2016-06-30apalis-tk1: integrate usb-rndisMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30images: i.mx 7 don't deploy gstreamer xvimagesinkMax Krummenacher
The plain framebuffer X11 driver does not support xv so the plugin does not work. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30trdx-image-fstype: integrate apalis-tk1Marcel Ziswiler
2016-06-30trdx-extra: integrate apalis-tk1Marcel Ziswiler
2016-06-30angstrom-lxde-image: integrate apalis-tk1Marcel Ziswiler
2016-06-30lxde: wallpaper: integrate apalis-tk1Marcel Ziswiler
2016-06-30buildconf/bblayers.conf: integrate watatuki's meta-jetson-tk1Marcel Ziswiler
2016-06-30base-files: transition search domain from colibri.net to toradex.netMarcel Ziswiler
2016-06-30trdx-extra.inc: add iperf3 to all imagesMax Krummenacher
2016-06-30Revert "gstreamer: fix argument parsing when using Bison 3"Max Krummenacher
This reverts commit 04324a6e680902d4c1aabeff7187975a6cbf09b0. The patch is now part of meta-openembedded jethro branch. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30i.MX 7: mention FreeRTOS issue in release notesStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30trdx-image-fstype: do not try to strip imx_usb.confStefan Agner
The star syntax currently includes imx_usb.conf to be stripped. We only deploy imx_usb (no .m32 variant), hence getting rid of the star should be save. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30trdx-image-fstype: imx7: deploy zImage/device trees to bin folderStefan Agner
2016-06-30florence: move to latest GTK2 version 0.5.4Stefan Agner
The latest GTK2 version is 0.5.4, which contains several bug fixes. Noteable, it fixes an issue where the SVG keys have not been displayed with recent versions of its dependencies. Note: This adds GStreamer 0.10 dependency... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30u-boot: get rid of obsolete patchesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30angstrom-qt5-x11-image.bb: add a recipe which deploys qt5 and starts a demoMax Krummenacher
2016-06-30qt5-x11-free-systemd: add systemd service recipe to start a qt5 appMax Krummenacher
2016-06-30update.sh: add parameter to force module typeMax Krummenacher
update.sh guesses the module type from rootfs/etc/issue which works for images created from our meta-toradex recipes. If another rootfs is used one has to edit etc/issue. Overcome that requirement by providing a -m parameter which allows forcing the targeted module type. Not giving -m or '-m 0' keeps the old behaviour. see 'update.sh -h' for valid values. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30update.sh: create a static volume for the Cortex-M4 firmwareStefan Agner
Create a static UBI volume to store the Cortex-M4 firmware. Use 0xE0000 which makes the three static volumes exactly 9MiB. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30update.sh: Colibri iMX6 eliminate warningMax Krummenacher
Eliminate the following warning: cp: warning: source file ‘colibri-imx6_bin/u-boot.imx’ specified more than once Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30apalis-tk1: add initial flashing infrastructureMarcel Ziswiler
2016-06-30update.sh: colibri_imx7/t20/vf: use update_fdt rather than update_dtbMarcel Ziswiler
To be more in-line with all our other modules change update_dtb to update_fdt also on all our NAND based modules and document it as such. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30update.sh: vf: fix typo in message and remove unnecessary echoStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30update.sh: imx7: use new U-Boot to flash modulesStefan Agner
U-Boot delivered with V2.6 Alpha1 does not have SoC type detection which can be used to load the device tree (imx7s/imx7d). Flash U-Boot first and reset to make sure we use the new U-Boot to flash the rest of the components. The later corrected the commit message. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30update.sh: update help text for new deployment schemeStefan Agner
2016-06-30update.sh: imx7: write kernel and dt into static UBI volumesStefan Agner
Write kernel and device tree into seperate UBI Volumes. This allows to use a lot less UBI/UBIFS support in U-Boot, which should lower the risk of hitting bugs in this area. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30update.sh: switch to mkfs.fatStefan Agner
The binary/symlink mkfs.vfat seems to be considered outdated, it is only deployed if one configures dosfstools with the flag --enable-compat-symlinks. Switch to mkfs.fat which seems to be the official binary to create FAT filesystems now. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30update.sh: write kernel and device tree into static UBI volumesDominik Sliwa
