We only perform work in kvm_assigned_dev_ack_irq if the guest IRQ is of
INTx type. This completely avoids the callback invocation in non-INTx
cases by registering the IRQ ack notifier only for INTx.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
Currently the method of dealing with an IO operation on a bus (PIO/MMIO)
is to call the read or write callback for each device registered
on the bus until we find a device which handles it.
Since the number of devices on a bus can be significant due to ioeventfds
and coalesced MMIO zones, this leads to a lot of overhead on each IO
operation.
Instead of registering devices, we now register ranges which points to
a device. Lookup is done using an efficient bsearch instead of a linear
search.
Performance test was conducted by comparing exit count per second with
200 ioeventfds created on one byte and the guest is trying to access a
different byte continuously (triggering usermode exits).
Before the patch the guest has achieved 259k exits per second, after the
patch the guest does 274k exits per second.
Cc: Avi Kivity <avi@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
This patch changes coalesced mmio to create one mmio device per
zone instead of handling all zones in one device.
Doing so enables us to take advantage of existing locking and prevents
a race condition between coalesced mmio registration/unregistration
and lookups.
Suggested-by: Avi Kivity <avi@redhat.com>
Move the check whether there are available entries to within the spinlock.
This allows working with larger amount of VCPUs and reduces premature
exits when using a large number of VCPUs.
Cc: Pekka Enberg <penberg@kernel.org>
Device drivers that create and destroy SR-IOV virtual functions via
calls to pci_enable_sriov() and pci_disable_sriov can cause catastrophic
failures if they attempt to destroy VFs while they are assigned to
guest virtual machines. By adding a flag for use by the KVM module
to indicate that a device is assigned a device driver can check that
flag and avoid destroying VFs while they are assigned and avoid system
failures.
CC: Ian Campbell <ijc@hellion.org.uk>
CC: Konrad Wilk <konrad.wilk@oracle.com>
Signed-off-by: Greg Rose <gregory.v.rose@intel.com>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
IOMMU interrupt remapping support provides a further layer of
isolation for device assignment by preventing arbitrary interrupt
block DMA writes by a malicious guest from reaching the host. By
default, we should require that the platform provides interrupt
remapping support, with an opt-in mechanism for existing behavior.
Both AMD IOMMU and Intel VT-d2 hardware support interrupt
remapping, however we currently only have software support on
the Intel side. Users wishing to re-enable device assignment
when interrupt remapping is not supported on the platform can
use the "allow_unsafe_assigned_interrupts=1" module option.
[avi: break long lines]
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
The idea is from Avi:
| We could cache the result of a miss in an spte by using a reserved bit, and
| checking the page fault error code (or seeing if we get an ept violation or
| ept misconfiguration), so if we get repeated mmio on a page, we don't need to
| search the slot list/tree.
| (https://lkml.org/lkml/2011/2/22/221)
When the page fault is caused by mmio, we cache the info in the shadow page
table, and also set the reserved bits in the shadow page table, so if the mmio
is caused again, we can quickly identify it and emulate it directly
Searching mmio gfn in memslots is heavy since we need to walk all memeslots, it
can be reduced by this feature, and also avoid walking guest page table for
soft mmu.
[jan: fix operator precedence issue]
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
If the page fault is caused by mmio, the gfn can not be found in memslots, and
'bad_pfn' is returned on gfn_to_hva path, so we can use 'bad_pfn' to identify
the mmio page fault.
And, to clarify the meaning of mmio pfn, we return fault page instead of bad
page when the gfn is not allowd to prefetch
Introduce kvm_read_guest_cached() function in addition to write one we
already have.
[ by glauber: export function signature in kvm header ]
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Signed-off-by: Glauber Costa <glommer@redhat.com>
Tested-by: Eric Munson <emunson@mgebm.net>
KVM_MAX_MSIX_PER_DEV implies that up to that many MSI-X entries can be
requested. But the kernel so far rejected already the upper limit.
KVM has an ioctl to define which signal mask should be used while running
inside VCPU_RUN. At least for big endian systems, this mask is different
on 32-bit and 64-bit systems (though the size is identical).
Add a compat wrapper that converts the mask to whatever the kernel accepts,
allowing 32-bit kvm user space to set signal masks.
This patch fixes qemu with --enable-io-thread on ppc64 hosts when running
32-bit user land.
So far kvm_arch_vcpu_setup is responsible for freeing the vcpu struct if
it fails. Move this confusing resonsibility back into the hands of
kvm_vm_ioctl_create_vcpu. Only kvm_arch_vcpu_setup of x86 is affected,
all other archs cannot fail.
