commit 744961341d472db6272ed9b42319a90f5a2aa7c4 upstream.
KVM guest can fail to startup with following trace on host:
qemu-system-x86: page allocation failure: order:4, mode:0x40d0
Call Trace:
dump_stack+0x47/0x67
warn_alloc_failed+0xee/0x150
__alloc_pages_direct_compact+0x14a/0x150
__alloc_pages_nodemask+0x776/0xb80
alloc_kmem_pages+0x3a/0x110
kmalloc_order+0x13/0x50
kmemdup+0x1b/0x40
__kvm_set_memory_region+0x24a/0x9f0 [kvm]
kvm_set_ioapic+0x130/0x130 [kvm]
kvm_set_memory_region+0x21/0x40 [kvm]
kvm_vm_ioctl+0x43f/0x750 [kvm]
Failure happens when attempting to allocate pages for
'struct kvm_memslots', however it doesn't have to be
present in physically contiguous (kmalloc-ed) address
space, change allocation to kvm_kvzalloc() so that
it will be vmalloc-ed when its size is more then a page.
Signed-off-by: Igor Mammedov <imammedo@redhat.com>
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
commit f2a81036516e2b97c07c49dd6d51d36bfa43593d upstream.
The two kmemdup invocations can be unified. I find that the new
placement of the comment makes it easier to see what happens.
Reviewed-by: Igor Mammedov <imammedo@redhat.com>
Reviewed-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp>
commit f2a25160887e00434ce1361007009120e1fecbda upstream.
__kvm_set_memory_region sets r to EINVAL very early.
Doing it again is not necessary. The same is true later on, where
r is assigned -ENOMEM twice.
Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com>
commit 3d32e4dbe71374a6780eaf51d719d76f9a9bf22f upstream.
The third parameter of kvm_unpin_pages() when called from
kvm_iommu_map_pages() is wrong, it should be the number of pages to un-pin
and not the page size.
This error was facilitated with an inconsistent API: kvm_pin_pages() takes
a size, but kvn_unpin_pages() takes a number of pages, so fix the problem
by matching the two.
This was introduced by commit 350b8bd ("kvm: iommu: fix the third parameter
of kvm_iommu_put_pages (CVE-2014-3601)"), which fixes the lack of
un-pinning for pages intended to be un-pinned (i.e. memory leak) but
unfortunately potentially aggravated the number of pages we un-pin that
should have stayed pinned. As far as I understand though, the same
practical mitigations apply.
This issue was found during review of Red Hat 6.6 patches to prepare
Ksplice rebootless updates.
Thanks to Vegard for his time on a late Friday evening to help me in
understanding this code.
Fixes: 350b8bd ("kvm: iommu: fix the third parameter of... (CVE-2014-3601)")
Signed-off-by: Quentin Casasnovas <quentin.casasnovas@oracle.com>
Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com>
Signed-off-by: Jamie Iles <jamie.iles@oracle.com>
Reviewed-by: Sasha Levin <sasha.levin@oracle.com>
commit 2ea75be3219571d0ec009ce20d9971e54af96e09 upstream.
vcpu ioctls can hang the calling thread if issued while a vcpu is running.
However, invalid ioctls can happen when userspace tries to probe the kind
of file descriptors (e.g. isatty() calls ioctl(TCGETS)); in that case,
we know the ioctl is going to be rejected as invalid anyway and we can
fail before trying to take the vcpu mutex.
This patch does not change functionality, it just makes invalid ioctls
fail faster.
Signed-off-by: David Matlack <dmatlack@google.com>
commit ee3d1570b58677885b4552bce8217fda7b226a68 upstream.
vcpu exits and memslot mutations can run concurrently as long as the
vcpu does not aquire the slots mutex. Thus it is theoretically possible
for memslots to change underneath a vcpu that is handling an exit.
If we increment the memslot generation number again after
synchronize_srcu_expedited(), vcpus can safely cache memslot generation
without maintaining a single rcu_dereference through an entire vm exit.
And much of the x86/kvm code does not maintain a single rcu_dereference
of the current memslots during each exit.
