path: root/tools
2014-10-05perf kmem: Make it work again on non NUMA machinesJiri Olsa
commit 4921e320244e099bdf237fd10428594ce5f5b87d upstream. The commit '2814eb0 perf kmem: Remove die() calls' disabled 'perf kmem' command for machines without numa support. It made the command fail if '/sys/devices/system/node' dir wasn't found. Skipping the numa based initialization in case the directory is not found and continue execution. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1379003976-5839-5-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: zhangzhiqiang <zhangzhiqiang.zhang@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-17mnt: Add tests for unprivileged remount cases that have found to be faultyEric W. Biederman
commit db181ce011e3c033328608299cd6fac06ea50130 upstream. Kenton Varda <kenton@sandstorm.io> discovered that by remounting a read-only bind mount read-only in a user namespace the MNT_LOCK_READONLY bit would be cleared, allowing an unprivileged user to the remount a read-only mount read-write. Upon review of the code in remount it was discovered that the code allowed nosuid, noexec, and nodev to be cleared. It was also discovered that the code was allowing the per mount atime flags to be changed. The first naive patch to fix these issues contained the flaw that using default atime settings when remounting a filesystem could be disallowed. To avoid this problems in the future add tests to ensure unprivileged remounts are succeeding and failing at the appropriate times. Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09tools: ffs-test: fix header values endianessMichal Nazarewicz
commit f35f71244da6e51db4e1f2c7e318581f498ececf upstream. It appears that no one ever run ffs-test on a big-endian machine, since it used cpu-endianess for fs_count and hs_count fields which should be in little-endian format. Fix by wrapping the numbers in cpu_to_le32. Signed-off-by: Michal Nazarewicz <mina86@mina86.com> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-06-11perf evsel: Fix printing of perf_event_paranoid messageDavid Ahern
commit b69e63a45f2d96a0dfe930ed20385058d4574d2f upstream. message is currently shown as: Error: You may not have permission to collect %sstats. Consider tweaking /proc/sys/kernel/perf_event_paranoid: Note the %sstats. With patch this becomes: Error: You may not have permission to collect stats. Consider tweaking /proc/sys/kernel/perf_event_paranoid: Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1369526040-1368-1-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: xiakaixu <xiakaixu@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13turbostat: Use GCC's CPUID functions to support PICJosh Triplett
commit 2b92865e648ce04a39fda4f903784a5d01ecb0dc upstream. turbostat uses inline assembly to call cpuid. On 32-bit x86, on systems that have certain security features enabled by default that make -fPIC the default, this causes a build error: turbostat.c: In function ‘check_cpuid’: turbostat.c:1906:2: error: PIC register clobbered by ‘ebx’ in ‘asm’ asm("cpuid" : "=a" (fms), "=c" (ecx), "=d" (edx) : "a" (1) : "ebx"); ^ GCC provides a header cpuid.h, containing a __get_cpuid function that works with both PIC and non-PIC. (On PIC, it saves and restores ebx around the cpuid instruction.) Use that instead. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-13turbostat: Don't put unprocessed uapi headers in the include pathJosh Triplett
commit b731f3119de57144e16c19fd593b8daeb637843e upstream. turbostat's Makefile puts arch/x86/include/uapi/ in the include path, so that it can include <asm/msr.h> from it. It isn't in general safe to include even uapi headers directly from the kernel tree without processing them through scripts/headers_install.sh, but asm/msr.h happens to work. However, that include path can break with some versions of system headers, by overriding some system headers with the unprocessed versions directly from the kernel source. For instance: In file included from /build/x86-generic/usr/include/bits/sigcontext.h:28:0, from /build/x86-generic/usr/include/signal.h:339, from /build/x86-generic/usr/include/sys/wait.h:31, from turbostat.c:27: ../../../../arch/x86/include/uapi/asm/sigcontext.h:4:28: fatal error: linux/compiler.h: No such file or directory This occurs because the system bits/sigcontext.h on that build system includes <asm/sigcontext.h>, and asm/sigcontext.h in the kernel source includes <linux/compiler.h>, which scripts/headers_install.sh would have filtered out. Since turbostat really only wants a single header, just include that one header rather than putting an entire directory of kernel headers on the include path. In the process, switch from msr.h to msr-index.h, since turbostat just wants the MSR numbers. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06perf kvm: Fix kvm report without guestmount.Dongsheng Yang
