2019-06-11wayland-app-launch: fix service status detectionApalis-iMX8_Console-Image_3.0b1.40-20190612Max Krummenacher
The service expects the script to return (Type=forking). Change the script so that the wayland app is started in the background. While at it configure the service to restart the application. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-06-05qt5-x11-image: add i.mx8 gstreamer pluginsMax Krummenacher
2019-06-05qt5-x11-image: unify with lxqt imageMax Krummenacher
2019-05-29console-tdx-image: rework starting a graphical appMax Krummenacher
Include a launcher for the weston-terminal if built for wayland/xwayland. Rework that the X11 launcher is only used if not using xwayland. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-29wayland-app-launch: add a simple systemd serviceMax Krummenacher
This tries to start a wayland application after weston got started. Create a copy of wayland-terminal-launch_1.0.bb with the variables changed according to your needs. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-29x-window-simple-app: fix rdependsMax Krummenacher
RDEPENDS is set by bitbake to an empty string, so using ?= is pointless. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22cpuburn-a53: don't link with staticMax Krummenacher
This reduces the binary from 400 to 4k. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22images: cleanupMax Krummenacher
packagegroup-base-extended is installed by inheriting core-image. packagegroup-basic installs dropbear, openssh-sftp, openssh-sftp-server dropbear can act as an scp client, drop openssh-scp Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22images: simplify prepending a machine nameMax Krummenacher
Define the string used for each machine in the machine configuration rather than doing this in each image recipe. Fallback to machine configuration name if not defined. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22images: drop angstrom specific variablesMax Krummenacher
2019-05-22tdx-extra: mx8: add u-boot fw-utilsMax Krummenacher
2019-05-22tdx-extra: mx8: add addional toolsMax Krummenacher
2019-05-22tdx-extra.inc: set PV to the BSP versionMax Krummenacher
We used to do this in the dropped tdx-image-fstype.inc. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22console-tdx-image: wayland; install a graphical backendMax Krummenacher
If a build is configured for a wayland or xwayland graphical backend install an sample application too. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22console-tdx-image: autostart xtermMax Krummenacher
Without this xinit fails because /usr/bin/x-window-manager does not exist and systemd then indefinitely retries to start X11. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22x-window-xterm: add recipeMax Krummenacher
This recipe starts xterm as the first X11 application. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-22x-window-simple-app: create common inc file and rename recipeMax Krummenacher
Pull out common code so that the bb file only contains information about the application which is to be started. Rename the recipe so that one knows what is going to be started. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-14Revert "angstrom-qt5-x11-image.bb: workaround ordering of populate_sdk ↵Max Krummenacher
populate_sdk_qt5" This reverts commit 0af5df0bd71d1714c1b2623fd9f6d57619926278. meta_qt5 got fixed so that it is no longer needed to force an inherit order. This prevents that with every build of the image the sdk is also built. Also apply the same to lxqt-image. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-13console-tdx-image: fix python callMax Krummenacher
2019-05-08tinycompress: import recipeMax Krummenacher
Import from meta-fsl-bsp-release @ sumo-4.14.78-1.0.0_ga Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-08images and helpers: drop qt4Max Krummenacher
Qt 4 was first released in 2005 and has been unsupported since 2015. Drop it from what we regularly install. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-04images: install the xserver depending on distro featuresMax Krummenacher
This is a follow-up to: e1026cf43 images: do not explicitely install ${XSERVER} Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-05-02cpuburn: add a cortex-a53 versionMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 832e3954f29df6ce1f5cc385ebefa2ef7f27ebd0)
2019-05-02clpeak: add recipeMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> (cherry picked from commit 2bba608252c7c09447e94bbacf8b1310113b12ff)
2019-04-25conf/layer.conf: decrease layer priority to 24Max Krummenacher
2019-04-24qt5-x11-image: cope with xwayland or native x11Max Krummenacher
2019-04-24lxqt-image: also deploy libdrm-testsMax Krummenacher
This among others installs modeprint, modetest. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-23colibri-vf: drop machineMax Krummenacher
We decided we won't do a BSP 3.0 for Vybrid. For new designs we recommend ULL now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-23images: drop the legacy update procedureMax Krummenacher
Use the Toradex Easy Installer instead. If you included tdx-image-fstype.inc in your image recipes you will have to remove that include. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-21lxqt-image: cope with xwayland or native x11Max Krummenacher
2019-04-20images: do not explicitely install ${XSERVER}Max Krummenacher
This is added through distro features settings. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-18images: add tools usefull for i.MX8 based SoCMax Krummenacher
2019-04-18tdx-extra: sort variable definitionsMax Krummenacher
No change in what gets installed intendend. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-18images: imx8: install util-linuxMax Krummenacher
This among others provides taskset. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-04-18images: replace canutils with can-utilsMax Krummenacher
can-utils support CAN-FD which canutils does not. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06tdx-image-fstype: drop include tdx_version.confMax Krummenacher
Variables from tdx_version.conf are now provided by the distro. Add defaults in case someone uses tdx-image-fstype without our distro. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06buildconf: moved to meta-toradex-distroMax Krummenacher
2019-03-06tk1: drop meta-jetson-tk1Max Krummenacher
All of meta-toradex-tegra contains now all needed for TK1. Drop meta-jetson-tk1. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06gvfs: add libusb to dependsMax Krummenacher
Without gphoto libusb is otherwise not available and configure fails. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06libpwquality: drop in favour of meta-oeMax Krummenacher
meta-oe now provides libpwquality. Drop the recipe here. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06backports: currently fails for mx8 machinesMax Krummenacher
The backports recipe does not yet work with the kernel used for apalis-imx8 and colibri-imx8qxp. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06tdx-extra: reenable license deploymentMax Krummenacher
2019-03-06images: don't add gstreamer1.0-libav unconditionallyMax Krummenacher
gstreamer1.0-libav needs commercial licenses to be whitelisted, thus only install it when this is allowed through configuration. E.g. add LICENSE_FLAGS_WHITELIST = "commercial_gstreamer1.0-libav" to local.conf to allow installing libav. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06qt3d: address race conditionMax Krummenacher
2019-03-06images: don't use backports for qemu machinesMax Krummenacher
The backports configuration does not match the kernel used. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06buildhistory: (re) enableMax Krummenacher
Angstrom sets this in the distro configuration, poky does not. So enable it in local.conf to get the usefull debug aid build/buildhistroy. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2019-03-06distro: move from angstrom to a poky based distroMax Krummenacher
2019-03-06timestamp-service: import from angstromMax Krummenacher
2019-03-06files: delete orphaned filesMax Krummenacher
2019-03-06squash with T30 removal, update.sh is used for tk1Max Krummenacher
