2016-08-17apalis/colibri-t30: fix dtb file name in u-boot update scriptsmeta-toradex_splitStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17gpioconfig: deploy v1.4 for apalis/colibri imx6Max Krummenacher
Deploy GPIOConfig V1.4. Apalis iMX6: corrects the iomux offset of PAD_SD4_DATA6. Colibri iMX6: corrects 'SODIMM Pin'/'EvalLoc' columns for pads: DI0_PIN15 NANDF_D4 NANDF_D6 SD1_CLK Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2016-08-17updated release notesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17build: Fix export script for non-bash shellsDominik Sliwa
Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-08-17update.sh: unify among machinesMax Krummenacher
2016-08-17update.sh: i.MX 6: reference kernel name through variableMax Krummenacher
2016-08-17update.sh: fix parameter to force module typeMax Krummenacher
The script fails when -m is given but rootfs/etc/issue fails to provide the version info. While at it correct wrong text output on i.MX 6 based modules. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2016-06-30gstreamer1.0-plugins-imx: don't build for vpuMax Krummenacher
Using libimxvpuapi causes asserts when using certain pipelines, e.g. with gst-play-1.0. Don't build the plugins which base on libimxvpuapi for now. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30apalis-tk1: lvds-tegra124: disable lvds by defaultMarcel Ziswiler
Disable LVDS output in favour of primary HDMI one on Apalis TK1. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30gpioconfig: fix pkg_postrmMarcel Ziswiler
2016-06-30images: i.mx 6 don't deploy gstreamer xvimagesink, xvinfoMax Krummenacher
The Vivante X driver does not support the X video extension. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30Revert "openssh: backport version 6.8 from master"Stefan Agner
Remove the locally backported 6.8 version since bitbake anyway use the newer 7.1 version from OpenEmbedded core. This reverts commit 8d0349a08564a8044bad7f0f3ff0982e6d5a6aa2. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30libimxvpuapi: add bbappend to use libdir from cross environmentMax Krummenacher
Pass $libdir to 'waf configure' to prevent using the build hosts libdir. Fixes: WARNING: libimxvpuapi-0.10.2-r0 do_package: QA Issue: libimxvpuapi: Files/directories were installed but not shipped in any package: /usr/lib64/libimxvpuapi.so /usr/lib64/libimxvpuapi.so.0 /usr/lib64/libimxvpuapi.so.0.10.2 /usr/lib64/pkgconfig /usr/lib64/pkgconfig/libimxvpuapi.pc Signed-off-by: Max Krummenacher <max.krummenacher at toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30florence: build without sound and drop gstreamer 0.10 dependencyMax Krummenacher
add configure options to build without sound. This removes the runtime dependency on gstreamer 0.10. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30apalis-tk1: integrate usb-rndisMarcel Ziswiler
2016-06-30images: i.mx 7 don't deploy gstreamer xvimagesinkMax Krummenacher
The plain framebuffer X11 driver does not support xv so the plugin does not work. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30trdx-image-fstype: integrate apalis-tk1Marcel Ziswiler
2016-06-30trdx-extra: integrate apalis-tk1Marcel Ziswiler
2016-06-30angstrom-lxde-image: integrate apalis-tk1Marcel Ziswiler
2016-06-30lxde: wallpaper: integrate apalis-tk1Marcel Ziswiler
2016-06-30buildconf/bblayers.conf: integrate watatuki's meta-jetson-tk1Marcel Ziswiler
2016-06-30base-files: transition search domain from colibri.net to toradex.netMarcel Ziswiler
2016-06-30trdx-extra.inc: add iperf3 to all imagesMax Krummenacher
2016-06-30Revert "gstreamer: fix argument parsing when using Bison 3"Max Krummenacher
This reverts commit 04324a6e680902d4c1aabeff7187975a6cbf09b0. The patch is now part of meta-openembedded jethro branch. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30i.MX 7: mention FreeRTOS issue in release notesStefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30trdx-image-fstype: do not try to strip imx_usb.confStefan Agner
The star syntax currently includes imx_usb.conf to be stripped. We only deploy imx_usb (no .m32 variant), hence getting rid of the star should be save. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30trdx-image-fstype: imx7: deploy zImage/device trees to bin folderStefan Agner
2016-06-30florence: move to latest GTK2 version 0.5.4Stefan Agner
The latest GTK2 version is 0.5.4, which contains several bug fixes. Noteable, it fixes an issue where the SVG keys have not been displayed with recent versions of its dependencies. Note: This adds GStreamer 0.10 dependency... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30u-boot: get rid of obsolete patchesMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30angstrom-qt5-x11-image.bb: add a recipe which deploys qt5 and starts a demoMax Krummenacher
2016-06-30qt5-x11-free-systemd: add systemd service recipe to start a qt5 appMax Krummenacher
2016-06-30update.sh: add parameter to force module typeMax Krummenacher
