commit 350b8bdd689cd2ab2c67c8a86a0be86cfa0751a7 upstream.
The third parameter of kvm_iommu_put_pages is wrong,
It should be 'gfn - slot->base_gfn'.
By making gfn very large, malicious guest or userspace can cause kvm to
go to this error path, and subsequently to pass a huge value as size.
Alternatively if gfn is small, then pages would be pinned but never
unpinned, causing host memory leak and local DOS.
Passing a reasonable but large value could be the most dangerous case,
because it would unpin a page that should have stayed pinned, and thus
allow the device to DMA into arbitrary memory. However, this cannot
happen because of the condition that can trigger the error:
- out of memory (where you can't allocate even a single page)
should not be possible for the attacker to trigger
- when exceeding the iommu's address space, guest pages after gfn
will also exceed the iommu's address space, and inside
kvm_iommu_put_pages() the iommu_iova_to_phys() will fail. The
page thus would not be unpinned at all.
Reported-by: Jack Morgenstein <jackm@mellanox.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit 0f6c0a740b7d3e1f3697395922d674000f83d060 upstream.
Currently, the EOI exit bitmap (used for APICv) does not include
interrupts that are masked. However, this can cause a bug that manifests
as an interrupt storm inside the guest. Alex Williamson reported the
bug and is the one who really debugged this; I only wrote the patch. :)
The scenario involves a multi-function PCI device with OHCI and EHCI
USB functions and an audio function, all assigned to the guest, where
both USB functions use legacy INTx interrupts.
As soon as the guest boots, interrupts for these devices turn into an
interrupt storm in the guest; the host does not see the interrupt storm.
Basically the EOI path does not work, and the guest continues to see the
interrupt over and over, even after it attempts to mask it at the APIC.
The bug is only visible with older kernels (RHEL6.5, based on 2.6.32
with not many changes in the area of APIC/IOAPIC handling).
Alex then tried forcing bit 59 (corresponding to the USB functions' IRQ)
on in the eoi_exit_bitmap and TMR, and things then work. What happens
is that VFIO asserts IRQ11, then KVM recomputes the EOI exit bitmap.
It does not have set bit 59 because the RTE was masked, so the IOAPIC
never sees the EOI and the interrupt continues to fire in the guest.
My guess was that the guest is masking the interrupt in the redirection
table in the interrupt routine, i.e. while the interrupt is set in a
LAPIC's ISR, The simplest fix is to ignore the masking state, we would
rather have an unnecessary exit rather than a missed IRQ ACK and anyway
IOAPIC interrupts are not as performance-sensitive as for example MSIs.
Alex tested this patch and it fixed his bug.
[Thanks to Alex for his precise description of the problem
and initial debugging effort. A lot of the text above is
based on emails exchanged with him.]
Reported-by: Alex Williamson <alex.williamson@redhat.com>
Tested-by: Alex Williamson <alex.williamson@redhat.com>
If the physical address of GICV isn't page-aligned, then we end up
creating a stage-2 mapping of the page containing it, which causes us to
map neighbouring memory locations directly into the guest.
As an example, consider a platform with GICV at physical 0x2c02f000
running a 64k-page host kernel. If qemu maps this into the guest at
0x80010000, then guest physical addresses 0x80010000 - 0x8001efff will
map host physical region 0x2c020000 - 0x2c02efff. Accesses to these
physical regions may cause UNPREDICTABLE behaviour, for example, on the
Juno platform this will cause an SError exception to EL3, which brings
down the entire physical CPU resulting in RCU stalls / HYP panics / host
crashing / wasted weeks of debugging.
SBSA recommends that systems alias the 4k GICV across the bounding 64k
region, in which case GICV physical could be described as 0x2c020000 in
the above scenario.
This patch fixes the problem by failing the vgic probe if the physical
base address or the size of GICV aren't page-aligned. Note that this
generated a warning in dmesg about freeing enabled IRQs, so I had to
move the IRQ enabling later in the probe.