We can prevent the following case:
vcpu (CPU 0) | thread (CPU 1)
1 vm exit |
2 srcu_read_unlock(&kvm->srcu) |
3 decide to cache something based on |
old memslots |
4 | change memslots
| (increments generation)
5 | synchronize_srcu(&kvm->srcu);
6 retrieve generation # from new memslots |
7 tag cache with new memslot generation |
8 srcu_read_unlock(&kvm->srcu) |
<action based on cache occurs even |
though the caching decision was based |
on the old memslots> |
<action *continues* to occur until next |
memslot generation change, which may |
be never> |
By incrementing the generation after synchronizing with kvm->srcu readers,
we ensure that the generation retrieved in (6) will become invalid soon
after (8).
Keeping the existing increment is not strictly necessary, but we
do keep it and just move it for consistency from update_memslots to
install_new_memslots. It invalidates old cached MMIOs immediately,
instead of having to wait for the end of synchronize_srcu_expedited,
which makes the code more clearly correct in case CPU 1 is preempted
right after synchronize_srcu() returns.
To avoid halving the generation space in SPTEs, always presume that the
low bit of the generation is zero when reconstructing a generation number
out of an SPTE. This effectively disables MMIO caching in SPTEs during
the call to synchronize_srcu_expedited. Using the low bit this way is
somewhat like a seqcount---where the protected thing is a cache, and
instead of retrying we can simply punt if we observe the low bit to be 1.
Reviewed-by: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Reviewed-by: David Matlack <dmatlack@google.com>
commit 350b8bdd689cd2ab2c67c8a86a0be86cfa0751a7 upstream.
The third parameter of kvm_iommu_put_pages is wrong,
It should be 'gfn - slot->base_gfn'.
By making gfn very large, malicious guest or userspace can cause kvm to
go to this error path, and subsequently to pass a huge value as size.
Alternatively if gfn is small, then pages would be pinned but never
unpinned, causing host memory leak and local DOS.
Passing a reasonable but large value could be the most dangerous case,
because it would unpin a page that should have stayed pinned, and thus
allow the device to DMA into arbitrary memory. However, this cannot
happen because of the condition that can trigger the error:
- out of memory (where you can't allocate even a single page)
should not be possible for the attacker to trigger
- when exceeding the iommu's address space, guest pages after gfn
will also exceed the iommu's address space, and inside
kvm_iommu_put_pages() the iommu_iova_to_phys() will fail. The
page thus would not be unpinned at all.
Reported-by: Jack Morgenstein <jackm@mellanox.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
commit 0f6c0a740b7d3e1f3697395922d674000f83d060 upstream.
Currently, the EOI exit bitmap (used for APICv) does not include
interrupts that are masked. However, this can cause a bug that manifests
as an interrupt storm inside the guest. Alex Williamson reported the
bug and is the one who really debugged this; I only wrote the patch. :)
The scenario involves a multi-function PCI device with OHCI and EHCI
USB functions and an audio function, all assigned to the guest, where
both USB functions use legacy INTx interrupts.
As soon as the guest boots, interrupts for these devices turn into an
interrupt storm in the guest; the host does not see the interrupt storm.
Basically the EOI path does not work, and the guest continues to see the
interrupt over and over, even after it attempts to mask it at the APIC.
The bug is only visible with older kernels (RHEL6.5, based on 2.6.32
with not many changes in the area of APIC/IOAPIC handling).
Alex then tried forcing bit 59 (corresponding to the USB functions' IRQ)
on in the eoi_exit_bitmap and TMR, and things then work. What happens
is that VFIO asserts IRQ11, then KVM recomputes the EOI exit bitmap.
It does not have set bit 59 because the RTE was masked, so the IOAPIC
never sees the EOI and the interrupt continues to fire in the guest.
My guess was that the guest is masking the interrupt in the redirection
table in the interrupt routine, i.e. while the interrupt is set in a
LAPIC's ISR, The simplest fix is to ignore the masking state, we would
rather have an unnecessary exit rather than a missed IRQ ACK and anyway
IOAPIC interrupts are not as performance-sensitive as for example MSIs.
Alex tested this patch and it fixed his bug.
[Thanks to Alex for his precise description of the problem
and initial debugging effort. A lot of the text above is
based on emails exchanged with him.]