commit ad85ace07a05062ef6b59c35a5e80b6eaee1eee6 upstream. Currently, if we use perf kvm --guestkallsyms --guestmodules report, we can not get the perf information from perf data file. All sample are shown as unknown. Reproducing steps: # perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules record -a sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.624 MB perf.data.guest (~27260 samples) ] # perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules report |grep % 100.00% [guest/6471] [unknown] [g] 0xffffffff8164f330 This bug was introduced by 207b57926 (perf kvm: Fix regression with guest machine creation). In original code, it uses perf_session__find_machine(), it means we deliver symbol to machine which has the same pid, if no machine found, deliver it to *default* guest. But if we use perf_session__findnew_machine() here, if no machine was found, new machine with pid will be built and added. Then the default guest which with pid == 0 will never get a symbol. And because the new machine initialized here has no kernel map created, the symbol delivered to it will be marked as "unknown". This patch here is to revert commit 207b57926 and fix the SEGFAULT bug in another way. Verification steps: # ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules record -a sleep 1 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.651 MB perf.data.guest (~28437 samples) ] # ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules report |grep % 22.64% :6471 [guest.kernel.kallsyms] [g] update_rq_clock.part.70 19.99% :6471 [guest.kernel.kallsyms] [g] d_free 18.46% :6471 [guest.kernel.kallsyms] [g] bio_phys_segments 16.25% :6471 [guest.kernel.kallsyms] [g] dequeue_task 12.78% :6471 [guest.kernel.kallsyms] [g] __switch_to 7.91% :6471 [guest.kernel.kallsyms] [g] scheduler_tick 1.75% :6471 [guest.kernel.kallsyms] [g] native_apic_mem_write 0.21% :6471 [guest.kernel.kallsyms] [g] apic_timer_interrupt Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Link: http://lkml.kernel.org/r/1387564907-3045-1-git-send-email-yangds.fnst@cn.fujitsu.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-25perf scripting perl: Fix build error on Fedora 12Arnaldo Carvalho de Melo
commit 3b16ff89676d9902dc39976aee3cb0314ee37d93 upstream. Cast __u64 to u64 to silence this warning on older distros, such as Fedora 12: CC /tmp/build/perf/util/scripting-engines/trace-event-perl.o cc1: warnings being treated as errors util/scripting-engines/trace-event-perl.c: In function ‘perl_process_tracepoint’: util/scripting-engines/trace-event-perl.c:285: error: format ‘%lu’ expects type ‘long unsigned int’, but argument 2 has type ‘__u64’ make[1]: *** [/tmp/build/perf/util/scripting-engines/trace-event-perl.o] Error 1 make: *** [install] Error 2 make: Leaving directory `/home/acme/git/linux/tools/perf' [acme@fedora12 linux]$ Reported-by: Waiman Long <Waiman.Long@hp.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tom.zanussi@linux.intel.com> Cc: Waiman Long <Waiman.Long@hp.com> Link: http://lkml.kernel.org/n/tip-nlxofdqcdjfm0w9o6bgq4kqv@git.kernel.org Link: http://lkml.kernel.org/r/1381265120-58532-1-git-send-email-Waiman.Long@hp.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Xie XiuQi <xiexiuqi@huawei.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-09cpupower: Fix segfault due to incorrect getopt_long arugmentsJosh Boyer
commit f447ef4a56dee4b68a91460bcdfe06b5011085f2 upstream. If a user calls 'cpupower set --perf-bias 15', the process will end with a SIGSEGV in libc because cpupower-set passes a NULL optarg to the atoi call. This is because the getopt_long structure currently has all of the options as having an optional_argument when they really have a required argument. We change the structure to use required_argument to match the short options and it resolves the issue. This fixes https://bugzilla.redhat.com/show_bug.cgi?id=1000439 Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-04perf tools: Remove cast of non-variadic function to variadicMichael Hudson-Doyle
