path: root/virt
2012-02-01Merge remote-tracking branch 'origin/dev/k3.3-rc1-iommu' into ↵Rohan Somvanshi
android-tegra-nv-3.1 Change-Id: I9001bb291779f107bbcb593d48f9f0f734074d0e
2012-01-23iommu/core: split mapping to page sizes as supported by the hardwareOhad Ben-Cohen
When mapping a memory region, split it to page sizes as supported by the iommu hardware. Always prefer bigger pages, when possible, in order to reduce the TLB pressure. The logic to do that is now added to the IOMMU core, so neither the iommu drivers themselves nor users of the IOMMU API have to duplicate it. This allows a more lenient granularity of mappings; traditionally the IOMMU API took 'order' (of a page) as a mapping size, and directly let the low level iommu drivers handle the mapping, but now that the IOMMU core can split arbitrary memory regions into pages, we can remove this limitation, so users don't have to split those regions by themselves. Currently the supported page sizes are advertised once and they then remain static. That works well for OMAP and MSM but it would probably not fly well with intel's hardware, where the page size capabilities seem to have the potential to be different between several DMA remapping devices. register_iommu() currently sets a default pgsize behavior, so we can convert the IOMMU drivers in subsequent patches. After all the drivers are converted, the temporary default settings will be removed. Mainline users of the IOMMU API (kvm and omap-iovmm) are adopted to deal with bytes instead of page order. Many thanks to Joerg Roedel <Joerg.Roedel@amd.com> for significant review! Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Cc: David Brown <davidb@codeaurora.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Joerg Roedel <Joerg.Roedel@amd.com> Cc: Stepan Moskovchenko <stepanm@codeaurora.org> Cc: KyongHo Cho <pullip.cho@samsung.com> Cc: Hiroshi DOYU <hdoyu@nvidia.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: kvm@vger.kernel.org Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-01-23iommu/core: Convert iommu_found to iommu_presentJoerg Roedel
With per-bus iommu_ops the iommu_found function needs to work on a bus_type too. This patch adds a bus_type parameter to that function and converts all call-places. The function is also renamed to iommu_present because the function now checks if an iommu is present for a given bus and does not check for a global iommu anymore. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-01-23iommu/core: Add bus_type parameter to iommu_domain_allocJoerg Roedel
This is necessary to store a pointer to the bus-specific iommu_ops in the iommu-domain structure. It will be used later to call into bus-specific iommu-ops. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Conflicts: drivers/iommu/iommu.c Change-Id: Iddbd561739552b663a4be293f1992314eb0f775a
2012-01-18KVM: Device assignment permission checksAlex Williamson
(cherry picked from commit 3d27e23b17010c668db311140b17bbbb70c78fb9) Only allow KVM device assignment to attach to devices which: - Are not bridges - Have BAR resources (assume others are special devices) - The user has permissions to use Assigning a bridge is a configuration error, it's not supported, and typically doesn't result in the behavior the user is expecting anyway. Devices without BAR resources are typically chipset components that also don't have host drivers. We don't want users to hold such devices captive or cause system problems by fencing them off into an iommu domain. We determine "permission to use" by testing whether the user has access to the PCI sysfs resource files. By default a normal user will not have access to these files, so it provides a good indication that an administration agent has granted the user access to the device. [Yang Bai: add missing #include] [avi: fix comment style] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Yang Bai <hamo.by@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-18KVM: Remove ability to assign a device without iommu supportAlex Williamson
(cherry picked from commit 423873736b78f549fbfa2f715f2e4de7e6c5e1e9) This option has no users and it exposes a security hole that we can allow devices to be assigned without iommu protection. Make KVM_DEV_ASSIGN_ENABLE_IOMMU a mandatory option. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-24KVM: IOMMU: Disable device assignment without interrupt remappingAlex Williamson
IOMMU interrupt remapping support provides a further layer of isolation for device assignment by preventing arbitrary interrupt block DMA writes by a malicious guest from reaching the host. By default, we should require that the platform provides interrupt remapping support, with an opt-in mechanism for existing behavior. Both AMD IOMMU and Intel VT-d2 hardware support interrupt remapping, however we currently only have software support on the Intel side. Users wishing to re-enable device assignment when interrupt remapping is not supported on the platform can use the "allow_unsafe_assigned_interrupts=1" module option. [avi: break long lines] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-24KVM: MMU: mmio page fault supportXiao Guangrong
