path: root/openembedded-layer/recipes-multimedia/webm/libvpx_%.bbappend
2017-12-22libvpx bbappend: follow version upgradeMax Krummenacher
The append is only needed for T20 as it does not have a neon unit. The other SoC compile fine without any change. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29meta-openembedded layer bbappendsMax Krummenacher
Move the appends on recipe's which are not in an essential required layer into a target layer specific directory and add them only if said layer is active in build/conf/bblayers.conf. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
