commit f35f71244da6e51db4e1f2c7e318581f498ececf upstream.
It appears that no one ever run ffs-test on a big-endian machine,
since it used cpu-endianess for fs_count and hs_count fields which
should be in little-endian format. Fix by wrapping the numbers in
cpu_to_le32.
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 2b92865e648ce04a39fda4f903784a5d01ecb0dc upstream.
turbostat uses inline assembly to call cpuid. On 32-bit x86, on systems
that have certain security features enabled by default that make -fPIC
the default, this causes a build error:
turbostat.c: In function ‘check_cpuid’:
turbostat.c:1906:2: error: PIC register clobbered by ‘ebx’ in ‘asm’
asm("cpuid" : "=a" (fms), "=c" (ecx), "=d" (edx) : "a" (1) : "ebx");
GCC provides a header cpuid.h, containing a __get_cpuid function that
works with both PIC and non-PIC. (On PIC, it saves and restores ebx
around the cpuid instruction.) Use that instead.
Signed-off-by: Josh Triplett <josh@joshtriplett.org>
Signed-off-by: Len Brown <len.brown@intel.com>
commit b731f3119de57144e16c19fd593b8daeb637843e upstream.
turbostat's Makefile puts arch/x86/include/uapi/ in the include path, so
that it can include <asm/msr.h> from it. It isn't in general safe to
include even uapi headers directly from the kernel tree without
processing them through scripts/headers_install.sh, but asm/msr.h
happens to work.
However, that include path can break with some versions of system
headers, by overriding some system headers with the unprocessed versions
directly from the kernel source. For instance:
In file included from /build/x86-generic/usr/include/bits/sigcontext.h:28:0,
from /build/x86-generic/usr/include/signal.h:339,
from /build/x86-generic/usr/include/sys/wait.h:31,
from turbostat.c:27:
../../../../arch/x86/include/uapi/asm/sigcontext.h:4:28: fatal error: linux/compiler.h: No such file or directory
This occurs because the system bits/sigcontext.h on that build system
includes <asm/sigcontext.h>, and asm/sigcontext.h in the kernel source
includes <linux/compiler.h>, which scripts/headers_install.sh would have
filtered out.
Since turbostat really only wants a single header, just include that one
header rather than putting an entire directory of kernel headers on the
include path.
In the process, switch from msr.h to msr-index.h, since turbostat just
wants the MSR numbers.
commit ad85ace07a05062ef6b59c35a5e80b6eaee1eee6 upstream.
Currently, if we use perf kvm --guestkallsyms --guestmodules report, we
can not get the perf information from perf data file. All sample are
shown as unknown.
Reproducing steps:
# perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules record -a sleep 1
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.624 MB perf.data.guest (~27260 samples) ]
# perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules report |grep %
100.00% [guest/6471] [unknown] [g] 0xffffffff8164f330
This bug was introduced by 207b57926 (perf kvm: Fix regression with guest machine creation).
In original code, it uses perf_session__find_machine(), it means we deliver symbol to machine
which has the same pid, if no machine found, deliver it to *default* guest. But if we use
perf_session__findnew_machine() here, if no machine was found, new machine with pid will be built
and added. Then the default guest which with pid == 0 will never get a symbol.
And because the new machine initialized here has no kernel map created, the symbol delivered to
it will be marked as "unknown".
This patch here is to revert commit 207b57926 and fix the SEGFAULT bug in another way.
Verification steps:
# ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules record -a sleep 1
[ perf record: Captured and wrote 0.651 MB perf.data.guest (~28437 samples) ]
# ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules report |grep %
22.64% :6471 [guest.kernel.kallsyms] [g] update_rq_clock.part.70
19.99% :6471 [guest.kernel.kallsyms] [g] d_free
18.46% :6471 [guest.kernel.kallsyms] [g] bio_phys_segments
16.25% :6471 [guest.kernel.kallsyms] [g] dequeue_task
12.78% :6471 [guest.kernel.kallsyms] [g] __switch_to
7.91% :6471 [guest.kernel.kallsyms] [g] scheduler_tick
1.75% :6471 [guest.kernel.kallsyms] [g] native_apic_mem_write
0.21% :6471 [guest.kernel.kallsyms] [g] apic_timer_interrupt
Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com>
Acked-by: David Ahern <dsahern@gmail.com>
Cc: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/1387564907-3045-1-git-send-email-yangds.fnst@cn.fujitsu.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit f447ef4a56dee4b68a91460bcdfe06b5011085f2 upstream.
If a user calls 'cpupower set --perf-bias 15', the process will end with
a SIGSEGV in libc because cpupower-set passes a NULL optarg to the atoi
call. This is because the getopt_long structure currently has all of
the options as having an optional_argument when they really have a
required argument. We change the structure to use required_argument to
match the short options and it resolves the issue.
This fixes https://bugzilla.redhat.com/show_bug.cgi?id=1000439
Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Thomas Renninger <trenn@suse.de>
commit 9d4ecc8893832337daf241236841db966fa53489 upstream.
