The script fails when -m is given but rootfs/etc/issue fails to provide
the version info.
While at it correct wrong text output on i.MX 6 based modules.
Using libimxvpuapi causes asserts when using certain pipelines,
e.g. with gst-play-1.0.
Don't build the plugins which base on libimxvpuapi for now.
Disable LVDS output in favour of primary HDMI one on Apalis TK1.
The Vivante X driver does not support the X video extension.
Remove the locally backported 6.8 version since bitbake anyway
use the newer 7.1 version from OpenEmbedded core.
This reverts commit 8d0349a08564a8044bad7f0f3ff0982e6d5a6aa2.
Pass $libdir to 'waf configure' to prevent using the build hosts libdir.
Fixes:
WARNING: libimxvpuapi-0.10.2-r0 do_package: QA Issue: libimxvpuapi: Files/directories were installed but not shipped in any package:
/usr/lib64/libimxvpuapi.so
/usr/lib64/libimxvpuapi.so.0
/usr/lib64/libimxvpuapi.so.0.10.2
/usr/lib64/pkgconfig
/usr/lib64/pkgconfig/libimxvpuapi.pc
Signed-off-by: Max Krummenacher <max.krummenacher at toradex.com>
add configure options to build without sound. This removes the runtime
dependency on gstreamer 0.10.
The plain framebuffer X11 driver does not support xv so the
plugin does not work.
This reverts commit 04324a6e680902d4c1aabeff7187975a6cbf09b0.
The patch is now part of meta-openembedded jethro branch.
The star syntax currently includes imx_usb.conf to be stripped. We
only deploy imx_usb (no .m32 variant), hence getting rid of the star
should be save.
The latest GTK2 version is 0.5.4, which contains several bug fixes.
Noteable, it fixes an issue where the SVG keys have not been displayed
with recent versions of its dependencies.
Note: This adds GStreamer 0.10 dependency...
update.sh guesses the module type from rootfs/etc/issue which works for images
created from our meta-toradex recipes.
If another rootfs is used one has to edit etc/issue.
Overcome that requirement by providing a -m parameter which allows forcing
the targeted module type.
Not giving -m or '-m 0' keeps the old behaviour.
see 'update.sh -h' for valid values.
Create a static UBI volume to store the Cortex-M4 firmware. Use
0xE0000 which makes the three static volumes exactly 9MiB.
Eliminate the following warning:
cp: warning: source file ‘colibri-imx6_bin/u-boot.imx’ specified more than once
To be more in-line with all our other modules change update_dtb to
update_fdt also on all our NAND based modules and document it as such.
U-Boot delivered with V2.6 Alpha1 does not have SoC type detection
which can be used to load the device tree (imx7s/imx7d). Flash
U-Boot first and reset to make sure we use the new U-Boot to flash
the rest of the components.
The later corrected the commit message.
Write kernel and device tree into seperate UBI Volumes. This
allows to use a lot less UBI/UBIFS support in U-Boot, which
should lower the risk of hitting bugs in this area.
The binary/symlink mkfs.vfat seems to be considered outdated, it
is only deployed if one configures dosfstools with the flag
--enable-compat-symlinks.
Switch to mkfs.fat which seems to be the official binary to create
FAT filesystems now.
Use static UBI volumes on Colibri T20.
Fix update over ethernet on Colibri Vybrid
Add exit trap to report unexpected exits (due to set -e). Note that
this traps every exit, also explicit calls to exit. Therefor register
the trap only during the sequencial image generating/coping part,
after the sanity checks...
If executing the command fails, the exit code will be <> 1 which
leads to an imeadiate exit (due to set -e). Avoid exiting by
adding "|| true" to the sanity check commands.
Use "command" instead of "which" for sanity checks. This is preferable
to several reasons, see:
http://stackoverflow.com/questions/592620/check-if-a-program-exists-from-a-bash-script
Also always use or (||) syntax to avoid bash script exits. Tested to
be working on Ubuntu, Fedora and Arch Linux.
By omitting an explicit exit code after the recovery command we
will get the exit code of the last command. This makes sense,
since we would be able to tell whether recovery actually succeeded
or not.
Since we introduced set -e commands which fail will exit silently.
This leads to no error message when the grep which tests for
specified parameters failed.
We could solve it with || true, but it seems more lightweight to
just test for the strings inside the if statement. It also checks
for the full length (e.g. disallows "25" as RAM size).
The later fixed only 256 MB RAM size copy paste issue.
Unix commands usually exit successfully when help was explicitly
asked for. However, in case arguments are incomplete or otherwise
wrong, exit with error.
printf allows to print escape sequences (e.g. for colored output)
and is part of the POSIX standard.
There are issues with running it with the mesa EGL component.
Adjusted update scripts for fast boot mode migration as per the
following article on our developer website:
http://developer.toradex.com/knowledge-base/linux-booting#eMMC_Fast_Boot_Mode_ApalisColibri_iMX6