Reported-by: Alex Williamson <alex.williamson@redhat.com>
Tested-by: Alex Williamson <alex.williamson@redhat.com>
commit 91021a6c8ffdc55804dab5acdfc7de4f278b9ac3 upstream.
When dispatch SGI(mode == 0), that is the vcpu of VM should send
sgi to the cpu which the target_cpus list.
So, there must add the "break" to branch of case 0.
Signed-off-by: Haibin Wang <wanghaibin.wang@huawei.com>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Signed-off-by: Christoffer Dall <christoffer.dall@linaro.org>
commit 5678de3f15010b9022ee45673f33bcfc71d47b60 upstream.
QE reported that they got the BUG_ON in ioapic_service to trigger.
I cannot reproduce it, but there are two reasons why this could happen.
The less likely but also easiest one, is when kvm_irq_delivery_to_apic
does not deliver to any APIC and returns -1.
Because irqe.shorthand == 0, the kvm_for_each_vcpu loop in that
function is never reached. However, you can target the similar loop in
kvm_irq_delivery_to_apic_fast; just program a zero logical destination
address into the IOAPIC, or an out-of-range physical destination address.
commit aac5c4226e7136c331ed384c25d5560204da10a0 upstream.
If kvm_io_bus_register_dev() fails then it returns success but it should
return an error code.
I also did a little cleanup like removing an impossible NULL test.
Fixes: 2b3c246a682c ('KVM: Make coalesced mmio use a device per zone')
commit 338c7dbadd2671189cec7faf64c84d01071b3f96 upstream.
In multiple functions the vcpu_id is used as an offset into a bitfield. Ag
malicious user could specify a vcpu_id greater than 255 in order to set or
clear bits in kernel memory. This could be used to elevate priveges in the
kernel. This patch verifies that the vcpu_id provided is less than 255.
The api documentation already specifies that the vcpu_id must be less than
max_vcpus, but this is currently not checked.
Reported-by: Andrew Honig <ahonig@google.com>
Signed-off-by: Andrew Honig <ahonig@google.com>
commit 27ef63c7e97d1e5dddd85051c03f8d44cc887f34 upstream.
When determining the page size we could use to map with the IOMMU, the
page size should also be aligned with the hva, not just the gfn. The
gfn may not reflect the real alignment within the hugetlbfs file.
Most of the time, this works fine. However, if the hugetlbfs file is
backed by non-contiguous huge pages, a multi-huge page memslot starts at
an unaligned offset within the hugetlbfs file, and the gfn is aligned
with respect to the huge page size, kvm_host_page_size() will return the
huge page size and we will use that to map with the IOMMU.
When we later unpin that same memslot, the IOMMU returns the unmap size
as the huge page size, and we happily unpin that many pfns in
monotonically increasing order, not realizing we are spanning
non-contiguous huge pages and partially unpin the wrong huge page.
Ensure the IOMMU mapping page size is aligned with the hva corresponding
to the gfn, which does reflect the alignment within the hugetlbfs file.
Reviewed-by: Marcelo Tosatti <mtosatti@redhat.com>
Signed-off-by: Greg Edwards <gedwards@ddn.com>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
I don't know if this was due to cut and paste, or somebody was really
using a D20 to pick the error code for kvm_init_debugfs as suggested by
Linus (EFAULT is 14, so the possibility cannot be entirely ruled out).
In any case, this patch fixes it.
Reported-by: Tim Gardner <tim.gardner@canonical.com>
gfn_to_memslot() can return NULL or invalid slot. We need to check slot
validity before accessing it.
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
When we cancel 'async_pf_execute()', we should behave as if the work was
never scheduled in 'kvm_setup_async_pf()'.
Fixes a bug when we can't unload module because the vm wasn't destroyed.
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
Reviewed-by: Gleb Natapov <gleb@redhat.com>
Page tables in a read-only memory slot will currently cause a triple
fault because the page walker uses gfn_to_hva and it fails on such a slot.
OVMF uses such a page table; however, real hardware seems to be fine with
that as long as the accessed/dirty bits are set. Save whether the slot
is readonly, and later check it when updating the accessed and dirty bits.