When introducing the PERF_RECORD_MMAP2 in:
5c5e854bc760 perf tools: Add attr->mmap2 support
A check for the number of entries parsed by sscanf was introduced that
assumed all of the 8 fields needed to be correctly parsed so that
particular /proc/pid/maps line would be considered synthesizable.
That broke anon records synthesizing, as it doesn't have the 'execname'
field.
Fix it by keeping the sscanf return check, changing it to not require
that the 'execname' variable be parsed, so that the preexisting logic
can kick in and set it to '//anon'.
This should get things like JIT profiling working again.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Cc: Bill Gray <bgray@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Joe Mario <jmario@redhat.com>
Cc: Richard Fowles <rfowles@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-bo4akalno7579shpz29u867j@git.kernel.org
[ commit log message is mine, dzickus reported the problem with a patch ]
commit 53805eca3d89b095062c11a6798689bb0af09216 upstream.
The 4fb71074a570 (perf ui/hist: Consolidate hpp helpers) cset introduced
a cast of percent_color_snprintf to a function pointer type with
varargs. Change percent_color_snprintf to be variadic and remove the
cast.
The symptom of this was all percentages being reported as 0.00% in perf
report --stdio output on the armhf arch.
Signed-off-by: Michael Hudson-Doyle <michael.hudson@linaro.org>
Acked-by: Namhyung Kim <namhyung@kernel.org>
Acked-by: Will Deacon <will.deacon@arm.com>
Cc: Jean Pihet <jean.pihet@linaro.org>
Link: http://lkml.kernel.org/r/87zjppvw7y.fsf@canonical.com
The tail position of the event buffer should only be modified after
actually use that event.
If not the event buffer could be invalid before use, and segment fault
occurs when invoking perf top -G.
Signed-off-by: Zhouyi Zhou <yizhouzhou@ict.ac.cn>
Cc: Zhouyi Zhou <yizhouzhou@ict.ac.cn>
Link: http://lkml.kernel.org/r/1382600613-32177-1-git-send-email-zhouzhouyi@gmail.com
[ Simplified the logic using exit gotos and renamed write_tail method to mmap_consume ]
Splitting -G and --call-graph for record command, so we could use '-G'
with no option.
The '-G' option now takes NO argument and enables the configured unwind
method, which is currently the frame pointers method.
It will be possible to configure unwind method via config file in
upcoming patches.
All current '-G' arguments is overtaken by --call-graph option.
NOTE: The documentation for top --call-graph option
was wrongly copied from report command.
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Tested-by: David Ahern <dsahern@gmail.com>
Tested-by: Ingo Molnar <mingo@kernel.org>
Reviewed-by: David Ahern <dsahern@gmail.com>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1382797536-32303-3-git-send-email-jolsa@redhat.com
Splitting -g and --call-graph for record command, so we could use '-g'
with no option.
The '-g' option now takes NO argument and enables the configured unwind
upcoming patches.
All current '-g' arguments is overtaken by --call-graph option.
Link: http://lkml.kernel.org/r/1382797536-32303-2-git-send-email-jolsa@redhat.com
[ reordered -g/--call-graph on --help and expanded the man page
according to comments by David Ahern and Namhyung Kim ]
Following commit tightened up the buffer size for output to strict width
of used format columns:
99cf666 perf hists: Fix formatting of long symbol names
This works fine until you hit color overhead output which places extra
bytes into output buffer. We need to account for color overhead in the
output buffer. Adding maximum color byte size to the output buffer size.
Link: http://lkml.kernel.org/r/1382700293-1803-1-git-send-email-jolsa@redhat.com
When introducing support for MMAP2 we considered more parts of each map
representation in /proc/PID/maps, and when disabling it we forgot to
reduce the number of expected parsed/assigned entries in the sscanf
call, fix it to expect the right number of desired fields, 5.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Based-on-a-patch-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Link: http://lkml.kernel.org/n/tip-vrbo1wik997ahjzl1chm3bdm@git.kernel.org
We are using the Python scripting interface in perf to extract kernel
events relevant for performance analysis of HPC codes. We noticed that
the "perf script" call allocates a significant amount of memory (in the
order of several 100 MiB) during it's run, e.g. 125 MiB for a 25 MiB
input file:
$> perf record -o perf.data -a -R -g fp \
-e power:cpu_frequency -e sched:sched_switch \
-e sched:sched_migrate_task -e sched:sched_process_exit \
-e sched:sched_process_fork -e sched:sched_process_exec \
-e cycles -m 4096 --freq 4000
$> /usr/bin/time perf script -i perf.data -s dummy_script.py
0.84user 0.13system 0:01.92elapsed 51%CPU (0avgtext+0avgdata
125532maxresident)k
73072inputs+0outputs (57major+33086minor)pagefaults 0swaps
Upon further investigation using the valgrind massif tool, we noticed
that Python objects that are created in trace-event-python.c via
PyString_FromString*() (and their Integer and Long counterparts) are
never free'd.
The reason for this seem to be missing Py_DECREF calls on the objects
that are returned by these functions and stored in the Python
dictionaries. The Python dictionaries do not steal references (as
opposed to Python tuples and lists) but instead add their own reference.
