path: root/recipes-kernel
2020-06-10backports: update to latestColibri-iMX7_LXDE-Image_2.8b7.-20200610Colibri-iMX6_LXDE-Image_2.8b7.-20200610Colibri-iMX6ULL_LXDE-Image_2.8b7.-20200610Colibri-VF_LXDE-Image_2.8b7.-20200610Colibri-T30_LXDE-Image_2.8b7.-20200610Colibri-T20_LXDE-Image_2.8b7.-20200610Apalis-iMX6_LXDE-Image_2.8b7.-20200610Apalis-TK1_LXDE-Image_2.8b7.-20200610Apalis-TK1-Mainline_LXDE-Image_2.8b7.-20200610Apalis-T30_LXDE-Image_2.8b7.-20200610Max Krummenacher
2020-05-25backports: small improvements for backports-5.4Oleksandr Suvorov
Make backports-5.4 recipe more reliable. Related-to: ELB-2724 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-05-25linux-toradex: prepare shared_dir betterOleksandr Suvorov
backports-5.4 requires Makefile in kernel shared_dir to be built successfully. Expand do_shared_workdir() accordingly. Related-to: ELB-2724 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-05-20backports: get back legacy 4.19 versionOleksandr Suvorov
backports-5.4 is not compatible with tegra kernel 3.1.x and vf kernel 4.4. Use backports-legacy-4.19 for these kernels. Related-to: ELB-2724 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-05-20backports: fix recipe buildingOleksandr Suvorov
Tune the recipe to build the backports-5.4 with rocko successfully. Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-05-15backports: replace hardcodeded path with oe prefixMax Krummenacher
Backported from 7ed9958daea9 commit. Related-to: TOR-992 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-05-15backports: upgrade from 4.19 to 5.4Oleksandr Suvorov
backports-5.4 provides latter drivers. The main issue that fixes with these backports: the earlier mwifiex drivers for Marvel 8997 WiFi module stucks on firmware crash (ELB-2596). Related-to: ELB-2724 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2020-05-15depmodwrapper: add config directory optionOleksandr Suvorov
Backports recipe deploys the custom config file for depmod. Use it in depmodwrapper to generate modules dependencies properly. Related-to: ELB-2724 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2019-05-10backports: update backports to 4.19.41Dominik Sliwa
2019-04-11backports: support menuconfigDominik Sliwa
2019-04-11backports: update config fileDominik Sliwa
2019-03-29backports: update backportsColibri-iMX7_LXDE-Image_2.8b6.184-20190401Colibri-iMX6_LXDE-Image_2.8b6.184-20190401Colibri-iMX6ULL_LXDE-Image_2.8b6.184-20190401Colibri-VF_LXDE-Image_2.8b6.183-20190331Colibri-T30_LXDE-Image_2.8b6.184-20190401Colibri-T20_LXDE-Image_2.8b6.184-20190401Apalis-iMX6_LXDE-Image_2.8b6.184-20190401Apalis-TK1_LXDE-Image_2.8b6.184-20190401Apalis-TK1-Mainline_LXDE-Image_2.8b6.184-20190401Apalis-T30_LXDE-Image_2.8b6.184-20190401Dominik Sliwa
Backports based on 4.19 kernel. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2019-03-19backports: update backportsDominik Sliwa
