path: root/virt/kvm
2015-10-22kvm: fix zero length mmio searchingJason Wang
commit 8f4216c7d28976f7ec1b2bcbfa0a9f787133c45e upstream. Currently, if we had a zero length mmio eventfd assigned on KVM_MMIO_BUS. It will never be found by kvm_io_bus_cmp() since it always compares the kvm_io_range() with the length that guest wrote. This will cause e.g for vhost, kick will be trapped by qemu userspace instead of vhost. Fixing this by using zero length if an iodevice is zero length. Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-10arm/arm64: KVM: Keep elrsr/aisr in sync with software modelChristoffer Dall
commit ae705930fca6322600690df9dc1c7d0516145a93 upstream. [Note the upstream one of this patch requires applying full GICv3 support but it's out of the scope of stable kernel. So this patch has a huge modification for stable kernel comparing to the upstream one.] There is an interesting bug in the vgic code, which manifests itself when the KVM run loop has a signal pending or needs a vmid generation rollover after having disabled interrupts but before actually switching to the guest. In this case, we flush the vgic as usual, but we sync back the vgic state and exit to userspace before entering the guest. The consequence is that we will be syncing the list registers back to the software model using the GICH_ELRSR and GICH_EISR from the last execution of the guest, potentially overwriting a list register containing an interrupt. This showed up during migration testing where we would capture a state where the VM has masked the arch timer but there were no interrupts, resulting in a hung test. Cc: Marc Zyngier <marc.zyngier@arm.com> Reported-by: Alex Bennee <alex.bennee@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Alex Bennée <alex.bennee@linaro.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-10arm/arm64: KVM: Require in-kernel vgic for the arch timersChristoffer Dall
commit 05971120fca43e0357789a14b3386bb56eef2201 upstream. [Note this patch is a bit different from the original one as the names of vgic_initialized and kvm_vgic_init are different.] It is curently possible to run a VM with architected timers support without creating an in-kernel VGIC, which will result in interrupts from the virtual timer going nowhere. To address this issue, move the architected timers initialization to the time when we run a VCPU for the first time, and then only initialize (and enable) the architected timers if we have a properly created and initialized in-kernel VGIC. When injecting interrupts from the virtual timer to the vgic, the current setup should ensure that this never calls an on-demand init of the VGIC, which is the only call path that could return an error from kvm_vgic_inject_irq(), so capture the return value and raise a warning if there's an error there. We also change the kvm_timer_init() function from returning an int to be a void function, since the function always succeeds. Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-03arm/arm64: KVM: vgic: Fix error code in kvm_vgic_create()Christoffer Dall
commit 6b50f54064a02b77a7b990032b80234fee59bcd6 upstream. If we detect another vCPU is running we just exit and return 0 as if we succesfully created the VGIC, but the VGIC wouldn't actual be created. This shouldn't break in-kernel behavior because the kernel will not observe the failed the attempt to create the VGIC, but userspace could be rightfully confused. Cc: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-03arm/arm64: KVM: Fix set_clear_sgi_pend_reg offsetChristoffer Dall
commit 0fea6d7628ed6e25a9ee1b67edf7c859718d39e8 upstream. The sgi values calculated in read_set_clear_sgi_pend_reg() and write_set_clear_sgi_pend_reg() were horribly incorrectly multiplied by 4 with catastrophic results in that subfunctions ended up overwriting memory not allocated for the expected purpose. This showed up as bugs in kfree() and the kernel complaining a lot of you turn on memory debugging. This addresses: http://marc.info/?l=kvm&m=141164910007868&w=2 Reported-by: Shannon Zhao <zhaoshenglong@huawei.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-03KVM: ARM: vgic: plug irq injection raceMarc Zyngier
commit 71afaba4a2e98bb7bdeba5078370ab43d46e67a1 upstream. [Since we don't backport commit 227844f (arm/arm64: KVM: Rename irq_state to irq_pending) for linux-3.14.y, here we still use vgic_update_irq_state instead of vgic_update_irq_pending.] As it stands, nothing prevents userspace from injecting an interrupt before the guest's GIC is actually initialized. This goes unnoticed so far (as everything is pretty much statically allocated), but ends up exploding in a spectacular way once we switch to a more dynamic allocation (the GIC data structure isn't there yet). The fix is to test for the "ready" flag in the VGIC distributor before trying to inject the interrupt. Note that in order to avoid breaking userspace, we have to ignore what is essentially an error. Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-29KVM: vgic: return int instead of bool when checking I/O rangesWill Deacon
