With common depmod config file, the backported rtl8188eu driver
tries to load for Realtek 8188EU USB devices. On the other hand,
on-module Wi-Fi chip loads built-in mwifiex_pcie driver. This driver
uses cfg80211 built-in module. Backported rtl8188eu driver can't use
built-in cfg80211 module, so to allow using Realtek 8188EU USB device
with Colibri iMX8QXP module, the built-in rtl8188eu driver should be
used.
With this patch the specific depmod config file deploys on the image
for Colibri iMX8QXP.
Related-to: ELB-2687
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Deploying depmod.conf file makes almost all manipulations
in postinst and postrm scripts useless. Clean up these scripts.
Only backported drivers should depend on backported common modules.
Deploying the 99-backports.conf file allows depmod to build modules.dep
dependancies file properly.
Generic and RT-kernels use diffierent package names.
Add dependancy on virtual name kernel package fixes
build issue for RT-kernels.
Related-to: ELB-2388
backports-5.4 provides latter drivers.
The main issue that fixes with these backports: the earlier mwifiex
drivers for Marvel 8997 WiFi module stucks on firmware crash (ELB-2596).