The idea is from Avi: | We could cache the result of a miss in an spte by using a reserved bit, and | checking the page fault error code (or seeing if we get an ept violation or | ept misconfiguration), so if we get repeated mmio on a page, we don't need to | search the slot list/tree. | (https://lkml.org/lkml/2011/2/22/221) When the page fault is caused by mmio, we cache the info in the shadow page table, and also set the reserved bits in the shadow page table, so if the mmio is caused again, we can quickly identify it and emulate it directly Searching mmio gfn in memslots is heavy since we need to walk all memeslots, it can be reduced by this feature, and also avoid walking guest page table for soft mmu. [jan: fix operator precedence issue] Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-24KVM: MMU: filter out the mmio pfn from the fault pfnXiao Guangrong
If the page fault is caused by mmio, the gfn can not be found in memslots, and 'bad_pfn' is returned on gfn_to_hva path, so we can use 'bad_pfn' to identify the mmio page fault. And, to clarify the meaning of mmio pfn, we return fault page instead of bad page when the gfn is not allowd to prefetch Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: introduce kvm_read_guest_cachedGleb Natapov
Introduce kvm_read_guest_cached() function in addition to write one we already have. [ by glauber: export function signature in kvm header ] Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Glauber Costa <glommer@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Tested-by: Eric Munson <emunson@mgebm.net> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: Fix off-by-one in overflow check of KVM_ASSIGN_SET_MSIX_NRJan Kiszka
KVM_MAX_MSIX_PER_DEV implies that up to that many MSI-X entries can be requested. But the kernel so far rejected already the upper limit. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: Add compat ioctl for KVM_SET_SIGNAL_MASKAlexander Graf
KVM has an ioctl to define which signal mask should be used while running inside VCPU_RUN. At least for big endian systems, this mask is different on 32-bit and 64-bit systems (though the size is identical). Add a compat wrapper that converts the mask to whatever the kernel accepts, allowing 32-bit kvm user space to set signal masks. This patch fixes qemu with --enable-io-thread on ppc64 hosts when running 32-bit user land. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: Clean up error handling during VCPU creationJan Kiszka
So far kvm_arch_vcpu_setup is responsible for freeing the vcpu struct if it fails. Move this confusing resonsibility back into the hands of kvm_vm_ioctl_create_vcpu. Only kvm_arch_vcpu_setup of x86 is affected, all other archs cannot fail. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-07-12KVM: use __copy_to_user/__clear_user to write guest pageXiao Guangrong
Simply use __copy_to_user/__clear_user to write guest page since we have already verified the user address when the memslot is set Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-06-07Merge branch 'kvm-updates/3.0' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/3.0' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: Initialize kvm before registering the mmu notifier KVM: x86: use proper port value when checking io instruction permission KVM: add missing void __user * cast to access_ok() call
2011-06-06KVM: Initialize kvm before registering the mmu notifierMike Waychison
It doesn't make sense to ever see a half-initialized kvm structure on mmu notifier callbacks. Previously, 85722cda changed the ordering to ensure that the mmu_lock was initialized before mmu notifier registration, but there is still a race where the mmu notifier could come in and try accessing other portions of struct kvm before they are intialized. Solve this by moving the mmu notifier registration to occur after the structure is completely initialized. Google-Bug-Id: 452199 Signed-off-by: Mike Waychison <mikew@google.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-26KVM: add missing void __user * cast to access_ok() callHeiko Carstens
fa3d315a "KVM: Validate userspace_addr of memslot when registered" introduced this new warning onn s390: kvm_main.c: In function '__kvm_set_memory_region': kvm_main.c:654:7: warning: passing argument 1 of '__access_ok' makes pointer from integer without a cast arch/s390/include/asm/uaccess.h:53:19: note: expected 'const void *' but argument is of type '__u64' Add the missing cast to get rid of it again... Cc: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) PCI: Don't use dmi_name_in_vendors in quirk PCI: remove unused AER functions PCI/sysfs: move bus cpuaffinity to class dev_attrs PCI: add rescan to /sys/.../pci_bus/.../ PCI: update bridge resources to get more big ranges when allocating space (again) KVM: Use pci_store/load_saved_state() around VM device usage PCI: Add interfaces to store and load the device saved state PCI: Track the size of each saved capability data area PCI/e1000e: Add and use pci_disable_link_state_locked() x86/PCI: derive pcibios_last_bus from ACPI MCFG PCI: add latency tolerance reporting enable/disable support PCI: add OBFF enable/disable support PCI: add ID-based ordering enable/disable support PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot. PCI: Set PCIE maxpayload for card during hotplug insertion PCI/ACPI: Report _OSC control mask returned on failure to get control x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs PCI: handle positive error codes PCI: check pci_vpd_pci22_wait() return PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio ... Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461 moved the intel SMBUS ID definitons to the i2c-i801.c driver.
