path: root/virt
2012-06-15KVM: Fix PCI header check on device assignmentJan Kiszka
The masking was wrong (must have been 0x7f), and there is no need to re-read the value as pci_setup_device already does this for us. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=43339 Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-06-05KVM: Fix buffer overflow in kvm_set_irq()Avi Kivity
kvm_set_irq() has an internal buffer of three irq routing entries, allowing connecting a GSI to three IRQ chips or on MSI. However setup_routing_entry() does not properly enforce this, allowing three irqchip routes followed by an MSI route to overflow the buffer. Fix by ensuring that an MSI entry is added to an empty list. Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-30KVM: s390: Implement the directed yield (diag 9c) hypervisor call for KVMKonstantin Weitz
This patch implements the directed yield hypercall found on other System z hypervisors. It delegates execution time to the virtual cpu specified in the instruction's parameter. Useful to avoid long spinlock waits in the guest. Christian Borntraeger: moved common code in virt/kvm/ Signed-off-by: Konstantin Weitz <WEITZKON@de.ibm.com> Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-24KVM: Introduce direct MSI message injection for in-kernel irqchipsJan Kiszka
Currently, MSI messages can only be injected to in-kernel irqchips by defining a corresponding IRQ route for each message. This is not only unhandy if the MSI messages are generated "on the fly" by user space, IRQ routes are a limited resource that user space has to manage carefully. By providing a direct injection path, we can both avoid using up limited resources and simplify the necessary steps for user land. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-19Merge branch 'linus' into queueMarcelo Tosatti
Merge reason: development work has dependency on kvm patches merged upstream. Conflicts: Documentation/feature-removal-schedule.txt Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-19KVM: lock slots_lock around device assignmentAlex Williamson
As pointed out by Jason Baron, when assigning a device to a guest we first set the iommu domain pointer, which enables mapping and unmapping of memory slots to the iommu. This leaves a window where this path is enabled, but we haven't synchronized the iommu mappings to the existing memory slots. Thus a slot being removed at that point could send us down unexpected code paths removing non-existent pinnings and iommu mappings. Take the slots_lock around creating the iommu domain and initial mappings as well as around iommu teardown to avoid this race. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-16KVM: dont clear TMR on EOIMichael S. Tsirkin
Intel spec says that TMR needs to be set/cleared when IRR is set, but kvm also clears it on EOI. I did some tests on a real (AMD based) system, and I see same TMR values both before and after EOI, so I think it's a minor bug in kvm. This patch fixes TMR to be set/cleared on IRR set only as per spec. And now that we don't clear TMR, we can save an atomic read of TMR on EOI that's not propagated to ioapic, by checking whether ioapic needs a specific vector first and calculating the mode afterwards. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-11KVM: unmap pages from the iommu when slots are removedAlex Williamson
We've been adding new mappings, but not destroying old mappings. This can lead to a page leak as pages are pinned using get_user_pages, but only unpinned with put_page if they still exist in the memslots list on vm shutdown. A memslot that is destroyed while an iommu domain is enabled for the guest will therefore result in an elevated page reference count that is never cleared. Additionally, without this fix, the iommu is only programmed with the first translation for a gpa. This can result in peer-to-peer errors if a mapping is destroyed and replaced by a new mapping at the same gpa as the iommu will still be pointing to the original, pinned memory address. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-04-08KVM: Remove unused dirty_bitmap_head and nr_dirty_pagesTakuya Yoshikawa
Now that we do neither double buffering nor heuristic selection of the write protection method these are not needed anymore. Note: some drivers have their own implementation of set_bit_le() and making it generic needs a bit of work; so we use test_and_set_bit_le() and will later replace it with generic set_bit_le(). Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-08KVM: fix kvm_vcpu_kick build failure on S390Marcelo Tosatti
S390's kvm_vcpu_stat does not contain halt_wakeup member. Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-08KVM: Factor out kvm_vcpu_kick to arch-generic codeChristoffer Dall
