path: root/virt/kvm
2011-01-12KVM: Refactor IRQ names of assigned devicesJan Kiszka
Cosmetic change, but it helps to correlate IRQs with PCI devices. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Switch assigned device IRQ forwarding to threaded handlerJan Kiszka
This improves the IRQ forwarding for assigned devices: By using the kernel's threaded IRQ scheme, we can get rid of the latency-prone work queue and simplify the code in the same run. Moreover, we no longer have to hold assigned_dev_lock while raising the guest IRQ, which can be a lenghty operation as we may have to iterate over all VCPUs. The lock is now only used for synchronizing masking vs. unmasking of INTx-type IRQs, thus is renames to intx_lock. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Clear assigned guest IRQ on releaseJan Kiszka
When we deassign a guest IRQ, clear the potentially asserted guest line. There might be no chance for the guest to do this, specifically if we switch from INTx to MSI mode. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Clean up vm creation and releaseJan Kiszka
IA64 support forces us to abstract the allocation of the kvm structure. But instead of mixing this up with arch-specific initialization and doing the same on destruction, split both steps. This allows to move generic destruction calls into generic code. It also fixes error clean-up on failures of kvm_create_vm for IA64. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: Refactor srcu struct release on early errorsJan Kiszka
2011-01-12KVM: fix the race while wakeup all pv guestXiao Guangrong
In kvm_async_pf_wakeup_all(), we add a dummy apf to vcpu->async_pf.done without holding vcpu->async_pf.lock, it will break if we are handling apfs at this time. Also use 'list_empty_careful()' instead of 'list_empty()' Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Acked-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: handle more completed apfs if possibleXiao Guangrong
If it's no need to inject async #PF to PV guest we can handle more completed apfs at one time, so we can retry guest #PF as early as possible Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Acked-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: replace vmalloc and memset with vzallocTakuya Yoshikawa
Let's use newly introduced vzalloc(). Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: get rid of warning within kvm_dev_ioctl_create_vmHeiko Carstens
Fixes this: CC arch/s390/kvm/../../../virt/kvm/kvm_main.o arch/s390/kvm/../../../virt/kvm/kvm_main.c: In function 'kvm_dev_ioctl_create_vm': arch/s390/kvm/../../../virt/kvm/kvm_main.c:1828:10: warning: unused variable 'r' Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: add cast within kvm_clear_guest_page to fix warningHeiko Carstens
Fixes this: CC arch/s390/kvm/../../../virt/kvm/kvm_main.o arch/s390/kvm/../../../virt/kvm/kvm_main.c: In function 'kvm_clear_guest_page': arch/s390/kvm/../../../virt/kvm/kvm_main.c:1224:2: warning: passing argument 3 of 'kvm_write_guest_page' makes pointer from integer without a cast arch/s390/kvm/../../../virt/kvm/kvm_main.c:1185:5: note: expected 'const void *' but argument is of type 'long unsigned int' Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: use kmalloc() for small dirty bitmapsTakuya Yoshikawa
Currently we are using vmalloc() for all dirty bitmaps even if they are small enough, say less than K bytes. We use kmalloc() if dirty bitmap size is less than or equal to PAGE_SIZE so that we can avoid vmalloc area usage for VGA. This will also make the logging start/stop faster. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: pre-allocate one more dirty bitmap to avoid vmalloc()Takuya Yoshikawa
Currently x86's kvm_vm_ioctl_get_dirty_log() needs to allocate a bitmap by vmalloc() which will be used in the next logging and this has been causing bad effect to VGA and live-migration: vmalloc() consumes extra systime, triggers tlb flush, etc. This patch resolves this issue by pre-allocating one more bitmap and switching between two bitmaps during dirty logging. Performance improvement: I measured performance for the case of VGA update by trace-cmd. The result was 1.5 times faster than the original one. In the case of live migration, the improvement ratio depends on the workload and the guest memory size. In general, the larger the memory size is the more benefits we get. Note: This does not change other architectures's logic but the allocation size becomes twice. This will increase the actual memory consumption only when the new size changes the number of pages allocated by vmalloc(). Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: introduce wrapper functions for creating/destroying dirty bitmapsTakuya Yoshikawa
