We might want not to support burn flash for new machines. Make it
optional by checking whether the machine specific directory exists.
The new machine colibri-imx7-emmc uses eMMC and hence the regular
u-boot.imx binary.
Add a trailing ';' to separate from commands appended later.
The library libunwind is a dependency for the .NET Core 2.0
runtime. Preinstall it in our standard images.
We rely on the init system to remount the root file system read-only,
which makes the mount flags for the rootfs in fstab relevant. Since
we run on flash drives minimize write cycles by disabling atime by
by default.
Use PV variable to define the image version. With that the Tezi
image class can use OpenEmbedded variables to get the image version.
If a dtb file has more than one dot the current logic fails.
e.g. 'device.tree.dtb' will be truncated at the first dot to 'device'
while it should be 'device.tree'.
Fix by removing awk in favour of letting basename also remove
the .dtb extension.
The README content was no longer applicable, change it to reflect
the current use of the files here.
Use ext4 by default for TK1 modules.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
Use ext4 by default for iMX6 modules.
Deploy gstreamer-0.10 with nvidia TK1 support plugins.
Deploy Ixora V1.1 device tree for Apalis iMX6.
This adds the bmode_usb binary to the i.MX6 rootfs which allows to
set some i.MX6 registers so, that on the next reboot (not powercycle)
the i.MX6 starts in serial download mode (aka. recovery mode).
The eject binary is used by the libudisk2.
Without it e.g. pcmanfm shows an error message that eject could
not be found.
If an image creates a rootfs which is exactly a multiple of 64 MByte then
the scripts never detects that the last chunk has been read and
'run update' never completes.
Fix that by explicitely setting filesize to 0 when a file read fails.
As reported by our customer our current ext3 generation script lacks
copying any extended file attributes as well e.g. as required for
capabilities or ACLs.
Reported-by: Felix Ruess <felix.ruess@roboception.de>
As the kernel is no longer part of the rootfilesystem, add its
version to the version.txt file.
Starting with the following commit
tdx-image-fstype.inc: rename U_BOOT_BINARY to UBOOT_BINARY
we no longer deploy a symlink 'u-boot.imx' to the u-boot binary.
Thus only use u-boot-nand.imx in the update.sh script.
Disable broken OMTC on T20/T30 and iMX6 based modules. Leave it enabled
on Apalis TK1 where it seems to work and Colibri iMX7 doing software
only rendering anyway.
https://wiki.mozilla.org/Platform/GFX/OffMainThreadCompositing
As somebody previously decided to rename U_BOOT_BINARY to UBOOT_BINARY
unbreak e.g. i.MX 6 Tezi builds by continuing that rename through the
various layers:
http://git.toradex.com/cgit/meta-toradex-bsp-common.git/commit/?h=morty&id=02f7fdfe5eaca64e0c710cce4d701a609d499e8b
Deploy Aster device tree for Colibri iMX7.
Deploy Aster device tree for Colibri iMX6.
Deploy Aster device tree for Colibri Vybrid.
Copy/paste error prevented the intended fix to get actually applied.
We found that having ACL enabled in systemd on a ubifs adversely
affects power cut resilience.
Currently systemd is unconditionally enabled in a systemd build.
Add a acl packageconfig option, but do not enable it.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Since commit ef66b5819da4 ("images: use next generation libusbgx
USB Gadget library") the gadget library no longer adds a USB CDC
ACM device which can be used as a serial console. Remove the extra
serial console from local.conf.
By default systemd utilities use escape sequences to produce colored
output. But systemd also uses less as a pager. The less command
provided in the Toradex demo images is provided by BusyBox, which
does not support color escape sequences. Disable colored output
altogether. This makes output of journalctl much more readable.
Increase MIN_PARTITION_FREE_SIZE as a provision for customers running
NVIDIA JetPack on Apalis TK1.
Add a note about having to change apalis-t30_bin/apalis_t30.img.cfg
resp. colibri-t30_bin/colibri_t30.img.cfg as well if changing BCT.
Add dummy U-Boot update scripts to avoid do_imagedeploy build failure.
Last man standing...
While at it also reflect changed name of tdx-nv-binaries.
For i.MX6 the pin NANDF_D4 was wrongly muxed.
For TK1 the number of pins was wrong which prevented access to some pins.
LXDE: LinuxImage -> LXDE-Image
Qt4: LinuxImage-qt -> Qt4-X11-Image
Qt4 embedded: LinuxImage-qte -> Qt4e-Image
Qt5: LinuxImage-qt5 -> Qt5-X11-Image
Console: LinuxConsoleImage -> Console-Image
Additionaly the underscore in the machine name is replaced by a dash
so that the image name is now comprised of 3 elements which themselfes
do not contain an underscore but are separated by underscores.
<machine>_<image type>_version
e.g.:
Apalis_iMX6_LinuxImageV2.7_20170327.tar.bz2
becomes
Apalis-iMX6_LXDE-Image_2.7b2-20170327.tar.bz2
Before using the SPL to setup the DDR we had two U-Boot variants for
Apalis iMX6, one for the commercial and one for the industrial
temperature range modules.
With the SPL that is decided at runtime and one does not need to
run a module specific 'run updateXXX' command.
While at it only differ in PACKAGECONFIG if really needed.
