[ Upstream commit caf1ff26e1aa178133df68ac3d40815fed2187d9 ]
These days, we experienced one guest crash with 8 cores and 3 disks,
with qemu error logs as bellow:
qemu-system-x86_64: /build/qemu-2.0.0/kvm-all.c:984:
kvm_irqchip_commit_routes: Assertion `ret == 0' failed.
And then we found one patch(bdf026317d) in qemu tree, which said
could fix this bug.
Execute the following script will reproduce the BUG quickly:
irq_affinity.sh
vda_irq_num=25
vdb_irq_num=27
while [ 1 ]
do
for irq in {1,2,4,8,10,20,40,80}
do
echo $irq > /proc/irq/$vda_irq_num/smp_affinity
echo $irq > /proc/irq/$vdb_irq_num/smp_affinity
dd if=/dev/vda of=/dev/zero bs=4K count=100 iflag=direct
dd if=/dev/vdb of=/dev/zero bs=4K count=100 iflag=direct
done
done
The following qemu log is added in the qemu code and is displayed when
this bug reproduced:
kvm_irqchip_commit_routes: max gsi: 1008, nr_allocated_irq_routes: 1024,
irq_routes->nr: 1024, gsi_count: 1024.
That's to say when irq_routes->nr == 1024, there are 1024 routing entries,
but in the kernel code when routes->nr >= 1024, will just return -EINVAL;
The nr is the number of the routing entries which is in of
[1 ~ KVM_MAX_IRQ_ROUTES], not the index in [0 ~ KVM_MAX_IRQ_ROUTES - 1].
This patch fix the BUG above.
Cc: stable@vger.kernel.org
Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com>
Signed-off-by: Wei Tang <tangwei@cmss.chinamobile.com>
Signed-off-by: Zhang Zhuoyu <zhangzhuoyu@cmss.chinamobile.com>
[ Upstream commit c622a3c21ede892e370b56e1ceb9eb28f8bbda6b ]
Found by syzkaller:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000120
IP: [<ffffffffa0797202>] kvm_irq_map_gsi+0x12/0x90 [kvm]
PGD 6f80b067 PUD b6535067 PMD 0
Oops: 0000 [#1] SMP
CPU: 3 PID: 4988 Comm: a.out Not tainted 4.4.9-300.fc23.x86_64 #1
Call Trace:
[<ffffffffa0795f62>] irqfd_update+0x32/0xc0 [kvm]
[<ffffffffa0796c7c>] kvm_irqfd+0x3dc/0x5b0 [kvm]
[<ffffffffa07943f4>] kvm_vm_ioctl+0x164/0x6f0 [kvm]
[<ffffffff81241648>] do_vfs_ioctl+0x298/0x480
[<ffffffff812418a9>] SyS_ioctl+0x79/0x90
[<ffffffff817a1062>] tracesys_phase2+0x84/0x89
Code: b5 71 a7 e0 5b 41 5c 41 5d 5d f3 c3 66 66 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 8b 8f 10 2e 00 00 31 c0 48 89 e5 <39> 91 20 01 00 00 76 6a 48 63 d2 48 8b 94 d1 28 01 00 00 48 85
RIP [<ffffffffa0797202>] kvm_irq_map_gsi+0x12/0x90 [kvm]
RSP <ffff8800926cbca8>
CR2: 0000000000000120
Testcase:
#include <unistd.h>
#include <sys/syscall.h>
#include <string.h>
#include <stdint.h>
#include <linux/kvm.h>
#include <fcntl.h>
#include <sys/ioctl.h>
long r[26];
int main()
memset(r, -1, sizeof(r));
r[2] = open("/dev/kvm", 0);
r[3] = ioctl(r[2], KVM_CREATE_VM, 0);
struct kvm_irqfd ifd;
ifd.fd = syscall(SYS_eventfd2, 5, 0);
ifd.gsi = 3;
ifd.flags = 2;
ifd.resamplefd = ifd.fd;
r[25] = ioctl(r[3], KVM_IRQFD, &ifd);
return 0;
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
[ Upstream commit e9ad4ec8379ad1ba6f68b8ca1c26b50b5ae0a327 ]
Moving the initialization earlier is needed in 4.6 because
kvm_arch_init_vm is now using mmu_lock, causing lockdep to
complain:
[ 284.440294] INFO: trying to register non-static key.