2011-05-22KVM: Fix kvm mmu_notifier initialization orderOGAWA Hirofumi
Like the following, mmu_notifier can be called after registering immediately. So, kvm have to initialize kvm->mmu_lock before it. BUG: spinlock bad magic on CPU#0, kswapd0/342 lock: ffff8800af8c4000, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0 Pid: 342, comm: kswapd0 Not tainted 2.6.39-rc5+ #1 Call Trace: [<ffffffff8118ce61>] spin_bug+0x9c/0xa3 [<ffffffff8118ce91>] do_raw_spin_lock+0x29/0x13c [<ffffffff81024923>] ? flush_tlb_others_ipi+0xaf/0xfd [<ffffffff812e22f3>] _raw_spin_lock+0x9/0xb [<ffffffffa0582325>] kvm_mmu_notifier_clear_flush_young+0x2c/0x66 [kvm] [<ffffffff810d3ff3>] __mmu_notifier_clear_flush_young+0x2b/0x57 [<ffffffff810c8761>] page_referenced_one+0x88/0xea [<ffffffff810c89bf>] page_referenced+0x1fc/0x256 [<ffffffff810b2771>] shrink_page_list+0x187/0x53a [<ffffffff810b2ed7>] shrink_inactive_list+0x1e0/0x33d [<ffffffff810acf95>] ? determine_dirtyable_memory+0x15/0x27 [<ffffffff812e90ee>] ? call_function_single_interrupt+0xe/0x20 [<ffffffff810b3356>] shrink_zone+0x322/0x3de [<ffffffff810a9587>] ? zone_watermark_ok_safe+0xe2/0xf1 [<ffffffff810b3928>] kswapd+0x516/0x818 [<ffffffff810b3412>] ? shrink_zone+0x3de/0x3de [<ffffffff81053d17>] kthread+0x7d/0x85 [<ffffffff812e9394>] kernel_thread_helper+0x4/0x10 [<ffffffff81053c9a>] ? __init_kthread_worker+0x37/0x37 [<ffffffff812e9390>] ? gs_change+0xb/0xb Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: Validate userspace_addr of memslot when registeredTakuya Yoshikawa
This way, we can avoid checking the user space address many times when we read the guest memory. Although we can do the same for write if we check which slots are writable, we do not care write now: reading the guest memory happens more often than writing. [avi: change VERIFY_READ to VERIFY_WRITE] Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-22KVM: ioapic: Fix an error field referenceLiu Yuan
Function ioapic_debug() in the ioapic_deliver() misnames one filed by reference. This patch correct it. Signed-off-by: Liu Yuan <tailai.ly@taobao.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-05-21KVM: Use pci_store/load_saved_state() around VM device usageAlex Williamson
Store the device saved state so that we can reload the device back to the original state when it's unassigned. This has the benefit that the state survives across pci_reset_function() calls via the PCI sysfs reset interface while the VM is using the device. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Avi Kivity <avi@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-11KVM: cleanup memslot_id functionXiao Guangrong
We can get memslot id from memslot->id directly Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-04-07Merge branch 'kvm-updates/2.6.39' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.39' of git://git.kernel.org/pub/scm/virt/kvm/kvm: KVM: move and fix substitue search for missing CPUID entries KVM: fix XSAVE bit scanning KVM: Enable async page fault processing KVM: fix crash on irqfd deassign
2011-04-06KVM: Enable async page fault processingGleb Natapov
If asynchronous hva_to_pfn() is requested call GUP with FOLL_NOWAIT to avoid sleeping on IO. Check for hwpoison is done at the same time, otherwise check_user_page_hwpoison() will call GUP again and will put vcpu to sleep. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-04-06KVM: fix crash on irqfd deassignMichael S. Tsirkin
irqfd in kvm used flush_work incorrectly: it assumed that work scheduled previously can't run after flush_work, but since kvm uses a non-reentrant workqueue (by means of schedule_work) we need flush_work_sync to get that guarantee. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Reported-by: Jean-Philippe Menil <jean-philippe.menil@univ-nantes.fr> Tested-by: Jean-Philippe Menil <jean-philippe.menil@univ-nantes.fr> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-25Merge branch 'syscore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'syscore' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: Introduce ARCH_NO_SYSDEV_OPS config option (v2) cpufreq: Use syscore_ops for boot CPU suspend/resume (v2) KVM: Use syscore_ops instead of sysdev class and sysdev PCI / Intel IOMMU: Use syscore_ops instead of sysdev class and sysdev timekeeping: Use syscore_ops instead of sysdev class and sysdev x86: Use syscore_ops instead of sysdev classes and sysdevs
2011-03-23kvm: use little-endian bitopsAkinobu Mita
As a preparation for removing ext2 non-atomic bit operations from asm/bitops.h. This converts ext2 non-atomic bit operations to little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23kvm: stop including asm-generic/bitops/le.h directlyAkinobu Mita