2018-12-18linux-firmware: use nonarch_base_libdirColibri-iMX7_LXDE-Image_2.8b5.156-20181228Colibri-iMX6_LXDE-Image_2.8b5.156-20181228Colibri-iMX6ULL_LXDE-Image_2.8b5.156-20181228Colibri-VF_LXDE-Image_2.8b5.156-20181228Colibri-T30_LXDE-Image_2.8b5.156-20181228Colibri-T20_LXDE-Image_2.8b5.156-20181228Apalis-iMX6_LXDE-Image_2.8b5.156-20181228Apalis-TK1_LXDE-Image_2.8b5.156-20181228Apalis-TK1-Mainline_LXDE-Image_2.8b5.156-20181228Apalis-T30_LXDE-Image_2.8b5.156-20181228Stefan Agner
When building with usrmerge, the firmware directory is in /usr/lib. Make sure we pickup firmwares from nonarch_base_libdir. This fixes a build warning when building Torizon: * Problem 1/1: * - nothing provides linux-firmware-rtl8188eu needed by linux-firmware-1:0.0+git0+d114732723-r0.all Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-09-27linux-firmware: add marvell sd8997_uapsta.binColibri-iMX7_LXDE-Image_2.8b4.129-20181005Colibri-iMX6_LXDE-Image_2.8b4.129-20181005Colibri-iMX6ULL_LXDE-Image_2.8b4.129-20181005Colibri-VF_LXDE-Image_2.8b4.129-20181005Colibri-T30_LXDE-Image_2.8b4.129-20181005Colibri-T20_LXDE-Image_2.8b4.129-20181005Apalis-iMX6_LXDE-Image_2.8b4.129-20181005Apalis-TK1_LXDE-Image_2.8b4.129-20181005Apalis-TK1-Mainline_LXDE-Image_2.8b4.129-20181005Apalis-T30_LXDE-Image_2.8b4.129-20181005Dominik Sliwa
Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-09-27backports: switch to 4.18 kernel based backportsDominik Sliwa
2018-09-27backports: add missing space in front of appendMarcel Ziswiler
Add missing space in front of DEPENDS_append in order to avoid issues caused by further appending. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2018-06-18backports: make sure backport packages are considered availableStefan Agner
Since kernel module packages are generated dynamically, the dependency resolution fails when one requests a specific package which is generated at build time. Use PACKAGES_DYNAMIC to tell the build system that backport-kernel-module-* packages can be considered available. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2018-03-22atemsys: bump version to latest versionStefan Agner
2017-12-28backports: update to latest revisionColibri-iMX7_LXDE-Image_2.8b1.64-20171229Colibri-iMX6_LXDE-Image_2.8b1.64-20171229Colibri-iMX6ULL_LXDE-Image_2.8b1.64-20171229Colibri-VF_LXDE-Image_2.8b1.64-20171229Colibri-T30_LXDE-Image_2.8b1.64-20171229Colibri-T20_LXDE-Image_2.8b1.64-20171229Apalis-iMX6_LXDE-Image_2.8b1.64-20171229Apalis-TK1_LXDE-Image_2.8b1.64-20171229Apalis-TK1-Mainline_LXDE-Image_2.8b1.64-20171229Apalis-T30_LXDE-Image_2.8b1.64-20171229Stefan Agner
2017-12-22backports: update defconfigDominik Sliwa
2017-12-22Revert "linux-firmware: split out firmware for marvell sd8887"Dominik Sliwa
This reverts commit e6641b0a6f93ebf752534b283d0dfb0c2c656ec2.
