2014-12-19 | colibri_vf: update U-Boot and Linux kernel git hashes | Stefan Agner | |
Two last minute fixes: Default Product/Vendor ID for USB peripheral in U-Boot and fix for the USB peripheral RNDIS freeze. | |||
2014-12-18 | Update all to latest and greatest U-Boot and Linux kernel. | Marcel Ziswiler | |
2014-12-16 | colibri-vf: switch to mainline kernel based on 3.18 | Stefan Agner | |
Switch default kernel recipe to linux-toradex-vf which will build a kernel based on the toradex 3.18-next branch. | |||
2014-12-11 | colibri-vf: update U-Boot | Max Krummenacher | |
2014-12-11 | apalis/colibri-imx6: U-Boot and Kernel for V1.0/V1.1 | Max Krummenacher | |
Update to a U-Boot and Kernel which can be used for Apalis iMX6 HW version V1.0 and V1.1. Also deploy additional device tree for Apalis iMX6 V1.0 modules | |||
2014-10-30 | u-boot: iMX6/VF update to latest from git | Max Krummenacher | |
2014-10-20 | colibri-vf: u-boot: switch to 2014.10 | Stefan Agner | |
Use rebased U-Boot release 2014.10. The README has a new md5sum and U-Boots new build system has default configurations ending with defconfig too. | |||
2014-10-06 | colibri-imx6: refactor recipes for new module | Max Krummenacher | |
2014-10-06 | u-boot: remove don't build the examples patch | Max Krummenacher | |
u-boot.inc no longer builds the standalone examples by default so do patch to not do so is no longer needed. The source tree will no longer be marked as git dirty. | |||
2014-08-04 | u-boot: update to latest git version | Max Krummenacher | |
2014-08-04 | u-boot-toradex: update to latest git version | Max Krummenacher | |
2014-08-04 | gpio-export: fix gpios-export.service | Max Krummenacher | |
2014-08-04 | gpio-export: add recipe for userspace export of gpios | Max Krummenacher | |
2014-08-04 | mcc/m4: use recipes from meta-fsl-arm | Max Krummenacher | |
deleted: recipes-bsp/libmcc/libmcc_1.04.bb deleted: recipes-bsp/mqxboot/mqxboot_1.0.bb deleted: recipes-kernel/kernel-module-mcc/kernel-module-mcc_1.04.bb | |||
2014-05-24 | colibri-vf: use latest u-boot and burnflash | Marcel Ziswiler | |
Use the latest U-Boot and burnflash. | |||
2014-05-07 | u-boot: make use of shared U-Boot branch | Stefan Agner | |
2014-04-30 | colibri-vf: switch to U-Boot 2014.04 and latest git | Stefan Agner | |
This commit switches Colibri VF machine to use the 2014.04 git branch. The change to latest U-Boot brings proper NAND hardware ECC support, which is also enabled in latest Linux kernel. Beside that, burnflash is updated to correctly work with the new U-Boot version and the altered Config Block location. | |||
2014-04-03 | u-boot: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-02 | u-boot: apalis-imx6 update to latest git version | Max Krummenacher | |
2014-04-01 | u-boot: convert bbappend to a bb | Max Krummenacher | |
2014-04-01 | u-boot: add Apalis iMX6 and Colibri VF recipe | Max Krummenacher | |
2014-04-01 | colibri-vf: use meta-fsl* layer for BSP files | Max Krummenacher | |
remove the files copied from meta-fsl* for Colibri-VF V2.1 move the colibri-vf u-boot and kernel stuff to meta-fsl-arm-extra | |||
2014-03-26 | mqxboot/libmcc: fixed dependencies to kernel module | Stefan Agner | |
We need to have the kernel modules header at build time, so mark it as not only a runtime dependency. | |||
2014-03-18 | u-boot Txx: update to latest | Max Krummenacher | |
2014-03-17 | kernel/u-boot: update to latest git revision | Stefan Agner | |
2014-03-17 | vybrid: backport Cortex-M utilites from meta-fsl | Stefan Agner | |
- Add utility mqxboot to load firmware into IRAM and reset M4 - Add kernel module mcc needed by libmcc - Add multi-core communication library libmcc for message queue based communication with Cortex-M core | |||
2014-02-10 | kernel/u-boot: update to latest git | Stefan Agner | |
2013-11-21 | u-boot: colibri-vf: use the unified u-boot 50/61 | Max Krummenacher | |
2013-11-21 | Machine: use the changed machinename colibri-vf | Max Krummenacher | |
2013-10-23 | u-boot: update to latest git version | Max Krummenacher | |
2013-10-10 | colibri-vf50: add the machine, kernel and u-boot | Max Krummenacher | |
- also add the relevant configuration files | |||
2013-10-10 | u-boot-fw-utils: add bbappend to use the same u-boot sources | Max Krummenacher | |
2013-10-07 | u-boot: clean up recipe | Max Krummenacher | |
2013-09-22 | u-boot: don't build the examples | Max Krummenacher | |
- they do fail because they don't heed the private libgcc | |||
2013-08-23 | u-boot: update to latest git version | Max Krummenacher | |
2013-06-26 | u-boot: update to latest git revision | Max Krummenacher | |
2013-03-04 | remove unused files | Max Krummenacher | |
2013-01-29 | u-boot: add Apalis-T30 | Max Krummenacher | |
- add Apalis-T30 - remove u-boot machine definition, this is also defined in the machine conf. | |||
2013-01-22 | u-boot: update to latest on git.toradex.com | Max Krummenacher | |
2012-12-31 | update u-boot and kernel git versions | Max Krummenacher | |
remove testfile | |||
2012-12-18 | u-boot: remove all modification, they are moved to u-boot git | Max Krummenacher | |
2012-10-18 | u-boot: update to 16a9368a88a28252ea1daedc1df03ccc49ea5b22 | Max Krummenacher | |
2012-10-18 | removed *~ backup files from git repo | Max Krummenacher | |
2012-10-18 | u-boot: update to a1ab5236759b1cd6fae427517d44d7be90b02c07 | Max Krummenacher | |
2012-08-23 | Use kernel and u-boot from git.toradex.com | Max Krummenacher | |
Move changes done to other repos into .bbappends in meta-toradex | |||
2012-08-15 | L4T R15, oe-core Image V2.0Beta1 | Max Krummenacher | |
2012-07-21 | pull u-boot unified for vibrante and l4t and the corresponding l4t kernel | Max Krummenacher | |
2012-06-12 | - mklibs is no longer downloadable in the 0.1.33 version, upgrade to next ↵ | Max Krummenacher | |
version | |||
2012-06-03 | u-boot base from meta instead of a copy from meta-ti | Max Krummenacher | |
fix u-boot to no longer fail at runtime, (write beyond array) | |||
2012-06-03 | Initial commit | Max Krummenacher | |