commit 1fa451bcc67fa921a04c5fac8dbcde7844d54512 upstream. vgic_ioaddr_overlap claims to return a bool, but in reality it returns an int. Shut sparse up by fixing the type signature. Cc: Christoffer Dall <christoffer.dall@linaro.org> Cc: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17kvm: arm64: vgic: fix hyp panic with 64k pages on juno platformWill Deacon
commit 63afbe7a0ac184ef8485dac4914e87b211b5bfaa upstream. If the physical address of GICV isn't page-aligned, then we end up creating a stage-2 mapping of the page containing it, which causes us to map neighbouring memory locations directly into the guest. As an example, consider a platform with GICV at physical 0x2c02f000 running a 64k-page host kernel. If qemu maps this into the guest at 0x80010000, then guest physical addresses 0x80010000 - 0x8001efff will map host physical region 0x2c020000 - 0x2c02efff. Accesses to these physical regions may cause UNPREDICTABLE behaviour, for example, on the Juno platform this will cause an SError exception to EL3, which brings down the entire physical CPU resulting in RCU stalls / HYP panics / host crashing / wasted weeks of debugging. SBSA recommends that systems alias the 4k GICV across the bounding 64k region, in which case GICV physical could be described as 0x2c020000 in the above scenario. This patch fixes the problem by failing the vgic probe if the physical base address or the size of GICV aren't page-aligned. Note that this generated a warning in dmesg about freeing enabled IRQs, so I had to move the IRQ enabling later in the probe. Cc: Christoffer Dall <christoffer.dall@linaro.org> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: Joel Schopp <joel.schopp@amd.com> Cc: Don Dutile <ddutile@redhat.com> Acked-by: Peter Maydell <peter.maydell@linaro.org> Acked-by: Joel Schopp <joel.schopp@amd.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Cc: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17KVM: ARM: vgic: Fix the overlap check action about setting the GICD & GICC ↵Haibin Wang
base address. commit 30c2117085bc4e05d091cee6eba79f069b41a9cd upstream. Currently below check in vgic_ioaddr_overlap will always succeed, because the vgic dist base and vgic cpu base are still kept UNDEF after initialization. The code as follows will be return forever. if (IS_VGIC_ADDR_UNDEF(dist) || IS_VGIC_ADDR_UNDEF(cpu)) return 0; So, before invoking the vgic_ioaddr_overlap, it needs to set the corresponding base address firstly. Signed-off-by: Haibin Wang <wanghaibin.wang@huawei.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Cc: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-17KVM: arm/arm64: vgic: fix GICD_ICFGR register accessesAndre Przywara
commit f2ae85b2ab3776b9e4e42e5b6fa090f40d396794 upstream. Since KVM internally represents the ICFGR registers by stuffing two of them into one word, the offset for accessing the internal representation and the one for the MMIO based access are different. So keep the original offset around, but adjust the internal array offset by one bit. Reported-by: Haibin Wang <wanghaibin.wang@huawei.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Cc: Shannon Zhao <shannon.zhao@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-06KVM: use slowpath for cross page cached accessesRadim Krčmář
commit ca3f0874723fad81d0c701b63ae3a17a408d5f25 upstream. kvm_write_guest_cached() does not mark all written pages as dirty and code comments in kvm_gfn_to_hva_cache_init() talk about NULL memslot with cross page accesses. Fix all the easy way. The check is '<= 1' to have the same result for 'len = 0' cache anywhere in the page. (nr_pages_needed is 0 on page boundary.) Fixes: 8f964525a121 ("KVM: Allow cross page reads and writes from cached translations.") Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Message-Id: <20150408121648.GA3519@potion.brq.redhat.com> Reviewed-by: Wanpeng Li <wanpeng.li@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-14kvm: fix excessive pages un-pinning in kvm_iommu_map error path.Quentin Casasnovas
