2017-10-03tdx-image-fstype: use U-Boot with 1kB paddingStefan Agner
Use u-boot-nand.imx which has the 1kB padding expected by boot ROM at the beginning so it can be easily written into raw NAND flash. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03packagegroup-dotnet-core: introduce packagegroup for .NET Core dependenciesStefan Agner
Introduce packagegroup which contains the dependencies required to use the .NET Core runtime. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03curl: use OpenSSL backend by defaultStefan Agner
The .NET Core framework recommends to use OpenSSL backend by default, otherwise not all SSL/TLS functions of the framework are available. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03flash_blk/eth.scr: apalis/colibri_t30: fix conf_blk_offsetMarcel Ziswiler
Do no longer hard-code conf_blk_offset now that we reliably determine it in check_configblock. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03flash_blk/eth.scr: replace loadaddr by fdt_addr_rMarcel Ziswiler
Unfortunately as loadaddr is equal to fdt_addr_r on some modules and equal to kernel_addr_r on others using it together with any of the others may cause issues. Therefore no longer make use of loadaddr and consistently use fdt_addr_r instead. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03flash_blk/eth.scr: fix check_configblockMarcel Ziswiler
The config block check aka check_configblock may fail during update depending on the size of the hardware area boot partition which may lead to the config block not getting properly migrated or updated if still using parts of the legacy update procedure. This patch fixes this by iterating over various sizes. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03flash_blk/eth.scr: apalis/colibri_t30: improve config block migrationMarcel Ziswiler
Improve on the config block locations checked for migration from WinCE/WEC. Now also takes vendor part of the Boot Configuration Table aka BCT into account. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03images: add colibri-imx7-emmcStefan Agner
2017-10-03tdx-image-fstype: make burnflash optionalStefan Agner
We might want not to support burn flash for new machines. Make it optional by checking whether the machine specific directory exists. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03tdx-image-fstype: only set u-boot-nand.imx for colibri-imx7Stefan Agner
The new machine colibri-imx7-emmc uses eMMC and hence the regular u-boot.imx binary. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03images: add colibri-imx6ullMax Krummenacher
Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03tdx-extra.inc: correctly use IMAGE_PREPROCESS_COMMANDMax Krummenacher
Add a trailing ';' to separate from commands appended later. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03tdx-extra: install libunwindStefan Agner
The library libunwind is a dependency for the .NET Core 2.0 runtime. Preinstall it in our standard images. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03fstab: add noatime to rootfs mount flagsStefan Agner
We rely on the init system to remount the root file system read-only, which makes the mount flags for the rootfs in fstab relevant. Since we run on flash drives minimize write cycles by disabling atime by by default. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03lxde-common: add wallpaper for colibri-imx6ullMax Krummenacher
2017-10-03tdx-image-fstype.inc: set PV to Toradex image versionStefan Agner
Use PV variable to define the image version. With that the Tezi image class can use OpenEmbedded variables to get the image version. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03update.sh: fix for dtb filenames containing multiple dotsMax Krummenacher
If a dtb file has more than one dot the current logic fails. e.g. 'device.tree.dtb' will be truncated at the first dot to 'device' while it should be 'device.tree'. Fix by removing awk in favour of letting basename also remove the .dtb extension. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03buildconf/README: fix itMax Krummenacher
The README content was no longer applicable, change it to reflect the current use of the files here. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03recipes-images: images: Use ext4 by default for TK1 modulesSanchayan Maity
Use ext4 by default for TK1 modules. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03recipes-images: images: deploy backports and relevant fwDominik Sliwa
Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03recipes-images: images: Use ext4 by default for iMX6 modulesSanchayan Maity
Use ext4 by default for iMX6 modules. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03recipes-images: apalis-tk1: deploy gstreamer-0.10Dominik Sliwa
Deploy gstreamer-0.10 with nvidia TK1 support plugins. Signed-off-by: Dominik Sliwa <dominik.sliwa@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03recipes-images: imx6: Deploy Ixora V1.1 device tree for Apalis iMX6Sanchayan Maity
Deploy Ixora V1.1 device tree for Apalis iMX6. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-10-03tdx-extra: add bmode-usb to the imageMax Krummenacher
This adds the bmode_usb binary to the i.MX6 rootfs which allows to set some i.MX6 registers so, that on the next reboot (not powercycle) the i.MX6 starts in serial download mode (aka. recovery mode). Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03angstrom-lxde-image: deploy ejectMax Krummenacher
The eject binary is used by the libudisk2. Without it e.g. pcmanfm shows an error message that eject could not be found. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03flash_blk/eth.scr: fix exit condition in the emmc rootfs flashing loopMax Krummenacher
