2017-03-01gstreamer1.0-plugins-imx: don't build for vpu also on dljethro-nextMax Krummenacher
Using libimxvpuapi causes asserts when using certain pipelines, e.g. with gst-play-1.0. Don't build the plugins which base on libimxvpuapi for now. remove it also for i.MX6 DL. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-12-22Revert "flash scripts: implement FCB/BCB upgrade"jethroStefan Agner
This reverts commit 5fe2de36e0380ee81c77dfb13b9b4ccebdbc3b0a. The U-Boot version in the current 2015.04-toradex does not support the new boot mode yet, hence do not upgrade FCB/BCB. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-11-26apalis-tk1: updated release notesMarcel Ziswiler
2016-11-21update toradex-mirrors to V2.6Apalis_TK1_LinuxImageV2.6.1Beta2_20161122Stefan Agner
Update the URL of Toradex mirrors to the V2.6 subfolder. Unfortunately we missed that before doing the V2.6 release, hence most builds will try to fetch sources from V2.5. Therefor we synchronized all sources of V2.5 and V2.6 images into the V2.5 source folder and symlinked V2.6 to it. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-11-21qtbase bbappend: configure unconditionally with -accessibilityMax Krummenacher
qtquickcontrols are only built if qtbase gets configured with accessibility. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-11-21flash scripts: implement FCB/BCB upgradeStefan Agner
Newer U-Boot versions no longer write a BCB which includes the work around for errata e9609. However, we need to be able to upgrade modules which still have such BCB on-disk. Use the following process to upgrade modules: 1. Use the old U-Boot to flash a new U-Boot using the old format 2. Use the new U-Boot to replace the old BCB with the new BCB 3. Use the new U-Boot to flash the new U-Boot using the new format Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-11-21qt4: add patch which fixes 24-bit color depthStefan Agner
2016-11-21updated release notesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29gstreamer1.0-plugins-imx bbappend: use version wildcardColibri_iMX7_LinuxImageV2.6.1Beta1_20160929Colibri_iMX6_LinuxImageV2.6.1Beta1_20160929Colibri_VF_LinuxImageV2.6.1Beta1_20161001Colibri_T30_LinuxImageV2.6.1Beta1_20160929Colibri_T20_LinuxImageV2.6.1Beta1_20160929Apalis_iMX6_LinuxImageV2.6.1Beta1_20160929Apalis_TK1_LinuxImageV2.6.1Beta1_20160929Apalis_T30_LinuxImageV2.6.1Beta1_20160929Max Krummenacher
2016-09-29buildconf/local.conf: silence warningMax Krummenacher
Each deployed source file throws the warning 'host-user-contaminated' in an angstrom setup. Silence the QA warning. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29apalis-tk1: deploy full mesa-demos in favour of segfaulting eglinfo-x11Marcel Ziswiler
2016-09-29apalis-tk1: use hdmi hotplug udev rule as wellMarcel Ziswiler
2016-09-29colibri_imx7: updated release notesMarcel Ziswiler
2016-09-29images: set PV to 2.6.1Max Krummenacher
2016-09-29recipes: stop using base_containsMax Krummenacher
The base_contains function is deprecated and we ought to use bb.utils.contains instead. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29angstrom-qt5-x11-image.bb: deploy qt5 tools into the sdkMax Krummenacher
Make sure that 'bitbake angstrom-qt5-x11-image –c populate-sdk' deploys additional qt5 tools. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29TMPDIR: rename from out to tmpMax Krummenacher
With the deploy dir no longer under TMPDIR switch back to the defaul tmp name as it does no longer contain the final deployable output. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29deploy dir: mv from build/out*/deploy to deployMax Krummenacher
This moves the final build artefacts to a more visible place. Additionally you can wipe the 'out*' directory to clean up old intermediate files without loosing the deployable artefacts. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29oe-layers: rename the parent directory from stuff to layersMax Krummenacher
Have all oe meta data layers in a directory called layers rather than stuff Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29apalis/colibri_imx6/t30: updated release notesMarcel Ziswiler
The V2.6 Embedded Linux BSPs for iMX6 and T30 modules are the first stable software releases for those modules. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-09-29bblayers.conf, export: follow split of meta-toradexMax Krummenacher
Replace meta-toradex with the four new meta-toradex-XX layers. While at it drop the variables for BSP and software layers. Add the new location of of bblayers.conf/local.conf to the export script. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-29systemd-compat-units: mv all systemd bbappends under recipes-coreMax Krummenacher
2016-09-29systemd: split bbappend to only change demo layer releated rndisMax Krummenacher