This makes it easy to change the way of allocating/freeing dirty bitmaps. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Fernando Luis Vazquez Cao <fernando@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: x86: trace "exit to userspace" eventGleb Natapov
Add tracepoint for userspace exit. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: propagate fault r/w information to gup(), allow read-only memoryMarcelo Tosatti
As suggested by Andrea, pass r/w error code to gup(), upgrading read fault to writable if host pte allows it. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: improve hva_to_pfn() readabilityGleb Natapov
Improve vma handling code readability in hva_to_pfn() and fix async pf handling code to properly check vma returned by find_vma(). Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Inject asynchronous page fault into a PV guest if page is swapped out.Gleb Natapov
Send async page fault to a PV guest if it accesses swapped out memory. Guest will choose another task to run upon receiving the fault. Allow async page fault injection only when guest is in user mode since otherwise guest may be in non-sleepable context and will not be able to reschedule. Vcpu will be halted if guest will fault on the same page again or if vcpu executes kernel code. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Add PV MSR to enable asynchronous page faults delivery.Gleb Natapov
Guest enables async PF vcpu functionality using this MSR. Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Add memory slot versioning and use it to provide fast guest write interfaceGleb Natapov
Keep track of memslots changes by keeping generation number in memslots structure. Provide kvm_write_guest_cached() function that skips gfn_to_hva() translation if memslots was not changed since previous invocation. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Retry fault before vmentryGleb Natapov
When page is swapped in it is mapped into guest memory only after guest tries to access it again and generate another fault. To save this fault we can map it immediately since we know that guest is going to access the page. Do it only when tdp is enabled for now. Shadow paging case is more complicated. CR[034] and EFER registers should be switched before doing mapping and then switched back. Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Halt vcpu if page it tries to access is swapped outGleb Natapov
If a guest accesses swapped out memory do not swap it in from vcpu thread context. Schedule work to do swapping and put vcpu into halted state instead. Interrupts will still be delivered to the guest and if interrupt will cause reschedule guest will continue to run another task. [avi: remove call to get_user_pages_noio(), nacked by Linus; this makes everything synchrnous again] Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24Merge branch 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.37' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (321 commits) KVM: Drop CONFIG_DMAR dependency around kvm_iommu_map_pages KVM: Fix signature of kvm_iommu_map_pages stub KVM: MCE: Send SRAR SIGBUS directly KVM: MCE: Add MCG_SER_P into KVM_MCE_CAP_SUPPORTED KVM: fix typo in copyright notice KVM: Disable interrupts around get_kernel_ns() KVM: MMU: Avoid sign extension in mmu_alloc_direct_roots() pae root address KVM: MMU: move access code parsing to FNAME(walk_addr) function KVM: MMU: audit: check whether have unsync sps after root sync KVM: MMU: audit: introduce audit_printk to cleanup audit code KVM: MMU: audit: unregister audit tracepoints before module unloaded KVM: MMU: audit: fix vcpu's spte walking KVM: MMU: set access bit for direct mapping KVM: MMU: cleanup for error mask set while walk guest page table KVM: MMU: update 'root_hpa' out of loop in PAE shadow path KVM: x86 emulator: Eliminate compilation warning in x86_decode_insn() KVM: x86: Fix constant type in kvm_get_time_scale KVM: VMX: Add AX to list of registers clobbered by guest switch KVM guest: Move a printk that's using the clock before it's ready KVM: x86: TSC catchup mode ...