[ 284.445259] the code is fine but needs lockdep annotation.
[ 284.450736] turning off the locking correctness validator.
[ 284.528318] [<ffffffff810aecc3>] lock_acquire+0xd3/0x240
[ 284.533733] [<ffffffffa0305aa0>] ? kvm_page_track_register_notifier+0x20/0x60 [kvm]
[ 284.541467] [<ffffffff81715581>] _raw_spin_lock+0x41/0x80
[ 284.546960] [<ffffffffa0305aa0>] ? kvm_page_track_register_notifier+0x20/0x60 [kvm]
[ 284.554707] [<ffffffffa0305aa0>] kvm_page_track_register_notifier+0x20/0x60 [kvm]
[ 284.562281] [<ffffffffa02ece70>] kvm_mmu_init_vm+0x20/0x30 [kvm]
[ 284.568381] [<ffffffffa02dbf7a>] kvm_arch_init_vm+0x1ea/0x200 [kvm]
[ 284.574740] [<ffffffffa02bff3f>] kvm_dev_ioctl+0xbf/0x4d0 [kvm]
However, it also helps fixing a preexisting problem, which is why this
patch is also good for stable kernels: kvm_create_vm was incrementing
current->mm->mm_count but not decrementing it at the out_err label (in
case kvm_init_mmu_notifier failed). The new initialization order makes
it possible to add the required mmdrop without adding a new error label.
Reported-by: Borislav Petkov <bp@alien8.de>
[ Upstream commit d7444794a02ff655eda87e3cc54e86b940e7736f ]
In async_pf we try to allocate with NOWAIT to get an element quickly
or fail. This code also handle failures gracefully. Lets silence
potential page allocation failures under load.
qemu-system-s39: page allocation failure: order:0,mode:0x2200000
Call Trace:
([<00000000001146b8>] show_trace+0xf8/0x148)
[<000000000011476a>] show_stack+0x62/0xe8
[<00000000004a36b8>] dump_stack+0x70/0x98
[<0000000000272c3a>] warn_alloc_failed+0xd2/0x148
[<000000000027709e>] __alloc_pages_nodemask+0x94e/0xb38
[<00000000002cd36a>] new_slab+0x382/0x400
[<00000000002cf7ac>] ___slab_alloc.constprop.30+0x2dc/0x378
[<00000000002d03d0>] kmem_cache_alloc+0x160/0x1d0
[<0000000000133db4>] kvm_setup_async_pf+0x6c/0x198
[<000000000013dee8>] kvm_arch_vcpu_ioctl_run+0xd48/0xd58
[<000000000012fcaa>] kvm_vcpu_ioctl+0x372/0x690
[<00000000002f66f6>] do_vfs_ioctl+0x3be/0x510
[<00000000002f68ec>] SyS_ioctl+0xa4/0xb8
[<0000000000781c5e>] system_call+0xd6/0x264
[<000003ffa24fa06a>] 0x3ffa24fa06a
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
Reviewed-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
[ Upstream commit 236cf17c2502007a9d2dda3c39fb0d9a6bd03cc2 ]
When we allocate bitmaps in vgic_vcpu_init_maps, we divide the number of
bits we need by 8 to figure out how many bytes to allocate. However,
bitmap elements are always accessed as unsigned longs, and if we didn't
happen to allocate a size such that size % sizeof(unsigned long) == 0,
bitmap accesses may go past the end of the allocation.