The kvm_vcpu_kick function performs roughly the same funcitonality on most all architectures, so we shouldn't have separate copies. PowerPC keeps a pointer to interchanging waitqueues on the vcpu_arch structure and to accomodate this special need a __KVM_HAVE_ARCH_VCPU_GET_WQ define and accompanying function kvm_arch_vcpu_wq have been defined. For all other architectures this is a generic inline that just returns &vcpu->wq; Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Christoffer Dall <c.dall@virtualopensystems.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-04-08KVM: resize kvm_io_range array dynamicallyAmos Kong
This patch makes the kvm_io_range array can be resized dynamically. Signed-off-by: Amos Kong <akong@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-20KVM: Convert intx_mask_lock to spin lockJan Kiszka
As kvm_notify_acked_irq calls kvm_assigned_dev_ack_irq under rcu_read_lock, we cannot use a mutex in the latter function. Switch to a spin lock to address this. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: use correct tlbs dirty type in cmpxchgAlex Shi
Using 'int' type is not suitable for a 'long' object. So, correct it. Signed-off-by: Alex Shi <alex.shi@intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: Allow host IRQ sharing for assigned PCI 2.3 devicesJan Kiszka
PCI 2.3 allows to generically disable IRQ sources at device level. This enables us to share legacy IRQs of such devices with other host devices when passing them to a guest. The new IRQ sharing feature introduced here is optional, user space has to request it explicitly. Moreover, user space can inform us about its view of PCI_COMMAND_INTX_DISABLE so that we can avoid unmasking the interrupt and signaling it if the guest masked it via the virtualized PCI config space. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Acked-by: Alex Williamson <alex.williamson@redhat.com> Acked-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: Ensure all vcpus are consistent with in-kernel irqchip settingsAvi Kivity
If some vcpus are created before KVM_CREATE_IRQCHIP, then irqchip_in_kernel() and vcpu->arch.apic will be inconsistent, leading to potential NULL pointer dereferences. Fix by: - ensuring that no vcpus are installed when KVM_CREATE_IRQCHIP is called - ensuring that a vcpu has an apic if it is installed after KVM_CREATE_IRQCHIP This is somewhat long winded because vcpu->arch.apic is created without kvm->lock held. Based on earlier patch by Michael Ellerman. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: mmu_notifier: Flush TLBs before releasing mmu_lockTakuya Yoshikawa
Other threads may process the same page in that small window and skip TLB flush and then return before these functions do flush. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: Introduce kvm_memory_slot::arch and move lpage_info into itTakuya Yoshikawa
Some members of kvm_memory_slot are not used by every architecture. This patch is the first step to make this difference clear by introducing kvm_memory_slot::arch; lpage_info is moved into it. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: Simplify ifndef conditional usage in __kvm_set_memory_region()Takuya Yoshikawa
Narrow down the controlled text inside the conditional so that it will include lpage_info and rmap stuff only. For this we change the way we check whether the slot is being created from "if (npages && !new.rmap)" to "if (npages && !old.npages)". We also stop checking if lpage_info is NULL when we create lpage_info because we do it from inside the slot creation code block. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: Split lpage_info creation out from __kvm_set_memory_region()Takuya Yoshikawa
This makes it easy to make lpage_info architecture specific. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-08KVM: Introduce gfn_to_index() which returns the index for a given levelTakuya Yoshikawa
This patch cleans up the code and removes the "(void)level;" warning suppressor. Note that we can also use this for PT_PAGE_TABLE_LEVEL to treat every level uniformly later. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: Move gfn_to_memslot() to kvm_host.hPaul Mackerras
