path: root/virt/kvm/iommu.c
2012-01-23iommu/core: split mapping to page sizes as supported by the hardwareOhad Ben-Cohen
When mapping a memory region, split it to page sizes as supported by the iommu hardware. Always prefer bigger pages, when possible, in order to reduce the TLB pressure. The logic to do that is now added to the IOMMU core, so neither the iommu drivers themselves nor users of the IOMMU API have to duplicate it. This allows a more lenient granularity of mappings; traditionally the IOMMU API took 'order' (of a page) as a mapping size, and directly let the low level iommu drivers handle the mapping, but now that the IOMMU core can split arbitrary memory regions into pages, we can remove this limitation, so users don't have to split those regions by themselves. Currently the supported page sizes are advertised once and they then remain static. That works well for OMAP and MSM but it would probably not fly well with intel's hardware, where the page size capabilities seem to have the potential to be different between several DMA remapping devices. register_iommu() currently sets a default pgsize behavior, so we can convert the IOMMU drivers in subsequent patches. After all the drivers are converted, the temporary default settings will be removed. Mainline users of the IOMMU API (kvm and omap-iovmm) are adopted to deal with bytes instead of page order. Many thanks to Joerg Roedel <Joerg.Roedel@amd.com> for significant review! Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Cc: David Brown <davidb@codeaurora.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Joerg Roedel <Joerg.Roedel@amd.com> Cc: Stepan Moskovchenko <stepanm@codeaurora.org> Cc: KyongHo Cho <pullip.cho@samsung.com> Cc: Hiroshi DOYU <hdoyu@nvidia.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: kvm@vger.kernel.org Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-01-23iommu/core: Convert iommu_found to iommu_presentJoerg Roedel
With per-bus iommu_ops the iommu_found function needs to work on a bus_type too. This patch adds a bus_type parameter to that function and converts all call-places. The function is also renamed to iommu_present because the function now checks if an iommu is present for a given bus and does not check for a global iommu anymore. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-01-23iommu/core: Add bus_type parameter to iommu_domain_allocJoerg Roedel
This is necessary to store a pointer to the bus-specific iommu_ops in the iommu-domain structure. It will be used later to call into bus-specific iommu-ops. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Conflicts: drivers/iommu/iommu.c Change-Id: Iddbd561739552b663a4be293f1992314eb0f775a
2011-07-24KVM: IOMMU: Disable device assignment without interrupt remappingAlex Williamson
IOMMU interrupt remapping support provides a further layer of isolation for device assignment by preventing arbitrary interrupt block DMA writes by a malicious guest from reaching the host. By default, we should require that the platform provides interrupt remapping support, with an opt-in mechanism for existing behavior. Both AMD IOMMU and Intel VT-d2 hardware support interrupt remapping, however we currently only have software support on the Intel side. Users wishing to re-enable device assignment when interrupt remapping is not supported on the platform can use the "allow_unsafe_assigned_interrupts=1" module option. [avi: break long lines] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-02KVM: Use u64 for frame data typesJoerg Roedel