When using KASAN (which does byte-granular access checks), this results
in a continuous stream of BUGs whenever these bitmaps are accessed:
BUG kmalloc-128 (Tainted: G B ): kasan: bad access detected
INFO: Allocated in vgic_init.part.25+0x55c/0x990 age=7493 cpu=3 pid=1730
INFO: Slab 0xffffffbde6d5da40 objects=16 used=15 fp=0xffffffc935769700 flags=0x4000000000000080
INFO: Object 0xffffffc935769500 @offset=1280 fp=0x (null)
Bytes b4 ffffffc9357694f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffffffc935769500: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffffffc935769510: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffffffc935769520: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffffffc935769530: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffffffc935769540: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffffffc935769550: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffffffc935769560: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Object ffffffc935769570: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Padding ffffffc9357695b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Padding ffffffc9357695c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Padding ffffffc9357695d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Padding ffffffc9357695e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Padding ffffffc9357695f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
CPU: 3 PID: 1740 Comm: kvm-vcpu-0 Tainted: G B 4.4.0+ #17
Hardware name: ARM Juno development board (r1) (DT)
Call trace:
[<ffffffc00008e770>] dump_backtrace+0x0/0x280
[<ffffffc00008ea04>] show_stack+0x14/0x20
[<ffffffc000726360>] dump_stack+0x100/0x188
[<ffffffc00030d324>] print_trailer+0xfc/0x168
[<ffffffc000312294>] object_err+0x3c/0x50
[<ffffffc0003140fc>] kasan_report_error+0x244/0x558
[<ffffffc000314548>] __asan_report_load8_noabort+0x48/0x50
[<ffffffc000745688>] __bitmap_or+0xc0/0xc8
[<ffffffc0000d9e44>] kvm_vgic_flush_hwstate+0x1bc/0x650
[<ffffffc0000c514c>] kvm_arch_vcpu_ioctl_run+0x2ec/0xa60
[<ffffffc0000b9a6c>] kvm_vcpu_ioctl+0x474/0xa68
[<ffffffc00036b7b0>] do_vfs_ioctl+0x5b8/0xcb0
[<ffffffc00036bf34>] SyS_ioctl+0x8c/0xa0
[<ffffffc000086cb0>] el0_svc_naked+0x24/0x28
Memory state around the buggy address:
ffffffc935769400: 00 00 fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffffffc935769480: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
>ffffffc935769500: 04 fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffffffc935769580: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffffffc935769600: 00 00 00 00 fc fc fc fc fc fc fc fc fc fc fc fc
Fix the issue by always allocating a multiple of sizeof(unsigned long),
as we do elsewhere in the vgic code.
Fixes: c1bfb577a ("arm/arm64: KVM: vgic: switch to dynamic allocation")
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Acked-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
commit eefd6b06b17c5478e7c24bea6f64beaa2c431ca6 upstream.
We register wildcard mmio eventfd on two buses, once for KVM_MMIO_BUS
and once on KVM_FAST_MMIO_BUS but with a single iodev
instance. This will lead to an issue: kvm_io_bus_destroy() knows
nothing about the devices on two buses pointing to a single dev. Which
will lead to double free[1] during exit. Fix this by allocating two
instances of iodevs then registering one on KVM_MMIO_BUS and another
on KVM_FAST_MMIO_BUS.
CPU: 1 PID: 2894 Comm: qemu-system-x86 Not tainted 3.19.0-26-generic #28-Ubuntu
Hardware name: LENOVO 2356BG6/2356BG6, BIOS G7ET96WW (2.56 ) 09/12/2013
task: ffff88009ae0c4b0 ti: ffff88020e7f0000 task.ti: ffff88020e7f0000
RIP: 0010:[<ffffffffc07e25d8>] [<ffffffffc07e25d8>] ioeventfd_release+0x28/0x60 [kvm]
RSP: 0018:ffff88020e7f3bc8 EFLAGS: 00010292
RAX: dead000000200200 RBX: ffff8801ec19c900 RCX: 000000018200016d
RDX: ffff8801ec19cf80 RSI: ffffea0008bf1d40 RDI: ffff8801ec19c900
RBP: ffff88020e7f3bd8 R08: 000000002fc75a01 R09: 000000018200016d