Hence, the reference that is returned by these object creation functions
is never released and the memory is leaked. (see [1,2])
The attached patch fixes this by wrapping all relevant calls to
PyDict_SetItemString() and decrementing the reference counter
immediately after the Python function call.
This reduces the allocated memory to a reasonable amount:
0.73user 0.05system 0:00.79elapsed 99%CPU (0avgtext+0avgdata
49132maxresident)k
0inputs+0outputs (0major+14045minor)pagefaults 0swaps
For comparison, with a 120 MiB input file the memory consumption
reported by time drops from almost 600 MiB to 146 MiB.
The patch has been tested using Linux 3.8.2 with Python 2.7.4 and Linux
3.11.6 with Python 2.7.5.
Please let me know if you need any further information.
[1] http://docs.python.org/2/c-api/tuple.html#PyTuple_SetItem
[2] http://docs.python.org/2/c-api/dict.html#PyDict_SetItemString
Signed-off-by: Joseph Schuchart <joseph.schuchart@tu-dresden.de>
Reviewed-by: Tom Zanussi <tom.zanussi@linux.intel.com>
Cc: Tom Zanussi <tom.zanussi@linux.intel.com>
Link: http://lkml.kernel.org/r/1381468543-25334-4-git-send-email-namhyung@kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
Pull perf/urgent fixes from Arnaldo Carvalho de Melo:
" * Fix build error on Fedora 12.
* Fix to initialize fname always before use it, bug introduced
during this merge window, from Masami Hiramatsu.
* Disable PERF_RECORD_MMAP2 support, from Stephane Eranian. "
For now, we disable the extended MMAP record support (MMAP2).
We have identified cases where it would not report the correct mapping
information, clone(VM_CLONE) but with separate pids. We will revisit
the support once we find a solution for this case.
The patch changes the kernel to return EINVAL if attr->mmap2 is set. The
patch also modifies the perf tool to use regular PERF_RECORD_MMAP for
synthetic events and it also prevents the tool from requesting
attr->mmap2 mode because the kernel would reject it.
The support will be revisited once the kenrel interface is updated.
In V2, we reduce the patch to the strict minimum.
In V3, we avoid calling perf_event_open() with mmap2 set because we know
it will fail and require fallback retry.
Signed-off-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/20131017173215.GA8820@quad
Cast __u64 to u64 to silence this warning on older distros, such as
Fedora 12:
CC /tmp/build/perf/util/scripting-engines/trace-event-perl.o
cc1: warnings being treated as errors
util/scripting-engines/trace-event-perl.c: In function ‘perl_process_tracepoint’:
util/scripting-engines/trace-event-perl.c:285: error: format ‘%lu’ expects type ‘long unsigned int’, but argument 2 has type ‘__u64’
make[1]: *** [/tmp/build/perf/util/scripting-engines/trace-event-perl.o] Error 1
make: *** [install] Error 2
make: Leaving directory `/home/acme/git/linux/tools/perf'
[acme@fedora12 linux]$
Reported-by: Waiman Long <Waiman.Long@hp.com>
Cc: Waiman Long <Waiman.Long@hp.com>
Link: http://lkml.kernel.org/n/tip-nlxofdqcdjfm0w9o6bgq4kqv@git.kernel.org
Link: http://lkml.kernel.org/r/1381265120-58532-1-git-send-email-Waiman.Long@hp.com
The err variable is intended to receive the timer_create() return before
checking it
Signed-off-by: Felipe Pena <felipensp@gmail.com>
Fix perf probe --list to initialize fname local var always before
use it. This may cause a SEGV if there is a probe which is in
the function body but not in any inline function.
Problem introduced in:
commit e08cfd4bda76
Author: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Date: Mon Sep 30 18:21:44 2013 +0900
perf probe: Fix to find line information for probe list
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/20131011122317.9662.29736.stgit@kbuild-fedora.novalocal
perf-record updates the header in the perf.data file at termination.
Without this update perf-report (and other processing built-ins) it
caused an infinite loop when perf report (or something like) called.
This is because the algorithm in __perf_session__process_events()
depends on the data_size which is read from file header. Use file size
directly instead in this case to do the best-effort processing.
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Tested-by: Sonny Rao <sonnyrao@chromium.org>
Cc: Sonny Rao <sonnyrao@chromium.org>
Link: http://lkml.kernel.org/r/1380529188-27193-1-git-send-email-namhyung@kernel.org
Signed-off-by: David Ahern <dsahern@gmail.com>
[ Reworded warning as per Ingo Molnar suggestion, replaces 'perf.data'
with session->filename, to precisely identify the data file involved ]
Doing a fresh install on a user home directory needs to first make sure
that the ~/libexec/perf-core/ directory is present so that
'perf-archive' like scripts, 'perf test' attr config files and 'perf
script' scripts can be installed.