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Gleb Natapov <gleb@kernel.org>
Cc: Joel Schopp <joel.schopp@amd.com>
Cc: Don Dutile <ddutile@redhat.com>
Acked-by: Peter Maydell <peter.maydell@linaro.org>
Acked-by: Joel Schopp <joel.schopp@amd.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
Pull more scheduler updates from Ingo Molnar:
"Second round of scheduler changes:
- try-to-wakeup and IPI reduction speedups, from Andy Lutomirski
- continued power scheduling cleanups and refactorings, from Nicolas
Pitre
- misc fixes and enhancements"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched/deadline: Delete extraneous extern for to_ratio()
sched/idle: Optimize try-to-wake-up IPI
sched/idle: Simplify wake_up_idle_cpu()
sched/idle: Clear polling before descheduling the idle thread
sched, trace: Add a tracepoint for IPI-less remote wakeups
cpuidle: Set polling in poll_idle
sched: Remove redundant assignment to "rt_rq" in update_curr_rt(...)
sched: Rename capacity related flags
sched: Final power vs. capacity cleanups
sched: Remove remaining dubious usage of "power"
sched: Let 'struct sched_group_power' care about CPU capacity
sched/fair: Disambiguate existing/remaining "capacity" usage
sched/fair: Change "has_capacity" to "has_free_capacity"
sched/fair: Remove "power" from 'struct numa_stats'
sched: Fix signedness bug in yield_to()
sched/fair: Use time_after() in record_wakee()
sched/balancing: Reduce the rate of needless idle load balancing
sched/fair: Fix unlocked reads of some cfs_b->quota/period
yield_to() is supposed to return -ESRCH if there is no task to
yield to, but because the type is bool that is the same as returning
true.
The only place I see which cares is kvm_vcpu_on_spin().
Reviewed-by: Raghavendra <raghavendra.kt@linux.vnet.ibm.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: kvm@vger.kernel.org
Link: http://lkml.kernel.org/r/20140523102042.GA7267@mwanda
Pull KVM updates from Paolo Bonzini:
"At over 200 commits, covering almost all supported architectures, this
was a pretty active cycle for KVM. Changes include:
- a lot of s390 changes: optimizations, support for migration, GDB
support and more
- ARM changes are pretty small: support for the PSCI 0.2 hypercall
interface on both the guest and the host (the latter acked by
Catalin)
- initial POWER8 and little-endian host support
- support for running u-boot on embedded POWER targets
- pretty large changes to MIPS too, completing the userspace
interface and improving the handling of virtualized timer hardware
- for x86, a larger set of changes is scheduled for 3.17. Still, we
have a few emulator bugfixes and support for running nested
fully-virtualized Xen guests (para-virtualized Xen guests have
always worked). And some optimizations too.
The only missing architecture here is ia64. It's not a coincidence
that support for KVM on ia64 is scheduled for removal in 3.17"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (203 commits)
KVM: add missing cleanup_srcu_struct
KVM: PPC: Book3S PR: Rework SLB switching code
KVM: PPC: Book3S PR: Use SLB entry 0
KVM: PPC: Book3S HV: Fix machine check delivery to guest
KVM: PPC: Book3S HV: Work around POWER8 performance monitor bugs
KVM: PPC: Book3S HV: Make sure we don't miss dirty pages
KVM: PPC: Book3S HV: Fix dirty map for hugepages
KVM: PPC: Book3S HV: Put huge-page HPTEs in rmap chain for base address
KVM: PPC: Book3S HV: Fix check for running inside guest in global_invalidates()
KVM: PPC: Book3S: Move KVM_REG_PPC_WORT to an unused register number
KVM: PPC: Book3S: Add ONE_REG register names that were missed
KVM: PPC: Add CAP to indicate hcall fixes
KVM: PPC: MPIC: Reset IRQ source private members
KVM: PPC: Graciously fail broken LE hypercalls
PPC: ePAPR: Fix hypercall on LE guest
KVM: PPC: BOOK3S: Remove open coded make_dsisr in alignment handler
KVM: PPC: BOOK3S: Always use the saved DAR value
PPC: KVM: Make NX bit available with magic page
KVM: PPC: Disable NX for old magic page using guests
KVM: PPC: BOOK3S: HV: Add mixed page-size support for guest
Reported-by: hrg <hrgstephen@gmail.com>
When starting lots of dataplane devices the bootup takes very long on
Christian's s390 with irqfd patches. With larger setups he is even
able to trigger some timeouts in some components. Turns out that the
KVM_SET_GSI_ROUTING ioctl takes very long (strace claims up to 0.1 sec)
when having multiple CPUs. This is caused by the synchronize_rcu and
the HZ=100 of s390. By changing the code to use a private srcu we can
speed things up. This patch reduces the boot time till mounting root
from 8 to 2 seconds on my s390 guest with 100 disks.