This moves __gfn_to_memslot() and search_memslots() from kvm_main.c to kvm_host.h to reduce the code duplication caused by the need for non-modular code in arch/powerpc/kvm/book3s_hv_rm_mmu.c to call gfn_to_memslot() in real mode. Rather than putting gfn_to_memslot() itself in a header, which would lead to increased code size, this puts __gfn_to_memslot() in a header. Then, the non-modular uses of gfn_to_memslot() are changed to call __gfn_to_memslot() instead. This way there is only one place in the source code that needs to be changed should the gfn_to_memslot() implementation need to be modified. On powerpc, the Book3S HV style of KVM has code that is called from real mode which needs to call gfn_to_memslot() and thus needs this. (Module code is allocated in the vmalloc region, which can't be accessed in real mode.) With this, we can remove builtin_gfn_to_memslot() from book3s_hv_rm_mmu.c. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Avi Kivity <avi@redhat.com> Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: fix error handling for out of range irqMichael S. Tsirkin
find_index_from_host_irq returns 0 on error but callers assume < 0 on error. This should not matter much: an out of range irq should never happen since irq handler was registered with this irq #, and even if it does we get a spurious msix irq in guest and typically nothing terrible happens. Still, better to make it consistent. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: Add barriers to allow mmu_notifier_retry to be used locklesslyPaul Mackerras
This adds an smp_wmb in kvm_mmu_notifier_invalidate_range_end() and an smp_rmb in mmu_notifier_retry() so that mmu_notifier_retry() will give the correct answer when called without kvm->mmu_lock being held. PowerPC Book3S HV KVM wants to use a bitlock per guest page rather than a single global spinlock in order to improve the scalability of updates to the guest MMU hashed page table, and so needs this. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Avi Kivity <avi@redhat.com> Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: ucontrol: export SIE control block to userCarsten Otte
This patch exports the s390 SIE hardware control block to userspace via the mapping of the vcpu file descriptor. In order to do so, a new arch callback named kvm_arch_vcpu_fault is introduced for all architectures. It allows to map architecture specific pages. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-03-05KVM: s390: add parameter for KVM_CREATE_VMCarsten Otte
This patch introduces a new config option for user controlled kernel virtual machines. It introduces a parameter to KVM_CREATE_VM that allows to set bits that alter the capabilities of the newly created virtual machine. The parameter is passed to kvm_arch_init_vm for all architectures. The only valid modifier bit for now is KVM_VM_S390_UCONTROL. This requires CAP_SYS_ADMIN privileges and creates a user controlled virtual machine on s390 architectures. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2012-02-01KVM: Fix __set_bit() race in mark_page_dirty() during dirty loggingTakuya Yoshikawa
It is possible that the __set_bit() in mark_page_dirty() is called simultaneously on the same region of memory, which may result in only one bit being set, because some callers do not take mmu_lock before mark_page_dirty(). This problem is hard to produce because when we reach mark_page_dirty() beginning from, e.g., tdp_page_fault(), mmu_lock is being held during __direct_map(): making kvm-unit-tests' dirty log api test write to two pages concurrently was not useful for this reason. So we have confirmed that there can actually be race condition by checking if some callers really reach there without holding mmu_lock using spin_is_locked(): probably they were from kvm_write_guest_page(). To fix this race, this patch changes the bit operation to the atomic version: note that nr_dirty_pages also suffers from the race but we do not need exactly correct numbers for now. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-10Merge branch 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommuLinus Torvalds
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (53 commits) iommu/amd: Set IOTLB invalidation timeout iommu/amd: Init stats for iommu=pt iommu/amd: Remove unnecessary cache flushes in amd_iommu_resume iommu/amd: Add invalidate-context call-back iommu/amd: Add amd_iommu_device_info() function iommu/amd: Adapt IOMMU driver to PCI register name changes iommu/amd: Add invalid_ppr callback iommu/amd: Implement notifiers for IOMMUv2 iommu/amd: Implement IO page-fault handler iommu/amd: Add routines to bind/unbind a pasid iommu/amd: Implement device aquisition code for IOMMUv2 iommu/amd: Add driver stub for AMD IOMMUv2 support iommu/amd: Add stat counter for IOMMUv2 events iommu/amd: Add device errata handling iommu/amd: Add function to get IOMMUv2 domain for pdev iommu/amd: Implement function to send PPR completions iommu/amd: Implement functions to manage GCR3 table iommu/amd: Implement IOMMUv2 TLB flushing routines iommu/amd: Add support for IOMMUv2 domain mode iommu/amd: Add amd_iommu_domain_direct_map function ...
