Introduce hva_to_pfn_atomic(), it's the fast path and can used in atomic
context, the later patch will use it
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
If there are active VCPUs which are marked as belonging to
a particular hardware CPU, request a clock sync for them when
enabling hardware; the TSC could be desynchronized on a newly
arriving CPU, and we need to recompute guests system time
relative to boot after a suspend event.
This covers both cases.
Note that it is acceptable to take the spinlock, as either
no other tasks will be running and no locks held (BSP after
resume), or other tasks will be guaranteed to drop the lock
relatively quickly (AP on CPU_STARTING).
Noting we now get clock synchronization requests for VCPUs
which are starting up (or restarting), it is tempting to
attempt to remove the arch/x86/kvm/x86.c CPU hot-notifiers
at this time, however it is not correct to do so; they are
required for systems with non-constant TSC as the frequency
may not be known immediately after the processor has started
until the cpufreq driver has had a chance to run and query
the chipset.
Updated: implement better locking semantics for hardware_enable
Removed the hack of dropping and retaking the lock by adding the
semantic that we always hold kvm_lock when hardware_enable is
called. The one place that doesn't need to worry about it is
resume, as resuming a frozen CPU, the spinlock won't be taken.
Signed-off-by: Zachary Amsden <zamsden@redhat.com>
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
When we reboot, we disable vmx extensions or otherwise INIT gets blocked.
If a task on another cpu hits a vmx instruction, it will fault if vmx is
disabled. We trap that to avoid a nasty oops and spin until the reboot
completes.
Problem is, we sleep with interrupts disabled. This blocks smp_send_stop()
from running, and the reboot process halts.
Fix by enabling interrupts before spinning.
KVM-Stable-Tag.
Signed-off-by: Avi Kivity <avi@redhat.com>
The CPU_STARTING callback was added upstream with the intention
of being used for KVM, specifically for the hardware enablement
that must be done before we can run in hardware virt. It had
bugs on the x86_64 architecture at the time, where it was called
after CPU_ONLINE. The arches have since merged and the bug is
gone.
It might be noted other features should probably start making
use of this callback; microcode updates in particular which
might be fixing important erratums would be best applied before
beginning to run user tasks.
Currently if guest access address that belongs to memory slot but is not
backed up by page or page is read only KVM treats it like MMIO access.
Remove that capability. It was never part of the interface and should
not be relied upon.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
They are not used outside of the file.
This patch converts unnecessary divide and modulo operations
in the KVM large page related code into logical operations.
This allows to convert gfn_t to u64 while not breaking 32
bit builds.
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
is_hwpoison_address accesses the page table, so the caller must hold
current->mm->mmap_sem in read mode. So fix its usage in hva_to_pfn of
kvm accordingly.
Comment is_hwpoison_address to remind other users.
Reported-by: Avi Kivity <avi@redhat.com>
Signed-off-by: Huang Ying <ying.huang@intel.com>
May be used for distinguishing between internal and user slots, or for sorting
slots in size order.
Makes it a little more readable and hackable.
As advertised in feature-removal-schedule.txt. Equivalent support is provided
by overlapping memory regions.
When the user passed in a NULL mask pass this on from the ioctl
handler.
Found by gcc 4.6's new warnings.
The type of '*new.rmap' is not 'struct page *', fix it
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Now that all arch specific ioctls have centralized locking, it is easy to
move it to the central dispatcher.
All vcpu ioctls need to be locked, so instead of locking each one specifically
we lock at the generic dispatcher.
This patch only updates generic ioctls and leaves arch specific ioctls alone.
In common cases, guest SRAO MCE will cause corresponding poisoned page
be un-mapped and SIGBUS be sent to QEMU-KVM, then QEMU-KVM will relay
the MCE to guest OS.
But it is reported that if the poisoned page is accessed in guest
after unmapping and before MCE is relayed to guest OS, userspace will
be killed.
The reason is as follows. Because poisoned page has been un-mapped,
guest access will cause guest exit and kvm_mmu_page_fault will be
called. kvm_mmu_page_fault can not get the poisoned page for fault
address, so kernel and user space MMIO processing is tried in turn. In
user MMIO processing, poisoned page is accessed again, then userspace
is killed by force_sig_info.
To fix the bug, kvm_mmu_page_fault send HWPOISON signal to QEMU-KVM
and do not try kernel and user space MMIO processing for poisoned
page.
[xiao: fix warning introduced by avi]
Reported-by: Max Asbock <masbock@linux.vnet.ibm.com>
vmx and svm vcpus have different contents and therefore may have different
alignmment requirements. Let each specify its required alignment.
As Avi pointed out, testing bit part in mark_page_dirty() was important
in the days of shadow paging, but currently EPT and NPT has already become
common and the chance of faulting a page more that once per iteration is
small. So let's remove the test bit to avoid extra access.
Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
When CPU_UP_CANCELED, hardware_enable() has not been called at the CPU
which is going up because raw_notifier_call_chain(CPU_ONLINE)
has not been called for this cpu.
Drop the handling for CPU_UP_CANCELED.
The RCU/SRCU API have already changed for proving RCU usage.
I got the following dmesg when PROVE_RCU=y because we used incorrect API.
This patch coverts rcu_deference() to srcu_dereference() or family API.
[ INFO: suspicious rcu_dereference_check() usage. ]
arch/x86/kvm/mmu.c:3020 invoked rcu_dereference_check() without protection!
rcu_scheduler_active = 1, debug_locks = 0
2 locks held by qemu-system-x86/8550:
#0: (&kvm->slots_lock){+.+.+.}, at: [<ffffffffa011a6ac>] kvm_set_memory_region+0x29/0x50 [kvm]
#1: (&(&kvm->mmu_lock)->rlock){+.+...}, at: [<ffffffffa012262d>] kvm_arch_commit_memory_region+0xa6/0xe2 [kvm]
stack backtrace:
Pid: 8550, comm: qemu-system-x86 Not tainted 2.6.34-rc4-tip-01028-g939eab1 #27
Call Trace:
[<ffffffff8106c59e>] lockdep_rcu_dereference+0xaa/0xb3
[<ffffffffa012f6c1>] kvm_mmu_calculate_mmu_pages+0x44/0x7d [kvm]
[<ffffffffa012263e>] kvm_arch_commit_memory_region+0xb7/0xe2 [kvm]
[<ffffffffa011a5d7>] __kvm_set_memory_region+0x636/0x6e2 [kvm]
[<ffffffffa011a6ba>] kvm_set_memory_region+0x37/0x50 [kvm]
[<ffffffffa015e956>] vmx_set_tss_addr+0x46/0x5a [kvm_intel]
[<ffffffffa0126592>] kvm_arch_vm_ioctl+0x17a/0xcf8 [kvm]
[<ffffffff810a8692>] ? unlock_page+0x27/0x2c
[<ffffffff810bf879>] ? __do_fault+0x3a9/0x3e1
[<ffffffffa011b12f>] kvm_vm_ioctl+0x364/0x38d [kvm]
[<ffffffff81060cfa>] ? up_read+0x23/0x3d
[<ffffffff810f3587>] vfs_ioctl+0x32/0xa6
[<ffffffff810f3b19>] do_vfs_ioctl+0x495/0x4db
[<ffffffff810e6b2f>] ? fget_light+0xc2/0x241
[<ffffffff810e416c>] ? do_sys_open+0x104/0x116
[<ffffffff81382d6d>] ? retint_swapgs+0xe/0x13
[<ffffffff810f3ba6>] sys_ioctl+0x47/0x6a
[<ffffffff810021db>] system_call_fastpath+0x16/0x1b
This patch limits the number of pages per memory slot to make
us free from extra care about type issues.
kvm_coalesced_mmio_init() keeps to hold the addresses of a coalesced
mmio ring page and dev even after it has freed them.
Also, if this function fails, though it might be rare, it seems to be
suggesting the system's serious state: so we'd better stop the works
following the kvm_creat_vm().
This patch clears these problems.
We move the coalesced mmio's initialization out of kvm_create_vm().
This seems to be natural because it includes a registration which
can be done only when vm is successfully created.
This patch change the errno of ioctl KVM_[UN]REGISTER_COALESCED_MMIO
from -EINVAL to -ENXIO if no coalesced mmio dev exists.
Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com>
This patch does:
- no need call tracepoint_synchronize_unregister() when kvm module
is unloaded since ftrace can handle it
- cleanup ftrace's macro
Marcelo introduced gfn_to_hva_memslot() when he implemented
gfn_to_pfn_memslot(). Let's use this for gfn_to_hva() too.
Note: also remove parentheses next to return as checkpatch said to do.
I got this dmesg due to srcu_read_lock() is missing in
kvm_mmu_notifier_release().
arch/x86/kvm/x86.h:72 invoked rcu_dereference_check() without protection!