Link: http://lkml.kernel.org/n/tip-z7ryi3r1b9dn9smbfnab0fdc@git.kernel.org
Fix to find the correct (as much as possible) line information for
listing probes. Without this fix, perf probe --list action will show
incorrect line information as below;
probe:getname_flags (on getname_flags@ksrc/linux-3/fs/namei.c)
probe:getname_flags_1 (on getname:-89@x86/include/asm/current.h)
probe:getname_flags_2 (on user_path_at_empty:-2054@x86/include/asm/current.h)
The minus line number is obviously wrong, and current.h is not related
to the probe point. Deeper investigation discovered that there were 2
issues related to this bug, and minor typos too.
The 1st issue is the rack of considering about nested inlined functions,
which causes the wrong (relative) line number.
The 2nd issue is that the dwarf line info is not correct at those
points. It points 14th line of current.h.
Since it seems that the line info includes somewhat unreliable
information, this fixes perf to try to find correct line information
from both of debuginfo and line info as below.
1) Probe address is the entry of a function instance
In this case, the line is set as the function declared line.
2) Probe address is the entry of an expanded inline function block
In this case, the line is set as the function call-site line.
This means that the line number is relative from the entry line
of caller function (which can be an inlined function if nested)
3) Probe address is inside a function instance or an expanded
In this case, perf probe queries the line number from lineinfo
and verify the function declared file is same as the file name
queried from lineinfo.
If the file name is different, it is a failure case. The probe
address is shown as symbol+offset.
4) Probe address is not in the any function instance
This is a failure case, the probe address is shown as
symbol+offset.
With this fix, perf probe -l shows correct probe lines as below;
probe:getname_flags_1 (on getname:2@ksrc/linux-3/fs/namei.c)
probe:getname_flags_2 (on user_path_at_empty:4@ksrc/linux-3/fs/namei.c)
Changes at v2:
- Fix typos in the function comments. (Thanks to Namhyung Kim)
- Use die_find_top_inlinefunc instead of die_find_inlinefunc_next.
Link: http://lkml.kernel.org/r/20130930092144.1693.11058.stgit@udc4-manage.rcp.hitachi.co.jp
In ubuntu systems the libaudit test was always failing due to the
newline in the printf call not being escaped, which somehow didn't
prevented the test from working as expected on other systems, such
as fedora18.
Fix it by removing the newline, as this is just a test, that program is
just a compile test.
The error messages, obtained using 'make V=1':
CHK libaudit
<stdin>: In function ‘main’:
<stdin>:5:9: error: missing terminating " character [-Werror]
<stdin>:5:2: error: missing terminating " character
<stdin>:6:1: error: missing terminating " character [-Werror]
<stdin>:7:2: error: expected expression before ‘return’
<stdin>:8:1: error: expected ‘;’ before ‘}’ token
cc1: all warnings being treated as errors
config/Makefile:241: No libaudit.h found, disables 'trace' tool, please install audit-libs-devel or libaudit-dev
After this change the test works as expected in all systems tested and the
'trace' tool is built when the needed devel packages are installed.
Link: http://lkml.kernel.org/n/tip-0trw8qs9hafeopc0vj1sicay@git.kernel.org
The commit acf2892270dc ("perf stat: Use perf_evlist__prepare/
start_workload()") converted to use the function but forgot to update
child_pid. Fix it.
Link: http://lkml.kernel.org/r/1380531671-28076-1-git-send-email-namhyung@kernel.org
Commands that do not implement an mmap2 handler should at least not die
with a segfault when processing files with MMAP2 events.
Link: http://lkml.kernel.org/r/1379900700-5186-5-git-send-email-dsahern@gmail.com
This reverts commit de95ab53645a2f0015e0f68ee723f18dce2b8b51.
Markus Trippelsdorf reported that this commit broke 'perf top':
> I just see a gray screen with no text at all. Sometimes the
> following error messages are printed:
> *** Error in `perf': invalid fastbin entry (free): 0x00000000029b18c0
> *** Error in `perf': malloc(): memory corruption (fast): 0x0000000000ee0b10 ***
While this code is fixable, the commit itself fails on several levels:
- it should have been a separate helper function
- why the heck does it do strchr() twice
- it casts a const char * over into char *
- sloppy style
- it's not even a regression fix!
So lets revert it and re-try the patch in v3.13.
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
The libbfd C++ demangler doesn't seem to deal with cloned functions,
like symbol.clone.NUM.
Just strip the dot part before demangling and add it back later.
Link: http://lkml.kernel.org/r/1378998998-10802-1-git-send-email-andi@firstfloor.org
In machine__create_modules() the 'path' char array was used in a call to
symbol__restricted_filename() without always being populated.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Namhyung Kim <namhyung@gmail.com>
Link: http://lkml.kernel.org/r/1379845338-29637-2-git-send-email-adrian.hunter@intel.com
[ Split patch removing unrelated conversion of sprintf to snprintf to perf/core ]
Fixes compile failure on Fedora 12.
Link: http://lkml.kernel.org/r/1379900700-5186-3-git-send-email-dsahern@gmail.com
Fix perf probe to probe on some symbols which have some optimzation
suffixes, e.g. ".part", ".isra", and ".constprop".
To fix this issue, instead of using the DIE name, perf probe uses the
symbol name found by dwfl_module_addrsym().
This also involves a perf probe --vars operation update which now shows
the symbol name instead of the DIE name.
