Currently our update.sh script limits the partition size to around
2GB by default so even after our automatic resizing only 2GB of the
4GB of available eMMC space can be used.
Set a higher and saner default EMMC_SIZE to allow automatic resizing
to the full EMMC space available.
Use run update_rootfs to update the rootfs.
oe-core included resize in their profile too.
Synchronize with the OE solution which already does the redirect.
OE-Core split the package into only native tools and one which uses perl
and fixed the dependencies so that perl is no longer pulled in.
silence warning for hash-style not gnu
WARNING: unclutter-1.09-r0 ... No GNU_HASH in the elf binary: '...unclutter' [ldflags]
When systemd was introduced to OE sysv initscripts did sometimes interfere
with systemd services. We deleted them at image creation time.
This is no longer done, however a task which creates a no longer called
script is still in the recipe. Remove that.
8GB by default so even after our automatic resizing only 8GB of the
16GB of available eMMC space can be used.
Signed-off-by: Sanchayan Maity <sanchayan.maity@toradex.com>
Our current update procedure reads the rootfs payload in pre
split files of 64 MB size. However due to the workaround for
u-boot counting in hex and split did in decimal, the number of
chunks is limited to 89 resulting in a maximum size of 5.5GB.
Update the u-boot counting procedure to count in 3 digits from
the current 2 digits. This allows more than 800 plus chunks
which should take care of rootfs size and any future eMMC
update requirements.
Now that we split the rootfs file by default for both Ethernet as
well as SD card update, it is no longer required to deploy the
rootfs.ext3 file which also saves space. Only deploy the split
rootfs files.
Our current update procedure requires the rootfs payload to fit in
one file on a FAT filesystem. This limits its usable size to 4GB.
Use the process of splitting up the files in 64MB chunks and then
doing the update which is also what the Ethernet update scripts
currently follow.
However due to the workaround for u-boot counting in hex and split
did in decimal, the number of chunks is limited to 89 resulting in
a maximum size of 5.5GB. We will remove the limitation in a follow
up patch.
We use the image summary as image name for the Toradex Easy Installer.
Since we might end up in a list of images of other operating systems
and maybe even other companies, make sure to mention Toradex and Linux.
While at it use a common summary pattern across all image recipes.
libwnck3 was removed from oe-core but did not (yet) make it into
meta-openembedded. Pull in the patch here.
From: Alexander Kanavin <alexander.kanavin@linux.intel.com>
Date: Tue, 1 Nov 2016 17:28:21 +0200
Subject: [PATCH] libwnck3: add a recipe
It is no longer needed in oe-core.
Signed-off-by: Alexander Kanavin <alexander.kanavin@linux.intel.com>
Signed-off-by: Martin Jansa <Martin.Jansa@gmail.com>
Follow the name change in the WinCE team.
Taken from a proposed but not yet applied solution upstream.
https://patchwork.openembedded.org/patch/103083/
Functions starting with "do_" have a special meaning for bitbake,
only use this prefix for bitbake tasks.
Don't emit DNS/NTP/Router/Timezone servers addresses to the RNDIS client.
We expect RNDIS to be used as a service/debug interface to connect to
a module. For this we do not want to reconfigure the connecting device
with the modules setup.
The old solution with using packagegroup-fsl-tools-gpu with a
bbappend to remove the big tools and examples needs more maintanance
and makes it hard for someone who really wants the examples or tools
in a image.
So change to a new packagegroup to deploy the libraries.
Also deploy OpenCL releated libraries seperately.
| WARNING: gnome-disk-utility-3.21.3-r4 do_package: QA Issue: gnome-disk-utility: Files/directories were installed but not shipped in any package:
| /usr/share/appdata
| /usr/share/dbus-1
| /usr/share/appdata/org.gnome.DiskUtility.appdata.xml
| /usr/share/dbus-1/services
| /usr/share/dbus-1/services/org.gnome.DiskUtility.service
While at it, drop the nautilus extension package, that is no longer provided.
This changes the update scripts for a system which boots an SPL into
static RAM which configures the DDR RAM, loads U-Boot proper into DDR
and passes execution to U-Boot.
The SPL is only written by the explicit update_spl command or when the
script does not find a valid U-Boot in eMMC.
If there is an SPL binary deploy it in addition to the already
deployed U-Boot binaries.
Applications now rely on udisk2 which they pull in through
dependencies. There is no need to install udisks explicitly.
Patch gets now applyed in meta-qt4.
This reverts commit 990b54bc5cd767a2c687bae77ca1c79e40c79c0d
libwnck is anyway now used in its gtk3 flavour. The gtk3 version
libwnck3 will get pulled-in through dependencies.
| ERROR: qt4e-demo-image-V2.6.2-r0 do_imagedeploy: Taskhash mismatch
| 9bea17c6bcf5fbd90fb03151cb68643e versus b54814c540d50da12a3be23f96a2df2f
| for meta-toradex-demos/recipes-images/images/qt4e-demo-image.bb.do_imagedeploy
mesa-glut was dropped in favour of freeglut in oe.
bitbake provides the build date in DATE, use that instead of system time.
This avoids
| ERROR: console-trdx-image-V2.6.2-r0 do_imagedeploy: Taskhash mismatch ab883ff241d53c36d27b32a14f097fb1 versus 11833452ea92ee48688ab00a9ceba7d9
| for /build/krm/oe-core_V2.6.2/build/../layers/meta-toradex-demos/recipes-images/images/console-trdx-image.bb.do_imagedeploy
add libpwquality recipe from meta-qt5-extra.
While at it override packageconfig only if built for vybrid.