commit 3d32e4dbe71374a6780eaf51d719d76f9a9bf22f upstream. The third parameter of kvm_unpin_pages() when called from kvm_iommu_map_pages() is wrong, it should be the number of pages to un-pin and not the page size. This error was facilitated with an inconsistent API: kvm_pin_pages() takes a size, but kvn_unpin_pages() takes a number of pages, so fix the problem by matching the two. This was introduced by commit 350b8bd ("kvm: iommu: fix the third parameter of kvm_iommu_put_pages (CVE-2014-3601)"), which fixes the lack of un-pinning for pages intended to be un-pinned (i.e. memory leak) but unfortunately potentially aggravated the number of pages we un-pin that should have stayed pinned. As far as I understand though, the same practical mitigations apply. This issue was found during review of Red Hat 6.6 patches to prepare Ksplice rebootless updates. Thanks to Vegard for his time on a late Friday evening to help me in understanding this code. Fixes: 350b8bd ("kvm: iommu: fix the third parameter of... (CVE-2014-3601)") Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com> Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Jamie Iles <jamie.iles@oracle.com> Reviewed-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30kvm: don't take vcpu mutex for obviously invalid vcpu ioctlsDavid Matlack
commit 2ea75be3219571d0ec009ce20d9971e54af96e09 upstream. vcpu ioctls can hang the calling thread if issued while a vcpu is running. However, invalid ioctls can happen when userspace tries to probe the kind of file descriptors (e.g. isatty() calls ioctl(TCGETS)); in that case, we know the ioctl is going to be rejected as invalid anyway and we can fail before trying to take the vcpu mutex. This patch does not change functionality, it just makes invalid ioctls fail faster. Signed-off-by: David Matlack <dmatlack@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-30kvm: fix potentially corrupt mmio cacheDavid Matlack
commit ee3d1570b58677885b4552bce8217fda7b226a68 upstream. vcpu exits and memslot mutations can run concurrently as long as the vcpu does not aquire the slots mutex. Thus it is theoretically possible for memslots to change underneath a vcpu that is handling an exit. If we increment the memslot generation number again after synchronize_srcu_expedited(), vcpus can safely cache memslot generation without maintaining a single rcu_dereference through an entire vm exit. And much of the x86/kvm code does not maintain a single rcu_dereference of the current memslots during each exit. We can prevent the following case: vcpu (CPU 0) | thread (CPU 1) --------------------------------------------+-------------------------- 1 vm exit | 2 srcu_read_unlock(&kvm->srcu) | 3 decide to cache something based on | old memslots | 4 | change memslots | (increments generation) 5 | synchronize_srcu(&kvm->srcu); 6 retrieve generation # from new memslots | 7 tag cache with new memslot generation | 8 srcu_read_unlock(&kvm->srcu) | ... | <action based on cache occurs even | though the caching decision was based | on the old memslots> | ... | <action *continues* to occur until next | memslot generation change, which may | be never> | | By incrementing the generation after synchronizing with kvm->srcu readers, we ensure that the generation retrieved in (6) will become invalid soon after (8). Keeping the existing increment is not strictly necessary, but we do keep it and just move it for consistency from update_memslots to install_new_memslots. It invalidates old cached MMIOs immediately, instead of having to wait for the end of synchronize_srcu_expedited, which makes the code more clearly correct in case CPU 1 is preempted right after synchronize_srcu() returns. To avoid halving the generation space in SPTEs, always presume that the low bit of the generation is zero when reconstructing a generation number out of an SPTE. This effectively disables MMIO caching in SPTEs during the call to synchronize_srcu_expedited. Using the low bit this way is somewhat like a seqcount---where the protected thing is a cache, and instead of retrying we can simply punt if we observe the low bit to be 1. Signed-off-by: David Matlack <dmatlack@google.com> Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Reviewed-by: David Matlack <dmatlack@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05kvm: iommu: fix the third parameter of kvm_iommu_put_pages (CVE-2014-3601)Michael S. Tsirkin