Use static UBI volumes on Colibri T20. Fix update over ethernet on Colibri Vybrid Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: fix some typosStefan Agner
2016-06-24update.sh: use exit trap to report unexpected exitsStefan Agner
Add exit trap to report unexpected exits (due to set -e). Note that this traps every exit, also explicit calls to exit. Therefor register the trap only during the sequencial image generating/coping part, after the sanity checks... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: do not error out during mkfs.ubifs/cbootimage testsStefan Agner
If executing the command fails, the exit code will be <> 1 which leads to an imeadiate exit (due to set -e). Avoid exiting by adding "|| true" to the sanity check commands. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: use command instead of whichStefan Agner
Use "command" instead of "which" for sanity checks. This is preferable to several reasons, see: http://stackoverflow.com/questions/592620/check-if-a-program-exists-from-a-bash-script Also always use or (||) syntax to avoid bash script exits. Tested to be working on Ubuntu, Fedora and Arch Linux. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: omit explicit exit code after recovery commandStefan Agner
By omitting an explicit exit code after the recovery command we will get the exit code of the last command. This makes sense, since we would be able to tell whether recovery actually succeeded or not. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: use test expressions in if statement for colibri-t20Stefan Agner
Since we introduced set -e commands which fail will exit silently. This leads to no error message when the grep which tests for specified parameters failed. We could solve it with || true, but it seems more lightweight to just test for the strings inside the if statement. It also checks for the full length (e.g. disallows "25" as RAM size). The later fixed only 256 MB RAM size copy paste issue. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: exit with success whenever help is specifiedStefan Agner
Unix commands usually exit successfully when help was explicitly asked for. However, in case arguments are incomplete or otherwise wrong, exit with error. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: use printf instead of echoStefan Agner
printf allows to print escape sequences (e.g. for colored output) and is part of the POSIX standard. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24i.MX 6: add gstreamer issue to release noteMax Krummenacher
2016-06-24Updated release notes.Marcel Ziswiler
2016-03-31angstrom-lxde-image.bb: drop webbrowser webkitgtk-bin for vybridsMax Krummenacher
There are issues with running it with the mesa EGL component. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-31angstrom-lxde-image.bb: deploy gpioconfig for Colibri iMX6Max Krummenacher
2016-03-31apalis/colibri_imx6: update scripts for fast boot mode migrationMarcel Ziswiler
Adjusted update scripts for fast boot mode migration as per the following article on our developer website: http://developer.toradex.com/knowledge-base/linux-booting#eMMC_Fast_Boot_Mode_ApalisColibri_iMX6 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-03-30firefox: disable annoying default browser checkMarcel Ziswiler
2016-03-30angstrom-lxde-image.bb: don't install a second icon themeMax Krummenacher
pcman-fm and gtk RRECOMMEND adwaita. Do not install them and keep the lxde-icon-theme Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30angstrom-lxde-image: don't force a dependency on gstreamer 1.0 for tegrasMax Krummenacher
On the tegras we have to stay with gstreamer 0.10. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30lxde-common: fix i.MX 7Solo detectionMax Krummenacher
2016-03-30psplash-angstrom_git.bbappend: removed, *.bb no longer existsMax Krummenacher
2016-03-30angstrom-lxde-image: mx7: don't deploy gplay, grecordMax Krummenacher
2016-03-30overrides: use append instead of +=Max Krummenacher
We want to append to the generic VAR when we build for a tegra machine. Using VAR_tegra += "" creates a machine specific VAR. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-30trdx-extra.inc: deploy u-boot utils for Colibri iMX7Max Krummenacher
2016-03-30gstreamer: fix argument parsing when using Bison 3Max Krummenacher
Use Stefan's patch until it is available from the meta-openembedded jethro branch. http://cgit.openembedded.org/meta-openembedded/commit/?h=master-next&id=bf8f27af3954ab68e39712516ab515de90b4db27 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