update.sh guesses the module type from rootfs/etc/issue which works for images created from our meta-toradex recipes. If another rootfs is used one has to edit etc/issue. Overcome that requirement by providing a -m parameter which allows forcing the targeted module type. Not giving -m or '-m 0' keeps the old behaviour. see 'update.sh -h' for valid values. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30update.sh: create a static volume for the Cortex-M4 firmwareStefan Agner
Create a static UBI volume to store the Cortex-M4 firmware. Use 0xE0000 which makes the three static volumes exactly 9MiB. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30update.sh: Colibri iMX6 eliminate warningMax Krummenacher
Eliminate the following warning: cp: warning: source file ‘colibri-imx6_bin/u-boot.imx’ specified more than once Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30apalis-tk1: add initial flashing infrastructureMarcel Ziswiler
2016-06-30update.sh: colibri_imx7/t20/vf: use update_fdt rather than update_dtbMarcel Ziswiler
To be more in-line with all our other modules change update_dtb to update_fdt also on all our NAND based modules and document it as such. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-06-30update.sh: vf: fix typo in message and remove unnecessary echoStefan Agner
2016-06-30update.sh: imx7: use new U-Boot to flash modulesStefan Agner
U-Boot delivered with V2.6 Alpha1 does not have SoC type detection which can be used to load the device tree (imx7s/imx7d). Flash U-Boot first and reset to make sure we use the new U-Boot to flash the rest of the components. The later corrected the commit message. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30update.sh: update help text for new deployment schemeStefan Agner
2016-06-30update.sh: imx7: write kernel and dt into static UBI volumesStefan Agner
Write kernel and device tree into seperate UBI Volumes. This allows to use a lot less UBI/UBIFS support in U-Boot, which should lower the risk of hitting bugs in this area. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30update.sh: switch to mkfs.fatStefan Agner
The binary/symlink mkfs.vfat seems to be considered outdated, it is only deployed if one configures dosfstools with the flag --enable-compat-symlinks. Switch to mkfs.fat which seems to be the official binary to create FAT filesystems now. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-30update.sh: write kernel and device tree into static UBI volumesDominik Sliwa
Use static UBI volumes on Colibri T20. Fix update over ethernet on Colibri Vybrid Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: fix some typosStefan Agner
2016-06-24update.sh: use exit trap to report unexpected exitsStefan Agner
Add exit trap to report unexpected exits (due to set -e). Note that this traps every exit, also explicit calls to exit. Therefor register the trap only during the sequencial image generating/coping part, after the sanity checks... Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: do not error out during mkfs.ubifs/cbootimage testsStefan Agner
If executing the command fails, the exit code will be <> 1 which leads to an imeadiate exit (due to set -e). Avoid exiting by adding "|| true" to the sanity check commands. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: use command instead of whichStefan Agner
Use "command" instead of "which" for sanity checks. This is preferable to several reasons, see: http://stackoverflow.com/questions/592620/check-if-a-program-exists-from-a-bash-script Also always use or (||) syntax to avoid bash script exits. Tested to be working on Ubuntu, Fedora and Arch Linux. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: omit explicit exit code after recovery commandStefan Agner
By omitting an explicit exit code after the recovery command we will get the exit code of the last command. This makes sense, since we would be able to tell whether recovery actually succeeded or not. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: use test expressions in if statement for colibri-t20Stefan Agner
Since we introduced set -e commands which fail will exit silently. This leads to no error message when the grep which tests for specified parameters failed. We could solve it with || true, but it seems more lightweight to just test for the strings inside the if statement. It also checks for the full length (e.g. disallows "25" as RAM size). The later fixed only 256 MB RAM size copy paste issue. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: exit with success whenever help is specifiedStefan Agner
Unix commands usually exit successfully when help was explicitly asked for. However, in case arguments are incomplete or otherwise wrong, exit with error. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2016-06-24update.sh: use printf instead of echoStefan Agner
printf allows to print escape sequences (e.g. for colored output) and is part of the POSIX standard. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