Without this patch, putting a probe on an inlined function which was
compiled with a suffixed symbol will fail like this:
$ perf probe -v getname_flags
probe-definition(0): getname_flags
symbol:getname_flags file:(null) line:0 offset:0 return:0 lazy:(null)
0 arguments
Looking at the vmlinux_path (6 entries long)
Using /lib/modules/3.11.0+/build/vmlinux for symbols
found inline addr: 0xffffffff8119bb70
Probe point found: getname_flags+0
found inline addr: 0xffffffff8119bcb6
Probe point found: getname+6
found inline addr: 0xffffffff811a06a6
Probe point found: user_path_at_empty+6
find 3 probe_trace_events.
Opening /sys/kernel/debug//tracing/kprobe_events write=1
Added new events:
Writing event: p:probe/getname_flags getname_flags+0
Failed to write event: No such file or directory
Error: Failed to add events. (-1)
Because the debuginfo knows only the original (non suffix) symbol name,
it uses the original symbol for probe address but the kernel (kallsyms)
knows only suffixed symbol. Then, the kernel rejects that original
symbol.
This patch uses dwfl_module_addrsym() to get the correct (suffixed)
symbol from symtab when a probe point is found.
Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20130925131616.31632.46658.stgit@udc4-manage.rcp.hitachi.co.jp
5c5e854b changed perf_event__synthesize_mmap_events to generate MMAP2
events. Since perf-trace does not have a handler for it it dies with a
segfault when trying to process files:
perf trace -i /tmp/perf.data
Segmentation fault
Link: http://lkml.kernel.org/r/1379900700-5186-4-git-send-email-dsahern@gmail.com
The commit '2814eb0 perf kmem: Remove die() calls' disabled 'perf kmem'
command for machines without numa support. It made the command fail if
'/sys/devices/system/node' dir wasn't found.
Skipping the numa based initialization in case the directory is not
found and continue execution.
Link: http://lkml.kernel.org/r/1379003976-5839-5-git-send-email-jolsa@redhat.com
Solve the problems around the broken definition of perf_event_mmap_page::
cap_usr_time and cap_usr_rdpmc fields which used to overlap, partially
fixed by:
860f085b74e9 ("perf: Fix broken union in 'struct perf_event_mmap_page'")
The problem with the fix (merged in v3.12-rc1 and not yet released
officially), noticed by Vince Weaver is that the new behavior is
not detectable by new user-space, and that due to the reuse of the
field names it's easy to mis-compile a binary if old headers are used
on a new kernel or new headers are used on an old kernel.
To solve all that make this change explicit, detectable and self-contained,
by iterating the ABI the following way:
- Always clear bit 0, and rename it to usrpage->cap_bit0, to at least not
confuse old user-space binaries. RDPMC will be marked as unavailable
to old binaries but that's within the ABI, this is a capability bit.
- Rename bit 1 to ->cap_bit0_is_deprecated and always set it to 1, so new
libraries can reliably detect that bit 0 is deprecated and perma-zero
without having to check the kernel version.
- Use bits 2, 3, 4 for the newly defined, correct functionality:
cap_user_rdpmc : 1, /* The RDPMC instruction can be used to read counts */
cap_user_time : 1, /* The time_* fields are used */
cap_user_time_zero : 1, /* The time_zero field is used */
- Rename all the bitfield names in perf_event.h to be different from the
old names, to make sure it's not possible to mis-compile it
accidentally with old assumptions.
The 'size' field can then be used in the future to add new fields and it
will act as a natural ABI version indicator as well.
Also adjust tools/perf/ userspace for the new definitions, noticed by
Adrian Hunter.
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Also-Fixed-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/n/tip-zr03yxjrpXesOzzupszqglbv@git.kernel.org
* Check for SIGINT in more loops, allowing tools such as 'perf report' to
react faster to Ctrl+C, from Arnaldo Carvalho de Melo.
* Fix objdump line parsing offset validation in the annotate code,
from Adrian Hunter.
* Fix buildid cache handling of kallsyms with kcore, from Adrian Hunter.
* Fix compile with libelf without get_phdrnum, from Adrian Hunter.
* Sharpen the libaudit dependencies test, refusing to build with older
libraries that doesn't have all the functions used by 'perf trace", fix
from Ingo Molnar.
* Fill in new definitions for madvise()/mmap() flags to fix the build in
older systems, from Ingo Molnar.
* Fix old GCC build error in older systems in the kallsyms parsing code in
trace-event-parse.c, from Ingo Molnar.
* Ignore DWARF declaration tags, allowing, for instance, that the
$ perf probe -L getname
command succeeds in showing the source code for the 'getname' kernel
function, telling in which lines probes can be inserted, fix from
Masami Hiramatsu.
* Fix linux/magic.h related build breakage in some systems, fix from
Vinson Lee.
The compilation only looks for linux/magic.h from the default include
paths, which does not include the source tree. This results in a build
error if linux/magic.h is not available or not installed.
For example, this build error occurs on CentOS 5.