commit 350b8bdd689cd2ab2c67c8a86a0be86cfa0751a7 upstream. The third parameter of kvm_iommu_put_pages is wrong, It should be 'gfn - slot->base_gfn'. By making gfn very large, malicious guest or userspace can cause kvm to go to this error path, and subsequently to pass a huge value as size. Alternatively if gfn is small, then pages would be pinned but never unpinned, causing host memory leak and local DOS. Passing a reasonable but large value could be the most dangerous case, because it would unpin a page that should have stayed pinned, and thus allow the device to DMA into arbitrary memory. However, this cannot happen because of the condition that can trigger the error: - out of memory (where you can't allocate even a single page) should not be possible for the attacker to trigger - when exceeding the iommu's address space, guest pages after gfn will also exceed the iommu's address space, and inside kvm_iommu_put_pages() the iommu_iova_to_phys() will fail. The page thus would not be unpinned at all. Reported-by: Jack Morgenstein <jackm@mellanox.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-05KVM: x86: always exit on EOIs for interrupts listed in the IOAPIC redir tablePaolo Bonzini
commit 0f6c0a740b7d3e1f3697395922d674000f83d060 upstream. Currently, the EOI exit bitmap (used for APICv) does not include interrupts that are masked. However, this can cause a bug that manifests as an interrupt storm inside the guest. Alex Williamson reported the bug and is the one who really debugged this; I only wrote the patch. :) The scenario involves a multi-function PCI device with OHCI and EHCI USB functions and an audio function, all assigned to the guest, where both USB functions use legacy INTx interrupts. As soon as the guest boots, interrupts for these devices turn into an interrupt storm in the guest; the host does not see the interrupt storm. Basically the EOI path does not work, and the guest continues to see the interrupt over and over, even after it attempts to mask it at the APIC. The bug is only visible with older kernels (RHEL6.5, based on 2.6.32 with not many changes in the area of APIC/IOAPIC handling). Alex then tried forcing bit 59 (corresponding to the USB functions' IRQ) on in the eoi_exit_bitmap and TMR, and things then work. What happens is that VFIO asserts IRQ11, then KVM recomputes the EOI exit bitmap. It does not have set bit 59 because the RTE was masked, so the IOAPIC never sees the EOI and the interrupt continues to fire in the guest. My guess was that the guest is masking the interrupt in the redirection table in the interrupt routine, i.e. while the interrupt is set in a LAPIC's ISR, The simplest fix is to ignore the masking state, we would rather have an unnecessary exit rather than a missed IRQ ACK and anyway IOAPIC interrupts are not as performance-sensitive as for example MSIs. Alex tested this patch and it fixed his bug. [Thanks to Alex for his precise description of the problem and initial debugging effort. A lot of the text above is based on emails exchanged with him.] Reported-by: Alex Williamson <alex.williamson@redhat.com> Tested-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-13KVM: ioapic: fix assignment of ioapic->rtc_status.pending_eoi (CVE-2014-0155)Paolo Bonzini
commit 5678de3f15010b9022ee45673f33bcfc71d47b60 upstream. QE reported that they got the BUG_ON in ioapic_service to trigger. I cannot reproduce it, but there are two reasons why this could happen. The less likely but also easiest one, is when kvm_irq_delivery_to_apic does not deliver to any APIC and returns -1. Because irqe.shorthand == 0, the kvm_for_each_vcpu loop in that function is never reached. However, you can target the similar loop in kvm_irq_delivery_to_apic_fast; just program a zero logical destination address into the IOAPIC, or an out-of-range physical destination address. Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-13KVM: async_pf: mm->mm_users can not pin apf->mmOleg Nesterov
commit 41c22f626254b9dc0376928cae009e73d1b6a49a upstream. get_user_pages(mm) is simply wrong if mm->mm_users == 0 and exit_mmap/etc was already called (or is in progress), mm->mm_count can only pin mm->pgd and mm_struct itself. Change kvm_setup_async_pf/async_pf_execute to inc/dec mm->mm_users. kvm_create_vm/kvm_destroy_vm play with ->mm_count too but this case looks fine at first glance, it seems that this ->mm is only used to verify that current->mm == kvm->mm. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-13KVM: ARM: vgic: Fix sgi dispatch problemHaibin Wang
commit 91021a6c8ffdc55804dab5acdfc7de4f278b9ac3 upstream. When dispatch SGI(mode == 0), that is the vcpu of VM should send sgi to the cpu which the target_cpus list. So, there must add the "break" to branch of case 0. Signed-off-by: Haibin Wang <wanghaibin.wang@huawei.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-14arm64: KVM: Add VGIC device control for arm64Christoffer Dall