Simply use __copy_to_user/__clear_user to write guest page since we have
already verified the user address when the memslot is set
* 'kvm-updates/3.0' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: Initialize kvm before registering the mmu notifier
KVM: x86: use proper port value when checking io instruction permission
KVM: add missing void __user * cast to access_ok() call
It doesn't make sense to ever see a half-initialized kvm structure on
mmu notifier callbacks. Previously, 85722cda changed the ordering to
ensure that the mmu_lock was initialized before mmu notifier
registration, but there is still a race where the mmu notifier could
come in and try accessing other portions of struct kvm before they are
intialized.
Solve this by moving the mmu notifier registration to occur after the
structure is completely initialized.
Google-Bug-Id: 452199
Signed-off-by: Mike Waychison <mikew@google.com>
fa3d315a "KVM: Validate userspace_addr of memslot when registered" introduced
this new warning onn s390:
kvm_main.c: In function '__kvm_set_memory_region':
kvm_main.c:654:7: warning: passing argument 1 of '__access_ok' makes pointer from integer without a cast
arch/s390/include/asm/uaccess.h:53:19: note: expected 'const void *' but argument is of type '__u64'
Add the missing cast to get rid of it again...
Cc: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits)
PCI: Don't use dmi_name_in_vendors in quirk
PCI: remove unused AER functions
PCI/sysfs: move bus cpuaffinity to class dev_attrs
PCI: add rescan to /sys/.../pci_bus/.../
PCI: update bridge resources to get more big ranges when allocating space (again)
KVM: Use pci_store/load_saved_state() around VM device usage
PCI: Add interfaces to store and load the device saved state
PCI: Track the size of each saved capability data area
PCI/e1000e: Add and use pci_disable_link_state_locked()
x86/PCI: derive pcibios_last_bus from ACPI MCFG
PCI: add latency tolerance reporting enable/disable support
PCI: add OBFF enable/disable support
PCI: add ID-based ordering enable/disable support
PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot.
PCI: Set PCIE maxpayload for card during hotplug insertion
PCI/ACPI: Report _OSC control mask returned on failure to get control
x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs
PCI: handle positive error codes
PCI: check pci_vpd_pci22_wait() return
PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio
Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461
moved the intel SMBUS ID definitons to the i2c-i801.c driver.
Like the following, mmu_notifier can be called after registering
immediately. So, kvm have to initialize kvm->mmu_lock before it.
BUG: spinlock bad magic on CPU#0, kswapd0/342
lock: ffff8800af8c4000, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
Pid: 342, comm: kswapd0 Not tainted 2.6.39-rc5+ #1
Call Trace:
[<ffffffff8118ce61>] spin_bug+0x9c/0xa3
[<ffffffff8118ce91>] do_raw_spin_lock+0x29/0x13c
[<ffffffff81024923>] ? flush_tlb_others_ipi+0xaf/0xfd
[<ffffffff812e22f3>] _raw_spin_lock+0x9/0xb
[<ffffffffa0582325>] kvm_mmu_notifier_clear_flush_young+0x2c/0x66 [kvm]
[<ffffffff810d3ff3>] __mmu_notifier_clear_flush_young+0x2b/0x57
[<ffffffff810c8761>] page_referenced_one+0x88/0xea
[<ffffffff810c89bf>] page_referenced+0x1fc/0x256
[<ffffffff810b2771>] shrink_page_list+0x187/0x53a
[<ffffffff810b2ed7>] shrink_inactive_list+0x1e0/0x33d
[<ffffffff810acf95>] ? determine_dirtyable_memory+0x15/0x27
[<ffffffff812e90ee>] ? call_function_single_interrupt+0xe/0x20
[<ffffffff810b3356>] shrink_zone+0x322/0x3de
[<ffffffff810a9587>] ? zone_watermark_ok_safe+0xe2/0xf1
[<ffffffff810b3928>] kswapd+0x516/0x818
[<ffffffff810b3412>] ? shrink_zone+0x3de/0x3de
[<ffffffff81053d17>] kthread+0x7d/0x85
[<ffffffff812e9394>] kernel_thread_helper+0x4/0x10
[<ffffffff81053c9a>] ? __init_kthread_worker+0x37/0x37
[<ffffffff812e9390>] ? gs_change+0xb/0xb
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
This way, we can avoid checking the user space address many times when
we read the guest memory.