2010-10-24KVM: Drop CONFIG_DMAR dependency around kvm_iommu_map_pagesJan Kiszka
We also have to call kvm_iommu_map_pages for CONFIG_AMD_IOMMU. So drop the dependency on Intel IOMMU, kvm_iommu_map_pages will be a nop anyway if CONFIG_IOMMU_API is not defined. KVM-Stable-Tag. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: fix typo in copyright noticeNicolas Kaiser
Fix typo in copyright notice. Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: cpu_relax() during spin waiting for rebootAvi Kivity
It doesn't really matter, but if we spin, we should spin in a more relaxed manner. This way, if something goes wrong at least it won't contribute to global warming. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: MMU: rewrite audit_mappings_page() functionXiao Guangrong
There is a bugs in this function, we call gfn_to_pfn() and kvm_mmu_gva_to_gpa_read() in atomic context(kvm_mmu_audit() is called under the spinlock(mmu_lock)'s protection). This patch fix it by: - introduce gfn_to_pfn_atomic instead of gfn_to_pfn - get the mapping gfn from kvm_mmu_page_get_gfn() And it adds 'notrap' ptes check in unsync/direct sps Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-10-24KVM: MMU: introduce gfn_to_page_many_atomic() functionXiao Guangrong
Introduce this function to get consecutive gfn's pages, it can reduce gup's overload, used by later patch Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: MMU: introduce hva_to_pfn_atomic functionXiao Guangrong
Introduce hva_to_pfn_atomic(), it's the fast path and can used in atomic context, the later patch will use it Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-24KVM: x86: Add clock sync request to hardware enableZachary Amsden
If there are active VCPUs which are marked as belonging to a particular hardware CPU, request a clock sync for them when enabling hardware; the TSC could be desynchronized on a newly arriving CPU, and we need to recompute guests system time relative to boot after a suspend event. This covers both cases. Note that it is acceptable to take the spinlock, as either no other tasks will be running and no locks held (BSP after resume), or other tasks will be guaranteed to drop the lock relatively quickly (AP on CPU_STARTING). Noting we now get clock synchronization requests for VCPUs which are starting up (or restarting), it is tempting to attempt to remove the arch/x86/kvm/x86.c CPU hot-notifiers at this time, however it is not correct to do so; they are required for systems with non-constant TSC as the frequency may not be known immediately after the processor has started until the cpufreq driver has had a chance to run and query the chipset. Updated: implement better locking semantics for hardware_enable Removed the hack of dropping and retaking the lock by adding the semantic that we always hold kvm_lock when hardware_enable is called. The one place that doesn't need to worry about it is resume, as resuming a frozen CPU, the spinlock won't be taken. Signed-off-by: Zachary Amsden <zamsden@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-10-22Merge branch 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: vfs: make no_llseek the default vfs: don't use BKL in default_llseek llseek: automatically add .llseek fop libfs: use generic_file_llseek for simple_attr mac80211: disallow seeks in minstrel debug code lirc: make chardev nonseekable viotape: use noop_llseek raw: use explicit llseek file operations ibmasmfs: use generic_file_llseek spufs: use llseek in all file operations arm/omap: use generic_file_llseek in iommu_debug lkdtm: use generic_file_llseek in debugfs net/wireless: use generic_file_llseek in debugfs drm: use noop_llseek
All file_operations should get a .llseek operation so we can make nonseekable_open the default for future file operations without a .llseek pointer. The three cases that we can automatically detect are no_llseek, seq_lseek and default_llseek. For cases where we can we can automatically prove that the file offset is always ignored, we use noop_llseek, which maintains the current behavior of not returning an error from a seek. New drivers should normally not use noop_llseek but instead use no_llseek and call nonseekable_open at open time. Existing drivers can be converted to do the same when the maintainer knows for certain that no user code relies on calling seek on the device file. The generated code is often incorrectly indented and right now contains comments that clarify for each added line why a specific variant was chosen. In the version that gets submitted upstream, the comments will be gone and I will manually fix the indentation, because there does not seem to be a way to do that using coccinelle. Some amount of new code is currently sitting in linux-next that should get the same modifications, which I will do at the end of the merge window. Many thanks to Julia Lawall for helping me learn to write a semantic patch that does all this. ===== begin semantic patch ===== // This adds an llseek= method to all file operations, // as a preparation for making no_llseek the default. // // The rules are // - use no_llseek explicitly if we do nonseekable_open // - use seq_lseek for sequential files // - use default_llseek if we know we access f_pos // - use noop_llseek if we know we don't access f_pos, // but we still want to allow users to call lseek // @ open1 exists @ identifier nested_open; @@ nested_open(...) { <+... nonseekable_open(...) ...