2012-01-09Merge branches 'iommu/fixes', 'arm/omap' and 'x86/amd' into nextJoerg Roedel
Conflicts: drivers/pci/hotplug/acpiphp_glue.c
2011-12-27KVM: ensure that debugfs entries have been createdHamo
by checking the return value from kvm_init_debug, we can ensure that the entries under debugfs for KVM have been created correctly. Signed-off-by: Yang Bai <hamo.by@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-27KVM: drop bsp_vcpu pointer from kvm structGleb Natapov
Drop bsp_vcpu pointer from kvm struct since its only use is incorrect anyway. Signed-off-by: Gleb Natapov <gleb@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-27KVM: Use memdup_user instead of kmalloc/copy_from_userSasha Levin
Switch to using memdup_user when possible. This makes code more smaller and compact, and prevents errors. Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: Use kmemdup() instead of kmalloc/memcpySasha Levin
Switch to kmemdup() in two places to shorten the code and avoid possible bugs. Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: Allow aligned byte and word writes to IOAPIC registers.Julian Stecklina
This fixes byte accesses to IOAPIC_REG_SELECT as mandated by at least the ICH10 and Intel Series 5 chipset specs. It also makes ioapic_mmio_write consistent with ioapic_mmio_read, which also allows byte and word accesses. Signed-off-by: Julian Stecklina <js@alien8.de> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: introduce a table to map slot id to index in memslots arrayXiao Guangrong
The operation of getting dirty log is frequent when framebuffer-based displays are used(for example, Xwindow), so, we introduce a mapping table to speed up id_to_memslot() Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: sort memslots by its size and use line searchXiao Guangrong
Sort memslots base on its size and use line search to find it, so that the larger memslots have better fit The idea is from Avi Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: introduce id_to_memslot functionXiao Guangrong
Introduce id_to_memslot to get memslot by slot id Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: introduce kvm_for_each_memslot macroXiao Guangrong
Introduce kvm_for_each_memslot to walk all valid memslot Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: introduce update_memslots functionXiao Guangrong
Introduce update_memslots to update slot which will be update to kvm->memslots Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: introduce KVM_MEM_SLOTS_NUM macroXiao Guangrong
Introduce KVM_MEM_SLOTS_NUM macro to instead of KVM_MEMORY_SLOTS + KVM_PRIVATE_MEM_SLOTS Signed-off-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: Count the number of dirty pages for dirty loggingTakuya Yoshikawa
Needed for the next patch which uses this number to decide how to write protect a slot. Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp> Signed-off-by: Avi Kivity <avi@redhat.com>
2011-12-27KVM: Use kmemdup rather than duplicating its implementationThomas Meyer
Use kmemdup rather than duplicating its implementation The semantic patch that makes this change is available in scripts/coccinelle/api/memdup.cocci. More information about semantic patching is available at http://coccinelle.lip6.fr/ Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-27KVM: make checks stricter in coalesced_mmio_in_range()Dan Carpenter
My testing version of Smatch complains that addr and len come from the user and they can wrap. The path is: -> kvm_vm_ioctl() -> kvm_vm_ioctl_unregister_coalesced_mmio() -> coalesced_mmio_in_range() I don't know what the implications are of wrapping here, but we may as well fix it, if only to silence the warning. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-25KVM: Device assignment permission checksAlex Williamson
Only allow KVM device assignment to attach to devices which: - Are not bridges - Have BAR resources (assume others are special devices) - The user has permissions to use Assigning a bridge is a configuration error, it's not supported, and typically doesn't result in the behavior the user is expecting anyway. Devices without BAR resources are typically chipset components that also don't have host drivers. We don't want users to hold such devices captive or cause system problems by fencing them off into an iommu domain. We determine "permission to use" by testing whether the user has access to the PCI sysfs resource files. By default a normal user will not have access to these files, so it provides a good indication that an administration agent has granted the user access to the device. [Yang Bai: add missing #include] [avi: fix comment style] Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Yang Bai <hamo.by@gmail.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-12-25KVM: Remove ability to assign a device without iommu supportAlex Williamson