Although we can do the same for write if we check which slots are
writable, we do not care write now: reading the guest memory happens
more often than writing.
[avi: change VERIFY_READ to VERIFY_WRITE]
Signed-off-by: Takuya Yoshikawa <yoshikawa.takuya@oss.ntt.co.jp>
Function ioapic_debug() in the ioapic_deliver() misnames
one filed by reference. This patch correct it.
Signed-off-by: Liu Yuan <tailai.ly@taobao.com>
Store the device saved state so that we can reload the device back
to the original state when it's unassigned. This has the benefit
that the state survives across pci_reset_function() calls via
the PCI sysfs reset interface while the VM is using the device.
Acked-by: Avi Kivity <avi@redhat.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
We can get memslot id from memslot->id directly
* 'kvm-updates/2.6.39' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: move and fix substitue search for missing CPUID entries
KVM: fix XSAVE bit scanning
KVM: Enable async page fault processing
KVM: fix crash on irqfd deassign
If asynchronous hva_to_pfn() is requested call GUP with FOLL_NOWAIT to
avoid sleeping on IO. Check for hwpoison is done at the same time,
otherwise check_user_page_hwpoison() will call GUP again and will put
vcpu to sleep.
irqfd in kvm used flush_work incorrectly: it assumed that work scheduled
previously can't run after flush_work, but since kvm uses a non-reentrant
workqueue (by means of schedule_work) we need flush_work_sync to get that
guarantee.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Reported-by: Jean-Philippe Menil <jean-philippe.menil@univ-nantes.fr>
Tested-by: Jean-Philippe Menil <jean-philippe.menil@univ-nantes.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6
* 'syscore' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6:
Introduce ARCH_NO_SYSDEV_OPS config option (v2)
cpufreq: Use syscore_ops for boot CPU suspend/resume (v2)
KVM: Use syscore_ops instead of sysdev class and sysdev
PCI / Intel IOMMU: Use syscore_ops instead of sysdev class and sysdev
timekeeping: Use syscore_ops instead of sysdev class and sysdev
x86: Use syscore_ops instead of sysdev classes and sysdevs
As a preparation for removing ext2 non-atomic bit operations from
asm/bitops.h. This converts ext2 non-atomic bit operations to
little-endian bit operations.
asm-generic/bitops/le.h is only intended to be included directly from
asm-generic/bitops/ext2-non-atomic.h or asm-generic/bitops/minix-le.h
which implements generic ext2 or minix bit operations.
This stops including asm-generic/bitops/le.h directly and use ext2
non-atomic bit operations instead.
It seems odd to use ext2_set_bit() on kvm, but it will replaced with
__set_bit_le() after introducing little endian bit operations for all
architectures. This indirect step is necessary to maintain bisectability
for some architectures which have their own little-endian bit operations.
KVM uses a sysdev class and a sysdev for executing kvm_suspend()
after interrupts have been turned off on the boot CPU (during system
suspend) and for executing kvm_resume() before turning on interrupts
on the boot CPU (during system resume). However, since both of these
functions ignore their arguments, the entire mechanism may be
replaced with a struct syscore_ops object which is simpler.
The RCU use in kvm_irqfd_deassign is tricky: we have rcu_assign_pointer
but no synchronize_rcu: synchronize_rcu is done by kvm_irq_routing_update
which we share a spinlock with.
Fix up a comment in an attempt to make this clearer.
Code under this lock requires non-preemptibility. Ensure this also over
-rt by converting it to raw spinlock.
Instead of sleeping in kvm_vcpu_on_spin, which can cause gigantic
slowdowns of certain workloads, we instead use yield_to to get
another VCPU in the same KVM guest to run sooner.
This seems to give a 10-15% speedup in certain workloads.
Signed-off-by: Rik van Riel <riel@redhat.com>
Keep track of which task is running a KVM vcpu. This helps us
figure out later what task to wake up if we want to boost a
vcpu that got preempted.
Unfortunately there are no guarantees that the same task
always keeps the same vcpu, so we can only track the task
across a single "run" of the vcpu.
is_hwpoison_address only checks whether the page table entry is
hwpoisoned, regardless the memory page mapped. While __get_user_pages
will check both.
QEMU will clear the poisoned page table entry (via unmap/map) to make
it possible to allocate a new memory page for the virtual address
across guest rebooting. But it is also possible that the underlying
memory page is kept poisoned even after the corresponding page table
entry is cleared, that is, a new memory page can not be allocated.