The BSP should automount for all users. The Demo Software Layers cares for RNDIS. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-09-28images: mv all files into recipes-image/imageMax Krummenacher
This requires to adjust the path to include files, e.g.: -require recipes/images/trdx-image-fstype.inc +require recipes-images/images/trdx-image-fstype.inc Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-28xserver-common_%.bbappend: delete, moved to meta-lxdeMax Krummenacher
This bbappend is required by packages built with meta-lxde. Thus move it were it belongs. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-28gdk-pixbuf_%.bbappend: delete, moved to meta-lxdeMax Krummenacher
2016-09-28stress: mv all files into recipes-support/stressMax Krummenacher
2016-09-28trdx-config: delete/mv all files into recipes-angstrom/angstrom/Max Krummenacher
Move angstrom-feed-configs.bbappend to the appropriate subdirectory. The files in the files/ subdirectory have been obsoleted with 3c3719ec6f9e ("trdx-config: remove obsolete package") and are no longer used, hence delete them. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-28trdx-oak-sensors: mv all files into recipes-support/trdx-oak-sensorsMax Krummenacher
2016-09-28gpioconfig: mv all files into recipes-support/gpioconfigMax Krummenacher
2016-09-28base-files: mv all files into recipes-core/base-filesMax Krummenacher
2016-09-28max9526-i2c: drop userspace i2c tools for max9526Max Krummenacher
They aren't needed anymore, the video ADC gets configured from its kernel driver. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-28images: max9526-i2c: no longer deploy the userspace configuratorMax Krummenacher
It isn't needed anymore, the video ADC gets configured from its kernel driver. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Stefan Agner <stefan.agner@toradex.com>
2016-09-28mklibs-native: drop in favour of newer oe-core oneMax Krummenacher
2016-09-28update readme and copying.mitMax Krummenacher
2016-09-28add layer.confMax Krummenacher
2016-08-17apalis/colibri-t30: fix dtb file name in u-boot update scriptsmeta-toradex_splitStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17gpioconfig: deploy v1.4 for apalis/colibri imx6Max Krummenacher
Deploy GPIOConfig V1.4. Apalis iMX6: corrects the iomux offset of PAD_SD4_DATA6. Colibri iMX6: corrects 'SODIMM Pin'/'EvalLoc' columns for pads: DI0_PIN15 NANDF_D4 NANDF_D6 SD1_CLK Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2016-08-17updated release notesMarcel Ziswiler
2016-08-17build: Fix export script for non-bash shellsDominik Sliwa
Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17update.sh: unify among machinesMax Krummenacher
2016-08-17update.sh: i.MX 6: reference kernel name through variableMax Krummenacher
2016-08-17update.sh: fix parameter to force module typeMax Krummenacher
The script fails when -m is given but rootfs/etc/issue fails to provide the version info. While at it correct wrong text output on i.MX 6 based modules. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2016-06-30gstreamer1.0-plugins-imx: don't build for vpuMax Krummenacher
Using libimxvpuapi causes asserts when using certain pipelines, e.g. with gst-play-1.0. Don't build the plugins which base on libimxvpuapi for now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30apalis-tk1: lvds-tegra124: disable lvds by defaultMarcel Ziswiler
Disable LVDS output in favour of primary HDMI one on Apalis TK1. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30gpioconfig: fix pkg_postrmMarcel Ziswiler
2016-06-30images: i.mx 6 don't deploy gstreamer xvimagesink, xvinfoMax Krummenacher
The Vivante X driver does not support the X video extension. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30Revert "openssh: backport version 6.8 from master"Stefan Agner
Remove the locally backported 6.8 version since bitbake anyway use the newer 7.1 version from OpenEmbedded core. This reverts commit 8d0349a08564a8044bad7f0f3ff0982e6d5a6aa2. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30libimxvpuapi: add bbappend to use libdir from cross environmentMax Krummenacher
Pass $libdir to 'waf configure' to prevent using the build hosts libdir. Fixes: WARNING: libimxvpuapi-0.10.2-r0 do_package: QA Issue: libimxvpuapi: Files/directories were installed but not shipped in any package: /usr/lib64/libimxvpuapi.so /usr/lib64/libimxvpuapi.so.0 /usr/lib64/libimxvpuapi.so.0.10.2 /usr/lib64/pkgconfig /usr/lib64/pkgconfig/libimxvpuapi.pc Signed-off-by: Max Krummenacher <max.krummenacher at toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30florence: build without sound and drop gstreamer 0.10 dependencyMax Krummenacher
add configure options to build without sound. This removes the runtime dependency on gstreamer 0.10. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