$ make -C tools/lib/lk V=1
gcc -o debugfs.o -c -ggdb3 -Wall -Wextra -std=gnu99 -Werror -O6
-D_FORTIFY_SOURCE=2 -Wbad-function-cast -Wdeclaration-after-statement
-Wformat-security -Wformat-y2k -Winit-self -Wmissing-declarations
-Wmissing-prototypes -Wnested-externs -Wno-system-headers
-Wold-style-definition -Wpacked -Wredundant-decls -Wshadow
-Wstrict-aliasing=3 -Wstrict-prototypes -Wswitch-default -Wswitch-enum
-Wundef -Wwrite-strings -Wformat -fPIC -D_LARGEFILE64_SOURCE
-D_FILE_OFFSET_BITS=64 debugfs.c
debugfs.c:8:25: error: linux/magic.h: No such file or directory
The only symbol from linux/magic.h needed by debugfs.c is DEBUGFS_MAGIC,
and that is already defined in debugfs.h. linux/magic.h isn't providing
any extra symbols and can unincluded. This is similar to the approach by
perf, which has its own magic.h wrapper at
tools/perf/util/include/linux/magic.h
Signed-off-by: Vinson Lee <vlee@twitter.com>
Acked-by: Borislav Petkov <bp@suse.de>
Cc: Borislav Petkov <bp@suse.de>
Cc: Vinson Lee <vlee@freedesktop.org>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/1379546200-17028-1-git-send-email-vlee@freedesktop.org
Old GCC (4.1) does not see through the code flow of parse_proc_kallsyms()
and gets confused about the status of 'fmt':
util/trace-event-parse.c: In function ‘parse_proc_kallsyms’:
util/trace-event-parse.c:189: warning: ‘fmt’ may be used uninitialized in this function
make: *** [util/trace-event-parse.o] Error 1
Help out GCC by initializing 'fmt' to NULL.
Link: http://lkml.kernel.org/r/20130912131649.GC23826@gmail.com
The commit ba28c59bc9ed8fb7b9a753cd88ee54a2c4f6265b fixed a declaration
entry bug in probe_point_search_cb(). There are same bugs in line
finder and call_probe_finder(). This introduces a new dwarf utility
function to determine given DIE is a function definition, not
declaration.
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Prashanth Nageshappa <prashanth@linux.vnet.ibm.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: yrl.pp-manager.tt@hitachi.com
Link: http://lkml.kernel.org/r/20120423032435.8737.80064.stgit@localhost.localdomain
When processing big files we were not checking if session_done was set
by the SIGINT signal handler, for instance in 'perf report'. Fix it.
Link: http://lkml.kernel.org/n/tip-pyad42lgrtq7xhg2dpsoauq7@git.kernel.org
Add a feature check for get_phdrnum() and implement a replacement if it
is not present.
Link: http://lkml.kernel.org/r/1379080170-6608-1-git-send-email-adrian.hunter@intel.com
When kallsyms is used with kcore the dso long_name becomes the kcore
file name. That prevents the buildid cache from caching kallsyms.
(There is no support at present for caching kcore). Fix by changing it
so that the kallsyms name is used in that case instead.
Link: http://lkml.kernel.org/r/1379009959-28046-1-git-send-email-adrian.hunter@intel.com
[ Kept 'struct foo' pointer as first parameter of foo__ prefixed functions ]
When parsing lines from objdump a line containing source code starting
with a numeric label is mistaken for a line of disassembly starting with
a memory address.
Current validation fails to recognise that the "memory address" is out
of range and calculates an invalid offset which later causes this
segfault:
Program received signal SIGSEGV, Segmentation fault.
0x0000000000457315 in disasm__calc_percent (notes=0xc98970, evidx=0, offset=143705, end=2127526177, path=0x7fffffffbf50)
at util/annotate.c:631
631 hits += h->addr[offset++];
(gdb) bt
#0 0x0000000000457315 in disasm__calc_percent (notes=0xc98970, evidx=0, offset=143705, end=2127526177, path=0x7fffffffbf50)
#1 0x00000000004d65e3 in annotate_browser__calc_percent (browser=0x7fffffffd130, evsel=0xa01da0) at ui/browsers/annotate.c:364
#2 0x00000000004d7433 in annotate_browser__run (browser=0x7fffffffd130, evsel=0xa01da0, hbt=0x0) at ui/browsers/annotate.c:672
#3 0x00000000004d80c9 in symbol__tui_annotate (sym=0xc989a0, map=0xa02660, evsel=0xa01da0, hbt=0x0) at ui/browsers/annotate.c:962
#4 0x00000000004d7aa0 in hist_entry__tui_annotate (he=0xdf73f0, evsel=0xa01da0, hbt=0x0) at ui/browsers/annotate.c:823
#5 0x00000000004dd648 in perf_evsel__hists_browse (evsel=0xa01da0, nr_events=1, helpline=
0x58b768 "For a higher level overview, try: perf report --sort comm,dso", ev_name=0xa02cd0 "cycles", left_exits=false, hbt=
0x0, min_pcnt=0, env=0xa011e0) at ui/browsers/hists.c:1659