commit 53805eca3d89b095062c11a6798689bb0af09216 upstream. The 4fb71074a570 (perf ui/hist: Consolidate hpp helpers) cset introduced a cast of percent_color_snprintf to a function pointer type with varargs. Change percent_color_snprintf to be variadic and remove the cast. The symptom of this was all percentages being reported as 0.00% in perf report --stdio output on the armhf arch. Signed-off-by: Michael Hudson-Doyle <michael.hudson@linaro.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Will Deacon <will.deacon@arm.com> Cc: Jean Pihet <jean.pihet@linaro.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Will Deacon <will.deacon@arm.com> Link: http://lkml.kernel.org/r/87zjppvw7y.fsf@canonical.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-05tools lib lk: Uninclude linux/magic.h in debugfs.cVinson Lee
commit ce7eebe5c3deef8e19c177c24ee75843256e69ca upstream. The compilation only looks for linux/magic.h from the default include paths, which does not include the source tree. This results in a build error if linux/magic.h is not available or not installed. For example, this build error occurs on CentOS 5. $ make -C tools/lib/lk V=1 [...] gcc -o debugfs.o -c -ggdb3 -Wall -Wextra -std=gnu99 -Werror -O6 -D_FORTIFY_SOURCE=2 -Wbad-function-cast -Wdeclaration-after-statement -Wformat-security -Wformat-y2k -Winit-self -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wno-system-headers -Wold-style-definition -Wpacked -Wredundant-decls -Wshadow -Wstrict-aliasing=3 -Wstrict-prototypes -Wswitch-default -Wswitch-enum -Wundef -Wwrite-strings -Wformat -fPIC -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 debugfs.c debugfs.c:8:25: error: linux/magic.h: No such file or directory The only symbol from linux/magic.h needed by debugfs.c is DEBUGFS_MAGIC, and that is already defined in debugfs.h. linux/magic.h isn't providing any extra symbols and can unincluded. This is similar to the approach by perf, which has its own magic.h wrapper at tools/perf/util/include/linux/magic.h Signed-off-by: Vinson Lee <vlee@twitter.com> Acked-by: Borislav Petkov <bp@suse.de> Cc: Borislav Petkov <bp@suse.de> Cc: Vinson Lee <vlee@freedesktop.org> Link: http://lkml.kernel.org/r/1379546200-17028-1-git-send-email-vlee@freedesktop.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-10-01perf tools: Handle JITed code in shared memoryAndi Kleen
commit 89365e6c9ad4c0e090e4c6a4b67a3ce319381d89 upstream. Need to check for /dev/zero. Most likely more strings are missing too. Signed-off-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1366848182-30449-1-git-send-email-andi@firstfloor.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Vinson Lee <vlee@freedesktop.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04perf tools: Revert regression in configuration of Python supportMichael Witten
commit a363a9da65d253fa7354ce5fd630f4f94df934cc upstream. Among other things, the following: commit 31160d7feab786c991780d7f0ce2755a469e0e5e Date: Tue Jan 8 16:22:36 2013 -0500 perf tools: Fix GNU make v3.80 compatibility issue attempts to aid the user by tapping into an existing error message, as described in the commit message: ... Also fix an issue where _get_attempt was called with only one argument. This prevented the error message from printing the name of the variable that can be used to fix the problem. or more precisely: -$(if $($(1)),$(call _ge_attempt,$($(1)),$(1)),$(call _ge_attempt,$(2))) +$(if $($(1)),$(call _ge_attempt,$($(1)),$(1)),$(call _ge_attempt,$(2),$(1))) However, The "missing" argument was in fact missing on purpose; it's absence is a signal that the error message should be skipped, because the failure would be due to the default value, not any user-supplied value. This can be seen in how `_ge_attempt' uses `gea_err' (in the config/utilities.mak file): _ge_attempt = $(if $(get-executable),$(get-executable),$(_gea_warn)$(call _gea_err,$(2))) _gea_warn = $(warning The path '$(1)' is not executable.) _gea_err = $(if $(1),$(error Please set '$(1)' appropriately)) That is, because the argument is no longer missing, the value `$(1)' (associated with `_gea_err') always evaluates to true, thus always triggering the error condition that is meant to be reserved for only the case when a user explicitly supplies an invalid value. Concretely, the result is a regression in the Makefile's configuration of python support; rather than gracefully disable support when the relevant executables cannot be found according to default values, the build process halts in error as though the user explicitly supplied the values. This new commit simply reverts the offending one-line change. Reported-by: Pekka Enberg <penberg@kernel.org> Link: http://lkml.kernel.org/r/CAOJsxLHv17Ys3M7P5q25imkUxQW6LE_vABxh1N3Tt7Mv6Ho4iw@mail.gmail.com Signed-off-by: Michael Witten <mfwitten@gmail.com> Cc: Mark Brown <broonie@sirena.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-04Tools: hv: KVP: Fix a bug in IPV6 subnet enumerationK. Y. Srinivasan
