path: root/virt
2016-08-19KVM: nVMX: Fix memory corruption when using VMCS shadowingJim Mattson
[ Upstream commit 2f1fe81123f59271bddda673b60116bde9660385 ] When freeing the nested resources of a vcpu, there is an assumption that the vcpu's vmcs01 is the current VMCS on the CPU that executes nested_release_vmcs12(). If this assumption is violated, the vcpu's vmcs01 may be made active on multiple CPUs at the same time, in violation of Intel's specification. Moreover, since the vcpu's vmcs01 is not VMCLEARed on every CPU on which it is active, it can linger in a CPU's VMCS cache after it has been freed and potentially repurposed. Subsequent eviction from the CPU's VMCS cache on a capacity miss can result in memory corruption. It is not sufficient for vmx_free_vcpu() to call vmx_load_vmcs01(). If the vcpu in question was last loaded on a different CPU, it must be migrated to the current CPU before calling vmx_load_vmcs01(). Signed-off-by: Jim Mattson <jmattson@google.com> Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com>
2016-07-10kvm: Fix irq route entries exceeding KVM_MAX_IRQ_ROUTESXiubo Li
[ Upstream commit caf1ff26e1aa178133df68ac3d40815fed2187d9 ] These days, we experienced one guest crash with 8 cores and 3 disks, with qemu error logs as bellow: qemu-system-x86_64: /build/qemu-2.0.0/kvm-all.c:984: kvm_irqchip_commit_routes: Assertion `ret == 0' failed. And then we found one patch(bdf026317d) in qemu tree, which said could fix this bug. Execute the following script will reproduce the BUG quickly: irq_affinity.sh ======================================================================== vda_irq_num=25 vdb_irq_num=27 while [ 1 ] do for irq in {1,2,4,8,10,20,40,80} do echo $irq > /proc/irq/$vda_irq_num/smp_affinity echo $irq > /proc/irq/$vdb_irq_num/smp_affinity dd if=/dev/vda of=/dev/zero bs=4K count=100 iflag=direct dd if=/dev/vdb of=/dev/zero bs=4K count=100 iflag=direct done done ======================================================================== The following qemu log is added in the qemu code and is displayed when this bug reproduced: kvm_irqchip_commit_routes: max gsi: 1008, nr_allocated_irq_routes: 1024, irq_routes->nr: 1024, gsi_count: 1024. That's to say when irq_routes->nr == 1024, there are 1024 routing entries, but in the kernel code when routes->nr >= 1024, will just return -EINVAL; The nr is the number of the routing entries which is in of [1 ~ KVM_MAX_IRQ_ROUTES], not the index in [0 ~ KVM_MAX_IRQ_ROUTES - 1]. This patch fix the BUG above. Cc: stable@vger.kernel.org Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com> Signed-off-by: Wei Tang <tangwei@cmss.chinamobile.com> Signed-off-by: Zhang Zhuoyu <zhangzhuoyu@cmss.chinamobile.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-06-17KVM: irqfd: fix NULL pointer dereference in kvm_irq_map_gsiPaolo Bonzini
[ Upstream commit c622a3c21ede892e370b56e1ceb9eb28f8bbda6b ] Found by syzkaller: BUG: unable to handle kernel NULL pointer dereference at 0000000000000120 IP: [<ffffffffa0797202>] kvm_irq_map_gsi+0x12/0x90 [kvm] PGD 6f80b067 PUD b6535067 PMD 0 Oops: 0000 [#1] SMP CPU: 3 PID: 4988 Comm: a.out Not tainted 4.4.9-300.fc23.x86_64 #1 [...] Call Trace: [<ffffffffa0795f62>] irqfd_update+0x32/0xc0 [kvm] [<ffffffffa0796c7c>] kvm_irqfd+0x3dc/0x5b0 [kvm] [<ffffffffa07943f4>] kvm_vm_ioctl+0x164/0x6f0 [kvm] [<ffffffff81241648>] do_vfs_ioctl+0x298/0x480 [<ffffffff812418a9>] SyS_ioctl+0x79/0x90 [<ffffffff817a1062>] tracesys_phase2+0x84/0x89 Code: b5 71 a7 e0 5b 41 5c 41 5d 5d f3 c3 66 66 66 66 2e 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 55 48 8b 8f 10 2e 00 00 31 c0 48 89 e5 <39> 91 20 01 00 00 76 6a 48 63 d2 48 8b 94 d1 28 01 00 00 48 85 RIP [<ffffffffa0797202>] kvm_irq_map_gsi+0x12/0x90 [kvm] RSP <ffff8800926cbca8> CR2: 0000000000000120 Testcase: #include <unistd.h> #include <sys/syscall.h> #include <string.h> #include <stdint.h> #include <linux/kvm.h> #include <fcntl.h> #include <sys/ioctl.h> long r[26]; int main() { memset(r, -1, sizeof(r)); r[2] = open("/dev/kvm", 0); r[3] = ioctl(r[2], KVM_CREATE_VM, 0); struct kvm_irqfd ifd; ifd.fd = syscall(SYS_eventfd2, 5, 0); ifd.gsi = 3; ifd.flags = 2; ifd.resamplefd = ifd.fd; r[25] = ioctl(r[3], KVM_IRQFD, &ifd); return 0; } Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: stable@vger.kernel.org Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-04-18KVM: fix spin_lock_init order on x86Paolo Bonzini
