Move all qt5 relevant stuff where it only gets parsed if meta-qt5 is
available.
As no image uses firefox, stop touching the recipe.
Thus this layer no longer depends on meta-browser.
As no image uses lxde, stop touching the recipes.
Thus this layer no longer depends on meta-lxde.
Related-to: ELB-1284
gstreamer 0.10 support is dropped in oe-core. Thus only install gstreamer 1.0
based components. Note that the TK1 support for gstreamer 1.0 is less
complete.
This is meant to replace the current demo images.
The console and graphical image can be used as a base to create tailored
images to the requirment of a specific use case.
The verification image is meant to test the BSP. It provides the tools
to exercise the CPU / GPU / VPU and the various SOC peripherals.
This provides a bunch of pictures, sound and video files in
different formats.
The recipe is imported from meta-phytec and updated to latest upstream.
https://git.phytec.de/meta-phytec/tree/recipes-devtools/serialtest
Drop PV to denote the image version. Using timestamps in PV causes
various issues. The image PV has not much meaning other than it has
been used by the Tezi image class. Sidestep by using DISTRO_VERSION
directly in the Tezi image class. See also:
http://lists.openembedded.org/pipermail/openembedded-core/2019-November/289765.html
Also only write /etc/issue in the do_rootfs task instead of writing
it in base-files first and then change it in do_rootfs. We sligtly
alter the login banner:
Before:
TDX X11 2.6-snapshot colibri-imx7-emmc ttymxc0
Colibri-iMX7-eMMC_Console-Image 3.0b2.65 20190830
With this change:
TDX X11 0.0.0-dev-20191103+build.12 (zeus) colibri-imx7-emmc ttymxc0
OE dropped the obsolete gstreamer version 0.10.
tinycompress is dual licenced. Specify both alternatives.
OE-core dropped eglinfo, thus remove it from our image recipes.
aa36510ebe eglinfo: remove the recipe
This package was dropped with the move to Qt 5.13.
https://bugreports.qt.io/browse/QTBUG-70510
This is now handled in openembedded-core
meta-openembedded dropped gstreamer 0.10 with commit 010c2f388.
meta-qt5 dropped the recipe.
See https://github.com/meta-qt5/meta-qt5/commit/7cc177d116ad98d0c922f98aa7f02c2cc655c0ec
This allows on newer (>=4.8) kernels to access the new gpio interface
through /dev/gpiochipX character devices.
https://git.kernel.org/pub/scm/libs/libgpiod/libgpiod.git/tree/README
Linux kernels >= 4.8 lack of strong entropy after boot.
This leads to long delay in starting wide class of applications
like ssh, qterminal etc.
Adding entropy helper service fixes this issue.
- add haveged daemon for tegra soc series
- add rng-tools for all other soc series.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
With the move away from angstrom we lost some networking and debugging
tools which angstrom did install by default. Add them again here.
avahi-autoipd ppp procps strace
Add the missing RDEPENDS.
The machine.conf sets the needed u-boot-fw-utils flavour with PREFERRED_PROVIDER.
Thus us the generic u-boot-fw-utils in IMAGE_INSTALL.
This installs the full featured util-linux applications and preferes them
over the busybox variants at the price of a bigger rootfs.
Backport from patch in meta-openembedded ML.
Put the changes we want to make to the default into scripts in /etc/profile.d
and keep the openembedded-core provided /etc/profile.
This keeps the maintained version of /etc/profile rather than having
to manually merge in fixes from the openembedded layer.
Related to: #49287
The Wi-Fi drivers from kernel 4.14 provide all needed features. So don't
bother with backports.
While at it move all Wi-Fi related packages into the Wi-Fi variables.
We want to choose different display managers for different image
recipes. Thus do not inject one through this packagegroup.
The gpio-tool recipe declares all binaries as stripped. The packages qa check
fails now if the binaries are not stripped as follows:
| ERROR: gpio-tool-1.0-r3 do_package: QA Issue: gpio-tool: Files/directories were installed but not shipped in any package:
| /usr/bin/.debug
| /usr/bin/.debug/gpio-tool
| Please set FILES such that these items are packaged. Alternatively if they are unneeded, avoid installing them or delete them within do_install.
| gpio-tool: 2 installed and not shipped files. [installed-vs-shipped]
The service expects the script to return (Type=forking). Change the script
so that the wayland app is started in the background.
While at it configure the service to restart the application.
Include a launcher for the weston-terminal if built for wayland/xwayland.
Rework that the X11 launcher is only used if not using xwayland.
This tries to start a wayland application after weston got started.
Create a copy of wayland-terminal-launch_1.0.bb with the variables
changed according to your needs.
RDEPENDS is set by bitbake to an empty string, so using ?= is pointless.
This reduces the binary from 400 to 4k.
packagegroup-base-extended is installed by inheriting core-image.
packagegroup-basic installs dropbear, openssh-sftp, openssh-sftp-server
dropbear can act as an scp client, drop openssh-scp
Define the string used for each machine in the machine configuration
rather than doing this in each image recipe.
Fallback to machine configuration name if not defined.
We used to do this in the dropped tdx-image-fstype.inc.