commit ed4bb9744b41d39ba35080c2390e201575121dc7 upstream. Each subnet string needs to be separated with a semicolon. Fix this bug. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-13turbostat: Increase output buffer size to accommodate C8-C10Josh Triplett
On platforms with C8-C10 support, the additional C-states cause turbostat to overrun its output buffer of 128 bytes per CPU. Increase this to 256 bytes per CPU. [ As a bugfix, this should go into 3.10; however, since the C8-C10 support didn't go in until after 3.9, this need not go into any stable kernel. ] Signed-off-by: Josh Triplett <josh@joshtriplett.org> Cc: Len Brown <len.brown@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-24revert "selftest: add simple test for soft-dirty bit"Andrew Morton
Revert commit 58c7be84fec8 ("selftest: add simple test for soft-dirty bit"). This is the self test for Pavel's pagemap2 patches which didn't actually get merged. Reported-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-22perf: net_dropmonitor: Remove progress indicatorBen Hutchings
We can read /proc/kallsyms in a fraction of a second, so why waste a further fraction of a second showing progress? Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-22perf: net_dropmonitor: Use bisection in symbol lookupBen Hutchings
2013-05-22perf: net_dropmonitor: Do not assume ordering of dictionariesBen Hutchings
The sort order of dictionaries in Python is undocumented. Use tuples instead, which are documented to be lexically ordered. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-22perf: net_dropmonitor: Fix symbol-relative addressesBen Hutchings
The comparison between traced and symbol addresses is backwards: if the traced address doesn't exactly match a symbol (which we don't expect it to), we'll show the next symbol and the offset to it, whereas we should show the previous symbol and the offset from it. Cc: stable@vger.kernel.org Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-22perf: net_dropmonitor: Fix trace parameter orderBen Hutchings
This works much better if we don't treat protocol numbers as addresses. Cc: stable@vger.kernel.org Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-05-11Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull idle update from Len Brown: "Add support for new Haswell-ULT CPU idle power states" * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: intel_idle: initial C8, C9, C10 support tools/power turbostat: display C8, C9, C10 residency
2013-05-02Merge tag 'virtio-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull virtio & lguest updates from Rusty Russell: "Lots of virtio work which wasn't quite ready for last merge window. Plus I dived into lguest again, reworking the pagetable code so we can move the switcher page: our fixmaps sometimes take more than 2MB now..." Ugh. Annoying conflicts with the tcm_vhost -> vhost_scsi rename. Hopefully correctly resolved. * tag 'virtio-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: (57 commits) caif_virtio: Remove bouncing email addresses lguest: improve code readability in lg_cpu_start. virtio-net: fill only rx queues which are being used lguest: map Switcher below fixmap. lguest: cache last cpu we ran on. lguest: map Switcher text whenever we allocate a new pagetable. lguest: don't share Switcher PTE pages between guests. lguest: expost switcher_pages array (as lg_switcher_pages). lguest: extract shadow PTE walking / allocating. lguest: make check_gpte et. al return bool. lguest: assume Switcher text is a single page. lguest: rename switcher_page to switcher_pages. lguest: remove RESERVE_MEM constant. lguest: check vaddr not pgd for Switcher protection. lguest: prepare to make SWITCHER_ADDR a variable. virtio: console: replace EMFILE with EBUSY for already-open port virtio-scsi: reset virtqueue affinity when doing cpu hotplug virtio-scsi: introduce multiqueue support virtio-scsi: push vq lock/unlock into virtscsi_vq_done virtio-scsi: pass struct virtio_scsi to virtqueue completion function ...