Uses of hlist_for_each_entry_rcu, hlist_add_head_rcu, hlist_del_init_rcu
are fine because they do not have lockdep checks (hlist_for_each_entry_rcu
uses rcu_dereference_raw rather than rcu_dereference, and write-sides
do not do rcu lockdep at all).
Note that we're hardly relying on the "sleepable" part of srcu. We just
want SRCU's faster detection of grace periods.
Testing was done by Andrew Theurer using netperf tests STREAM, MAERTS
and RR. The difference between results "before" and "after" the patch
has mean -0.2% and standard deviation 0.6%. Using a paired t-test on the
data points says that there is a 2.5% probability that the patch is the
cause of the performance difference (rather than a random fluctuation).
(Restricting the t-test to RR, which is the most likely to be affected,
changes the numbers to respectively -0.3% mean, 0.7% stdev, and 8%
probability that the numbers actually say something about the patch.
The probability increases mostly because there are fewer data points).
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Michael S. Tsirkin <mst@redhat.com>
Tested-by: Christian Borntraeger <borntraeger@de.ibm.com> # s390
Reviewed-by: Christian Borntraeger <borntraeger@de.ibm.com>
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvmarm/kvmarm into kvm-master
First round of KVM/ARM Fixes for 3.15
Includes vgic fixes, a possible kernel corruption bug due to
misalignment of pages and disabling of KVM in KConfig on big-endian
systems, because the last one breaks the build.
base address.
Currently below check in vgic_ioaddr_overlap will always succeed,
because the vgic dist base and vgic cpu base are still kept UNDEF
after initialization. The code as follows will be return forever.
if (IS_VGIC_ADDR_UNDEF(dist) || IS_VGIC_ADDR_UNDEF(cpu))
return 0;
So, before invoking the vgic_ioaddr_overlap, it needs to set the
corresponding base address firstly.
Signed-off-by: Haibin Wang <wanghaibin.wang@huawei.com>
async_pf_execute() passes tsk == current to gup(), this is doesn't
hurt but unnecessary and misleading. "tsk" is only used to account
the number of faults and current is the random workqueue thread.
Suggested-by: Andrea Arcangeli <aarcange@redhat.com>
async_pf_execute() has no reasons to adopt apf->mm, gup(current, mm)
should work just fine even if current has another or NULL ->mm.
Recently kvm_async_page_present_sync() was added insedie the "use_mm"
section, but it seems that it doesn't need current->mm too.
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Since KVM internally represents the ICFGR registers by stuffing two
of them into one word, the offset for accessing the internal
representation and the one for the MMIO based access are different.
So keep the original offset around, but adjust the internal array
offset by one bit.
Reported-by: Haibin Wang <wanghaibin.wang@huawei.com>
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
get_user_pages(mm) is simply wrong if mm->mm_users == 0 and exit_mmap/etc
was already called (or is in progress), mm->mm_count can only pin mm->pgd
and mm_struct itself.