#6 0x00000000004de372 in perf_evlist__tui_browse_hists (evlist=0xa01520, help=
0x58b768 "For a higher level overview, try: perf report --sort comm,dso", hbt=0x0, min_pcnt=0, env=0xa011e0)
at ui/browsers/hists.c:1950
#7 0x000000000042cf6b in __cmd_report (rep=0x7fffffffd6c0) at builtin-report.c:581
#8 0x000000000042e25d in cmd_report (argc=0, argv=0x7fffffffe4b0, prefix=0x0) at builtin-report.c:965
#9 0x000000000041a0e1 in run_builtin (p=0x801548, argc=1, argv=0x7fffffffe4b0) at perf.c:319
#10 0x000000000041a319 in handle_internal_command (argc=1, argv=0x7fffffffe4b0) at perf.c:376
#11 0x000000000041a465 in run_argv (argcp=0x7fffffffe38c, argv=0x7fffffffe380) at perf.c:420
#12 0x000000000041a707 in main (argc=1, argv=0x7fffffffe4b0) at perf.c:521
After the fix is applied the symbol can be annotated showing the
problematic line "1: rep"
copy_user_generic_string /usr/lib/debug/lib/modules/3.9.10-100.fc17.x86_64/vmlinux
ENTRY(copy_user_generic_string)
CFI_STARTPROC
ASM_STAC
andl %edx,%edx
and %edx,%edx
jz 4f
je 37
cmpl $8,%edx
cmp $0x8,%edx
jb 2f /* less than 8 bytes, go to byte copy loop */
jb 33
ALIGN_DESTINATION
mov %edi,%ecx
and $0x7,%ecx
je 28
sub $0x8,%ecx
neg %ecx
sub %ecx,%edx
1a: mov (%rsi),%al
mov %al,(%rdi)
inc %rsi
inc %rdi
dec %ecx
jne 1a
movl %edx,%ecx
28: mov %edx,%ecx
shrl $3,%ecx
shr $0x3,%ecx
andl $7,%edx
and $0x7,%edx
1: rep
100.00 rep movsq %ds:(%rsi),%es:(%rdi)
movsq
2: movl %edx,%ecx
33: mov %edx,%ecx
3: rep
rep movsb %ds:(%rsi),%es:(%rdi)
movsb
4: xorl %eax,%eax
37: xor %eax,%eax
data32 xchg %ax,%ax
ASM_CLAC
ret
retq
Link: http://lkml.kernel.org/r/1379009721-27667-1-git-send-email-adrian.hunter@intel.com
builtin-trace.c started using various new syscall features not defined
in the header files of older distros - resulting in build failures.
Fill in the (ABI) constants if they are not defined.
(There might be a better place to put this than builtin-trace.c, into a
compat header or so.)
Cc: linux-tip-commits@vger.kernel.org
Link: http://lkml.kernel.org/r/20130912132900.GE23826@gmail.com
There are older libaudit versions that don't have an
audit_errno_to_name() method, resulting in a builtin-trace.c build
error:
builtin-trace.c: In function ‘trace__sys_exit’:
builtin-trace.c:794: warning: implicit declaration of function ‘audit_errno_to_name’
Expand the libaudit test to detect this.
Link: http://lkml.kernel.org/r/20130912132706.GD23826@gmail.com
[ Fix the test by escaping the double quotes ]
Pull perf fixes from Ingo Molnar:
"Various fixes.
The -g perf report lockup you reported is only partially addressed,
patches that fix the excessive runtime are still being worked on"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf/x86: Fix uncore PCI fixed counter handling
uprobes: Fix utask->depth accounting in handle_trampoline()
perf/x86: Add constraint for IVB CYCLE_ACTIVITY:CYCLES_LDM_PENDING
perf: Fix up MMAP2 buffer space reservation
perf kvm: Fix sample_type manipulation
perf evlist: Fix id pos in perf_evlist__open()
perf trace: Handle perf.data files with no tracepoints
perf session: Separate progress bar update when processing events
perf trace: Check if MAP_32BIT is defined
perf evlist: Fix parsing with no sample_id_all bit set
perf tools: Add test for parsing with no sample_id_all bit
perf trace: Check control+C more often
This patch adds support for the new PERF_RECORD_MMAP2 record type
exposed by the kernel. This is an extended PERF_RECORD_MMAP record.
It adds for each file-backed mapping the device major, minor number and
the inode number and generation.
This triplet uniquely identifies the source of a file-backed mapping. It
can be used to detect identical virtual mappings between processes, for
instance.
The patch will prefer MMAP2 over MMAP.
Cc: Namhyung Kim <namhyung.kim@lge.com>
Link: http://lkml.kernel.org/r/1377079825-19057-3-git-send-email-eranian@google.com
[ Cope with 314add6 "Change machine__findnew_thread() to set thread pid",
fix 'perf test' regression test entry affected,
use perf_missing_features.mmap2 to fallback to not using .mmap2 in older kernels,
so that new tools can work with kernels where this feature is not present ]
Manipulating the sample_type of an evsel requires the use of:
perf_evsel__set_sample_bit()
and perf_evsel__reset_sample_bit()
Link: http://lkml.kernel.org/r/1378496412-2424-3-git-send-email-adrian.hunter@intel.com
Ensure the id_pos is correct when perf_evlist__open() is used.