2013-05-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: "Highlights (1721 non-merge commits, this has to be a record of some sort): 1) Add 'random' mode to team driver, from Jiri Pirko and Eric Dumazet. 2) Make it so that any driver that supports configuration of multiple MAC addresses can provide the forwarding database add and del calls by providing a default implementation and hooking that up if the driver doesn't have an explicit set of handlers. From Vlad Yasevich. 3) Support GSO segmentation over tunnels and other encapsulating devices such as VXLAN, from Pravin B Shelar. 4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton. 5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita Dukkipati. 6) In the PHY layer, allow supporting wake-on-lan in situations where the PHY registers have to be written for it to be configured. Use it to support wake-on-lan in mv643xx_eth. From Michael Stapelberg. 7) Significantly improve firewire IPV6 support, from YOSHIFUJI Hideaki. 8) Allow multiple packets to be sent in a single transmission using network coding in batman-adv, from Martin Hundebøll. 9) Add support for T5 cxgb4 chips, from Santosh Rastapur. 10) Generalize the VXLAN forwarding tables so that there is more flexibility in configurating various aspects of the endpoints. From David Stevens. 11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver, from Dmitry Kravkov. 12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo Neira Ayuso. 13) Start adding networking selftests. 14) In situations of overload on the same AF_PACKET fanout socket, or per-cpu packet receive queue, minimize drop by distributing the load to other cpus/fanouts. From Willem de Bruijn and Eric Dumazet. 15) Add support for new payload offset BPF instruction, from Daniel Borkmann. 16) Convert several drivers over to mdoule_platform_driver(), from Sachin Kamat. 17) Provide a minimal BPF JIT image disassembler userspace tool, from Daniel Borkmann. 18) Rewrite F-RTO implementation in TCP to match the final specification of it in RFC4138 and RFC5682. From Yuchung Cheng. 19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear you like netlink, so I implemented netlink dumping of netlink sockets.") From Andrey Vagin. 20) Remove ugly passing of rtnetlink attributes into rtnl_doit functions, from Thomas Graf. 21) Allow userspace to be able to see if a configuration change occurs in the middle of an address or device list dump, from Nicolas Dichtel. 22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes Frederic Sowa. 23) Increase accuracy of packet length used by packet scheduler, from Jason Wang. 24) Beginning set of changes to make ipv4/ipv6 fragment handling more scalable and less susceptible to overload and locking contention, from Jesper Dangaard Brouer. 25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*() instead. From Hong Zhiguo. 26) Optimize route usage in IPVS by avoiding reference counting where possible, from Julian Anastasov. 27) Convert IPVS schedulers to RCU, also from Julian Anastasov. 28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger Eitzenberger. 29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG, nfnetlink_log, and nfnetlink_queue. From Gao feng. 30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa. 31) Support several new r8169 chips, from Hayes Wang. 32) Support tokenized interface identifiers in ipv6, from Daniel Borkmann. 33) Use usbnet_link_change() helper in USB net driver, from Ming Lei. 34) Add 802.1ad vlan offload support, from Patrick McHardy. 35) Support mmap() based netlink communication, also from Patrick McHardy. 36) Support HW timestamping in mlx4 driver, from Amir Vadai. 37) Rationalize AF_PACKET packet timestamping when transmitting, from Willem de Bruijn and Daniel Borkmann. 38) Bring parity to what's provided by /proc/net/packet socket dumping and the info provided by netlink socket dumping of AF_PACKET sockets. From Nicolas Dichtel. 39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin Poirier" * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits) filter: fix va_list build error af_unix: fix a fatal race with bit fields bnx2x: Prevent memory leak when cnic is absent bnx2x: correct reading of speed capabilities net: sctp: attribute printl with __printf for gcc fmt checks netlink: kconfig: move mmap i/o into netlink kconfig netpoll: convert mutex into a semaphore netlink: Fix skb ref counting. net_sched: act_ipt forward compat with xtables mlx4_en: fix a build error on 32bit arches Revert "bnx2x: allow nvram test to run when device is down" bridge: avoid OOPS if root port not found drivers: net: cpsw: fix kernel warn on cpsw irq enable sh_eth: use random MAC address if no valid one supplied 3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA) tg3: fix to append hardware time stamping flags unix/stream: fix peeking with an offset larger than data in queue unix/dgram: fix peeking with an offset larger than data in queue unix/dgram: peek beyond 0-sized skbs openvswitch: Remove unneeded ovs_netdev_get_ifindex() ...