asm-generic/bitops/le.h is only intended to be included directly from asm-generic/bitops/ext2-non-atomic.h or asm-generic/bitops/minix-le.h which implements generic ext2 or minix bit operations. This stops including asm-generic/bitops/le.h directly and use ext2 non-atomic bit operations instead. It seems odd to use ext2_set_bit() on kvm, but it will replaced with __set_bit_le() after introducing little endian bit operations for all architectures. This indirect step is necessary to maintain bisectability for some architectures which have their own little-endian bit operations. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23KVM: Use syscore_ops instead of sysdev class and sysdevRafael J. Wysocki
KVM uses a sysdev class and a sysdev for executing kvm_suspend() after interrupts have been turned off on the boot CPU (during system suspend) and for executing kvm_resume() before turning on interrupts on the boot CPU (during system resume). However, since both of these functions ignore their arguments, the entire mechanism may be replaced with a struct syscore_ops object which is simpler. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: improve comment on rcu use in irqfd_deassignMichael S. Tsirkin
The RCU use in kvm_irqfd_deassign is tricky: we have rcu_assign_pointer but no synchronize_rcu: synchronize_rcu is done by kvm_irq_routing_update which we share a spinlock with. Fix up a comment in an attempt to make this clearer. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: Convert kvm_lock to raw_spinlockJan Kiszka
Code under this lock requires non-preemptibility. Ensure this also over -rt by converting it to raw spinlock. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: use yield_to instead of sleep in kvm_vcpu_on_spinRik van Riel
Instead of sleeping in kvm_vcpu_on_spin, which can cause gigantic slowdowns of certain workloads, we instead use yield_to to get another VCPU in the same KVM guest to run sooner. This seems to give a 10-15% speedup in certain workloads. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: keep track of which task is running a KVM vcpuRik van Riel
Keep track of which task is running a KVM vcpu. This helps us figure out later what task to wake up if we want to boost a vcpu that got preempted. Unfortunately there are no guarantees that the same task always keeps the same vcpu, so we can only track the task across a single "run" of the vcpu. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: Replace is_hwpoison_address with __get_user_pagesHuang Ying
is_hwpoison_address only checks whether the page table entry is hwpoisoned, regardless the memory page mapped. While __get_user_pages will check both. QEMU will clear the poisoned page table entry (via unmap/map) to make it possible to allocate a new memory page for the virtual address across guest rebooting. But it is also possible that the underlying memory page is kept poisoned even after the corresponding page table entry is cleared, that is, a new memory page can not be allocated. __get_user_pages can catch these situations. Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-03-17KVM: make make_all_cpus_request() locklessXiao Guangrong
Now, we have 'vcpu->mode' to judge whether need to send ipi to other cpus, this way is very exact, so checking request bit is needless, then we can drop the spinlock let it's collateral Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: Add "exiting guest mode" stateXiao Guangrong
Currently we keep track of only two states: guest mode and host mode. This patch adds an "exiting guest mode" state that tells us that an IPI will happen soon, so unless we need to wait for the IPI, we can avoid it completely. Also 1: No need atomically to read/write ->mode in vcpu's thread 2: reorganize struct kvm_vcpu to make ->mode and ->requests in the same cache line explicitly Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-03-17KVM: fix build warning within __kvm_set_memory_region() on s390Heiko Carstens
Get rid of this warning: CC arch/s390/kvm/../../../virt/kvm/kvm_main.o arch/s390/kvm/../../../virt/kvm/kvm_main.c:596:12: warning: 'kvm_create_dirty_bitmap' defined but not used The only caller of the function is within a !CONFIG_S390 section, so add the same ifdef around kvm_create_dirty_bitmap() as well. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-03-17KVM: MMU: Don't flush shadow when enabling dirty trackingAvi Kivity
Instead, drop large mappings, which were the reason we dropped shadow. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-13thp: add compound_trans_head() helperAndrea Arcangeli
Cleanup some code with common compound_trans_head helper. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <jweiner@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Cc: Avi Kivity <avi@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: mmu_notifier_test_youngAndrea Arcangeli