Change kvm_setup_async_pf/async_pf_execute to inc/dec mm->mm_users.
kvm_create_vm/kvm_destroy_vm play with ->mm_count too but this case looks
fine at first glance, it seems that this ->mm is only used to verify that
current->mm == kvm->mm.
Cc: stable@vger.kernel.org
When dispatch SGI(mode == 0), that is the vcpu of VM should send
sgi to the cpu which the target_cpus list.
So, there must add the "break" to branch of case 0.
Cc: <stable@vger.kernel.org> # 3.10+
As result of deprecation of MSI-X/MSI enablement functions
pci_enable_msix() and pci_enable_msi_block() all drivers
using these two interfaces need to be updated to use the
new pci_enable_msi_range() or pci_enable_msi_exact()
and pci_enable_msix_range() or pci_enable_msix_exact()
interfaces.
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Cc: linux-pci@vger.kernel.org
This reverts commit 5befdc385ddb2d5ae8995ad89004529a3acf58fc.
Since we will allow flush tlb out of mmu-lock in the later
patch
Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kvms390/linux into queue
Lazy storage key handling
Linux does not use the ACC and F bits of the storage key. Newer Linux
versions also do not use the storage keys for dirty and reference
tracking. We can optimize the guest handling for those guests for faults
as well as page-in and page-out by simply not caring about the guest
visible storage key. We trap guest storage key instruction to enable
those keys only on demand.
Migration bitmap
Until now s390 never provided a proper dirty bitmap. Let's provide a
proper migration bitmap for s390. We also change the user dirty tracking
to a fault based mechanism. This makes the host completely independent
from the storage keys. Long term this will allow us to back guest memory
with large pages.
per-VM device attributes
To avoid the introduction of new ioctls, let's provide the
attribute semanantic also on the VM-"device".
Userspace controlled CMMA
The CMMA assist is changed from "always on" to "on if requested" via
per-VM device attributes. In addition a callback to reset all usage
states is provided.
Proper guest DAT handling for intercepts
While instructions handled by SIE take care of all addressing aspects,
KVM/s390 currently does not care about guest address translation of
intercepts. This worked out fine, because
- the s390 Linux kernel has a 1:1 mapping between kernel virtual<->real
for all pages up to memory size
- intercepts happen only for a small amount of cases
- all of these intercepts happen to be in the kernel text for current
distros
Of course we need to be better for other intercepts, kernel modules etc.
We provide the infrastructure and rework all in-kernel intercepts to work
on logical addresses (paging etc) instead of real ones. The code has
been running internally for several months now, so it is time for going
public.
GDB support
We provide breakpoints, single stepping and watchpoints.
Fixes/Cleanups
- Improve program check delivery
- Factor out the handling of transactional memory on program checks
- Use the existing define __LC_PGM_TDB
- Several cleanups in the lowcore structure
- Documentation
NOTES
- All patches touching base s390 are either ACKed or written by the s390
maintainers
- One base KVM patch "KVM: add kvm_is_error_gpa() helper"
- One patch introduces the notion of VM device attributes
include/uapi/linux/kvm.h
Replace the kvm_s390_sync_dirty_log() stub with code to construct the KVM
dirty_bitmap from S390 memory change bits. Also add code to properly clear
the dirty_bitmap size when clearing the bitmap.
Signed-off-by: Jason J. Herne <jjherne@us.ibm.com>
CC: Dominik Dingel <dingel@linux.vnet.ibm.com>
[Dominik Dingel: use gmap_test_and_clear_dirty, locking fixes]
With KVM, MMIO is much slower than PIO, due to the need to
do page walk and emulation. But with EPT, it does not have to be: we
know the address from the VMCS so if the address is unique, we can look
up the eventfd directly, bypassing emulation.
Unfortunately, this only works if userspace does not need to match on
access length and data. The implementation adds a separate FAST_MMIO
bus internally. This serves two purposes:
- minimize overhead for old userspace that does not use eventfd with lengtth = 0
- minimize disruption in other code (since we don't know the length,
devices on the MMIO bus only get a valid address in write, this
way we don't need to touch all devices to teach them to handle
an invalid length)
At the moment, this optimization only has effect for EPT on x86.