2013-04-30selftest: add a test case for PTRACE_PEEKSIGINFOAndrey Vagin
* Dump signals from process-wide and per-thread queues with different sizes of buffers. * Check error paths for buffers with restricted permissions. A part of buffer or a whole buffer is for read-only. * Try to get nonexistent signal. Signed-off-by: Andrew Vagin <avagin@openvz.org> Cc: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Dave Jones <davej@redhat.com> Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Pedro Alves <palves@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30selftest: add simple test for soft-dirty bitPavel Emelyanov
It creates a mapping of 3 pages and checks that reads, writes and clear-refs result in present and soft-dirt bits reported from pagemap2 set as expected. [akpm@linux-foundation.org: alphasort the Makefile TARGETS to reduce rejects] Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-04-30Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Features: - Add "uretprobes" - an optimization to uprobes, like kretprobes are an optimization to kprobes. "perf probe -x file sym%return" now works like kretprobes. By Oleg Nesterov. - Introduce per core aggregation in 'perf stat', from Stephane Eranian. - Add memory profiling via PEBS, from Stephane Eranian. - Event group view for 'annotate' in --stdio, --tui and --gtk, from Namhyung Kim. - Add support for AMD NB and L2I "uncore" counters, by Jacob Shin. - Add Ivy Bridge-EP uncore support, by Zheng Yan - IBM zEnterprise EC12 oprofile support patchlet from Robert Richter. - Add perf test entries for checking breakpoint overflow signal handler issues, from Jiri Olsa. - Add perf test entry for for checking number of EXIT events, from Namhyung Kim. - Add perf test entries for checking --cpu in record and stat, from Jiri Olsa. - Introduce perf stat --repeat forever, from Frederik Deweerdt. - Add --no-demangle to report/top, from Namhyung Kim. - PowerPC fixes plus a couple of cleanups/optimizations in uprobes and trace_uprobes, by Oleg Nesterov. Various fixes and refactorings: - Fix dependency of the python binding wrt libtraceevent, from Naohiro Aota. - Simplify some perf_evlist methods and to allow 'stat' to share code with 'record' and 'trace', by Arnaldo Carvalho de Melo. - Remove dead code in related to libtraceevent integration, from Namhyung Kim. - Revert "perf sched: Handle PERF_RECORD_EXIT events" to get 'perf sched lat' back working, by Arnaldo Carvalho de Melo - We don't use Newt anymore, just plain libslang, by Arnaldo Carvalho de Melo. - Kill a bunch of die() calls, from Namhyung Kim. - Fix build on non-glibc systems due to libio.h absence, from Cody P Schafer. - Remove some perf_session and tracing dead code, from David Ahern. - Honor parallel jobs, fix from Borislav Petkov - Introduce tools/lib/lk library, initially just removing duplication among tools/perf and tools/vm. from Borislav Petkov ... and many more I missed to list, see the shortlog and git log for more details." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (136 commits) perf/x86/intel/P4: Robistify P4 PMU types perf/x86/amd: Fix AMD NB and L2I "uncore" support perf/x86/amd: Remove old-style NB counter support from perf_event_amd.c perf/x86: Check all MSRs before passing hw check perf/x86/amd: Add support for AMD NB and L2I "uncore" counters perf/x86/intel: Add Ivy Bridge-EP uncore support perf/x86/intel: Fix SNB-EP CBO and PCU uncore PMU filter management perf/x86: Avoid kfree() in CPU_{STARTING,DYING} uprobes/perf: Avoid perf_trace_buf_prepare/submit if ->perf_events is empty uprobes/tracing: Don't pass addr=ip to perf_trace_buf_submit() uprobes/tracing: Change create_trace_uprobe() to support uretprobes uprobes/tracing: Make seq_printf() code uretprobe-friendly uprobes/tracing: Make register_uprobe_event() paths uretprobe-friendly uprobes/tracing: Make uprobe_{trace,perf}_print() uretprobe-friendly uprobes/tracing: Introduce is_ret_probe() and uretprobe_dispatcher() uprobes/tracing: Introduce uprobe_{trace,perf}_print() helpers uprobes/tracing: Generalize struct uprobe_trace_entry_head uprobes/tracing: Kill the pointless local_save_flags/preempt_count calls uprobes/tracing: Kill the pointless seq_print_ip_sym() call uprobes/tracing: Kill the pointless task_pt_regs() calls ...