This fixes a problem introduced in 7556257 that broke 'perf kvm stat
live' in that this tool wasn't updated to use the sample_type bits
setting helpers.
Link: http://lkml.kernel.org/r/1378496412-2424-2-git-send-email-adrian.hunter@intel.com
Before:
perf trace -i perf.data
Segmentation fault (core dumped)
After:
# perf trace -i perf.data
Data file does not have raw_syscalls:sys_enter events
When there are no tracepoints in a perf.data file the struct pevent
that contains the list of tracepoints that will be used to lookup the
tracepoint id by name will not be populated, causing a NULL deref.
And we don't need to do all that dance to look at pevents for an entry
with a slighly different name to then lookup the tracepoint by its id on
the evlist, just use the perf_evlist__find_tracepoint_by_name() routine,
that will find the tracepoint, if present.
Link: http://lkml.kernel.org/n/tip-egcm21k1e6gcyxpcgjxtmsq3@git.kernel.org
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux
Pull virtio update from Rusty Russell:
"More console fixes; these are the theoretical ones which didn't get
CC:stable. But for that reason, I did a merge with master partway
through to avoid an unnecessary conflict.
Also: a fun lguest bug turns out if you don't clear the TF flag when
trapping Bad Things happen to the guest kernel as the stack
overflows..."
* tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux:
virtio_pci: pm: Use CONFIG_PM_SLEEP instead of CONFIG_PM
lguest: fix GPF in guest when using gdb.
lguest: fix guest kernel stack overflow when TF bit set.
lguest: fix BUG_ON() in invalid guest page table.
virtio: console: prevent use-after-free of port name in port unplug
virtio: console: cleanup an error message
virtio: console: fix locking around send_sigio_to_port()
virtio: console: add locking in port unplug path
virtio: console: add locks around buffer removal in port unplug path
tools/lguest: offer VIRTIO_F_ANY_LAYOUT for net device.
virtio tools: add .gitignore
lguest: Point to the right directory for the lguest launcher
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"Here's the powerpc batch for this merge window. Some of the
highlights are:
- A bunch of endian fixes ! We don't have full LE support yet in that
release but this contains a lot of fixes all over arch/powerpc to
use the proper accessors, call the firmware with the right endian
mode, etc...
- A few updates to our "powernv" platform (non-virtualized, the one
to run KVM on), among other, support for bridging the P8 LPC bus
for UARTs, support and some EEH fixes.
- Some mpc51xx clock API cleanups in preparation for a clock API
overhaul
- A pile of cleanups of our old math emulation code, including better
support for using it to emulate optional FP instructions on
embedded chips that otherwise have a HW FPU.
- Some infrastructure in selftest, for powerpc now, but could be
generalized, initially used by some tests for our perf instruction
counting code.
- A pile of fixes for hotplug on pseries (that was seriously
bitrotting)
- The usual slew of freescale embedded updates, new boards, 64-bit
hiberation support, e6500 core PMU support, etc..."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (146 commits)
powerpc: Correct FSCR bit definitions
powerpc/xmon: Fix printing of set of CPUs in xmon
powerpc/pseries: Move lparcfg.c to platforms/pseries
powerpc/powernv: Return secondary CPUs to firmware on kexec
powerpc/btext: Fix CONFIG_PPC_EARLY_DEBUG_BOOTX on ppc32
powerpc: Cleanup handling of the DSCR bit in the FSCR register
powerpc/pseries: Child nodes are not detached by dlpar_detach_node
powerpc/pseries: Add mising of_node_put in delete_dt_node
powerpc/pseries: Make dlpar_configure_connector parent node aware
powerpc/pseries: Do all node initialization in dlpar_parse_cc_node
powerpc/pseries: Fix parsing of initial node path in update_dt_node
powerpc/pseries: Pack update_props_workarea to map correctly to rtas buffer header
powerpc/pseries: Fix over writing of rtas return code in update_dt_node
powerpc/pseries: Fix creation of loop in device node property list
powerpc: Skip emulating & leave interrupts off for kernel program checks
powerpc: Add more exception trampolines for hypervisor exceptions
powerpc: Fix location and rename exception trampolines
powerpc: Add more trap names to xmon
powerpc/pseries: Add a warning in the case of cross-cpu VPA registration
powerpc: Update the 00-Index in Documentation/powerpc
Currently when processing events in the __perf_session__process_events
function we update a progress bar based on the file_size. During the
same processing we update the progress bar from within
flush_sample_queue which is based on number of samples count.
Having 2 different based updates is causing the progress bar to jump
heavily back and forth giving not much usefull info.
Fixing this by keeping only __perf_session__process_events based
progress bar update. And turning on flush_sample_queue progress bar
update only for final flushing.
This reduces the number of time the progress bar update function is
called and it significantly reduces the loading time for TUI, where the
progress bar update takes quite a lot of time.
Link: http://lkml.kernel.org/r/20130905091449.GC1100@krava.brq.redhat.com