It will be possible to speed up MMIO for NPT and MMU using the same
idea in the future.
With this patch applied, on VMX MMIO EVENTFD is essentially as fast as PIO.
I was unable to detect any measureable slowdown to non-eventfd MMIO.
Making MMIO faster is important for the upcoming virtio 1.0 which
includes an MMIO signalling capability.
The idea was suggested by Peter Anvin. Lots of thanks to Gleb for
pre-review and suggestions.
It is sometimes benefitial to ignore IO size, and only match on address.
In hindsight this would have been a better default than matching length
when KVM_IOEVENTFD_FLAG_DATAMATCH is not set, In particular, this kind
of access can be optimized on VMX: there no need to do page lookups.
This can currently be done with many ioeventfds but in a suboptimal way.
However we can't change kernel/userspace ABI without risk of breaking
some applications.
Use len = 0 to mean "ignore length for matching" in a more optimal way.
Pull KVM fixes from Marcelo Tosatti:
- Fix for guest triggerable BUG_ON (CVE-2014-0155)
- CR4.SMAP support
- Spurious WARN_ON() fix
* git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: x86: remove WARN_ON from get_kernel_ns()
KVM: Rename variable smep to cr4_smep
KVM: expose SMAP feature to guest
KVM: Disable SMAP for guests in EPT realmode and EPT unpaging mode
KVM: Add SMAP support when setting CR4
KVM: Remove SMAP bit from CR4_RESERVED_BITS
KVM: ioapic: try to recover if pending_eoi goes out of range
KVM: ioapic: fix assignment of ioapic->rtc_status.pending_eoi (CVE-2014-0155)
Commit 8146875de7d4 (arm, kvm: Fix CPU hotplug callback registration)
holds the lock before calling the two functions:
kvm_vgic_hyp_init()
kvm_timer_hyp_init()
and both the two functions are calling register_cpu_notifier()
to register cpu notifier, so cause double lock on cpu_add_remove_lock.
Considered that both two functions are only called inside
kvm_arch_init() with holding cpu_add_remove_lock, so simply use
__register_cpu_notifier() to fix the problem.
Fixes: 8146875de7d4 (arm, kvm: Fix CPU hotplug callback registration)
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Reviewed-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
The RTC tracking code tracks the cardinality of rtc_status.dest_map
into rtc_status.pending_eoi. It has some WARN_ONs that trigger if
pending_eoi ever becomes negative; however, these do not do anything
to recover, and it bad things will happen soon after they trigger.
When the next RTC interrupt is triggered, rtc_check_coalesced() will
return false, but ioapic_service will find pending_eoi != 0 and
do a BUG_ON. To avoid this, should pending_eoi ever be nonzero,
call kvm_rtc_eoi_tracking_restore_all to recompute a correct
dest_map and pending_eoi.
QE reported that they got the BUG_ON in ioapic_service to trigger.
I cannot reproduce it, but there are two reasons why this could happen.
The less likely but also easiest one, is when kvm_irq_delivery_to_apic
does not deliver to any APIC and returns -1.
Because irqe.shorthand == 0, the kvm_for_each_vcpu loop in that
function is never reached. However, you can target the similar loop in
kvm_irq_delivery_to_apic_fast; just program a zero logical destination
address into the IOAPIC, or an out-of-range physical destination address.