This fixes the build breakage introduced by c07a0191ef2de1f9510f12d1f88e3b0b5cd8d66f and adds support for the device control API and save/restore of the VGIC state for ARMv8. The defines were simply missing from the arm64 header files and uaccess.h must be implicitly imported from somewhere else on arm. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-01-30KVM: return an error code in kvm_vm_ioctl_register_coalesced_mmio()Dan Carpenter
If kvm_io_bus_register_dev() fails then it returns success but it should return an error code. I also did a little cleanup like removing an impossible NULL test. Cc: stable@vger.kernel.org Fixes: 2b3c246a682c ('KVM: Make coalesced mmio use a device per zone') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-01-22Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Paolo Bonzini: "First round of KVM updates for 3.14; PPC parts will come next week. Nothing major here, just bugfixes all over the place. The most interesting part is the ARM guys' virtualized interrupt controller overhaul, which lets userspace get/set the state and thus enables migration of ARM VMs" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (67 commits) kvm: make KVM_MMU_AUDIT help text more readable KVM: s390: Fix memory access error detection KVM: nVMX: Update guest activity state field on L2 exits KVM: nVMX: Fix nested_run_pending on activity state HLT KVM: nVMX: Clean up handling of VMX-related MSRs KVM: nVMX: Add tracepoints for nested_vmexit and nested_vmexit_inject KVM: nVMX: Pass vmexit parameters to nested_vmx_vmexit KVM: nVMX: Leave VMX mode on clearing of feature control MSR KVM: VMX: Fix DR6 update on #DB exception KVM: SVM: Fix reading of DR6 KVM: x86: Sync DR7 on KVM_SET_DEBUGREGS add support for Hyper-V reference time counter KVM: remove useless write to vcpu->hv_clock.tsc_timestamp KVM: x86: fix tsc catchup issue with tsc scaling KVM: x86: limit PIT timer frequency KVM: x86: handle invalid root_hpa everywhere kvm: Provide kvm_vcpu_eligible_for_directed_yield() stub kvm: vfio: silence GCC warning KVM: ARM: Remove duplicate include arm/arm64: KVM: relax the requirements of VMA alignment for THP ...
2014-01-15kvm: Provide kvm_vcpu_eligible_for_directed_yield() stubScott Wood
Commit 7940876e1330671708186ac3386aa521ffb5c182 ("kvm: make local functions static") broke KVM PPC builds due to removing (rather than moving) the stub version of kvm_vcpu_eligible_for_directed_yield(). This patch reintroduces it. Signed-off-by: Scott Wood <scottwood@freescale.com> Cc: Stephen Hemminger <stephen@networkplumber.org> Cc: Alexander Graf <agraf@suse.de> [Move the #ifdef inside the function. - Paolo] Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-01-15kvm: vfio: silence GCC warningPaul Bolle
Building vfio.o triggers a GCC warning (when building for 32 bits x86): arch/x86/kvm/../../../virt/kvm/vfio.c: In function 'kvm_vfio_set_group': arch/x86/kvm/../../../virt/kvm/vfio.c:104:22: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast] void __user *argp = (void __user *)arg; ^ Silence this warning by casting arg to unsigned long. argp's current type, "void __user *", is always casted to "int32_t __user *". So its type might as well be changed to "int32_t __user *". Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2014-01-08kvm: remove dead codeStephen Hemminger
The function kvm_io_bus_read_cookie is defined but never used in current in-tree code. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2014-01-08kvm: make local functions staticStephen Hemminger
Running 'make namespacecheck' found lots of functions that should be declared static, since only used in one file. Signed-off-by: Stephen Hemminger <stephen@networkplumber.org> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2013-12-21KVM: arm-vgic: Support CPU interface reg accessChristoffer Dall
Implement support for the CPU interface register access driven by MMIO address offsets from the CPU interface base address. Useful for user space to support save/restore of the VGIC state. This commit adds support only for the same logic as the current VGIC support, and no more. For example, the active priority registers are handled as RAZ/WI, just like setting priorities on the emulated distributor. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Add GICD_SPENDSGIR and GICD_CPENDSGIR handlersChristoffer Dall