+> } @ open exists@ identifier open_f; identifier i, f; identifier open1.nested_open; @@ int open_f(struct inode *i, struct file *f) { <+... ( nonseekable_open(...) | nested_open(...) ) ...+> } @ read disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ read_no_fpos disable optional_qualifier exists @ identifier read_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off) { ... when != off } @ write @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; expression E; identifier func; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { <+... ( *off = E | *off += E | func(..., off, ...) | E = *off ) ...+> } @ write_no_fpos @ identifier write_f; identifier f, p, s, off; type ssize_t, size_t, loff_t; @@ ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off) { ... when != off } @ fops0 @ identifier fops; @@ struct file_operations fops = { ... }; @ has_llseek depends on fops0 @ identifier fops0.fops; identifier llseek_f; @@ struct file_operations fops = { ... .llseek = llseek_f, ... }; @ has_read depends on fops0 @ identifier fops0.fops; identifier read_f; @@ struct file_operations fops = { ... .read = read_f, ... }; @ has_write depends on fops0 @ identifier fops0.fops; identifier write_f; @@ struct file_operations fops = { ... .write = write_f, ... }; @ has_open depends on fops0 @ identifier fops0.fops; identifier open_f; @@ struct file_operations fops = { ... .open = open_f, ... }; // use no_llseek if we call nonseekable_open //////////////////////////////////////////// @ nonseekable1 depends on !has_llseek && has_open @ identifier fops0.fops; identifier nso ~= "nonseekable_open"; @@ struct file_operations fops = { ... .open = nso, ... +.llseek = no_llseek, /* nonseekable */ }; @ nonseekable2 depends on !has_llseek @ identifier fops0.fops; identifier open.open_f; @@ struct file_operations fops = { ... .open = open_f, ... +.llseek = no_llseek, /* open uses nonseekable */ }; // use seq_lseek for sequential files ///////////////////////////////////// @ seq depends on !has_llseek @ identifier fops0.fops; identifier sr ~= "seq_read"; @@ struct file_operations fops = { ... .read = sr, ... +.llseek = seq_lseek, /* we have seq_read */ }; // use default_llseek if there is a readdir /////////////////////////////////////////// @ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier readdir_e; @@ // any other fop is used that changes pos struct file_operations fops = { ... .readdir = readdir_e, ... +.llseek = default_llseek, /* readdir is present */ }; // use default_llseek if at least one of read/write touches f_pos ///////////////////////////////////////////////////////////////// @ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read.read_f; @@ // read fops use offset struct file_operations fops = { ... .read = read_f, ... +.llseek = default_llseek, /* read accesses f_pos */ }; @ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, ... + .llseek = default_llseek, /* write accesses f_pos */ }; // Use noop_llseek if neither read nor write accesses f_pos /////////////////////////////////////////////////////////// @ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; identifier write_no_fpos.write_f; @@ // write fops use offset struct file_operations fops = { ... .write = write_f, .read = read_f, ... +.llseek = noop_llseek, /* read and write both use no f_pos */ }; @ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier write_no_fpos.write_f; @@ struct file_operations fops = { ... .write = write_f, ... +.llseek = noop_llseek, /* write uses no f_pos */ }; @ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; identifier read_no_fpos.read_f; @@ struct file_operations fops = { ... .read = read_f, ... +.llseek = noop_llseek, /* read uses no f_pos */ }; @ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @ identifier fops0.fops; @@ struct file_operations fops = { ... +.llseek = noop_llseek, /* no read or write fn */ }; ===== End semantic patch ===== Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Julia Lawall <julia@diku.dk> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-23KVM: Fix reboot on Intel hostsAvi Kivity
When we reboot, we disable vmx extensions or otherwise INIT gets blocked. If a task on another cpu hits a vmx instruction, it will fault if vmx is disabled. We trap that to avoid a nasty oops and spin until the reboot completes. Problem is, we sleep with interrupts disabled. This blocks smp_send_stop() from running, and the reboot process halts. Fix by enabling interrupts before spinning. KVM-Stable-Tag. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-09-23KVM: fix irqfd assign/deassign raceMichael S. Tsirkin
I think I see the following (theoretical) race: During irqfd assign, we drop irqfds lock before we schedule inject work. Therefore, deassign running on another CPU could cause shutdown and flush to run before inject, causing user after free in inject. A simple fix it to schedule inject under the lock. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-09-09KVM: x86: Perform hardware_enable in CPU_STARTING callbackZachary Amsden