Pull VFIO updates from Alex Williamson:
"VFIO updates for v3.15 include:
- Allow the vfio-type1 IOMMU to support multiple domains within a
container
- Plumb path to query whether all domains are cache-coherent
- Wire query into kvm-vfio device to avoid KVM x86 WBINVD emulation
- Always select CONFIG_ANON_INODES, vfio depends on it (Arnd)
The first patch also makes the vfio-type1 IOMMU driver completely
independent of the bus_type of the devices it's handling, which
enables it to be used for both vfio-pci and a future vfio-platform
(and hopefully combinations involving both simultaneously)"
* tag 'vfio-v3.15-rc1' of git://github.com/awilliam/linux-vfio:
vfio: always select ANON_INODES
kvm/vfio: Support for DMA coherent IOMMUs
vfio: Add external user check extension interface
vfio/type1: Add extension to test DMA cache coherence of IOMMU
vfio/iommu_type1: Multi-IOMMU domain support
Pull kvm updates from Paolo Bonzini:
"PPC and ARM do not have much going on this time. Most of the cool
stuff, instead, is in s390 and (after a few releases) x86.
ARM has some caching fixes and PPC has transactional memory support in
guests. MIPS has some fixes, with more probably coming in 3.16 as
QEMU will soon get support for MIPS KVM.
For x86 there are optimizations for debug registers, which trigger on
some Windows games, and other important fixes for Windows guests. We
now expose to the guest Broadwell instruction set extensions and also
Intel MPX. There's also a fix/workaround for OS X guests, nested
virtualization features (preemption timer), and a couple kvmclock
refinements.
For s390, the main news is asynchronous page faults, together with
improvements to IRQs (floating irqs and adapter irqs) that speed up
virtio devices"
* tag 'kvm-3.15-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (96 commits)
KVM: PPC: Book3S HV: Save/restore host PMU registers that are new in POWER8
KVM: PPC: Book3S HV: Fix decrementer timeouts with non-zero TB offset
KVM: PPC: Book3S HV: Don't use kvm_memslots() in real mode
KVM: PPC: Book3S HV: Return ENODEV error rather than EIO
KVM: PPC: Book3S: Trim top 4 bits of physical address in RTAS code
KVM: PPC: Book3S HV: Add get/set_one_reg for new TM state
KVM: PPC: Book3S HV: Add transactional memory support
KVM: Specify byte order for KVM_EXIT_MMIO
KVM: vmx: fix MPX detection
KVM: PPC: Book3S HV: Fix KVM hang with CONFIG_KVM_XICS=n
KVM: PPC: Book3S: Introduce hypervisor call H_GET_TCE
KVM: PPC: Book3S HV: Fix incorrect userspace exit on ioeventfd write
KVM: s390: clear local interrupts at cpu initial reset
KVM: s390: Fix possible memory leak in SIGP functions
KVM: s390: fix calculation of idle_mask array size
KVM: s390: randomize sca address
KVM: ioapic: reinject pending interrupts on KVM_SET_IRQCHIP
KVM: Bump KVM_MAX_IRQ_ROUTES for s390
KVM: s390: irq routing for adapter interrupts.
KVM: s390: adapter interrupt sources
Pull x86 LTO changes from Peter Anvin:
"More infrastructure work in preparation for link-time optimization
(LTO). Most of these changes is to make sure symbols accessed from
assembly code are properly marked as visible so the linker doesn't
remove them.
My understanding is that the changes to support LTO are still not
upstream in binutils, but are on the way there. This patchset should
conclude the x86-specific changes, and remaining patches to actually
enable LTO will be fed through the Kbuild tree (other than keeping up
with changes to the x86 code base, of course), although not
necessarily in this merge window"
* 'x86-asmlinkage-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (25 commits)
Kbuild, lto: Handle basic LTO in modpost
Kbuild, lto: Disable LTO for asm-offsets.c
Kbuild, lto: Add a gcc-ld script to let run gcc as ld
Kbuild, lto: add ld-version and ld-ifversion macros
Kbuild, lto: Drop .number postfixes in modpost
Kbuild, lto, workaround: Don't warn for initcall_reference in modpost
lto: Disable LTO for sys_ni
lto: Handle LTO common symbols in module loader
lto, workaround: Add workaround for initcall reordering
lto: Make asmlinkage __visible
x86, lto: Disable LTO for the x86 VDSO
initconst, x86: Fix initconst mistake in ts5500 code
initconst: Fix initconst mistake in dcdbas
asmlinkage: Make trace_hardirqs_on/off_caller visible
asmlinkage, x86: Fix 32bit memcpy for LTO
asmlinkage Make __stack_chk_failed and memcmp visible
asmlinkage: Mark rwsem functions that can be called from assembler asmlinkage
asmlinkage: Make main_extable_sort_needed visible
asmlinkage, mutex: Mark __visible
asmlinkage: Make trace_hardirq visible
After the previous patches, an interrupt whose bit is set in the IRR
register will never be in the LAPIC's IRR and has never been injected
on the migration source. So inject it on the destination.