Handle MMIO accesses to the two registers which should support both the case where the VMs want to read/write either of these registers and the case where user space reads/writes these registers to do save/restore of the VGIC state. Note that the added complexity compared to simple set/clear enable registers stems from the bookkeping of source cpu ids. It may be possible to change the underlying data structure to simplify the complexity, but since this is not in the critical path at all, this will do. Also note that reading this register from a live guest will not be accurate compared to on hardware, because some state may be living on the CPU LRs and the only way to give a consistent read would be to force stop all the VCPUs and request them to unqueu the LR state onto the distributor. Until we have an actual user of live reading this register, we can live with the difference. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Support unqueueing of LRs to the distChristoffer Dall
To properly access the VGIC state from user space it is very unpractical to have to loop through all the LRs in all register access functions. Instead, support moving all pending state from LRs to the distributor, but leave active state LRs alone. Note that to accurately present the active and pending state to VCPUs reading these distributor registers from a live VM, we would have to stop all other VPUs than the calling VCPU and ask each CPU to unqueue their LR state onto the distributor and add fields to track active state on the distributor side as well. We don't have any users of such functionality yet and there are other inaccuracies of the GIC emulation, so don't provide accurate synchronized access to this state just yet. However, when the time comes, having this function should help. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Add vgic reg access from dev attrChristoffer Dall
Add infrastructure to handle distributor and cpu interface register accesses through the KVM_{GET/SET}_DEVICE_ATTR interface by adding the KVM_DEV_ARM_VGIC_GRP_DIST_REGS and KVM_DEV_ARM_VGIC_GRP_CPU_REGS groups and defining the semantics of the attr field to be the MMIO offset as specified in the GICv2 specs. Missing register accesses or other changes in individual register access functions to support save/restore of the VGIC state is added in subsequent patches. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Make vgic mmio functions more genericChristoffer Dall
Rename the vgic_ranges array to vgic_dist_ranges to be more specific and to prepare for handling CPU interface register access as well (for save/restore of VGIC state). Pass offset from distributor or interface MMIO base to find_matching_range function instead of the physical address of the access in the VM memory map. This allows other callers unaware of the VM specifics, but with generic VGIC knowledge to reuse the function. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Set base addr through device APIChristoffer Dall
Support setting the distributor and cpu interface base addresses in the VM physical address space through the KVM_{SET,GET}_DEVICE_ATTR API in addition to the ARM specific API. This has the added benefit of being able to share more code in user space and do things in a uniform manner. Also deprecate the older API at the same time, but backwards compatibility will be maintained. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21KVM: arm-vgic: Support KVM_CREATE_DEVICE for VGICChristoffer Dall
Support creating the ARM VGIC device through the KVM_CREATE_DEVICE ioctl, which can then later be leveraged to use the KVM_{GET/SET}_DEVICE_ATTR, which is useful both for setting addresses in a more generic API than the ARM-specific one and is useful for save/restore of VGIC state. Adds KVM_CAP_DEVICE_CTRL to ARM capabilities. Note that we change the check for creating a VGIC from bailing out if any VCPUs were created, to bailing out if any VCPUs were ever run. This is an important distinction that shouldn't break anything, but allows creating the VGIC after the VCPUs have been created. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21ARM: KVM: Allow creating the VGIC after VCPUsChristoffer Dall
Rework the VGIC initialization slightly to allow initialization of the vgic cpu-specific state even if the irqchip (the VGIC) hasn't been created by user space yet. This is safe, because the vgic data structures are already allocated when the CPU is allocated if VGIC support is compiled into the kernel. Further, the init process does not depend on any other information and the sacrifice is a slight performance degradation for creating VMs in the no-VGIC case. The reason is that the new device control API doesn't mandate creating the VGIC before creating the VCPU and it is unreasonable to require user space to create the VGIC before creating the VCPUs. At the same time move the irqchip_in_kernel check out of kvm_vcpu_first_run_init and into the init function to make the per-vcpu and global init functions symmetric and add comments on the exported functions making it a bit easier to understand the init flow by only looking at vgic.c. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21ARM/KVM: save and restore generic timer registersAndre Przywara