[ Upstream commit e9ad4ec8379ad1ba6f68b8ca1c26b50b5ae0a327 ] Moving the initialization earlier is needed in 4.6 because kvm_arch_init_vm is now using mmu_lock, causing lockdep to complain: [ 284.440294] INFO: trying to register non-static key. [ 284.445259] the code is fine but needs lockdep annotation. [ 284.450736] turning off the locking correctness validator. ... [ 284.528318] [<ffffffff810aecc3>] lock_acquire+0xd3/0x240 [ 284.533733] [<ffffffffa0305aa0>] ? kvm_page_track_register_notifier+0x20/0x60 [kvm] [ 284.541467] [<ffffffff81715581>] _raw_spin_lock+0x41/0x80 [ 284.546960] [<ffffffffa0305aa0>] ? kvm_page_track_register_notifier+0x20/0x60 [kvm] [ 284.554707] [<ffffffffa0305aa0>] kvm_page_track_register_notifier+0x20/0x60 [kvm] [ 284.562281] [<ffffffffa02ece70>] kvm_mmu_init_vm+0x20/0x30 [kvm] [ 284.568381] [<ffffffffa02dbf7a>] kvm_arch_init_vm+0x1ea/0x200 [kvm] [ 284.574740] [<ffffffffa02bff3f>] kvm_dev_ioctl+0xbf/0x4d0 [kvm] However, it also helps fixing a preexisting problem, which is why this patch is also good for stable kernels: kvm_create_vm was incrementing current->mm->mm_count but not decrementing it at the out_err label (in case kvm_init_mmu_notifier failed). The new initialization order makes it possible to add the required mmdrop without adding a new error label. Cc: stable@vger.kernel.org Reported-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-03-07KVM: async_pf: do not warn on page allocation failuresChristian Borntraeger
[ Upstream commit d7444794a02ff655eda87e3cc54e86b940e7736f ] In async_pf we try to allocate with NOWAIT to get an element quickly or fail. This code also handle failures gracefully. Lets silence potential page allocation failures under load. qemu-system-s39: page allocation failure: order:0,mode:0x2200000 [...] Call Trace: ([<00000000001146b8>] show_trace+0xf8/0x148) [<000000000011476a>] show_stack+0x62/0xe8 [<00000000004a36b8>] dump_stack+0x70/0x98 [<0000000000272c3a>] warn_alloc_failed+0xd2/0x148 [<000000000027709e>] __alloc_pages_nodemask+0x94e/0xb38 [<00000000002cd36a>] new_slab+0x382/0x400 [<00000000002cf7ac>] ___slab_alloc.constprop.30+0x2dc/0x378 [<00000000002d03d0>] kmem_cache_alloc+0x160/0x1d0 [<0000000000133db4>] kvm_setup_async_pf+0x6c/0x198 [<000000000013dee8>] kvm_arch_vcpu_ioctl_run+0xd48/0xd58 [<000000000012fcaa>] kvm_vcpu_ioctl+0x372/0x690 [<00000000002f66f6>] do_vfs_ioctl+0x3be/0x510 [<00000000002f68ec>] SyS_ioctl+0xa4/0xb8 [<0000000000781c5e>] system_call+0xd6/0x264 [<000003ffa24fa06a>] 0x3ffa24fa06a Cc: stable@vger.kernel.org Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Reviewed-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2016-03-07KVM: arm/arm64: vgic: Ensure bitmaps are long enoughMark Rutland
[ Upstream commit 236cf17c2502007a9d2dda3c39fb0d9a6bd03cc2 ] When we allocate bitmaps in vgic_vcpu_init_maps, we divide the number of bits we need by 8 to figure out how many bytes to allocate. However, bitmap elements are always accessed as unsigned longs, and if we didn't happen to allocate a size such that size % sizeof(unsigned long) == 0, bitmap accesses may go past the end of the allocation. When using KASAN (which does byte-granular access checks), this results in a continuous stream of BUGs whenever these bitmaps are accessed: ============================================================================= BUG kmalloc-128 (Tainted: G B ): kasan: bad access detected ----------------------------------------------------------------------------- INFO: Allocated in vgic_init.part.25+0x55c/0x990 age=7493 cpu=3 pid=1730 INFO: Slab 0xffffffbde6d5da40 objects=16 used=15 fp=0xffffffc935769700 flags=0x4000000000000080 INFO: Object 0xffffffc935769500 @offset=1280 fp=0x (null) Bytes b4 ffffffc9357694f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Object ffffffc935769500: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Object ffffffc935769510: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Object ffffffc935769520: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Object ffffffc935769530: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Object ffffffc935769540: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Object ffffffc935769550: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Object ffffffc935769560: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Object ffffffc935769570: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Padding ffffffc9357695b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Padding ffffffc9357695c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Padding ffffffc9357695d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Padding ffffffc9357695e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Padding ffffffc9357695f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ CPU: 3 PID: 1740 Comm: kvm-vcpu-0 Tainted: G B 4.4.0+ #17 Hardware name: ARM Juno development board (r1) (DT) Call trace: [<ffffffc00008e770>] dump_backtrace+0x0/0x280 [<ffffffc00008ea04>] show_stack+0x14/0x20 [<ffffffc000726360>] dump_stack+0x100/0x188 [<ffffffc00030d324>] print_trailer+0xfc/0x168 [<ffffffc000312294>] object_err+0x3c/0x50 [<ffffffc0003140fc>] kasan_report_error+0x244/0x558 [<ffffffc000314548>] __asan_report_load8_noabort+0x48/0x50 [<ffffffc000745688>] __bitmap_or+0xc0/0xc8 [<ffffffc0000d9e44>] kvm_vgic_flush_hwstate+0x1bc/0x650 [<ffffffc0000c514c>] kvm_arch_vcpu_ioctl_run+0x2ec/0xa60 [<ffffffc0000b9a6c>] kvm_vcpu_ioctl+0x474/0xa68 [<ffffffc00036b7b0>] do_vfs_ioctl+0x5b8/0xcb0 [<ffffffc00036bf34>] SyS_ioctl+0x8c/0xa0 [<ffffffc000086cb0>] el0_svc_naked+0x24/0x28 Memory state around the buggy address: ffffffc935769400: 00 00 fc fc fc fc fc fc fc fc fc fc fc fc fc fc ffffffc935769480: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc >ffffffc935769500: 04 fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc ^ ffffffc935769580: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc ffffffc935769600: 00 00 00 00 fc fc fc fc fc fc fc fc fc fc fc fc ================================================================== Fix the issue by always allocating a multiple of sizeof(unsigned long), as we do elsewhere in the vgic code. Fixes: c1bfb577a ("arm/arm64: KVM: vgic: switch to dynamic allocation") Cc: stable@vger.kernel.org Acked-by: Marc Zyngier <marc.zyngier@arm.com> Acked-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Sasha Levin <sasha.levin@oracle.com>
2015-10-22kvm: fix double free for fast mmio eventfdJason Wang
commit eefd6b06b17c5478e7c24bea6f64beaa2c431ca6 upstream. We register wildcard mmio eventfd on two buses, once for KVM_MMIO_BUS and once on KVM_FAST_MMIO_BUS but with a single iodev instance. This will lead to an issue: kvm_io_bus_destroy() knows nothing about the devices on two buses pointing to a single dev. Which will lead to double free[1] during exit. Fix this by allocating two instances of iodevs then registering one on KVM_MMIO_BUS and another on KVM_FAST_MMIO_BUS. CPU: 1 PID: 2894 Comm: qemu-system-x86 Not tainted 3.19.0-26-generic #28-Ubuntu Hardware name: LENOVO 2356BG6/2356BG6, BIOS G7ET96WW (2.56 ) 09/12/2013 task: ffff88009ae0c4b0 ti: ffff88020e7f0000 task.ti: ffff88020e7f0000 RIP: 0010:[<ffffffffc07e25d8>] [<ffffffffc07e25d8>] ioeventfd_release+0x28/0x60 [kvm] RSP: 0018:ffff88020e7f3bc8 EFLAGS: 00010292 RAX: dead000000200200 RBX: ffff8801ec19c900 RCX: 000000018200016d RDX: ffff8801ec19cf80 RSI: ffffea0008bf1d40 RDI: ffff8801ec19c900 RBP: ffff88020e7f3bd8 R08: 000000002fc75a01 R09: 000000018200016d R10: ffffffffc07df6ae R11: ffff88022fc75a98 R12: ffff88021e7cc000 R13: ffff88021e7cca48 R14: ffff88021e7cca50 R15: ffff8801ec19c880 FS: 00007fc1ee3e6700(0000) GS:ffff88023e240000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00007f8f389d8000 CR3: 000000023dc13000 CR4: 00000000001427e0 Stack: ffff88021e7cc000 0000000000000000 ffff88020e7f3be8 ffffffffc07e2622 ffff88020e7f3c38 ffffffffc07df69a ffff880232524160 ffff88020e792d80 0000000000000000 ffff880219b78c00 0000000000000008 ffff8802321686a8 Call Trace: [<ffffffffc07e2622>] ioeventfd_destructor+0x12/0x20 [kvm] [<ffffffffc07df69a>] kvm_put_kvm+0xca/0x210 [kvm] [<ffffffffc07df818>] kvm_vcpu_release+0x18/0x20 [kvm] [<ffffffff811f69f7>] __fput+0xe7/0x250 [<ffffffff811f6bae>] ____fput+0xe/0x10 [<ffffffff81093f04>] task_work_run+0xd4/0xf0 [<ffffffff81079358>] do_exit+0x368/0xa50 [<ffffffff81082c8f>] ? recalc_sigpending+0x1f/0x60 [<ffffffff81079ad5>] do_group_exit+0x45/0xb0 [<ffffffff81085c71>] get_signal+0x291/0x750 [<ffffffff810144d8>] do_signal+0x28/0xab0 [<ffffffff810f3a3b>] ? do_futex+0xdb/0x5d0 [<ffffffff810b7028>] ? __wake_up_locked_key+0x18/0x20 [<ffffffff810f3fa6>] ? SyS_futex+0x76/0x170 [<ffffffff81014fc9>] do_notify_resume+0x69/0xb0 [<ffffffff817cb9af>] int_signal+0x12/0x17 Code: 5d c3 90 0f 1f 44 00 00 55 48 89 e5 53 48 89 fb 48 83 ec 08 48 8b 7f 20 e8 06 d6 a5 c0 48 8b 43 08 48 8b 13 48 89 df 48 89 42 08 <48> 89 10 48 b8 00 01 10 00 00 RIP [<ffffffffc07e25d8>] ioeventfd_release+0x28/0x60 [kvm] RSP <ffff88020e7f3bc8> Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22kvm: factor out core eventfd assign/deassign logicJason Wang
commit 85da11ca587c8eb73993a1b503052391a73586f9 upstream. This patch factors out core eventfd assign/deassign logic and leaves the argument checking and bus index selection to callers. Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22kvm: fix zero length mmio searchingJason Wang