The CPU_STARTING callback was added upstream with the intention of being used for KVM, specifically for the hardware enablement that must be done before we can run in hardware virt. It had bugs on the x86_64 architecture at the time, where it was called after CPU_ONLINE. The arches have since merged and the bug is gone. It might be noted other features should probably start making use of this callback; microcode updates in particular which might be fixing important erratums would be best applied before beginning to run user tasks. Signed-off-by: Zachary Amsden <zamsden@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-02KVM: Convert mask notifiers to use irqchip/pin instead of gsiGleb Natapov
Devices register mask notifier using gsi, but irqchip knows about irqchip/pin, so conversion from irqchip/pin to gsi should be done before looking for mask notifier to call. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-02KVM: Return EFAULT from kvm ioctl when guest accesses bad areaGleb Natapov
Currently if guest access address that belongs to memory slot but is not backed up by page or page is read only KVM treats it like MMIO access. Remove that capability. It was never part of the interface and should not be relied upon. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-02KVM: define hwpoison variables staticGleb Natapov
They are not used outside of the file. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-02KVM: Use u64 for frame data typesJoerg Roedel
For 32bit machines where the physical address width is larger than the virtual address width the frame number types in KVM may overflow. Fix this by changing them to u64. [sfr: fix build on 32-bit ppc] Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Remove unnecessary divide operationsJoerg Roedel
This patch converts unnecessary divide and modulo operations in the KVM large page related code into logical operations. This allows to convert gfn_t to u64 while not breaking 32 bit builds. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Fix IOMMU memslot reference warningSheng Yang
This patch fixes the following warning. =================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- include/linux/kvm_host.h:259 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 no locks held by qemu-system-x86/29679. stack backtrace: Pid: 29679, comm: qemu-system-x86 Not tainted 2.6.35-rc3+ #200 Call Trace: [<ffffffff810a224e>] lockdep_rcu_dereference+0xa8/0xb1 [<ffffffffa018a06f>] kvm_iommu_unmap_memslots+0xc9/0xde [kvm] [<ffffffffa018a0c4>] kvm_iommu_unmap_guest+0x40/0x4e [kvm] [<ffffffffa018f772>] kvm_arch_destroy_vm+0x1a/0x186 [kvm] [<ffffffffa01800d0>] kvm_put_kvm+0x110/0x167 [kvm] [<ffffffffa0180ecc>] kvm_vcpu_release+0x18/0x1c [kvm] [<ffffffff81156f5d>] fput+0x22a/0x3a0 [<ffffffff81152288>] filp_close+0xb4/0xcd [<ffffffff8106599f>] put_files_struct+0x1b7/0x36b [<ffffffff81065830>] ? put_files_struct+0x48/0x36b [<ffffffff8131ee59>] ? do_raw_spin_unlock+0x118/0x160 [<ffffffff81065bc0>] exit_files+0x6d/0x75 [<ffffffff81068348>] do_exit+0x47d/0xc60 [<ffffffff8177e7b5>] ? _raw_spin_unlock_irq+0x30/0x36 [<ffffffff81068bfa>] do_group_exit+0xcf/0x134 [<ffffffff81080790>] get_signal_to_deliver+0x732/0x81d [<ffffffff81095996>] ? cpu_clock+0x4e/0x60 [<ffffffff81002082>] do_notify_resume+0x117/0xc43 [<ffffffff810a2fa3>] ? trace_hardirqs_on+0xd/0xf [<ffffffff81080d79>] ? sys_rt_sigtimedwait+0x2b5/0x3bf [<ffffffff8177d9f2>] ? trace_hardirqs_off_thunk+0x3a/0x3c [<ffffffff81003221>] ? sysret_signal+0x5/0x3d [<ffffffff8100343b>] int_signal+0x12/0x17 Signed-off-by: Sheng Yang <sheng@linux.intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Fix a race condition for usage of is_hwpoison_address()Huang Ying
is_hwpoison_address accesses the page table, so the caller must hold current->mm->mmap_sem in read mode. So fix its usage in hva_to_pfn of kvm accordingly. Comment is_hwpoison_address to remind other users. Reported-by: Avi Kivity <avi@redhat.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: Keep slot ID in memory slot structureAvi Kivity
May be used for distinguishing between internal and user slots, or for sorting slots in size order. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: Add mini-API for vcpu->requestsAvi Kivity
Makes it a little more readable and hackable. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: Remove memory alias supportAvi Kivity
As advertised in feature-removal-schedule.txt. Equivalent support is provided by overlapping memory regions. Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: x86: In DM_LOWEST, only deliver interrupts to vcpus with enabled LAPIC'sChris Lalancette
Otherwise we might try to deliver a timer interrupt to a cpu that can't possibly handle it. Signed-off-by: Chris Lalancette <clalance@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Fix unused but set warningsAndi Kleen
No real bugs in this one. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: Fix KVM_SET_SIGNAL_MASK with arg == NULLAndi Kleen
When the user passed in a NULL mask pass this on from the ioctl handler. Found by gcc 4.6's new warnings. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-08-01KVM: cleanup "*new.rmap" typeLai Jiangshan
The type of '*new.rmap' is not 'struct page *', fix it Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2010-08-01KVM: Update Red Hat copyrightsAvi Kivity
2010-08-01KVM: Consolidate arch specific vcpu ioctl lockingAvi Kivity
Now that all arch specific ioctls have centralized locking, it is easy to move it to the central dispatcher. Signed-off-by: Avi Kivity <avi@redhat.com>