Pull vfs pile 1 from Al Viro:
"Unfortunately, this merge window it'll have a be a lot of small piles -
my fault, actually, for not keeping #for-next in anything that would
resemble a sane shape ;-/
This pile: assorted fixes (the first 3 are -stable fodder, IMO) and
cleanups + %pd/%pD formats (dentry/file pathname, up to 4 last
components) + several long-standing patches from various folks.
There definitely will be a lot more (starting with Miklos'
check_submount_and_drop() series)"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits)
direct-io: Handle O_(D)SYNC AIO
direct-io: Implement generic deferred AIO completions
add formats for dentry/file pathnames
kvm eventfd: switch to fdget
powerpc kvm: use fdget
switch fchmod() to fdget
switch epoll_ctl() to fdget
switch copy_module_from_fd() to fdget
git simplify nilfs check for busy subtree
ibmasmfs: don't bother passing superblock when not needed
don't pass superblock to hypfs_{mkdir,create*}
don't pass superblock to hypfs_diag_create_files
don't pass superblock to hypfs_vm_create_files()
oprofile: get rid of pointless forward declarations of struct super_block
oprofilefs_create_...() do not need superblock argument
oprofilefs_mkdir() doesn't need superblock argument
don't bother with passing superblock to oprofile_create_stats_files()
oprofile: don't bother with passing superblock to ->create_files()
don't bother passing sb to oprofile_create_files()
coh901318: don't open-code simple_read_from_buffer()
For bytemaps each IRQ field is 1 byte wide, so we pack 4 irq fields in
one word and since there are 32 private (per cpu) irqs, we have 8
private u32 fields on the vgic_bytemap struct. We shift the offset from
the base of the register group right by 2, giving us the word index
instead of the field index. But then there are 8 private words, not 4,
which is also why we subtract 8 words from the offset of the shared
words.
All the code in handle_mmio_cfg_reg() assumes the offset has
been shifted right to accomodate for the 2:1 bit compression,
but this is only done when getting the register address.
Shift the offset early so the code works mostly unchanged.
Reported-by: Zhaobo (Bob, ERC) <zhaobo@huawei.com>
vgic_get_target_reg is quite complicated, for no good reason.
Actually, it is fairly easy to write it in a much more efficient
way by using the target CPU array instead of the bitmap.
This is the type-safe comparison function, so the double-underscore is
not related.
The checks on PG_reserved in the page structure on head and tail pages
aren't necessary because split_huge_page wouldn't transfer the
PG_reserved bit from head to tail anyway.
This was a forward-thinking check done in the case PageReserved was
set by a driver-owned page mapped in userland with something like
remap_pfn_range in a VM_PFNMAP region, but using hugepmds (not
possible right now). It was meant to be very safe, but it's overkill
as it's unlikely split_huge_page could ever run without the driver
noticing and tearing down the hugepage itself.
And if a driver in the future will really want to map a reserved
hugepage in userland using an huge pmd it should simply take care of
marking all subpages reserved too to keep KVM safe. This of course
would require such a hypothetical driver to tear down the huge pmd
itself and splitting the hugepage itself, instead of relaying on
split_huge_page, but that sounds very reasonable, especially
considering split_huge_page wouldn't currently transfer the reserved
bit anyway.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
KVM uses anon_inode_get() to allocate file descriptors as part
of some of its ioctls. But those ioctls are lacking a flag argument
allowing userspace to choose options for the newly opened file descriptor.
In such case it's advised to use O_CLOEXEC by default so that
userspace is allowed to choose, without race, if the file descriptor
is going to be inherited across exec().
This patch set O_CLOEXEC flag on all file descriptors created
with anon_inode_getfd() to not leak file descriptors across exec().
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Link: http://lkml.kernel.org/r/cover.1377372576.git.ydroneaud@opteya.com
kvm_io_bus_sort_cmp is used also directly, not just as a callback for
sort and bsearch. In these cases, it is handy to have a type-safe
variant. This patch introduces such a variant, __kvm_io_bus_sort_cmp,
and uses it throughout kvm_main.c.
This is called right after the memslots is updated, i.e. when the result
of update_memslots() gets installed in install_new_memslots(). Since
the memslots needs to be updated twice when we delete or move a memslot,
kvm_arch_commit_memory_region() does not correspond to this exactly.