commit 8f4216c7d28976f7ec1b2bcbfa0a9f787133c45e upstream. Currently, if we had a zero length mmio eventfd assigned on KVM_MMIO_BUS. It will never be found by kvm_io_bus_cmp() since it always compares the kvm_io_range() with the length that guest wrote. This will cause e.g for vhost, kick will be trapped by qemu userspace instead of vhost. Fixing this by using zero length if an iodevice is zero length. Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22kvm: don't try to register to KVM_FAST_MMIO_BUS for non mmio eventfdJason Wang
commit 8453fecbecae26edb3f278627376caab05d9a88d upstream. We only want zero length mmio eventfd to be registered on KVM_FAST_MMIO_BUS. So check this explicitly when arg->len is zero to make sure this. Cc: Gleb Natapov <gleb@kernel.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Jason Wang <jasowang@redhat.com> Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-10KVM: arm/arm64: vgic: Avoid injecting reserved IRQ numbersMarc Zyngier
commit 4839ddc27b7212ec58874f62c97da7400c8523be upstream. Commit fd1d0ddf2ae9 (KVM: arm/arm64: check IRQ number on userland injection) rightly limited the range of interrupts userspace can inject in a guest, but failed to consider the (unlikely) case where a guest is configured with 1024 interrupts. In this case, interrupts ranging from 1020 to 1023 are unuseable, as they have a special meaning for the GIC CPU interface. Make sure that these number cannot be used as an IRQ. Also delete a redundant (and similarily buggy) check in kvm_set_irq. Reported-by: Peter Maydell <peter.maydell@linaro.org> Cc: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-22Merge tag 'kvm-arm-for-4.1-take2' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master KVM/ARM changes for v4.1, take #2: Rather small this time: - a fix for a nasty bug with virtual IRQ injection - a fix for irqfd
2015-04-22KVM: arm/arm64: check IRQ number on userland injectionAndre Przywara
When userland injects a SPI via the KVM_IRQ_LINE ioctl we currently only check it against a fixed limit, which historically is set to 127. With the new dynamic IRQ allocation the effective limit may actually be smaller (64). So when now a malicious or buggy userland injects a SPI in that range, we spill over on our VGIC bitmaps and bytemaps memory. I could trigger a host kernel NULL pointer dereference with current mainline by injecting some bogus IRQ number from a hacked kvmtool: ----------------- .... DEBUG: kvm_vgic_inject_irq(kvm, cpu=0, irq=114, level=1) DEBUG: vgic_update_irq_pending(kvm, cpu=0, irq=114, level=1) DEBUG: IRQ #114 still in the game, writing to bytemap now... Unable to handle kernel NULL pointer dereference at virtual address 00000000 pgd = ffffffc07652e000 [00000000] *pgd=00000000f658b003, *pud=00000000f658b003, *pmd=0000000000000000 Internal error: Oops: 96000006 [#1] PREEMPT SMP Modules linked in: CPU: 1 PID: 1053 Comm: lkvm-msi-irqinj Not tainted 4.0.0-rc7+ #3027 Hardware name: FVP Base (DT) task: ffffffc0774e9680 ti: ffffffc0765a8000 task.ti: ffffffc0765a8000 PC is at kvm_vgic_inject_irq+0x234/0x310 LR is at kvm_vgic_inject_irq+0x30c/0x310 pc : [<ffffffc0000ae0a8>] lr : [<ffffffc0000ae180>] pstate: 80000145 ..... So this patch fixes this by checking the SPI number against the actual limit. Also we remove the former legacy hard limit of 127 in the ioctl code. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> CC: <stable@vger.kernel.org> # 4.0, 3.19, 3.18 [maz: wrap KVM_ARM_IRQ_GIC_MAX with #ifndef __KERNEL__, as suggested by Christopher Covington] Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-04-22KVM: arm: irqfd: fix value returned by kvm_irq_map_gsiEric Auger
irqfd/arm curently does not support routing. kvm_irq_map_gsi is supposed to return all the routing entries associated with the provided gsi and return the number of those entries. We should return 0 at this point. Signed-off-by: Eric Auger <eric.auger@linaro.org> Acked-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-04-21KVM: PPC: Book3S HV: Create debugfs file for each guest's HPTPaul Mackerras