R10: ffffffffc07df6ae R11: ffff88022fc75a98 R12: ffff88021e7cc000
R13: ffff88021e7cca48 R14: ffff88021e7cca50 R15: ffff8801ec19c880
FS: 00007fc1ee3e6700(0000) GS:ffff88023e240000(0000) knlGS:0000000000000000
CR2: 00007f8f389d8000 CR3: 000000023dc13000 CR4: 00000000001427e0
Stack:
ffff88021e7cc000 0000000000000000 ffff88020e7f3be8 ffffffffc07e2622
ffff88020e7f3c38 ffffffffc07df69a ffff880232524160 ffff88020e792d80
0000000000000000 ffff880219b78c00 0000000000000008 ffff8802321686a8
Call Trace:
[<ffffffffc07e2622>] ioeventfd_destructor+0x12/0x20 [kvm]
[<ffffffffc07df69a>] kvm_put_kvm+0xca/0x210 [kvm]
[<ffffffffc07df818>] kvm_vcpu_release+0x18/0x20 [kvm]
[<ffffffff811f69f7>] __fput+0xe7/0x250
[<ffffffff811f6bae>] ____fput+0xe/0x10
[<ffffffff81093f04>] task_work_run+0xd4/0xf0
[<ffffffff81079358>] do_exit+0x368/0xa50
[<ffffffff81082c8f>] ? recalc_sigpending+0x1f/0x60
[<ffffffff81079ad5>] do_group_exit+0x45/0xb0
[<ffffffff81085c71>] get_signal+0x291/0x750
[<ffffffff810144d8>] do_signal+0x28/0xab0
[<ffffffff810f3a3b>] ? do_futex+0xdb/0x5d0
[<ffffffff810b7028>] ? __wake_up_locked_key+0x18/0x20
[<ffffffff810f3fa6>] ? SyS_futex+0x76/0x170
[<ffffffff81014fc9>] do_notify_resume+0x69/0xb0
[<ffffffff817cb9af>] int_signal+0x12/0x17
Code: 5d c3 90 0f 1f 44 00 00 55 48 89 e5 53 48 89 fb 48 83 ec 08 48 8b 7f 20 e8 06 d6 a5 c0 48 8b 43 08 48 8b 13 48 89 df 48 89 42 08 <48> 89 10 48 b8 00 01 10 00 00
RIP [<ffffffffc07e25d8>] ioeventfd_release+0x28/0x60 [kvm]
RSP <ffff88020e7f3bc8>
Cc: Gleb Natapov <gleb@kernel.org>
Signed-off-by: Jason Wang <jasowang@redhat.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
commit 85da11ca587c8eb73993a1b503052391a73586f9 upstream.
This patch factors out core eventfd assign/deassign logic and leaves
the argument checking and bus index selection to callers.
commit 8f4216c7d28976f7ec1b2bcbfa0a9f787133c45e upstream.
Currently, if we had a zero length mmio eventfd assigned on
KVM_MMIO_BUS. It will never be found by kvm_io_bus_cmp() since it
always compares the kvm_io_range() with the length that guest
wrote. This will cause e.g for vhost, kick will be trapped by qemu
userspace instead of vhost. Fixing this by using zero length if an
iodevice is zero length.
commit 8453fecbecae26edb3f278627376caab05d9a88d upstream.
We only want zero length mmio eventfd to be registered on
KVM_FAST_MMIO_BUS. So check this explicitly when arg->len is zero to
make sure this.
commit 4839ddc27b7212ec58874f62c97da7400c8523be upstream.
Commit fd1d0ddf2ae9 (KVM: arm/arm64: check IRQ number on userland
injection) rightly limited the range of interrupts userspace can
inject in a guest, but failed to consider the (unlikely) case where
a guest is configured with 1024 interrupts.
In this case, interrupts ranging from 1020 to 1023 are unuseable,
as they have a special meaning for the GIC CPU interface.
Make sure that these number cannot be used as an IRQ. Also delete
a redundant (and similarily buggy) check in kvm_set_irq.
Reported-by: Peter Maydell <peter.maydell@linaro.org>
Cc: Andre Przywara <andre.przywara@arm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master
KVM/ARM changes for v4.1, take #2:
Rather small this time:
- a fix for a nasty bug with virtual IRQ injection
- a fix for irqfd
When userland injects a SPI via the KVM_IRQ_LINE ioctl we currently
only check it against a fixed limit, which historically is set
to 127. With the new dynamic IRQ allocation the effective limit may
actually be smaller (64).
So when now a malicious or buggy userland injects a SPI in that
range, we spill over on our VGIC bitmaps and bytemaps memory.
I could trigger a host kernel NULL pointer dereference with current
mainline by injecting some bogus IRQ number from a hacked kvmtool:
DEBUG: kvm_vgic_inject_irq(kvm, cpu=0, irq=114, level=1)
DEBUG: vgic_update_irq_pending(kvm, cpu=0, irq=114, level=1)
DEBUG: IRQ #114 still in the game, writing to bytemap now...
