https://github.com/morphis/meta-snappy/commit/f6df6a63756d9976bcccb5fefdbc64e5cc794c99
The Toradex product ID from the config block is decimal coded
ASCII with leading zeros. In C and bash, leading zeros means octal
number... This leads to wrong calculation of the USB product ID
and to errors if the product ID contains the number 8 or 9 (since
those are not valid under the octal numeric system).
Fix both issues by explicitly force decimal system for the Toradex
product ID.
Prevents a warning when not building for one of the machines which have a g1.schema
| WARNING: ...libusbgx/libusbgx_git.bb: Unable to get checksum for libusbgx SRC_URI entry g1.schema: file could not be found
Update libusbgx to a version with OS Descriptor support for better
interoperability with Windows operating systems. Add configuration
using RNDIS with Toradex vendor id. Read serial number and product
id from the device tree to configure the USB gadget device.
libusbgx (libusbg-neXt) is a fork of libusbg which is more actively
maintained.
Move the appends on recipe's which are not in an essential required layer
into a target layer specific directory and add them only if said layer
is active in build/conf/bblayers.conf.
Despite the reordering of when to load the USB Gadget configuration
with commit fadb16f153aa ("libusbg: enable USB Gadgets after Connman
to avoid interference") the network device ended up to be down after
startup. It seems that there is a race condition in systemd-networkd
which triggers especially in combination with USB Gadget, a issue on
the systemd issue tracker has been created:
https://github.com/systemd/systemd/issues/1784
There have been various changes related to link handling between
systemd 219 and the latest version 227. It is possible that the issue
is already solved.
Until this has been resolved, explicitly load the USB Gadget before
starting systemd-networkd seems to get around the issue.
It seems that Connman disables ALL interfaces on startup, even if
they are listed in NetworkInterfaceBlacklist. This leads to the
following situation:
networkd starts...
usb0 gets created...
networkd sets the device up (event triggered)
connman starts... and sets the device down!
networkd does not restart the device in this situation. To avoid
the situation, create the USB Gadget functions after connman. It
seems that if connman is up and running, it does not touch the
device anymore.
Add updated version of USB gadget library. Also add a systemd start-
script which loads the default schema located at /etc/usbg/g1.schema.