This creates a debugfs directory for each HV guest (assuming debugfs is enabled in the kernel config), and within that directory, a file by which the contents of the guest's HPT (hashed page table) can be read. The directory is named vmnnnn, where nnnn is the PID of the process that created the guest. The file is named "htab". This is intended to help in debugging problems in the host's management of guest memory. The contents of the file consist of a series of lines like this: 3f48 4000d032bf003505 0000000bd7ff1196 00000003b5c71196 The first field is the index of the entry in the HPT, the second and third are the HPT entry, so the third entry contains the real page number that is mapped by the entry if the entry's valid bit is set. The fourth field is the guest's view of the second doubleword of the entry, so it contains the guest physical address. (The format of the second through fourth fields are described in the Power ISA and also in arch/powerpc/include/asm/mmu-hash64.h.) Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2015-04-13Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Paolo Bonzini: "First batch of KVM changes for 4.1 The most interesting bit here is irqfd/ioeventfd support for ARM and ARM64. Summary: ARM/ARM64: fixes for live migration, irqfd and ioeventfd support (enabling vhost, too), page aging s390: interrupt handling rework, allowing to inject all local interrupts via new ioctl and to get/set the full local irq state for migration and introspection. New ioctls to access memory by virtual address, and to get/set the guest storage keys. SIMD support. MIPS: FPU and MIPS SIMD Architecture (MSA) support. Includes some patches from Ralf Baechle's MIPS tree. x86: bugfixes (notably for pvclock, the others are small) and cleanups. Another small latency improvement for the TSC deadline timer" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (146 commits) KVM: use slowpath for cross page cached accesses kvm: mmu: lazy collapse small sptes into large sptes KVM: x86: Clear CR2 on VCPU reset KVM: x86: DR0-DR3 are not clear on reset KVM: x86: BSP in MSR_IA32_APICBASE is writable KVM: x86: simplify kvm_apic_map KVM: x86: avoid logical_map when it is invalid KVM: x86: fix mixed APIC mode broadcast KVM: x86: use MDA for interrupt matching kvm/ppc/mpic: drop unused IRQ_testbit KVM: nVMX: remove unnecessary double caching of MAXPHYADDR KVM: nVMX: checks for address bits beyond MAXPHYADDR on VM-entry KVM: x86: cache maxphyaddr CPUID leaf in struct kvm_vcpu KVM: vmx: pass error code with internal error #2 x86: vdso: fix pvclock races with task migration KVM: remove kvm_read_hva and kvm_read_hva_atomic KVM: x86: optimize delivery of TSC deadline timer interrupt KVM: x86: extract blocking logic from __vcpu_run kvm: x86: fix x86 eflags fixed bit KVM: s390: migrate vcpu interrupt state ...
2015-04-10KVM: use slowpath for cross page cached accessesRadim Krčmář
kvm_write_guest_cached() does not mark all written pages as dirty and code comments in kvm_gfn_to_hva_cache_init() talk about NULL memslot with cross page accesses. Fix all the easy way. The check is '<= 1' to have the same result for 'len = 0' cache anywhere in the page. (nr_pages_needed is 0 on page boundary.) Fixes: 8f964525a121 ("KVM: Allow cross page reads and writes from cached translations.") Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Message-Id: <20150408121648.GA3519@potion.brq.redhat.com> Reviewed-by: Wanpeng Li <wanpeng.li@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-04-08KVM: remove kvm_read_hva and kvm_read_hva_atomicPaolo Bonzini
The corresponding write functions just use __copy_to_user. Do the same on the read side. This reverts what's left of commit 86ab8cffb498 (KVM: introduce gfn_to_hva_read/kvm_read_hva/kvm_read_hva_atomic, 2012-08-21) Cc: Xiao Guangrong <guangrong.xiao@linux.intel.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Message-Id: <1427976500-28533-1-git-send-email-pbonzini@redhat.com>
2015-04-07Merge tag 'kvm-s390-next-20150331' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into HEAD Features and fixes for 4.1 (kvm/next) 1. Assorted changes 1.1 allow more feature bits for the guest 1.2 Store breaking event address on program interrupts 2. Interrupt handling rework 2.1 Fix copy_to_user while holding a spinlock (cc stable) 2.2 Rework floating interrupts to follow the priorities 2.3 Allow to inject all local interrupts via new ioctl 2.4 allow to get/set the full local irq state, e.g. for migration and introspection
2015-04-07Merge tag 'kvm-arm-for-4.1' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into 'kvm-next' KVM/ARM changes for v4.1: - fixes for live migration - irqfd support - kvm-io-bus & vgic rework to enable ioeventfd - page ageing for stage-2 translation - various cleanups
2015-04-07Merge tag 'kvm-arm-fixes-4.0-rc5' of ↵Paolo Bonzini
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into 'kvm-next' Fixes for KVM/ARM for 4.0-rc5. Fixes page refcounting issues in our Stage-2 page table management code, fixes a missing unlock in a gicv3 error path, and fixes a race that can cause lost interrupts if signals are pending just prior to entering the guest.