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = ffffffc07652e000
[00000000] *pgd=00000000f658b003, *pud=00000000f658b003, *pmd=0000000000000000
Internal error: Oops: 96000006 [#1] PREEMPT SMP
Modules linked in:
CPU: 1 PID: 1053 Comm: lkvm-msi-irqinj Not tainted 4.0.0-rc7+ #3027
Hardware name: FVP Base (DT)
task: ffffffc0774e9680 ti: ffffffc0765a8000 task.ti: ffffffc0765a8000
PC is at kvm_vgic_inject_irq+0x234/0x310
LR is at kvm_vgic_inject_irq+0x30c/0x310
pc : [<ffffffc0000ae0a8>] lr : [<ffffffc0000ae180>] pstate: 80000145
So this patch fixes this by checking the SPI number against the
actual limit. Also we remove the former legacy hard limit of
127 in the ioctl code.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org>
CC: <stable@vger.kernel.org> # 4.0, 3.19, 3.18
[maz: wrap KVM_ARM_IRQ_GIC_MAX with #ifndef __KERNEL__,
as suggested by Christopher Covington]
irqfd/arm curently does not support routing. kvm_irq_map_gsi is
supposed to return all the routing entries associated with the
provided gsi and return the number of those entries. We should
return 0 at this point.
Signed-off-by: Eric Auger <eric.auger@linaro.org>
This creates a debugfs directory for each HV guest (assuming debugfs
is enabled in the kernel config), and within that directory, a file
by which the contents of the guest's HPT (hashed page table) can be
read. The directory is named vmnnnn, where nnnn is the PID of the
process that created the guest. The file is named "htab". This is
intended to help in debugging problems in the host's management
of guest memory.
The contents of the file consist of a series of lines like this:
3f48 4000d032bf003505 0000000bd7ff1196 00000003b5c71196
The first field is the index of the entry in the HPT, the second and
third are the HPT entry, so the third entry contains the real page
number that is mapped by the entry if the entry's valid bit is set.
The fourth field is the guest's view of the second doubleword of the
entry, so it contains the guest physical address. (The format of the
second through fourth fields are described in the Power ISA and also
in arch/powerpc/include/asm/mmu-hash64.h.)
Pull KVM updates from Paolo Bonzini:
"First batch of KVM changes for 4.1
The most interesting bit here is irqfd/ioeventfd support for ARM and
ARM64.
Summary:
ARM/ARM64:
fixes for live migration, irqfd and ioeventfd support (enabling
vhost, too), page aging
s390:
interrupt handling rework, allowing to inject all local interrupts
via new ioctl and to get/set the full local irq state for migration
and introspection. New ioctls to access memory by virtual address,
and to get/set the guest storage keys. SIMD support.
MIPS:
FPU and MIPS SIMD Architecture (MSA) support. Includes some
patches from Ralf Baechle's MIPS tree.
x86:
bugfixes (notably for pvclock, the others are small) and cleanups.
Another small latency improvement for the TSC deadline timer"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (146 commits)
KVM: use slowpath for cross page cached accesses
kvm: mmu: lazy collapse small sptes into large sptes
KVM: x86: Clear CR2 on VCPU reset
KVM: x86: DR0-DR3 are not clear on reset
KVM: x86: BSP in MSR_IA32_APICBASE is writable
KVM: x86: simplify kvm_apic_map
KVM: x86: avoid logical_map when it is invalid
KVM: x86: fix mixed APIC mode broadcast
KVM: x86: use MDA for interrupt matching
kvm/ppc/mpic: drop unused IRQ_testbit
KVM: nVMX: remove unnecessary double caching of MAXPHYADDR
KVM: nVMX: checks for address bits beyond MAXPHYADDR on VM-entry
KVM: x86: cache maxphyaddr CPUID leaf in struct kvm_vcpu
KVM: vmx: pass error code with internal error #2
x86: vdso: fix pvclock races with task migration
KVM: remove kvm_read_hva and kvm_read_hva_atomic
KVM: x86: optimize delivery of TSC deadline timer interrupt
KVM: x86: extract blocking logic from __vcpu_run
kvm: x86: fix x86 eflags fixed bit
KVM: s390: migrate vcpu interrupt state
kvm_write_guest_cached() does not mark all written pages as dirty and
code comments in kvm_gfn_to_hva_cache_init() talk about NULL memslot
with cross page accesses. Fix all the easy way.