For migration to work we need to save (and later restore) the state of each core's virtual generic timer. Since this is per VCPU, we can use the [gs]et_one_reg ioctl and export the three needed registers (control, counter, compare value). Though they live in cp15 space, we don't use the existing list, since they need special accessor functions and the arch timer is optional. Acked-by: Marc Zynger <marc.zyngier@arm.com> Signed-off-by: Andre Przywara <andre.przywara@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-21arm/arm64: KVM: arch_timer: Initialize cntvoff at kvm_initChristoffer Dall
Initialize the cntvoff at kvm_init_vm time, not before running the VCPUs at the first time because that will overwrite any potentially restored values from user space. Cc: Andre Przywara <andre.przywara@linaro.org> Acked-by: Marc Zynger <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2013-12-13KVM: Use cond_resched() directly and remove useless kvm_resched()Takuya Yoshikawa
Since the commit 15ad7146 ("KVM: Use the scheduler preemption notifiers to make kvm preemptible"), the remaining stuff in this function is a simple cond_resched() call with an extra need_resched() check which was there to avoid dropping VCPUs unnecessarily. Now it is meaningless. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-12-12KVM: Improve create VCPU parameter (CVE-2013-4587)Andy Honig
In multiple functions the vcpu_id is used as an offset into a bitfield. Ag malicious user could specify a vcpu_id greater than 255 in order to set or clear bits in kernel memory. This could be used to elevate priveges in the kernel. This patch verifies that the vcpu_id provided is less than 255. The api documentation already specifies that the vcpu_id must be less than max_vcpus, but this is currently not checked. Reported-by: Andrew Honig <ahonig@google.com> Cc: stable@vger.kernel.org Signed-off-by: Andrew Honig <ahonig@google.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-11-21KVM: kvm_clear_guest_page(): fix empty_zero_page usageHeiko Carstens
Using the address of 'empty_zero_page' as source address in order to clear a page is wrong. On some architectures empty_zero_page is only the pointer to the struct page of the empty_zero_page. Therefore the clear page operation would copy the contents of a couple of struct pages instead of clearing a page. For kvm only arm/arm64 are affected by this bug. To fix this use the ZERO_PAGE macro instead which will return the struct page address of the empty_zero_page on all architectures. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-11-15Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM changes from Paolo Bonzini: "Here are the 3.13 KVM changes. There was a lot of work on the PPC side: the HV and emulation flavors can now coexist in a single kernel is probably the most interesting change from a user point of view. On the x86 side there are nested virtualization improvements and a few bugfixes. ARM got transparent huge page support, improved overcommit, and support for big endian guests. Finally, there is a new interface to connect KVM with VFIO. This helps with devices that use NoSnoop PCI transactions, letting the driver in the guest execute WBINVD instructions. This includes some nVidia cards on Windows, that fail to start without these patches and the corresponding userspace changes" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (146 commits) kvm, vmx: Fix lazy FPU on nested guest arm/arm64: KVM: PSCI: propagate caller endianness to the incoming vcpu arm/arm64: KVM: MMIO support for BE guest kvm, cpuid: Fix sparse warning kvm: Delete prototype for non-existent function kvm_check_iopl kvm: Delete prototype for non-existent function complete_pio hung_task: add method to reset detector pvclock: detect watchdog reset at pvclock read kvm: optimize out smp_mb after srcu_read_unlock srcu: API for barrier after srcu read unlock KVM: remove vm mmap method KVM: IOMMU: hva align mapping page size KVM: x86: trace cpuid emulation when called from emulator KVM: emulator: cleanup decode_register_operand() a bit KVM: emulator: check rex prefix inside decode_register() KVM: x86: fix emulation of "movzbl %bpl, %eax" kvm_host: typo fix KVM: x86: emulate SAHF instruction MAINTAINERS: add tree for kvm.git Documentation/kvm: add a 00-INDEX file ...