2015-03-31KVM: s390: add ioctl to inject local interruptsJens Freimann
We have introduced struct kvm_s390_irq a while ago which allows to inject all kinds of interrupts as defined in the Principles of Operation. Add ioctl to inject interrupts with the extended struct kvm_s390_irq Signed-off-by: Jens Freimann <jfrei@linux.vnet.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
2015-03-30KVM: arm/arm64: rework MMIO abort handling to use KVM MMIO busAndre Przywara
Currently we have struct kvm_exit_mmio for encapsulating MMIO abort data to be passed on from syndrome decoding all the way down to the VGIC register handlers. Now as we switch the MMIO handling to be routed through the KVM MMIO bus, it does not make sense anymore to use that structure already from the beginning. So we keep the data in local variables until we put them into the kvm_io_bus framework. Then we fill kvm_exit_mmio in the VGIC only, making it a VGIC private structure. On that way we replace the data buffer in that structure with a pointer pointing to a single location in a local variable, so we get rid of some copying on the way. With all of the virtual GIC emulation code now being registered with the kvm_io_bus, we can remove all of the old MMIO handling code and its dispatching functionality. I didn't bother to rename kvm_exit_mmio (to vgic_mmio or something), because that touches a lot of code lines without any good reason. This is based on an original patch by Nikolay. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Cc: Nikolay Nikolaev <n.nikolaev@virtualopensystems.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-03-30KVM: arm/arm64: prepare GICv3 emulation to use kvm_io_bus MMIO handlingAndre Przywara
Using the framework provided by the recent vgic.c changes, we register a kvm_io_bus device on mapping the virtual GICv3 resources. The distributor mapping is pretty straight forward, but the redistributors need some more love, since they need to be tagged with the respective redistributor (read: VCPU) they are connected with. We use the kvm_io_bus framework to register one devices per VCPU. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-03-30KVM: arm/arm64: merge GICv3 RD_base and SGI_base register framesAndre Przywara
Currently we handle the redistributor registers in two separate MMIO regions, one for the overall behaviour and SPIs and one for the SGIs/PPIs. That latter forces the creation of _two_ KVM I/O bus devices for each redistributor. Since the spec mandates those two pages to be contigious, we could as well merge them and save the churn with the second KVM I/O bus device. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-03-26KVM: arm/arm64: prepare GICv2 emulation to be handled by kvm_io_busAndre Przywara
Using the framework provided by the recent vgic.c changes we register a kvm_io_bus device when initializing the virtual GICv2. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-03-26KVM: arm/arm64: implement kvm_io_bus MMIO handling for the VGICAndre Przywara
Currently we use a lot of VGIC specific code to do the MMIO dispatching. Use the previous reworks to add kvm_io_bus style MMIO handlers. Those are not yet called by the MMIO abort handler, also the actual VGIC emulator function do not make use of it yet, but will be enabled with the following patches. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-03-26KVM: arm/arm64: simplify vgic_find_range() and callersAndre Przywara
The vgic_find_range() function in vgic.c takes a struct kvm_exit_mmio argument, but actually only used the length field in there. Since we need to get rid of that structure in that part of the code anyway, let's rework the function (and it's callers) to pass the length argument to the function directly. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-03-26KVM: arm/arm64: rename struct kvm_mmio_range to vgic_io_rangeAndre Przywara
The name "kvm_mmio_range" is a bit bold, given that it only covers the VGIC's MMIO ranges. To avoid confusion with kvm_io_range, rename it to vgic_io_range. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Christoffer Dall <christoffer.dall@linaro.org> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-03-26KVM: move iodev.h from virt/kvm/ to include/kvmAndre Przywara
iodev.h contains definitions for the kvm_io_bus framework. This is needed both by the generic KVM code in virt/kvm as well as by architecture specific code under arch/. Putting the header file in virt/kvm and using local includes in the architecture part seems at least dodgy to me, so let's move the file into include/kvm, so that a more natural "#include <kvm/iodev.h>" can be used by all of the code. This also solves a problem later when using struct kvm_io_device in arm_vgic.h. Fixing up the FSF address in the GPL header and a wrong include path on the way. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Christoffer Dall <christoffer.dall@linaro.org> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-03-26KVM: Redesign kvm_io_bus_ API to pass VCPU structure to the callbacks.Nikolay Nikolaev
This is needed in e.g. ARM vGIC emulation, where the MMIO handling depends on the VCPU that does the access. Signed-off-by: Nikolay Nikolaev <n.nikolaev@virtualopensystems.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Paolo Bonzini <pbonzini@redhat.com> Acked-by: Christoffer Dall <christoffer.dall@linaro.org> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Marc Zyngier <marc.zyngier@arm.com>
