qtquickcontrols are only built if qtbase gets configured with accessibility.
Newer U-Boot versions no longer write a BCB which includes the work
around for errata e9609. However, we need to be able to upgrade
modules which still have such BCB on-disk. Use the following process
to upgrade modules:
1. Use the old U-Boot to flash a new U-Boot using the old format
2. Use the new U-Boot to replace the old BCB with the new BCB
3. Use the new U-Boot to flash the new U-Boot using the new format
Each deployed source file throws the warning 'host-user-contaminated'
in an angstrom setup.
Silence the QA warning.
The base_contains function is deprecated and we ought to use
bb.utils.contains instead.
Make sure that 'bitbake angstrom-qt5-x11-image –c populate-sdk'
deploys additional qt5 tools.
With the deploy dir no longer under TMPDIR switch back to the defaul
tmp name as it does no longer contain the final deployable output.
This moves the final build artefacts to a more visible place.
Additionally you can wipe the 'out*' directory to clean up
old intermediate files without loosing the deployable artefacts.
Have all oe meta data layers in a directory called layers rather than stuff
The V2.6 Embedded Linux BSPs for iMX6 and T30 modules are the first
stable software releases for those modules.
Replace meta-toradex with the four new meta-toradex-XX layers.
While at it drop the variables for BSP and software layers.
Add the new location of of bblayers.conf/local.conf to the export
script.
The BSP should automount for all users.
The Demo Software Layers cares for RNDIS.
This requires to adjust the path to include files, e.g.:
-require recipes/images/trdx-image-fstype.inc
+require recipes-images/images/trdx-image-fstype.inc
This bbappend is required by packages built with meta-lxde.
Thus move it were it belongs.
Move angstrom-feed-configs.bbappend to the appropriate subdirectory.
The files in the files/ subdirectory have been obsoleted with
3c3719ec6f9e ("trdx-config: remove obsolete package") and are no
longer used, hence delete them.
They aren't needed anymore, the video ADC gets configured from its
kernel driver.
It isn't needed anymore, the video ADC gets configured from its
kernel driver.
Deploy GPIOConfig V1.4.
Apalis iMX6: corrects the iomux offset of PAD_SD4_DATA6.
Colibri iMX6: corrects 'SODIMM Pin'/'EvalLoc' columns for pads:
DI0_PIN15
NANDF_D4
NANDF_D6
SD1_CLK
The script fails when -m is given but rootfs/etc/issue fails to provide
the version info.
While at it correct wrong text output on i.MX 6 based modules.
Using libimxvpuapi causes asserts when using certain pipelines,
e.g. with gst-play-1.0.
Don't build the plugins which base on libimxvpuapi for now.
Disable LVDS output in favour of primary HDMI one on Apalis TK1.
The Vivante X driver does not support the X video extension.
Remove the locally backported 6.8 version since bitbake anyway
use the newer 7.1 version from OpenEmbedded core.
This reverts commit 8d0349a08564a8044bad7f0f3ff0982e6d5a6aa2.
Pass $libdir to 'waf configure' to prevent using the build hosts libdir.
Fixes:
WARNING: libimxvpuapi-0.10.2-r0 do_package: QA Issue: libimxvpuapi: Files/directories were installed but not shipped in any package:
/usr/lib64/libimxvpuapi.so
/usr/lib64/libimxvpuapi.so.0
/usr/lib64/libimxvpuapi.so.0.10.2
/usr/lib64/pkgconfig
/usr/lib64/pkgconfig/libimxvpuapi.pc
Signed-off-by: Max Krummenacher <max.krummenacher at toradex.com>
add configure options to build without sound. This removes the runtime
dependency on gstreamer 0.10.
The plain framebuffer X11 driver does not support xv so the
plugin does not work.