This fixes migration of Windows guests without HPET (they use the RTC
to trigger the scheduler tick, and lose it after migration).
Reviewed-by: Alex Williamson <alex.williamson@redhat.com>
We will reuse it to process a nonzero IRR that is passed to KVM_SET_IRQCHIP.
This ensures that IRR bits are set in the KVM_GET_IRQCHIP result only if
the interrupt is still sitting in the IOAPIC. After the next patches, it
avoids spurious reinjection of the interrupt when KVM_SET_IRQCHIP is
called.
Commonize the handling of masking, which was absent for kvm_ioapic_set_irq.
Setting remote_irr does not need a separate function either, and merging
the two functions avoids confusion.
When registering a new irqfd, we call its ->poll method to collect any
event that might have previously been pending so that we can trigger it.
This is done under the kvm->irqfds.lock, which means the eventfd's ctx
lock is taken under it.
However, if we get a POLLHUP in irqfd_wakeup, we will be called with the
ctx lock held before getting the irqfds.lock to deactivate the irqfd,
causing lockdep to complain.
Calling the ->poll method does not really need the irqfds.lock, so let's
just move it after we've given up the irqfds.lock in kvm_irqfd_assign().
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Both QEMU and KVM have already accumulated a significant number of
optimizations based on the hard-coded assumption that ioapic polarity
will always use the ActiveHigh convention, where the logical and
physical states of level-triggered irq lines always match (i.e.,
active(asserted) == high == 1, inactive == low == 0). QEMU guests
are expected to follow directions given via ACPI and configure the
ioapic with polarity 0 (ActiveHigh). However, even when misbehaving
guests (e.g. OS X <= 10.9) set the ioapic polarity to 1 (ActiveLow),
QEMU will still use the ActiveHigh signaling convention when
interfacing with KVM.
This patch modifies KVM to completely ignore ioapic polarity as set by
the guest OS, enabling misbehaving guests to work alongside those which
comply with the ActiveHigh polarity specified by QEMU's ACPI tables.
Signed-off-by: Gabriel L. Somlo <somlo@cmu.edu>
[Move documentation to KVM_IRQ_LINE, add ia64. - Paolo]
VFIO now has support for using the IOMMU_CACHE flag and a mechanism
for an external user to test the current operating mode of the IOMMU.
Add support for this to the kvm-vfio pseudo device so that we only
register noncoherent DMA when necessary.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Acked-by: Paolo Bonzini <pbonzini@redhat.com>
Use the arch specific function kvm_arch_vcpu_runnable() to add a further
criterium to identify a suitable vcpu to yield to during undirected yield
processing.
Signed-off-by: Michael Mueller <mimu@linux.vnet.ibm.com>
When this was introduced, kvm_flush_remote_tlbs() could be called
without holding mmu_lock. It is now acknowledged that the function
must be called before releasing mmu_lock, and all callers have already
been changed to do so.
There is no need to use smp_mb() and cmpxchg() any more.
Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp>
This fixes the build breakage introduced by
c07a0191ef2de1f9510f12d1f88e3b0b5cd8d66f and adds support for the device
control API and save/restore of the VGIC state for ARMv8.
The defines were simply missing from the arm64 header files and
uaccess.h must be implicitly imported from somewhere else on arm.
kvm_rebooting is referenced from assembler code, thus
needs to be visible.