2015-03-23kvm: avoid page allocation failure in kvm_set_memory_region()Igor Mammedov
KVM guest can fail to startup with following trace on host: qemu-system-x86: page allocation failure: order:4, mode:0x40d0 Call Trace: dump_stack+0x47/0x67 warn_alloc_failed+0xee/0x150 __alloc_pages_direct_compact+0x14a/0x150 __alloc_pages_nodemask+0x776/0xb80 alloc_kmem_pages+0x3a/0x110 kmalloc_order+0x13/0x50 kmemdup+0x1b/0x40 __kvm_set_memory_region+0x24a/0x9f0 [kvm] kvm_set_ioapic+0x130/0x130 [kvm] kvm_set_memory_region+0x21/0x40 [kvm] kvm_vm_ioctl+0x43f/0x750 [kvm] Failure happens when attempting to allocate pages for 'struct kvm_memslots', however it doesn't have to be present in physically contiguous (kmalloc-ed) address space, change allocation to kvm_kvzalloc() so that it will be vmalloc-ed when its size is more then a page. Signed-off-by: Igor Mammedov <imammedo@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2015-03-18KVM: Eliminate extra function calls in kvm_get_dirty_log_protect()Takuya Yoshikawa
When all bits in mask are not set, kvm_arch_mmu_enable_log_dirty_pt_masked() has nothing to do. But since it needs to be called from the generic code, it cannot be inlined, and a few function calls, two when PML is enabled, are wasted. Since it is common to see many pages remain clean, e.g. framebuffers can stay calm for a long time, it is worth eliminating this overhead. Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp> Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2015-03-16Merge tag 'kvm-arm-fixes-4.0-rc5' of ↵Marcelo Tosatti
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm Fixes for KVM/ARM for 4.0-rc5. Fixes page refcounting issues in our Stage-2 page table management code, fixes a missing unlock in a gicv3 error path, and fixes a race that can cause lost interrupts if signals are pending just prior to entering the guest.
2015-03-14arm/arm64: KVM: Fix migration race in the arch timerChristoffer Dall
When a VCPU is no longer running, we currently check to see if it has a timer scheduled in the future, and if it does, we schedule a host hrtimer to notify is in case the timer expires while the VCPU is still not running. When the hrtimer fires, we mask the guest's timer and inject the timer IRQ (still relying on the guest unmasking the time when it receives the IRQ). This is all good and fine, but when migration a VM (checkpoint/restore) this introduces a race. It is unlikely, but possible, for the following sequence of events to happen: 1. Userspace stops the VM 2. Hrtimer for VCPU is scheduled 3. Userspace checkpoints the VGIC state (no pending timer interrupts) 4. The hrtimer fires, schedules work in a workqueue 5. Workqueue function runs, masks the timer and injects timer interrupt 6. Userspace checkpoints the timer state (timer masked) At restore time, you end up with a masked timer without any timer interrupts and your guest halts never receiving timer interrupts. Fix this by only kicking the VCPU in the workqueue function, and sample the expired state of the timer when entering the guest again and inject the interrupt and mask the timer only then. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Alex Bennée <alex.bennee@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-03-14arm/arm64: KVM: support for un-queuing active IRQsChristoffer Dall
Migrating active interrupts causes the active state to be lost completely. This implements some additional bitmaps to track the active state on the distributor and export this to user space. Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Alex Bennée <alex.bennee@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-03-14arm/arm64: KVM: add a common vgic_queue_irq_to_lr fnAlex Bennée
This helps re-factor away some of the repetitive code and makes the code flow more nicely. Signed-off-by: Alex Bennée <alex.bennee@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-03-14arm/arm64: KVM: Keep elrsr/aisr in sync with software modelChristoffer Dall
There is an interesting bug in the vgic code, which manifests itself when the KVM run loop has a signal pending or needs a vmid generation rollover after having disabled interrupts but before actually switching to the guest. In this case, we flush the vgic as usual, but we sync back the vgic state and exit to userspace before entering the guest. The consequence is that we will be syncing the list registers back to the software model using the GICH_ELRSR and GICH_EISR from the last execution of the guest, potentially overwriting a list register containing an interrupt. This showed up during migration testing where we would capture a state where the VM has masked the arch timer but there were no interrupts, resulting in a hung test. Cc: Marc Zyngier <marc.zyngier@arm.com> Reported-by: Alex Bennee <alex.bennee@linaro.org> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org> Signed-off-by: Alex Bennée <alex.bennee@linaro.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-03-13arm/arm64: KVM: fix missing unlock on error in kvm_vgic_create()Wei Yongjun
Add the missing unlock before return from function kvm_vgic_create() in the error handling case. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-03-12KVM: arm/arm64: add irqfd supportEric Auger
