Relates-to: ELB-2665
TDX_BUILDNB is an optional build number to identify a specific
build. This is useful for CI builds.
The terms external and internal version has been changed to package and item version.
Use variable names to reflect that.
TDX_VER_EXT -> TDX_VER_PACKAGE
TDX_VER_EXT_MIN -> TDX_VER_PACKAGE_MIN
TDX_VER_INT -> TDX_VER_ITEM
While at it fix spelling in TDX_VER_MINOR (only used within the file).
With the drop of meta-linaro-toolchain bbappend files without a
matching bb file lead to a fatal ERROR.
Keep this a warning in our setup.
Use OpenEmbedded standard variables such as PV and DATE as much
as possible. This allows to reuse the Tezi image class for non-
Toradex images with their own versioning scheme.
0123456789012345678901234567890123456789012345678901234567890123456789
These variables are used to mark the BSP version in U-Boot, the Linux
kernel and the final image.
Note that some can be overridden from the shell environment, e.g.:
export BB_ENV_EXTRAWHITE="$BB_ENV_EXTRAWHITE TDX_VERNIGHTLY"
export TDX_VERNIGHTLY="-nightly"
While at it clean-up and unify with other Toradex layers.
This is only used for choosing a custom logo size. Not needed in our
use case.
meta-openembedded/meta-oe/recipes-kernel/linux/linux.inc
machine/u-boot/kernel files have been added to meta-fsl-arm-extra.
Use them from there now.
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb
in the kernel.
The v1_0 denotes the Apalis module version, not the evaluation board version.
Use systemd V2.18 from meta-angstrom.
Issues with firmware loading and the 3.1.10 kernel for the tegra machines
are fixed with a backport from oe-core.
Also deploy an additional device tree supporting a Colibri iMX6 with
Analog Camera Module.
The default changed to zImage so explicit set uImage for now.
While at it cleanup the recipe, remove pci from Colibri machine features.
This patch fixes the issue of getting serial tty login at ttymxc1 (UART_B).
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Update to a U-Boot and Kernel which can be used for Apalis iMX6
HW version V1.0 and V1.1.
Also deploy additional device tree for Apalis iMX6 V1.0 modules
Angstrom started using thumb2 on machines with armv7-a architectures.
This commit removes our override to stay on arm instruction set, so
if building our machines with the angstrom distribution you now get
thumb2 builds.
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
If the package manager finds a version newer than the prefered-version that one
gets installed. As we need a specific one for the tegras and for imx6 we
change the 'epoch' to something very high.
unify the features between machines
kernel26 is deprecated and unused
apm does not make sense on ARM
While at it remove some commented stuff
Be consistent with the other machine recipes
Help the autobuilder setup
File now provided by openembedded-core
This reverts commit 592b1395c7cdff2125b5e42a7f9605749e625419.
remove the files copied from meta-fsl* for Colibri-VF V2.1
move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra
- Colibri T30 and Apalis T30 changed to NEON
- Colibri VF50 changed to hard float
This makes packages built for T30 incompatible with Colibri T20
(but Colibri T20 packages can still be used on T30)
remove when moving to dora branch
revert when moving to dora
- also add the relevant configuration files
- builds a unified kernel usable on
Colibri PXA 270, PXA3xx Module Versions V1.x refer:
http://git.toradex.com/gitweb/linux-toradex.git/commitdiff/4fd7b3182077613d7e3c93607b98d6b826f89dd8
probably one needs to use the older adapted kernel and u-boot
but with kernel options amended by systemd needs
- adds a dummy burnflash tarball to not break final packaging
