- they do fail because they don't heed the private libgcc
- is already installed
- make the menuentry behave as the one time calibration on first boot
this allows a debug installation of dropbear with openssh-scp,
openssh-sftp and openssh-sftp-server
Apalis_T30_LinuxImageV2.0Beta1_20130626
- on Colbri/Apalis T30 the rootfs is downloaded in a minimum size.
On first boot this filesystem is resized to fill its full partion.
This slows down IO responsivness during the first 5 minutes.
- unified the burnflash sources to work on Colibri T20/T30, Apalis T30
- change the PXA dummy burnflash accordingly
- increase the initial free rootfs space to 100M on eMMC partition
will be resized on first boot to full partition size
relevant for Colibri T30, Apalis T30
- Unclutter hides your X mouse cursor when you do not need it