In the following patch, x86 will use this new API to check if the mmio
generation has reached its maximum value, in which case mmio sptes need
to be flushed out.
Signed-off-by: Takuya Yoshikawa <yoshikawa_takuya_b1@lab.ntt.co.jp>
Acked-by: Alexander Graf <agraf@suse.de>
Add new functions kvm_io_bus_{read,write}_cookie() that allows users of
the kvm io infrastructure to use a cookie value to speed up lookup of a
device on an io bus.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Pull KVM fixes from Paolo Bonzini:
"On the x86 side, there are some optimizations and documentation
updates. The big ARM/KVM change for 3.11, support for AArch64, will
come through Catalin Marinas's tree. s390 and PPC have misc cleanups
and bugfixes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (87 commits)
KVM: PPC: Ignore PIR writes
KVM: PPC: Book3S PR: Invalidate SLB entries properly
KVM: PPC: Book3S PR: Allow guest to use 1TB segments
KVM: PPC: Book3S PR: Don't keep scanning HPTEG after we find a match
KVM: PPC: Book3S PR: Fix invalidation of SLB entry 0 on guest entry
KVM: PPC: Book3S PR: Fix proto-VSID calculations
KVM: PPC: Guard doorbell exception with CONFIG_PPC_DOORBELL
KVM: Fix RTC interrupt coalescing tracking
kvm: Add a tracepoint write_tsc_offset
KVM: MMU: Inform users of mmio generation wraparound
KVM: MMU: document fast invalidate all mmio sptes
KVM: MMU: document fast invalidate all pages
KVM: MMU: document fast page fault
KVM: MMU: document mmio page fault
KVM: MMU: document write_flooding_count
KVM: MMU: document clear_spte_count
KVM: MMU: drop kvm_mmu_zap_mmio_sptes
KVM: MMU: init kvm generation close to mmio wrap-around value
KVM: MMU: add tracepoint for check_mmio_spte
KVM: MMU: fast invalidate all mmio sptes
into queue
KVM/ARM pull request for 3.11 merge window
* tag 'kvm-arm-3.11' of git://git.linaro.org/people/cdall/linux-kvm-arm.git:
ARM: kvm: don't include drivers/virtio/Kconfig
Update MAINTAINERS: KVM/ARM work now funded by Linaro
arm/kvm: Cleanup KVM_ARM_MAX_VCPUS logic
ARM: KVM: clear exclusive monitor on all exception returns
ARM: KVM: add missing dsb before invalidating Stage-2 TLBs
ARM: KVM: perform save/restore of PAR
ARM: KVM: get rid of S2_PGD_SIZE
ARM: KVM: don't special case PC when doing an MMIO
ARM: KVM: use phys_addr_t instead of unsigned long long for HYP PGDs
ARM: KVM: remove dead prototype for __kvm_tlb_flush_vmid
ARM: KVM: Don't handle PSCI calls via SMC
ARM: KVM: Allow host virt timer irq to be different from guest timer virt irq
This reverts most of the f1ed0450a5fac7067590317cbf027f566b6ccbca. After
the commit kvm_apic_set_irq() no longer returns accurate information
about interrupt injection status if injection is done into disabled
APIC. RTC interrupt coalescing tracking relies on the information to be
accurate and cannot recover if it is not.
The arch_timer irq numbers (or PPI numbers) are implementation dependent,
so the host virtual timer irq number can be different from guest virtual
timer irq number.
This patch ensures that host virtual timer irq number is read from DTB and
guest virtual timer irq is determined based on vcpu target type.
Signed-off-by: Anup Patel <anup.patel@linaro.org>
Signed-off-by: Pranavkumar Sawargaonkar <pranavkumar@linaro.org>
Signed-off-by: Christoffer Dall <cdall@cs.columbia.edu>
We can easily reach the 1000 limit by start VM with a couple
hundred I/O devices (multifunction=on). The hardcode limit
already been adjusted 3 times (6 ~ 200 ~ 300 ~ 1000).
In userspace, we already have maximum file descriptor to
limit ioeventfd count. But kvm_io_bus devices also are used
for pit, pic, ioapic, coalesced_mmio. They couldn't be limited
by maximum file descriptor.