2 locks held by qemu-system-x86/3100:
#0: (rcu_read_lock){.+.+..}, at: [<ffffffff810d73dc>] __mmu_notifier_release+0x38/0xdf
#1: (&(&kvm->mmu_lock)->rlock){+.+...}, at: [<ffffffffa0130a6a>] kvm_mmu_zap_all+0x21/0x5e [kvm]
stack backtrace:
Pid: 3100, comm: qemu-system-x86 Not tainted 2.6.34-rc3-22949-gbc8a97a-dirty #2
Call Trace:
[<ffffffff8106afd9>] lockdep_rcu_dereference+0xaa/0xb3
[<ffffffffa0123a89>] unalias_gfn+0x56/0xab [kvm]
[<ffffffffa0119600>] gfn_to_memslot+0x16/0x25 [kvm]
[<ffffffffa012ffca>] gfn_to_rmap+0x17/0x6e [kvm]
[<ffffffffa01300c1>] rmap_remove+0xa0/0x19d [kvm]
[<ffffffffa0130649>] kvm_mmu_zap_page+0x109/0x34d [kvm]
[<ffffffffa0130a7e>] kvm_mmu_zap_all+0x35/0x5e [kvm]
[<ffffffffa0122870>] kvm_arch_flush_shadow+0x16/0x22 [kvm]
[<ffffffffa01189e0>] kvm_mmu_notifier_release+0x15/0x17 [kvm]
[<ffffffff810d742c>] __mmu_notifier_release+0x88/0xdf
[<ffffffff810d73dc>] ? __mmu_notifier_release+0x38/0xdf
[<ffffffff81040848>] ? exit_mm+0xe0/0x115
[<ffffffff810c2cb0>] exit_mmap+0x2c/0x17e
[<ffffffff8103c472>] mmput+0x2d/0xd4
[<ffffffff81040870>] exit_mm+0x108/0x115
Int is not long enough to store the size of a dirty bitmap.
This patch fixes this problem with the introduction of a wrapper
function to calculate the sizes of dirty bitmaps.
Note: in mark_page_dirty(), we have to consider the fact that
__set_bit() takes the offset as int, not long.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The code relies on kvm->requests_lock inhibiting preemption.
Noted by Jan Kiszka.
This patch introduces a generic function to find out the
host page size for a given gfn. This function is needed by
the kvm iommu code. This patch also simplifies the x86
host_mapping_level function.
The commit 0953ca73 "KVM: Simplify coalesced mmio initialization"
allocate kvm_coalesced_mmio_ring in the kvm_coalesced_mmio_init(), but
didn't discard the original allocation...
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
cleanup_srcu_struct on VM destruction remains broken:
BUG: unable to handle kernel paging request at ffffffffffffffff
IP: [<ffffffff802533d2>] srcu_read_lock+0x16/0x21
RIP: 0010:[<ffffffff802533d2>] [<ffffffff802533d2>] srcu_read_lock+0x16/0x21
Call Trace:
[<ffffffffa05354c4>] kvm_arch_vcpu_uninit+0x1b/0x48 [kvm]
[<ffffffffa05339c6>] kvm_vcpu_uninit+0x9/0x15 [kvm]
[<ffffffffa0569f7d>] vmx_free_vcpu+0x7f/0x8f [kvm_intel]
[<ffffffffa05357b5>] kvm_arch_destroy_vm+0x78/0x111 [kvm]
[<ffffffffa053315b>] kvm_put_kvm+0xd4/0xfe [kvm]
Move it to kvm_arch_destroy_vm.
Reported-by: Jan Kiszka <jan.kiszka@siemens.com>
Using a similar two-step procedure as for memslots.
Use two steps for memslot deletion: mark the slot invalid (which stops
instantiation of new shadow pages for that slot, but allows destruction),
then instantiate the new empty slot.
Also simplifies kvm_handle_hva locking.
So its possible to iommu map a memslot before making it visible to
kvm.
Which takes a memslot pointer instead of using kvm->memslots.
To be used by SRCU convertion later.
Required for SRCU convertion later.
Have a pointer to an allocated region inside struct kvm.
[alex: fix ppc book 3s]
- add destructor function
- move related allocation into constructor
- add stubs for !CONFIG_KVM_MMIO
They aren't related.
arch/s390/kvm/../../../virt/kvm/kvm_main.c: In function 'kvm_create_vm':
arch/s390/kvm/../../../virt/kvm/kvm_main.c:409: warning: label 'out_err' defined but not used
One possible order is:
KVM_CREATE_IRQCHIP ioctl(took kvm->lock) -> kvm_iobus_register_dev() ->
down_write(kvm->slots_lock).
The other one is in kvm_vm_ioctl_assign_device(), which take kvm->slots_lock
first, then kvm->lock.
Update the comment of lock order as well.
Observe it due to kernel locking debug warnings.
Cc: stable@kernel.org
It seems a couple places such as arch/ia64/kernel/perfmon.c and
drivers/infiniband/core/uverbs_main.c could use anon_inode_getfile()
instead of a private pseudo-fs + alloc_file(), if only there were a way
to get a read-only file. So provide this by having anon_inode_getfile()
create a read-only file if we pass O_RDONLY in flags.
Signed-off-by: Roland Dreier <rolandd@cisco.com>
include/linux/kvm.h