The check is '<= 1' to have the same result for 'len = 0' cache anywhere
in the page. (nr_pages_needed is 0 on page boundary.)
Fixes: 8f964525a121 ("KVM: Allow cross page reads and writes from cached translations.")
Message-Id: <20150408121648.GA3519@potion.brq.redhat.com>
Reviewed-by: Wanpeng Li <wanpeng.li@linux.intel.com>
The corresponding write functions just use __copy_to_user. Do the
same on the read side.
This reverts what's left of commit 86ab8cffb498 (KVM: introduce
gfn_to_hva_read/kvm_read_hva/kvm_read_hva_atomic, 2012-08-21)
Cc: Xiao Guangrong <guangrong.xiao@linux.intel.com>
Message-Id: <1427976500-28533-1-git-send-email-pbonzini@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into HEAD
Features and fixes for 4.1 (kvm/next)
1. Assorted changes
1.1 allow more feature bits for the guest
1.2 Store breaking event address on program interrupts
2. Interrupt handling rework
2.1 Fix copy_to_user while holding a spinlock (cc stable)
2.2 Rework floating interrupts to follow the priorities
2.3 Allow to inject all local interrupts via new ioctl
2.4 allow to get/set the full local irq state, e.g. for migration
and introspection
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into 'kvm-next'
KVM/ARM changes for v4.1:
- fixes for live migration
- irqfd support
- kvm-io-bus & vgic rework to enable ioeventfd
- page ageing for stage-2 translation
- various cleanups
Fixes for KVM/ARM for 4.0-rc5.
Fixes page refcounting issues in our Stage-2 page table management code,
fixes a missing unlock in a gicv3 error path, and fixes a race that can
cause lost interrupts if signals are pending just prior to entering the
guest.
We have introduced struct kvm_s390_irq a while ago which allows to
inject all kinds of interrupts as defined in the Principles of
Operation.
Add ioctl to inject interrupts with the extended struct kvm_s390_irq
Signed-off-by: Jens Freimann <jfrei@linux.vnet.ibm.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Currently we have struct kvm_exit_mmio for encapsulating MMIO abort
data to be passed on from syndrome decoding all the way down to the
VGIC register handlers. Now as we switch the MMIO handling to be
routed through the KVM MMIO bus, it does not make sense anymore to
use that structure already from the beginning. So we keep the data in
local variables until we put them into the kvm_io_bus framework.
Then we fill kvm_exit_mmio in the VGIC only, making it a VGIC private
structure. On that way we replace the data buffer in that structure
with a pointer pointing to a single location in a local variable, so
we get rid of some copying on the way.
With all of the virtual GIC emulation code now being registered with
the kvm_io_bus, we can remove all of the old MMIO handling code and
its dispatching functionality.
I didn't bother to rename kvm_exit_mmio (to vgic_mmio or something),
because that touches a lot of code lines without any good reason.
This is based on an original patch by Nikolay.
Cc: Nikolay Nikolaev <n.nikolaev@virtualopensystems.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Using the framework provided by the recent vgic.c changes, we
register a kvm_io_bus device on mapping the virtual GICv3 resources.
The distributor mapping is pretty straight forward, but the
redistributors need some more love, since they need to be tagged with
the respective redistributor (read: VCPU) they are connected with.
We use the kvm_io_bus framework to register one devices per VCPU.
Currently we handle the redistributor registers in two separate MMIO
regions, one for the overall behaviour and SPIs and one for the
SGIs/PPIs. That latter forces the creation of _two_ KVM I/O bus
devices for each redistributor.
Since the spec mandates those two pages to be contigious, we could as
well merge them and save the churn with the second KVM I/O bus device.
Using the framework provided by the recent vgic.c changes we register
a kvm_io_bus device when initializing the virtual GICv2.
Currently we use a lot of VGIC specific code to do the MMIO
dispatching.
Use the previous reworks to add kvm_io_bus style MMIO handlers.
Those are not yet called by the MMIO abort handler, also the actual
VGIC emulator function do not make use of it yet, but will be enabled
with the following patches.
The vgic_find_range() function in vgic.c takes a struct kvm_exit_mmio
argument, but actually only used the length field in there. Since we
need to get rid of that structure in that part of the code anyway,
let's rework the function (and it's callers) to pass the length
argument to the function directly.