This patch enables irqfd on arm/arm64. Both irqfd and resamplefd are supported. Injection is implemented in vgic.c without routing. This patch enables CONFIG_HAVE_KVM_EVENTFD and CONFIG_HAVE_KVM_IRQFD. KVM_CAP_IRQFD is now advertised. KVM_CAP_IRQFD_RESAMPLE capability automatically is advertised as soon as CONFIG_HAVE_KVM_IRQFD is set. Irqfd injection is restricted to SPI. The rationale behind not supporting PPI irqfd injection is that any device using a PPI would be a private-to-the-CPU device (timer for instance), so its state would have to be context-switched along with the VCPU and would require in-kernel wiring anyhow. It is not a relevant use case for irqfds. Signed-off-by: Eric Auger <eric.auger@linaro.org> Reviewed-by: Christoffer Dall <christoffer.dall@linaro.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-03-12KVM: arm/arm64: remove coarse grain dist locking at kvm_vgic_sync_hwstateEric Auger
To prepare for irqfd addition, coarse grain locking is removed at kvm_vgic_sync_hwstate level and finer grain locking is introduced in vgic_process_maintenance only. Signed-off-by: Eric Auger <eric.auger@linaro.org> Acked-by: Christoffer Dall <christoffer.dall@linaro.org> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-03-12KVM: introduce kvm_arch_intc_initialized and use it in irqfdEric Auger
Introduce __KVM_HAVE_ARCH_INTC_INITIALIZED define and associated kvm_arch_intc_initialized function. This latter allows to test whether the virtual interrupt controller is initialized and ready to accept virtual IRQ injection. On some architectures, the virtual interrupt controller is dynamically instantiated, justifying that kind of check. The new function can now be used by irqfd to check whether the virtual interrupt controller is ready on KVM_IRQFD request. If not, KVM_IRQFD returns -EAGAIN. Signed-off-by: Eric Auger <eric.auger@linaro.org> Acked-by: Christoffer Dall <christoffer.dall@linaro.org> Reviewed-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-03-11KVM: vgic: add virt-capable compatible stringsMark Rutland
Several dts only list "arm,cortex-a7-gic" or "arm,gic-400" in their GIC compatible list, and while this is correct (and supported by the GIC driver), KVM will fail to detect that it can support these cases. This patch adds the missing strings to the VGIC code. The of_device_id entries are padded to keep the probe function data aligned. Signed-off-by: Mark Rutland <mark.rutland@arm.com> Cc: Andre Przywara <andre.przywara@arm.com> Cc: Christoffer Dall <christoffer.dall@linaro.org> Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Michal Simek <monstr@monstr.eu> Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
2015-03-10kvm: move advertising of KVM_CAP_IRQFD to common codePaolo Bonzini
POWER supports irqfds but forgot to advertise them. Some userspace does not check for the capability, but others check it---thus they work on x86 and s390 but not POWER. To avoid that other architectures in the future make the same mistake, let common code handle KVM_CAP_IRQFD the same way as KVM_CAP_IRQFD_RESAMPLE. Reported-and-tested-by: Greg Kurz <gkurz@linux.vnet.ibm.com> Cc: stable@vger.kernel.org Fixes: 297e21053a52f060944e9f0de4c64fad9bcd72fc Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2015-03-10KVM: Use pr_info/pr_err in kvm_main.cXiubo Li
WARNING: Prefer [subsystem eg: netdev]_info([subsystem]dev, ... then dev_info(dev, ... then pr_info(... to printk(KERN_INFO ... + printk(KERN_INFO "kvm: exiting hardware virtualization\n"); WARNING: Prefer [subsystem eg: netdev]_err([subsystem]dev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ... + printk(KERN_ERR "kvm: misc device register failed\n"); Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2015-03-10KVM: Fix indentation in kvm_main.cXiubo Li
ERROR: code indent should use tabs where possible + const struct kvm_io_range *r2)$ WARNING: please, no spaces at the start of a line + const struct kvm_io_range *r2)$ This patch fixes this ERROR & WARNING to reduce noise when checking new patches in kvm_main.c. Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2015-03-10KVM: no space before tabs in kvm_main.cXiubo Li
WARNING: please, no space before tabs + * ^I^Ikvm->lock --> kvm->slots_lock --> kvm->irq_lock$ WARNING: please, no space before tabs +^I^I * ^I- gfn_to_hva (kvm_read_guest, gfn_to_pfn)$ WARNING: please, no space before tabs +^I^I * ^I- kvm_is_visible_gfn (mmu_check_roots)$ This patch fixes these warnings to reduce noise when checking new patches in kvm_main.c. Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2015-03-10KVM: Missing blank line after declarations in kvm_main.cXiubo Li
There are many Warnings like this: WARNING: Missing a blank line after declarations + struct kvm_coalesced_mmio_zone zone; + r = -EFAULT; This patch fixes these warnings to reduce noise when checking new patches in kvm_main.c. Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2015-03-10KVM: EXPORT_SYMBOL should immediately follow its functionXiubo Li
WARNING: EXPORT_SYMBOL(foo); should immediately follow its function/variable +EXPORT_SYMBOL_GPL(gfn_to_page); This patch fixes these warnings to reduce noise when checking new patches in kvm_main.c. Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2015-03-10KVM: Fix ERROR: do not initialise statics to 0 or NULL in kvm_main.cXiubo Li
ERROR: do not initialise statics to 0 or NULL +static int kvm_usage_count = 0; The kvm_usage_count will be placed to .bss segment when linking, so not need to set it to 0 here obviously. This patch fixes this ERROR to reduce noise when checking new patches in kvm_main.c. Signed-off-by: Xiubo Li <lixiubo@cmss.chinamobile.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