__get_user_pages can catch these situations.
Signed-off-by: Huang Ying <ying.huang@intel.com>
Now, we have 'vcpu->mode' to judge whether need to send ipi to other
cpus, this way is very exact, so checking request bit is needless,
then we can drop the spinlock let it's collateral
Currently we keep track of only two states: guest mode and host
mode. This patch adds an "exiting guest mode" state that tells
us that an IPI will happen soon, so unless we need to wait for the
IPI, we can avoid it completely.
Also
1: No need atomically to read/write ->mode in vcpu's thread
2: reorganize struct kvm_vcpu to make ->mode and ->requests
in the same cache line explicitly
Get rid of this warning:
CC arch/s390/kvm/../../../virt/kvm/kvm_main.o
arch/s390/kvm/../../../virt/kvm/kvm_main.c:596:12: warning: 'kvm_create_dirty_bitmap' defined but not used
The only caller of the function is within a !CONFIG_S390 section, so add the
same ifdef around kvm_create_dirty_bitmap() as well.
Instead, drop large mappings, which were the reason we dropped shadow.
Cleanup some code with common compound_trans_head helper.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Johannes Weiner <jweiner@redhat.com>
For GRU and EPT, we need gup-fast to set referenced bit too (this is why
it's correct to return 0 when shadow_access_mask is zero, it requires
gup-fast to set the referenced bit). qemu-kvm access already sets the
young bit in the pte if it isn't zero-copy, if it's zero copy or a shadow
paging EPT minor fault we relay on gup-fast to signal the page is in
use...
We also need to check the young bits on the secondary pagetables for NPT
and not nested shadow mmu as the data may never get accessed again by the
primary pte.
Without this closer accuracy, we'd have to remove the heuristic that
avoids collapsing hugepages in hugepage virtual regions that have not even
a single subpage in use.
->test_young is full backwards compatible with GRU and other usages that
don't have young bits in pagetables set by the hardware and that should
nuke the secondary mmu mappings when ->clear_flush_young runs just like
EPT does.
Removing the heuristic that checks the young bit in
khugepaged/collapse_huge_page completely isn't so bad either probably but
I thought it was worth it and this makes it reliable.
This should work for both hugetlbfs and transparent hugepages.
[akpm@linux-foundation.org: bring forward PageTransCompound() addition for bisectability]
Since vmx blocks INIT signals, we disable virtualization extensions during
reboot. This leads to virtualization instructions faulting; we trap these
faults and spin while the reboot continues.
Unfortunately spinning on a non-preemptible kernel may block a task that
reboot depends on; this causes the reboot to hang.
Fix by skipping over the instruction and hoping for the best.
Quote from Avi:
| I don't think we need to flush immediately; set a "tlb dirty" bit somewhere
| that is cleareded when we flush the tlb. kvm_mmu_notifier_invalidate_page()
| can consult the bit and force a flush if set.
Store irq routing table pointer in the irqfd object,
and use that to inject MSI directly without bouncing out to
a kernel thread.
While we touch this structure, rearrange irqfd fields to make fastpath
better packed for better cache utilization.
This also adds some comments about locking rules and rcu usage in code.
Some notes on the design:
- Use pointer into the rt instead of copying an entry,
to make it possible to use rcu, thus side-stepping
locking complexities. We also save some memory this way.
- Old workqueue code is still used for level irqs.
I don't think we DTRT with level anyway, however,
it seems easier to keep the code around as
it has been thought through and debugged, and fix level later than
rip out and re-instate it later.
Acked-by: Marcelo Tosatti <mtosatti@redhat.com>
Acked-by: Gregory Haskins <ghaskins@novell.com>
The naming convension of hardware_[dis|en]able family is little bit confusing
because only hardware_[dis|en]able_all are using _nolock suffix.
Renaming current hardware_[dis|en]able() to *_nolock() and using
hardware_[dis|en]able() as wrapper functions which take kvm_lock for them
reduces extra confusion.
In kvm_cpu_hotplug(), only CPU_STARTING case is protected by kvm_lock.
This patch adds missing protection for CPU_DYING case.
Any arch not supporting device assigment will also not build
assigned-dev.c. So testing for KVM_CAP_DEVICE_DEASSIGNMENT is pointless.
KVM_CAP_ASSIGN_DEV_IRQ is unconditinally set. Moreover, add a default
case for dispatching the ioctl.
Acked-by: Alex Williamson <alex.williamson@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
The guest may change states that pci_reset_function does not touch. So
we better save/restore the assigned device across guest usage.