Currently only ioeventfds take too much kvm_io_bus devices,
so just exclude it from counting kvm_io_range limit.
Also fixed one indent issue in kvm_host.h
Signed-off-by: Amos Kong <akong@redhat.com>
Reviewed-by: Stefan Hajnoczi <stefanha@redhat.com>
As KVM/arm64 is looming on the horizon, it makes sense to move some
of the common code to a single location in order to reduce duplication.
The code could live anywhere. Actually, most of KVM is already built
with a bunch of ugly ../../.. hacks in the various Makefiles, so we're
not exactly talking about style here. But maybe it is time to start
moving into a less ugly direction.
The include files must be in a "public" location, as they are accessed
from non-KVM files (arch/arm/kernel/asm-offsets.c).
For this purpose, introduce two new locations:
- virt/kvm/arm/ : x86 and ia64 already share the ioapic code in
virt/kvm, so this could be seen as a (very ugly) precedent.
- include/kvm/ : there is already an include/xen, and while the
intent is slightly different, this seems as good a location as
any
Eventually, we should probably have independant Makefiles at every
levels (just like everywhere else in the kernel), but this is just
the first step.
Since the arrival of posted interrupt support we can no longer guarantee
that coalesced IRQs are always reported to the IRQ source. Moreover,
accumulated APIC timer events could cause a busy loop when a VCPU should
rather be halted. The consensus is to remove coalesced tracking from the
LAPIC.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
Acked-by: Marcelo Tosatti <mtosatti@redhat.com>
Add the missing misc_deregister() before return from kvm_init()
in the debugfs init error handling case.
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Pull kvm fixes from Gleb Natapov:
"Most of the fixes are in the emulator since now we emulate more than
we did before for correctness sake we see more bugs there, but there
is also an OOPS fixed and corruption of xcr0 register."
* tag 'kvm-3.10-2' of git://git.kernel.org/pub/scm/virt/kvm/kvm:
KVM: emulator: emulate SALC
KVM: emulator: emulate XLAT
KVM: emulator: emulate AAM
KVM: VMX: fix halt emulation while emulating invalid guest sate
KVM: Fix kvm_irqfd_init initialization
KVM: x86: fix maintenance of guest/host xcr0 state
Pull MIPS updates from Ralf Baechle:
- More work on DT support for various platforms
- Various fixes that were to late to make it straight into 3.9
- Improved platform support, in particular the Netlogic XLR and
BCM63xx, and the SEAD3 and Malta eval boards.
- Support for several Ralink SOC families.
- Complete support for the microMIPS ASE which basically reencodes the
existing MIPS32/MIPS64 ISA to use non-constant size instructions.
- Some fallout from LTO work which remove old cruft and will generally
make the MIPS kernel easier to maintain and resistant to compiler
optimization, even in absence of LTO.
- KVM support. While MIPS has announced hardware virtualization
extensions this KVM extension uses trap and emulate mode for
virtualization of MIPS32. More KVM work to add support for VZ
hardware virtualizaiton extensions and MIPS64 will probably already
be merged for 3.11.
Most of this has been sitting in -next for a long time. All defconfigs
have been build or run time tested except three for which fixes are being
sent by other maintainers.
Semantic conflict with kvm updates done as per Ralf
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (118 commits)
MIPS: Add new GIC clockevent driver.
MIPS: Formatting clean-ups for clocksources.
MIPS: Refactor GIC clocksource code.
MIPS: Move 'gic_frequency' to common location.
MIPS: Move 'gic_present' to common location.
MIPS: MIPS16e: Add unaligned access support.
MIPS: MIPS16e: Support handling of delay slots.
MIPS: MIPS16e: Add instruction formats.
MIPS: microMIPS: Optimise 'strnlen' core library function.
MIPS: microMIPS: Optimise 'strlen' core library function.
MIPS: microMIPS: Optimise 'strncpy' core library function.
MIPS: microMIPS: Optimise 'memset' core library function.
MIPS: microMIPS: Add configuration option for microMIPS kernel.
MIPS: microMIPS: Disable LL/SC and fix linker bug.
MIPS: microMIPS: Add vdso support.
MIPS: microMIPS: Add unaligned access support.