For GRU and EPT, we need gup-fast to set referenced bit too (this is why it's correct to return 0 when shadow_access_mask is zero, it requires gup-fast to set the referenced bit). qemu-kvm access already sets the young bit in the pte if it isn't zero-copy, if it's zero copy or a shadow paging EPT minor fault we relay on gup-fast to signal the page is in use... We also need to check the young bits on the secondary pagetables for NPT and not nested shadow mmu as the data may never get accessed again by the primary pte. Without this closer accuracy, we'd have to remove the heuristic that avoids collapsing hugepages in hugepage virtual regions that have not even a single subpage in use. ->test_young is full backwards compatible with GRU and other usages that don't have young bits in pagetables set by the hardware and that should nuke the secondary mmu mappings when ->clear_flush_young runs just like EPT does. Removing the heuristic that checks the young bit in khugepaged/collapse_huge_page completely isn't so bad either probably but I thought it was worth it and this makes it reliable. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-13thp: kvm mmu transparent hugepage supportAndrea Arcangeli
This should work for both hugetlbfs and transparent hugepages. [akpm@linux-foundation.org: bring forward PageTransCompound() addition for bisectability] Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Cc: Avi Kivity <avi@redhat.com> Cc: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12KVM: Don't spin on virt instruction faults during rebootAvi Kivity
Since vmx blocks INIT signals, we disable virtualization extensions during reboot. This leads to virtualization instructions faulting; we trap these faults and spin while the reboot continues. Unfortunately spinning on a non-preemptible kernel may block a task that reboot depends on; this causes the reboot to hang. Fix by skipping over the instruction and hoping for the best. Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: MMU: delay flush all tlbs on sync_page pathXiao Guangrong
Quote from Avi: | I don't think we need to flush immediately; set a "tlb dirty" bit somewhere | that is cleareded when we flush the tlb. kvm_mmu_notifier_invalidate_page() | can consult the bit and force a flush if set. Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: fast-path msi injection with irqfdMichael S. Tsirkin
Store irq routing table pointer in the irqfd object, and use that to inject MSI directly without bouncing out to a kernel thread. While we touch this structure, rearrange irqfd fields to make fastpath better packed for better cache utilization. This also adds some comments about locking rules and rcu usage in code. Some notes on the design: - Use pointer into the rt instead of copying an entry, to make it possible to use rcu, thus side-stepping locking complexities. We also save some memory this way. - Old workqueue code is still used for level irqs. I don't think we DTRT with level anyway, however, it seems easier to keep the code around as it has been thought through and debugged, and fix level later than rip out and re-instate it later. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Acked-by: Marcelo Tosatti <mtosatti@redhat.com> Acked-by: Gregory Haskins <ghaskins@novell.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-01-12KVM: rename hardware_[dis|en]able() to *_nolock() and add locking wrappersTakuya Yoshikawa
The naming convension of hardware_[dis|en]able family is little bit confusing because only hardware_[dis|en]able_all are using _nolock suffix. Renaming current hardware_[dis|en]able() to *_nolock() and using hardware_[dis|en]able() as wrapper functions which take kvm_lock for them reduces extra confusion. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: take kvm_lock for hardware_disable() during cpu hotplugTakuya Yoshikawa
In kvm_cpu_hotplug(), only CPU_STARTING case is protected by kvm_lock. This patch adds missing protection for CPU_DYING case. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Clean up kvm_vm_ioctl_assigned_deviceJan Kiszka
Any arch not supporting device assigment will also not build assigned-dev.c. So testing for KVM_CAP_DEVICE_DEASSIGNMENT is pointless. KVM_CAP_ASSIGN_DEV_IRQ is unconditinally set. Moreover, add a default case for dispatching the ioctl. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-01-12KVM: Save/restore state of assigned PCI deviceJan Kiszka
The guest may change states that pci_reset_function does not touch. So we better save/restore the assigned device across guest usage. Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