2013-11-06KVM: remove vm mmap methodGleb Natapov
It was used in conjunction with KVM_SET_MEMORY_REGION ioctl which was removed by b74a07beed0 in 2010, QEMU stopped using it in 2008, so it is time to remove the code finally. Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-11-05KVM: IOMMU: hva align mapping page sizeGreg Edwards
When determining the page size we could use to map with the IOMMU, the page size should also be aligned with the hva, not just the gfn. The gfn may not reflect the real alignment within the hugetlbfs file. Most of the time, this works fine. However, if the hugetlbfs file is backed by non-contiguous huge pages, a multi-huge page memslot starts at an unaligned offset within the hugetlbfs file, and the gfn is aligned with respect to the huge page size, kvm_host_page_size() will return the huge page size and we will use that to map with the IOMMU. When we later unpin that same memslot, the IOMMU returns the unmap size as the huge page size, and we happily unpin that many pfns in monotonically increasing order, not realizing we are spanning non-contiguous huge pages and partially unpin the wrong huge page. Ensure the IOMMU mapping page size is aligned with the hva corresponding to the gfn, which does reflect the alignment within the hugetlbfs file. Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Edwards <gedwards@ddn.com> Cc: stable@vger.kernel.org Signed-off-by: Gleb Natapov <gleb@redhat.com>
2013-11-04Merge branch 'kvm-ppc-queue' of git://github.com/agraf/linux-2.6 into queueGleb Natapov
Conflicts: arch/powerpc/include/asm/processor.h
2013-10-30kvm: Create non-coherent DMA registerationAlex Williamson
We currently use some ad-hoc arch variables tied to legacy KVM device assignment to manage emulation of instructions that depend on whether non-coherent DMA is present. Create an interface for this, adapting legacy KVM device assignment and adding VFIO via the KVM-VFIO device. For now we assume that non-coherent DMA is possible any time we have a VFIO group. Eventually an interface can be developed as part of the VFIO external user interface to query the coherency of a group. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-30kvm/x86: Convert iommu_flags to iommu_noncoherentAlex Williamson
Default to operating in coherent mode. This simplifies the logic when we switch to a model of registering and unregistering noncoherent I/O with KVM. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-30kvm: Add VFIO deviceAlex Williamson
So far we've succeeded at making KVM and VFIO mostly unaware of each other, but areas are cropping up where a connection beyond eventfds and irqfds needs to be made. This patch introduces a KVM-VFIO device that is meant to be a gateway for such interaction. The user creates the device and can add and remove VFIO groups to it via file descriptors. When a group is added, KVM verifies the group is valid and gets a reference to it via the VFIO external user interface. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-30KVM: use a more sensible error number when debugfs directory creation failsPaolo Bonzini
I don't know if this was due to cut and paste, or somebody was really using a D20 to pick the error code for kvm_init_debugfs as suggested by Linus (EFAULT is 14, so the possibility cannot be entirely ruled out). In any case, this patch fixes it. Reported-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-28KVM: Mapping IOMMU pages after updating memslotYang Zhang
In kvm_iommu_map_pages(), we need to know the page size via call kvm_host_page_size(). And it will check whether the target slot is valid before return the right page size. Currently, we will map the iommu pages when creating a new slot. But we call kvm_iommu_map_pages() during preparing the new slot. At that time, the new slot is not visible by domain(still in preparing). So we cannot get the right page size from kvm_host_page_size() and this will break the IOMMU super page logic. The solution is to map the iommu pages after we insert the new slot into domain. Signed-off-by: Yang Zhang <yang.z.zhang@Intel.com> Tested-by: Patrick Lu <patrick.lu@intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2013-10-17Powerpc KVM work is based on a commit after rc4.Gleb Natapov
Merging master into next to satisfy the dependencies. Conflicts: arch/arm/kvm/reset.c
2013-10-17kvm: Add struct kvm arg to memslot APIsAneesh Kumar K.V
We will use that in the later patch to find the kvm ops handler Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Alexander Graf <agraf@suse.de>