MIPS: microMIPS: Support handling of delay slots.
MIPS: microMIPS: Add support for exception handling.
MIPS: microMIPS: Floating point support.
MIPS: microMIPS: Fix macro naming in micro-assembler.
Signed-off-by: Sanjay Lal <sanjayl@kymasys.com>
Cc: kvm@vger.kernel.org
Cc: linux-mips@linux-mips.org
In commit a0f155e96 'KVM: Initialize irqfd from kvm_init()', when
kvm_init() is called the second time (e.g kvm-amd.ko and kvm-intel.ko),
kvm_arch_init() will fail with -EEXIST, then kvm_irqfd_exit() will be
called on the error handling path. This way, the kvm_irqfd system will
not be ready.
This patch fix the following:
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81c0721e>] _raw_spin_lock+0xe/0x30
PGD 0
Oops: 0002 [#1] SMP
Modules linked in: vhost_net
CPU 6
Pid: 4257, comm: qemu-system-x86 Not tainted 3.9.0-rc3+ #757 Dell Inc. OptiPlex 790/0V5HMK
RIP: 0010:[<ffffffff81c0721e>] [<ffffffff81c0721e>] _raw_spin_lock+0xe/0x30
RSP: 0018:ffff880221721cc8 EFLAGS: 00010046
RAX: 0000000000000100 RBX: ffff88022dcc003f RCX: ffff880221734950
RDX: ffff8802208f6ca8 RSI: 000000007fffffff RDI: 0000000000000000
RBP: ffff880221721cc8 R08: 0000000000000002 R09: 0000000000000002
R10: 00007f7fd01087e0 R11: 0000000000000246 R12: ffff8802208f6ca8
R13: 0000000000000080 R14: ffff880223e2a900 R15: 0000000000000000
FS: 00007f7fd38488e0(0000) GS:ffff88022dcc0000(0000) knlGS:0000000000000000
CR2: 0000000000000000 CR3: 000000022309f000 CR4: 00000000000427e0
Process qemu-system-x86 (pid: 4257, threadinfo ffff880221720000, task ffff880222bd5640)
Stack:
ffff880221721d08 ffffffff810ac5c5 ffff88022431dc00 0000000000000086
0000000000000080 ffff880223e2a900 ffff8802208f6ca8 0000000000000000
ffff880221721d48 ffffffff810ac8fe 0000000000000000 ffff880221734000
Call Trace:
[<ffffffff810ac5c5>] __queue_work+0x45/0x2d0
[<ffffffff810ac8fe>] queue_work_on+0x8e/0xa0
[<ffffffff810ac949>] queue_work+0x19/0x20
[<ffffffff81009b6b>] irqfd_deactivate+0x4b/0x60
[<ffffffff8100a69d>] kvm_irqfd+0x39d/0x580
[<ffffffff81007a27>] kvm_vm_ioctl+0x207/0x5b0
[<ffffffff810c9545>] ? update_curr+0xf5/0x180
[<ffffffff811b66e8>] do_vfs_ioctl+0x98/0x550
[<ffffffff810c1f5e>] ? finish_task_switch+0x4e/0xe0
[<ffffffff81c054aa>] ? __schedule+0x2ea/0x710
[<ffffffff811b6bf7>] sys_ioctl+0x57/0x90
[<ffffffff8140ae9e>] ? trace_hardirqs_on_thunk+0x3a/0x3c
[<ffffffff81c0f602>] system_call_fastpath+0x16/0x1b
Code: c1 ea 08 38 c2 74 0f 66 0f 1f 44 00 00 f3 90 0f b6 03 38 c2 75 f7 48 83 c4 08 5b c9 c3 55 48 89 e5 66 66 66 66 90 b8 00 01 00 00 <f0> 66 0f c1 07 89 c2 66 c1 ea 08 38 c2 74 0c 0f 1f 00 f3 90 0f
RIP [<ffffffff81c0721e>] _raw_spin_lock+0xe/0x30
RSP <ffff880221721cc8>
---[ end trace 13fb1e4b6e5ab21f ]---
Signed-off-by: Asias He <asias@redhat.com>
Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com>
Pull kvm updates from Gleb Natapov:
"Highlights of the updates are:
general:
- new emulated device API
- legacy device assignment is now optional
- irqfd interface is more generic and can be shared between arches
x86:
- VMCS shadow support and other nested VMX improvements
- APIC virtualization and Posted Interrupt hardware support
- Optimize mmio spte zapping
ppc:
- BookE: in-kernel MPIC emulation with irqfd support
- Book3S: in-kernel XICS emulation (incomplete)
- Book3S: HV: migration fixes
- BookE: more debug support preparation
- BookE: e6500 support
ARM:
- reworking of Hyp idmaps
s390:
- ioeventfd for virtio-ccw
And many other bug fixes, cleanups and improvements"
* tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (204 commits)