2013-04-29Merge tag 'ktest-v3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull ktest update from Steven Rostedt: "A couple of fixes to handle a config file that tests multiple machines and has conflicts it the grub menus. That is, if the machines use the same grub menu name, but they are at different locations in the menu.lst file" * tag 'ktest-v3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Reset grub menu cache with different machines ktest: Allow tests to use different GRUB_MENUs
2013-04-29Merge tag 'char-misc-3.10-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver update from Greg Kroah-Hartman: "Here's the big char / misc driver update for 3.10-rc1 A number of various driver updates, the majority being new functionality in the MEI driver subsystem (it's now a subsystem, it started out just a single driver), extcon updates, memory updates, hyper-v updates, and a bunch of other small stuff that doesn't fit in any other tree. All of these have been in linux-next for a while" * tag 'char-misc-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (148 commits) Tools: hv: Fix a checkpatch warning tools: hv: skip iso9660 mounts in hv_vss_daemon tools: hv: use FIFREEZE/FITHAW in hv_vss_daemon tools: hv: use getmntent in hv_vss_daemon Tools: hv: Fix a checkpatch warning tools: hv: fix checks for origin of netlink message in hv_vss_daemon Tools: hv: fix warnings in hv_vss_daemon misc: mark spear13xx-pcie-gadget as broken mei: fix krealloc() misuse in in mei_cl_irq_read_msg() mei: reduce flow control only for completed messages mei: reseting -> resetting mei: fix reading large reposnes mei: revamp mei_irq_read_client_message function mei: revamp mei_amthif_irq_read_message mei: revamp hbm state machine Revert "drivers/scsi: use module_pcmcia_driver() in pcmcia drivers" Revert "scsi: pcmcia: nsp_cs: remove module init/exit function prototypes" scsi: pcmcia: nsp_cs: remove module init/exit function prototypes mei: wd: fix line over 80 characters misc: tsl2550: Use dev_pm_ops ...
2013-04-29selftests: psock_tpacket: fix status checkDaniel Borkmann
Testing like this for TP_STATUS_AVAILABLE clearly is a stupid bug since it always returns true. Fix this by only checking for flags where the kernel owns the packet and negate this result, since we also could run into the non-zero status TP_STATUS_WRONG_FORMAT and need to reclaim frames. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-24ktest: Reset grub menu cache with different machinesSteven Rostedt (Red Hat)
Different tests may use a different machine. In such cases, we need to try to get the current grub menu index. If the same grub menu is used for two different machines, it may not be at the same index on the second machine. A search for the index must be performed again. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-04-24Tools: hv: Fix a checkpatch warningK. Y. Srinivasan
Fix a checkpatch warning. Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-24tools: hv: skip iso9660 mounts in hv_vss_daemonOlaf Hering
fsreeze does not work for iso9660 filesystems. A ENOSUPP may be caught in the freeze case, but the subsequent thaw call would fail and leads to a false error. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-24tools: hv: use FIFREEZE/FITHAW in hv_vss_daemonOlaf Hering
As suggested by Paolo Bonzini, use ioctl instead of calling fsfreeze. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-24tools: hv: use getmntent in hv_vss_daemonOlaf Hering
As suggested by Paolo Bonzini, use getmntent instead of parsing output of mount(1). Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-24tools: hv: fix checks for origin of netlink message in hv_vss_daemonOlaf Hering
Similar to what commit 95a69adab9acfc3981c504737a2b6578e4d846ef ("tools: hv: Netlink source address validation allows DoS") does in hv_kvp_daemon, improve checks for origin of netlink connector message. Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-24Tools: hv: fix warnings in hv_vss_daemonOlaf Hering
This change fixes a few compile errors: hv_vss_daemon.c:64:15: warning: unknown escape sequence '\/' hv_vss_daemon.c:64:15: warning: unknown escape sequence '\/' hv_vss_daemon.c: In function 'vss_operate': hv_vss_daemon.c:66: warning: 'return' with no value, in function returning non-void hv_vss_daemon.c: In function 'main': hv_vss_daemon.c:130: warning: ignoring return value of 'daemon', declared with attribute warn_unused_result hv_vss_daemon.c: In function 'vss_operate': hv_vss_daemon.c:47: warning: 'fs_op' may be used uninitialized in this function Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: K. Y. Srinivasan <kys@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netDavid S. Miller
