This builds for gtk3 and vte with API 2.91
While at it remove unneeded RDEPENDS, these are pulled in automatically
by oe.
While at it change the license string to MIT as the license text is an
exact MIT copy and limit the checksummed part to only the license header.
Fixes do_compile:
| make[1]: *** No rule to make target 'Keybinder-0.0.typelib', needed by 'all-am'. Stop.
The base_contains function is deprecated and we ought to use
bb.utils.contains instead.
This is also done by the session manager effectively starting the
autostart items twice.
This also fixes a compile error against openbox 3.5.2 and later.
${PN} might be extended with some magic prefix, so don't use it in SRC_URI
assignments et. al.
The SUMMARY variable gives a short description of the package (<72 chars).
A missing DESCRIPTION is automatically set to the content of SUMMARY.
change all recipe which fail out of tree builds to autotools-brokensep
Patch is sent to the oe-core layer. As this will not make it into dizzy
add it here until we have it available from openembedded/meta.