For 32bit machines where the physical address width is larger than the virtual address width the frame number types in KVM may overflow. Fix this by changing them to u64. [sfr: fix build on 32-bit ppc] Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Fix IOMMU memslot reference warningSheng Yang
This patch fixes the following warning. =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- include/linux/kvm_host.h:259 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 no locks held by qemu-system-x86/29679. stack backtrace: Pid: 29679, comm: qemu-system-x86 Not tainted 2.6.35-rc3+ #200 Call Trace: [<ffffffff810a224e>] lockdep_rcu_dereference+0xa8/0xb1 [<ffffffffa018a06f>] kvm_iommu_unmap_memslots+0xc9/0xde [kvm] [<ffffffffa018a0c4>] kvm_iommu_unmap_guest+0x40/0x4e [kvm] [<ffffffffa018f772>] kvm_arch_destroy_vm+0x1a/0x186 [kvm] [<ffffffffa01800d0>] kvm_put_kvm+0x110/0x167 [kvm] [<ffffffffa0180ecc>] kvm_vcpu_release+0x18/0x1c [kvm] [<ffffffff81156f5d>] fput+0x22a/0x3a0 [<ffffffff81152288>] filp_close+0xb4/0xcd [<ffffffff8106599f>] put_files_struct+0x1b7/0x36b [<ffffffff81065830>] ? put_files_struct+0x48/0x36b [<ffffffff8131ee59>] ? do_raw_spin_unlock+0x118/0x160 [<ffffffff81065bc0>] exit_files+0x6d/0x75 [<ffffffff81068348>] do_exit+0x47d/0xc60 [<ffffffff8177e7b5>] ? _raw_spin_unlock_irq+0x30/0x36 [<ffffffff81068bfa>] do_group_exit+0xcf/0x134 [<ffffffff81080790>] get_signal_to_deliver+0x732/0x81d [<ffffffff81095996>] ? cpu_clock+0x4e/0x60 [<ffffffff81002082>] do_notify_resume+0x117/0xc43 [<ffffffff810a2fa3>] ? trace_hardirqs_on+0xd/0xf [<ffffffff81080d79>] ? sys_rt_sigtimedwait+0x2b5/0x3bf [<ffffffff8177d9f2>] ? trace_hardirqs_off_thunk+0x3a/0x3c [<ffffffff81003221>] ? sysret_signal+0x5/0x3d [<ffffffff8100343b>] int_signal+0x12/0x17 Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Update Red Hat copyrightsAvi Kivity
2010-06-09KVM: Fix order passed to iommu_unmapJan Kiszka
This is obviously a left-over from the the old interface taking the size. Apparently a mostly harmless issue with the current iommu_unmap implementation. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-05-21Merge branch 'kvm-updates/2.6.35' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.35' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (269 commits) KVM: x86: Add missing locking to arch specific vcpu ioctls KVM: PPC: Add missing vcpu_load()/vcpu_put() in vcpu ioctls KVM: MMU: Segregate shadow pages with different cr0.wp KVM: x86: Check LMA bit before set_efer KVM: Don't allow lmsw to clear cr0.pe KVM: Add cpuid.txt file KVM: x86: Tell the guest we'll warn it about tsc stability x86, paravirt: don't compute pvclock adjustments if we trust the tsc x86: KVM guest: Try using new kvm clock msrs KVM: x86: export paravirtual cpuid flags in KVM_GET_SUPPORTED_CPUID KVM: x86: add new KVMCLOCK cpuid feature KVM: x86: change msr numbers for kvmclock x86, paravirt: Add a global synchronization point for pvclock x86, paravirt: Enable pvclock flags in vcpu_time_info structure KVM: x86: Inject #GP with the right rip on efer writes KVM: SVM: Don't allow nested guest to VMMCALL into host KVM: x86: Fix exception reinjection forced to true KVM: Fix wallclock version writing race KVM: MMU: Don't read pdptrs with mmu spinlock held in mmu_alloc_roots KVM: VMX: enable VMXON check with SMX enabled (Intel TXT) ...