If an image creates a rootfs which is exactly a multiple of 64 MByte then the scripts never detects that the last chunk has been read and 'run update' never completes. Fix that by explicitely setting filesize to 0 when a file read fails. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-10-03genext3fs.sh: fix copying of extened file attributesMarcel Ziswiler
As reported by our customer our current ext3 generation script lacks copying any extended file attributes as well e.g. as required for capabilities or ACLs. Reported-by: Felix Ruess <felix.ruess@roboception.de> Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2017-07-05colibri-imx7: update.sh: log kernel versionColibri-iMX7_LXDE-Image_2.7b3-20170630Colibri-iMX6_LXDE-Image_2.7b3-20170630Colibri-VF_LXDE-Image_2.7b3-20170630Colibri-T30_LXDE-Image_2.7b3-20170630Colibri-T20_LXDE-Image_2.7b3-20170630Apalis-iMX6_LXDE-Image_2.7b3-20170630Apalis-TK1_LXDE-Image_2.7b3-20170630Apalis-T30_LXDE-Image_2.7b3-20170630Max Krummenacher
As the kernel is no longer part of the rootfilesystem, add its version to the version.txt file. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-07-05colibri-imx7: update.sh: use u-boot-nand.imx for recoveryMax Krummenacher
Starting with the following commit tdx-image-fstype.inc: rename U_BOOT_BINARY to UBOOT_BINARY we no longer deploy a symlink 'u-boot.imx' to the u-boot binary. Thus only use u-boot-nand.imx in the update.sh script. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-07-01firefox: disable broken omtc on imx6 and t20/t30 based modulesMarcel Ziswiler
Disable broken OMTC on T20/T30 and iMX6 based modules. Leave it enabled on Apalis TK1 where it seems to work and Colibri iMX7 doing software only rendering anyway. https://wiki.mozilla.org/Platform/GFX/OffMainThreadCompositing Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-30angstrom-lxde-image: add packagegroup-snapd to emmc modulesMarcel Ziswiler
2017-06-30bblayers.conf: add meta-snappyMarcel Ziswiler
2017-06-30tdx-image-fstype.inc: fix building imx7Marcel Ziswiler
2017-06-30tdx-image-fstype.inc: rename U_BOOT_BINARY to UBOOT_BINARYMarcel Ziswiler
As somebody previously decided to rename U_BOOT_BINARY to UBOOT_BINARY unbreak e.g. i.MX 6 Tezi builds by continuing that rename through the various layers: http://git.toradex.com/cgit/meta-toradex-bsp-common.git/commit/?h=morty&id=02f7fdfe5eaca64e0c710cce4d701a609d499e8b Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-30recipes-images: colibri-imx7: deploy Aster device treeSanchayan Maity
Deploy Aster device tree for Colibri iMX7. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30recipes-images: imx6: deploy Aster device treeSanchayan Maity
Deploy Aster device tree for Colibri iMX6. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30recipes-images: colibri-vf: deploy Aster device treeSanchayan Maity
Deploy Aster device tree for Colibri Vybrid. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30run-postinsts_1.0.bbappend: fix FILESEXTRAPATHS_prependMax Krummenacher
Copy/paste error prevented the intended fix to get actually applied. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30systemd: Add a acl packageconfigBhuvanchandra DV
We found that having ACL enabled in systemd on a ubifs adversely affects power cut resilience. Currently systemd is unconditionally enabled in a systemd build. Add a acl packageconfig option, but do not enable it. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30buildconf: do not add extra console for Colibri VFxxStefan Agner
Since commit ef66b5819da4 ("images: use next generation libusbgx USB Gadget library") the gadget library no longer adds a USB CDC ACM device which can be used as a serial console. Remove the extra serial console from local.conf. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30profile: disable systemd color outputStefan Agner
By default systemd utilities use escape sequences to produce colored output. But systemd also uses less as a pager. The less command provided in the Toradex demo images is provided by BusyBox, which does not support color escape sequences. Disable colored output altogether. This makes output of journalctl much more readable. Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2017-06-30update.sh: increase min partition free size & add note about bct changeMarcel Ziswiler
Increase MIN_PARTITION_FREE_SIZE as a provision for customers running NVIDIA JetPack on Apalis TK1. Add a note about having to change apalis-t30_bin/apalis_t30.img.cfg resp. colibri-t30_bin/colibri_t30.img.cfg as well if changing BCT. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-06-30updated release notesMarcel Ziswiler
2017-06-30colibri-pxa: add dummy u-boot update scriptsMarcel Ziswiler
Add dummy U-Boot update scripts to avoid do_imagedeploy build failure. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-04-10angstrom-feed-configs.bbappend: rename trdx to tdxColibri-iMX7_LXDE-Image_2.7b2-20170410Colibri-iMX6_LXDE-Image_2.7b2-20170410Colibri-VF_LXDE-Image_2.7b2-20170410Colibri-T30_LXDE-Image_2.7b2-20170410Colibri-T20_LXDE-Image_2.7b2-20170410Apalis-iMX6_LXDE-Image_2.7b2-20170410Apalis-TK1_LXDE-Image_2.7b2-20170410Apalis-T30_LXDE-Image_2.7b2-20170410Marcel Ziswiler
Last man standing... Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-04-10genext3fs.sh: rename mnt/trdx-rootfs to mnt/tdx-rootfsMarcel Ziswiler
2017-04-10console-tdx-image: renamed from console-trdx-imageMarcel Ziswiler
2017-04-10tdx-image-fstype.inc: renamed from trdx-image-fstype.incMarcel Ziswiler
2017-04-10tdx-extra.inc: renamed from trdx-extra.incMarcel Ziswiler
While at it also reflect changed name of tdx-nv-binaries. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Dominik Sliwa <dominik.sliwa@toradex.com>
2017-04-10tdx-oak-sensors: renamed from trdx-oak-sensorsMarcel Ziswiler