2017-12-22backports: switch to 4.14 kernel based backportsDominik Sliwa
2017-12-22backports: fix dependsMax Krummenacher
add coreutils native to depends in do_configure: | /bin/bash: line 28: seq: command not found resulting in do_compile failing: | In file included from /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/ieee80211_i.h:35:0, | from /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/status.c:17: | /build/krm/oe-core_master/build/tmp-glibc/work/colibri_vf-angstrom-linux-gnueabi/backports/4.11-r0/git/net/mac80211/sta_info.h:460:21: error: field 'hash_node' has incom | struct rhlist_head hash_node; | ^~~~~~~~~ Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-12-06backports: pin version to specific git hashMax Krummenacher
Don't use HEAD of branch for every build. That way we get more reproduciable builds and the git fetcher will not access the network on every build to check what the current HEAD actually is. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-11-27linux-firmware: split out firmware for marvell sd8887Colibri-iMX6ULL_LXDE-Image_2.7b5-20171201Apalis-TK1_LXDE-Image_2.7b5-20171201Max Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2017-10-04backports: use oe supplied kernel_versionColibri-iMX7_LXDE-Image_2.7b4-20171005Colibri-iMX6_LXDE-Image_2.7b4-20171005Colibri-VF_LXDE-Image_2.7b4-20171005Colibri-T30_LXDE-Image_2.7b4-20171005Colibri-T20_LXDE-Image_2.7b4-20171005Apalis-iMX6_LXDE-Image_2.7b4-20171005Apalis-TK1_LXDE-Image_2.7b4-20171007Apalis-TK1-Mainline_LXDE-Image_2.7b4-20171005Apalis-T30_LXDE-Image_2.7b4-20171005Dominik Sliwa
Use KERNEL_VERSION variable instad of running make kernelversion Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-10-03linux-firmware: firmware for rtl8188euDominik Sliwa
2017-10-03backports: toradex backports packageDominik Sliwa
Introducing Backports. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-03-14linux-firmware: drop bbappend, changes are now in metaMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14Apalis/Colibri iMX6: drop in favour of meta-fsl-arm-extraMax Krummenacher
machine/u-boot/kernel files have been added to meta-fsl-arm-extra. Use them from there now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2015-12-15linux-firmware: backport rtl8192cx: Add latest available firmwareMax Krummenacher
2015-12-15linux-toradex-fsl: update to latest revisionMax Krummenacher
Update to latest revision which fixes Colibri iMX6D not powerering off but creating a stacktrace. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-12-15linux-toradex_4.1: convert recipe to bbappendMax Krummenacher
We have this recipe in meta-fsl-arm-extra. Convert it to a bbappend and only keep the changes to the bb files. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2015-11-04Apalis/Colibri iMX6: Update Linux kernel to latestMax Krummenacher
2015-11-04linux: fix B != SMarcel Ziswiler
2015-11-04apalis/colibri_imx6/t20/t30: add version/git hash to KernelStefan Agner
Add LOCALVERSION and generate a scmversion file to annotate the Kernel with the Toradex release and a git hash.
2015-11-04apalis/colibri_imx6: update/load USB Gadget ConfigFS automaticallyStefan Agner
Since we use USB Gadget ConfigFS now use libusbg to load the USB Gadget configuration automatically.
2015-11-03Update Linux kernel and U-Boot to latest.Marcel Ziswiler
2015-10-21colibri_vf: update/load USB Gadget ConfigFS automaticallyStefan Agner
Update defconfig and kernel version to latest version from git. This also configures the USB Gadget ConfigFS as a module. Add the ConfigFS module to the list of autoloaded modules.
2015-10-12Apalis iMX6: cleanup filename for V1.0 HWMax Krummenacher
Follow the rename imx6q-apalis-eval_v1_0.dtb to imx6q-apalis_v1_0-eval.dtb in the kernel. The v1_0 denotes the Apalis module version, not the evaluation board version.
2015-10-12apalis-imx6: update kernel to toradex_imx_3.14.28_1.0.0_ga-nextMax Krummenacher
2015-08-13colibri-vf: initial kernel based on upstream 4.1Max Krummenacher
2015-08-07kernel: adapt to oe's new shared work dirMax Krummenacher
2015-08-07colibri-vf: moved to meta-fsl-arm, remove hereMax Krummenacher
2015-06-03colibri_vf: enable SCSI disk required for USB mass storageStefan Agner
SCSI lock device disk support is required for USB mass storage to work. Also enable asynchronous SCSI scanning by default.
2015-05-29mcc-kmod: fix revision to build with kernel revision usedStefan Agner
Use a fixed revision of the MCC kernel module which makes sure it builds with the corresponding Vybrid Linux kernel, which also uses a fixed git hash.
2015-05-18Apalis/Colibri iMX6: use toradex_imx_3.10.17_1.0.0_ga branchMax Krummenacher
2015-05-18Colibri VF: use latest from toradex_vf_4.0 branchMax Krummenacher
2015-05-18Apalis/Colibri iMX6: update kernel to latest in -nextMax Krummenacher