kvm: Add compat_ioctl for device control API
KVM: x86: Account for failing enable_irq_window for NMI window request
KVM: PPC: Book3S: Add API for in-kernel XICS emulation
kvm/ppc/mpic: fix missing unlock in set_base_addr()
kvm/ppc: Hold srcu lock when calling kvm_io_bus_read/write
kvm/ppc/mpic: remove users
kvm/ppc/mpic: fix mmio region lists when multiple guests used
kvm/ppc/mpic: remove default routes from documentation
kvm: KVM_CAP_IOMMU only available with device assignment
ARM: KVM: iterate over all CPUs for CPU compatibility check
KVM: ARM: Fix spelling in error message
ARM: KVM: define KVM_ARM_MAX_VCPUS unconditionally
KVM: ARM: Fix API documentation for ONE_REG encoding
ARM: KVM: promote vfp_host pointer to generic host cpu context
ARM: KVM: add architecture specific hook for capabilities
ARM: KVM: perform HYP initilization for hotplugged CPUs
ARM: KVM: switch to a dual-step HYP init code
ARM: KVM: rework HYP page table freeing
ARM: KVM: enforce maximum size for identity mapped code
ARM: KVM: move to a KVM provided HYP idmap
This API shouldn't have 32/64-bit issues, but VFS assumes it does
unless told otherwise.
This adds the API for userspace to instantiate an XICS device in a VM
and connect VCPUs to it. The API consists of a new device type for
the KVM_CREATE_DEVICE ioctl, a new capability KVM_CAP_IRQ_XICS, which
functions similarly to KVM_CAP_IRQ_MPIC, and the KVM_IRQ_LINE ioctl,
which is used to assert and deassert interrupt inputs of the XICS.
The XICS device has one attribute group, KVM_DEV_XICS_GRP_SOURCES.
Each attribute within this group corresponds to the state of one
interrupt source. The attribute number is the same as the interrupt
source number.
This does not support irq routing or irqfd yet.
Acked-by: David Gibson <david@gibson.dropbear.id.au>
The hassle of getting refcounting right was greater than the hassle
of keeping a list of devices to destroy on VM exit.
Hook the MPIC code up to the KVM interfaces, add locking, etc.
[agraf: add stub function for kvmppc_mpic_set_epr, non-booke, 64bit]
Currently, devices that are emulated inside KVM are configured in a
hardcoded manner based on an assumption that any given architecture
only has one way to do it. If there's any need to access device state,
it is done through inflexible one-purpose-only IOCTLs (e.g.
KVM_GET/SET_LAPIC). Defining new IOCTLs for every little thing is
cumbersome and depletes a limited numberspace.
This API provides a mechanism to instantiate a device of a certain
type, returning an ID that can be used to set/get attributes of the
device. Attributes may include configuration parameters (e.g.
register base address), device state, operational commands, etc. It
is similar to the ONE_REG API, except that it acts on devices rather
than vcpus.
Both device types and individual attributes can be tested without having
to create the device or get/set the attribute, without the need for
separately managing enumerated capabilities.
Now that we have most irqfd code completely platform agnostic, let's move
irqfd's resample capability return to generic code as well.
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Setting up IRQ routes is nothing IOAPIC specific. Extract everything
that really is generic code into irqchip.c and only leave the ioapic
specific bits to irq_comm.c.
The current irq_comm.c file contains pieces of code that are generic
across different irqchip implementations, as well as code that is
fully IOAPIC specific.
Split the generic bits out into irqchip.c.