Conflicts: drivers/net/ethernet/emulex/benet/be_main.c drivers/net/ethernet/intel/igb/igb_main.c drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c include/net/scm.h net/batman-adv/routing.c net/ipv4/tcp_input.c The e{uid,gid} --> {uid,gid} credentials fix conflicted with the cleanup in net-next to now pass cred structs around. The be2net driver had a bug fix in 'net' that overlapped with the VLAN interface changes by Patrick McHardy in net-next. An IGB conflict existed because in 'net' the build_skb() support was reverted, and in 'net-next' there was a comment style fix within that code. Several batman-adv conflicts were resolved by making sure that all calls to batadv_is_my_mac() are changed to have a new bat_priv first argument. Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO rewrite in 'net-next', mostly overlapping changes. Thanks to Stephen Rothwell and Antonio Quartulli for help with several of these merge resolutions. Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-19net: Add .gitignore to networking selftests directory.David S. Miller
2013-04-17tools/power turbostat: display C8, C9, C10 residencyKristen Carlson Accardi
Display residency in the new C-states, C8, C9, C10. C8, C9, C10 are present on some: "Fourth Generation Intel(R) Core(TM) Processors", which are based on Intel(R) microarchitecture code name Haswell. Signed-off-by: Kristen Carlson Accardi <kristen@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2013-04-17Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull idle patches from Len Brown: "A pair of small patches for 3.9-rc7. This CPU-id should have been included in the ones that we updated earlier in 3.9. This pair of patches will allow this flavor of Haswell to behave like the other flavors." * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: tools/power turbostat: additional Haswell CPU-id intel_idle: additional Haswell CPU-id
2013-04-12treewide: Fix typo in printksMasanari Iida
Correct spelling typos in printk and comments. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-04-07selftests: net: add PF_PACKET TPACKET v1/v2/v3 selftestsDaniel Borkmann
This patch adds a simple test case that probes the packet socket's TPACKET_V1, TPACKET_V2 and TPACKET_V3 behavior regarding mmap(2)'ed I/O for a small burst of 100 packets. The test currently runs for ... TPACKET_V1: RX_RING, TX_RING TPACKET_V2: RX_RING, TX_RING TPACKET_V3: RX_RING ... and will output on success: test: TPACKET_V1 with PACKET_RX_RING .................... 100 pkts (9600 bytes) test: TPACKET_V1 with PACKET_TX_RING .................... 100 pkts (9600 bytes) test: TPACKET_V2 with PACKET_RX_RING .................... 100 pkts (9600 bytes) test: TPACKET_V2 with PACKET_TX_RING .................... 100 pkts (9600 bytes) test: TPACKET_V3 with PACKET_RX_RING .................... 100 pkts (9600 bytes) OK. All tests passed Reusable parts of psock_fanout.c have been put into a psock_lib.h file for common usage. Test case successfully tested on x86_64. Signed-off-by: Daniel Borkmann <dborkman@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-04-01perf map browser: Exit just on well known key pressesArnaldo Carvalho de Melo
Initial motivation was to avoid the confusing exit when when '/' is pressed in non verbose mode, as specified in the help line searches are only available in verbose mode. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-20xezxim2y4agmkx7f3sucll@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-04-01perf tools: Remove dependency on libnewtArnaldo Carvalho de Melo
Now that the map browser shares the input routine with the hists browser, there is no need for using any libnewt routine, so remove all traces except for honouring NO_NEWT=1 on the makefile command line as an indication that TUI support is not needed, in fact it just sets NO_SLANG=1. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-wae5o7xca9m52bj1re28jc5j@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-04-01perf map browser: Use ui_browser__input_window()Arnaldo Carvalho de Melo
Instead of an ad-hoc, libnewt based equivalent. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-elrijp95pijt66y6mmij4xm1@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-04-01perf python: Fix dependency for python/perf.soNaohiro Aota
The python/perf.so binding lacks dependency for libtraceevent.a so that it cause the following error building python/perf.so. This patch introduce the dependency for it. $ make python/perf.so CHK -fstack-protector-all CHK -Wstack-protector CHK -Wvolatile-register-var CHK -D_FORTIFY_SOURCE=2 CHK bionic CHK libelf CHK libdw CHK libunwind CHK -DLIBELF_MMAP CHK libaudit CHK libnewt CHK gtk2 CHK -DHAVE_GTK_INFO_BAR CHK perl CHK python CHK python version CHK libbfd CHK -DHAVE_STRLCPY CHK -DHAVE_ON_EXIT CHK -DBACKTRACE_SUPPORT CHK libnuma GEN python/perf.so x86_64-pc-linux-gnu-gcc: error: ../lib/traceevent/libtraceevent.a: No such file or directory error: command 'x86_64-pc-linux-gnu-gcc' failed with exit status 1 cp: cannot stat 'python_ext_build/lib/perf.so': No such file or directory make: *** [python/perf.so] Error 1 Signed-off-by: Naohiro Aota <naota@elisp.net> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/87wqswzznx.fsf@locke.i-did-not-set--mail-host-address--so-tickle-me Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-04-01perf tools: Convert needless static variable to localArnaldo Carvalho de Melo
Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-k85ajz97xbrd8fkt2a8pp7q1@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
