path: root/buildconf
2016-06-30buildconf/bblayers.conf: integrate watatuki's meta-jetson-tk1Marcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-14local.conf: add colibri-imx7Stefan Agner
Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-03-14bblayers.conf: angstrom now depends on meta-qt5Max Krummenacher
meta-angstrom unconditionally includes stuff from meta-qt5. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com> Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-03-14local.conf: adopt DISTRO to jethroMax Krummenacher
2016-03-14bblayers.conf: drop unused layerMax Krummenacher
2015-11-04local.conf: enable USB CDC ACM console for Vybrid based devicesStefan Agner
The Vybrid devices use a composite gadget device by default which offers a serial connection over USB on the USB peripheral port. This enables a serial console on that tty.
2015-11-03local.conf: add Toradex source mirror as pre-mirrorStefan Agner
To download the sources mirrored on sources.toradex.com add the Toradex mirror as pre-mirror.
2015-10-30local.conf: List Toradex machines explicitlyStefan Agner
List all Toradex machines explicitly while still selecting Colibri T20 by default. Move selection of Qemu targets after our machines.
2015-10-30build: add list of Toradex imagesStefan Agner
2015-08-18local.conf: adopt DISTRO to fido and drop PREFERRED_PROVIDER_glibcMarcel Ziswiler
2015-05-12local.conf: update PREFERRED_PROVIDER for libcStefan Agner
eglibc has been superseded by glibc. Update the PREFERRED_PROVIDER to use set the preferred provider of glibc.
2015-05-12bblayers: add meta-python which is required for dizzy nowMax Krummenacher
2015-05-12local.conf: update the distro version to its dizzy valueMax Krummenacher
2014-08-04local.conf: update sample local.confMax Krummenacher
2014-04-04bblayers.conf: add new required layers to defaultsMax Krummenacher
2014-04-01local.conf: update default local.confMax Krummenacher
- include package-management metadata in image - update distro to angstrom-v2013.12
2013-10-16build: fix cp destination in sample scriptMax Krummenacher
2013-10-16build: add a sample script for setting up the environmentMax Krummenacher
2013-10-16local.conf: set sensible defaultsMax Krummenacher
2013-10-16bblayers: remove unneeded layerMax Krummenacher
2013-10-16bblayers.conf: change path to meta-lxdeMax Krummenacher
2013-10-10conf: update sample configurationMax Krummenacher
2013-09-22local.conf template: add inclusion of license informationMax Krummenacher
2012-10-18config changes due to oe-core updateMax Krummenacher
2012-08-15L4T R15, oe-core Image V2.0Beta1Max Krummenacher
2012-07-19build configuration filesMax Krummenacher