This option has no users and it exposes a security hole that we can allow devices to be assigned without iommu protection. Make KVM_DEV_ASSIGN_ENABLE_IOMMU a mandatory option. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
2011-11-10iommu/core: split mapping to page sizes as supported by the hardwareOhad Ben-Cohen
When mapping a memory region, split it to page sizes as supported by the iommu hardware. Always prefer bigger pages, when possible, in order to reduce the TLB pressure. The logic to do that is now added to the IOMMU core, so neither the iommu drivers themselves nor users of the IOMMU API have to duplicate it. This allows a more lenient granularity of mappings; traditionally the IOMMU API took 'order' (of a page) as a mapping size, and directly let the low level iommu drivers handle the mapping, but now that the IOMMU core can split arbitrary memory regions into pages, we can remove this limitation, so users don't have to split those regions by themselves. Currently the supported page sizes are advertised once and they then remain static. That works well for OMAP and MSM but it would probably not fly well with intel's hardware, where the page size capabilities seem to have the potential to be different between several DMA remapping devices. register_iommu() currently sets a default pgsize behavior, so we can convert the IOMMU drivers in subsequent patches. After all the drivers are converted, the temporary default settings will be removed. Mainline users of the IOMMU API (kvm and omap-iovmm) are adopted to deal with bytes instead of page order. Many thanks to Joerg Roedel <Joerg.Roedel@amd.com> for significant review! Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Cc: David Brown <davidb@codeaurora.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Joerg Roedel <Joerg.Roedel@amd.com> Cc: Stepan Moskovchenko <stepanm@codeaurora.org> Cc: KyongHo Cho <pullip.cho@samsung.com> Cc: Hiroshi DOYU <hdoyu@nvidia.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: kvm@vger.kernel.org Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2011-10-31kvm: iommu.c file requires the full module.h present.Paul Gortmaker
This file has things like module_param_named() and MODULE_PARM_DESC() so it needs the full module.h header present. Without it, you'll get: CC arch/x86/kvm/../../../virt/kvm/iommu.o virt/kvm/iommu.c:37: error: expected ‘)’ before ‘bool’ virt/kvm/iommu.c:39: error: expected ‘)’ before string constant make[3]: *** [arch/x86/kvm/../../../virt/kvm/iommu.o] Error 1 make[2]: *** [arch/x86/kvm] Error 2 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31kvm: fix implicit use of stat.h header filePaul Gortmaker
This was coming in via an implicit module.h (and its sub-includes) before, but we'll be cleaning that up shortly. Call out the stat.h include requirement in advance. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-30Merge branch 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommuLinus Torvalds
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (33 commits) iommu/core: Remove global iommu_ops and register_iommu iommu/msm: Use bus_set_iommu instead of register_iommu iommu/omap: Use bus_set_iommu instead of register_iommu iommu/vt-d: Use bus_set_iommu instead of register_iommu iommu/amd: Use bus_set_iommu instead of register_iommu iommu/core: Use bus->iommu_ops in the iommu-api iommu/core: Convert iommu_found to iommu_present iommu/core: Add bus_type parameter to iommu_domain_alloc Driver core: Add iommu_ops to bus_type iommu/core: Define iommu_ops and register_iommu only with CONFIG_IOMMU_API iommu/amd: Fix wrong shift direction iommu/omap: always provide iommu debug code iommu/core: let drivers know if an iommu fault handler isn't installed iommu/core: export iommu_set_fault_handler() iommu/omap: Fix build error with !IOMMU_SUPPORT iommu/omap: Migrate to the generic fault report mechanism iommu/core: Add fault reporting mechanism iommu/core: Use PAGE_SIZE instead of hard-coded value iommu/core: use the existing IS_ALIGNED macro iommu/msm: ->unmap() should return order of unmapped page ... Fixup trivial conflicts in drivers/iommu/Makefile: "move omap iommu to dedicated iommu folder" vs "Rename the DMAR and INTR_REMAP config options" just happened to touch lines next to each other.
