
The stdio perf top crashes when we change the terminal
window size. The reason is that we assumed we get the
perf_top pointer as a signal handler argument which is
not the case.
Changing the SIGWINCH handler logic to change global
resize variable, which is checked in the main thread
loop.
Tested-by: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/n/tip-ysuzwz77oev1ftgvdscn9bpu@git.kernel.org