2010-05-17KVM: use the correct RCU API for PROVE_RCU=yLai Jiangshan
The RCU/SRCU API have already changed for proving RCU usage. I got the following dmesg when PROVE_RCU=y because we used incorrect API. This patch coverts rcu_deference() to srcu_dereference() or family API. =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- arch/x86/kvm/mmu.c:3020 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by qemu-system-x86/8550: #0: (&kvm->slots_lock){+.+.+.}, at: [<ffffffffa011a6ac>] kvm_set_memory_region+0x29/0x50 [kvm] #1: (&(&kvm->mmu_lock)->rlock){+.+...}, at: [<ffffffffa012262d>] kvm_arch_commit_memory_region+0xa6/0xe2 [kvm] stack backtrace: Pid: 8550, comm: qemu-system-x86 Not tainted 2.6.34-rc4-tip-01028-g939eab1 #27 Call Trace: [<ffffffff8106c59e>] lockdep_rcu_dereference+0xaa/0xb3 [<ffffffffa012f6c1>] kvm_mmu_calculate_mmu_pages+0x44/0x7d [kvm] [<ffffffffa012263e>] kvm_arch_commit_memory_region+0xb7/0xe2 [kvm] [<ffffffffa011a5d7>] __kvm_set_memory_region+0x636/0x6e2 [kvm] [<ffffffffa011a6ba>] kvm_set_memory_region+0x37/0x50 [kvm] [<ffffffffa015e956>] vmx_set_tss_addr+0x46/0x5a [kvm_intel] [<ffffffffa0126592>] kvm_arch_vm_ioctl+0x17a/0xcf8 [kvm] [<ffffffff810a8692>] ? unlock_page+0x27/0x2c [<ffffffff810bf879>] ? __do_fault+0x3a9/0x3e1 [<ffffffffa011b12f>] kvm_vm_ioctl+0x364/0x38d [kvm] [<ffffffff81060cfa>] ? up_read+0x23/0x3d [<ffffffff810f3587>] vfs_ioctl+0x32/0xa6 [<ffffffff810f3b19>] do_vfs_ioctl+0x495/0x4db [<ffffffff810e6b2f>] ? fget_light+0xc2/0x241 [<ffffffff810e416c>] ? do_sys_open+0x104/0x116 [<ffffffff81382d6d>] ? retint_swapgs+0xe/0x13 [<ffffffff810f3ba6>] sys_ioctl+0x47/0x6a [<ffffffff810021db>] system_call_fastpath+0x16/0x1b Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-03-07kvm: Change kvm_iommu_map_pages to map large pagesJoerg Roedel
This patch changes the implementation of of kvm_iommu_map_pages to map the pages with the host page size into the io virtual address space. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Acked-By: Avi Kivity <avi@redhat.com>
2010-03-01KVM: enable PCI multiple-segments for pass-through deviceZhai, Edwin
Enable optional parameter (default 0) - PCI segment (or domain) besides BDF, when assigning PCI device to guest. Signed-off-by: Zhai Edwin <edwin.zhai@intel.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: introduce kvm->srcu and convert kvm_set_memory_region to SRCU updateMarcelo Tosatti
Use two steps for memslot deletion: mark the slot invalid (which stops instantiation of new shadow pages for that slot, but allows destruction), then instantiate the new empty slot. Also simplifies kvm_handle_hva locking. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: use gfn_to_pfn_memslot in kvm_iommu_map_pagesMarcelo Tosatti
So its possible to iommu map a memslot before making it visible to kvm. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-03-01KVM: modify memslots layout in struct kvmMarcelo Tosatti
Have a pointer to an allocated region inside struct kvm. [alex: fix ppc book 3s] Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2009-06-10KVM: Enable snooping control for supported hardwareSheng Yang
Memory aliases with different memory type is a problem for guest. For the guest without assigned device, the memory type of guest memory would always been the same as host(WB); but for the assigned device, some part of memory may be used as DMA and then set to uncacheable memory type(UC/WC), which would be a conflict of host memory type then be a potential issue. Snooping control can guarantee the cache correctness of memory go through the DMA engine of VT-d. [avi: fix build on ia64] Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-02-15KVM: Fix assigned devices circular locking dependencyMark McLoughlin
kvm->slots_lock is outer to kvm->lock, so take slots_lock in kvm_vm_ioctl_assign_device() before taking kvm->lock, rather than taking it in kvm_iommu_map_memslots(). Cc: stable@kernel.org Signed-off-by: Mark McLoughlin <markmc@redhat.com> Acked-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-01-03kvm/iommu: fix compile warningJoerg Roedel
This fixes a compile warning about a variable thats maybe used uninitialized in the function. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2009-01-03KVM: change KVM to use IOMMU APIJoerg Roedel
2009-01-03KVM: rename vtd.c to iommu.cJoerg Roedel
Impact: file renamed The code in the vtd.c file can be reused for other IOMMUs as well. So rename it to make it clear that it handle more than VT-d. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