The name "kvm_mmio_range" is a bit bold, given that it only covers
the VGIC's MMIO ranges. To avoid confusion with kvm_io_range, rename
it to vgic_io_range.
iodev.h contains definitions for the kvm_io_bus framework. This is
needed both by the generic KVM code in virt/kvm as well as by
architecture specific code under arch/. Putting the header file in
virt/kvm and using local includes in the architecture part seems at
least dodgy to me, so let's move the file into include/kvm, so that a
more natural "#include <kvm/iodev.h>" can be used by all of the code.
This also solves a problem later when using struct kvm_io_device
in arm_vgic.h.
Fixing up the FSF address in the GPL header and a wrong include path
on the way.
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
This is needed in e.g. ARM vGIC emulation, where the MMIO handling
depends on the VCPU that does the access.
Signed-off-by: Nikolay Nikolaev <n.nikolaev@virtualopensystems.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
KVM guest can fail to startup with following trace on host:
qemu-system-x86: page allocation failure: order:4, mode:0x40d0
Call Trace:
dump_stack+0x47/0x67
warn_alloc_failed+0xee/0x150
__alloc_pages_direct_compact+0x14a/0x150
__alloc_pages_nodemask+0x776/0xb80
alloc_kmem_pages+0x3a/0x110
kmalloc_order+0x13/0x50
kmemdup+0x1b/0x40
__kvm_set_memory_region+0x24a/0x9f0 [kvm]
kvm_set_ioapic+0x130/0x130 [kvm]
kvm_set_memory_region+0x21/0x40 [kvm]
kvm_vm_ioctl+0x43f/0x750 [kvm]
Failure happens when attempting to allocate pages for
'struct kvm_memslots', however it doesn't have to be
present in physically contiguous (kmalloc-ed) address
space, change allocation to kvm_kvzalloc() so that
it will be vmalloc-ed when its size is more then a page.
Signed-off-by: Igor Mammedov <imammedo@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
When all bits in mask are not set,
kvm_arch_mmu_enable_log_dirty_pt_masked() has nothing to do. But since
it needs to be called from the generic code, it cannot be inlined, and
a few function calls, two when PML is enabled, are wasted.
Since it is common to see many pages remain clean, e.g. framebuffers can
stay calm for a long time, it is worth eliminating this overhead.
Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp>
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
guest.
When a VCPU is no longer running, we currently check to see if it has a
timer scheduled in the future, and if it does, we schedule a host
hrtimer to notify is in case the timer expires while the VCPU is still
not running. When the hrtimer fires, we mask the guest's timer and
inject the timer IRQ (still relying on the guest unmasking the time when
it receives the IRQ).
This is all good and fine, but when migration a VM (checkpoint/restore)
this introduces a race. It is unlikely, but possible, for the following
sequence of events to happen:
1. Userspace stops the VM
2. Hrtimer for VCPU is scheduled
3. Userspace checkpoints the VGIC state (no pending timer interrupts)
4. The hrtimer fires, schedules work in a workqueue
5. Workqueue function runs, masks the timer and injects timer interrupt
6. Userspace checkpoints the timer state (timer masked)
At restore time, you end up with a masked timer without any timer
interrupts and your guest halts never receiving timer interrupts.
Fix this by only kicking the VCPU in the workqueue function, and sample
the expired state of the timer when entering the guest again and inject
the interrupt and mask the timer only then.
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Alex Bennée <alex.bennee@linaro.org>
Migrating active interrupts causes the active state to be lost
completely. This implements some additional bitmaps to track the active
state on the distributor and export this to user space.
This helps re-factor away some of the repetitive code and makes the code
flow more nicely.
There is an interesting bug in the vgic code, which manifests itself
when the KVM run loop has a signal pending or needs a vmid generation
rollover after having disabled interrupts but before actually switching
to the guest.
In this case, we flush the vgic as usual, but we sync back the vgic
state and exit to userspace before entering the guest. The consequence
is that we will be syncing the list registers back to the software model
using the GICH_ELRSR and GICH_EISR from the last execution of the guest,
potentially overwriting a list register containing an interrupt.
This showed up during migration testing where we would capture a state
where the VM has masked the arch timer but there were no interrupts,
resulting in a hung test.