Cc: Gleb Natapov <gleb@redhat.com>
Link: http://lkml.kernel.org/r/1391845930-28580-1-git-send-email-ak@linux.intel.com
Commit KVM: async_pf: Provide additional direct page notification
missed the call from kvm_check_async_pf_completion to the new introduced function.
Reported-by: Paolo Bonzini <pbonzini@redhat.com>
Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com>
On s390 we are not able to cancel work. Instead we will flush the work and wait for
completion.
By setting a Kconfig option, the architecture can control when
guest notifications will be presented by the apf backend.
There is the default batch mechanism, working as before, where the vcpu
thread should pull in this information.
Opposite to this, there is now the direct mechanism, that will push the
information to the guest.
This way s390 can use an already existing architecture interface.
Still the vcpu thread should call check_completion to cleanup leftovers.
If kvm_io_bus_register_dev() fails then it returns success but it should
return an error code.
I also did a little cleanup like removing an impossible NULL test.
Fixes: 2b3c246a682c ('KVM: Make coalesced mmio use a device per zone')
This patch adds a floating irq controller as a kvm_device.
It will be necessary for migration of floating interrupts as well
as for hardening the reset code by allowing user space to explicitly
remove all pending floating interrupts.
Signed-off-by: Jens Freimann <jfrei@linux.vnet.ibm.com>
Reviewed-by: Cornelia Huck <cornelia.huck@de.ibm.com>
"First round of KVM updates for 3.14; PPC parts will come next week.
Nothing major here, just bugfixes all over the place. The most
interesting part is the ARM guys' virtualized interrupt controller
overhaul, which lets userspace get/set the state and thus enables
migration of ARM VMs"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (67 commits)
kvm: make KVM_MMU_AUDIT help text more readable
KVM: s390: Fix memory access error detection
KVM: nVMX: Update guest activity state field on L2 exits
KVM: nVMX: Fix nested_run_pending on activity state HLT
KVM: nVMX: Clean up handling of VMX-related MSRs
KVM: nVMX: Add tracepoints for nested_vmexit and nested_vmexit_inject
KVM: nVMX: Pass vmexit parameters to nested_vmx_vmexit
KVM: nVMX: Leave VMX mode on clearing of feature control MSR
KVM: VMX: Fix DR6 update on #DB exception
KVM: SVM: Fix reading of DR6
KVM: x86: Sync DR7 on KVM_SET_DEBUGREGS
add support for Hyper-V reference time counter
KVM: remove useless write to vcpu->hv_clock.tsc_timestamp
KVM: x86: fix tsc catchup issue with tsc scaling
KVM: x86: limit PIT timer frequency
KVM: x86: handle invalid root_hpa everywhere
kvm: Provide kvm_vcpu_eligible_for_directed_yield() stub
kvm: vfio: silence GCC warning
KVM: ARM: Remove duplicate include
arm/arm64: KVM: relax the requirements of VMA alignment for THP
Commit 7940876e1330671708186ac3386aa521ffb5c182 ("kvm: make local
functions static") broke KVM PPC builds due to removing (rather than
moving) the stub version of kvm_vcpu_eligible_for_directed_yield().
This patch reintroduces it.
Cc: Stephen Hemminger <stephen@networkplumber.org>
Cc: Alexander Graf <agraf@suse.de>
[Move the #ifdef inside the function. - Paolo]
Building vfio.o triggers a GCC warning (when building for 32 bits x86):
arch/x86/kvm/../../../virt/kvm/vfio.c: In function 'kvm_vfio_set_group':
arch/x86/kvm/../../../virt/kvm/vfio.c:104:22: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
void __user *argp = (void __user *)arg;
Silence this warning by casting arg to unsigned long.
argp's current type, "void __user *", is always casted to "int32_t
__user *". So its type might as well be changed to "int32_t __user *".
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
The function kvm_io_bus_read_cookie is defined but never used
in current in-tree code.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Running 'make namespacecheck' found lots of functions that
should be declared static, since only used in one file.
