Workaround for resize script
Due to the move to systemd, all init scripts located under /etc/init.d
get deleted by the inherited systemd recipes (systemd.inc). Since we
don't use the script as a system V init script, we can move the script
to /usr/bin.
Since we explicitly ask to build Qt for OpenGL ES2, we should also
make OpenGL ES2 as a explicit dependency.
GPIOconfig tool
Add recipe to build mainline kernel. Currently, the 3.17 next branch will
be built. To use this kernel, add this lines to your local.conf
PREFERRED_PROVIDER_virtual/kernel ?= "linux-toradex"
IMAGE_INSTALL_append = "kernel-devicetree"
KERNEL_DEVICETREE += "vf500-colibri-eval-v3.dtb vf610-colibri-eval-v3.dtb"
Also, the multi-core communication packages (mqxboot, libmcc, mcc-pingpong
and kernel-module-mcc) need to be removed from recipes/images/trdx-extra.inc
since the required kernel interfaces are not available on the 3.17 mainline
port.
Got the U-Boot stuff mixed up.
This is also done by the session manager effectively starting the
autostart items twice.
Angstrom started using thumb2 on machines with armv7-a architectures.
This commit removes our override to stay on arm instruction set, so
if building our machines with the angstrom distribution you now get
thumb2 builds.
Use latest U-Boot from git.
Migrate to using cbootimage and tegrarcm.
Remove xinput-calibrator systemd service since autostart is done
using /etc/xdg/autostart/xinput_calibrator.desktop.
Remove explicit installation of ConsoleKit since we use systemd-
logind nowadays. Also, pam-plugin-ck-connector, the ConsoleKit pam
plug-in, is not required anymore. The equavilent for systemd is
part of libpam (pam_systemd.so).
The secondary PolKit authenticatin agent polkit-gnome is not
necessary since LXDE has its own authentication agent lxpolkit.
Switch to newer LXDM which supports logind as login/session
management.
Detect the module type using the compatible property of the device
tree to symlink the module specific background image.
Use rebased U-Boot release 2014.10. The README has a new md5sum
and U-Boots new build system has default configurations ending
with defconfig too.
Due to U-Boot udpate we need to create one big UBI volume. Since
attaching the UBI volume is the expensive operation (compared to
mount the UBIFS inside that volume), it is relatively cheep to
load the kernel directly from the root filesystems /boot directory
instead of creating a own volume for the kernel. This also makes
it simpler to load a mainline kernel (along with the required dtb
file).
However, we loose the integrity check of the uImage. But since
there were no measures in place to handle a invalid image, we do
not loose functionality here. In case we need integrity check, we
should consider switching to the new FIT image format...
meta-angstrom backported systemd 2.16 into daisy. Keep using 2.11 for now.
u-boot.inc no longer builds the standalone examples by default so
do patch to not do so is no longer needed.
The source tree will no longer be marked as git dirty.
release-notes/Apalis_iMX6_LinuxReleaseNotesV2.x.txt
The enlightement svn seems to be down.
Workaround by using their git repo which provides the same data
and is already used in the master branch of meta-openembedded.
Remove once we upgrade from daisy to the next stable release.
gnutls use libgcrypt and should init gcrypt's mutex functionality but does not.
This leads to asserts in libgcrypt:
Ohhhh jeeee: Assertion `pool_is_locked' failed (random-csprng.c:615:mix_pool)
This patch hacks autoconf to always use libpthread and thus initalizes libgcrypt
with working mutex functions.
These features add and use software rendering.
Don't provide them for space and performance reasons.
Base kernel on Freescales 3.10.17_1.0.0_ga and provide a device tree plus
code changes for Apalis iMX6.