Cc: Marc Zyngier <marc.zyngier@arm.com>
Reported-by: Alex Bennee <alex.bennee@linaro.org>
Add the missing unlock before return from function kvm_vgic_create()
in the error handling case.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
This patch enables irqfd on arm/arm64.
Both irqfd and resamplefd are supported. Injection is implemented
in vgic.c without routing.
This patch enables CONFIG_HAVE_KVM_EVENTFD and CONFIG_HAVE_KVM_IRQFD.
KVM_CAP_IRQFD is now advertised. KVM_CAP_IRQFD_RESAMPLE capability
automatically is advertised as soon as CONFIG_HAVE_KVM_IRQFD is set.
Irqfd injection is restricted to SPI. The rationale behind not
supporting PPI irqfd injection is that any device using a PPI would
be a private-to-the-CPU device (timer for instance), so its state
would have to be context-switched along with the VCPU and would
require in-kernel wiring anyhow. It is not a relevant use case for
irqfds.
To prepare for irqfd addition, coarse grain locking is removed at
kvm_vgic_sync_hwstate level and finer grain locking is introduced in
vgic_process_maintenance only.
Introduce __KVM_HAVE_ARCH_INTC_INITIALIZED define and
associated kvm_arch_intc_initialized function. This latter
allows to test whether the virtual interrupt controller is initialized
and ready to accept virtual IRQ injection. On some architectures,
the virtual interrupt controller is dynamically instantiated, justifying
that kind of check.
The new function can now be used by irqfd to check whether the
virtual interrupt controller is ready on KVM_IRQFD request. If not,
KVM_IRQFD returns -EAGAIN.
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Several dts only list "arm,cortex-a7-gic" or "arm,gic-400" in their GIC
compatible list, and while this is correct (and supported by the GIC
driver), KVM will fail to detect that it can support these cases.
This patch adds the missing strings to the VGIC code. The of_device_id
entries are padded to keep the probe function data aligned.
Cc: Christoffer Dall <christoffer.dall@linaro.org>
POWER supports irqfds but forgot to advertise them. Some userspace does
not check for the capability, but others check it---thus they work on
x86 and s390 but not POWER.
To avoid that other architectures in the future make the same mistake, let
common code handle KVM_CAP_IRQFD the same way as KVM_CAP_IRQFD_RESAMPLE.
Reported-and-tested-by: Greg Kurz <gkurz@linux.vnet.ibm.com>
Fixes: 297e21053a52f060944e9f0de4c64fad9bcd72fc
WARNING: Prefer [subsystem eg: netdev]_info([subsystem]dev, ... then
dev_info(dev, ... then pr_info(... to printk(KERN_INFO ...
+ printk(KERN_INFO "kvm: exiting hardware virtualization\n");
WARNING: Prefer [subsystem eg: netdev]_err([subsystem]dev, ... then
dev_err(dev, ... then pr_err(... to printk(KERN_ERR ...
+ printk(KERN_ERR "kvm: misc device register failed\n");
ERROR: code indent should use tabs where possible
+ const struct kvm_io_range *r2)$
WARNING: please, no spaces at the start of a line
This patch fixes this ERROR & WARNING to reduce noise when checking new
patches in kvm_main.c.
WARNING: please, no space before tabs
+ * ^I^Ikvm->lock --> kvm->slots_lock --> kvm->irq_lock$
+^I^I * ^I- gfn_to_hva (kvm_read_guest, gfn_to_pfn)$
+^I^I * ^I- kvm_is_visible_gfn (mmu_check_roots)$
This patch fixes these warnings to reduce noise when checking new
There are many Warnings like this:
WARNING: Missing a blank line after declarations
+ struct kvm_coalesced_mmio_zone zone;
+ r = -EFAULT;
WARNING: EXPORT_SYMBOL(foo); should immediately follow its
function/variable
+EXPORT_SYMBOL_GPL(gfn_to_page);
ERROR: do not initialise statics to 0 or NULL
+static int kvm_usage_count = 0;
The kvm_usage_count will be placed to .bss segment when linking, so
not need to set it to 0 here obviously.
This patch fixes this ERROR to reduce noise when checking new patches
in kvm_main.c.
WARNING: labels should not be indented
+ out_free_irq_routing:
This patch fixes this WARNING to reduce noise when checking new patches
in kvm_main.c.
